  4. VIS-Adapter nach Neuinst.+Backitup-Restore tot
    5.5k
vis
22 Beiträge 3 Kommentatoren 2.3k Aufrufe 3 Beobachtet
  • DJMarc75D DJMarc75
    @w00dy
    iobroker upgrade vis@1.4.0
    probier mal
    W Offline
    W Offline
    w00dy
    @djmarc75
    Hi, das hatte ich schon probiert und dachte das "@" sei falsch gewesen. Beide Varianten gehen nicht.
    LG,
    w00dy
      @w00dy
      iobroker upgrade vis@1.4.10 --host ioBroker --debug
      W Offline
      W Offline
      w00dy
      Geht leider auch nicht:
      pi@ioBroker:~ $ iobroker upgrade vis@1.4.10 --host ioBroker --debug
      This upgrade of "vis" will at least introduce the following changes:
      -> 1.4.8:
      Added support for js-controller 4.x
      -> 1.4.7:
      Fixed subscribeOidAtRuntime if called with invalid IDs
      Added support of license manager
      BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
      Would you like to upgrade vis from @0.0.0 to @1.4.10 now? [(y)es, (n)o]: yes
      Update vis from @0.0.0 to @1.4.10
      NPM version: 8.19.3
      Installing iobroker.vis@1.4.10... (System call)
      npm ERR! code 6
      npm ERR! path /opt/iobroker/node_modules/iobroker.vis
      npm ERR! command failed
      npm ERR! command sh -c -- node main.js --install
      npm ERR!     /home/iobroker/.npm/_logs/2023-01-27T11_33_40_209Z-debug-0.log
      host.ioBroker Cannot install iobroker.vis@1.4.10: 6
      pi@ioBroker:~ $
      LG,
      w00dy
      • W w00dy
        -> 1.4.8:
        -> 1.4.7:
        NPM version: 8.19.3
        npm ERR! code 6
        pi@ioBroker:~ $
        @w00dy
        Was steht denn in dem genannten Log drin?
        W 1 Antwort Letzte Antwort
          @w00dy
          W Offline
          W Offline
          w00dy
          schrieb am zuletzt editiert von w00dy
          Für mich nur Kauderwelsch 😏 . Ich hoffe, du kannst was damit anfangen....
          0 verbose cli /usr/bin/node /usr/bin/npm
          1 info using npm@8.19.3
          2 info using node@v16.19.0
          3 timing npm:load:whichnode Completed in 0ms
          4 timing config:load:defaults Completed in 6ms
          5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 2ms
          6 timing config:load:builtin Completed in 3ms
          7 timing config:load:cli Completed in 13ms
          8 timing config:load:env Completed in 1ms
          9 timing config:load:file:/opt/iobroker/.npmrc Completed in 4ms
          10 timing config:load:project Completed in 32ms
          11 timing config:load:file:/home/iobroker/.npmrc Completed in 1ms
          12 timing config:load:user Completed in 1ms
          13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
          14 timing config:load:global Completed in 0ms
          15 timing config:load:validate Completed in 1ms
          16 timing config:load:credentials Completed in 3ms
          17 timing config:load:setEnvs Completed in 4ms
          18 timing config:load Completed in 66ms
          19 timing npm:load:configload Completed in 66ms
          20 timing npm:load:mkdirpcache Completed in 3ms
          21 timing npm:load:mkdirplogs Completed in 0ms
          22 verbose title npm install iobroker.vis@1.4.10
          23 verbose argv "install" "--save-exact" "iobroker.vis@1.4.10"
          24 timing npm:load:setTitle Completed in 4ms
          25 timing config:load:flatten Completed in 12ms
          26 timing npm:load:display Completed in 14ms
          27 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs
          28 verbose logfile /home/iobroker/.npm/_logs/2023-01-27T11_33_40_209Z-debug-0.log
          29 timing npm:load:logFile Completed in 21ms
          30 timing npm:load:timers Completed in 1ms
          31 timing npm:load:configScope Completed in 0ms
          32 timing npm:load Completed in 116ms
          33 timing arborist:ctor Completed in 3ms
          34 silly logfile start cleaning logs, removing 2 files
          35 silly logfile done cleaning log files
          36 timing idealTree:init Completed in 4703ms
          37 timing idealTree:userRequests Completed in 31ms
          38 silly idealTree buildDeps
          39 silly fetch manifest iobroker.vis@1.4.10
          40 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
          41 http fetch GET 200 https://registry.npmjs.org/iobroker.vis 3328ms (cache hit)
          42 silly placeDep ROOT iobroker.vis@1.4.10 OK for: iobroker.inst@3.0.0 want: 1.4.10
          43 silly fetch manifest axios@^0.24.0
          44 http fetch GET 200 https://registry.npmjs.org/axios 2012ms (cache hit)
          45 timing idealTree:#root Completed in 5395ms
          46 silly placeDep node_modules/iobroker.vis axios@0.24.0 OK for: iobroker.vis@1.4.10 want: ^0.24.0
          47 timing idealTree:node_modules/iobroker.vis Completed in 16ms
          48 timing idealTree:node_modules/iobroker.vis/node_modules/axios Completed in 0ms
          49 timing idealTree:buildDeps Completed in 5415ms
          50 timing idealTree:fixDepFlags Completed in 41ms
          51 timing idealTree Completed in 10274ms
          52 timing reify:loadTrees Completed in 10341ms
          53 timing reify:diffTrees Completed in 192ms
          54 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv' ]
          55 silly reify mark retired [
          55 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archive-type'
          55 silly reify ]
          56 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asn1' ]
          57 silly reify mark retired [
          57 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/assert-plus'
          57 silly reify ]
          58 silly reify mark retired [
          58 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asynckit'
          58 silly reify ]
          59 silly reify mark retired [
          59 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws-sign2'
          59 silly reify ]
          60 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws4' ]
          61 silly reify mark retired [
          61 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/base64-js'
          61 silly reify ]
          62 silly reify mark retired [
          62 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bcrypt-pbkdf'
          62 silly reify ]
          63 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bl' ]
          64 silly reify mark retired [
          64 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bluetooth-hci-socket'
          64 silly reify ]
          65 silly reify mark retired [
          65 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bplist-parser'
          65 silly reify ]
          66 silly reify mark retired [
          66 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer'
          66 silly reify ]
          67 silly reify mark retired [
          67 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-alloc'
          67 silly reify ]
          68 silly reify mark retired [
          68 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-alloc-unsafe'
          68 silly reify ]
          69 silly reify mark retired [
          69 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-crc32'
          69 silly reify ]
          70 silly reify mark retired [
          70 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-fill'
          70 silly reify ]
          71 silly reify mark retired [
          71 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cacheable-request'
          71 silly reify ]
          72 silly reify mark retired [
          72 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/call-bind'
          72 silly reify ]
          73 silly reify mark retired [
          73 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/caseless'
          73 silly reify ]
          74 silly reify mark retired [
          74 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-response'
          74 silly reify ]
          75 silly reify mark retired [
          75 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript',
          75 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/coffee',
          75 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/cake'
          75 silly reify ]
          76 silly reify mark retired [
          76 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/combined-stream'
          76 silly reify ]
          77 silly reify mark retired [
          77 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/commander'
          77 silly reify ]
          78 silly reify mark retired [
          78 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/content-disposition'
          78 silly reify ]
          79 silly reify mark retired [
          79 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/core-util-is'
          79 silly reify ]
          80 silly reify mark retired [
          80 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dashdash'
          80 silly reify ]
          81 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/debug' ]
          82 silly reify mark retired [
          82 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decode-uri-component'
          82 silly reify ]
          83 silly reify mark retired [
          83 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress'
          83 silly reify ]
          84 silly reify mark retired [
          84 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-response'
          84 silly reify ]
          85 silly reify mark retired [
          85 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-tar'
          85 silly reify ]
          86 silly reify mark retired [
          86 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-tarbz2'
          86 silly reify ]
          87 silly reify mark retired [
          87 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-targz'
          87 silly reify ]
          88 silly reify mark retired [
          88 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-unzip'
          88 silly reify ]
          89 silly reify mark retired [
          89 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/define-properties'
          89 silly reify ]
          90 silly reify mark retired [
          90 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/delayed-stream'
          90 silly reify ]
          91 silly reify mark retired [
          91 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/download'
          91 silly reify ]
          92 silly reify mark retired [
          92 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexer3'
          92 silly reify ]
          93 silly reify mark retired [
          93 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ecc-jsbn'
          93 silly reify ]
          94 silly reify mark retired [
          94 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/end-of-stream'
          94 silly reify ]
          95 silly reify mark retired [
          95 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ext-list'
          95 silly reify ]
          96 silly reify mark retired [
          96 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ext-name'
          96 silly reify ]
          97 silly reify mark retired [
          97 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extend'
          97 silly reify ]
          98 silly reify mark retired [
          98 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extsprintf'
          98 silly reify ]
          99 silly reify mark retired [
          99 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-deep-equal'
          99 silly reify ]
          100 silly reify mark retired [
          100 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-json-stable-stringify'
          100 silly reify ]
          101 silly reify mark retired [
          101 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fd-slicer'
          101 silly reify ]
          102 silly reify mark retired [
          102 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/file-type'
          102 silly reify ]
          103 silly reify mark retired [
          103 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/filename-reserved-regex'
          103 silly reify ]
          104 silly reify mark retired [
          104 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/filenamify'
          104 silly reify ]
          105 silly reify mark retired [
          105 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/forever-agent'
          105 silly reify ]
          106 silly reify mark retired [
          106 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/form-data'
          106 silly reify ]
          107 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/from2' ]
          108 silly reify mark retired [
          108 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fs-constants'
          108 silly reify ]
          109 silly reify mark retired [
          109 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/function-bind'
          109 silly reify ]
          110 silly reify mark retired [
          110 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/get-intrinsic'
          110 silly reify ]
          111 silly reify mark retired [
          111 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/getpass'
          111 silly reify ]
          112 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/got' ]
          113 silly reify mark retired [
          113 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/graceful-fs'
          113 silly reify ]
          114 silly reify mark retired [
          114 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-schema'
          114 silly reify ]
          115 silly reify mark retired [
          115 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-validator'
          115 silly reify ]
          116 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has' ]
          117 silly reify mark retired [
          117 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-property-descriptors'
          117 silly reify ]
          118 silly reify mark retired [
          118 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbol-support-x'
          118 silly reify ]
          119 silly reify mark retired [
          119 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbols'
          119 silly reify ]
          120 silly reify mark retired [
          120 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-to-string-tag-x'
          120 silly reify ]
          121 silly reify mark retired [
          121 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-cache-semantics'
          121 silly reify ]
          122 silly reify mark retired [
          122 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature'
          122 silly reify ]
          123 silly reify mark retired [
          123 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ieee754'
          123 silly reify ]
          124 silly reify mark retired [
          124 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/immediate'
          124 silly reify ]
          125 silly reify mark retired [
          125 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/inherits'
          125 silly reify ]
          126 silly reify mark retired [
          126 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/into-stream'
          126 silly reify ]
          127 silly reify mark retired [
          127 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-nan'
          127 silly reify ]
          128 silly reify mark retired [
          128 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-natural-number'
          128 silly reify ]
          129 silly reify mark retired [
          129 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-object'
          129 silly reify ]
          130 silly reify mark retired [
          130 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-retry-allowed'
          130 silly reify ]
          131 silly reify mark retired [
          131 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-typedarray'
          131 silly reify ]
          132 silly reify mark retired [
          132 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isarray'
          132 silly reify ]
          133 silly reify mark retired [
          133 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isstream'
          133 silly reify ]
          134 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isurl' ]
          135 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsbn' ]
          136 silly reify mark retired [
          136 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-buffer'
          136 silly reify ]
          137 silly reify mark retired [
          137 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema'
          137 silly reify ]
          138 silly reify mark retired [
          138 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema-traverse'
          138 silly reify ]
          139 silly reify mark retired [
          139 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-stringify-safe'
          139 silly reify ]
          140 silly reify mark retired [
          140 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsonata'
          140 silly reify ]
          141 silly reify mark retired [
          141 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsprim'
          141 silly reify ]
          142 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jszip' ]
          143 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/keyv' ]
          144 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lie' ]
          145 silly reify mark retired [
          145 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/long-timeout'
          145 silly reify ]
          146 silly reify mark retired [
          146 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lowercase-keys'
          146 silly reify ]
          147 silly reify mark retired [
          147 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lru-cache'
          147 silly reify ]
          148 silly reify mark retired [
          148 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/make-dir'
          148 silly reify ]
          149 silly reify mark retired [
          149 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-db'
          149 silly reify ]
          150 silly reify mark retired [
          150 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-types'
          150 silly reify ]
          151 silly reify mark retired [
          151 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mimic-response'
          151 silly reify ]
          152 silly reify mark retired [
          152 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/minimist'
          152 silly reify ]
          153 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ms' ]
          154 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/nan' ]
          155 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/noble' ]
          156 silly reify mark retired [
          156 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-addon-api'
          156 silly reify ]
          157 silly reify mark retired [
          157 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-gyp-build',
          157 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-gyp-build',
          157 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-gyp-build-optional',
          157 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-gyp-build-test'
          157 silly reify ]
          158 silly reify mark retired [
          158 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-inspect',
          158 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-inspect'
          158 silly reify ]
          159 silly reify mark retired [
          159 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/normalize-url'
          159 silly reify ]
          160 silly reify mark retired [
          160 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/oauth-sign'
          160 silly reify ]
          161 silly reify mark retired [
          161 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/object-assign'
          161 silly reify ]
          162 silly reify mark retired [
          162 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/object-keys'
          162 silly reify ]
          163 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/once' ]
          164 silly reify mark retired [
          164 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-cancelable'
          164 silly reify ]
          165 silly reify mark retired [
          165 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-event'
          165 silly reify ]
          166 silly reify mark retired [
          166 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-finally'
          166 silly reify ]
          167 silly reify mark retired [
          167 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-is-promise'
          167 silly reify ]
          168 silly reify mark retired [
          168 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-timeout'
          168 silly reify ]
          169 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pako' ]
          170 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pend' ]
          171 silly reify mark retired [
          171 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/performance-now'
          171 silly reify ]
          172 silly reify mark retired [
          172 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/picocolors'
          172 silly reify ]
          173 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pify' ]
          174 silly reify mark retired [
          174 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie'
          174 silly reify ]
          175 silly reify mark retired [
          175 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie-promise'
          175 silly reify ]
          176 silly reify mark retired [
          176 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/prepend-http'
          176 silly reify ]
          177 silly reify mark retired [
          177 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/process-nextick-args'
          177 silly reify ]
          178 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/psl' ]
          179 silly reify mark retired [
          179 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/punycode'
          179 silly reify ]
          180 silly reify mark retired [
          180 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/query-string'
          180 silly reify ]
          181 silly reify mark retired [
          181 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/readable-stream'
          181 silly reify ]
          182 silly reify mark retired [
          182 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request'
          182 silly reify ]
          183 silly reify mark retired [
          183 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/responselike'
          183 silly reify ]
          184 silly reify mark retired [
          184 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safe-buffer'
          184 silly reify ]
          185 silly reify mark retired [
          185 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safer-buffer'
          185 silly reify ]
          186 silly reify mark retired [
          186 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/seek-bzip',
          186 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/seek-bunzip',
          186 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/seek-table'
          186 silly reify ]
          187 silly reify mark retired [
          187 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/semver',
          187 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/semver'
          187 silly reify ]
          188 silly reify mark retired [
          188 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/setimmediate'
          188 silly reify ]
          189 silly reify mark retired [
          189 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sort-keys'
          189 silly reify ]
          190 silly reify mark retired [
          190 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sort-keys-length'
          190 silly reify ]
          191 silly reify mark retired [
          191 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sorted-array-functions'
          191 silly reify ]
          192 silly reify mark retired [
          192 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/strict-uri-encode'
          192 silly reify ]
          193 silly reify mark retired [
          193 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/string_decoder'
          193 silly reify ]
          194 silly reify mark retired [
          194 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-dirs'
          194 silly reify ]
          195 silly reify mark retired [
          195 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-outer'
          195 silly reify ]
          196 silly reify mark retired [
          196 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/suncalc2'
          196 silly reify ]
          197 silly reify mark retired [
          197 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tar-stream'
          197 silly reify ]
          198 silly reify mark retired [
          198 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/through'
          198 silly reify ]
          199 silly reify mark retired [
          199 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/timed-out'
          199 silly reify ]
          200 silly reify mark retired [
          200 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/to-buffer'
          200 silly reify ]
          201 silly reify mark retired [
          201 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tough-cookie'
          201 silly reify ]
          202 silly reify mark retired [
          202 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/trim-repeated'
          202 silly reify ]
          203 silly reify mark retired [
          203 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tunnel-agent'
          203 silly reify ]
          204 silly reify mark retired [
          204 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tweetnacl'
          204 silly reify ]
          205 silly reify mark retired [
          205 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript',
          205 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsc',
          205 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsserver'
          205 silly reify ]
          206 silly reify mark retired [
          206 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/unbzip2-stream'
          206 silly reify ]
          207 silly reify mark retired [
          207 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uri-js'
          207 silly reify ]
          208 silly reify mark retired [
          208 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/url-parse-lax'
          208 silly reify ]
          209 silly reify mark retired [
          209 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/url-to-options'
          209 silly reify ]
          210 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/usb' ]
          211 silly reify mark retired [
          211 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/util-deprecate'
          211 silly reify ]
          212 silly reify mark retired [
          212 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uuid',
          212 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/uuid'
          212 silly reify ]
          213 silly reify mark retired [
          213 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/verror'
          213 silly reify ]
          214 silly reify mark retired [
          214 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/virtual-tsc'
          214 silly reify ]
          215 silly reify mark retired [
          215 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/wake_on_lan',
          215 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/wake'
          215 silly reify ]
          216 silly reify mark retired [
          216 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/wrappy'
          216 silly reify ]
          217 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/xtend' ]
          218 silly reify mark retired [
          218 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/yallist'
          218 silly reify ]
          219 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/yauzl' ]
          220 silly reify mark retired [
          220 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/adapter-core'
          220 silly reify ]
          221 silly reify mark retired [
          221 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/caseless'
          221 silly reify ]
          222 silly reify mark retired [
          222 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@sindresorhus/is'
          222 silly reify ]
          223 silly reify mark retired [
          223 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/iobroker'
