  4. Lastfluss, Energie animierte Gif
vistemplate
69 Beiträge 15 Kommentatoren 19.3k Aufrufe 22 Beobachtet
  • liv-in-skyL liv-in-sky
    @wiesel-1
    der reverse hat keine wirkung - ist wohl ein überbleibsel meiner tests
    was aber funktioniert ist den stroke-dashoffset ins minus zu ändern
    [{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"<svg width=\"900\" height=\"210\">\n\t\t<path class=\"loading101\" d=\"M50 0 L50 200 L250 200 L250 100 L400 100 L400 200 L500 200 L500 55 \" />\n\t\t  \n        \n\t\t</svg>\n\t\t\n\t\t\n\t\t<style>\n\t\t\n\t\t.loading101 {\n\tfill: none;\n\tstroke: lightblue;\n\t\tborder-radius: 50%;\n\tstroke-width: 5;\n\tstroke-dasharray: 15 5;\n\tanimation: strokeAni .7s infinite linear;\n}\n\n.inner {\n\tstroke: #c32e04;\n  animation-direction: reverse;\n\t\n}\n\n@keyframes strokeAni {\n\t0% {\n\t\tstroke-dashoffset: 40;\n\t}\n\t100% {\n\t\tstroke-dashoffset: 0;\n\t}\n}\n\n\t\t\n\t\t</style>"},"style":{"left":"523px","top":"880px","width":"530px","height":"234px","transform":"rotate(180deg)"},"widgetSet":"basic"}]
    W Offline
    W Offline
    Wiesel 1
    schrieb am zuletzt editiert von Wiesel 1
    @liv-in-sky
    Danke für den Tip. Wenn ich das Widget einfüge und das Vorzeichen bei stroke-dashoffset setze, fangen alle meine Leitungen an Rückwärts zu laufen ;-)... Ich hab ein kleines Heizungssystem damit ausgerüstet. Also Vor und Rücklauf. Und diese sollen entsprechend fließen. Die Loadings sind bereits mit einzelnen Nr. entkoppelt. Erstaunlich, das dein Loading auch meine anderen bereits bestehenden Systeme mit ändert.
    Ich teste weiter. Ist auf jeden Fall ein Ansatz. Alternativ muss ich die einzelnen Koordinatenpunkte rückwärts anordnen ;-(...
    • W Wiesel 1
      @liv-in-sky
      liv-in-skyL Offline
      liv-in-skyL Offline
      @wiesel-1 du musst das strokeani auch umbenennen
      Damit es nur für dieses Widget gültig ist
      W M 2 Antworten Letzte Antwort
        W Offline
        W Offline
        Wiesel 1
        @liv-in-sky
        Spitze!!! Genau das war es. 2x strokeani mit eigener Nummer gekennzeichnet und die Befehlsketten sind entkoppelt. Jetzt visualisiert jeder Strang so wie er soll. Die Striche gefallen mir dabei sogar noch besser wie die Pfeile.
        Viele Dank für die Hilfe!
          @wiesel-1
          mguenther
          @liv-in-sky
          bekommt man es auch irgendwie hin, dass z.B. ein Farbverlauf in der Linie noch hinzugefügt werden kann?
          Beispiel:
          die gestrichelte Linie startet mit Rot und endet irgendwann mit Blau. Ich habe im Internet mir SVG angeschaut, bin aber noch nicht dahintergekommen. In einem Rechteck ist ein Farbverlauf wohl möglich.
            mguenther
            @liv-in-sky
            Ich ergänze gleich meine 2. Frage. Ich bekomme es einfach nicht hin. Es gibt ja neben der Linie auch andere geometrische Formen.
            Wie könnte ich denn z.B. die Reihenfolge Linie, Halbkreis, Linie, Halbkreis, Linie... oder Linie, Ellipse, Halbkreis, Ellipse... erzeugen?
            Worauf möchte ich hinaus? Im Prinzip suche ich etwas wie so:
            • M mguenther
              @liv-in-sky
              liv-in-skyL Offline
              liv-in-skyL Offline
              @mguenther sorry - aber so tief bin ich da nicht eingestiegen - wenn du eine lösung gefunden hast - gerne hier posten
                mguenther
                @liv-in-sky sagte in Lastfluss, Energie animierte Gif:
                alles gut, danke dir - wie immer. Dachte, du schüttelst das so einfach aus dem Ärmel - ich teste weiter...
