  4. Tado Adapter wird nicht mehr grün
    5.5k
97 Beiträge 6 Kommentatoren 12.0k Aufrufe 6 Beobachtet
  • R Offline
    Robbi12
    2023-01-28 10:50:31.478  - error: host.IoBroker Caught by controller[0]:   },
    2023-01-28 10:50:31.478  - error: host.IoBroker Caught by controller[0]:   cause: Error: connect ETIMEDOUT 52.17.162.58:443
    2023-01-28 10:50:31.478  - error: host.IoBroker Caught by controller[0]:       at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1278:16) {
    2023-01-28 10:50:31.478  - error: host.IoBroker Caught by controller[0]:     errno: -110,
    2023-01-28 10:50:31.478  - error: host.IoBroker Caught by controller[0]:     code: 'ETIMEDOUT',
    2023-01-28 10:50:31.478  - error: host.IoBroker Caught by controller[0]:     syscall: 'connect',
    2023-01-28 10:50:31.478  - error: host.IoBroker Caught by controller[0]:     address: '52.17.162.58',
    2023-01-28 10:50:31.478  - error: host.IoBroker Caught by controller[0]:     port: 443
    2023-01-28 10:50:31.478  - error: host.IoBroker Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2023-01-28 10:50:31.478  - error: host.IoBroker Caught by controller[2]: Error: connect ETIMEDOUT 52.17.162.58:443
    2023-01-28 10:50:31.478  - error: host.IoBroker Caught by controller[2]:     at Function.AxiosError.from (/opt/iobroker/node_modules/iobroker.tado/node_modules/axios/lib/core/AxiosError.js:89:14)
    2023-01-28 10:50:31.478  - error: host.IoBroker Caught by controller[2]:     at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/iobroker.tado/node_modules/axios/lib/adapters/http.js:533:25)
    2023-01-28 10:50:31.478  - error: host.IoBroker Caught by controller[2]:     at RedirectableRequest.emit (node:events:513:28)
    2023-01-28 10:50:31.479  - error: host.IoBroker Caught by controller[2]:     at RedirectableRequest.emit (node:domain:489:12)
    2023-01-28 10:50:31.479  - error: host.IoBroker Caught by controller[2]:     at ClientRequest.eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:14:24)
    2023-01-28 10:50:31.479  - error: host.IoBroker Caught by controller[2]:     at ClientRequest.emit (node:events:525:35)
    2023-01-28 10:50:31.479  - error: host.IoBroker Caught by controller[2]:     at ClientRequest.emit (node:domain:489:12)
    2023-01-28 10:50:31.479  - error: host.IoBroker Caught by controller[2]:     at TLSSocket.socketErrorListener (node:_http_client:494:9)
    2023-01-28 10:50:31.479  - error: host.IoBroker Caught by controller[2]:     at TLSSocket.emit (node:events:513:28)
    2023-01-28 10:50:31.479  - error: host.IoBroker Caught by controller[2]:     at TLSSocket.emit (node:domain:489:12)
    2023-01-28 10:50:31.479  - error: host.IoBroker instance system.adapter.tado.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2023-01-28 10:50:31.479  - info: host.IoBroker Restart adapter system.adapter.tado.0 because enabled
    2023-01-28 10:51:01.571  - info: host.IoBroker instance system.adapter.tado.0 started with pid 13333
    • R Robbi12
      @robbi12
      Deine Zeitzone ist schonmal nicht gesetzt, würde ich sagen. Sonst noch falsche Einstellungen?
      iob diag
      sagt?
      • R Offline
        Robbi12
        @thomas-braun Das was oben gezeigt. Oder soll ich das ellenlange Ergebnis zeigen?
        • R Offline
          Robbi12
          Zeitzone habe ich nun gesetzt
          Operatingsystem:        Ubuntu 22.04.1 LTS
          Installation:           lxc
          Timezone:               Europe/Berlin
          User-ID:                0
          X-Server:               false
          Pending OS-Updates:     0
          Nodejs-Installation:    /usr/bin/nodejs         v16.19.0
                                  /usr/bin/node           v16.19.0
                                  /usr/bin/npm            8.19.3
                                  /usr/bin/npx            8.19.3
          ioBroker Core:          js-controller           4.0.24
                                  admin                   6.3.5
          • R Robbi12
            Installation:           lxc
            User-ID:                0
            X-Server:               false
                                    /usr/bin/npm            8.19.3
                                    /usr/bin/npx            8.19.3
                                    admin                   6.3.5
            @robbi12
            Zeig mal die vollständige Ausgabe.