          223 silly reify ]
          224 silly reify mark retired [
          224 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node'
          224 silly reify ]
          225 silly reify mark retired [
          225 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/request'
          225 silly reify ]
          226 silly reify mark retired [
          226 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/tough-cookie'
          226 silly reify ]
          227 silly reify mark retired [
          227 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk',
          227 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-conv',
          227 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-sign',
          227 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-verify'
          227 silly reify ]
          228 silly reify moves {
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ajv-JWAHQ164',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archive-type': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.archive-type-3GzbVy99',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asn1': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.asn1-begjjmYE',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/assert-plus': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.assert-plus-CvwT5c2f',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asynckit': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.asynckit-s0phpr5l',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws-sign2': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.aws-sign2-i67xE5NL',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws4': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.aws4-ewgSeGU1',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/base64-js': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.base64-js-CMxDgSwp',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bcrypt-pbkdf': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bcrypt-pbkdf-FkcXJSG6',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bl': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bl-tXcstEmh',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bluetooth-hci-socket': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bluetooth-hci-socket-LLgU3d50',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bplist-parser': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bplist-parser-Gw4mjLSv',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.buffer-jMN3QEXD',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-alloc': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.buffer-alloc-X1fED6E7',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-alloc-unsafe': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.buffer-alloc-unsafe-80OHTfqv',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-crc32': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.buffer-crc32-cFTv6cUc',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-fill': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.buffer-fill-5TccPbH2',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cacheable-request': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.cacheable-request-7Qr1qFGw',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/call-bind': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.call-bind-jQ2HDLx1',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/caseless': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.caseless-H2SaxUok',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-response': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.clone-response-huORZ122',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.coffeescript-btitSxqy',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/coffee': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.coffee-Ne3HN5Co',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/cake': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.cake-vF6kAtwy',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/combined-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.combined-stream-HoYmPyrw',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/commander': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.commander-P4zg2JoS',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/content-disposition': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.content-disposition-ykNJNQbu',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/core-util-is': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.core-util-is-eZ4fUaee',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dashdash': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.dashdash-nWlk69uH',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/debug': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.debug-A3k10AtD',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decode-uri-component': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decode-uri-component-CMOQnZCN',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decompress-jANiOqwy',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-response': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decompress-response-mSREN8o7',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-tar': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decompress-tar-aFLFgMpn',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-tarbz2': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decompress-tarbz2-J0MOywyt',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-targz': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decompress-targz-NMX7flNZ',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-unzip': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decompress-unzip-SCgptaCu',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/define-properties': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.define-properties-6XwZYcVY',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/delayed-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.delayed-stream-qacC3mjc',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/download': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.download-FZgZNHG4',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexer3': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.duplexer3-GSniCpAc',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ecc-jsbn': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ecc-jsbn-W1wmyGbT',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/end-of-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.end-of-stream-pGA0SfeC',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ext-list': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ext-list-CbquslXA',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ext-name': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ext-name-w2cAb5N9',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extend': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.extend-pv2WceUi',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extsprintf': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.extsprintf-l37IDaAf',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-deep-equal': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.fast-deep-equal-JqieQuGS',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-json-stable-stringify': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.fast-json-stable-stringify-zZtSpvEn',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fd-slicer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.fd-slicer-CGbB7jDs',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/file-type': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.file-type-MyF2AuGo',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/filename-reserved-regex': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.filename-reserved-regex-NQVIkyqX',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/filenamify': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.filenamify-055Pvtkk',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/forever-agent': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.forever-agent-hJzMqug0',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/form-data': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.form-data-f5gN4soy',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/from2': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.from2-rHxymetq',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fs-constants': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.fs-constants-RCPP7GAQ',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/function-bind': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.function-bind-xNuYoKHH',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/get-intrinsic': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.get-intrinsic-jaHndEV0',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/getpass': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.getpass-kOCUh1aA',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/got': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.got-LoRNXoPs',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/graceful-fs': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.graceful-fs-0lTymp4w',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-schema': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.har-schema-rWbJu3Hi',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-validator': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.har-validator-eyrBsHVJ',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.has-xBeCSK4w',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-property-descriptors': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.has-property-descriptors-NgHV0bqO',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbol-support-x': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.has-symbol-support-x-kJ1XKcwn',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbols': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.has-symbols-BlLhZd6T',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-to-string-tag-x': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.has-to-string-tag-x-D0rqbi1N',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-cache-semantics': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.http-cache-semantics-pwHcy6Um',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.http-signature-oUoVxdIq',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ieee754': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ieee754-ZkXktYfP',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/immediate': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.immediate-mU3gxEZk',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/inherits': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.inherits-n3Ch46Yn',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/into-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.into-stream-9jikZ2iK',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-nan': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.is-nan-aBR69xZy',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-natural-number': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.is-natural-number-7DVP81Ku',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-object': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.is-object-f37RttIf',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-retry-allowed': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.is-retry-allowed-bbEHMwWr',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-typedarray': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.is-typedarray-kgxdw7hd',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isarray': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.isarray-5wOzaH7B',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isstream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.isstream-kucfBgOe',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isurl': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.isurl-PFPtYcIS',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsbn': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.jsbn-7awNYEqn',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-buffer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.json-buffer-1DvjfwxG',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.json-schema-gJeujQHS',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema-traverse': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.json-schema-traverse-lxkTlMes',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-stringify-safe': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.json-stringify-safe-6OEF7DXQ',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsonata': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.jsonata-sj644a8k',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsprim': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.jsprim-Hb03jZ2t',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jszip': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.jszip-E0haUyzW',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/keyv': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.keyv-j7k6j1x3',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lie': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.lie-rDNcdBdn',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/long-timeout': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.long-timeout-UsqWplKY',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lowercase-keys': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.lowercase-keys-H4pYv5DL',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lru-cache': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.lru-cache-pTWFZBit',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/make-dir': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.make-dir-kpACuPQc',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-db': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.mime-db-ILNMz48k',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-types': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.mime-types-vVlqwvNj',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mimic-response': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.mimic-response-l1h59Fzs',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/minimist': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.minimist-HEtqlfZM',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ms': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ms-T3oF4fuS',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/nan': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.nan-adtTkJBo',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/noble': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.noble-UcE4HbYj',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-addon-api': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.node-addon-api-zOIY1GW8',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-gyp-build': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.node-gyp-build-Nc8n2hOB',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-gyp-build': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.node-gyp-build-L57SCOlW',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-gyp-build-optional': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.node-gyp-build-optional-Tk80r8za',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-gyp-build-test': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.node-gyp-build-test-izfPMJbu',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-inspect': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.node-inspect-7uCQsf40',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-inspect': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.node-inspect-RjTdcqZj',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/normalize-url': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.normalize-url-dTP3Oa7k',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/oauth-sign': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.oauth-sign-4TUsb1Hr',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/object-assign': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.object-assign-5Cf04ud8',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/object-keys': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.object-keys-L9W7bKqM',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/once': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.once-RFC770N3',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-cancelable': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.p-cancelable-u9fp3HLr',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-event': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.p-event-E5j32boQ',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-finally': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.p-finally-L9V5raVS',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-is-promise': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.p-is-promise-tNH5kneE',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-timeout': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.p-timeout-eSN8lQGZ',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pako': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.pako-rbL7BtOy',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pend': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.pend-BYTjI9Hf',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/performance-now': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.performance-now-rzc7QsAk',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/picocolors': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.picocolors-DQ4TN0mE',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pify': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.pify-kU90vZ0r',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.pinkie-7z22R4ew',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie-promise': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.pinkie-promise-6MuYHt6L',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/prepend-http': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.prepend-http-oFgNJ3Hh',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/process-nextick-args': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.process-nextick-args-1FsUsOM8',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/psl': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.psl-P3JlcAO8',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/punycode': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.punycode-l3TLrnOQ',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/query-string': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.query-string-3uidnXUa',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/readable-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.readable-stream-DGJrLMhV',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.request-IwHtFKjv',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/responselike': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.responselike-tYm4pETH',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safe-buffer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.safe-buffer-GY19LMpy',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safer-buffer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.safer-buffer-VoLQjGhM',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/seek-bzip': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.seek-bzip-JAWtZniv',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/seek-bunzip': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.seek-bunzip-CkVLvAS4',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/seek-table': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.seek-table-f3sdHWHj',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/semver': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.semver-nXF4HfsQ',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/semver': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.semver-Dy7i6zG2',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/setimmediate': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.setimmediate-rLmz5kvN',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sort-keys': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.sort-keys-qcvjMZ6g',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sort-keys-length': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.sort-keys-length-4IGif44d',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sorted-array-functions': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.sorted-array-functions-b2PxWBDs',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/strict-uri-encode': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.strict-uri-encode-WyOTcxtB',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/string_decoder': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.string_decoder-QqeclkYI',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-dirs': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.strip-dirs-8hbG4Qht',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-outer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.strip-outer-syQyolcG',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/suncalc2': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.suncalc2-tGRLIVnX',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tar-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.tar-stream-oOO7qk7O',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/through': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.through-fysaHtUl',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/timed-out': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.timed-out-wvGaABGU',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/to-buffer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.to-buffer-ZDZJ5ICv',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tough-cookie': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.tough-cookie-msAnSxYU',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/trim-repeated': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.trim-repeated-p6XbDaUh',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tunnel-agent': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.tunnel-agent-oUVQRXxE',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tweetnacl': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.tweetnacl-BnSTSyIu',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.typescript-EcwXdkx5',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsc': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.tsc-0PIrZBWg',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsserver': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.tsserver-QDbM4cAE',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/unbzip2-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.unbzip2-stream-7cC95xXq',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uri-js': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.uri-js-8VwjhWYz',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/url-parse-lax': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.url-parse-lax-L4Pi5Fdr',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/url-to-options': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.url-to-options-VEmeYCpr',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/usb': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.usb-eaYctfOO',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/util-deprecate': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.util-deprecate-e5GNBBxw',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uuid': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.uuid-0rL1ORyz',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/uuid': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.uuid-gQ53C49H',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/verror': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.verror-EsRYTvUd',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/virtual-tsc': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.virtual-tsc-Z1y2mItj',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/wake_on_lan': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.wake_on_lan-aA1sq5Hq',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/wake': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.wake-PZWgBD8w',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/wrappy': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.wrappy-FK4KH90e',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/xtend': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.xtend-kCzojcVd',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/yallist': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.yallist-Jj27Vzng',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/yauzl': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.yauzl-I4OoZHvp',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/adapter-core': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/.adapter-core-5hqHvhca',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/caseless': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.caseless-E7EBKTiW',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@sindresorhus/is': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@sindresorhus/.is-g9nAs77m',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/iobroker': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.iobroker-H0DYMotS',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.node-f0Rqzy2m',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/request': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.request-jbJT2ToX',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/tough-cookie': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.tough-cookie-ZhFQ7n2j',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.sshpk-29rDccd4',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-conv': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.sshpk-conv-dbhOTJ0f',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-sign': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.sshpk-sign-0kGWm4VB',
          228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-verify': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.sshpk-verify-Bif9pYCN'
          228 silly reify }
          229 timing reify:retireShallow Completed in 216ms
          230 timing reify:createSparse Completed in 9ms
          231 timing reify:loadBundles Completed in 0ms
          232 verbose reify failed optional dependency /opt/iobroker/node_modules/fsevents
          233 silly reify mark deleted [ '/opt/iobroker/node_modules/fsevents' ]
          234 timing reifyNode:node_modules/fsevents Completed in 13ms
          235 timing reifyNode:node_modules/iobroker.vis/node_modules/axios Completed in 443ms
          236 timing reifyNode:node_modules/iobroker.javascript/node_modules/@types/node Completed in 530ms
          237 timing reifyNode:node_modules/iobroker.vis Completed in 850ms
          238 timing reify:unpack Completed in 851ms
          239 timing reify:unretire Completed in 3ms
          240 timing build:queue Completed in 3ms
          241 info run iobroker.vis@1.4.10 install node_modules/iobroker.vis node main.js --install
          242 info run iobroker.vis@1.4.10 install { code: 6, signal: null }
          243 timing reify:rollback:createSparse Completed in 366ms
          244 timing reify:rollback:retireShallow Completed in 111ms
          245 timing command:install Completed in 15673ms
          246 verbose stack Error: command failed
          246 verbose stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:63:27)
          246 verbose stack at ChildProcess.emit (node:events:513:28)
          246 verbose stack at maybeClose (node:internal/child_process:1100:16)
          246 verbose stack at Process.ChildProcess._handle.onexit (node:internal/child_process:304:5)
          247 verbose pkgid iobroker.vis@1.4.10
          248 verbose cwd /opt/iobroker
          249 verbose Linux 5.15.84-v8+
          250 verbose node v16.19.0
          251 verbose npm v8.19.3
          252 error code 6
          253 error path /opt/iobroker/node_modules/iobroker.vis
          254 error command failed
          255 error command sh -c -- node main.js --install
          256 verbose exit 6
          257 timing npm Completed in 16070ms
          258 verbose unfinished npm timer reify 1674819220592
          259 verbose unfinished npm timer reify:build 1674819232226
          260 verbose unfinished npm timer build 1674819232229
          261 verbose unfinished npm timer build:deps 1674819232230
          262 verbose unfinished npm timer build:run:install 1674819232234
          263 verbose unfinished npm timer build:run:install:node_modules/iobroker.vis 1674819232235
          264 verbose code 6
          265 error A complete log of this run can be found in:
          265 error /home/iobroker/.npm/_logs/2023-01-27T11_33_40_209Z-debug-0.log
          LG,
          w00dy
          • W w00dy
            Für mich nur Kauderwelsch 😏 . Ich hoffe, du kannst was damit anfangen....