                  mguenther
                  Es gibt ein paar Tools im Internet, sehe ich gerade und das erste (https://boxy-svg.com), was ich genutzt hatte, erzeugt sowas:
                  Der Export kostet halt etwas, ich muss mal sehen, ob ich eine kostenlose Variante (Testversion o.ä.) hinbekomme. Muss dann nur noch sehen, wie ich das in das Widget integriere
                  • M mguenther
                    liv-in-skyL Offline
                    liv-in-skyL Offline
                    @mguenther
                    hab ein wenig gespielt
                    das ist rausgekommen - nehme aber an, du hast schon was gefunden:
                    <svg width="900" height="610" >
                       	<defs>
                       <linearGradient id='MyGradient1011' x1="0%" y1="0%" x2="0%" y2="100%">
                         <stop offset='0%' stop-color='red' />
                         <stop offset='100%' stop-color=' lightblue' />
                       </linearGradient>
                           </defs>
                           <g transform="scale(1)" style="stroke:url(#MyGradient1011) " >
                            <path class="loading1011" d="M 180,120 A 10,10 0 0,0 180,180 l280 0
                                                        A 10,10 0 1,1 460,240 l-280 0
                                                        A 10,10 0 0,0 180,300 l280 0
                                                        A 10,10 0 1,1 460,360 l-280 0"/>
                           </g>
                       	</svg>
                       	<style>
                       	.loading1011 {
                       fill: none;
                       	border-radius: 50%;
                       stroke-width: 5;
                    .inner {
                       stroke: #c32e04;
                       0% {
                       	stroke-dashoffset: -40;
                       100% {
                       	</style>
                    oder:
                    <svg width="600" height="510" >
                       <defs>
                       <linearGradient id='MyGradientFull' x1="0%" y1="0%" x2="0%" y2="100%">
                       </linearGradient>
                        </defs>
                        <g transform="scale(1)" >
                           <g  >
                            <path  class="loadingFull" d="M200,50  L200,95
                                                           A28,28 0 0,1 180,120
                                                           A10,10 0 0,0 180,180
                                                           A10,10 0 0,0 180,180 l280 0
                                                           A10,10 0 1,1 460,240 l-280 0
                                                           A10,10 0 0,0 180,300 l280 0
                                                           A10,10 0 1,1 460,360 l-320 0
                                fill= "none" stroke-width="8" stroke-dasharray="15 5"
                                stroke="url(#MyGradientFull)"
                             <path class="loadingFull" d="M140,360 A28,28 0 0,1 110,330 l0 -280
                               " fill= "none" stroke-width="8" stroke-dasharray="15 5" stroke="lightblue"
                           </g>
                           <g>
                       </g>
                       </g> </svg>
                       	<style>
                       	.loadingFull {
                        animation: strokeFull .7s infinite linear;
                    @keyframes strokeFull {
                       0% {
                       100% {
                      </style>
                    können beide verkleinert werden
                    M M 2 Antworten Letzte Antwort
                      @mguenther
                         	<defs>
                         </linearGradient>
                             </defs>
                             </g>
                         	</svg>
                         	<style>
                         	.loading1011 {
                         fill: none;
                         	border-radius: 50%;
                         stroke-width: 5;
                      .inner {
                         stroke: #c32e04;
                         0% {
                         100% {
                         	</style>
                      oder:
                         <defs>
                         </linearGradient>
                          </defs>
                             <g  >
                             </g>
                             <g>
                         </g>
                         </g> </svg>
                         	<style>
                         	.loadingFull {
                         0% {
                         100% {
                        </style>
                      mguenther
                      @liv-in-sky
                      boah - ich werd bekloppt... Ich war unterwegs und wollte mich jetzt damit auseinandersetzen.
                      Danke dir - wie immer. Ich schau es mir an und arbeite mich rein...
                      • M mguenther
                        @liv-in-sky
                        liv-in-skyL Offline
                        liv-in-skyL Offline
                        @mguenther
                        diese A commands sind ein "gefriggel" :-)
                          @mguenther
                          mguenther
                          schrieb am zuletzt editiert von mguenther
                          @liv-in-sky
                          "Gefriggel hinbekommen... hab nur ein Problem... Der Farbverlauf passt nicht. Der Verlauf ist quasi über das gesamte Bild von oben nach unten bzw. links nach rechts. Daher hast du ja auch beim 2. Bild links die Linie ergänzt.
                          Meine Koordinaten wären eigentlich so gewesen:
                          M 380 215
                          L 180 215
                          L 10 15
                          A 2.0 1 0 1 1 25 10
                          L 200 180
                          A 2.0 1 0 0 0 260 170
                          L 50 15
                          A 2.0 1 0 1 1 70 10
                          L 365 200
                          L380 200
                          Dann passiert aber folgendes:
                          Da noch ne Idee, wie in der Linie der Farbverlauf erfolgt? Außer dass ich meine Geometrie um 90° drehen müsste...
                          liv-in-skyL 3 Antworten Letzte Antwort
                          • M mguenther
                            @liv-in-sky
                            M 380 215
                            L 180 215
                            L 10 15
                            A 2.0 1 0 1 1 25 10
                            L 200 180
                            L 50 15
                            A 2.0 1 0 1 1 70 10
                            L 365 200
                            L380 200
                            liv-in-skyL Offline
                            liv-in-skyL Offline
                            @mguenther
                            da müßte eigentlich der farbverlauf von links nach rechts laufen - evtl musst du mehrere pfade machen - der untere quere"strang" müßte dann ein eigenständer pfad (in blau) sein - oder ?
