<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[VIS-Adapter nach Neuinst.+Backitup-Restore tot]]></title><description><![CDATA[<p dir="auto">Moin.</p>
<p dir="auto">Um esphome zu testen, musste ich leider auf die 64-bit Variante von Bullseye für den Raspberry umsteigen.</p>
<p dir="auto">Leider läuft die Visualisierung (vis) nach dem Restore mit Backitup nicht mehr und läßt sich auch nicht installieren. Der Rest scheint bisher normal zu funktionieren.</p>
<p dir="auto">Fehlerprotokoll:</p>
<pre><code>$ iobroker add vis --host ioBroker
Installing iobroker.vis@1.4.15... (System call)
host.ioBroker Cannot install iobroker.vis@1.4.15: 6
ERROR: Process exited with code 25
2023-01-27 09:50:41.751 - info: vis.0 (2587) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.0, js-controller: 4.0.24
2023-01-27 09:50:41.957 - info: vis.0 (2587) vis license is OK.
2023-01-27 09:50:42.306 - error: vis.0 (2587) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
2023-01-27 09:50:42.307 - error: vis.0 (2587) unhandled promise rejection: Not exists
2023-01-27 09:50:42.310 - error: vis.0 (2587) Error: Not exists
at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2983:17)
at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1043:26)
at Immediate. (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1092:29)
at processImmediate (node:internal/timers:468:21)
2023-01-27 09:50:42.312 - error: vis.0 (2587) Not exists
2023-01-27 09:50:42.818 - info: vis.0 (2587) terminating
2023-01-27 09:50:42.819 - warn: vis.0 (2587) Terminated (UNCAUGHT_EXCEPTION): Without reason
2023-01-27 09:50:43.835 - error: host.ioBroker iobroker host.ioBroker Cannot install iobroker.vis@1.4.15: 6
</code></pre>
<p dir="auto">Habt Ihr eine Idee, was da los ist?</p>
<p dir="auto">Viele Grüße, w00dy</p>
]]></description><link>https://forum.iobroker.net/topic/62447/vis-adapter-nach-neuinst-backitup-restore-tot</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 18:49:14 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/62447.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 27 Jan 2023 09:42:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to VIS-Adapter nach Neuinst.+Backitup-Restore tot on Sat, 28 Jan 2023 13:13:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">...vis läuft jetzt, sogar in der aktuellen stable Version 1.4.15.<br />
Nachdem ich in den Instanzen alles was zu vis gehörte (Widgets, Icons usw.) gelöscht habe, konnte ich vis ganz normal über Adapter installieren.</p>
<p dir="auto">Komisch ist nur, dass alle Widgets, Icons, usw. in vis vorhanden sind und genutzt werden können, obwohl diese in den Instanzen nicht mehr vorhanden sind. Auch meine Visualisierung geht einwandfrei.<img src="https://forum.iobroker.net/assets/plugins/nodebb-plugin-emoji/emoji/android/1f914.png?v=ba16ebd4856" class="not-responsive emoji emoji-android emoji--thinking_face" style="height:23px;width:auto;vertical-align:middle" title=":thinking_face:" alt="🤔" /></p>
<p dir="auto">Bist du der Meinung, ich sollte diese dennoch nachinstallieren?</p>
]]></description><link>https://forum.iobroker.net/post/936633</link><guid isPermaLink="true">https://forum.iobroker.net/post/936633</guid><dc:creator><![CDATA[w00dy]]></dc:creator><pubDate>Sat, 28 Jan 2023 13:13:37 GMT</pubDate></item><item><title><![CDATA[Reply to VIS-Adapter nach Neuinst.+Backitup-Restore tot on Sat, 28 Jan 2023 10:49:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/w00dy" aria-label="Profile: w00dy">@<bdi>w00dy</bdi></a></p>
<p dir="auto">Ich vermute da eher ein 'krummes Setup' bei dir und keinen generellen Fehler bei Backitup.</p>
]]></description><link>https://forum.iobroker.net/post/936560</link><guid isPermaLink="true">https://forum.iobroker.net/post/936560</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sat, 28 Jan 2023 10:49:36 GMT</pubDate></item><item><title><![CDATA[Reply to VIS-Adapter nach Neuinst.+Backitup-Restore tot on Sat, 28 Jan 2023 10:46:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
Ok, danke für die Info. Meinst du, ich kann Backitup als Fehlerquelle ausschließen?</p>
]]></description><link>https://forum.iobroker.net/post/936557</link><guid isPermaLink="true">https://forum.iobroker.net/post/936557</guid><dc:creator><![CDATA[w00dy]]></dc:creator><pubDate>Sat, 28 Jan 2023 10:46:28 GMT</pubDate></item><item><title><![CDATA[Reply to VIS-Adapter nach Neuinst.+Backitup-Restore tot on Sat, 28 Jan 2023 10:38:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/w00dy" aria-label="Profile: w00dy">@<bdi>w00dy</bdi></a></p>
<p dir="auto">Ist was auf deinem System. Generell läuft das.</p>
<p dir="auto">Auf meinem 64bit-Frickel-System:</p>
<pre><code>echad@chet:~ $ iobroker upgrade vis@1.4.10
BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
Would you like to upgrade vis from @0.0.0 to @1.4.10 now? [(y)es, (n)o]: y
Update vis from @0.0.0 to @1.4.10
NPM version: 9.3.1
Installing iobroker.vis@1.4.10... (System call)
added 2 packages, removed 159 packages, and changed 1 package in 18s
97 packages are looking for funding
  run `npm fund` for details
upload [328] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/dialog.png icon/dialog.png image/png
upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/img/eg_trans.png img/eg_trans.png image/png
upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/mine/128/zip.png js/fm/icon/mine/128/zip.png image/pngupload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/css/superfish/megafish.css lib/css/superfish/megafish.css text/css
upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/css/table.css widgets/basic/css/table.css text/css
upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_HtmlLogout.png widgets/basic/img/Prev_HtmlLogout.png image/png
upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_TableBody.png widgets/basic/img/Prev_TableBody.png image/png
upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_ValueInput.png widgets/basic/img/Prev_ValueInput.png image/png
upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_tplFrame.png widgets/basic/img/Prev_tplFrame.png image/png
upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic.html widgets/basic.html text/html
upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqplot/doc.html widgets/jqplot/doc.html text/html
upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui/img/Prev_JquiIconDialog.png widgets/jqui/img/Prev_JquiIconDialog.png image/png
upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.roundabout.min.js widgets/swipe/js/jquery.roundabout.min.js application/javascript
upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.touchSwipe.min.js widgets/swipe/js/jquery.touchSwipe.min.js application/javascript
upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe.html widgets/swipe.html text/html
upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/jquery.sliderTabs.js widgets/tabs/jquery.sliderTabs.js application/javascript
upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/indicator.png widgets/tabs/styles/images/indicator.png image/png
upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/indicatorActive.png widgets/tabs/styles/images/indicatorActive.png image/png
upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/leftArrow.png widgets/tabs/styles/images/leftArrow.png image/png
upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/leftPanelArrow.png widgets/tabs/styles/images/leftPanelArrow.png image/png
upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/rightArrow.png widgets/tabs/styles/images/rightArrow.png image/png
upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/rightPanelArrow.png widgets/tabs/styles/images/rightPanelArrow.png image/png
upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.css widgets/tabs/styles/jquery.sliderTabs.css text/css
upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.css.orig widgets/tabs/styles/jquery.sliderTabs.css.orig null
upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.min.css widgets/tabs/styles/jquery.sliderTabs.min.css text/css
upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs.html widgets/tabs.html text/html
upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/dev.html widgets/todo/dev.html text/html
upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/homematic.html widgets/todo/homematic.html text/html
upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/special.html widgets/todo/special.html text/html
upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/weather.html widgets/todo/weather.html text/html
upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/trashschedule/css/style.css widgets/trashschedule/css/style.css text/css
upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/trashschedule/js/trashschedule.js widgets/trashschedule/js/trashschedule.js application/javascript
upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/trashschedule.html widgets/trashschedule.html text/html
upload [3] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
upload [2] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index_m.html index_m.html text/html
upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/words.js words.js application/javascript
echad@chet:~ $
</code></pre>
]]></description><link>https://forum.iobroker.net/post/936548</link><guid isPermaLink="true">https://forum.iobroker.net/post/936548</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sat, 28 Jan 2023 10:38:58 GMT</pubDate></item><item><title><![CDATA[Reply to VIS-Adapter nach Neuinst.+Backitup-Restore tot on Sat, 28 Jan 2023 10:33:12 GMT]]></title><description><![CDATA[<p dir="auto">Kann mir wenigsten jemand sagen, ob dieser Fehler generell bei einem Raspi mit 64-bit OS besteht, oder das ausschließlich ein Fehler meines Systems ist?</p>
]]></description><link>https://forum.iobroker.net/post/936547</link><guid isPermaLink="true">https://forum.iobroker.net/post/936547</guid><dc:creator><![CDATA[w00dy]]></dc:creator><pubDate>Sat, 28 Jan 2023 10:33:12 GMT</pubDate></item><item><title><![CDATA[Reply to VIS-Adapter nach Neuinst.+Backitup-Restore tot on Fri, 27 Jan 2023 16:32:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/djmarc75" aria-label="Profile: djmarc75">@<bdi>djmarc75</bdi></a>  Komisch, bei mir hat er gemeckert, von wegen der Text sei zu lang?!?</p>
<p dir="auto">Danke, wollte es gerade aufteilen!</p>
]]></description><link>https://forum.iobroker.net/post/936213</link><guid isPermaLink="true">https://forum.iobroker.net/post/936213</guid><dc:creator><![CDATA[w00dy]]></dc:creator><pubDate>Fri, 27 Jan 2023 16:32:11 GMT</pubDate></item><item><title><![CDATA[Reply to VIS-Adapter nach Neuinst.+Backitup-Restore tot on Fri, 27 Jan 2023 16:29:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/w00dy" aria-label="Profile: w00dy">@<bdi>w00dy</bdi></a></p>
<pre><code>0 verbose cli /usr/bin/node /usr/bin/npm
1 info using npm@8.19.3
2 info using node@v16.19.0
3 timing npm:load:whichnode Completed in 0ms
4 timing config:load:defaults Completed in 6ms
5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 2ms
6 timing config:load:builtin Completed in 3ms
7 timing config:load:cli Completed in 13ms
8 timing config:load:env Completed in 1ms
9 timing config:load:file:/opt/iobroker/.npmrc Completed in 4ms
10 timing config:load:project Completed in 32ms
11 timing config:load:file:/home/iobroker/.npmrc Completed in 1ms
12 timing config:load:user Completed in 1ms
13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
14 timing config:load:global Completed in 0ms
15 timing config:load:validate Completed in 1ms
16 timing config:load:credentials Completed in 3ms
17 timing config:load:setEnvs Completed in 4ms
18 timing config:load Completed in 66ms
19 timing npm:load:configload Completed in 66ms
20 timing npm:load:mkdirpcache Completed in 3ms
21 timing npm:load:mkdirplogs Completed in 0ms
22 verbose title npm install iobroker.vis@1.4.10
23 verbose argv "install" "--save-exact" "iobroker.vis@1.4.10"
24 timing npm:load:setTitle Completed in 4ms
25 timing config:load:flatten Completed in 12ms
26 timing npm:load:display Completed in 14ms
27 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs
28 verbose logfile /home/iobroker/.npm/_logs/2023-01-27T11_33_40_209Z-debug-0.log
29 timing npm:load:logFile Completed in 21ms
30 timing npm:load:timers Completed in 1ms
31 timing npm:load:configScope Completed in 0ms
32 timing npm:load Completed in 116ms
33 timing arborist:ctor Completed in 3ms
34 silly logfile start cleaning logs, removing 2 files
35 silly logfile done cleaning log files
36 timing idealTree:init Completed in 4703ms
37 timing idealTree:userRequests Completed in 31ms
38 silly idealTree buildDeps
39 silly fetch manifest iobroker.vis@1.4.10
40 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
41 http fetch GET 200 https://registry.npmjs.org/iobroker.vis 3328ms (cache hit)
42 silly placeDep ROOT iobroker.vis@1.4.10 OK for: iobroker.inst@3.0.0 want: 1.4.10
43 silly fetch manifest axios@^0.24.0
44 http fetch GET 200 https://registry.npmjs.org/axios 2012ms (cache hit)
45 timing idealTree:#root Completed in 5395ms
46 silly placeDep node_modules/iobroker.vis axios@0.24.0 OK for: iobroker.vis@1.4.10 want: ^0.24.0
47 timing idealTree:node_modules/iobroker.vis Completed in 16ms
48 timing idealTree:node_modules/iobroker.vis/node_modules/axios Completed in 0ms
49 timing idealTree:buildDeps Completed in 5415ms
50 timing idealTree:fixDepFlags Completed in 41ms
51 timing idealTree Completed in 10274ms
52 timing reify:loadTrees Completed in 10341ms
53 timing reify:diffTrees Completed in 192ms
54 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv' ]
55 silly reify mark retired [
55 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archive-type'
55 silly reify ]
56 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asn1' ]
57 silly reify mark retired [
57 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/assert-plus'
57 silly reify ]
58 silly reify mark retired [
58 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asynckit'
58 silly reify ]
59 silly reify mark retired [
59 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws-sign2'
59 silly reify ]
60 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws4' ]
61 silly reify mark retired [
61 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/base64-js'
61 silly reify ]
62 silly reify mark retired [
62 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bcrypt-pbkdf'
62 silly reify ]
63 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bl' ]
64 silly reify mark retired [
64 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bluetooth-hci-socket'
64 silly reify ]
65 silly reify mark retired [
65 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bplist-parser'
65 silly reify ]
66 silly reify mark retired [
66 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer'
66 silly reify ]
67 silly reify mark retired [
67 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-alloc'
67 silly reify ]
68 silly reify mark retired [
68 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-alloc-unsafe'
68 silly reify ]
69 silly reify mark retired [
69 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-crc32'
69 silly reify ]
70 silly reify mark retired [
70 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-fill'
70 silly reify ]
71 silly reify mark retired [
71 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cacheable-request'
71 silly reify ]
72 silly reify mark retired [
72 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/call-bind'
72 silly reify ]
73 silly reify mark retired [
73 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/caseless'
73 silly reify ]
74 silly reify mark retired [
74 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-response'
74 silly reify ]
75 silly reify mark retired [
75 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript',
75 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/coffee',