            0 verbose cli /usr/bin/node /usr/bin/npm
            1 info using npm@8.19.3
            2 info using node@v16.19.0
            3 timing npm:load:whichnode Completed in 0ms
            4 timing config:load:defaults Completed in 6ms
            5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 2ms
            6 timing config:load:builtin Completed in 3ms
            7 timing config:load:cli Completed in 13ms
            8 timing config:load:env Completed in 1ms
            9 timing config:load:file:/opt/iobroker/.npmrc Completed in 4ms
            10 timing config:load:project Completed in 32ms
            11 timing config:load:file:/home/iobroker/.npmrc Completed in 1ms
            12 timing config:load:user Completed in 1ms
            13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
            14 timing config:load:global Completed in 0ms
            15 timing config:load:validate Completed in 1ms
            16 timing config:load:credentials Completed in 3ms
            17 timing config:load:setEnvs Completed in 4ms
            18 timing config:load Completed in 66ms
            19 timing npm:load:configload Completed in 66ms
            20 timing npm:load:mkdirpcache Completed in 3ms
            21 timing npm:load:mkdirplogs Completed in 0ms
            22 verbose title npm install iobroker.vis@1.4.10
            23 verbose argv "install" "--save-exact" "iobroker.vis@1.4.10"
            24 timing npm:load:setTitle Completed in 4ms
            25 timing config:load:flatten Completed in 12ms
            26 timing npm:load:display Completed in 14ms
            27 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs
            28 verbose logfile /home/iobroker/.npm/_logs/2023-01-27T11_33_40_209Z-debug-0.log
            29 timing npm:load:logFile Completed in 21ms
            30 timing npm:load:timers Completed in 1ms
            31 timing npm:load:configScope Completed in 0ms
            32 timing npm:load Completed in 116ms
            33 timing arborist:ctor Completed in 3ms
            34 silly logfile start cleaning logs, removing 2 files
            35 silly logfile done cleaning log files
            36 timing idealTree:init Completed in 4703ms
            37 timing idealTree:userRequests Completed in 31ms
            38 silly idealTree buildDeps
            39 silly fetch manifest iobroker.vis@1.4.10
            40 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
            41 http fetch GET 200 https://registry.npmjs.org/iobroker.vis 3328ms (cache hit)
            42 silly placeDep ROOT iobroker.vis@1.4.10 OK for: iobroker.inst@3.0.0 want: 1.4.10
            43 silly fetch manifest axios@^0.24.0
            44 http fetch GET 200 https://registry.npmjs.org/axios 2012ms (cache hit)
            45 timing idealTree:#root Completed in 5395ms
            46 silly placeDep node_modules/iobroker.vis axios@0.24.0 OK for: iobroker.vis@1.4.10 want: ^0.24.0
            47 timing idealTree:node_modules/iobroker.vis Completed in 16ms
            48 timing idealTree:node_modules/iobroker.vis/node_modules/axios Completed in 0ms
            49 timing idealTree:buildDeps Completed in 5415ms
            50 timing idealTree:fixDepFlags Completed in 41ms
            51 timing idealTree Completed in 10274ms
            52 timing reify:loadTrees Completed in 10341ms
            53 timing reify:diffTrees Completed in 192ms
            54 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv' ]
            55 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archive-type'
            55 silly reify ]
            56 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asn1' ]
            57 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/assert-plus'
            57 silly reify ]
            58 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asynckit'
            58 silly reify ]
            59 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws-sign2'
            59 silly reify ]
            60 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws4' ]
            61 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/base64-js'
            61 silly reify ]
            62 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bcrypt-pbkdf'
            62 silly reify ]
            63 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bl' ]
            64 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bluetooth-hci-socket'
            64 silly reify ]
            65 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bplist-parser'
            65 silly reify ]
            66 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer'
            66 silly reify ]
            67 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-alloc'
            67 silly reify ]
            68 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-alloc-unsafe'
            68 silly reify ]
            69 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-crc32'
            69 silly reify ]
            70 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-fill'
            70 silly reify ]
            71 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cacheable-request'
            71 silly reify ]
            72 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/call-bind'
            72 silly reify ]
            73 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/caseless'
            73 silly reify ]
            74 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-response'
            74 silly reify ]
            75 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript',
            75 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/coffee',
            75 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/cake'
            75 silly reify ]
            76 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/combined-stream'
            76 silly reify ]
            77 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/commander'
            77 silly reify ]
            78 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/content-disposition'
            78 silly reify ]
            79 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/core-util-is'
            79 silly reify ]
            80 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dashdash'
            80 silly reify ]
            81 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/debug' ]
            82 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decode-uri-component'
            82 silly reify ]
            83 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress'
            83 silly reify ]
            84 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-response'
            84 silly reify ]
            85 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-tar'
            85 silly reify ]
            86 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-tarbz2'
            86 silly reify ]
            87 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-targz'
            87 silly reify ]
            88 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-unzip'
            88 silly reify ]
            89 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/define-properties'
            89 silly reify ]
            90 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/delayed-stream'
            90 silly reify ]
            91 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/download'
            91 silly reify ]
            92 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexer3'
            92 silly reify ]
            93 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ecc-jsbn'
            93 silly reify ]
            94 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/end-of-stream'
            94 silly reify ]
            95 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ext-list'
            95 silly reify ]
            96 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ext-name'
            96 silly reify ]
            97 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extend'
            97 silly reify ]
            98 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extsprintf'
            98 silly reify ]
            99 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-deep-equal'
            99 silly reify ]
            100 silly reify mark retired [
            100 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-json-stable-stringify'
            100 silly reify ]
            101 silly reify mark retired [
            101 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fd-slicer'
            101 silly reify ]
            102 silly reify mark retired [
            102 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/file-type'
            102 silly reify ]
            103 silly reify mark retired [
            103 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/filename-reserved-regex'
            103 silly reify ]
            104 silly reify mark retired [
            104 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/filenamify'
            104 silly reify ]
            105 silly reify mark retired [
            105 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/forever-agent'
            105 silly reify ]
            106 silly reify mark retired [
            106 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/form-data'
            106 silly reify ]
            107 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/from2' ]
            108 silly reify mark retired [
            108 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fs-constants'
            108 silly reify ]
            109 silly reify mark retired [
            109 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/function-bind'
            109 silly reify ]
            110 silly reify mark retired [
            110 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/get-intrinsic'
            110 silly reify ]
            111 silly reify mark retired [
            111 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/getpass'
            111 silly reify ]
            112 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/got' ]
            113 silly reify mark retired [
            113 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/graceful-fs'
            113 silly reify ]
            114 silly reify mark retired [
            114 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-schema'
            114 silly reify ]
            115 silly reify mark retired [
            115 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-validator'
            115 silly reify ]
            116 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has' ]
            117 silly reify mark retired [
            117 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-property-descriptors'
            117 silly reify ]
            118 silly reify mark retired [
            118 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbol-support-x'
            118 silly reify ]
            119 silly reify mark retired [
            119 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbols'
            119 silly reify ]
            120 silly reify mark retired [
            120 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-to-string-tag-x'
            120 silly reify ]
            121 silly reify mark retired [
            121 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-cache-semantics'
            121 silly reify ]
            122 silly reify mark retired [
            122 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature'
            122 silly reify ]
            123 silly reify mark retired [
            123 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ieee754'
            123 silly reify ]
            124 silly reify mark retired [
            124 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/immediate'
            124 silly reify ]
            125 silly reify mark retired [
            125 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/inherits'
            125 silly reify ]
            126 silly reify mark retired [
            126 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/into-stream'
            126 silly reify ]
            127 silly reify mark retired [
            127 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-nan'
            127 silly reify ]
            128 silly reify mark retired [
            128 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-natural-number'
            128 silly reify ]
            129 silly reify mark retired [
            129 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-object'
            129 silly reify ]
            130 silly reify mark retired [
            130 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-retry-allowed'
            130 silly reify ]
            131 silly reify mark retired [
            131 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-typedarray'
            131 silly reify ]
            132 silly reify mark retired [
            132 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isarray'
            132 silly reify ]
            133 silly reify mark retired [
            133 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isstream'
            133 silly reify ]
            134 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isurl' ]
            135 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsbn' ]
            136 silly reify mark retired [
            136 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-buffer'
            136 silly reify ]
            137 silly reify mark retired [
            137 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema'
            137 silly reify ]
            138 silly reify mark retired [
            138 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema-traverse'
            138 silly reify ]
            139 silly reify mark retired [
            139 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-stringify-safe'
            139 silly reify ]
            140 silly reify mark retired [
            140 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsonata'
            140 silly reify ]
            141 silly reify mark retired [
            141 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsprim'
            141 silly reify ]
            142 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jszip' ]
            143 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/keyv' ]
            144 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lie' ]
            145 silly reify mark retired [
            145 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/long-timeout'
            145 silly reify ]
            146 silly reify mark retired [
            146 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lowercase-keys'
            146 silly reify ]
            147 silly reify mark retired [
            147 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lru-cache'
            147 silly reify ]
            148 silly reify mark retired [
            148 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/make-dir'
            148 silly reify ]
            149 silly reify mark retired [
            149 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-db'
            149 silly reify ]
            150 silly reify mark retired [
            150 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-types'
            150 silly reify ]
            151 silly reify mark retired [
            151 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mimic-response'
            151 silly reify ]
            152 silly reify mark retired [
            152 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/minimist'
            152 silly reify ]
            153 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ms' ]
            154 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/nan' ]
            155 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/noble' ]
            156 silly reify mark retired [
            156 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-addon-api'
            156 silly reify ]
            157 silly reify mark retired [
            157 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-gyp-build',
            157 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-gyp-build',
            157 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-gyp-build-optional',
            157 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-gyp-build-test'
            157 silly reify ]
            158 silly reify mark retired [
            158 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-inspect',
            158 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-inspect'
            158 silly reify ]
            159 silly reify mark retired [
            159 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/normalize-url'
            159 silly reify ]
            160 silly reify mark retired [
            160 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/oauth-sign'
            160 silly reify ]
            161 silly reify mark retired [
            161 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/object-assign'
            161 silly reify ]
            162 silly reify mark retired [
            162 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/object-keys'
            162 silly reify ]
            163 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/once' ]
            164 silly reify mark retired [
            164 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-cancelable'
            164 silly reify ]
            165 silly reify mark retired [
            165 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-event'
            165 silly reify ]
            166 silly reify mark retired [
            166 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-finally'
            166 silly reify ]
            167 silly reify mark retired [
            167 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-is-promise'
            167 silly reify ]
            168 silly reify mark retired [
            168 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-timeout'
            168 silly reify ]
            169 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pako' ]
            170 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pend' ]
            171 silly reify mark retired [
            171 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/performance-now'
            171 silly reify ]
            172 silly reify mark retired [
            172 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/picocolors'
            172 silly reify ]
            173 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pify' ]
            174 silly reify mark retired [
            174 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie'
            174 silly reify ]
            175 silly reify mark retired [
            175 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie-promise'
            175 silly reify ]
            176 silly reify mark retired [
            176 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/prepend-http'
            176 silly reify ]
            177 silly reify mark retired [
            177 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/process-nextick-args'
            177 silly reify ]
            178 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/psl' ]
            179 silly reify mark retired [
            179 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/punycode'
            179 silly reify ]
            180 silly reify mark retired [
            180 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/query-string'
            180 silly reify ]
            181 silly reify mark retired [
            181 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/readable-stream'
            181 silly reify ]
            182 silly reify mark retired [
            182 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request'
            182 silly reify ]
            183 silly reify mark retired [
            183 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/responselike'
            183 silly reify ]
            184 silly reify mark retired [
            184 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safe-buffer'
            184 silly reify ]
            185 silly reify mark retired [
            185 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safer-buffer'
            185 silly reify ]
            186 silly reify mark retired [
            186 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/seek-bzip',
            186 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/seek-bunzip',
            186 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/seek-table'
            186 silly reify ]
            187 silly reify mark retired [
            187 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/semver',
            187 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/semver'
            187 silly reify ]
            188 silly reify mark retired [
            188 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/setimmediate'
            188 silly reify ]
            189 silly reify mark retired [
            189 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sort-keys'
            189 silly reify ]
            190 silly reify mark retired [
            190 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sort-keys-length'
            190 silly reify ]
            191 silly reify mark retired [
            191 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sorted-array-functions'
            191 silly reify ]
            192 silly reify mark retired [
            192 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/strict-uri-encode'
            192 silly reify ]
            193 silly reify mark retired [
            193 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/string_decoder'
            193 silly reify ]
            194 silly reify mark retired [
            194 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-dirs'
            194 silly reify ]
            195 silly reify mark retired [
            195 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-outer'
            195 silly reify ]
            196 silly reify mark retired [
            196 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/suncalc2'
            196 silly reify ]
            197 silly reify mark retired [
            197 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tar-stream'
            197 silly reify ]
            198 silly reify mark retired [
            198 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/through'
            198 silly reify ]
            199 silly reify mark retired [
            199 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/timed-out'
            199 silly reify ]
            200 silly reify mark retired [
            200 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/to-buffer'
            200 silly reify ]
            201 silly reify mark retired [
            201 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tough-cookie'
            201 silly reify ]
            202 silly reify mark retired [
            202 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/trim-repeated'
            202 silly reify ]
            203 silly reify mark retired [
            203 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tunnel-agent'
            203 silly reify ]
            204 silly reify mark retired [
            204 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tweetnacl'
            204 silly reify ]
            205 silly reify mark retired [
            205 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript',
            205 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsc',
            205 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsserver'
            205 silly reify ]
            206 silly reify mark retired [
            206 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/unbzip2-stream'
            206 silly reify ]
            207 silly reify mark retired [
            207 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uri-js'
            207 silly reify ]
            208 silly reify mark retired [
            208 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/url-parse-lax'
            208 silly reify ]
            209 silly reify mark retired [
            209 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/url-to-options'
            209 silly reify ]
            210 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/usb' ]
            211 silly reify mark retired [
            211 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/util-deprecate'
            211 silly reify ]
            212 silly reify mark retired [
            212 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uuid',
            212 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/uuid'
            212 silly reify ]
            213 silly reify mark retired [
            213 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/verror'
            213 silly reify ]
            214 silly reify mark retired [
            214 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/virtual-tsc'
            214 silly reify ]
            215 silly reify mark retired [
            215 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/wake_on_lan',
            215 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/wake'
            215 silly reify ]
            216 silly reify mark retired [
            216 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/wrappy'
            216 silly reify ]
            217 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/xtend' ]
            218 silly reify mark retired [
            218 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/yallist'
            218 silly reify ]
            219 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/yauzl' ]
            220 silly reify mark retired [
            220 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/adapter-core'
            220 silly reify ]
            221 silly reify mark retired [
            221 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/caseless'
            221 silly reify ]
            222 silly reify mark retired [
            222 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@sindresorhus/is'
            222 silly reify ]
            223 silly reify mark retired [
            223 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/iobroker'
            223 silly reify ]
            224 silly reify mark retired [
            224 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node'
            224 silly reify ]
            225 silly reify mark retired [
            225 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/request'
            225 silly reify ]
            226 silly reify mark retired [
            226 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/tough-cookie'
            226 silly reify ]
            227 silly reify mark retired [
            227 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk',
            227 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-conv',
            227 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-sign',
            227 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-verify'
            227 silly reify ]
            228 silly reify moves {
