  4. Script Hilfe für Abfrage Serielle Kommunikation gesucht!
    6.8k
192 Beiträge 15 Kommentatoren 40.9k Aufrufe 10 Beobachtet
  • wendy2702W Offline
    wendy2702W Offline
    #137
    Hier noch zum Umschalten Warmwasser auf 45 Grad
    createState('Waterkotte.Daten.WW_TEMP_Change_feedback');
    // To use the `ByteLength` parser:
    const { SerialPort } = require('serialport');
    const { ByteLengthParser } = require('@serialport/parser-byte-length');
    var buffer = Buffer.alloc(14);
    buffer[0] = 0x10;
    buffer[1] = 0x02;
    buffer[2] = 0x01;
    buffer[3] = 0x13;
    buffer[4] = 0x01;
    buffer[5] = 0x3b;
    buffer[6] = 0x00;		// Fourth 2 Hex
    buffer[7] = 0x00;		// Third 2 Hex
    buffer[8] = 0x34;		//Second 2 Hex
    buffer[9] = 0x42;		//First 2 Hex
    buffer[10] = 0x10;
    buffer[11] = 0x03;
    buffer[12] = 0xc8;  	//CRC
    buffer[13] = 0x72;		//CRC
    const port = new SerialPort({
       path: '/dev/ttyUSB1',
       baudRate: 9600,
       dataBits : 8,
       parity : 'none',
       stopBits: 1
       //  flowControl : false
    function (err) {
       if (err) {
    //        port.close();
           return console.log('Error1: ', err.message);
       const parser = port.pipe(new ByteLengthParser({ length: 11 }));
       parser.on('data', function (data) {
       	console.log('Data received: ' + data.toString('hex'));
       	var daten = data.toString('hex');
       	setState('Waterkotte.Daten.WW_TEMP_Change_feedback', daten, true);
       	//port.close();
       // Flush input
       port.flush();
       // send Data
           port.write(buffer, function(err) {
       	    if (err) {
       		    return console.log('Error on write: ', err.message);
       	    console.log('Daten send');
    // 		    port.close();
    port.on('open', function() {
       console.log('Connected');
    port.on('error', function(err) {
       console.log('Error2: ', err.message);
    //	port.close();
    // close port if the script stopped (to be able to open it again)
    onStop(function (callback) {
       if (port && port.isOpen) {
       	port.close();
       	console.log('port closed');
    Hier umschalten Warmwasser auf 60Grad
    buffer[0] = 0x10;
    buffer[1] = 0x02;
    buffer[2] = 0x01;
    buffer[3] = 0x13;
    buffer[4] = 0x01;
    buffer[5] = 0x3b;
    buffer[6] = 0x00;
    buffer[7] = 0x00;
    buffer[8] = 0x70;
    buffer[9] = 0x42;
    buffer[10] = 0x10;
    buffer[11] = 0x03;
    buffer[12] = 0xd0;
    buffer[13] = 0x77;
       baudRate: 9600,
       dataBits : 8,
       parity : 'none',
       stopBits: 1
    function (err) {
       if (err) {
    //        port.close();
       	//port.close();
       // Flush input
       port.flush();
       // send Data
       	    if (err) {
    // 		    port.close();
    //	port.close();
       	port.close();
    • wendy2702W wendy2702
      @axel-koeneke sagte in Script Hilfe für Abfrage Serielle Kommunikation gesucht!:
      Hallo Wendy,
      hast du das Script schon unter V10 zum laufen gebracht?
      Ja, heute Zeit gehabt, getestet mit Serialport 10.4.0
      pi@iob-test:/opt/iobroker/node_modules/iobroker.javascript $ npm ls serialport
      iobroker.javascript@5.4.0 /opt/iobroker/node_modules/iobroker.javascript
      └── serialport@10.4.0
      Vielleicht findet ja jemand Zeit und Lust das auch mal bei sich zu testen.