75 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/cake'
75 silly reify ]
76 silly reify mark retired [
76 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/combined-stream'
76 silly reify ]
77 silly reify mark retired [
77 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/commander'
77 silly reify ]
78 silly reify mark retired [
78 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/content-disposition'
78 silly reify ]
79 silly reify mark retired [
79 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/core-util-is'
79 silly reify ]
80 silly reify mark retired [
80 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dashdash'
80 silly reify ]
81 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/debug' ]
82 silly reify mark retired [
82 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decode-uri-component'
82 silly reify ]
83 silly reify mark retired [
83 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress'
83 silly reify ]
84 silly reify mark retired [
84 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-response'
84 silly reify ]
85 silly reify mark retired [
85 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-tar'
85 silly reify ]
86 silly reify mark retired [
86 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-tarbz2'
86 silly reify ]
87 silly reify mark retired [
87 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-targz'
87 silly reify ]
88 silly reify mark retired [
88 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-unzip'
88 silly reify ]
89 silly reify mark retired [
89 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/define-properties'
89 silly reify ]
90 silly reify mark retired [
90 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/delayed-stream'
90 silly reify ]
91 silly reify mark retired [
91 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/download'
91 silly reify ]
92 silly reify mark retired [
92 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexer3'
92 silly reify ]
93 silly reify mark retired [
93 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ecc-jsbn'
93 silly reify ]
94 silly reify mark retired [
94 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/end-of-stream'
94 silly reify ]
95 silly reify mark retired [
95 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ext-list'
95 silly reify ]
96 silly reify mark retired [
96 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ext-name'
96 silly reify ]
97 silly reify mark retired [
97 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extend'
97 silly reify ]
98 silly reify mark retired [
98 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extsprintf'
98 silly reify ]
99 silly reify mark retired [
99 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-deep-equal'
99 silly reify ]
100 silly reify mark retired [
100 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-json-stable-stringify'
100 silly reify ]
101 silly reify mark retired [
101 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fd-slicer'
101 silly reify ]
102 silly reify mark retired [
102 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/file-type'
102 silly reify ]
103 silly reify mark retired [
103 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/filename-reserved-regex'
103 silly reify ]
104 silly reify mark retired [
104 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/filenamify'
104 silly reify ]
105 silly reify mark retired [
105 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/forever-agent'
105 silly reify ]
106 silly reify mark retired [
106 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/form-data'
106 silly reify ]
107 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/from2' ]
108 silly reify mark retired [
108 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fs-constants'
108 silly reify ]
109 silly reify mark retired [
109 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/function-bind'
109 silly reify ]
110 silly reify mark retired [
110 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/get-intrinsic'
110 silly reify ]
111 silly reify mark retired [
111 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/getpass'
111 silly reify ]
112 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/got' ]
113 silly reify mark retired [
113 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/graceful-fs'
113 silly reify ]
114 silly reify mark retired [
114 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-schema'
114 silly reify ]
115 silly reify mark retired [
115 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-validator'
115 silly reify ]
116 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has' ]
117 silly reify mark retired [
117 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-property-descriptors'
117 silly reify ]
118 silly reify mark retired [
118 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbol-support-x'
118 silly reify ]
119 silly reify mark retired [
119 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbols'
119 silly reify ]
120 silly reify mark retired [
120 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-to-string-tag-x'
120 silly reify ]
121 silly reify mark retired [
121 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-cache-semantics'
121 silly reify ]
122 silly reify mark retired [
122 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature'
122 silly reify ]
123 silly reify mark retired [
123 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ieee754'
123 silly reify ]
124 silly reify mark retired [
124 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/immediate'
124 silly reify ]
125 silly reify mark retired [
125 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/inherits'
125 silly reify ]
126 silly reify mark retired [
126 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/into-stream'
126 silly reify ]
127 silly reify mark retired [
127 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-nan'
127 silly reify ]
128 silly reify mark retired [
128 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-natural-number'
128 silly reify ]
129 silly reify mark retired [
129 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-object'
129 silly reify ]
130 silly reify mark retired [
130 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-retry-allowed'
130 silly reify ]
131 silly reify mark retired [
131 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-typedarray'
131 silly reify ]
132 silly reify mark retired [
132 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isarray'
132 silly reify ]
133 silly reify mark retired [
133 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isstream'
133 silly reify ]
134 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isurl' ]
135 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsbn' ]
136 silly reify mark retired [
136 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-buffer'
136 silly reify ]
137 silly reify mark retired [
137 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema'
137 silly reify ]
138 silly reify mark retired [
138 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema-traverse'
138 silly reify ]
139 silly reify mark retired [
139 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-stringify-safe'
139 silly reify ]
140 silly reify mark retired [
140 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsonata'
140 silly reify ]
141 silly reify mark retired [
141 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsprim'
141 silly reify ]
142 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jszip' ]
143 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/keyv' ]
144 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lie' ]
145 silly reify mark retired [
145 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/long-timeout'
145 silly reify ]
146 silly reify mark retired [
146 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lowercase-keys'
146 silly reify ]
147 silly reify mark retired [
147 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lru-cache'
147 silly reify ]
148 silly reify mark retired [
148 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/make-dir'
148 silly reify ]
149 silly reify mark retired [
149 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-db'
149 silly reify ]
150 silly reify mark retired [
150 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-types'
150 silly reify ]
151 silly reify mark retired [
151 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mimic-response'
151 silly reify ]
152 silly reify mark retired [
152 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/minimist'
152 silly reify ]
153 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ms' ]
154 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/nan' ]
155 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/noble' ]
156 silly reify mark retired [
156 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-addon-api'
156 silly reify ]
157 silly reify mark retired [
157 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-gyp-build',
157 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-gyp-build',
157 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-gyp-build-optional',
157 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-gyp-build-test'
157 silly reify ]
158 silly reify mark retired [
158 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-inspect',
158 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-inspect'
158 silly reify ]
159 silly reify mark retired [
159 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/normalize-url'
159 silly reify ]
160 silly reify mark retired [
160 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/oauth-sign'
160 silly reify ]
161 silly reify mark retired [
161 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/object-assign'
161 silly reify ]
162 silly reify mark retired [
162 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/object-keys'
162 silly reify ]
163 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/once' ]
164 silly reify mark retired [
164 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-cancelable'
164 silly reify ]
165 silly reify mark retired [
165 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-event'
165 silly reify ]
166 silly reify mark retired [
166 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-finally'
166 silly reify ]
167 silly reify mark retired [
167 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-is-promise'
167 silly reify ]
168 silly reify mark retired [
168 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-timeout'
168 silly reify ]
169 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pako' ]
170 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pend' ]
171 silly reify mark retired [
171 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/performance-now'
171 silly reify ]
172 silly reify mark retired [
172 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/picocolors'
172 silly reify ]
173 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pify' ]
174 silly reify mark retired [
174 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie'
174 silly reify ]
175 silly reify mark retired [
175 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie-promise'
175 silly reify ]
176 silly reify mark retired [
176 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/prepend-http'
176 silly reify ]
177 silly reify mark retired [
177 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/process-nextick-args'
177 silly reify ]
178 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/psl' ]
179 silly reify mark retired [
179 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/punycode'
179 silly reify ]
180 silly reify mark retired [
180 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/query-string'
180 silly reify ]
181 silly reify mark retired [
181 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/readable-stream'
181 silly reify ]
182 silly reify mark retired [
182 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request'
182 silly reify ]
183 silly reify mark retired [
183 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/responselike'
183 silly reify ]
184 silly reify mark retired [
184 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safe-buffer'
184 silly reify ]
185 silly reify mark retired [
185 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safer-buffer'
185 silly reify ]
186 silly reify mark retired [
186 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/seek-bzip',
186 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/seek-bunzip',
186 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/seek-table'
186 silly reify ]
187 silly reify mark retired [
187 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/semver',
187 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/semver'
187 silly reify ]
188 silly reify mark retired [
188 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/setimmediate'
188 silly reify ]
189 silly reify mark retired [
189 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sort-keys'
189 silly reify ]
190 silly reify mark retired [
190 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sort-keys-length'
190 silly reify ]
191 silly reify mark retired [
191 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sorted-array-functions'
191 silly reify ]
192 silly reify mark retired [
192 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/strict-uri-encode'
192 silly reify ]
193 silly reify mark retired [
193 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/string_decoder'
193 silly reify ]
194 silly reify mark retired [
194 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-dirs'
194 silly reify ]
195 silly reify mark retired [
195 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-outer'
195 silly reify ]
196 silly reify mark retired [
196 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/suncalc2'
196 silly reify ]
197 silly reify mark retired [
197 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tar-stream'
197 silly reify ]
198 silly reify mark retired [
198 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/through'
198 silly reify ]
199 silly reify mark retired [
199 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/timed-out'
199 silly reify ]
200 silly reify mark retired [
200 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/to-buffer'
200 silly reify ]
201 silly reify mark retired [
201 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tough-cookie'
201 silly reify ]
202 silly reify mark retired [
202 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/trim-repeated'
202 silly reify ]
203 silly reify mark retired [
203 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tunnel-agent'
203 silly reify ]
204 silly reify mark retired [
204 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tweetnacl'
204 silly reify ]
205 silly reify mark retired [
205 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript',
205 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsc',
205 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsserver'
205 silly reify ]
206 silly reify mark retired [
206 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/unbzip2-stream'
206 silly reify ]
207 silly reify mark retired [
207 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uri-js'
207 silly reify ]
208 silly reify mark retired [
208 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/url-parse-lax'
208 silly reify ]
209 silly reify mark retired [
209 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/url-to-options'
209 silly reify ]
210 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/usb' ]
211 silly reify mark retired [
211 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/util-deprecate'
211 silly reify ]
212 silly reify mark retired [
212 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uuid',
212 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/uuid'