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ajv-JWAHQ164',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archive-type': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.archive-type-3GzbVy99',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asn1': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.asn1-begjjmYE',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/assert-plus': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.assert-plus-CvwT5c2f',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asynckit': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.asynckit-s0phpr5l',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws-sign2': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.aws-sign2-i67xE5NL',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws4': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.aws4-ewgSeGU1',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/base64-js': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.base64-js-CMxDgSwp',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bcrypt-pbkdf': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bcrypt-pbkdf-FkcXJSG6',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bl': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bl-tXcstEmh',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bluetooth-hci-socket': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bluetooth-hci-socket-LLgU3d50',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bplist-parser': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bplist-parser-Gw4mjLSv',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.buffer-jMN3QEXD',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-alloc': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.buffer-alloc-X1fED6E7',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-alloc-unsafe': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.buffer-alloc-unsafe-80OHTfqv',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-crc32': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.buffer-crc32-cFTv6cUc',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-fill': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.buffer-fill-5TccPbH2',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cacheable-request': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.cacheable-request-7Qr1qFGw',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/call-bind': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.call-bind-jQ2HDLx1',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/caseless': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.caseless-H2SaxUok',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-response': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.clone-response-huORZ122',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.coffeescript-btitSxqy',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/coffee': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.coffee-Ne3HN5Co',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/cake': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.cake-vF6kAtwy',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/combined-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.combined-stream-HoYmPyrw',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/commander': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.commander-P4zg2JoS',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/content-disposition': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.content-disposition-ykNJNQbu',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/core-util-is': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.core-util-is-eZ4fUaee',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dashdash': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.dashdash-nWlk69uH',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/debug': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.debug-A3k10AtD',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decode-uri-component': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decode-uri-component-CMOQnZCN',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decompress-jANiOqwy',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-response': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decompress-response-mSREN8o7',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-tar': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decompress-tar-aFLFgMpn',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-tarbz2': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decompress-tarbz2-J0MOywyt',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-targz': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decompress-targz-NMX7flNZ',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-unzip': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decompress-unzip-SCgptaCu',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/define-properties': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.define-properties-6XwZYcVY',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/delayed-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.delayed-stream-qacC3mjc',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/download': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.download-FZgZNHG4',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexer3': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.duplexer3-GSniCpAc',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ecc-jsbn': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ecc-jsbn-W1wmyGbT',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/end-of-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.end-of-stream-pGA0SfeC',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ext-list': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ext-list-CbquslXA',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ext-name': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ext-name-w2cAb5N9',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extend': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.extend-pv2WceUi',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extsprintf': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.extsprintf-l37IDaAf',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-deep-equal': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.fast-deep-equal-JqieQuGS',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-json-stable-stringify': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.fast-json-stable-stringify-zZtSpvEn',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fd-slicer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.fd-slicer-CGbB7jDs',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/file-type': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.file-type-MyF2AuGo',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/filename-reserved-regex': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.filename-reserved-regex-NQVIkyqX',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/filenamify': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.filenamify-055Pvtkk',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/forever-agent': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.forever-agent-hJzMqug0',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/form-data': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.form-data-f5gN4soy',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/from2': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.from2-rHxymetq',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fs-constants': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.fs-constants-RCPP7GAQ',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/function-bind': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.function-bind-xNuYoKHH',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/get-intrinsic': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.get-intrinsic-jaHndEV0',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/getpass': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.getpass-kOCUh1aA',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/got': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.got-LoRNXoPs',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/graceful-fs': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.graceful-fs-0lTymp4w',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-schema': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.har-schema-rWbJu3Hi',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-validator': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.har-validator-eyrBsHVJ',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.has-xBeCSK4w',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-property-descriptors': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.has-property-descriptors-NgHV0bqO',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbol-support-x': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.has-symbol-support-x-kJ1XKcwn',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbols': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.has-symbols-BlLhZd6T',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-to-string-tag-x': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.has-to-string-tag-x-D0rqbi1N',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-cache-semantics': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.http-cache-semantics-pwHcy6Um',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.http-signature-oUoVxdIq',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ieee754': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ieee754-ZkXktYfP',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/immediate': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.immediate-mU3gxEZk',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/inherits': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.inherits-n3Ch46Yn',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/into-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.into-stream-9jikZ2iK',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-nan': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.is-nan-aBR69xZy',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-natural-number': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.is-natural-number-7DVP81Ku',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-object': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.is-object-f37RttIf',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-retry-allowed': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.is-retry-allowed-bbEHMwWr',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-typedarray': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.is-typedarray-kgxdw7hd',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isarray': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.isarray-5wOzaH7B',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isstream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.isstream-kucfBgOe',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isurl': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.isurl-PFPtYcIS',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsbn': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.jsbn-7awNYEqn',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-buffer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.json-buffer-1DvjfwxG',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.json-schema-gJeujQHS',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema-traverse': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.json-schema-traverse-lxkTlMes',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-stringify-safe': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.json-stringify-safe-6OEF7DXQ',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsonata': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.jsonata-sj644a8k',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsprim': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.jsprim-Hb03jZ2t',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jszip': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.jszip-E0haUyzW',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/keyv': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.keyv-j7k6j1x3',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lie': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.lie-rDNcdBdn',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/long-timeout': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.long-timeout-UsqWplKY',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lowercase-keys': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.lowercase-keys-H4pYv5DL',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lru-cache': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.lru-cache-pTWFZBit',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/make-dir': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.make-dir-kpACuPQc',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-db': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.mime-db-ILNMz48k',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-types': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.mime-types-vVlqwvNj',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mimic-response': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.mimic-response-l1h59Fzs',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/minimist': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.minimist-HEtqlfZM',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ms': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ms-T3oF4fuS',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/nan': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.nan-adtTkJBo',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/noble': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.noble-UcE4HbYj',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-addon-api': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.node-addon-api-zOIY1GW8',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-gyp-build': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.node-gyp-build-Nc8n2hOB',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-gyp-build': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.node-gyp-build-L57SCOlW',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-gyp-build-optional': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.node-gyp-build-optional-Tk80r8za',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-gyp-build-test': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.node-gyp-build-test-izfPMJbu',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-inspect': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.node-inspect-7uCQsf40',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-inspect': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.node-inspect-RjTdcqZj',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/normalize-url': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.normalize-url-dTP3Oa7k',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/oauth-sign': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.oauth-sign-4TUsb1Hr',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/object-assign': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.object-assign-5Cf04ud8',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/object-keys': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.object-keys-L9W7bKqM',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/once': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.once-RFC770N3',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-cancelable': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.p-cancelable-u9fp3HLr',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-event': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.p-event-E5j32boQ',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-finally': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.p-finally-L9V5raVS',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-is-promise': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.p-is-promise-tNH5kneE',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-timeout': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.p-timeout-eSN8lQGZ',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pako': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.pako-rbL7BtOy',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pend': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.pend-BYTjI9Hf',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/performance-now': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.performance-now-rzc7QsAk',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/picocolors': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.picocolors-DQ4TN0mE',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pify': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.pify-kU90vZ0r',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.pinkie-7z22R4ew',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie-promise': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.pinkie-promise-6MuYHt6L',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/prepend-http': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.prepend-http-oFgNJ3Hh',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/process-nextick-args': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.process-nextick-args-1FsUsOM8',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/psl': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.psl-P3JlcAO8',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/punycode': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.punycode-l3TLrnOQ',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/query-string': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.query-string-3uidnXUa',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/readable-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.readable-stream-DGJrLMhV',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.request-IwHtFKjv',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/responselike': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.responselike-tYm4pETH',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safe-buffer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.safe-buffer-GY19LMpy',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safer-buffer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.safer-buffer-VoLQjGhM',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/seek-bzip': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.seek-bzip-JAWtZniv',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/seek-bunzip': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.seek-bunzip-CkVLvAS4',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/seek-table': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.seek-table-f3sdHWHj',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/semver': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.semver-nXF4HfsQ',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/semver': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.semver-Dy7i6zG2',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/setimmediate': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.setimmediate-rLmz5kvN',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sort-keys': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.sort-keys-qcvjMZ6g',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sort-keys-length': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.sort-keys-length-4IGif44d',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sorted-array-functions': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.sorted-array-functions-b2PxWBDs',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/strict-uri-encode': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.strict-uri-encode-WyOTcxtB',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/string_decoder': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.string_decoder-QqeclkYI',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-dirs': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.strip-dirs-8hbG4Qht',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-outer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.strip-outer-syQyolcG',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/suncalc2': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.suncalc2-tGRLIVnX',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tar-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.tar-stream-oOO7qk7O',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/through': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.through-fysaHtUl',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/timed-out': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.timed-out-wvGaABGU',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/to-buffer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.to-buffer-ZDZJ5ICv',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tough-cookie': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.tough-cookie-msAnSxYU',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/trim-repeated': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.trim-repeated-p6XbDaUh',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tunnel-agent': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.tunnel-agent-oUVQRXxE',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tweetnacl': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.tweetnacl-BnSTSyIu',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.typescript-EcwXdkx5',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsc': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.tsc-0PIrZBWg',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsserver': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.tsserver-QDbM4cAE',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/unbzip2-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.unbzip2-stream-7cC95xXq',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uri-js': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.uri-js-8VwjhWYz',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/url-parse-lax': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.url-parse-lax-L4Pi5Fdr',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/url-to-options': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.url-to-options-VEmeYCpr',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/usb': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.usb-eaYctfOO',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/util-deprecate': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.util-deprecate-e5GNBBxw',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uuid': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.uuid-0rL1ORyz',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/uuid': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.uuid-gQ53C49H',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/verror': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.verror-EsRYTvUd',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/virtual-tsc': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.virtual-tsc-Z1y2mItj',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/wake_on_lan': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.wake_on_lan-aA1sq5Hq',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/wake': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.wake-PZWgBD8w',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/wrappy': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.wrappy-FK4KH90e',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/xtend': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.xtend-kCzojcVd',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/yallist': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.yallist-Jj27Vzng',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/yauzl': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.yauzl-I4OoZHvp',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/adapter-core': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/.adapter-core-5hqHvhca',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/caseless': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.caseless-E7EBKTiW',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@sindresorhus/is': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@sindresorhus/.is-g9nAs77m',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/iobroker': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.iobroker-H0DYMotS',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.node-f0Rqzy2m',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/request': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.request-jbJT2ToX',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/tough-cookie': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.tough-cookie-ZhFQ7n2j',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.sshpk-29rDccd4',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-conv': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.sshpk-conv-dbhOTJ0f',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-sign': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.sshpk-sign-0kGWm4VB',
            228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-verify': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.sshpk-verify-Bif9pYCN'
            228 silly reify }
            229 timing reify:retireShallow Completed in 216ms
            230 timing reify:createSparse Completed in 9ms
            231 timing reify:loadBundles Completed in 0ms
            232 verbose reify failed optional dependency /opt/iobroker/node_modules/fsevents
            233 silly reify mark deleted [ '/opt/iobroker/node_modules/fsevents' ]
            234 timing reifyNode:node_modules/fsevents Completed in 13ms
            235 timing reifyNode:node_modules/iobroker.vis/node_modules/axios Completed in 443ms
            236 timing reifyNode:node_modules/iobroker.javascript/node_modules/@types/node Completed in 530ms
            237 timing reifyNode:node_modules/iobroker.vis Completed in 850ms
            238 timing reify:unpack Completed in 851ms
            239 timing reify:unretire Completed in 3ms
            240 timing build:queue Completed in 3ms
            241 info run iobroker.vis@1.4.10 install node_modules/iobroker.vis node main.js --install
            242 info run iobroker.vis@1.4.10 install { code: 6, signal: null }
            243 timing reify:rollback:createSparse Completed in 366ms
            244 timing reify:rollback:retireShallow Completed in 111ms
            245 timing command:install Completed in 15673ms
            246 verbose stack Error: command failed
            246 verbose stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:63:27)
            246 verbose stack at ChildProcess.emit (node:events:513:28)
            246 verbose stack at maybeClose (node:internal/child_process:1100:16)
            246 verbose stack at Process.ChildProcess._handle.onexit (node:internal/child_process:304:5)
            247 verbose pkgid iobroker.vis@1.4.10
            248 verbose cwd /opt/iobroker
            249 verbose Linux 5.15.84-v8+
            250 verbose node v16.19.0
            251 verbose npm v8.19.3
            252 error code 6
            253 error path /opt/iobroker/node_modules/iobroker.vis
            254 error command failed
            255 error command sh -c -- node main.js --install
            256 verbose exit 6
            257 timing npm Completed in 16070ms
            258 verbose unfinished npm timer reify 1674819220592
            259 verbose unfinished npm timer reify:build 1674819232226
            260 verbose unfinished npm timer build 1674819232229
            261 verbose unfinished npm timer build:deps 1674819232230
            262 verbose unfinished npm timer build:run:install 1674819232234
            263 verbose unfinished npm timer build:run:install:node_modules/iobroker.vis 1674819232235
            264 verbose code 6
            265 error A complete log of this run can be found in:
            265 error /home/iobroker/.npm/_logs/2023-01-27T11_33_40_209Z-debug-0.log
            DJMarc75D Offline
            DJMarc75D Offline
            DJMarc75
            @w00dy nicht in Spoiler sondern Codetags reinsetzen bitte
            Lehrling seit 1975 !!!
            W 1 Antwort Letzte Antwort
            • DJMarc75D DJMarc75
              W Offline
              W Offline
              w00dy
              @djmarc75 ...geht nicht, da zu lang!