      // Anpassungen durch USER:
      // Zeile 8 Javascript.x <-- eigene verwendete JS Instanz angeben
      // Zeile 29 Device anpassen
      // Zeile 41 Javascript.x <-- eigene verwendete JS Instanz angeben
      createState('Waterkotte.Daten.Abfrage_Rohdaten');
      //createState('Waterkotte.Daten.Abfrage_Error');
      setState("javascript.0.Waterkotte.Daten.Abfrage_Error"/*Waterkotte.Daten.Abfrage_Error*/, false);
      var buffer = Buffer.alloc(12);
      buffer[0] = 0x10;
      buffer[1] = 0x02;
      buffer[2] = 0x01;
      buffer[3] = 0x15;
      buffer[4] = 0x00;
      buffer[5] = 0x00;
      buffer[6] = 0x00;
      buffer[7] = 0xf3;
      buffer[8] = 0x10;
      buffer[9] = 0x03;
      buffer[10] = 0x7c;
      buffer[11] = 0x32;
          path: '/dev/ttyUSB0',
          baudRate: 9600,
          dataBits : 8,
          parity : 'none',
          stopBits: 1
      function (err)
          {if (err) {
      //        port.close();
              setState("javascript.0.Waterkotte.Daten.Abfrage_Error"/*Waterkotte.Daten.Abfrage_Error*/, true);
          const parser = port.pipe(new ByteLengthParser({ length: 253 }));
              setState('Waterkotte.Daten.Abfrage_Rohdaten', daten, true);
              //port.close();
           // Flush input
           port.flush();
           // send Data
               if (err) {
      //       port.close();
      //  port.close();
              port.close();
      Geht bestimmt auch schöner aber mehr geben meine Rudimentären JS Kenntnisse aktuell nicht her :-)
      Axel KoenekeA Offline
      Axel Koeneke
      #138
      @wendy2702 sagte in Script Hilfe für Abfrage Serielle Kommunikation gesucht!:
      Hallo Wendy,
      buffer[0] = 0x10;
      buffer[1] = 0x02;
      buffer[2] = 0x01;
      buffer[3] = 0x15;
      buffer[4] = 0x00;
      buffer[5] = 0x00;
      buffer[6] = 0x00;
      buffer[7] = 0xf3;
      buffer[8] = 0x10;
      buffer[9] = 0x03;
      buffer[10] = 0x7c;
      buffer[11] = 0x32;
          baudRate: 9600,
          dataBits : 8,
          parity : 'none',
          stopBits: 1
      function (err)
          {if (err) {
      //        port.close();
              //port.close();
           // Flush input
           port.flush();
           // send Data
               if (err) {
      //       port.close();
      //  port.close();
              port.close();
      Moin, werde es heute Abend mal testen.
      Axel
        Hallo Wendy,
        buffer[0] = 0x10;
        buffer[1] = 0x02;
        buffer[2] = 0x01;
        buffer[3] = 0x15;
        buffer[4] = 0x00;
        buffer[5] = 0x00;
        buffer[6] = 0x00;
        buffer[7] = 0xf3;
        buffer[8] = 0x10;
        buffer[9] = 0x03;
        buffer[10] = 0x7c;
        buffer[11] = 0x32;
            baudRate: 9600,
            dataBits : 8,
            parity : 'none',
            stopBits: 1
        function (err)
            {if (err) {
        //        port.close();
                //port.close();
             // Flush input
             port.flush();
             // send Data
                 if (err) {
        //       port.close();
        //  port.close();
                port.close();
        etzeste13
        #139
        @wendy2702
        ich habe dein Scrict nun getestet....
        es funktioniert mit dem serialport 10.. mit dem 9.x hat es nicht funktioniert.
        Vielen Dank für die Anpassung des Scripts!!
        vG
        Etze
        • E etzeste13
          @wendy2702
          vG
          Etze
          wendy2702W Offline
          wendy2702W Offline
          #140
          @etzeste13 Danke fürs testen!
          Axel KoenekeA 1 Antwort Letzte Antwort
            Axel Koeneke
            #141
            @wendy2702 Bin jetzt auch zum testen gezwungen worden.
            Läuft prima!
            • Axel KoenekeA Axel Koeneke
              Läuft prima!
              Axel Koeneke
              #142
              @wendy2702 Habe jetzt mal den Error Datenpunkt im Eventlogger mitgeschrieben und bin überrascht wie oft die Instanz zurückgesetzt wird. Ist das bei dir auch so?
              Axel
                Axel
                wendy2702W Offline
                wendy2702W Offline
                #143
                @axel-koeneke Was genau zeichnest du da auf und welche Instanz meinst du?
                • Axel KoenekeA Offline
                  Axel Koeneke
                  #144
                  @wendy2702 Ich starte die Javascript Instanz (nur die auf dem Slave(PI)) neu, wenn das Error Bit in der Abfrage gesetzt wird. So wie du es wohl auch machst.
                    wendy2702W Offline
                    wendy2702W Offline
                    #145
                    @axel-koeneke Hmmm,
                    also meine JS Instanz wurde in den letzten 8 Tagen 2x neu gestartet. Da gab es laut log wohl eine Überschneidung und der Port wurde nicht sauber geschlossen.