212 silly reify ]
213 silly reify mark retired [
213 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/verror'
213 silly reify ]
214 silly reify mark retired [
214 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/virtual-tsc'
214 silly reify ]
215 silly reify mark retired [
215 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/wake_on_lan',
215 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/wake'
215 silly reify ]
216 silly reify mark retired [
216 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/wrappy'
216 silly reify ]
217 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/xtend' ]
218 silly reify mark retired [
218 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/yallist'
218 silly reify ]
219 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/yauzl' ]
220 silly reify mark retired [
220 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/adapter-core'
220 silly reify ]
221 silly reify mark retired [
221 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/caseless'
221 silly reify ]
222 silly reify mark retired [
222 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@sindresorhus/is'
222 silly reify ]
223 silly reify mark retired [
223 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/iobroker'
223 silly reify ]
224 silly reify mark retired [
224 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node'
224 silly reify ]
225 silly reify mark retired [
225 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/request'
225 silly reify ]
226 silly reify mark retired [
226 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/tough-cookie'
226 silly reify ]
227 silly reify mark retired [
227 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk',
227 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-conv',
227 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-sign',
227 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-verify'
227 silly reify ]
228 silly reify moves {
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ajv-JWAHQ164',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archive-type': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.archive-type-3GzbVy99',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asn1': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.asn1-begjjmYE',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/assert-plus': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.assert-plus-CvwT5c2f',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asynckit': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.asynckit-s0phpr5l',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws-sign2': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.aws-sign2-i67xE5NL',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws4': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.aws4-ewgSeGU1',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/base64-js': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.base64-js-CMxDgSwp',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bcrypt-pbkdf': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bcrypt-pbkdf-FkcXJSG6',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bl': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bl-tXcstEmh',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bluetooth-hci-socket': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bluetooth-hci-socket-LLgU3d50',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bplist-parser': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bplist-parser-Gw4mjLSv',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.buffer-jMN3QEXD',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-alloc': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.buffer-alloc-X1fED6E7',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-alloc-unsafe': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.buffer-alloc-unsafe-80OHTfqv',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-crc32': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.buffer-crc32-cFTv6cUc',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-fill': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.buffer-fill-5TccPbH2',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cacheable-request': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.cacheable-request-7Qr1qFGw',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/call-bind': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.call-bind-jQ2HDLx1',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/caseless': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.caseless-H2SaxUok',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-response': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.clone-response-huORZ122',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.coffeescript-btitSxqy',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/coffee': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.coffee-Ne3HN5Co',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/cake': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.cake-vF6kAtwy',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/combined-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.combined-stream-HoYmPyrw',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/commander': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.commander-P4zg2JoS',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/content-disposition': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.content-disposition-ykNJNQbu',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/core-util-is': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.core-util-is-eZ4fUaee',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dashdash': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.dashdash-nWlk69uH',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/debug': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.debug-A3k10AtD',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decode-uri-component': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decode-uri-component-CMOQnZCN',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decompress-jANiOqwy',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-response': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decompress-response-mSREN8o7',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-tar': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decompress-tar-aFLFgMpn',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-tarbz2': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decompress-tarbz2-J0MOywyt',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-targz': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decompress-targz-NMX7flNZ',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-unzip': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decompress-unzip-SCgptaCu',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/define-properties': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.define-properties-6XwZYcVY',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/delayed-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.delayed-stream-qacC3mjc',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/download': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.download-FZgZNHG4',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexer3': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.duplexer3-GSniCpAc',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ecc-jsbn': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ecc-jsbn-W1wmyGbT',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/end-of-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.end-of-stream-pGA0SfeC',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ext-list': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ext-list-CbquslXA',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ext-name': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ext-name-w2cAb5N9',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extend': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.extend-pv2WceUi',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extsprintf': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.extsprintf-l37IDaAf',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-deep-equal': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.fast-deep-equal-JqieQuGS',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-json-stable-stringify': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.fast-json-stable-stringify-zZtSpvEn',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fd-slicer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.fd-slicer-CGbB7jDs',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/file-type': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.file-type-MyF2AuGo',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/filename-reserved-regex': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.filename-reserved-regex-NQVIkyqX',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/filenamify': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.filenamify-055Pvtkk',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/forever-agent': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.forever-agent-hJzMqug0',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/form-data': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.form-data-f5gN4soy',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/from2': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.from2-rHxymetq',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fs-constants': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.fs-constants-RCPP7GAQ',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/function-bind': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.function-bind-xNuYoKHH',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/get-intrinsic': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.get-intrinsic-jaHndEV0',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/getpass': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.getpass-kOCUh1aA',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/got': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.got-LoRNXoPs',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/graceful-fs': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.graceful-fs-0lTymp4w',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-schema': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.har-schema-rWbJu3Hi',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-validator': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.har-validator-eyrBsHVJ',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.has-xBeCSK4w',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-property-descriptors': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.has-property-descriptors-NgHV0bqO',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbol-support-x': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.has-symbol-support-x-kJ1XKcwn',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbols': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.has-symbols-BlLhZd6T',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-to-string-tag-x': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.has-to-string-tag-x-D0rqbi1N',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-cache-semantics': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.http-cache-semantics-pwHcy6Um',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.http-signature-oUoVxdIq',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ieee754': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ieee754-ZkXktYfP',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/immediate': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.immediate-mU3gxEZk',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/inherits': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.inherits-n3Ch46Yn',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/into-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.into-stream-9jikZ2iK',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-nan': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.is-nan-aBR69xZy',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-natural-number': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.is-natural-number-7DVP81Ku',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-object': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.is-object-f37RttIf',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-retry-allowed': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.is-retry-allowed-bbEHMwWr',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-typedarray': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.is-typedarray-kgxdw7hd',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isarray': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.isarray-5wOzaH7B',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isstream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.isstream-kucfBgOe',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isurl': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.isurl-PFPtYcIS',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsbn': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.jsbn-7awNYEqn',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-buffer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.json-buffer-1DvjfwxG',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.json-schema-gJeujQHS',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema-traverse': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.json-schema-traverse-lxkTlMes',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-stringify-safe': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.json-stringify-safe-6OEF7DXQ',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsonata': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.jsonata-sj644a8k',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsprim': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.jsprim-Hb03jZ2t',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jszip': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.jszip-E0haUyzW',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/keyv': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.keyv-j7k6j1x3',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lie': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.lie-rDNcdBdn',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/long-timeout': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.long-timeout-UsqWplKY',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lowercase-keys': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.lowercase-keys-H4pYv5DL',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lru-cache': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.lru-cache-pTWFZBit',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/make-dir': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.make-dir-kpACuPQc',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-db': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.mime-db-ILNMz48k',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-types': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.mime-types-vVlqwvNj',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mimic-response': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.mimic-response-l1h59Fzs',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/minimist': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.minimist-HEtqlfZM',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ms': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ms-T3oF4fuS',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/nan': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.nan-adtTkJBo',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