              LG,
              w00dy
              • W w00dy
                DJMarc75D Offline
                DJMarc75D Offline
                DJMarc75
                @w00dy
                0 verbose cli /usr/bin/node /usr/bin/npm
                1 info using npm@8.19.3
                2 info using node@v16.19.0
                3 timing npm:load:whichnode Completed in 0ms
                4 timing config:load:defaults Completed in 6ms
                5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 2ms
                6 timing config:load:builtin Completed in 3ms
                7 timing config:load:cli Completed in 13ms
                8 timing config:load:env Completed in 1ms
                9 timing config:load:file:/opt/iobroker/.npmrc Completed in 4ms
                10 timing config:load:project Completed in 32ms
                11 timing config:load:file:/home/iobroker/.npmrc Completed in 1ms
                12 timing config:load:user Completed in 1ms
                13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
                14 timing config:load:global Completed in 0ms
                15 timing config:load:validate Completed in 1ms
                16 timing config:load:credentials Completed in 3ms
                17 timing config:load:setEnvs Completed in 4ms
                18 timing config:load Completed in 66ms
                19 timing npm:load:configload Completed in 66ms
                20 timing npm:load:mkdirpcache Completed in 3ms
                21 timing npm:load:mkdirplogs Completed in 0ms
                22 verbose title npm install iobroker.vis@1.4.10
                23 verbose argv "install" "--save-exact" "iobroker.vis@1.4.10"
                24 timing npm:load:setTitle Completed in 4ms
                25 timing config:load:flatten Completed in 12ms
                26 timing npm:load:display Completed in 14ms
                27 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs
                28 verbose logfile /home/iobroker/.npm/_logs/2023-01-27T11_33_40_209Z-debug-0.log
                29 timing npm:load:logFile Completed in 21ms
                30 timing npm:load:timers Completed in 1ms
                31 timing npm:load:configScope Completed in 0ms
                32 timing npm:load Completed in 116ms
                33 timing arborist:ctor Completed in 3ms
                34 silly logfile start cleaning logs, removing 2 files
                35 silly logfile done cleaning log files
                36 timing idealTree:init Completed in 4703ms
                37 timing idealTree:userRequests Completed in 31ms
                38 silly idealTree buildDeps
                39 silly fetch manifest iobroker.vis@1.4.10
                40 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
                41 http fetch GET 200 https://registry.npmjs.org/iobroker.vis 3328ms (cache hit)
                42 silly placeDep ROOT iobroker.vis@1.4.10 OK for: iobroker.inst@3.0.0 want: 1.4.10
                43 silly fetch manifest axios@^0.24.0
                44 http fetch GET 200 https://registry.npmjs.org/axios 2012ms (cache hit)
                45 timing idealTree:#root Completed in 5395ms
                46 silly placeDep node_modules/iobroker.vis axios@0.24.0 OK for: iobroker.vis@1.4.10 want: ^0.24.0
                47 timing idealTree:node_modules/iobroker.vis Completed in 16ms
                48 timing idealTree:node_modules/iobroker.vis/node_modules/axios Completed in 0ms
                49 timing idealTree:buildDeps Completed in 5415ms
                50 timing idealTree:fixDepFlags Completed in 41ms
                51 timing idealTree Completed in 10274ms
                52 timing reify:loadTrees Completed in 10341ms
                53 timing reify:diffTrees Completed in 192ms
                54 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv' ]
                55 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archive-type'
                55 silly reify ]
                56 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asn1' ]
                57 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/assert-plus'
                57 silly reify ]
                58 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asynckit'
                58 silly reify ]
                59 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws-sign2'
                59 silly reify ]
                60 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws4' ]
                61 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/base64-js'
                61 silly reify ]
                62 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bcrypt-pbkdf'
                62 silly reify ]
                63 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bl' ]
                64 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bluetooth-hci-socket'
                64 silly reify ]
                65 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bplist-parser'
                65 silly reify ]
                66 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer'
                66 silly reify ]
                67 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-alloc'
                67 silly reify ]
                68 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-alloc-unsafe'
                68 silly reify ]
                69 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-crc32'
                69 silly reify ]
                70 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-fill'
                70 silly reify ]
                71 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cacheable-request'
                71 silly reify ]
                72 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/call-bind'
                72 silly reify ]
                73 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/caseless'
                73 silly reify ]
                74 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-response'
                74 silly reify ]
                75 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript',
                75 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/coffee',
                75 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/cake'
                75 silly reify ]
                76 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/combined-stream'
                76 silly reify ]
                77 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/commander'
                77 silly reify ]
                78 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/content-disposition'
                78 silly reify ]
                79 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/core-util-is'
                79 silly reify ]
                80 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dashdash'
                80 silly reify ]
                81 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/debug' ]
                82 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decode-uri-component'
                82 silly reify ]
                83 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress'
                83 silly reify ]
                84 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-response'
                84 silly reify ]
                85 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-tar'
                85 silly reify ]
                86 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-tarbz2'
                86 silly reify ]
                87 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-targz'
                87 silly reify ]
                88 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-unzip'
                88 silly reify ]
                89 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/define-properties'
                89 silly reify ]
                90 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/delayed-stream'
                90 silly reify ]
                91 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/download'
                91 silly reify ]
                92 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexer3'
                92 silly reify ]
                93 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ecc-jsbn'
                93 silly reify ]
                94 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/end-of-stream'
                94 silly reify ]
                95 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ext-list'
                95 silly reify ]
                96 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ext-name'
                96 silly reify ]
                97 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extend'
                97 silly reify ]
                98 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extsprintf'
                98 silly reify ]
                99 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-deep-equal'
                99 silly reify ]
                100 silly reify mark retired [
                100 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-json-stable-stringify'
                100 silly reify ]
                101 silly reify mark retired [
                101 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fd-slicer'
                101 silly reify ]
                102 silly reify mark retired [
                102 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/file-type'
                102 silly reify ]
                103 silly reify mark retired [
                103 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/filename-reserved-regex'
                103 silly reify ]
                104 silly reify mark retired [
                104 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/filenamify'
                104 silly reify ]
                105 silly reify mark retired [
                105 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/forever-agent'
                105 silly reify ]
                106 silly reify mark retired [
                106 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/form-data'
                106 silly reify ]
                107 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/from2' ]
                108 silly reify mark retired [
                108 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fs-constants'
                108 silly reify ]
                109 silly reify mark retired [
                109 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/function-bind'
                109 silly reify ]
                110 silly reify mark retired [
                110 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/get-intrinsic'
                110 silly reify ]
                111 silly reify mark retired [
                111 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/getpass'
                111 silly reify ]
                112 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/got' ]
                113 silly reify mark retired [
                113 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/graceful-fs'
                113 silly reify ]
                114 silly reify mark retired [
                114 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-schema'
                114 silly reify ]
                115 silly reify mark retired [
                115 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-validator'
                115 silly reify ]
                116 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has' ]
                117 silly reify mark retired [
                117 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-property-descriptors'
                117 silly reify ]
                118 silly reify mark retired [
                118 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbol-support-x'
                118 silly reify ]
                119 silly reify mark retired [
                119 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbols'
                119 silly reify ]
                120 silly reify mark retired [
                120 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-to-string-tag-x'
                120 silly reify ]
                121 silly reify mark retired [
                121 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-cache-semantics'
                121 silly reify ]
                122 silly reify mark retired [
                122 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature'
                122 silly reify ]
                123 silly reify mark retired [
                123 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ieee754'
                123 silly reify ]
                124 silly reify mark retired [
                124 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/immediate'
                124 silly reify ]
                125 silly reify mark retired [
                125 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/inherits'
                125 silly reify ]
                126 silly reify mark retired [
                126 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/into-stream'
                126 silly reify ]
                127 silly reify mark retired [
                127 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-nan'
                127 silly reify ]
                128 silly reify mark retired [
                128 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-natural-number'
                128 silly reify ]
                129 silly reify mark retired [
                129 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-object'
                129 silly reify ]
                130 silly reify mark retired [
                130 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-retry-allowed'
                130 silly reify ]
                131 silly reify mark retired [
                131 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-typedarray'
                131 silly reify ]
                132 silly reify mark retired [
                132 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isarray'
                132 silly reify ]
                133 silly reify mark retired [
                133 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isstream'
                133 silly reify ]
                134 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isurl' ]
                135 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsbn' ]
                136 silly reify mark retired [
                136 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-buffer'
                136 silly reify ]
                137 silly reify mark retired [
                137 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema'
                137 silly reify ]
                138 silly reify mark retired [
                138 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema-traverse'
                138 silly reify ]
                139 silly reify mark retired [
                139 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-stringify-safe'
                139 silly reify ]
                140 silly reify mark retired [
                140 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsonata'
                140 silly reify ]
                141 silly reify mark retired [
                141 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsprim'
                141 silly reify ]
                142 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jszip' ]
                143 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/keyv' ]
                144 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lie' ]
                145 silly reify mark retired [
                145 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/long-timeout'
                145 silly reify ]
                146 silly reify mark retired [
                146 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lowercase-keys'
                146 silly reify ]
                147 silly reify mark retired [
                147 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lru-cache'
                147 silly reify ]
                148 silly reify mark retired [
                148 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/make-dir'
                148 silly reify ]
                149 silly reify mark retired [
                149 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-db'
                149 silly reify ]
                150 silly reify mark retired [
                150 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-types'
                150 silly reify ]
                151 silly reify mark retired [
                151 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mimic-response'
                151 silly reify ]
                152 silly reify mark retired [
                152 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/minimist'
                152 silly reify ]
                153 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ms' ]
                154 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/nan' ]
                155 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/noble' ]
                156 silly reify mark retired [
                156 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-addon-api'
                156 silly reify ]
                157 silly reify mark retired [
                157 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-gyp-build',
                157 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-gyp-build',
                157 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-gyp-build-optional',
                157 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-gyp-build-test'
                157 silly reify ]
                158 silly reify mark retired [
                158 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-inspect',
                158 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-inspect'
                158 silly reify ]
                159 silly reify mark retired [
                159 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/normalize-url'
                159 silly reify ]
                160 silly reify mark retired [
                160 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/oauth-sign'
                160 silly reify ]
                161 silly reify mark retired [
                161 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/object-assign'
                161 silly reify ]
                162 silly reify mark retired [
                162 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/object-keys'
                162 silly reify ]
                163 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/once' ]
                164 silly reify mark retired [
                164 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-cancelable'
                164 silly reify ]
                165 silly reify mark retired [
                165 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-event'
                165 silly reify ]
                166 silly reify mark retired [
                166 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-finally'
                166 silly reify ]
                167 silly reify mark retired [
                167 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-is-promise'
                167 silly reify ]
                168 silly reify mark retired [
                168 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-timeout'
                168 silly reify ]
                169 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pako' ]
                170 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pend' ]
                171 silly reify mark retired [
                171 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/performance-now'
                171 silly reify ]
                172 silly reify mark retired [
                172 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/picocolors'
                172 silly reify ]
                173 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pify' ]
                174 silly reify mark retired [
                174 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie'
                174 silly reify ]
                175 silly reify mark retired [
                175 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie-promise'
                175 silly reify ]
                176 silly reify mark retired [
                176 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/prepend-http'
                176 silly reify ]
                177 silly reify mark retired [
                177 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/process-nextick-args'
                177 silly reify ]
                178 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/psl' ]
                179 silly reify mark retired [
                179 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/punycode'
                179 silly reify ]
                180 silly reify mark retired [
                180 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/query-string'
                180 silly reify ]
                181 silly reify mark retired [
                181 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/readable-stream'
                181 silly reify ]
                182 silly reify mark retired [
                182 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request'
                182 silly reify ]
                183 silly reify mark retired [
                183 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/responselike'
                183 silly reify ]
                184 silly reify mark retired [
                184 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safe-buffer'
                184 silly reify ]
                185 silly reify mark retired [
                185 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safer-buffer'
                185 silly reify ]
                186 silly reify mark retired [
                186 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/seek-bzip',
                186 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/seek-bunzip',
                186 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/seek-table'
                186 silly reify ]
                187 silly reify mark retired [
                187 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/semver',
                187 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/semver'
                187 silly reify ]
                188 silly reify mark retired [
                188 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/setimmediate'
                188 silly reify ]
                189 silly reify mark retired [
                189 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sort-keys'
                189 silly reify ]
                190 silly reify mark retired [
                190 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sort-keys-length'
                190 silly reify ]
                191 silly reify mark retired [
                191 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sorted-array-functions'
                191 silly reify ]
                192 silly reify mark retired [
                192 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/strict-uri-encode'
                192 silly reify ]
                193 silly reify mark retired [
                193 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/string_decoder'
                193 silly reify ]
                194 silly reify mark retired [
                194 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-dirs'
                194 silly reify ]
                195 silly reify mark retired [
                195 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-outer'
                195 silly reify ]
                196 silly reify mark retired [
                196 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/suncalc2'
                196 silly reify ]
                197 silly reify mark retired [
                197 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tar-stream'
                197 silly reify ]
                198 silly reify mark retired [
                198 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/through'
                198 silly reify ]
                199 silly reify mark retired [
                199 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/timed-out'
                199 silly reify ]
                200 silly reify mark retired [
                200 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/to-buffer'
                200 silly reify ]
                201 silly reify mark retired [
                201 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tough-cookie'
                201 silly reify ]
                202 silly reify mark retired [
                202 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/trim-repeated'
                202 silly reify ]
                203 silly reify mark retired [
                203 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tunnel-agent'
                203 silly reify ]
                204 silly reify mark retired [
                204 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tweetnacl'
                204 silly reify ]
                205 silly reify mark retired [
                205 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript',
                205 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsc',
                205 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsserver'
                205 silly reify ]
                206 silly reify mark retired [
                206 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/unbzip2-stream'
                206 silly reify ]
                207 silly reify mark retired [
                207 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uri-js'
                207 silly reify ]
                208 silly reify mark retired [
                208 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/url-parse-lax'
                208 silly reify ]
                209 silly reify mark retired [
                209 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/url-to-options'
                209 silly reify ]
                210 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/usb' ]
                211 silly reify mark retired [
                211 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/util-deprecate'
                211 silly reify ]
                212 silly reify mark retired [
                212 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uuid',
                212 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/uuid'
                212 silly reify ]
                213 silly reify mark retired [
                213 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/verror'
                213 silly reify ]
                214 silly reify mark retired [
                214 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/virtual-tsc'
                214 silly reify ]
                215 silly reify mark retired [
                215 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/wake_on_lan',
                215 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/wake'
                215 silly reify ]
                216 silly reify mark retired [
                216 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/wrappy'
                216 silly reify ]
                217 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/xtend' ]
                218 silly reify mark retired [
                218 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/yallist'
                218 silly reify ]
                219 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/yauzl' ]
                220 silly reify mark retired [
                220 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/adapter-core'
                220 silly reify ]
                221 silly reify mark retired [
                221 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/caseless'
                221 silly reify ]
                222 silly reify mark retired [
                222 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@sindresorhus/is'
                222 silly reify ]
                223 silly reify mark retired [
                223 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/iobroker'
                223 silly reify ]
                224 silly reify mark retired [
                224 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node'
                224 silly reify ]
                225 silly reify mark retired [
                225 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/request'
                225 silly reify ]
