  4. Alpha Testing: OCPP Wallbox Adapter
    6.3k
ocppwallboxadapter
448 Beiträge 49 Kommentatoren 152.5k Aufrufe 47 Beobachtet
  • foxriver76F foxriver76
    @jrlohni Hast du den richtigen chargeLimitType eingestellt? Lt. config bei dir nur Current erlaubt, also regeln in Ampere. Ansonsten gerne mal debug Log zeigen, evtl. sehen wir dann was da falsch läuft. Bzw. von welchem Hersteller ist die Box? Bei mir Pulsar Plus gibts aktuell auch Probleme, habe denen geschrieben, allerdings noch keine sinnvolle Antwort erhalten was sie oder ich falsch machen.
    Jrlohni
    #348
    @foxriver76 Anbei meine Einstellungen, ja habe "A" gewählt:
    Es handelt sich bei mir um einen go-e Charger in der Gemini flex Version.
    Log:
    ocpp.0
    2023-02-06 15:17:13.083	info	Received MeterValues from "/.1"
    ocpp.0
    2023-02-06 14:57:57.923	error	Cannot execute command "availability" for "/.1":
    ocpp.0
    2023-02-06 14:57:49.924	warn	Charge point responded with "Rejected" on changing charge limit
    ocpp.0
    2023-02-06 14:57:42.673	error	Cannot execute command "numberPhases" for "/.1": No chargeLimit set
    ocpp.0
    2023-02-06 14:57:15.924	info	Removing LocalAuthListManagement functionality as unsupported
    ocpp.0
    2023-02-06 14:57:15.837	info	Supported profiles by client "/" are "Core,FirmwareManagement,SmartCharging,RemoteTrigger"
    ocpp.0
    2023-02-06 14:57:15.595	info	Sending GetConfiguration to "/"
    ocpp.0
    2023-02-06 14:57:14.440	info	Requesting MeterValues from "/"
    ocpp.0
    2023-02-06 14:57:13.429	info	Received Status Notification from "/.1": Finishing
    ocpp.0
    2023-02-06 14:57:13.301	info	Requesting StatusNotification from "/"
    ocpp.0
    2023-02-06 14:57:12.704	info	Received MeterValues from "/.1"
    ocpp.0
    2023-02-06 14:57:12.574	info	Received Status Notification from "/.1": Finishing
    ocpp.0
    2023-02-06 14:57:12.479	info	Received Status Notification from "/.0": Available
    ocpp.0
    2023-02-06 14:57:12.301	info	Received boot notification from "/"
    ocpp.0
    2023-02-06 14:57:12.184	info	New device connected: "/"
    ocpp.0
    2023-02-06 14:57:12.044	info	New valid connection from "/" (http/ocpp1.6)
    ocpp.0
    2023-02-06 14:57:02.062	info	Server listening on port 9220
    ocpp.0
    2023-02-06 14:57:02.006	info	Starting OCPP Server
    ocpp.0
    2023-02-06 14:57:01.955	info	starting. Version 0.12.2 in /opt/iobroker/node_modules/iobroker.ocpp, node: v14.21.2, js-controller: 4.0.23
    host.raspberrypi
    2023-02-06 14:57:00.095	info	instance system.adapter.ocpp.0 started with pid 5222
    host.raspberrypi
    2023-02-06 14:56:57.585	info	instance system.adapter.ocpp.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.raspberrypi
    2023-02-06 14:56:57.024	info	stopInstance system.adapter.ocpp.0 send kill signal
    ocpp.0
    2023-02-06 14:56:57.005	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    ocpp.0
    2023-02-06 14:56:57.003	info	terminating
    ocpp.0
    2023-02-06 14:56:56.982	info	Got terminate signal TERMINATE_YOURSELF
    host.raspberrypi
    2023-02-06 14:56:56.976	info	stopInstance system.adapter.ocpp.0 (force=false, process=true)
    ocpp.0
