  4. Test Adapter Govee via AWS/App
    6.6k
132 Beiträge 29 Kommentatoren 37.4k Aufrufe 34 Beobachtet
  • T tombox
    @ilovegym Es gäbe anscheinend noch ein anderes status format bitte mal die GitHub version testen
    @tombox
    erst lief se ohne Fehler, auf einmal kam dann das hier dauernd, hatte ein Device an..
    2023-01-08 20:14:20.401  - debug: govee-app.0 (600033) MQTT message: GA/0d2dfc1424762d1da5b0d91a8f8868ca {"proType":2,"sku":"H605B","device":"BE:20:D6:39:32:37:2B:67","softVersion":"1.02.01","wifiSoftVersion":"1.00.12","cmd":"status","type":0,"transaction":"x_1673205258458","pactType":1,"pactCode":1,"state":{"onOff":1,"brightness":100,"color":{"r":255,"g":0,"b":0},"colorTemInKelvin":0,"mode":0,"wifiHardVersion":"1.03.10","bleHardVersion":"3.02.01","result":1},"op":{"command":["qlUAZDIAAQAyAAAAAAAAAAAAAJo=","qgUAAWQBAWMAAAAAAAAAAAAAAKk=","qhEAHg8PAAAAAAAAAAAAAAAAAKU=","qhL/ZAAAgAoAAAAAAAAAAAAAAKk=","qiP/AAAAgAAAAIAAAACAAAAAgHY=","qjYBAQEAAAAAAAAAAAAAAAAAAJ0=","qqkABgEQAwENBQAAAAAAAAAAAB4=","qqkCAWQAAAAAAAAAAAAAAAAAAGQ="]}}
    2023-01-08 20:14:30.679  - debug: govee-app.0 (600033) MQTT message: GA/0d2dfc1424762d1da5b0d91a8f8868ca {"proType":0,"msg":"{\"sku\":\"H6104\",\"device\":\"9A:5B:78:9C:E7:05:6A:42\",\"type\":0,\"transaction\":\"1673205270\",\"cmd\":\"IoTConnected\"}"}
    2023-01-08 20:14:30.680  - error: govee-app.0 (600033) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-01-08 20:14:30.681  - error: govee-app.0 (600033) unhandled promise rejection: Unexpected token u in JSON at position 0
    2023-01-08 20:14:30.684  - error: govee-app.0 (600033) SyntaxError: Unexpected token u in JSON at position 0
       at JSON.parse (<anonymous>)
       at DeviceClient.<anonymous> (/opt/iobroker/node_modules/iobroker.govee-app/main.js:462:25)
       at DeviceClient.emit (node:events:513:28)
       at DeviceClient.emit (node:domain:489:12)
       at MqttClient.<anonymous> (/opt/iobroker/node_modules/aws-iot-device-sdk/device/index.js:826:12)
       at MqttClient.emit (node:events:513:28)
       at MqttClient.emit (node:domain:489:12)
       at Arguments.<anonymous> (/opt/iobroker/node_modules/aws-iot-device-sdk/node_modules/mqtt/lib/client.js:1265:27)
       at Object.MqttClient.options.customHandleAcks (/opt/iobroker/node_modules/aws-iot-device-sdk/node_modules/mqtt/lib/client.js:183:150)
       at MqttClient._handlePublish (/opt/iobroker/node_modules/aws-iot-device-sdk/node_modules/mqtt/lib/client.js:1258:15)
    2023-01-08 20:14:30.684  - error: govee-app.0 (600033) Unexpected token u in JSON at position 0
    2023-01-08 20:14:30.695  - info: govee-app.0 (600033) terminating
    2023-01-08 20:14:30.695  - debug: govee-app.0 (600033) Plugin sentry destroyed
    2023-01-08 20:14:30.695  - warn: govee-app.0 (600033) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-01-08 20:14:31.244  - error: host.iobrokerS Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2023-01-08 20:14:31.245  - error: host.iobrokerS Caught by controller[0]: SyntaxError: Unexpected token u in JSON at position 0
    2023-01-08 20:14:31.245  - error: host.iobrokerS Caught by controller[0]:     at JSON.parse (<anonymous>)
    2023-01-08 20:14:31.245  - error: host.iobrokerS Caught by controller[0]:     at DeviceClient.<anonymous> (/opt/iobroker/node_modules/iobroker.govee-app/main.js:462:25)
    2023-01-08 20:14:31.245  - error: host.iobrokerS Caught by controller[0]:     at DeviceClient.emit (node:events:513:28)
    2023-01-08 20:14:31.245  - error: host.iobrokerS Caught by controller[0]:     at DeviceClient.emit (node:domain:489:12)
    2023-01-08 20:14:31.245  - error: host.iobrokerS Caught by controller[0]:     at MqttClient.<anonymous> (/opt/iobroker/node_modules/aws-iot-device-sdk/device/index.js:826:12)
    2023-01-08 20:14:31.245  - error: host.iobrokerS Caught by controller[0]:     at MqttClient.emit (node:events:513:28)
    2023-01-08 20:14:31.245  - error: host.iobrokerS Caught by controller[0]:     at MqttClient.emit (node:domain:489:12)
    2023-01-08 20:14:31.245  - error: host.iobrokerS Caught by controller[0]:     at Arguments.<anonymous> (/opt/iobroker/node_modules/aws-iot-device-sdk/node_modules/mqtt/lib/client.js:1265:27)