                226 silly reify mark retired [
                226 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/tough-cookie'
                226 silly reify ]
                227 silly reify mark retired [
                227 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk',
                227 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-conv',
                227 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-sign',
                227 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-verify'
                227 silly reify ]
                228 silly reify moves {
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ajv-JWAHQ164',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archive-type': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.archive-type-3GzbVy99',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asn1': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.asn1-begjjmYE',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/assert-plus': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.assert-plus-CvwT5c2f',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asynckit': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.asynckit-s0phpr5l',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws-sign2': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.aws-sign2-i67xE5NL',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws4': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.aws4-ewgSeGU1',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/base64-js': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.base64-js-CMxDgSwp',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bcrypt-pbkdf': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bcrypt-pbkdf-FkcXJSG6',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bl': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bl-tXcstEmh',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bluetooth-hci-socket': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bluetooth-hci-socket-LLgU3d50',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bplist-parser': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bplist-parser-Gw4mjLSv',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.buffer-jMN3QEXD',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-alloc': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.buffer-alloc-X1fED6E7',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-alloc-unsafe': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.buffer-alloc-unsafe-80OHTfqv',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-crc32': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.buffer-crc32-cFTv6cUc',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-fill': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.buffer-fill-5TccPbH2',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cacheable-request': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.cacheable-request-7Qr1qFGw',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/call-bind': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.call-bind-jQ2HDLx1',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/caseless': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.caseless-H2SaxUok',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-response': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.clone-response-huORZ122',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.coffeescript-btitSxqy',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/coffee': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.coffee-Ne3HN5Co',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/cake': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.cake-vF6kAtwy',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/combined-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.combined-stream-HoYmPyrw',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/commander': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.commander-P4zg2JoS',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/content-disposition': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.content-disposition-ykNJNQbu',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/core-util-is': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.core-util-is-eZ4fUaee',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dashdash': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.dashdash-nWlk69uH',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/debug': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.debug-A3k10AtD',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decode-uri-component': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decode-uri-component-CMOQnZCN',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decompress-jANiOqwy',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-response': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decompress-response-mSREN8o7',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-tar': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decompress-tar-aFLFgMpn',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-tarbz2': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decompress-tarbz2-J0MOywyt',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-targz': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decompress-targz-NMX7flNZ',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-unzip': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decompress-unzip-SCgptaCu',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/define-properties': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.define-properties-6XwZYcVY',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/delayed-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.delayed-stream-qacC3mjc',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/download': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.download-FZgZNHG4',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexer3': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.duplexer3-GSniCpAc',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ecc-jsbn': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ecc-jsbn-W1wmyGbT',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/end-of-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.end-of-stream-pGA0SfeC',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ext-list': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ext-list-CbquslXA',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ext-name': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ext-name-w2cAb5N9',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extend': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.extend-pv2WceUi',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extsprintf': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.extsprintf-l37IDaAf',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-deep-equal': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.fast-deep-equal-JqieQuGS',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-json-stable-stringify': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.fast-json-stable-stringify-zZtSpvEn',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fd-slicer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.fd-slicer-CGbB7jDs',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/file-type': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.file-type-MyF2AuGo',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/filename-reserved-regex': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.filename-reserved-regex-NQVIkyqX',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/filenamify': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.filenamify-055Pvtkk',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/forever-agent': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.forever-agent-hJzMqug0',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/form-data': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.form-data-f5gN4soy',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/from2': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.from2-rHxymetq',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fs-constants': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.fs-constants-RCPP7GAQ',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/function-bind': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.function-bind-xNuYoKHH',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/get-intrinsic': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.get-intrinsic-jaHndEV0',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/getpass': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.getpass-kOCUh1aA',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/got': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.got-LoRNXoPs',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/graceful-fs': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.graceful-fs-0lTymp4w',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-schema': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.har-schema-rWbJu3Hi',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-validator': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.har-validator-eyrBsHVJ',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.has-xBeCSK4w',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-property-descriptors': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.has-property-descriptors-NgHV0bqO',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbol-support-x': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.has-symbol-support-x-kJ1XKcwn',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbols': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.has-symbols-BlLhZd6T',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-to-string-tag-x': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.has-to-string-tag-x-D0rqbi1N',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-cache-semantics': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.http-cache-semantics-pwHcy6Um',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.http-signature-oUoVxdIq',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ieee754': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ieee754-ZkXktYfP',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/immediate': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.immediate-mU3gxEZk',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/inherits': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.inherits-n3Ch46Yn',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/into-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.into-stream-9jikZ2iK',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-nan': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.is-nan-aBR69xZy',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-natural-number': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.is-natural-number-7DVP81Ku',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-object': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.is-object-f37RttIf',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-retry-allowed': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.is-retry-allowed-bbEHMwWr',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-typedarray': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.is-typedarray-kgxdw7hd',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isarray': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.isarray-5wOzaH7B',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isstream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.isstream-kucfBgOe',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isurl': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.isurl-PFPtYcIS',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsbn': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.jsbn-7awNYEqn',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-buffer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.json-buffer-1DvjfwxG',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.json-schema-gJeujQHS',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema-traverse': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.json-schema-traverse-lxkTlMes',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-stringify-safe': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.json-stringify-safe-6OEF7DXQ',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsonata': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.jsonata-sj644a8k',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsprim': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.jsprim-Hb03jZ2t',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jszip': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.jszip-E0haUyzW',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/keyv': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.keyv-j7k6j1x3',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lie': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.lie-rDNcdBdn',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/long-timeout': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.long-timeout-UsqWplKY',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lowercase-keys': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.lowercase-keys-H4pYv5DL',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lru-cache': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.lru-cache-pTWFZBit',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/make-dir': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.make-dir-kpACuPQc',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-db': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.mime-db-ILNMz48k',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-types': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.mime-types-vVlqwvNj',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mimic-response': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.mimic-response-l1h59Fzs',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/minimist': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.minimist-HEtqlfZM',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ms': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ms-T3oF4fuS',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/nan': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.nan-adtTkJBo',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/noble': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.noble-UcE4HbYj',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-addon-api': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.node-addon-api-zOIY1GW8',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-gyp-build': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.node-gyp-build-Nc8n2hOB',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-gyp-build': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.node-gyp-build-L57SCOlW',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-gyp-build-optional': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.node-gyp-build-optional-Tk80r8za',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-gyp-build-test': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.node-gyp-build-test-izfPMJbu',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-inspect': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.node-inspect-7uCQsf40',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-inspect': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.node-inspect-RjTdcqZj',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/normalize-url': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.normalize-url-dTP3Oa7k',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/oauth-sign': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.oauth-sign-4TUsb1Hr',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/object-assign': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.object-assign-5Cf04ud8',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/object-keys': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.object-keys-L9W7bKqM',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/once': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.once-RFC770N3',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-cancelable': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.p-cancelable-u9fp3HLr',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-event': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.p-event-E5j32boQ',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-finally': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.p-finally-L9V5raVS',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-is-promise': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.p-is-promise-tNH5kneE',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-timeout': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.p-timeout-eSN8lQGZ',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pako': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.pako-rbL7BtOy',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pend': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.pend-BYTjI9Hf',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/performance-now': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.performance-now-rzc7QsAk',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/picocolors': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.picocolors-DQ4TN0mE',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pify': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.pify-kU90vZ0r',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.pinkie-7z22R4ew',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie-promise': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.pinkie-promise-6MuYHt6L',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/prepend-http': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.prepend-http-oFgNJ3Hh',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/process-nextick-args': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.process-nextick-args-1FsUsOM8',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/psl': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.psl-P3JlcAO8',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/punycode': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.punycode-l3TLrnOQ',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/query-string': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.query-string-3uidnXUa',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/readable-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.readable-stream-DGJrLMhV',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.request-IwHtFKjv',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/responselike': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.responselike-tYm4pETH',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safe-buffer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.safe-buffer-GY19LMpy',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safer-buffer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.safer-buffer-VoLQjGhM',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/seek-bzip': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.seek-bzip-JAWtZniv',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/seek-bunzip': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.seek-bunzip-CkVLvAS4',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/seek-table': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.seek-table-f3sdHWHj',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/semver': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.semver-nXF4HfsQ',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/semver': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.semver-Dy7i6zG2',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/setimmediate': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.setimmediate-rLmz5kvN',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sort-keys': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.sort-keys-qcvjMZ6g',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sort-keys-length': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.sort-keys-length-4IGif44d',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sorted-array-functions': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.sorted-array-functions-b2PxWBDs',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/strict-uri-encode': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.strict-uri-encode-WyOTcxtB',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/string_decoder': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.string_decoder-QqeclkYI',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-dirs': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.strip-dirs-8hbG4Qht',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-outer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.strip-outer-syQyolcG',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/suncalc2': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.suncalc2-tGRLIVnX',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tar-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.tar-stream-oOO7qk7O',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/through': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.through-fysaHtUl',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/timed-out': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.timed-out-wvGaABGU',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/to-buffer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.to-buffer-ZDZJ5ICv',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tough-cookie': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.tough-cookie-msAnSxYU',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/trim-repeated': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.trim-repeated-p6XbDaUh',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tunnel-agent': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.tunnel-agent-oUVQRXxE',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tweetnacl': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.tweetnacl-BnSTSyIu',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.typescript-EcwXdkx5',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsc': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.tsc-0PIrZBWg',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsserver': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.tsserver-QDbM4cAE',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/unbzip2-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.unbzip2-stream-7cC95xXq',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uri-js': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.uri-js-8VwjhWYz',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/url-parse-lax': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.url-parse-lax-L4Pi5Fdr',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/url-to-options': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.url-to-options-VEmeYCpr',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/usb': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.usb-eaYctfOO',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/util-deprecate': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.util-deprecate-e5GNBBxw',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uuid': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.uuid-0rL1ORyz',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/uuid': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.uuid-gQ53C49H',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/verror': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.verror-EsRYTvUd',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/virtual-tsc': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.virtual-tsc-Z1y2mItj',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/wake_on_lan': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.wake_on_lan-aA1sq5Hq',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/wake': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.wake-PZWgBD8w',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/wrappy': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.wrappy-FK4KH90e',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/xtend': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.xtend-kCzojcVd',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/yallist': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.yallist-Jj27Vzng',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/yauzl': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.yauzl-I4OoZHvp',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/adapter-core': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/.adapter-core-5hqHvhca',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/caseless': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.caseless-E7EBKTiW',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@sindresorhus/is': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@sindresorhus/.is-g9nAs77m',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/iobroker': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.iobroker-H0DYMotS',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.node-f0Rqzy2m',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/request': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.request-jbJT2ToX',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/tough-cookie': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.tough-cookie-ZhFQ7n2j',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.sshpk-29rDccd4',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-conv': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.sshpk-conv-dbhOTJ0f',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-sign': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.sshpk-sign-0kGWm4VB',
                228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-verify': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.sshpk-verify-Bif9pYCN'
                228 silly reify }
                229 timing reify:retireShallow Completed in 216ms
                230 timing reify:createSparse Completed in 9ms
                231 timing reify:loadBundles Completed in 0ms
                232 verbose reify failed optional dependency /opt/iobroker/node_modules/fsevents
                233 silly reify mark deleted [ '/opt/iobroker/node_modules/fsevents' ]
                234 timing reifyNode:node_modules/fsevents Completed in 13ms
                235 timing reifyNode:node_modules/iobroker.vis/node_modules/axios Completed in 443ms
                236 timing reifyNode:node_modules/iobroker.javascript/node_modules/@types/node Completed in 530ms
                237 timing reifyNode:node_modules/iobroker.vis Completed in 850ms
                238 timing reify:unpack Completed in 851ms
                239 timing reify:unretire Completed in 3ms
                240 timing build:queue Completed in 3ms
                241 info run iobroker.vis@1.4.10 install node_modules/iobroker.vis node main.js --install
                242 info run iobroker.vis@1.4.10 install { code: 6, signal: null }
                243 timing reify:rollback:createSparse Completed in 366ms
                244 timing reify:rollback:retireShallow Completed in 111ms
                245 timing command:install Completed in 15673ms
                246 verbose stack Error: command failed
                246 verbose stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:63:27)
                246 verbose stack at ChildProcess.emit (node:events:513:28)
                246 verbose stack at maybeClose (node:internal/child_process:1100:16)
                246 verbose stack at Process.ChildProcess._handle.onexit (node:internal/child_process:304:5)
                247 verbose pkgid iobroker.vis@1.4.10
                248 verbose cwd /opt/iobroker
                249 verbose Linux 5.15.84-v8+
                250 verbose node v16.19.0
                251 verbose npm v8.19.3
                252 error code 6
                253 error path /opt/iobroker/node_modules/iobroker.vis
                254 error command failed
                255 error command sh -c -- node main.js --install
                256 verbose exit 6
                257 timing npm Completed in 16070ms
                258 verbose unfinished npm timer reify 1674819220592
                259 verbose unfinished npm timer reify:build 1674819232226
                260 verbose unfinished npm timer build 1674819232229
                261 verbose unfinished npm timer build:deps 1674819232230
                262 verbose unfinished npm timer build:run:install 1674819232234
                263 verbose unfinished npm timer build:run:install:node_modules/iobroker.vis 1674819232235
                264 verbose code 6
                265 error A complete log of this run can be found in:
                265 error /home/iobroker/.npm/_logs/2023-01-27T11_33_40_209Z-debug-0.log
                bei mir nicht 😀
                Lehrling seit 1975 !!!