    2023-02-06 14:56:55.925	info	Removing LocalAuthListManagement functionality as unsupported
    ocpp.0
    2023-02-06 14:56:55.838	info	Supported profiles by client "/" are "Core,FirmwareManagement,SmartCharging,RemoteTrigger"
    ocpp.0
    2023-02-06 14:56:55.622	info	Sending GetConfiguration to "/"
    ocpp.0
    2023-02-06 14:56:54.471	info	Requesting MeterValues from "/"
    ocpp.0
    2023-02-06 14:56:53.460	info	Received Status Notification from "/.1": Finishing
    ocpp.0
    2023-02-06 14:56:53.363	info	Requesting StatusNotification from "/"
    ocpp.0
    2023-02-06 14:56:52.876	info	Received MeterValues from "/.1"
    ocpp.0
    2023-02-06 14:56:52.615	info	Received Status Notification from "/.1": Finishing
    ocpp.0
    2023-02-06 14:56:52.518	info	Received Status Notification from "/.0": Available
    ocpp.0
    2023-02-06 14:56:52.363	info	Received boot notification from "/"
    ocpp.0
    2023-02-06 14:56:52.223	info	New device connected: "/"
    ocpp.0
    2023-02-06 14:56:52.084	info	New valid connection from "/" (http/ocpp1.6)
    ocpp.0
    2023-02-06 14:56:22.111	info	Server listening on port 9220
    ocpp.0
    2023-02-06 14:56:22.056	info	Starting OCPP Server
    ocpp.0
    2023-02-06 14:56:22.018	info	starting. Version 0.12.2 in /opt/iobroker/node_modules/iobroker.ocpp, node: v14.21.2, js-controller: 4.0.23
    Habe den Adapter noch einmal neu gestartet zwischendurch :)
    • J Jrlohni
      Log:
      ocpp.0
      ocpp.0
      ocpp.0
      ocpp.0
      ocpp.0
      ocpp.0
      ocpp.0
      ocpp.0
      ocpp.0
      ocpp.0
      ocpp.0
      ocpp.0
      ocpp.0
      ocpp.0
      ocpp.0
      ocpp.0
      ocpp.0
      ocpp.0
      ocpp.0
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      ocpp.0
      ocpp.0
      ocpp.0
      host.raspberrypi
      ocpp.0
      ocpp.0
      ocpp.0
      ocpp.0
      ocpp.0
      ocpp.0
      ocpp.0
      ocpp.0
      ocpp.0
      ocpp.0
      ocpp.0
      ocpp.0
      ocpp.0
      ocpp.0
      ocpp.0
      foxriver76F Offline
      foxriver76F Offline
      foxriver76
      #349
      @jrlohni Geht es evtl. mit numberPhases 3?
      Videotutorials & mehr
        Jrlohni
        schrieb am zuletzt editiert von Jrlohni
        #350
        @foxriver76 ging leider auch nicht. Die numberPhases nimmt er nicht an und das chargeLimit wird immer noch "Rejected". Auch mit einer Änderung von diversen Möglichkeiten von "True" und "False" ändert sich nichts.
        foxriver76F 2 Antworten Letzte Antwort
        • J Jrlohni
          foxriver76F Offline
          foxriver76F Offline
          foxriver76
          #351
          @jrlohni dann benötigt es wohl eine Änderung im Adapter, so dass man numberCharges deaktiviert indem man es auf null setzt. Ich denke dann sollte es gehen.
          • J Jrlohni
            foxriver76F Offline
            foxriver76F Offline
            foxriver76
            #352
            @jrlohni Probier bitte v0.12.3, sollte gleich auf npm sein.
            • J Offline
              Jrlohni
              #353
              @foxriver76 Leider hat die Version auch keine Besserung gebracht...
              Hab wirklich jede Möglichkeit durchgespielt. Habe numberPhases auf 1, 3, null, (null), NULL und 0 gesetzt...