/noble': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.noble-UcE4HbYj',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-addon-api': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.node-addon-api-zOIY1GW8',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-gyp-build': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.node-gyp-build-Nc8n2hOB',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-gyp-build': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.node-gyp-build-L57SCOlW',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-gyp-build-optional': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.node-gyp-build-optional-Tk80r8za',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-gyp-build-test': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.node-gyp-build-test-izfPMJbu',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-inspect': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.node-inspect-7uCQsf40',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-inspect': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.node-inspect-RjTdcqZj',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/normalize-url': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.normalize-url-dTP3Oa7k',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/oauth-sign': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.oauth-sign-4TUsb1Hr',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/object-assign': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.object-assign-5Cf04ud8',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/object-keys': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.object-keys-L9W7bKqM',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/once': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.once-RFC770N3',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-cancelable': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.p-cancelable-u9fp3HLr',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-event': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.p-event-E5j32boQ',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-finally': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.p-finally-L9V5raVS',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-is-promise': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.p-is-promise-tNH5kneE',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-timeout': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.p-timeout-eSN8lQGZ',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pako': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.pako-rbL7BtOy',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pend': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.pend-BYTjI9Hf',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/performance-now': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.performance-now-rzc7QsAk',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/picocolors': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.picocolors-DQ4TN0mE',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pify': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.pify-kU90vZ0r',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.pinkie-7z22R4ew',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie-promise': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.pinkie-promise-6MuYHt6L',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/prepend-http': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.prepend-http-oFgNJ3Hh',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/process-nextick-args': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.process-nextick-args-1FsUsOM8',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/psl': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.psl-P3JlcAO8',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/punycode': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.punycode-l3TLrnOQ',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/query-string': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.query-string-3uidnXUa',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/readable-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.readable-stream-DGJrLMhV',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.request-IwHtFKjv',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/responselike': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.responselike-tYm4pETH',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safe-buffer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.safe-buffer-GY19LMpy',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safer-buffer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.safer-buffer-VoLQjGhM',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/seek-bzip': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.seek-bzip-JAWtZniv',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/seek-bunzip': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.seek-bunzip-CkVLvAS4',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/seek-table': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.seek-table-f3sdHWHj',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/semver': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.semver-nXF4HfsQ',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/semver': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.semver-Dy7i6zG2',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/setimmediate': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.setimmediate-rLmz5kvN',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sort-keys': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.sort-keys-qcvjMZ6g',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sort-keys-length': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.sort-keys-length-4IGif44d',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sorted-array-functions': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.sorted-array-functions-b2PxWBDs',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/strict-uri-encode': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.strict-uri-encode-WyOTcxtB',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/string_decoder': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.string_decoder-QqeclkYI',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-dirs': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.strip-dirs-8hbG4Qht',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-outer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.strip-outer-syQyolcG',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/suncalc2': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.suncalc2-tGRLIVnX',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tar-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.tar-stream-oOO7qk7O',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/through': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.through-fysaHtUl',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/timed-out': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.timed-out-wvGaABGU',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/to-buffer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.to-buffer-ZDZJ5ICv',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tough-cookie': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.tough-cookie-msAnSxYU',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/trim-repeated': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.trim-repeated-p6XbDaUh',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tunnel-agent': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.tunnel-agent-oUVQRXxE',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tweetnacl': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.tweetnacl-BnSTSyIu',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.typescript-EcwXdkx5',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsc': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.tsc-0PIrZBWg',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsserver': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.tsserver-QDbM4cAE',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/unbzip2-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.unbzip2-stream-7cC95xXq',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uri-js': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.uri-js-8VwjhWYz',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/url-parse-lax': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.url-parse-lax-L4Pi5Fdr',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/url-to-options': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.url-to-options-VEmeYCpr',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/usb': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.usb-eaYctfOO',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/util-deprecate': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.util-deprecate-e5GNBBxw',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uuid': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.uuid-0rL1ORyz',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/uuid': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.uuid-gQ53C49H',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/verror': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.verror-EsRYTvUd',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/virtual-tsc': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.virtual-tsc-Z1y2mItj',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/wake_on_lan': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.wake_on_lan-aA1sq5Hq',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/wake': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.wake-PZWgBD8w',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/wrappy': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.wrappy-FK4KH90e',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/xtend': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.xtend-kCzojcVd',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/yallist': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.yallist-Jj27Vzng',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/yauzl': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.yauzl-I4OoZHvp',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/adapter-core': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/.adapter-core-5hqHvhca',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/caseless': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.caseless-E7EBKTiW',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@sindresorhus/is': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@sindresorhus/.is-g9nAs77m',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/iobroker': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.iobroker-H0DYMotS',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.node-f0Rqzy2m',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/request': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.request-jbJT2ToX',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/tough-cookie': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.tough-cookie-ZhFQ7n2j',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.sshpk-29rDccd4',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-conv': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.sshpk-conv-dbhOTJ0f',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-sign': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.sshpk-sign-0kGWm4VB',
228 silly reify '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-verify': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.sshpk-verify-Bif9pYCN'
228 silly reify }
229 timing reify:retireShallow Completed in 216ms
230 timing reify:createSparse Completed in 9ms
231 timing reify:loadBundles Completed in 0ms
232 verbose reify failed optional dependency /opt/iobroker/node_modules/fsevents
233 silly reify mark deleted [ '/opt/iobroker/node_modules/fsevents' ]
234 timing reifyNode:node_modules/fsevents Completed in 13ms
235 timing reifyNode:node_modules/iobroker.vis/node_modules/axios Completed in 443ms
236 timing reifyNode:node_modules/iobroker.javascript/node_modules/@types/node Completed in 530ms
237 timing reifyNode:node_modules/iobroker.vis Completed in 850ms
238 timing reify:unpack Completed in 851ms
239 timing reify:unretire Completed in 3ms
240 timing build:queue Completed in 3ms
241 info run iobroker.vis@1.4.10 install node_modules/iobroker.vis node main.js --install
242 info run iobroker.vis@1.4.10 install { code: 6, signal: null }
243 timing reify:rollback:createSparse Completed in 366ms
244 timing reify:rollback:retireShallow Completed in 111ms
245 timing command:install Completed in 15673ms
246 verbose stack Error: command failed
246 verbose stack at ChildProcess.&lt;anonymous&gt; (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:63:27)
246 verbose stack at ChildProcess.emit (node:events:513:28)
246 verbose stack at maybeClose (node:internal/child_process:1100:16)
246 verbose stack at Process.ChildProcess._handle.onexit (node:internal/child_process:304:5)
247 verbose pkgid iobroker.vis@1.4.10
248 verbose cwd /opt/iobroker
249 verbose Linux 5.15.84-v8+
250 verbose node v16.19.0
251 verbose npm v8.19.3
252 error code 6
253 error path /opt/iobroker/node_modules/iobroker.vis
254 error command failed
255 error command sh -c -- node main.js --install
256 verbose exit 6
257 timing npm Completed in 16070ms
258 verbose unfinished npm timer reify 1674819220592
259 verbose unfinished npm timer reify:build 1674819232226
260 verbose unfinished npm timer build 1674819232229
261 verbose unfinished npm timer build:deps 1674819232230
262 verbose unfinished npm timer build:run:install 1674819232234
263 verbose unfinished npm timer build:run:install:node_modules/iobroker.vis 1674819232235
264 verbose code 6
265 error A complete log of this run can be found in:
265 error /home/iobroker/.npm/_logs/2023-01-27T11_33_40_209Z-debug-0.log
</code></pre>
<p dir="auto">bei mir nicht <img src="https://forum.iobroker.net/assets/plugins/nodebb-plugin-emoji/emoji/android/1f600.png?v=ba16ebd4856" class="not-responsive emoji emoji-android emoji--grinning" style="height:23px;width:auto;vertical-align:middle" title=":grinning:" alt="😀" /></p>
]]></description><link>https://forum.iobroker.net/post/936210</link><guid isPermaLink="true">https://forum.iobroker.net/post/936210</guid><dc:creator><![CDATA[DJMarc75]]></dc:creator><pubDate>Fri, 27 Jan 2023 16:29:10 GMT</pubDate></item><item><title><![CDATA[Reply to VIS-Adapter nach Neuinst.+Backitup-Restore tot on Fri, 27 Jan 2023 16:27:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/djmarc75" aria-label="Profile: djmarc75">@<bdi>djmarc75</bdi></a>  ...geht nicht, da zu lang!</p>
]]></description><link>https://forum.iobroker.net/post/936208</link><guid isPermaLink="true">https://forum.iobroker.net/post/936208</guid><dc:creator><![CDATA[w00dy]]></dc:creator><pubDate>Fri, 27 Jan 2023 16:27:13 GMT</pubDate></item><item><title><![CDATA[Reply to VIS-Adapter nach Neuinst.+Backitup-Restore tot on Fri, 27 Jan 2023 16:08:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/w00dy" aria-label="Profile: w00dy">@<bdi>w00dy</bdi></a> nicht in Spoiler sondern Codetags reinsetzen bitte</p>
]]></description><link>https://forum.iobroker.net/post/936190</link><guid isPermaLink="true">https://forum.iobroker.net/post/936190</guid><dc:creator><![CDATA[DJMarc75]]></dc:creator><pubDate>Fri, 27 Jan 2023 16:08:19 GMT</pubDate></item><item><title><![CDATA[Reply to VIS-Adapter nach Neuinst.+Backitup-Restore tot on Fri, 27 Jan 2023 16:07:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">Für mich nur Kauderwelsch <img src="https://forum.iobroker.net/assets/plugins/nodebb-plugin-emoji/emoji/android/1f60f.png?v=ba16ebd4856" class="not-responsive emoji emoji-android emoji--smirk" style="height:23px;width:auto;vertical-align:middle" title=":smirk:" alt="😏" /> . Ich hoffe, du kannst was damit anfangen....</p>