                W 1 Antwort Letzte Antwort
                • DJMarc75D DJMarc75
                  @w00dy
                  0 verbose cli /usr/bin/node /usr/bin/npm
                  1 info using npm@8.19.3
                  2 info using node@v16.19.0
                  3 timing npm:load:whichnode Completed in 0ms
                  4 timing config:load:defaults Completed in 6ms
                  5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 2ms
                  6 timing config:load:builtin Completed in 3ms
                  7 timing config:load:cli Completed in 13ms
                  8 timing config:load:env Completed in 1ms
                  9 timing config:load:file:/opt/iobroker/.npmrc Completed in 4ms
                  10 timing config:load:project Completed in 32ms
                  11 timing config:load:file:/home/iobroker/.npmrc Completed in 1ms
                  12 timing config:load:user Completed in 1ms
                  13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
                  14 timing config:load:global Completed in 0ms
                  15 timing config:load:validate Completed in 1ms
                  16 timing config:load:credentials Completed in 3ms
                  17 timing config:load:setEnvs Completed in 4ms
                  18 timing config:load Completed in 66ms
                  19 timing npm:load:configload Completed in 66ms
                  20 timing npm:load:mkdirpcache Completed in 3ms
                  21 timing npm:load:mkdirplogs Completed in 0ms
                  22 verbose title npm install iobroker.vis@1.4.10
                  23 verbose argv "install" "--save-exact" "iobroker.vis@1.4.10"
                  24 timing npm:load:setTitle Completed in 4ms
                  25 timing config:load:flatten Completed in 12ms
                  26 timing npm:load:display Completed in 14ms
                  27 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs
                  28 verbose logfile /home/iobroker/.npm/_logs/2023-01-27T11_33_40_209Z-debug-0.log
                  29 timing npm:load:logFile Completed in 21ms
                  30 timing npm:load:timers Completed in 1ms
                  31 timing npm:load:configScope Completed in 0ms
                  32 timing npm:load Completed in 116ms
                  33 timing arborist:ctor Completed in 3ms
                  34 silly logfile start cleaning logs, removing 2 files
                  35 silly logfile done cleaning log files
                  36 timing idealTree:init Completed in 4703ms
                  37 timing idealTree:userRequests Completed in 31ms
                  38 silly idealTree buildDeps
                  39 silly fetch manifest iobroker.vis@1.4.10
                  40 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
                  41 http fetch GET 200 https://registry.npmjs.org/iobroker.vis 3328ms (cache hit)
                  42 silly placeDep ROOT iobroker.vis@1.4.10 OK for: iobroker.inst@3.0.0 want: 1.4.10
                  43 silly fetch manifest axios@^0.24.0
                  44 http fetch GET 200 https://registry.npmjs.org/axios 2012ms (cache hit)
                  45 timing idealTree:#root Completed in 5395ms
                  46 silly placeDep node_modules/iobroker.vis axios@0.24.0 OK for: iobroker.vis@1.4.10 want: ^0.24.0
                  47 timing idealTree:node_modules/iobroker.vis Completed in 16ms
                  48 timing idealTree:node_modules/iobroker.vis/node_modules/axios Completed in 0ms
                  49 timing idealTree:buildDeps Completed in 5415ms
                  50 timing idealTree:fixDepFlags Completed in 41ms
                  51 timing idealTree Completed in 10274ms
                  52 timing reify:loadTrees Completed in 10341ms
                  53 timing reify:diffTrees Completed in 192ms
                  54 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv' ]
                  55 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archive-type'
                  55 silly reify ]
                  56 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asn1' ]
                  57 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/assert-plus'
                  57 silly reify ]
                  58 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asynckit'
                  58 silly reify ]
                  59 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws-sign2'
                  59 silly reify ]
                  60 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws4' ]
                  61 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/base64-js'
                  61 silly reify ]
                  62 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bcrypt-pbkdf'
                  62 silly reify ]
                  63 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bl' ]
                  64 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bluetooth-hci-socket'
                  64 silly reify ]
                  65 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bplist-parser'
                  65 silly reify ]
                  66 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer'
                  66 silly reify ]
                  67 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-alloc'
                  67 silly reify ]
                  68 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-alloc-unsafe'
                  68 silly reify ]
                  69 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-crc32'
                  69 silly reify ]
                  70 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-fill'
                  70 silly reify ]
                  71 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cacheable-request'
                  71 silly reify ]
                  72 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/call-bind'
                  72 silly reify ]
                  73 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/caseless'
                  73 silly reify ]
                  74 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-response'
                  74 silly reify ]
                  75 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript',
                  75 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/coffee',
                  75 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/cake'
                  75 silly reify ]
                  76 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/combined-stream'
                  76 silly reify ]
                  77 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/commander'
                  77 silly reify ]
                  78 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/content-disposition'
                  78 silly reify ]
                  79 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/core-util-is'
                  79 silly reify ]
                  80 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dashdash'
                  80 silly reify ]
                  81 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/debug' ]
                  82 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decode-uri-component'
                  82 silly reify ]
                  83 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress'
                  83 silly reify ]
                  84 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-response'
                  84 silly reify ]
                  85 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-tar'
                  85 silly reify ]
                  86 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-tarbz2'
                  86 silly reify ]
                  87 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-targz'
                  87 silly reify ]
                  88 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-unzip'
                  88 silly reify ]
                  89 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/define-properties'
                  89 silly reify ]
                  90 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/delayed-stream'
                  90 silly reify ]
                  91 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/download'
                  91 silly reify ]
                  92 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexer3'
                  92 silly reify ]
                  93 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ecc-jsbn'
                  93 silly reify ]
                  94 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/end-of-stream'
                  94 silly reify ]
                  95 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ext-list'
                  95 silly reify ]
                  96 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ext-name'
                  96 silly reify ]
                  97 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extend'
                  97 silly reify ]
                  98 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extsprintf'
                  98 silly reify ]
                  99 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-deep-equal'
                  99 silly reify ]
                  100 silly reify mark retired [
                  100 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-json-stable-stringify'
                  100 silly reify ]
                  101 silly reify mark retired [
                  101 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fd-slicer'
                  101 silly reify ]
                  102 silly reify mark retired [
                  102 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/file-type'
                  102 silly reify ]
                  103 silly reify mark retired [
                  103 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/filename-reserved-regex'
                  103 silly reify ]
                  104 silly reify mark retired [
                  104 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/filenamify'
                  104 silly reify ]
                  105 silly reify mark retired [
                  105 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/forever-agent'
                  105 silly reify ]
                  106 silly reify mark retired [
                  106 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/form-data'
                  106 silly reify ]
                  107 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/from2' ]
                  108 silly reify mark retired [
                  108 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fs-constants'
                  108 silly reify ]
                  109 silly reify mark retired [
                  109 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/function-bind'
                  109 silly reify ]
                  110 silly reify mark retired [
                  110 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/get-intrinsic'
                  110 silly reify ]
                  111 silly reify mark retired [
                  111 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/getpass'
                  111 silly reify ]
                  112 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/got' ]
                  113 silly reify mark retired [
                  113 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/graceful-fs'
                  113 silly reify ]
                  114 silly reify mark retired [
                  114 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-schema'
                  114 silly reify ]
                  115 silly reify mark retired [
                  115 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-validator'
                  115 silly reify ]
                  116 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has' ]
                  117 silly reify mark retired [
                  117 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-property-descriptors'
                  117 silly reify ]
                  118 silly reify mark retired [
                  118 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbol-support-x'
                  118 silly reify ]
                  119 silly reify mark retired [
                  119 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbols'
                  119 silly reify ]
                  120 silly reify mark retired [
                  120 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-to-string-tag-x'
                  120 silly reify ]
                  121 silly reify mark retired [
                  121 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-cache-semantics'
                  121 silly reify ]
                  122 silly reify mark retired [
                  122 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature'
                  122 silly reify ]
                  123 silly reify mark retired [
                  123 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ieee754'
                  123 silly reify ]
                  124 silly reify mark retired [
                  124 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/immediate'
                  124 silly reify ]
                  125 silly reify mark retired [
                  125 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/inherits'
                  125 silly reify ]
                  126 silly reify mark retired [
                  126 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/into-stream'
                  126 silly reify ]
                  127 silly reify mark retired [
                  127 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-nan'
                  127 silly reify ]
                  128 silly reify mark retired [
                  128 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-natural-number'
                  128 silly reify ]
                  129 silly reify mark retired [
                  129 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-object'
                  129 silly reify ]
                  130 silly reify mark retired [
                  130 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-retry-allowed'
                  130 silly reify ]
                  131 silly reify mark retired [
                  131 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-typedarray'
                  131 silly reify ]
                  132 silly reify mark retired [
                  132 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isarray'
                  132 silly reify ]
                  133 silly reify mark retired [
                  133 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isstream'
                  133 silly reify ]
                  134 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isurl' ]
                  135 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsbn' ]
                  136 silly reify mark retired [
                  136 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-buffer'
                  136 silly reify ]
                  137 silly reify mark retired [
                  137 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema'
                  137 silly reify ]
                  138 silly reify mark retired [
                  138 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema-traverse'
                  138 silly reify ]
                  139 silly reify mark retired [
                  139 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-stringify-safe'
                  139 silly reify ]
                  140 silly reify mark retired [
                  140 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsonata'
                  140 silly reify ]
                  141 silly reify mark retired [
                  141 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsprim'
                  141 silly reify ]
                  142 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jszip' ]
                  143 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/keyv' ]
                  144 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lie' ]
                  145 silly reify mark retired [
                  145 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/long-timeout'
                  145 silly reify ]
                  146 silly reify mark retired [
                  146 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lowercase-keys'
                  146 silly reify ]
                  147 silly reify mark retired [
                  147 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lru-cache'
                  147 silly reify ]
                  148 silly reify mark retired [
                  148 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/make-dir'
                  148 silly reify ]
                  149 silly reify mark retired [
                  149 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-db'
                  149 silly reify ]
                  150 silly reify mark retired [
                  150 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-types'
                  150 silly reify ]
                  151 silly reify mark retired [
                  151 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mimic-response'
                  151 silly reify ]
                  152 silly reify mark retired [
                  152 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/minimist'
                  152 silly reify ]
                  153 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ms' ]
                  154 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/nan' ]
                  155 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/noble' ]
                  156 silly reify mark retired [
                  156 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-addon-api'
                  156 silly reify ]
                  157 silly reify mark retired [
                  157 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-gyp-build',
                  157 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-gyp-build',
                  157 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-gyp-build-optional',
                  157 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-gyp-build-test'
                  157 silly reify ]
                  158 silly reify mark retired [
                  158 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-inspect',
                  158 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-inspect'
                  158 silly reify ]
                  159 silly reify mark retired [
                  159 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/normalize-url'
                  159 silly reify ]
                  160 silly reify mark retired [
                  160 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/oauth-sign'
                  160 silly reify ]
                  161 silly reify mark retired [
                  161 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/object-assign'
                  161 silly reify ]
                  162 silly reify mark retired [
                  162 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/object-keys'
                  162 silly reify ]
                  163 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/once' ]
                  164 silly reify mark retired [
                  164 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-cancelable'
                  164 silly reify ]
                  165 silly reify mark retired [
                  165 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-event'
                  165 silly reify ]
                  166 silly reify mark retired [
                  166 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-finally'
                  166 silly reify ]
                  167 silly reify mark retired [
                  167 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-is-promise'
                  167 silly reify ]
                  168 silly reify mark retired [
                  168 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-timeout'
                  168 silly reify ]
                  169 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pako' ]
                  170 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pend' ]
                  171 silly reify mark retired [
                  171 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/performance-now'
                  171 silly reify ]
                  172 silly reify mark retired [
                  172 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/picocolors'
                  172 silly reify ]
                  173 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pify' ]
                  174 silly reify mark retired [
                  174 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie'
                  174 silly reify ]
                  175 silly reify mark retired [
                  175 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie-promise'
                  175 silly reify ]
                  176 silly reify mark retired [
                  176 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/prepend-http'
                  176 silly reify ]
                  177 silly reify mark retired [
                  177 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/process-nextick-args'
                  177 silly reify ]
                  178 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/psl' ]
                  179 silly reify mark retired [
                  179 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/punycode'
                  179 silly reify ]
                  180 silly reify mark retired [
                  180 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/query-string'
                  180 silly reify ]
                  181 silly reify mark retired [
                  181 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/readable-stream'
                  181 silly reify ]
                  182 silly reify mark retired [
                  182 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request'
                  182 silly reify ]
                  183 silly reify mark retired [
                  183 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/responselike'
                  183 silly reify ]
                  184 silly reify mark retired [
                  184 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safe-buffer'
                  184 silly reify ]
                  185 silly reify mark retired [
                  185 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safer-buffer'
                  185 silly reify ]
                  186 silly reify mark retired [
                  186 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/seek-bzip',
                  186 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/seek-bunzip',
                  186 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/seek-table'
                  186 silly reify ]
                  187 silly reify mark retired [
                  187 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/semver',
                  187 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/semver'
                  187 silly reify ]
                  188 silly reify mark retired [
                  188 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/setimmediate'
                  188 silly reify ]
                  189 silly reify mark retired [
                  189 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sort-keys'
                  189 silly reify ]
                  190 silly reify mark retired [
                  190 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sort-keys-length'
                  190 silly reify ]
                  191 silly reify mark retired [
                  191 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sorted-array-functions'
                  191 silly reify ]
                  192 silly reify mark retired [
                  192 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/strict-uri-encode'
                  192 silly reify ]
                  193 silly reify mark retired [
                  193 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/string_decoder'
                  193 silly reify ]
                  194 silly reify mark retired [
                  194 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-dirs'
                  194 silly reify ]
                  195 silly reify mark retired [
                  195 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-outer'
                  195 silly reify ]
                  196 silly reify mark retired [
                  196 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/suncalc2'
                  196 silly reify ]
                  197 silly reify mark retired [
                  197 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tar-stream'
                  197 silly reify ]
                  198 silly reify mark retired [
                  198 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/through'
                  198 silly reify ]
                  199 silly reify mark retired [
                  199 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/timed-out'
                  199 silly reify ]
                  200 silly reify mark retired [
                  200 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/to-buffer'
                  200 silly reify ]
                  201 silly reify mark retired [
                  201 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tough-cookie'
                  201 silly reify ]
                  202 silly reify mark retired [
                  202 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/trim-repeated'
                  202 silly reify ]
                  203 silly reify mark retired [
                  203 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tunnel-agent'
                  203 silly reify ]
                  204 silly reify mark retired [
                  204 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tweetnacl'
                  204 silly reify ]
                  205 silly reify mark retired [
                  205 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript',
                  205 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsc',
                  205 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsserver'
                  205 silly reify ]
                  206 silly reify mark retired [
                  206 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/unbzip2-stream'
                  206 silly reify ]
                  207 silly reify mark retired [
                  207 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uri-js'
                  207 silly reify ]
                  208 silly reify mark retired [
                  208 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/url-parse-lax'
                  208 silly reify ]
                  209 silly reify mark retired [
                  209 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/url-to-options'
                  209 silly reify ]
                  210 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/usb' ]
                  211 silly reify mark retired [
                  211 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/util-deprecate'
                  211 silly reify ]
                  212 silly reify mark retired [
                  212 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uuid',
                  212 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/uuid'
                  212 silly reify ]
                  213 silly reify mark retired [
                  213 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/verror'
                  213 silly reify ]
                  214 silly reify mark retired [
                  214 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/virtual-tsc'
                  214 silly reify ]
                  215 silly reify mark retired [
                  215 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/wake_on_lan',
                  215 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/wake'
                  215 silly reify ]
                  216 silly reify mark retired [
                  216 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/wrappy'
                  216 silly reify ]
                  217 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/xtend' ]
                  218 silly reify mark retired [
                  218 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/yallist'
                  218 silly reify ]
                  219 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/yauzl' ]
                  220 silly reify mark retired [
                  220 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/adapter-core'
                  220 silly reify ]
                  221 silly reify mark retired [
                  221 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/caseless'
                  221 silly reify ]
                  222 silly reify mark retired [
                  222 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@sindresorhus/is'
                  222 silly reify ]
                  223 silly reify mark retired [
                  223 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/iobroker'
                  223 silly reify ]
                  224 silly reify mark retired [
                  224 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node'
                  224 silly reify ]
                  225 silly reify mark retired [
                  225 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/request'
                  225 silly reify ]
                  226 silly reify mark retired [
                  226 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/tough-cookie'
                  226 silly reify ]
                  227 silly reify mark retired [
                  227 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk',
                  227 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-conv',
                  227 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-sign',
                  227 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-verify'
                  227 silly reify ]
                  228 silly reify moves {
