  4. [Neuer Adapter] smartstate
34 Beiträge 5 Kommentatoren 5.0k Aufrufe 17 Beobachtet
  • BananaJoeB BananaJoe
    @chrid
    2023-02-07 19:22:36.514  - error: smartstate.0 (1886549) uncaught exception: id is not defined
    2023-02-07 19:22:36.518  - error: smartstate.0 (1886549) ReferenceError: id is not defined
        at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.smartstate/main.js:568:2)
        at Module._compile (node:internal/modules/cjs/loader:1165:14)
        at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
        at Module.load (node:internal/modules/cjs/loader:1043:32)
        at Function.Module._load (node:internal/modules/cjs/loader:878:12)
        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
        at node:internal/main/run_main_module:22:47
    2023-02-07 19:22:36.519  - error: smartstate.0 (1886549) id is not defined
    2023-02-07 19:22:37.022  - warn: smartstate.0 (1886549) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-02-07 19:22:38.793  - warn: smartstate.0 (1886549) Unable to increase LUA script timeout: Connection is closed.
    2023-02-07 19:22:39.071  - error: host.iobroker instance system.adapter.smartstate.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2023-02-07 19:22:39.071  - info: host.iobroker Restart adapter system.adapter.smartstate.0 because enabled
    2023-02-07 19:22:48.824  - info: admin.2 (1701438) ==> Connected system.user.admin from 192.168.1.32
    2023-02-07 19:23:09.381  - info: host.iobroker instance system.adapter.smartstate.0 started with pid 1887274
    2023-02-07 19:23:10.598  - error: smartstate.0 (1887274) uncaught exception: id is not defined
    2023-02-07 19:23:10.601  - error: smartstate.0 (1887274) ReferenceError: id is not defined
    2023-02-07 19:23:10.602  - error: smartstate.0 (1887274) id is not defined
    2023-02-07 19:23:11.110  - warn: smartstate.0 (1887274) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-02-07 19:23:11.775  - error: smartstate.0 (1887274) uncaught exception: Connection is closed.
    2023-02-07 19:23:11.777  - error: smartstate.0 (1887274) Error: Connection is closed.
        at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
        at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
        at Object.onceWrapper (node:events:628:26)
        at Socket.emit (node:events:513:28)
        at TCP.<anonymous> (node:net:301:12)
    2023-02-07 19:23:11.781  - error: smartstate.0 (1887274) Connection is closed.
    2023-02-07 19:23:12.261  - error: host.iobroker instance system.adapter.smartstate.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2023-02-07 19:23:12.263  - info: host.iobroker Restart adapter system.adapter.smartstate.0 because enabled
    2023-02-07 19:23:42.528  - info: host.iobroker instance system.adapter.smartstate.0 started with pid 1887422
    2023-02-07 19:23:43.517  - error: smartstate.0 (1887422) uncaught exception: id is not defined
    2023-02-07 19:23:43.519  - error: smartstate.0 (1887422) ReferenceError: id is not defined
    2023-02-07 19:23:43.520  - error: smartstate.0 (1887422) id is not defined
    2023-02-07 19:23:44.022  - warn: smartstate.0 (1887422) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-02-07 19:23:44.716  - error: host.iobroker instance system.adapter.smartstate.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2023-02-07 19:23:44.717  - info: host.iobroker Restart adapter system.adapter.smartstate.0 because enabled
    2023-02-07 19:23:44.717  - warn: host.iobroker Do not restart adapter system.adapter.smartstate.0 because restart loop detected
    BananaJoeB Online
    BananaJoeB Online
    BananaJoe
    @bananajoe
    ok, einmal gelöscht und neu anlegen ...
    Immer noch Fehler:
    2023-02-07 19:26:00.559  - error: smartstate.0 (1888687) id is not defined
    2023-02-07 19:26:01.061  - warn: smartstate.0 (1888687) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-02-07 19:26:01.744  - error: host.iobroker instance system.adapter.smartstate.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2023-02-07 19:26:01.746  - info: host.iobroker Do not restart adapter system.adapter.smartstate.0 because disabled or deleted
    2023-02-07 19:27:44.398  - info: admin.2 (1701438) <== Disconnect system.user.admin from 192.168.1.32
    2023-02-07 19:28:01.423  - info: host.iobroker "system.adapter.smartstate.0" enabled
    2023-02-07 19:28:02.529  - info: host.iobroker instance system.adapter.smartstate.0 started with pid 1890004
    2023-02-07 19:28:03.725  - error: smartstate.0 (1890004) uncaught exception: id is not defined
    2023-02-07 19:28:03.727  - error: smartstate.0 (1890004) ReferenceError: id is not defined
    C 1 Antwort Letzte Antwort
    • C ChriD
      @bananajoe
      Danke für die Rückmeldung!
      Im Hintergrund habe ich grundsätzlich dafür schon eine Funktion eingebaut dass man den Rückgabewert des oder der states (pattern) anpassen kann. D.h du würdest dann in der Pattern Zeile noch ein Feld haben wo du dann einfach "value = !value" reinschreiben könntest. Das ist halt aber wirklich ein Feld wo man im Endeffekt validen javascript code reinschreiben müsste.