                    W 1 Antwort Letzte Antwort
                      @axel-koeneke Hmmm,
                      W Offline
                      W Offline
                      worxweis
                      #146
                      Hallo Leute!
                      ich besitze auch eine Waterkotte WP mit WPCU Regler!
                      Model: DS 9301, FW1.00.11d
                      Hier ist der Standard Kommunikationsmodus "Line-Modbus". Schnittstelle hat der Regler eine RS232.
                      Hat irgendjemand hier Erfahrung, ob man diesen Regler mit dem Modbus Adapter auslesen kann?
                      RTU kann der ja, und Line-Modbus dürfte ja eine RTU Modbus Variante sein, oder?
                        wendy2702W Offline
                        #147
                        @worxweis sagte in Script Hilfe für Abfrage Serielle Kommunikation gesucht!:
                        WPCU Regler
                        Lese mal ab hier:
                        https://forum.iobroker.net/post/221705
                          @etzeste13 Kann viele Ursachen haben.
                          Nullmodem Kabel ist falsch belegt
                          "Modem" ist in der WP deaktiviert
                          Das Flachbandkabel am Resümat zur RS232 Buchse ist ab
                          USB Seriell Adapter hat einen Fehler
                          Um zu Testen ob dein Adapter und das Kabel funktioniert kannst du es mal mit dieser SW Versuchen:
                          Waterkotte Control
                          W Offline
                          W Offline
                          worxweis
                          #148
                          @wendy2702 Hallo!
                          bin nicht so der Linux Fuchs. Kann mir jemand erklären, wie ich das Watercontrol am Raspy oder auf einem Windows Rechner zum laufen bekomme?
                          Danke!
                          • W worxweis
                            @wendy2702 Hallo!
                            Danke!
                            wendy2702W Offline
                            wendy2702W Offline
                            #149
                            Watercontrol
                            Was meinst du damit?
                              Watercontrol
                              W Offline
                              W Offline
                              worxweis
                              #150
                              @wendy2702 Na ich meine das Prog Waterkotte Controll
                              1. welche Dateien benötige ich hier
                              2. wie erstelle ich damit ein Programm, dass ich ausführen kann, um die Verbindung zu testen.
                              Ich habe jetzt nämlich im IOBroker die Scripte soweit am laufen, keine Fehlermeldungen mehr, bekomme aber keine Daten aus der Waterkotte raus. Daher würde ich das gerne mal mit dem Programm testen.
                              Habe meinen Raspberry vor Ort, bzw. einen Laptop mit Windows.
                              • W worxweis
                                Hallo Leute!
                                wendy2702W Offline
                                wendy2702W Offline
                                #151
                                Hallo Leute!
                                Der Regler, passt nicht zu der SW die du testen möchtest:
                                  Hallo Leute!
                                  W Offline
                                  W Offline
                                  worxweis
                                  #152
                                  @wendy2702 okay, aber gibt es irgendeine Software, mit der ich die Schnittstelle prüfen kann, ob sie ohne iobroker funktioniert?
                                  • W worxweis
                                    wendy2702W Offline
                                    wendy2702W Offline
                                    #153
                                    @worxweis Kann ich dir nicht sagen. Hatte nie einen WPCU Regler.
                                    Da musst du Google oder die Suchmaschine deiner Wahl bemühen.
                                      trollsoft
                                      #154
                                      Hallo, danke für all Eure Infos zum Fernauslesen des Resümats. Benutze selbst den HomeAssistant mit NodeRed. https://github.com/trollsoft7/waterkotte-resuemat-nodered
                                      Darüber funktioniert das Auslesen einwandfrei.
                                      Kenne den IOBroker kaum, aber vielleicht hilft es jemanden. lg
                                      • T trollsoft
                                        mickymM Online
                                        mickymM Online
                                        mickym
                                        #155
                                        @trollsoft dann installiere doch den Node-Red Adapter. Ich nutze Node Red generell als Logik Maschine im iobroker. Iobroker und node-red sind in Kombination unschlagbar
                                        • mickymM mickym
                                          trollsoft
                                          #156
                                          @mickym Danke, bin mit dem HA recht zufrieden. Wollte es euch nur zur Verfügung stellen, vielleicht kann es ja jemand brauchen. Eure Beiträge haben mir auch sehr geholfen.
