  4. [Neuer Adapter] radar-trap
255 Beiträge 27 Kommentatoren 72.1k Aufrufe 22 Beobachtet
  • carsten04C carsten04
    @oli Gibt es noch weitere Fehlermeldungen in der dev-Konsole? Bitte einmal bei geöffneter dev-Konsole mit F5 neu starten und schauen ob mehr Infos eingehen.
    O Online
    O Online
    Oli
    @carsten04
    das ist alles was an Fehlermeldungen im VIS Editor kommt
    VM417:410 Uncaught (in promise) SyntaxError: Expected double-quoted property name in JSON at position 247968
       at JSON.parse (<anonymous>)
       at getTranslation (info.js:13:47)
    getTranslation @ info.js:13
    await in getTranslation (async)
    (anonym) @ info.js:6
    jquery-1.11.2.min.js:4          GET http://192.168.2.120:8082/vis/adapter/rssfeed/words.js 404 (Not Found)
    send @ jquery-1.11.2.min.js:4
    ajax @ jquery-1.11.2.min.js:4
    m.<computed> @ jquery-1.11.2.min.js:4
    (anonym) @ rssfeed.js:15
    vis-editor.css:1          GET http://192.168.2.120:8082/vis/icon/dimmer.png 404 (Not Found)
    visEditInspect.js:2276 Uncaught TypeError: Cannot read properties of undefined (reading 'widgets')
       at HTMLDivElement.<anonymous> (visEditInspect.js:2276:46)
       at Function.each (jquery-1.11.2.min.js:2:2975)
       at m.fn.init.each (jquery-1.11.2.min.js:2:835)
       at Object.inspectWidgets (visEditInspect.js:2269:49)
       at vis.js:3630:29
       at r.<anonymous> (conn.js:936:45)
       at r.onack (index.js:83:1)
       at r.onpacket (index.js:83:1)
       at r.<anonymous> (index.js:83:1)
       at r.emit (index.js:83:1)
       at r.ondecoded (index.js:83:1)
       at a.<anonymous> (index.js:83:1)
       at a.add (index.js:83:1)
       at r.ondata (index.js:83:1)
       at r.onPacket (index.js:83:1)
       at r.onData (index.js:83:1)
       at ws.onmessage (index.js:83:1)
    (anonym) @ visEditInspect.js:2276
    each @ jquery-1.11.2.min.js:2
    inspectWidgets @ visEditInspect.js:2269
    (anonym) @ vis.js:3630
    (anonym) @ conn.js:936
    r.onack @ index.js:83
    r.onpacket @ index.js:83
    (anonym) @ index.js:83
    r.emit @ index.js:83
    r.ondecoded @ index.js:83
    a.add @ index.js:83
    r.ondata @ index.js:83
    r.onPacket @ index.js:83
    r.onData @ index.js:83
    ws.onmessage @ index.js:83
    Hier noch Warnungen aus dem VIS Editor
    Entwicklertools konnten Quellzuordnung nicht laden: Inhalt für http://192.168.2.120:8082/lib/js/socket.io.js.map: HTTP-Fehler: Statuscode 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE konnte nicht geladen werden
    Entwicklertools konnten Quellzuordnung nicht laden: Inhalt für http://192.168.2.120:8082/vis/widgets/radar-trap2/js/mapbox/mapbox-gl-csp.js.map: HTTP-Fehler: Statuscode 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE konnte nicht geladen werden
    Oliver
    • O oxident
      @oli Hmm, schätze, wir sitzen im selben Boot.
      Habe diverse Dinge bereits versucht und verschiedene Kombinationen durch. Bisher leider noch kein Erfolg. Habe radar-trap2 daher erstmal wieder komplett deinstalliert (dann lief's sofort wieder) und werde demnächst mal tiefer graben.
      O Online
      O Online
      Oli
      @oxident
      ja leider, halte mich bitte auf dem laufenden, ob du eine Lösung gefunden hast
      Oliver
      carsten04C 1 Antwort Letzte Antwort
      • O Oli
        @oxident
        carsten04C Offline
        carsten04C Offline
        carsten04
        @oli Läuft Dein Admin hinter einem Proxy, oder hast Du im Admin https aktiviert? Das funktioniert nämlich noch nicht.
        O 1 Antwort Letzte Antwort
          O Online
          O Online
          Oli
          @carsten04
          mein ioBroker läuft als Docker auf einer Qnap, mit Proxy kenne ich mich nicht aus, also gehe ich davon aus, dass dies nicht der Fall ist. Hier mal meine Admin Adapter Einstellungen
          Oliver
          • O Oli
            @carsten04
            carsten04C Offline
            carsten04C Offline
            carsten04
            @oli Kannst Du bitte mal neu von GitHub installieren und vorher alles sauber deinstallieren. Es fehlten die map-Dateien und es kann sein, dass es daran gelegen hat. Danke!
              O Online
              O Online
              Oli
              @carsten04
              Was verstehst du unter alles deinstallieren?