    2023-01-08 20:14:31.245  - error: host.iobrokerS Caught by controller[0]:     at Object.MqttClient.options.customHandleAcks (/opt/iobroker/node_modules/aws-iot-device-sdk/node_modules/mqtt/lib/client.js:183:150)
    2023-01-08 20:14:31.245  - error: host.iobrokerS Caught by controller[0]:     at MqttClient._handlePublish (/opt/iobroker/node_modules/aws-iot-device-sdk/node_modules/mqtt/lib/client.js:1258:15)
    2023-01-08 20:14:31.246  - error: host.iobrokerS instance system.adapter.govee-app.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2023-01-08 20:14:31.246  - info: host.iobrokerS Restart adapter system.adapter.govee-app.0 because enabled
    2023-01-08 20:14:31.246  - warn: host.iobrokerS Do not restart adapter system.adapter.govee-app.0 because restart loop detected
      @tombox
      tombox
      @ilovegym sollte jetzt gefixt sein
      ? ? K 3 Antworten Letzte Antwort
      • T tombox
        @tombox
        guten Morgen, danke, hab gestern Abend die letzte Git installiert, laeuft bis jetzt ohne Fehler.
        Funktionen on/off, brightness, color und snapshot funktionieren.
        Getested mit Devices 2x H6104 und Dreamview T1 Pro.
        • T tombox
          @tombox
          Läuft bei mir auch super ;-)
          • T tombox
            kimukao
            @tombox Eine Frage: Solange ich nur ein Govee Licht über Script steuere funktioniert alles (bis auf eine Verzögerung von 1-2 Sekunden) ohne Probleme. Wenn ich aber mehrere Lichter gleichzeitig steuere wird der Befehl zwar an die iobroker Datenpunkte weitergegeben (dort steht dann zB 1 oder 0), das Licht aber nicht zuverlässig geschaltet. Ist das nur bei mir so, oder kann das ein anderer User so bestätigen?
            T ? 2 Antworten Letzte Antwort
            • K kimukao
              tombox
              @kimukao probier mal die github version ob das verhalten dann anders ist.
              hast du dabei die app offen oder beendet?
              • K kimukao
                @kimukao
                Viel mir jetzt noch nicht auf allerdings schalte ich eh meist eine gruppe bzw. über default (tap to run commands ) wo ja alles drin drinnen ist was er machen soll
                  @tombox
                  @tombox
                  Hi Tom,
                  Kriegst du vielleicht noch die Gruppe als DP ?
                  Das wöre noch gut.
                  Dsnke dir
                  Olli
                    @tombox
                    Hi Tom,
                    Das wöre noch gut.
                    Dsnke dir
                    Olli
                    tombox
                    @olli_m ja habe noch groups hinzugefügt
                    • T tombox
                      @tombox
                      perfekt :-)
                      • T tombox
                        kimukao
                        @tombox Super! Jetzt klappt's mit der gleichzeitigen Schaltung mehrerer Lichter. Danke! Die Gruppenfunktion ist auch sehr hilfreich. Hab ich direkt in meine Automationen eingebunden.
                        • OstfrieseUnterwegsO Offline
                          OstfrieseUnterwegs
                          @tombox
                          Läuft soweit ohne Auffälligkeiten.
                          Allerdings... würde es nicht Sinn machen die 3 DP für Farbe r,g,b zu einem DP zusammenzufassen? Dann ließe sich das in den meisten Visualisierungen besser verarbeiten.
                          • OstfrieseUnterwegsO OstfrieseUnterwegs
                            @tombox
                            tombox
                            @ostfrieseunterwegs Was wäre der beste Weg? wo man 122,10,22 eingibt?
                            OstfrieseUnterwegsO E 2 Antworten Letzte Antwort
                            • T tombox
                              OstfrieseUnterwegs
                              @tombox ich würde sagen mit Hex: #f4fdff
                              • T tombox
                                ExMatador
                                @tombox
                                Das Einschalten mittels 1-On und 0-Off ist etwas gewöhnungsbedürftig. Shellys, tuya und andere schalten mit true/false - das ist für Automatisierungsscripte (enums mit aliases) dann etwas leichter im Handling.
                                Aber ansonsten klappt die Integration schon sehr gut.