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ajv-JWAHQ164',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archive-type': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.archive-type-3GzbVy99',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asn1': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.asn1-begjjmYE',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/assert-plus': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.assert-plus-CvwT5c2f',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asynckit': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.asynckit-s0phpr5l',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws-sign2': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.aws-sign2-i67xE5NL',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws4': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.aws4-ewgSeGU1',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/base64-js': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.base64-js-CMxDgSwp',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bcrypt-pbkdf': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bcrypt-pbkdf-FkcXJSG6',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bl': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bl-tXcstEmh',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bluetooth-hci-socket': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bluetooth-hci-socket-LLgU3d50',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bplist-parser': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bplist-parser-Gw4mjLSv',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.buffer-jMN3QEXD',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-alloc': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.buffer-alloc-X1fED6E7',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-alloc-unsafe': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.buffer-alloc-unsafe-80OHTfqv',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-crc32': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.buffer-crc32-cFTv6cUc',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-fill': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.buffer-fill-5TccPbH2',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cacheable-request': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.cacheable-request-7Qr1qFGw',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/call-bind': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.call-bind-jQ2HDLx1',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/caseless': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.caseless-H2SaxUok',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-response': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.clone-response-huORZ122',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.coffeescript-btitSxqy',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/coffee': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.coffee-Ne3HN5Co',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/cake': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.cake-vF6kAtwy',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/combined-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.combined-stream-HoYmPyrw',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/commander': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.commander-P4zg2JoS',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/content-disposition': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.content-disposition-ykNJNQbu',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/core-util-is': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.core-util-is-eZ4fUaee',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dashdash': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.dashdash-nWlk69uH',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/debug': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.debug-A3k10AtD',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decode-uri-component': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decode-uri-component-CMOQnZCN',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decompress-jANiOqwy',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-response': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decompress-response-mSREN8o7',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-tar': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decompress-tar-aFLFgMpn',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-tarbz2': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decompress-tarbz2-J0MOywyt',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-targz': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decompress-targz-NMX7flNZ',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-unzip': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decompress-unzip-SCgptaCu',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/define-properties': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.define-properties-6XwZYcVY',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/delayed-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.delayed-stream-qacC3mjc',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/download': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.download-FZgZNHG4',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexer3': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.duplexer3-GSniCpAc',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ecc-jsbn': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ecc-jsbn-W1wmyGbT',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/end-of-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.end-of-stream-pGA0SfeC',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ext-list': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ext-list-CbquslXA',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ext-name': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ext-name-w2cAb5N9',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extend': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.extend-pv2WceUi',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extsprintf': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.extsprintf-l37IDaAf',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-deep-equal': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.fast-deep-equal-JqieQuGS',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-json-stable-stringify': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.fast-json-stable-stringify-zZtSpvEn',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fd-slicer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.fd-slicer-CGbB7jDs',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/file-type': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.file-type-MyF2AuGo',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/filename-reserved-regex': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.filename-reserved-regex-NQVIkyqX',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/filenamify': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.filenamify-055Pvtkk',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/forever-agent': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.forever-agent-hJzMqug0',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/form-data': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.form-data-f5gN4soy',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/from2': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.from2-rHxymetq',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fs-constants': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.fs-constants-RCPP7GAQ',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/function-bind': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.function-bind-xNuYoKHH',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/get-intrinsic': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.get-intrinsic-jaHndEV0',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/getpass': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.getpass-kOCUh1aA',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/got': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.got-LoRNXoPs',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/graceful-fs': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.graceful-fs-0lTymp4w',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-schema': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.har-schema-rWbJu3Hi',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-validator': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.har-validator-eyrBsHVJ',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.has-xBeCSK4w',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-property-descriptors': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.has-property-descriptors-NgHV0bqO',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbol-support-x': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.has-symbol-support-x-kJ1XKcwn',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbols': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.has-symbols-BlLhZd6T',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-to-string-tag-x': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.has-to-string-tag-x-D0rqbi1N',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-cache-semantics': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.http-cache-semantics-pwHcy6Um',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.http-signature-oUoVxdIq',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ieee754': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ieee754-ZkXktYfP',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/immediate': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.immediate-mU3gxEZk',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/inherits': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.inherits-n3Ch46Yn',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/into-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.into-stream-9jikZ2iK',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-nan': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.is-nan-aBR69xZy',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-natural-number': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.is-natural-number-7DVP81Ku',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-object': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.is-object-f37RttIf',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-retry-allowed': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.is-retry-allowed-bbEHMwWr',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-typedarray': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.is-typedarray-kgxdw7hd',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isarray': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.isarray-5wOzaH7B',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isstream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.isstream-kucfBgOe',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isurl': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.isurl-PFPtYcIS',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsbn': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.jsbn-7awNYEqn',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-buffer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.json-buffer-1DvjfwxG',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.json-schema-gJeujQHS',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema-traverse': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.json-schema-traverse-lxkTlMes',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-stringify-safe': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.json-stringify-safe-6OEF7DXQ',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsonata': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.jsonata-sj644a8k',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsprim': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.jsprim-Hb03jZ2t',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jszip': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.jszip-E0haUyzW',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/keyv': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.keyv-j7k6j1x3',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lie': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.lie-rDNcdBdn',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/long-timeout': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.long-timeout-UsqWplKY',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lowercase-keys': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.lowercase-keys-H4pYv5DL',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lru-cache': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.lru-cache-pTWFZBit',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/make-dir': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.make-dir-kpACuPQc',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-db': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.mime-db-ILNMz48k',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-types': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.mime-types-vVlqwvNj',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mimic-response': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.mimic-response-l1h59Fzs',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/minimist': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.minimist-HEtqlfZM',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ms': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ms-T3oF4fuS',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/nan': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.nan-adtTkJBo',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/noble': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.noble-UcE4HbYj',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-addon-api': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.node-addon-api-zOIY1GW8',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-gyp-build': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.node-gyp-build-Nc8n2hOB',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-gyp-build': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.node-gyp-build-L57SCOlW',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-gyp-build-optional': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.node-gyp-build-optional-Tk80r8za',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-gyp-build-test': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.node-gyp-build-test-izfPMJbu',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-inspect': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.node-inspect-7uCQsf40',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-inspect': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.node-inspect-RjTdcqZj',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/normalize-url': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.normalize-url-dTP3Oa7k',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/oauth-sign': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.oauth-sign-4TUsb1Hr',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/object-assign': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.object-assign-5Cf04ud8',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/object-keys': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.object-keys-L9W7bKqM',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/once': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.once-RFC770N3',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-cancelable': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.p-cancelable-u9fp3HLr',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-event': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.p-event-E5j32boQ',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-finally': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.p-finally-L9V5raVS',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-is-promise': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.p-is-promise-tNH5kneE',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-timeout': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.p-timeout-eSN8lQGZ',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pako': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.pako-rbL7BtOy',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pend': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.pend-BYTjI9Hf',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/performance-now': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.performance-now-rzc7QsAk',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/picocolors': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.picocolors-DQ4TN0mE',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pify': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.pify-kU90vZ0r',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.pinkie-7z22R4ew',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie-promise': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.pinkie-promise-6MuYHt6L',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/prepend-http': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.prepend-http-oFgNJ3Hh',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/process-nextick-args': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.process-nextick-args-1FsUsOM8',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/psl': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.psl-P3JlcAO8',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/punycode': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.punycode-l3TLrnOQ',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/query-string': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.query-string-3uidnXUa',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/readable-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.readable-stream-DGJrLMhV',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.request-IwHtFKjv',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/responselike': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.responselike-tYm4pETH',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safe-buffer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.safe-buffer-GY19LMpy',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safer-buffer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.safer-buffer-VoLQjGhM',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/seek-bzip': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.seek-bzip-JAWtZniv',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/seek-bunzip': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.seek-bunzip-CkVLvAS4',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/seek-table': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.seek-table-f3sdHWHj',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/semver': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.semver-nXF4HfsQ',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/semver': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.semver-Dy7i6zG2',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/setimmediate': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.setimmediate-rLmz5kvN',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sort-keys': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.sort-keys-qcvjMZ6g',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sort-keys-length': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.sort-keys-length-4IGif44d',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sorted-array-functions': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.sorted-array-functions-b2PxWBDs',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/strict-uri-encode': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.strict-uri-encode-WyOTcxtB',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/string_decoder': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.string_decoder-QqeclkYI',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-dirs': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.strip-dirs-8hbG4Qht',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-outer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.strip-outer-syQyolcG',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/suncalc2': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.suncalc2-tGRLIVnX',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tar-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.tar-stream-oOO7qk7O',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/through': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.through-fysaHtUl',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/timed-out': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.timed-out-wvGaABGU',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/to-buffer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.to-buffer-ZDZJ5ICv',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tough-cookie': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.tough-cookie-msAnSxYU',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/trim-repeated': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.trim-repeated-p6XbDaUh',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tunnel-agent': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.tunnel-agent-oUVQRXxE',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tweetnacl': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.tweetnacl-BnSTSyIu',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.typescript-EcwXdkx5',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsc': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.tsc-0PIrZBWg',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsserver': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.tsserver-QDbM4cAE',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/unbzip2-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.unbzip2-stream-7cC95xXq',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uri-js': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.uri-js-8VwjhWYz',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/url-parse-lax': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.url-parse-lax-L4Pi5Fdr',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/url-to-options': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.url-to-options-VEmeYCpr',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/usb': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.usb-eaYctfOO',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/util-deprecate': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.util-deprecate-e5GNBBxw',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uuid': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.uuid-0rL1ORyz',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/uuid': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.uuid-gQ53C49H',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/verror': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.verror-EsRYTvUd',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/virtual-tsc': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.virtual-tsc-Z1y2mItj',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/wake_on_lan': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.wake_on_lan-aA1sq5Hq',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/wake': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.wake-PZWgBD8w',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/wrappy': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.wrappy-FK4KH90e',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/xtend': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.xtend-kCzojcVd',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/yallist': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.yallist-Jj27Vzng',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/yauzl': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.yauzl-I4OoZHvp',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/adapter-core': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/.adapter-core-5hqHvhca',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/caseless': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.caseless-E7EBKTiW',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@sindresorhus/is': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@sindresorhus/.is-g9nAs77m',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/iobroker': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.iobroker-H0DYMotS',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.node-f0Rqzy2m',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/request': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.request-jbJT2ToX',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/tough-cookie': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.tough-cookie-ZhFQ7n2j',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.sshpk-29rDccd4',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-conv': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.sshpk-conv-dbhOTJ0f',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-sign': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.sshpk-sign-0kGWm4VB',
                  228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-verify': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.sshpk-verify-Bif9pYCN'
                  228 silly reify }
                  229 timing reify:retireShallow Completed in 216ms
                  230 timing reify:createSparse Completed in 9ms
                  231 timing reify:loadBundles Completed in 0ms
                  232 verbose reify failed optional dependency /opt/iobroker/node_modules/fsevents
                  233 silly reify mark deleted [ '/opt/iobroker/node_modules/fsevents' ]
                  234 timing reifyNode:node_modules/fsevents Completed in 13ms
                  235 timing reifyNode:node_modules/iobroker.vis/node_modules/axios Completed in 443ms
                  236 timing reifyNode:node_modules/iobroker.javascript/node_modules/@types/node Completed in 530ms
                  237 timing reifyNode:node_modules/iobroker.vis Completed in 850ms
                  238 timing reify:unpack Completed in 851ms
                  239 timing reify:unretire Completed in 3ms
                  240 timing build:queue Completed in 3ms
                  241 info run iobroker.vis@1.4.10 install node_modules/iobroker.vis node main.js --install
                  242 info run iobroker.vis@1.4.10 install { code: 6, signal: null }
                  243 timing reify:rollback:createSparse Completed in 366ms
                  244 timing reify:rollback:retireShallow Completed in 111ms
                  245 timing command:install Completed in 15673ms
                  246 verbose stack Error: command failed
                  246 verbose stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:63:27)
                  246 verbose stack at ChildProcess.emit (node:events:513:28)
                  246 verbose stack at maybeClose (node:internal/child_process:1100:16)
                  246 verbose stack at Process.ChildProcess._handle.onexit (node:internal/child_process:304:5)
                  247 verbose pkgid iobroker.vis@1.4.10
                  248 verbose cwd /opt/iobroker
                  249 verbose Linux 5.15.84-v8+
                  250 verbose node v16.19.0
                  251 verbose npm v8.19.3
                  252 error code 6
                  253 error path /opt/iobroker/node_modules/iobroker.vis
                  254 error command failed
                  255 error command sh -c -- node main.js --install
                  256 verbose exit 6
                  257 timing npm Completed in 16070ms
                  258 verbose unfinished npm timer reify 1674819220592
                  259 verbose unfinished npm timer reify:build 1674819232226
                  260 verbose unfinished npm timer build 1674819232229
                  261 verbose unfinished npm timer build:deps 1674819232230
                  262 verbose unfinished npm timer build:run:install 1674819232234
                  263 verbose unfinished npm timer build:run:install:node_modules/iobroker.vis 1674819232235
                  264 verbose code 6
                  265 error A complete log of this run can be found in:
                  265 error /home/iobroker/.npm/_logs/2023-01-27T11_33_40_209Z-debug-0.log
                  bei mir nicht 😀
                  W Offline
                  W Offline
                  w00dy
                  @djmarc75 Komisch, bei mir hat er gemeckert, von wegen der Text sei zu lang?!?
                  Danke, wollte es gerade aufteilen!
                  LG,
                  w00dy
                  • W Offline
                    W Offline
                    w00dy
                    Kann mir wenigsten jemand sagen, ob dieser Fehler generell bei einem Raspi mit 64-bit OS besteht, oder das ausschließlich ein Fehler meines Systems ist?
                    LG,
                    w00dy
                    • W w00dy
                      @w00dy
                      Ist was auf deinem System. Generell läuft das.
                      Auf meinem 64bit-Frickel-System:
                      echad@chet:~ $ iobroker upgrade vis@1.4.10
                      BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                      Would you like to upgrade vis from @0.0.0 to @1.4.10 now? [(y)es, (n)o]: y
                      Update vis from @0.0.0 to @1.4.10
                      NPM version: 9.3.1
                      Installing iobroker.vis@1.4.10... (System call)
                      added 2 packages, removed 159 packages, and changed 1 package in 18s
                      97 packages are looking for funding
                        run `npm fund` for details
                      upload [328] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
                      upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/dialog.png icon/dialog.png image/png
                      upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/img/eg_trans.png img/eg_trans.png image/png
                      upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/mine/128/zip.png js/fm/icon/mine/128/zip.png image/pngupload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/css/superfish/megafish.css lib/css/superfish/megafish.css text/css
                      upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/css/table.css widgets/basic/css/table.css text/css
                      upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_HtmlLogout.png widgets/basic/img/Prev_HtmlLogout.png image/png
                      upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_TableBody.png widgets/basic/img/Prev_TableBody.png image/png
                      upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_ValueInput.png widgets/basic/img/Prev_ValueInput.png image/png
                      upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_tplFrame.png widgets/basic/img/Prev_tplFrame.png image/png
                      upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic.html widgets/basic.html text/html
                      upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqplot/doc.html widgets/jqplot/doc.html text/html
                      upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui/img/Prev_JquiIconDialog.png widgets/jqui/img/Prev_JquiIconDialog.png image/png
                      upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.roundabout.min.js widgets/swipe/js/jquery.roundabout.min.js application/javascript
                      upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.touchSwipe.min.js widgets/swipe/js/jquery.touchSwipe.min.js application/javascript
                      upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe.html widgets/swipe.html text/html
                      upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/jquery.sliderTabs.js widgets/tabs/jquery.sliderTabs.js application/javascript
                      upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/indicator.png widgets/tabs/styles/images/indicator.png image/png
                      upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/indicatorActive.png widgets/tabs/styles/images/indicatorActive.png image/png
                      upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/leftArrow.png widgets/tabs/styles/images/leftArrow.png image/png
                      upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/leftPanelArrow.png widgets/tabs/styles/images/leftPanelArrow.png image/png
                      upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/rightArrow.png widgets/tabs/styles/images/rightArrow.png image/png
                      upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/rightPanelArrow.png widgets/tabs/styles/images/rightPanelArrow.png image/png
                      upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.css widgets/tabs/styles/jquery.sliderTabs.css text/css
                      upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.css.orig widgets/tabs/styles/jquery.sliderTabs.css.orig null
                      upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.min.css widgets/tabs/styles/jquery.sliderTabs.min.css text/css
                      upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs.html widgets/tabs.html text/html
                      upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/dev.html widgets/todo/dev.html text/html
                      upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/homematic.html widgets/todo/homematic.html text/html
                      upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/special.html widgets/todo/special.html text/html
                      upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/weather.html widgets/todo/weather.html text/html
                      upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/trashschedule/css/style.css widgets/trashschedule/css/style.css text/css
                      upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/trashschedule/js/trashschedule.js widgets/trashschedule/js/trashschedule.js application/javascript
                      upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/trashschedule.html widgets/trashschedule.html text/html
                      upload [3] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
                      upload [2] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index_m.html index_m.html text/html
                      upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
                      upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/words.js words.js application/javascript
                      echad@chet:~ $
                      W 1 Antwort Letzte Antwort
                        @w00dy
                        NPM version: 9.3.1
                        echad@chet:~ $
                        W Offline
                        W Offline
                        w00dy
                        Ok, danke für die Info. Meinst du, ich kann Backitup als Fehlerquelle ausschließen?
                        LG,
                        w00dy
                        • W w00dy
                          @w00dy
                          Ich vermute da eher ein 'krummes Setup' bei dir und keinen generellen Fehler bei Backitup.
                            @w00dy
                            W Offline
                            W Offline
                            w00dy
                            ...vis läuft jetzt, sogar in der aktuellen stable Version 1.4.15.
                            Nachdem ich in den Instanzen alles was zu vis gehörte (Widgets, Icons usw.) gelöscht habe, konnte ich vis ganz normal über Adapter installieren.
                            Komisch ist nur, dass alle Widgets, Icons, usw. in vis vorhanden sind und genutzt werden können, obwohl diese in den Instanzen nicht mehr vorhanden sind. Auch meine Visualisierung geht einwandfrei.🤔
                            Bist du der Meinung, ich sollte diese dennoch nachinstallieren?
                            LG,
                            w00dy