              Wenn numberPhrases nicht vom Wert "number" war, gab es natürlich eine Fehlermeldung.
              Wie man auf den Screenshot sieht schickt der Adapter für go-e ohne Probleme Daten welche auch vom Charger angenommen werden. Ich würde aber gerne über OCPP gehen, damit ich auch mit weiteren Ladestationen, welche bald kommen, über ein System kommunizieren kann.
              Was mir auffällt: In der Fehlermeldung wegen der falschen Datentypen in "numberPhases" ist "startPeriod" immer 0, könnte es was damit zu tun haben?
              • J Jrlohni
                foxriver76F Offline
                foxriver76F Offline
                foxriver76
                #354
                @jrlohni ich mache mal noch eine 0.12.4 nur um sicher zu gehen, wenn du einen string null setzt, ist klar, dass dann ist mir klar, dass nix geht. Wobei Admin aus dem String null meines Wissens nach wirklich null macht.
                  Jrlohni
                  #355
                  @foxriver76 Auch da hat sich nichts geändert, außer das nun die Fehlermeldung bei nem String nicht mehr kommt...
                  Vielen Dank!
                  • J Jrlohni
                    @foxriver76, ne war wohl abgetippt.. Habe noch mal kontrolliert. Das "r" ist dort nicht vorhanden.
                    Bei "chargeLimit" sagt er mir immer:
                    "Charge point responded with "Rejected" on changing charge limit"
                    in einer früheren Version ging es mal.
                    Ja den Channel gibt es mit diversen States:
                    Für supportetFeatureProfiles steht dort: Core,FirmwareManagement,SmartCharging,RemoteTrigger
                    Also wohl kein LocalAuthListManagement :)
                    Grüße und vielen Dank!
                    fL4sH 0
                    schrieb am zuletzt editiert von fL4sH 0
                    #356
                    @jrlohni said in Alpha Testing: OCPP Wallbox Adapter:
                    Versuch mal die Transaktion mit Chargelimit 0 (A oder W) zu starten, so funktioniert das aktuell bei mir. Anschließend kann das Chargelimit während die Transaktion läuft geändert werden. Wenn das Chargelimit vor dem Start gesetzt wurde kommt bei mir auch die Fehlermeldeung:
                    ocpp.0 2023-02-08 11:55:00.033	warn	Starting transaction has been rejected by charge point
                      fL4sH 0
                      #357
                      @foxriver76 said in Alpha Testing: OCPP Wallbox Adapter:
                      Es scheint wohl mit der aktuellen Version 0.12.4 ein Problem mit dem State numberPhases zu geben.
                      Wenn sich das Chargelimit ändert muss man aktuell den Wert von numberPhases=2 manuell pushen damit sich die Werte in der Wallbox ändern. Wenn nur das Chargelimit geändert wird ändern sich die Daten in der Wallbox nicht.
                      Kann es sein das in dem Befehl Sending SetChargingProfile der Value numberPhases fehlt ?
                      Ich habe mal versucht das im Code zu beschreiben.
                      ocpp.0 2023-02-08 12:04:28.408	info	Received Status Notification from "/TACW1142021G1020.1": Charging
                      ocpp.0 2023-02-08 12:04:28.408	debug	{"connectorId":1,"errorCode":"NoError","info":"null","status":"Charging","vendorErrorCode":"0x0000","commandOcpp":"StatusNotification"}
                      ocpp.0 2023-02-08 12:04:27.908	info	Received Status Notification from "/TACW1142021G1020.1": SuspendedEV
                      ocpp.0 2023-02-08 12:04:27.908	debug {"connectorId":1,"errorCode":"NoError","info":"null","status":"SuspendedEV","vendorErrorCode":"0x0000","commandOcpp":"StatusNotification"}
                      numberPhases wurde gesetzt      ocpp.0 2023-02-08 12:04:27.404	debug	Sending SetChargingProfile for /TACW1142021G1020.1
                      ocpp.0 2023-02-08 12:04:15.387	info	Received MeterValues from "/TACW1142021G1020.1"
                      ocpp.0 2023-02-08 12:04:15.387	debug	{"connectorId":1,"transactionId":1,"meterValue":[{"timestamp":"2023-02-08T11:04:15.000Z","sampledValue":[{"value":"235.30","context":"Sample.Periodic","format":"Raw","measurand":"Voltage","phase":"L1-N","unit":"V"},{"value":"0.0","context":"Sample.Periodic","format":"Raw","measurand":"Current.Import","phase":"L1","unit":"A"},{"value":"0","context":"Sample.Periodic","format":"Raw","measurand":"Power.Active.Import","phase":"L1","unit":"W"},{"value":"234.30","context":"Sample.Periodic","format":"Raw","measurand":"Voltage","phase":"L2-N","unit":"V"},{"value":"0.0","context":"Sample.Periodic","format":"Raw","measurand":"Current.Import","phase":"L2","unit":"A"},{"value":"0","context":"Sample.Periodic","format":"Raw","measurand":"Power.Active.Import","phase":"L2","unit":"W"},{"value":"234.20","context":"Sample.Periodic","format":"Raw","measurand":"Voltage","phase":"L3-N","unit":"V"},{"value":"0.0","context":"Sample.Periodic","format":"Raw","measurand":"Current.Import","phase":"L3","unit":"A"},{"value":"0","context":"Sample.Periodic","format":"Raw","measurand":"Power.Active.Import","phase":"L3","unit":"W"},{"value":"13","context":"Sample.Periodic","format":"Raw","measurand":"Energy.Active.Import.Register","unit":"Wh"},{"value":"0","context":"Sample.Periodic","format":"Raw","measurand":"Current.Offered","unit":"A"},{"value":"0.0","context":"Sample.Periodic","format":"Raw","measurand":"Current.Import","unit":"A"},{"value":"0","context":"Sample.Periodic","format":"Raw","measurand":"Power.Active.Import","unit":"W"}]}],"commandOcpp":"MeterValues"}
                      ocpp.0 2023-02-08 12:04:00.582	info	Received Status Notification from "/TACW1142021G1020.1": SuspendedEVSE
                      ocpp.0 2023-02-08 12:04:00.581	debug	{"connectorId":1,"errorCode":"NoError","info":"null","status":"SuspendedEVSE","vendorErrorCode":"0x0000","commandOcpp":"StatusNotification"}
                      Chargelimit wurde gesetzt        ocpp.0 2023-02-08 12:04:00.035	debug	Sending SetChargingProfile for /TACW1142021G1020.1
                      • F fL4sH 0
                        foxriver76F Offline
                        foxriver76F Offline
                        foxriver76
                        schrieb am zuletzt editiert von foxriver76
                        #358
                        @fl4sh-0 Number of Phases wird nun nur hinzugefügt, wenn im State tatsächlich drin steht (vorher wurde in dem Fall 3 mitgesendet), da das die einzige mir bekannte Änderung zu früher war, bei der ich dachte sie könnte das Problem von @Jrlohni verursachen, nachdem dem nicht so ist, kann ich das auch reverten.
                        reverted mit 0.12.5
                          reverted mit 0.12.5
                          fL4sH 0
                          #359
                          reverted mit 0.12.5
                          Jetzt schein das Verhalten wieder richtig zu sein. Bei Änderung des Chargelimits werden die Werte wieder ohne die numberPhase zu pushen angenommen.
                          Danke für die Änderung.
                          • F Offline
                            frank11
                            #360
                            Mir ist beim letzten Update aufgefallen, dass nach dem Neustart der Eintrag meines letzten Ladevorgangs nochmals in der influxDB gespeichert wurde und ich den per Hand auslöschen musste.
                            Ist das normales Verhalten und muss ich da bei jedem Update drauf achten?