<p dir="auto"></p><section class="spoiler-wrapper"><button class="spoiler-control btn btn-default">Spoiler</button><section style="display:none" class="spoiler-content"><br />
0 verbose cli /usr/bin/node /usr/bin/npm<br />
1 info using npm@8.19.3<br />
2 info using node@v16.19.0<br />
3 timing npm:load:whichnode Completed in 0ms<br />
4 timing config:load:defaults Completed in 6ms<br />
5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 2ms<br />
6 timing config:load:builtin Completed in 3ms<br />
7 timing config:load:cli Completed in 13ms<br />
8 timing config:load:env Completed in 1ms<br />
9 timing config:load:file:/opt/iobroker/.npmrc Completed in 4ms<br />
10 timing config:load:project Completed in 32ms<br />
11 timing config:load:file:/home/iobroker/.npmrc Completed in 1ms<br />
12 timing config:load:user Completed in 1ms<br />
13 timing config:load:file:/usr/etc/npmrc Completed in 0ms<br />
14 timing config:load:global Completed in 0ms<br />
15 timing config:load:validate Completed in 1ms<br />
16 timing config:load:credentials Completed in 3ms<br />
17 timing config:load:setEnvs Completed in 4ms<br />
18 timing config:load Completed in 66ms<br />
19 timing npm:load:configload Completed in 66ms<br />
20 timing npm:load:mkdirpcache Completed in 3ms<br />
21 timing npm:load:mkdirplogs Completed in 0ms<br />
22 verbose title npm install iobroker.vis@1.4.10<br />
23 verbose argv "install" "--save-exact" "iobroker.vis@1.4.10"<br />
24 timing npm:load:setTitle Completed in 4ms<br />
25 timing config:load:flatten Completed in 12ms<br />
26 timing npm:load:display Completed in 14ms<br />
27 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs<br />
28 verbose logfile /home/iobroker/.npm/_logs/2023-01-27T11_33_40_209Z-debug-0.log<br />
29 timing npm:load:logFile Completed in 21ms<br />
30 timing npm:load:timers Completed in 1ms<br />
31 timing npm:load:configScope Completed in 0ms<br />
32 timing npm:load Completed in 116ms<br />
33 timing arborist:ctor Completed in 3ms<br />
34 silly logfile start cleaning logs, removing 2 files<br />
35 silly logfile done cleaning log files<br />
36 timing idealTree:init Completed in 4703ms<br />
37 timing idealTree:userRequests Completed in 31ms<br />
38 silly idealTree buildDeps<br />
39 silly fetch manifest iobroker.vis@1.4.10<br />
40 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules<br />
41 http fetch GET 200 <a href="https://registry.npmjs.org/iobroker.vis" rel="nofollow ugc">https://registry.npmjs.org/iobroker.vis</a> 3328ms (cache hit)<br />
42 silly placeDep ROOT iobroker.vis@1.4.10 OK for: iobroker.inst@3.0.0 want: 1.4.10<br />
43 silly fetch manifest axios@^0.24.0<br />
44 http fetch GET 200 <a href="https://registry.npmjs.org/axios" rel="nofollow ugc">https://registry.npmjs.org/axios</a> 2012ms (cache hit)<br />
45 timing idealTree:#root Completed in 5395ms<br />
46 silly placeDep node_modules/iobroker.vis axios@0.24.0 OK for: iobroker.vis@1.4.10 want: ^0.24.0<br />
47 timing idealTree:node_modules/iobroker.vis Completed in 16ms<br />
48 timing idealTree:node_modules/iobroker.vis/node_modules/axios Completed in 0ms<br />
49 timing idealTree:buildDeps Completed in 5415ms<br />
50 timing idealTree:fixDepFlags Completed in 41ms<br />
51 timing idealTree Completed in 10274ms<br />
52 timing reify:loadTrees Completed in 10341ms<br />
53 timing reify:diffTrees Completed in 192ms<br />
54 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv' ]<br />
55 silly reify mark retired [<br />
55 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archive-type'<br />
55 silly reify ]<br />
56 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asn1' ]<br />
57 silly reify mark retired [<br />
57 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/assert-plus'<br />
57 silly reify ]<br />
58 silly reify mark retired [<br />
58 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asynckit'<br />
58 silly reify ]<br />
59 silly reify mark retired [<br />
59 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws-sign2'<br />
59 silly reify ]<br />
60 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws4' ]<br />
61 silly reify mark retired [<br />
61 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/base64-js'<br />
61 silly reify ]<br />
62 silly reify mark retired [<br />
62 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bcrypt-pbkdf'<br />
62 silly reify ]<br />
63 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bl' ]<br />
64 silly reify mark retired [<br />
64 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bluetooth-hci-socket'<br />
64 silly reify ]<br />
65 silly reify mark retired [<br />
65 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bplist-parser'<br />
65 silly reify ]<br />
66 silly reify mark retired [<br />
66 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer'<br />
66 silly reify ]<br />
67 silly reify mark retired [<br />
67 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-alloc'<br />
67 silly reify ]<br />
68 silly reify mark retired [<br />
68 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-alloc-unsafe'<br />
68 silly reify ]<br />
69 silly reify mark retired [<br />
69 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-crc32'<br />
69 silly reify ]<br />
70 silly reify mark retired [<br />
70 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-fill'<br />
70 silly reify ]<br />
71 silly reify mark retired [<br />
71 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cacheable-request'<br />
71 silly reify ]<br />
72 silly reify mark retired [<br />
72 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/call-bind'<br />
72 silly reify ]<br />
73 silly reify mark retired [<br />
73 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/caseless'<br />
73 silly reify ]<br />
74 silly reify mark retired [<br />
74 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-response'<br />
74 silly reify ]<br />
75 silly reify mark retired [<br />
75 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript',<br />
75 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/coffee',<br />
75 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/cake'<br />
75 silly reify ]<br />
76 silly reify mark retired [<br />
76 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/combined-stream'<br />
76 silly reify ]<br />
77 silly reify mark retired [<br />
77 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/commander'<br />
77 silly reify ]<br />
78 silly reify mark retired [<br />
78 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/content-disposition'<br />
78 silly reify ]<br />
79 silly reify mark retired [<br />
79 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/core-util-is'<br />
79 silly reify ]<br />
80 silly reify mark retired [<br />
80 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dashdash'<br />
80 silly reify ]<br />
81 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/debug' ]<br />
82 silly reify mark retired [<br />
82 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decode-uri-component'<br />
82 silly reify ]<br />
83 silly reify mark retired [<br />
83 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress'<br />
83 silly reify ]<br />
84 silly reify mark retired [<br />
84 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-response'<br />
84 silly reify ]<br />
85 silly reify mark retired [<br />
85 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-tar'<br />
85 silly reify ]<br />
86 silly reify mark retired [<br />
86 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-tarbz2'<br />
86 silly reify ]<br />
87 silly reify mark retired [<br />
87 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-targz'<br />
87 silly reify ]<br />
88 silly reify mark retired [<br />
88 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-unzip'<br />
88 silly reify ]<br />
89 silly reify mark retired [<br />
89 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/define-properties'<br />
89 silly reify ]<br />
90 silly reify mark retired [<br />
90 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/delayed-stream'<br />
90 silly reify ]<br />
91 silly reify mark retired [<br />
91 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/download'<br />
91 silly reify ]<br />
92 silly reify mark retired [<br />
92 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexer3'<br />
92 silly reify ]<br />
93 silly reify mark retired [<br />
93 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ecc-jsbn'<br />
93 silly reify ]<br />
94 silly reify mark retired [<br />
94 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/end-of-stream'<br />
94 silly reify ]<br />
95 silly reify mark retired [<br />
95 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ext-list'<br />
95 silly reify ]<br />
96 silly reify mark retired [<br />
96 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ext-name'<br />
96 silly reify ]<br />
97 silly reify mark retired [<br />
97 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extend'<br />
97 silly reify ]<br />
98 silly reify mark retired [<br />
98 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extsprintf'<br />
98 silly reify ]<br />
99 silly reify mark retired [<br />
99 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-deep-equal'<br />
99 silly reify ]<br />
100 silly reify mark retired [<br />
100 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-json-stable-stringify'<br />
100 silly reify ]<br />
101 silly reify mark retired [<br />
101 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fd-slicer'<br />
101 silly reify ]<br />
102 silly reify mark retired [<br />
102 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/file-type'<br />
102 silly reify ]<br />
103 silly reify mark retired [<br />
103 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/filename-reserved-regex'<br />
103 silly reify ]<br />
104 silly reify mark retired [<br />
104 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/filenamify'<br />
104 silly reify ]<br />
105 silly reify mark retired [<br />
105 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/forever-agent'<br />
105 silly reify ]<br />
106 silly reify mark retired [<br />
106 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/form-data'<br />
106 silly reify ]<br />
107 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/from2' ]<br />
108 silly reify mark retired [<br />
108 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fs-constants'<br />
108 silly reify ]<br />
109 silly reify mark retired [<br />
109 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/function-bind'<br />
109 silly reify ]<br />
110 silly reify mark retired [<br />
110 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/get-intrinsic'<br />
110 silly reify ]<br />
111 silly reify mark retired [<br />
111 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/getpass'<br />
111 silly reify ]<br />
112 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/got' ]<br />
113 silly reify mark retired [<br />
113 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/graceful-fs'<br />
113 silly reify ]<br />
114 silly reify mark retired [<br />
114 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-schema'<br />
114 silly reify ]<br />
115 silly reify mark retired [<br />
115 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-validator'<br />
115 silly reify ]<br />
116 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has' ]<br />
117 silly reify mark retired [<br />
117 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-property-descriptors'<br />
117 silly reify ]<br />
118 silly reify mark retired [<br />
118 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbol-support-x'<br />
118 silly reify ]<br />
119 silly reify mark retired [<br />
119 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbols'<br />
119 silly reify ]<br />
120 silly reify mark retired [<br />
120 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-to-string-tag-x'<br />
120 silly reify ]<br />
121 silly reify mark retired [<br />
121 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-cache-semantics'<br />
121 silly reify ]<br />
122 silly reify mark retired [<br />
122 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature'<br />
122 silly reify ]<br />
123 silly reify mark retired [<br />
123 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ieee754'<br />
123 silly reify ]<br />
124 silly reify mark retired [<br />
124 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/immediate'<br />
124 silly reify ]<br />
125 silly reify mark retired [<br />
125 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/inherits'<br />
125 silly reify ]<br />
126 silly reify mark retired [<br />
126 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/into-stream'<br />
126 silly reify ]<br />
127 silly reify mark retired [<br />
127 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-nan'<br />
127 silly reify ]<br />
128 silly reify mark retired [<br />
128 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-natural-number'<br />
128 silly reify ]<br />
129 silly reify mark retired [<br />
129 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-object'<br />
129 silly reify ]<br />
130 silly reify mark retired [<br />
130 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-retry-allowed'<br />
130 silly reify ]<br />
131 silly reify mark retired [<br />
131 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-typedarray'<br />
131 silly reify ]<br />
132 silly reify mark retired [<br />
132 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isarray'<br />
132 silly reify ]<br />
133 silly reify mark retired [<br />
133 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isstream'<br />
133 silly reify ]<br />
134 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isurl' ]<br />
135 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsbn' ]<br />
136 silly reify mark retired [<br />
136 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-buffer'<br />
136 silly reify ]<br />
137 silly reify mark retired [<br />
137 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema'<br />
137 silly reify ]<br />
138 silly reify mark retired [<br />
138 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema-traverse'<br />
138 silly reify ]<br />
139 silly reify mark retired [<br />
139 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-stringify-safe'<br />
139 silly reify ]<br />
140 silly reify mark retired [<br />
140 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsonata'<br />
140 silly reify ]<br />
141 silly reify mark retired [<br />
141 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsprim'<br />
141 silly reify ]<br />
142 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jszip' ]<br />
143 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/keyv' ]<br />
144 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lie' ]<br />
145 silly reify mark retired [<br />
145 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/long-timeout'<br />
145 silly reify ]<br />
146 silly reify mark retired [<br />
146 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lowercase-keys'<br />
146 silly reify ]<br />
147 silly reify mark retired [<br />
147 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lru-cache'<br />
147 silly reify ]<br />
148 silly reify mark retired [<br />
148 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/make-dir'<br />
148 silly reify ]<br />
149 silly reify mark retired [<br />
149 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-db'<br />
149 silly reify ]<br />
150 silly reify mark retired [<br />
150 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-types'<br />
150 silly reify ]<br />
151 silly reify mark retired [<br />