      Oder hättest du eine Idee wie man das schöner bzw. Userfreundlicher lösen könnte?
      OliverIOO Offline
      OliverIOO Offline
      OliverIO
      @chrid sagte in [Neuer Adapter] smartstate:
      Als Ankreuzfeld in den Einstellungen. bspw Wert negieren.
      Du müsstest ja durch das Pattern sowieso ermitteln wieviel Datenpunkte selektiert werden.
      Wenn von 10 Geräten 4 an sind, dann ergibt ohne Kreuz das Ergebnis 4
      und mit ankreuzen 10-4 = 6
      Meine Adapter und Widgets
      Links im Profil
      • wendy2702W Online
        wendy2702W Online
        Adapter Installiert und so eingestellt:
        Dann kommt im Object nur das:
          @bananajoe
          Immer noch Fehler:
          ChriD
          @bananajoe
          Bitte nochmal adapter neu installieren, dann ist der id Fehler weg
          • wendy2702W wendy2702
            ChriD
            @wendy2702
            Danke für die Rückmeldung. Bei mir siehts mit den gleichen Einstellungen so aus:
            Unter welchen Objekten liegen den die "Fenster" states?
            Sind die unter "devices"? oder "channels"?
            Magst du mir einen Screenshot vom Tree posten?
            So in etwa, nur halt mit den Fensterkontakten:
            wendy2702W 2 Antworten Letzte Antwort
            • C ChriD
              @wendy2702
              wendy2702W Online
              wendy2702W Online
              @chrid bin auf Dienstreise. Eventuell heute Abend oder morgen Abend kann ich den liefern.
              • C ChriD
                @bananajoe
                BananaJoeB Online
                BananaJoeB Online
                BananaJoe
                @bananajoe
                ok, Funktioniert jetzt.
                Das hier liefert mir 13
                als Zahl im Datenpunkt.
                Das hier liefert mir 26 ...
                Im JSON sind dann die 13 Geräte die nicht available sind, also ok
                • C ChriD
                  @wendy2702
                  wendy2702W Online
                  wendy2702W Online
                  @chrid Hi,
                  das sind Aliase:
                  Denke mir ist aber gerade aufgefallen warum es so sein koennte. Vermutlich liegt es an dern verschiedenen Zustaenden.
                  Werde mal Sensoren mit den gleichen Zustaenden einstellen.
                    @chrid Hi,
                    das sind Aliase:
                    ChriD
                    schrieb am zuletzt editiert von ChriD
                    @wendy2702
                    Nein, das liegt daran das du kein "device" als parent für deine aliase hast und deine aliase eigentlich ja das device sind. Bitte benutze das stateObject stattdessen. Das device Object ist nur befüllt wenn es ein parent device gibt im object tree.
                    Das stateObject ist dann genau das jeweilige alias objekt
                    Einfach deviceObject mit stateObject austauschen
                    • C ChriD
                      @wendy2702
                      wendy2702W Online
                      wendy2702W Online
                      @chrid OK.
                      Teste ich wenn ich wieder zu Hause bin.
                      EDIT: OK die Fenster werden jetzt angezeigt. Allerdings steht da ja jetzt der komplette Name des Objekts drin:
                      alias.0.Fenster.Fenster_Schlafzimmer;alias.0.Fenster.Fenster_Wohnzimmer
                      Hier wäre es natürlich Wünschenswert wenn nur der Name: "Schlafzimmer, Wohnzimmer" usw. stehen würde.
                        @chrid OK.
                        ChriD
                        @wendy2702
                        Dann kannst du das einfach ändern indem du den code in der Funktion anpasst auf:
                        return params.stateObject.common.name
                        • C ChriD
                          @wendy2702
                          wendy2702W Online
                          wendy2702W Online
                          @wendy2702
                          OK.
                          Ich frage mal ganz frech: Kann man, sprich du, das nicht direkt in den Adapter einbauen?
                            @wendy2702
                            OK.
                            ChriD
                            @wendy2702
                            Vielleicht habe ich mich etwas unklar ausgedrückt, aber du kannst das einfach hier ganz einfach an der Oberfläche ändern:
                            Ich weiß nicht recht was ich da anpassen sollte? Das standardmäßig der "common.name" anstatt die "id" benutzt wird? Andere User möchten vll. aber die Id als Standard und nicht den Namen. :man-shrugging:
                            Ist das so ein großes Problem?
                            • C ChriD
                              @wendy2702
                              wendy2702W Online
                              wendy2702W Online
                              @wendy2702
                              Mir ist schon klar das ich das an der stelle ändern muss.
                              Allerdings würde ich persönlich bei einem Adapter bevorzugen wenn man das entweder per Drop down oder checkbox selektieren könnte.
                              Was man allerdings mit der ID will/anfangen kann weiss ich eh nicht.