              Bis jetzt bin ich immer auf die Adapter ansichten und habe dort den Adapter deinstalliert
              Oliver
              • O Oli
                @carsten04
                carsten04C Offline
                carsten04C Offline
                carsten04
                @oli Ja genau. Du kannst auch noch vorher die Instanz löschen. Wichtig ist, dass im Objektbaum alles weg ist.
                  O Online
                  O Online
                  Oli
                  @carsten04
                  habe jetzt den Adapter neu installiert, aber leider bringt er mir immer noch Verbindungsfehler im VIS Editor
                  Fehlermeldung
                  VM6944:410 Uncaught (in promise) SyntaxError: Expected double-quoted property name in JSON at position 247968
                  Warnmeldung
                  Einstellungen Web-Adapter
                  Schade finde den Adapter echt genial von den Infos
                  Oliver
                  • O Oli
                    @carsten04
                    Fehlermeldung
                    Warnmeldung
                    carsten04C Offline
                    carsten04C Offline
                    carsten04
                    schrieb am zuletzt editiert von carsten04
                    @oli Klappt denn das Anlegen von Routen und die Kartendarstellung im Adapter-Admin fehlerfrei? Eigentlich ist meine Umgebung fast identisch zu Deiner, außer dass mein Docker-Container auf einer Synology läuft. Die Fehlermeldungen die bei Dir kommen haben auch keinen Bezug zum Adapter (z.B. dimmer.png oder words.js), da ist noch irgendetwas anderes nicht ok. Hast Du in Deiner VIS noch etwas anderes am Start?
                      O Online
                      O Online
                      Oli
                      @carsten04
                      Nein, habe gerade festgestellt, dass ich keine Routen speichern kann, dass Speichersympol wird nicht grün
                      Oliver
                      • O Oli
                        @carsten04
                        carsten04C Offline
                        carsten04C Offline
                        carsten04
                        @oli Dann mach mal folgendes: restart der Instanz. Wenn alles richtig läuft, dann bekommst Du bei der Eingabe von Start und Ziel direkt Vorschläge angezeigt, so wie hier. Wichtig: Du musst den richtigen Vorschlag mit RETURN übernehmen.
                          O Online
                          O Online
                          Oli
                          schrieb am zuletzt editiert von Oli
                          @carsten04
                          das klappt leider auch nicht, da kommen keine Vorschläge
                          jetzt kamen mehr Fehler
                          trycatch.ts:281          GET http://192.168.2.120:3040/socket.io/?EIO=3&transport=polling&t=OOo98Rv net::ERR_CONNECTION_REFUSED
                          (anonym) @ trycatch.ts:281
                          (anonym) @ instrument.ts:309
                          i.create @ index.js:83
                          i @ index.js:83
                          o.request @ index.js:83
                          o.doPoll @ index.js:83
                          r.poll @ index.js:83
                          r.doOpen @ index.js:83
                          r.open @ index.js:83
                          r @ index.js:83
                          r @ index.js:83
                          r.open.r.connect @ index.js:83
                          sentryWrapped @ helpers.ts:87
                          setTimeout (async)
                          (anonym) @ trycatch.ts:119
                          r.reconnect @ index.js:83
                          r.onclose @ index.js:83
                          r.onClose @ index.js:83
                          ws.onclose @ index.js:83
                          trycatch.ts:281          GET http://192.168.2.120:3040/socket.io/?EIO=3&transport=polling&t=OOo99fy net::ERR_CONNECTION_REFUSED
                          i @ index.js:83
                          r @ index.js:83
                          r @ index.js:83
                          setTimeout (async)
                          r.onError @ index.js:83
                          i.onError @ index.js:83
                          setTimeout (async)
                          hasXDR.e.onreadystatechange @ index.js:83
                          XMLHttpRequest.send (async)
                          i @ index.js:83
                          r @ index.js:83
                          r @ index.js:83
                          setTimeout (async)
                          trycatch.ts:281          GET http://192.168.2.120:3040/socket.io/?EIO=3&transport=polling&t=OOo9AeS net::ERR_CONNECTION_REFUSED
                          i @ index.js:83
                          r @ index.js:83
                          r @ index.js:83
                          setTimeout (async)
                          setTimeout (async)
                          i @ index.js:83
                          r @ index.js:83
                          r @ index.js:83
                          setTimeout (async)
                          setTimeout (async)
                          i @ index.js:83
                          r @ index.js:83
                          r @ index.js:83
                          setTimeout (async)
                          trycatch.ts:281          GET http://192.168.2.120:3040/socket.io/?EIO=3&transport=polling&t=OOo9oC2 net::ERR_CONNECTION_REFUSED
                          i @ index.js:83
                          r @ index.js:83
                          r @ index.js:83
                          setTimeout (async)
                             at vis.js:3630:29
                          a.add @ index.js:83
                          Bin, jetzt mal unterwegs.