                                Vielen Dank
                                ExMatador
                                Intel(R) Core(TM) i7 | 32GB | 1TB SSD
                                Virtualization: wsl2 | Ubuntu 22.04 | Docker
                                ESPeasy | ESP8266 | ESP32 | ESP32CAM
                                Zigbee | Coral | Lupus XT2 | Ender 3 S1 Pro
                                Frigate | Influx | Grafana | GPX-Tracking | usw.
                                OstfrieseUnterwegsO 1 Antwort Letzte Antwort
                                • E ExMatador
                                  @tombox
                                  Vielen Dank
                                  ExMatador
                                  OstfrieseUnterwegs
                                  @exmatador Da kommen Alias und read/write Funktionen zum Einsatz:
                                    "type": "state",
                                    "common": {
                                      "name": "Switch",
                                      "role": "switch",
                                      "type": "boolean",
                                      "read": true,
                                      "write": true,
                                      "alias": {
                                        "id": "govee-app.0.AA:BB:CC.remote.turn",
                                        "read": "val==1?true:false",
                                        "write": "val?1:0"
                                      "custom": {
                                        "iot.0": {
                                          "smartName": {
                                            "de": "Todesstern",
                                            "smartType": "LIGHT"
                                    "_id": "alias.0.device.todesstern.switch",
                                    "native": {},
                                    "acl": {
                                      "object": 1636,
                                      "state": 1636,
                                      "owner": "system.user.admin",
                                    "user": "system.user.admin",
                                    "ts": 1673270947902
                                  E 1 Antwort Letzte Antwort
                                  • J Online
                                    J Online
                                    jensven
                                    habe den adapter nun auch installiert, leider bekomme ich folgenden error:
                                    Ein und auschalten funktioniert, bekomme aber alle 5 Minuten diese Meldung
                                    govee-app.0
                                    2023-02-15 16:20:56.501	debug	MQTT message: **************** {"proType":2,"sku":"H6199","device":"**********","softVersion":"1.09.12","wifiSoftVersion":"1.00.29","cmd":"status","type":0,"transaction":"x_1676474455558","pactType":2,"pactCode":1,"state":{"onOff":0,"brightness":70,"color":{"r":0,"g":0,"b":255},"colorTemInKelvin":0,"mode":0,"wifiHardVersion":"1.03.00","bleHardVersion":"3.02.01","result":1},"op":{"command":["qlUAZDIBAAAyAAAAAAAAAAAAAJo=","qgUAAAADAGMAAAAAAAAAAAAAAM8=","qhEAHg8PAAAAAAAAAAAAAAAAAKU=","qhL/ZAAAgAoAAAAAAAAAAAAAAKk=","qiP/AAAAgAAAAIAAAACAAAAAgHY=","qqkABgEQAwEOAwAAAAAAAAAAABs=","qqkCATIAAAAAAAAAAAAAAAAAADI="]}}
                                    govee-app.0
                                    2023-02-15 16:20:55.557	debug	MQTT publish to ********
                                    govee-app.0
                                    2023-02-15 16:19:29.155	debug	MQTT subscribe to ******
                                    govee-app.0
                                    2023-02-15 16:19:29.154	debug	MQTT connected
                                    govee-app.0
                                    2023-02-15 16:19:28.655	debug	MQTT reconnect
                                    govee-app.0
                                    2023-02-15 16:19:27.653	debug	MQTT offline
                                    govee-app.0
                                    2023-02-15 16:19:27.652	error	MQTT ERROR: Error: read ECONNRESET
                                    evtl. Datenschutz bedenkliche Infos wurden durch ***** ersetzt.
                                    • J jensven
                                      govee-app.0
                                      govee-app.0
                                      govee-app.0
                                      govee-app.0
                                      govee-app.0
                                      govee-app.0
                                      govee-app.0
                                      tombox
                                      @jensven Mhh mal beobachten ob es dauerhaft ist oder nur wenn du die app offen hast
                                      • J Online
                                        J Online
                                        jensven
                                        Das ist dauerhaft
                                        govee-app.0 2023-02-16 06:24:13.960	error	MQTT ERROR: Error: read ECONNRESET
                                        govee-app.0 2023-02-16 06:29:14.796	error	MQTT ERROR: Error: read ECONNRESET
                                        govee-app.0 2023-02-16 06:34:42.424	error	MQTT ERROR: Error: read ECONNRESET
                                        govee-app.0 2023-02-16 06:38:58.716	error	MQTT ERROR: Error: read ECONNRESET
                                        govee-app.0 2023-02-16 06:44:29.991	error	MQTT ERROR: Error: read ECONNRESET
                                        Habe jetzt nur die Errors eingestellt.
                                        Wie schon geschrieben alle 5 Minuten kommt der. Und zu dieser Zeit habe ich geschlafen
                                        • J jensven
                                          Das ist dauerhaft
                                          tombox
                                          @jensven Sind die immer alle 5min oder nur ab und zu