151 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mimic-response'<br />
151 silly reify ]<br />
152 silly reify mark retired [<br />
152 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/minimist'<br />
152 silly reify ]<br />
153 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ms' ]<br />
154 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/nan' ]<br />
155 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/noble' ]<br />
156 silly reify mark retired [<br />
156 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-addon-api'<br />
156 silly reify ]<br />
157 silly reify mark retired [<br />
157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-gyp-build',<br />
157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-gyp-build',<br />
157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-gyp-build-optional',<br />
157 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-gyp-build-test'<br />
157 silly reify ]<br />
158 silly reify mark retired [<br />
158 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-inspect',<br />
158 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-inspect'<br />
158 silly reify ]<br />
159 silly reify mark retired [<br />
159 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/normalize-url'<br />
159 silly reify ]<br />
160 silly reify mark retired [<br />
160 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/oauth-sign'<br />
160 silly reify ]<br />
161 silly reify mark retired [<br />
161 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/object-assign'<br />
161 silly reify ]<br />
162 silly reify mark retired [<br />
162 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/object-keys'<br />
162 silly reify ]<br />
163 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/once' ]<br />
164 silly reify mark retired [<br />
164 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-cancelable'<br />
164 silly reify ]<br />
165 silly reify mark retired [<br />
165 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-event'<br />
165 silly reify ]<br />
166 silly reify mark retired [<br />
166 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-finally'<br />
166 silly reify ]<br />
167 silly reify mark retired [<br />
167 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-is-promise'<br />
167 silly reify ]<br />
168 silly reify mark retired [<br />
168 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-timeout'<br />
168 silly reify ]<br />
169 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pako' ]<br />
170 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pend' ]<br />
171 silly reify mark retired [<br />
171 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/performance-now'<br />
171 silly reify ]<br />
172 silly reify mark retired [<br />
172 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/picocolors'<br />
172 silly reify ]<br />
173 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pify' ]<br />
174 silly reify mark retired [<br />
174 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie'<br />
174 silly reify ]<br />
175 silly reify mark retired [<br />
175 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie-promise'<br />
175 silly reify ]<br />
176 silly reify mark retired [<br />
176 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/prepend-http'<br />
176 silly reify ]<br />
177 silly reify mark retired [<br />
177 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/process-nextick-args'<br />
177 silly reify ]<br />
178 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/psl' ]<br />
179 silly reify mark retired [<br />
179 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/punycode'<br />
179 silly reify ]<br />
180 silly reify mark retired [<br />
180 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/query-string'<br />
180 silly reify ]<br />
181 silly reify mark retired [<br />
181 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/readable-stream'<br />
181 silly reify ]<br />
182 silly reify mark retired [<br />
182 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request'<br />
182 silly reify ]<br />
183 silly reify mark retired [<br />
183 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/responselike'<br />
183 silly reify ]<br />
184 silly reify mark retired [<br />
184 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safe-buffer'<br />
184 silly reify ]<br />
185 silly reify mark retired [<br />
185 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safer-buffer'<br />
185 silly reify ]<br />
186 silly reify mark retired [<br />
186 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/seek-bzip',<br />
186 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/seek-bunzip',<br />
186 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/seek-table'<br />
186 silly reify ]<br />
187 silly reify mark retired [<br />
187 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/semver',<br />
187 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/semver'<br />
187 silly reify ]<br />
188 silly reify mark retired [<br />
188 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/setimmediate'<br />
188 silly reify ]<br />
189 silly reify mark retired [<br />
189 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sort-keys'<br />
189 silly reify ]<br />
190 silly reify mark retired [<br />
190 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sort-keys-length'<br />
190 silly reify ]<br />
191 silly reify mark retired [<br />
191 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sorted-array-functions'<br />
191 silly reify ]<br />
192 silly reify mark retired [<br />
192 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/strict-uri-encode'<br />
192 silly reify ]<br />
193 silly reify mark retired [<br />
193 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/string_decoder'<br />
193 silly reify ]<br />
194 silly reify mark retired [<br />
194 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-dirs'<br />
194 silly reify ]<br />
195 silly reify mark retired [<br />
195 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-outer'<br />
195 silly reify ]<br />
196 silly reify mark retired [<br />
196 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/suncalc2'<br />
196 silly reify ]<br />
197 silly reify mark retired [<br />
197 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tar-stream'<br />
197 silly reify ]<br />
198 silly reify mark retired [<br />
198 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/through'<br />
198 silly reify ]<br />
199 silly reify mark retired [<br />
199 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/timed-out'<br />
199 silly reify ]<br />
200 silly reify mark retired [<br />
200 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/to-buffer'<br />
200 silly reify ]<br />
201 silly reify mark retired [<br />
201 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tough-cookie'<br />
201 silly reify ]<br />
202 silly reify mark retired [<br />
202 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/trim-repeated'<br />
202 silly reify ]<br />
203 silly reify mark retired [<br />
203 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tunnel-agent'<br />
203 silly reify ]<br />
204 silly reify mark retired [<br />
204 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tweetnacl'<br />
204 silly reify ]<br />
205 silly reify mark retired [<br />
205 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript',<br />
205 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsc',<br />
205 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsserver'<br />
205 silly reify ]<br />
206 silly reify mark retired [<br />
206 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/unbzip2-stream'<br />
206 silly reify ]<br />
207 silly reify mark retired [<br />
207 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uri-js'<br />
207 silly reify ]<br />
208 silly reify mark retired [<br />
208 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/url-parse-lax'<br />
208 silly reify ]<br />
209 silly reify mark retired [<br />
209 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/url-to-options'<br />
209 silly reify ]<br />
210 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/usb' ]<br />
211 silly reify mark retired [<br />
211 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/util-deprecate'<br />
211 silly reify ]<br />
212 silly reify mark retired [<br />
212 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uuid',<br />
212 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/uuid'<br />
212 silly reify ]<br />
213 silly reify mark retired [<br />
213 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/verror'<br />
213 silly reify ]<br />
214 silly reify mark retired [<br />
214 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/virtual-tsc'<br />
214 silly reify ]<br />
215 silly reify mark retired [<br />
215 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/wake_on_lan',<br />
215 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/wake'<br />
215 silly reify ]<br />
216 silly reify mark retired [<br />
216 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/wrappy'<br />
216 silly reify ]<br />
217 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/xtend' ]<br />
218 silly reify mark retired [<br />
218 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/yallist'<br />
218 silly reify ]<br />
219 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/yauzl' ]<br />
220 silly reify mark retired [<br />
220 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/<a class="plugin-mentions-user plugin-mentions-a" href="/user/iobroker" aria-label="Profile: iobroker">@<bdi>iobroker</bdi></a>/adapter-core'<br />
220 silly reify ]<br />
221 silly reify mark retired [<br />
221 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/caseless'<br />
221 silly reify ]<br />
222 silly reify mark retired [<br />
222 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@sindresorhus/is'<br />
222 silly reify ]<br />
223 silly reify mark retired [<br />
223 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/iobroker'<br />
223 silly reify ]<br />
224 silly reify mark retired [<br />
224 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node'<br />
224 silly reify ]<br />
225 silly reify mark retired [<br />
225 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/request'<br />
225 silly reify ]<br />
226 silly reify mark retired [<br />
226 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/tough-cookie'<br />
226 silly reify ]<br />
227 silly reify mark retired [<br />
227 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk',<br />
227 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-conv',<br />
227 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-sign',<br />
227 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-verify'<br />
227 silly reify ]<br />
228 silly reify moves {<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ajv-JWAHQ164',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/archive-type': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.archive-type-3GzbVy99',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asn1': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.asn1-begjjmYE',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/assert-plus': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.assert-plus-CvwT5c2f',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/asynckit': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.asynckit-s0phpr5l',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws-sign2': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.aws-sign2-i67xE5NL',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/aws4': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.aws4-ewgSeGU1',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/base64-js': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.base64-js-CMxDgSwp',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bcrypt-pbkdf': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bcrypt-pbkdf-FkcXJSG6',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bl': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bl-tXcstEmh',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bluetooth-hci-socket': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bluetooth-hci-socket-LLgU3d50',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/bplist-parser': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bplist-parser-Gw4mjLSv',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.buffer-jMN3QEXD',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-alloc': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.buffer-alloc-X1fED6E7',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-alloc-unsafe': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.buffer-alloc-unsafe-80OHTfqv',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-crc32': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.buffer-crc32-cFTv6cUc',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-fill': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.buffer-fill-5TccPbH2',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cacheable-request': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.cacheable-request-7Qr1qFGw',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/call-bind': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.call-bind-jQ2HDLx1',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/caseless': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.caseless-H2SaxUok',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-response': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.clone-response-huORZ122',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.coffeescript-btitSxqy',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/coffee': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.coffee-Ne3HN5Co',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/cake': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.cake-vF6kAtwy',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/combined-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.combined-stream-HoYmPyrw',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/commander': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.commander-P4zg2JoS',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/content-disposition': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.content-disposition-ykNJNQbu',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/core-util-is': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.core-util-is-eZ4fUaee',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/dashdash': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.dashdash-nWlk69uH',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/debug': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.debug-A3k10AtD',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decode-uri-component': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decode-uri-component-CMOQnZCN',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decompress-jANiOqwy',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-response': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decompress-response-mSREN8o7',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-tar': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decompress-tar-aFLFgMpn',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-tarbz2': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decompress-tarbz2-J0MOywyt',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-targz': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decompress-targz-NMX7flNZ',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/decompress-unzip': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.decompress-unzip-SCgptaCu',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/define-properties': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.define-properties-6XwZYcVY',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/delayed-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.delayed-stream-qacC3mjc',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/download': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.download-FZgZNHG4',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexer3': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.duplexer3-GSniCpAc',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ecc-jsbn': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ecc-jsbn-W1wmyGbT',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/end-of-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.end-of-stream-pGA0SfeC',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ext-list': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ext-list-CbquslXA',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ext-name': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ext-name-w2cAb5N9',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extend': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.extend-pv2WceUi',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/extsprintf': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.extsprintf-l37IDaAf',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-deep-equal': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.fast-deep-equal-JqieQuGS',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-json-stable-stringify': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.fast-json-stable-stringify-zZtSpvEn',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fd-slicer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.fd-slicer-CGbB7jDs',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/file-type': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.file-type-MyF2AuGo',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/filename-reserved-regex': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.filename-reserved-regex-NQVIkyqX',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/filenamify': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.filenamify-055Pvtkk',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/forever-agent': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.forever-agent-hJzMqug0',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/form-data': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.form-data-f5gN4soy',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/from2': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.from2-rHxymetq',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/fs-constants': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.fs-constants-RCPP7GAQ',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/function-bind': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.function-bind-xNuYoKHH',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/get-intrinsic': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.get-intrinsic-jaHndEV0',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/getpass': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.getpass-kOCUh1aA',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/got': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.got-LoRNXoPs',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/graceful-fs': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.graceful-fs-0lTymp4w',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-schema': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.har-schema-rWbJu3Hi',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-validator': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.har-validator-eyrBsHVJ',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.has-xBeCSK4w',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-property-descriptors': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.has-property-descriptors-NgHV0bqO',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbol-support-x': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.has-symbol-support-x-kJ1XKcwn',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbols': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.has-symbols-BlLhZd6T',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-to-string-tag-x': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.has-to-string-tag-x-D0rqbi1N',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-cache-semantics': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.http-cache-semantics-pwHcy6Um',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.http-signature-oUoVxdIq',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ieee754': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ieee754-ZkXktYfP',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/immediate': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.immediate-mU3gxEZk',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/inherits': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.inherits-n3Ch46Yn',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/into-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.into-stream-9jikZ2iK',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-nan': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.is-nan-aBR69xZy',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-natural-number': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.is-natural-number-7DVP81Ku',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-object': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.is-object-f37RttIf',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-retry-allowed': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.is-retry-allowed-bbEHMwWr',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/is-typedarray': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.is-typedarray-kgxdw7hd',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isarray': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.isarray-5wOzaH7B',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isstream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.isstream-kucfBgOe',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/isurl': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.isurl-PFPtYcIS',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsbn': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.jsbn-7awNYEqn',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-buffer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.json-buffer-1DvjfwxG',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.json-schema-gJeujQHS',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema-traverse': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.json-schema-traverse-lxkTlMes',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/json-stringify-safe': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.json-stringify-safe-6OEF7DXQ',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsonata': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.jsonata-sj644a8k',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jsprim': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.jsprim-Hb03jZ2t',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/jszip': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.jszip-E0haUyzW',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/keyv': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.keyv-j7k6j1x3',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lie': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.lie-rDNcdBdn',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/long-timeout': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.long-timeout-UsqWplKY',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lowercase-keys': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.lowercase-keys-H4pYv5DL',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/lru-cache': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.lru-cache-pTWFZBit',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/make-dir': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.make-dir-kpACuPQc',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-db': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.mime-db-ILNMz48k',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-types': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.mime-types-vVlqwvNj',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mimic-response': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.mimic-response-l1h59Fzs',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/minimist': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.minimist-HEtqlfZM',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ms': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.ms-T3oF4fuS',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/nan': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.nan-adtTkJBo',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/noble': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.noble-UcE4HbYj',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-addon-api': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.node-addon-api-zOIY1GW8',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-gyp-build': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.node-gyp-build-Nc8n2hOB',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-gyp-build': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.node-gyp-build-L57SCOlW',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-gyp-build-optional': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.node-gyp-build-optional-Tk80r8za',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-gyp-build-test': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.node-gyp-build-test-izfPMJbu',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-inspect': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.node-inspect-7uCQsf40',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/node-inspect': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.node-inspect-RjTdcqZj',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/normalize-url': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.normalize-url-dTP3Oa7k',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/oauth-sign': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.oauth-sign-4TUsb1Hr',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/object-assign': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.object-assign-5Cf04ud8',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/object-keys': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.object-keys-L9W7bKqM',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/once': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.once-RFC770N3',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-cancelable': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.p-cancelable-u9fp3HLr',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-event': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.p-event-E5j32boQ',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-finally': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.p-finally-L9V5raVS',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-is-promise': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.p-is-promise-tNH5kneE',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/p-timeout': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.p-timeout-eSN8lQGZ',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pako': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.pako-rbL7BtOy',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pend': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.pend-BYTjI9Hf',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/performance-now': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.performance-now-rzc7QsAk',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/picocolors': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.picocolors-DQ4TN0mE',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pify': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.pify-kU90vZ0r',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.pinkie-7z22R4ew',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie-promise': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.pinkie-promise-6MuYHt6L',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/prepend-http': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.prepend-http-oFgNJ3Hh',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/process-nextick-args': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.process-nextick-args-1FsUsOM8',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/psl': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.psl-P3JlcAO8',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/punycode': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.punycode-l3TLrnOQ',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/query-string': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.query-string-3uidnXUa',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/readable-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.readable-stream-DGJrLMhV',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.request-IwHtFKjv',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/responselike': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.responselike-tYm4pETH',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safe-buffer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.safe-buffer-GY19LMpy',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/safer-buffer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.safer-buffer-VoLQjGhM',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/seek-bzip': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.seek-bzip-JAWtZniv',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/seek-bunzip': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.seek-bunzip-CkVLvAS4',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/seek-table': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.seek-table-f3sdHWHj',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/semver': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.semver-nXF4HfsQ',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/semver': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.semver-Dy7i6zG2',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/setimmediate': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.setimmediate-rLmz5kvN',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sort-keys': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.sort-keys-qcvjMZ6g',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sort-keys-length': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.sort-keys-length-4IGif44d',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sorted-array-functions': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.sorted-array-functions-b2PxWBDs',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/strict-uri-encode': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.strict-uri-encode-WyOTcxtB',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/string_decoder': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.string_decoder-QqeclkYI',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-dirs': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.strip-dirs-8hbG4Qht',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-outer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.strip-outer-syQyolcG',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/suncalc2': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.suncalc2-tGRLIVnX',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tar-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.tar-stream-oOO7qk7O',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