                          Oliver
                          • O Oli
                            @carsten04
                            i @ index.js:83
                            r @ index.js:83
                            r @ index.js:83
                            setTimeout (async)
                            i @ index.js:83
                            r @ index.js:83
                            r @ index.js:83
                            setTimeout (async)
                            setTimeout (async)
                            i @ index.js:83
                            r @ index.js:83
                            r @ index.js:83
                            setTimeout (async)
                            i @ index.js:83
                            r @ index.js:83
                            r @ index.js:83
                            setTimeout (async)
                            setTimeout (async)
                            i @ index.js:83
                            r @ index.js:83
                            r @ index.js:83
                            setTimeout (async)
                            setTimeout (async)
                            i @ index.js:83
                            r @ index.js:83
                            r @ index.js:83
                            setTimeout (async)
                            i @ index.js:83
                            r @ index.js:83
                            r @ index.js:83
                            setTimeout (async)
                               at vis.js:3630:29
                            a.add @ index.js:83
                            carsten04C Offline
                            carsten04C Offline
                            carsten04
                            @oli Mhm, das ist alles sehr merkwürdig. Hast Du den feathers-Port eventuell schon anderweitig vergeben? Kannst Du einmal bei geöffneter dev-Konsole die Instanz neu starten und schauen, ob da irgendetwas kommt?
                              O Online
                              O Online
                              Oli
                              @carsten04
                              Fehlermeldungen aus der Instanz
                              websocket.js:124 WebSocket connection to 'ws://192.168.2.120:3040/socket.io/?EIO=3&transport=websocket' failed:
                              Pc.doOpen @ websocket.js:124
                              Kf.open @ transport.js:84
                              cn.open @ socket.js:250
                              cn @ socket.js:122
                              cn @ socket.js:28
                              Pn.open.Pn.connect @ manager.js:226
                              (anonym) @ manager.js:544
                              cn @ socket.js:122
                              cn @ socket.js:28
                              browser-layer.js:92          GET https://api.mapbox.com/geocoding/v5/mapbox.places/xxxxxxxxxxxxxxxxxxxxxxxxxxxxx.json?language=de&types=address%2Cpoi&limit=1&access_token=XXXXXXXXXXXXXXXXXXXXXXXXXXXXAvM61g 401 (Unauthorized)
                              (anonym) @ browser-layer.js:92
                              zje @ browser-layer.js:38
                              (anonym) @ browser-layer.js:116
                              Promise.then (async)
                              LVt @ browser-layer.js:114
                              Hy.send @ mapi-request.js:160
                              (anonym) @ RouteGeocoderField.tsx:62
                              S2t @ react-dom.production.min.js:262
                              jn.unstable_runWithPriority @ scheduler.production.min.js:18
                              i_ @ react-dom.production.min.js:122
                              My @ react-dom.production.min.js:261
                              IK @ react-dom.production.min.js:243
                              (anonym) @ react-dom.production.min.js:123
                              cEe @ react-dom.production.min.js:123
                              jf @ react-dom.production.min.js:122
                              x2t @ react-dom.production.min.js:244
                              GK @ react-dom.production.min.js:292
                              HK @ react-dom.production.min.js:49
                              QRt @ react-dom.production.min.js:50
                              tEe @ react-dom.production.min.js:105
                              QK @ react-dom.production.min.js:75
                              JK @ react-dom.production.min.js:74
                              ESe @ react-dom.production.min.js:292
                              gkt @ react-dom.production.min.js:73
                              index_m.html:1 Uncaught (in promise) RVt {message: 'Not Authorized - Invalid Token', type: 'HttpError', statusCode: 401, request: Hy, body: {…}}
                              (anonym) @ RouteGeocoderField.tsx:63
                              Oliver
                              • O Oli
                                @carsten04
                                cn @ socket.js:122
                                cn @ socket.js:28
                                cn @ socket.js:122
                                cn @ socket.js:28
                                carsten04C Offline
                                carsten04C Offline
                                carsten04
                                @oli Das hilft mir schon mal weiter. Danke Dir.
                                  O Online
                                  O Online
                                  Oli
                                  @carsten04
                                  gerne
                                  Oliver
                                  • O Oli
                                    @carsten04
                                    gerne
                                    carsten04C Offline
                                    carsten04C Offline
                                    carsten04
                                    @oli Hinweis: Dein Token ist definitiv ungültig. Das müsstest Du mal checken. Der Rest könnten Folgefehler seien. Am Besten Du erstellst Dir ein neues Token und nutzt nicht den Default public token. Wenn der Token korrekt ist, kannst Du auf jeden Fall im Tab KARTEN schon einmal eine Karte ohne Route sehen.
                                    • O Offline
                                      O Offline
                                      oxident
                                      Also bei mir tritt das VIS-Problem ja auch auf, nutze aber weder Docker noch Proxy. Die Routenerstellung funktioniert jedoch und der Feathers-Port ist verfügbar.
                                      • O oxident
                                        carsten04C Offline
                                        carsten04C Offline
                                        carsten04
                                        @oxident Du siehst dann im Admin unter Karten auch die eingegebenen Routen und die Hindernisse, richtig?
                                          O Offline
                                          O Offline
                                          oxident
                                          @carsten04 Ja, soweit alles ok!
