  4. JavaScript
  5. Daten jede Stunde in JSON schreiben
4 Beiträge 2 Kommentatoren 481 Aufrufe 2 Beobachtet
  • Chris76eC Offline
    Chris76eC Offline
    Chris76e
    schrieb am zuletzt editiert von Chris76e
    möchte bestimmte Daten zur jeden volle Stunde in ein JSON schreiben um sie später darstellen zukönnen, ähnlich wie auf Awekas.
    ist das so okay, oder gibt es da eine besser Lösung?
    // Reference the state objects for temperature, air pressure, and wind speed
    var tempState = "javascript.0.Wetterstation.Aussentemperatur";
    var pressureState = "javascript.0.Wetterstation.Druck_absolut";
    var windState = "javascript.0.Wetterstation.Wind";
    var weatherStatState = "0_userdata.0.JSON.WetterStatistikJedeStunde";
    // Define a function to collect data and write to the weather statistics state
    function collectData() {
        // Get the current date and time
        var date = new Date();
        var dateString = date.toLocaleDateString();
        var timeString = date.toLocaleTimeString();
        // Get the values of temperature, air pressure, and wind speed
        var temp = getState(tempState).val;
        var pressure = getState(pressureState).val;
        var wind = getState(windState).val;
        // Get the current value of the weather statistics state
        var currentData = getState(weatherStatState).val || '[]';
        // Convert the current data to an array
        currentData = JSON.parse(currentData);
        // Add the new data to the existing data
        currentData.push({
            date: dateString,
            time: timeString,
            temperature: temp,
            airPressure: pressure,
            windSpeed: wind
        // Write the updated data to the weather statistics state
        setState(weatherStatState, JSON.stringify(currentData));
    // Schedule the collectData function to run every hour
    schedule("0 * * * *", collectData);
    JSON
        "date": "11.2.2023",
        "time": "06:00:00",
        "temperature": 5.72,
        "airPressure": 1028.82,
        "windSpeed": 1.44
        "time": "07:00:00",
        "temperature": 5.61,
        "airPressure": 1028.61,
        "windSpeed": 0
        "time": "08:00:00",
        "airPressure": 1028.72,
        "windSpeed": 1.44
        "time": "09:00:00",
        "temperature": 5.88,
        "airPressure": 1029.33,
        "windSpeed": 0
        "time": "10:00:00",
        "temperature": 6.22,
        "airPressure": 1029.73,
        "windSpeed": 0.32
        "time": "11:00:00",
        "temperature": 6.5,
        "airPressure": 1030.24,
        "windSpeed": 1.12
    Awekas
    • Chris76eC Chris76e
          currentData.push({
              date: dateString,
              time: timeString,
              temperature: temp,
              windSpeed: wind
      JSON
          "time": "06:00:00",
          "windSpeed": 1.44
          "time": "07:00:00",
          "windSpeed": 0
          "time": "08:00:00",
          "windSpeed": 1.44
          "time": "09:00:00",
          "windSpeed": 0
          "time": "10:00:00",
          "windSpeed": 0.32
          "time": "11:00:00",
          "temperature": 6.5,
          "windSpeed": 1.12
      Awekas
      Ahnungsbefreit
      @chris76e schau mal hier, da habe ich eine Vorlage für solche Aufgaben gepostet. Dabei wird nicht per CRON per getriggert, sondern auf jede Aktualisierung des JSON.
      https://forum.iobroker.net/topic/62779/vorlage-script-json-datenpunkte-mit-sync?_=1676114744352
      Chris76eC 1 Antwort Letzte Antwort
      • A Ahnungsbefreit
        Chris76eC Offline
        Chris76eC Offline
        Chris76e
        @ahnungsbefreit
        wenn ich dein script richtig verstehe, ist es doch was anderes. Ich möchte aus verschiedene DP stündlich ein JSON erstellen damit ich in meiner VIS eine Tabelle darstellen kann und diese nach Datum filtern.
          @ahnungsbefreit
          Ahnungsbefreit
          @chris76e sorry, falsch verstanden. Das kommt davon, wenn man schnell am Handy liest und dabei mit der Enkelin spielt 🙄