/through': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.through-fysaHtUl',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/timed-out': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.timed-out-wvGaABGU',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/to-buffer': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.to-buffer-ZDZJ5ICv',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tough-cookie': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.tough-cookie-msAnSxYU',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/trim-repeated': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.trim-repeated-p6XbDaUh',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tunnel-agent': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.tunnel-agent-oUVQRXxE',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/tweetnacl': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.tweetnacl-BnSTSyIu',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.typescript-EcwXdkx5',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsc': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.tsc-0PIrZBWg',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/tsserver': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.tsserver-QDbM4cAE',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/unbzip2-stream': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.unbzip2-stream-7cC95xXq',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uri-js': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.uri-js-8VwjhWYz',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/url-parse-lax': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.url-parse-lax-L4Pi5Fdr',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/url-to-options': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.url-to-options-VEmeYCpr',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/usb': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.usb-eaYctfOO',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/util-deprecate': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.util-deprecate-e5GNBBxw',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/uuid': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.uuid-0rL1ORyz',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/uuid': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.uuid-gQ53C49H',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/verror': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.verror-EsRYTvUd',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/virtual-tsc': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.virtual-tsc-Z1y2mItj',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/wake_on_lan': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.wake_on_lan-aA1sq5Hq',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/wake': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.wake-PZWgBD8w',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/wrappy': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.wrappy-FK4KH90e',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/xtend': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.xtend-kCzojcVd',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/yallist': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.yallist-Jj27Vzng',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/yauzl': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.yauzl-I4OoZHvp',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/<a class="plugin-mentions-user plugin-mentions-a" href="/user/iobroker" aria-label="Profile: iobroker">@<bdi>iobroker</bdi></a>/adapter-core': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/<a class="plugin-mentions-user plugin-mentions-a" href="/user/iobroker" aria-label="Profile: iobroker">@<bdi>iobroker</bdi></a>/.adapter-core-5hqHvhca',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/caseless': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.caseless-E7EBKTiW',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@sindresorhus/is': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@sindresorhus/.is-g9nAs77m',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/iobroker': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.iobroker-H0DYMotS',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.node-f0Rqzy2m',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/request': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.request-jbJT2ToX',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/tough-cookie': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.tough-cookie-ZhFQ7n2j',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.sshpk-29rDccd4',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-conv': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.sshpk-conv-dbhOTJ0f',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-sign': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.sshpk-sign-0kGWm4VB',<br />
228 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/sshpk-verify': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.sshpk-verify-Bif9pYCN'<br />
228 silly reify }<br />
229 timing reify:retireShallow Completed in 216ms<br />
230 timing reify:createSparse Completed in 9ms<br />
231 timing reify:loadBundles Completed in 0ms<br />
232 verbose reify failed optional dependency /opt/iobroker/node_modules/fsevents<br />
233 silly reify mark deleted [ '/opt/iobroker/node_modules/fsevents' ]<br />
234 timing reifyNode:node_modules/fsevents Completed in 13ms<br />
235 timing reifyNode:node_modules/iobroker.vis/node_modules/axios Completed in 443ms<br />
236 timing reifyNode:node_modules/iobroker.javascript/node_modules/@types/node Completed in 530ms<br />
237 timing reifyNode:node_modules/iobroker.vis Completed in 850ms<br />
238 timing reify:unpack Completed in 851ms<br />
239 timing reify:unretire Completed in 3ms<br />
240 timing build:queue Completed in 3ms<br />
241 info run iobroker.vis@1.4.10 install node_modules/iobroker.vis node main.js --install<br />
242 info run iobroker.vis@1.4.10 install { code: 6, signal: null }<br />
243 timing reify:rollback:createSparse Completed in 366ms<br />
244 timing reify:rollback:retireShallow Completed in 111ms<br />
245 timing command:install Completed in 15673ms<br />
246 verbose stack Error: command failed<br />
246 verbose stack     at ChildProcess.&lt;anonymous&gt; (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:63:27)<br />
246 verbose stack     at ChildProcess.emit (node:events:513:28)<br />
246 verbose stack     at maybeClose (node:internal/child_process:1100:16)<br />
246 verbose stack     at Process.ChildProcess._handle.onexit (node:internal/child_process:304:5)<br />
247 verbose pkgid iobroker.vis@1.4.10<br />
248 verbose cwd /opt/iobroker<br />
249 verbose Linux 5.15.84-v8+<br />
250 verbose node v16.19.0<br />
251 verbose npm  v8.19.3<br />
252 error code 6<br />
253 error path /opt/iobroker/node_modules/iobroker.vis<br />
254 error command failed<br />
255 error command sh -c -- node main.js --install<br />
256 verbose exit 6<br />
257 timing npm Completed in 16070ms<br />
258 verbose unfinished npm timer reify 1674819220592<br />
259 verbose unfinished npm timer reify:build 1674819232226<br />
260 verbose unfinished npm timer build 1674819232229<br />
261 verbose unfinished npm timer build:deps 1674819232230<br />
262 verbose unfinished npm timer build:run:install 1674819232234<br />
263 verbose unfinished npm timer build:run:install:node_modules/iobroker.vis 1674819232235<br />
264 verbose code 6<br />
265 error A complete log of this run can be found in:<br />
265 error     /home/iobroker/.npm/_logs/2023-01-27T11_33_40_209Z-debug-0.log<p></p>
<p dir="auto"></p></section></section><p></p>
]]></description><link>https://forum.iobroker.net/post/936188</link><guid isPermaLink="true">https://forum.iobroker.net/post/936188</guid><dc:creator><![CDATA[w00dy]]></dc:creator><pubDate>Fri, 27 Jan 2023 16:07:08 GMT</pubDate></item><item><title><![CDATA[Reply to VIS-Adapter nach Neuinst.+Backitup-Restore tot on Fri, 27 Jan 2023 12:24:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/w00dy" aria-label="Profile: w00dy">@<bdi>w00dy</bdi></a></p>
<p dir="auto">Was steht denn in dem genannten Log drin?</p>
]]></description><link>https://forum.iobroker.net/post/936064</link><guid isPermaLink="true">https://forum.iobroker.net/post/936064</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 27 Jan 2023 12:24:17 GMT</pubDate></item><item><title><![CDATA[Reply to VIS-Adapter nach Neuinst.+Backitup-Restore tot on Fri, 27 Jan 2023 11:37:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">Geht leider auch nicht:</p>
<pre><code>pi@ioBroker:~ $ iobroker upgrade vis@1.4.10 --host ioBroker --debug
This upgrade of "vis" will at least introduce the following changes:
-&gt; 1.4.8:
Added support for js-controller 4.x
-&gt; 1.4.7:
Fixed subscribeOidAtRuntime if called with invalid IDs
Added support of license manager
BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
Would you like to upgrade vis from @0.0.0 to @1.4.10 now? [(y)es, (n)o]: yes
Update vis from @0.0.0 to @1.4.10
NPM version: 8.19.3
Installing iobroker.vis@1.4.10... (System call)
npm ERR! code 6
npm ERR! path /opt/iobroker/node_modules/iobroker.vis
npm ERR! command failed
npm ERR! command sh -c -- node main.js --install
npm ERR!     /home/iobroker/.npm/_logs/2023-01-27T11_33_40_209Z-debug-0.log
host.ioBroker Cannot install iobroker.vis@1.4.10: 6
pi@ioBroker:~ $
</code></pre>
]]></description><link>https://forum.iobroker.net/post/936047</link><guid isPermaLink="true">https://forum.iobroker.net/post/936047</guid><dc:creator><![CDATA[w00dy]]></dc:creator><pubDate>Fri, 27 Jan 2023 11:37:02 GMT</pubDate></item><item><title><![CDATA[Reply to VIS-Adapter nach Neuinst.+Backitup-Restore tot on Fri, 27 Jan 2023 11:36:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/djmarc75" aria-label="Profile: djmarc75">@<bdi>djmarc75</bdi></a><br />
Hi, das hatte ich schon probiert und dachte das "@" sei falsch gewesen. Beide Varianten gehen nicht.</p>
]]></description><link>https://forum.iobroker.net/post/936046</link><guid isPermaLink="true">https://forum.iobroker.net/post/936046</guid><dc:creator><![CDATA[w00dy]]></dc:creator><pubDate>Fri, 27 Jan 2023 11:36:35 GMT</pubDate></item><item><title><![CDATA[Reply to VIS-Adapter nach Neuinst.+Backitup-Restore tot on Fri, 27 Jan 2023 11:20:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/w00dy" aria-label="Profile: w00dy">@<bdi>w00dy</bdi></a></p>
<pre><code>iobroker upgrade vis@1.4.10 --host ioBroker --debug
</code></pre>
]]></description><link>https://forum.iobroker.net/post/936039</link><guid isPermaLink="true">https://forum.iobroker.net/post/936039</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 27 Jan 2023 11:20:59 GMT</pubDate></item><item><title><![CDATA[Reply to VIS-Adapter nach Neuinst.+Backitup-Restore tot on Fri, 27 Jan 2023 11:02:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/w00dy" aria-label="Profile: w00dy">@<bdi>w00dy</bdi></a></p>
<pre><code>iobroker upgrade vis@1.4.0
</code></pre>
<p dir="auto">probier mal</p>
]]></description><link>https://forum.iobroker.net/post/936032</link><guid isPermaLink="true">https://forum.iobroker.net/post/936032</guid><dc:creator><![CDATA[DJMarc75]]></dc:creator><pubDate>Fri, 27 Jan 2023 11:02:10 GMT</pubDate></item><item><title><![CDATA[Reply to VIS-Adapter nach Neuinst.+Backitup-Restore tot on Fri, 27 Jan 2023 11:00:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<pre><code>pi@ioBroker:~ $ iobroker add vis 1.4.10
ERROR: No repositories defined. Please define one repository as active:  "iob repo set &lt;stable | beta | live-beta&gt;
pi@ioBroker:~ $ iob repo set stable
Repository "stable" set as active.
live-beta     : http://iobroker.live/repo/sources-dist-latest.json
Active repo(s): stable
pi@ioBroker:~ $
</code></pre>
<p dir="auto">Ich bin echt nicht fit an der Konsole, aber jetzt sollten doch alle Voraussetzungen erfüllt sein um vis 1.4.10 installieren zu können.</p>
<p dir="auto">Ich komme da einfach nicht weiter. Hast du noch ne Idee?</p>
]]></description><link>https://forum.iobroker.net/post/936030</link><guid isPermaLink="true">https://forum.iobroker.net/post/936030</guid><dc:creator><![CDATA[w00dy]]></dc:creator><pubDate>Fri, 27 Jan 2023 11:00:22 GMT</pubDate></item><item><title><![CDATA[Reply to VIS-Adapter nach Neuinst.+Backitup-Restore tot on Fri, 27 Jan 2023 10:22:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">OK, mein Fehler, falsch interpretiert. Dennoch bekomme ich folgenden Fehler:</p>
pi@ioBroker:~ $
</code></pre>
<p dir="auto">Als Repo ist stable in den Einstellungen aktiviert.<br />
<img src="/assets/uploads/files/1674814924366-p01.png" alt="P01.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.iobroker.net/post/936001</link><guid isPermaLink="true">https://forum.iobroker.net/post/936001</guid><dc:creator><![CDATA[w00dy]]></dc:creator><pubDate>Fri, 27 Jan 2023 10:22:07 GMT</pubDate></item><item><title><![CDATA[Reply to VIS-Adapter nach Neuinst.+Backitup-Restore tot on Fri, 27 Jan 2023 10:05:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">Das funktioniert nicht:</p>
<pre><code>pi@ioBroker:~ $ iobroker add vis@1.4.10
NPM version: 8.19.3
pi@ioBroker:~ $
</code></pre>
]]></description><link>https://forum.iobroker.net/post/935991</link><guid isPermaLink="true">https://forum.iobroker.net/post/935991</guid><dc:creator><![CDATA[w00dy]]></dc:creator><pubDate>Fri, 27 Jan 2023 10:05:00 GMT</pubDate></item><item><title><![CDATA[Reply to VIS-Adapter nach Neuinst.+Backitup-Restore tot on Fri, 27 Jan 2023 10:02:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/w00dy" aria-label="Profile: w00dy">@<bdi>w00dy</bdi></a><br />
Die Kommandozeile ist wie immer dein Freund:</p>
<pre><code>iobroker add vis@GEWÜNSCHTE_VERSIONSNUMMER
</code></pre>
]]></description><link>https://forum.iobroker.net/post/935989</link><guid isPermaLink="true">https://forum.iobroker.net/post/935989</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 27 Jan 2023 10:02:02 GMT</pubDate></item><item><title><![CDATA[Reply to VIS-Adapter nach Neuinst.+Backitup-Restore tot on Fri, 27 Jan 2023 10:01:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> sagte in <a href="/post/935976">VIS-Adapter n. Neuinst.+Backitup-Restore tot-Neuinst.=error</a>:</p>
<blockquote>
<p dir="auto">Warum leider? Die 64bit-Version ist wesentlich sinnvoller, wenn man schon die Wahl hat.</p>
</blockquote>
<p dir="auto">Da hast du schon recht! Das "leider" bezieht sich nur auf das Problem welches danach entstand.</p>
<p dir="auto">Woher bekomme ich denn die Version von vis. 1.4.10? Normalerweise kann ich die Versionen bei den Adaptern die installiert sind auswählen, das Funktioniert bei mir allerdings nicht.</p>
]]></description><link>https://forum.iobroker.net/post/935988</link><guid isPermaLink="true">https://forum.iobroker.net/post/935988</guid><dc:creator><![CDATA[w00dy]]></dc:creator><pubDate>Fri, 27 Jan 2023 10:01:05 GMT</pubDate></item><item><title><![CDATA[Reply to VIS-Adapter nach Neuinst.+Backitup-Restore tot on Fri, 27 Jan 2023 09:47:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/w00dy" aria-label="Profile: w00dy">@<bdi>w00dy</bdi></a> sagte in <a href="/post/935968">VIS-Adapter n. Neuinst.+Backitup-Restore tot-Neuinst.=error</a>:</p>
<blockquote>
<p dir="auto">Habt Ihr eine Idee, was da los ist?</p>
</blockquote>
<p dir="auto">Installier eine der Vorversionen von vis. 1.4.10 z. B. und dann dort das Backup drüberbügeln.</p>
<blockquote>
<p dir="auto">musste ich leider auf die 64-bit Variante von Bullseye für den Raspberry umsteigen.</p>
</blockquote>
]]></description><link>https://forum.iobroker.net/post/935976</link><guid isPermaLink="true">https://forum.iobroker.net/post/935976</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 27 Jan 2023 09:47:25 GMT</pubDate></item></channel></rss>