                            Korrektur: anscheinend tritt das bei jedem Neustart auf, dass der letzte Wert in die Datenbank geschrieben wird. Das ist ein Bug, oder?
                            • F frank11
                              foxriver76F Offline
                              foxriver76F Offline
                              foxriver76
                              #361
                              @frank11 das kannst du soweit ich weiß in den DP Optionen für die Aufzeichnung einstellen.
                                frank11
                                #362
                                @foxriver76 Oh je, den Parameter hab ich ja noch nie gesehen. Und der heißt auch noch genauso.
                                Danke.
                                Jetzt wäre meine Verständnisfrage: wofür gibt es denn? Damit der Wert trotz eines Absturzes während des Schreibens in gesichert wird?
                                  beender
                                  schrieb am zuletzt editiert von beender
                                  #363
                                  ich kann weder eine Transaction starten noch stoppen. Es kommt immer diese Fehlermeldung:
                                  2023-03-20 22:24:41.244	warn	Stopping transaction has been rejected by charge point
                                  2023-03-20 22:24:41.238	debug	Sending RemoteStopTransaction for /abb_terra_ac.1
                                  2023-03-20 22:24:39.724	debug	Received heartbeat from "/abb_terra_ac"
                                  2023-03-20 22:24:39.724	debug	{"commandOcpp":"Heartbeat"}
                                  2023-03-20 22:24:14.063	warn	Starting transaction has been rejected by charge point
                                  2023-03-20 22:24:14.048	debug	Sending RemoteStartTransaction for /abb_terra_ac.1: {"connectorId":1,"idTag":"ioBroker","chargingProfile":{"chargingProfileId":1,"stackLevel":0,"chargingProfilePurpose":"TxDefaultProfile","chargingProfileKind":"Recurring","recurrencyKind":"Daily","chargingSchedule":{"duration":86400,"startSchedule":"2013-01-01T00:00Z","chargingRateUnit":"A","chargingSchedulePeriod":[{"startPeriod":0,"limit":16,"numberPhases":3}]}}}
                                  Als Status bekomme ich SuspendedEV zurück, sobald ich das chargeLimit zwischen 6A - 16A einstelle.
                                  Mit einem chageLimit von 0, null bekomme ich den Status SuspendedEVSE.
                                  Ich habe eine ABB Terra AC 11 kW Wallbox und bin für jeden Tipp sehr dankbar :)
                                  • B beender
                                    fL4sH 0
                                    #364
                                    @beender said in Alpha Testing: OCPP Wallbox Adapter:
                                    Du musst bei der ABB die Transaktion mit 0 A oder 0 W starten. Anschließend kannst du das chargelimit einstellen. So funktioniert das aktuell bei mir mit der ABB
                                    • F fL4sH 0
                                      Meister MopperM Online
                                      Meister Mopper
                                      #365
                                      @foxriver76
                                      v0.12.2
                                      Habe heute mal mein Skript für das Überschussladen getestet. Nach Ausschalten des Ladevorgangs überschrieb mir der Adapter das vorher definierte idTag mit ioBroker.
                                      Das bedeutet, dass ich nach jedem automatischen Beenden des Ladevorgangs das Tag neu in den Datenpunkt schreiben muss?
                                      Ist das so gewollt?
                                      Proxmox und HA ...
                                      foxriver76F J 2 Antworten Letzte Antwort
                                        @foxriver76
                                        v0.12.2
                                        Ist das so gewollt?
                                        foxriver76F Offline
                                        foxriver76F Offline
                                        foxriver76
                                        #366
                                        @meister-mopper idTag ist read only und jede über den adapter gestartete Transaktion ist mit dem iobroker tag versehen ansonsten das tag von dem rfid Chip welches du nutzt
                                          Meister Mopper
                                          #367
                                          @foxriver76
                                          Wo trage ich denn mein rfid-tag ein?
                                          Proxmox und HA ...