                            • M mguenther
                              @liv-in-sky
                              M 380 215
                              L 180 215
                              L 10 15
                              A 2.0 1 0 1 1 25 10
                              L 200 180
                              L 50 15
                              A 2.0 1 0 1 1 70 10
                              L 365 200
                              L380 200
                              liv-in-skyL Offline
                              liv-in-skyL Offline
                              @mguenther
                              hier z.b. ein vertikaler verlauf https://www.w3schools.com/graphics/svg_grad_linear.asp
                                @mguenther
                                mguenther
                                @liv-in-sky
                                so sieht es aktuell aus (unten müsste rot sein)
                                Dein Link mit dem Farbverlauf schau ich mir mal an. Problem ist - es ist ja nicht ein reiner Verlauf von rechts nach links oder von oben nach unten - ich muss mir das mal anschauen...
                                • M mguenther
                                  @liv-in-sky
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  @mguenther habe ich verstanden - da muss ich erstmal nachsehen, was mit den linear grdienten machbar ist denke das könnte damit gehen https://developer.mozilla.org/en-US/docs/Web/SVG/Tutorial/Gradients#center_and_focal_point
                                    mguenther
                                    @liv-in-sky
                                    ah, super - über den ersten Link mit dem gradient Angaben in Prozent lässt es sich nicht darstellen. Zumindest komme ich nach kurzem Nachdenken nicht drauf. Wenn du bei deinem 2. Link was findest - wäre spitze. Ich schau mir das auch an.
                                    Alternativ schau ich mir mal an, ob ich noch die Form etwas anders darstellen kann. Dann könnte es auch mit den Prozentangaben klappen...
                                    • M mguenther
                                      @liv-in-sky
                                      liv-in-skyL Offline
                                      liv-in-skyL Offline
                                      @mguenther
                                      evtl mit dieser seite: http://thenewcode.com/1155/Understanding-Linear-SVG-Gradients gleich das bild mit dem blau gelb - wenn man das irgendwie hindreht - und einen extra pfad für die untere linie macht - werd heute nicht mehr viel zeit haben - eher nächste woche mal
                                        @mguenther
                                        mguenther
                                        @liv-in-sky
                                        danke dir - aber das ist doch der gleiche Ansatz - oder?
                                        A diagonal gradient will therefore be created by setting y2 to a value of 100%:
                                        <linearGradient id="testbed4" y2="100%">
                                            <stop stop-color="yellow" offset="0" />
                                            <stop stop-color="blue" offset="0.5" />
                                            <stop stop-color="black" offset="1" />
                                        </linearGradient>
                                        Note that this does not create a 45° gradient, as the values are relative to the dimensions of the element
                                        • M mguenther
                                          @liv-in-sky
                                          M 380 215
                                          L 180 215
                                          L 10 15
                                          A 2.0 1 0 1 1 25 10
                                          L 200 180
                                          L 50 15
                                          A 2.0 1 0 1 1 70 10
                                          L 365 200
                                          L380 200
                                          liv-in-skyL Offline
                                          liv-in-skyL Offline
                                          @mguenther
                                          was ist damit
                                          besser bekomm ich es im moment nicht hin
                                          <svg width="100%" height="100%" >
                                          	<defs>
                                              <linearGradient id="MyGradientFull1" x1="0%" y1="83%" x2="100%" y2="17%">
                                                   <stop offset="35%" style="stop-color:rgb(255,0,14);stop-opacity:1.00" />
                                                    <stop offset="45%" style="stop-color:rgb(130,195,238);stop-opacity:1.00" />
                                                    <stop offset="50%" style="stop-color:rgb(40,118,166);stop-opacity:1.00" />
                                                    <stop offset="60%" style="stop-color:rgb(7,41,219);stop-opacity:1.00" />
                                              </linearGradient>
                                            </defs>
                                                  <g  >
                                          	<path class="loadingFull" d="M380,215 L180 215
                                                      " fill= "none" stroke-width="8" stroke-dasharray="15 5" stroke="red"></path>
                                                   <path  class="loadingFull1" d="M 180 215
                                          L 10 15
                                          A 2.0 1 0 1 1 25 10
                                          L 200 180
                                          L 50 15
                                          A 2.0 1 0 1 1 70 10
                                          L 365 200
                                          L380 200
                                                       stroke="url(#MyGradientFull1)"
                                                  </g>
                                                  <g>
                                              </g>
                                              </g> </svg>
                                          		<style>
                                          		.loadingFull1 {
                                          	 animation: strokeFull1 .7s infinite linear;
                                          @keyframes strokeFull1 {
                                          	0% {
                                          	100% {
                                             </style>
                                          [/s]