            R S 2 Antworten Letzte Antwort
              @robbi12
              Robbi12
              schrieb am zuletzt editiert von Robbi12
              Wieder entfernt
              • R Robbi12
                Wieder entfernt
                @robbi12
                Hampel da nicht als root herum und leg das nodesource-Repo passend zu deinem jammy an.
                • R Offline
                  Robbi12
                  @thomas-braun said in Tado Adapter wird nicht mehr grün:
                  nodesource-Repo
                  Hi. Da bin ich überfordert.
                  Ich habe den IoBroker nach gängigen Anleitungen im Netz auf nen Proxmox Container installiert. Das geht wohl dann so auf root.
                  Bislang lief auch alles wunderbar. Nun lediglich Tado nicht mehr.
                  Bin aber jederzeit lernbereit und mache das anders wenn ich weiß wie
                  • R Robbi12
                    nodesource-Repo
                    @robbi12 sagte in Tado Adapter wird nicht mehr grün:
                    In der offiziellen Anleitung zu ioBroker auf Proxmox steht es richtig drin.
                    Zu den Paketquellen: Schau in meiner Signatur nach.
                    R 1 Antwort Letzte Antwort
                    • R Offline
                      Robbi12
                      @thomas-braun Gut. Habe gerade einen neuen Benutzer angelegt und dann den Fix drüberlaufen lassen.
                      Habe aber auch kein Problem Iobroker neu aufzusetzen und mit Backitup das relevante wieder zurückzuholen
                        Robbi12
                        @thomas-braun So. Neu aufgesetzt. Alles dann ohne root.
                        Ändert aber nichts. Nach Restart wird er manchmal kurz grün, dann wieder gelb und später viele Fehler. Dann auch die Meldung im Host, dass der Adapter nicht startet.
                        Ich denke irgendwas ist bei Tado faul. Vorgestern ging ja noch alles normal
                        • R Robbi12
                          Hier verhält sich der tado-Adapter allerdings unauffällig.
                            Robbi12
                            Gerade aufgefallen. Volvo Adapter verliert auch die Verbindung. Viessmann auch. Die bekommen aber Daten und werden nicht gelb sondern bleiben grün.
                            Eigenartigerweise bekommt der Tado auch von einem Raum Informationen, einmalig beim starten ohne grün zu werden.
                            Evtl. was mit meinem Anbieter "Vodafone". Hoffe dass es sich die nächsten Tage erledigt
                            • wendy2702W Offline
                              wendy2702W Offline
                              52.17.162.58:443
                              Kannst du diese IP vom ioBroker aus anpingen?
                              Geht die Adresse bei dir im Browser auf?
                              Bei mir kommt erst ein Zertifikatsfehler im Browser, fängt der Adapter das ab?
                              • wendy2702W wendy2702
                                52.17.162.58:443
                                Robbi12
                                @wendy2702 said in Tado Adapter wird nicht mehr grün:
                                52.17.162.58:443
                                400 Bad Request
                                The plain HTTP request was sent to HTTPS port
                                ohne 443 geht er auf https und dann zur tado seite
                                wendy2702W GlasfaserG 2 Antworten Letzte Antwort
                                • R Robbi12
                                  52.17.162.58:443
                                  400 Bad Request
                                  wendy2702W Offline
                                  wendy2702W Offline
                                  @robbi12 und ist die IP vom Iob aus erreichbar?
                                    Robbi12
                                    @wendy2702 Wie kann ich das Testen?
                                    • R Robbi12
                                      wendy2702W Offline
                                      wendy2702W Offline
                                      @robbi12 Session per z.B. Putty auf deinen IOB Server und von dort dann ein ping auf die IP oder ein traceroute
                                        @robbi12
                                        spooky82
                                        @thomas-braun Auch mein tado Adapter wird seit gestern nicht mehr grün.
                                        Was brauchst du zum Analysieren?
                                        iob läuft bei mir in einem doker.
                                          wendy2702W Offline
                                          geht denn euer login auf der Seite noch?
                                          @spooky82 : logfiles
