  3. Einsteigerfragen
  4. Homematic Adapter findet Geräte nicht
    5.4k
hm-rpchomematic iphomematic
80 Beiträge 7 Kommentatoren 10.1k Aufrufe 5 Beobachtet
  • CodierknechtC Codierknecht
    @j-h
    Port 2010 in RM freigeben?
    j hJ Offline
    j hJ Offline
    j h
    @codierknecht
    Ich hab den Port jetzt mal noch hier hinzugefügt, aber zuvor war die Einstellung ja auch bereits auf "Ports offen"
    @Homoran
    Hier ein kleiner Auszug aus dem DebugLog nach einem Neustart
    hm-rpc.0
    2023-01-08 13:46:47.734	debug	PING ok
    hm-rpc.0
    2023-01-08 13:46:47.724	debug	Send PING...
    hm-rpc.0
    2023-01-08 13:46:47.723	debug	[KEEPALIVE] Check if connection is alive
    hm-rpc.0
    2023-01-08 13:45:17.721	debug	start ping interval
    hm-rpc.0
    2023-01-08 13:45:17.721	debug	clear connecting interval
    hm-rpc.0
    2023-01-08 13:45:17.720	info	Connected
    hm-rpc.0
    2023-01-08 13:45:17.707	debug	start connecting interval
    hm-rpc.0
    2023-01-08 13:45:17.703	debug	xmlrpc -> 192.168.178.80:2010/ init ["http://http://192.168.178.45/:2010","IoBro:hm-rpc.0:17d68861e7654575c20ac2bc23ea3834"]
    hm-rpc.0
    2023-01-08 13:45:17.703	debug	Connect...
    hm-rpc.0
    2023-01-08 13:45:17.702	info	xmlrpc client is trying to connect to 192.168.178.80:2010/ with ["http://http://192.168.178.45/:2010","IoBro:hm-rpc.0:17d68861e7654575c20ac2bc23ea3834"]
    hm-rpc.0
    2023-01-08 13:45:17.701	info	xmlrpc server is trying to listen on 192.168.178.45:2010
    hm-rpc.0
    2023-01-08 13:45:17.622	info	starting. Version 1.15.16 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v16.19.0, js-controller: 4.0.24
    hm-rpc.0
    2023-01-08 13:45:17.497	debug	Plugin sentry Initialize Plugin (enabled=true)
    hm-rpc.0
    2023-01-08 13:45:17.441	debug	States connected to redis: 0.0.0.0:9000
    hm-rpc.0
    2023-01-08 13:45:17.395	debug	States create User PubSub Client
    hm-rpc.0
    2023-01-08 13:45:17.394	debug	States create System PubSub Client
    hm-rpc.0
    2023-01-08 13:45:17.389	debug	Redis States: Use Redis connection: 0.0.0.0:9000
    hm-rpc.0
    2023-01-08 13:45:17.382	debug	Objects connected to redis: 0.0.0.0:9001
    hm-rpc.0
    2023-01-08 13:45:17.379	debug	Objects client initialize lua scripts
    hm-rpc.0
    2023-01-08 13:45:17.368	debug	Objects create User PubSub Client
    hm-rpc.0
    2023-01-08 13:45:17.368	debug	Objects create System PubSub Client
    hm-rpc.0
    2023-01-08 13:45:17.367	debug	Objects client ready ... initialize now
    hm-rpc.0
    2023-01-08 13:45:17.344	debug	Redis Objects: Use Redis connection: 0.0.0.0:9001
    hm-rpc.0
    2023-01-08 13:45:06.588	info	Terminated (NO_ERROR): Without reason
    hm-rpc.0
    2023-01-08 13:45:06.587	info	terminating
    hm-rpc.0
    2023-01-08 13:45:06.583	info	Disconnected
    hm-rpc.0
    2023-01-08 13:45:06.565	info	xmlrpc -> 192.168.178.80:2010/ init ["http://http://192.168.178.45/:2010",""]
    hm-rpc.0
    2023-01-08 13:44:36.563	error	Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
    hm-rpc.0
    2023-01-08 13:27:06.526	info	Connected
    Ich sehe gerade das dort 2 mal "http" bei der URL drin steht (und ein Slash vor dem Port). Bei der Konfiguration der Homematic Adresse habe ich das aber nicht mit angegeben ?!
    Das dachte ich mir, wollte es aber versuchen.
    • j hJ j h
      @codierknecht
      @Homoran
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      hm-rpc.0
      @j-h sagte in Homematic Adapter findet Geräte nicht:
      ich auch!
      starte mal den iobroker neu (und die ccu)
      • j hJ j h
        @codierknecht
        @Homoran
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        hm-rpc.0
        @j-h sagte in: Bei der Konfiguration der Homematic Adresse habe ich das aber nicht mit angegeben ?!
        Callback-Adresse im Tab "ZUSÄTZLICHE EINSTELLUNGEN"?
        Da sich ioBroker und RM im gleichen Subnetz befinden, kann man die Callback-Adresse leer lassen.
        j hJ 1 Antwort Letzte Antwort
          j hJ Offline
          j hJ Offline
          j h
          Stimmt, die hatte ich noch drin stehen.
          War auch nur ein Test den ich in meiner Verzweiflung mal ausprobiert hatte.
          Hab sie nun wieder gelöscht. Der Log sieht jetzt wie folgt aus:
          hm-rpc.0
          2023-01-08 14:14:20.315	debug	start ping interval
          hm-rpc.0
          2023-01-08 14:14:20.315	debug	clear connecting interval
          hm-rpc.0
          2023-01-08 14:14:20.314	info	Connected
          hm-rpc.0
          2023-01-08 14:14:20.304	debug	start connecting interval
          hm-rpc.0
          2023-01-08 14:14:20.300	debug	xmlrpc -> 192.168.178.80:2010/ init ["http://192.168.178.45:2010","IoBro:hm-rpc.0:dec1e05b2fe448c084e64f17678317e4"]
          hm-rpc.0
          2023-01-08 14:14:20.300	debug	Connect...
          hm-rpc.0
          2023-01-08 14:14:20.299	info	xmlrpc client is trying to connect to 192.168.178.80:2010/ with ["http://192.168.178.45:2010","IoBro:hm-rpc.0:dec1e05b2fe448c084e64f17678317e4"]
          hm-rpc.0
          2023-01-08 14:14:20.299	info	xmlrpc server is trying to listen on 192.168.178.45:2010
          hm-rpc.0
          2023-01-08 14:14:20.222	info	starting. Version 1.15.16 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v16.19.0, js-controller: 4.0.24
          hm-rpc.0
          2023-01-08 14:14:20.105	debug	Plugin sentry Initialize Plugin (enabled=true)
          hm-rpc.0
          2023-01-08 14:14:20.077	debug	States connected to redis: 0.0.0.0:9000
          hm-rpc.0
          2023-01-08 14:14:20.027	debug	States create User PubSub Client
          hm-rpc.0
          2023-01-08 14:14:20.026	debug	States create System PubSub Client
          hm-rpc.0
          2023-01-08 14:14:20.019	debug	Redis States: Use Redis connection: 0.0.0.0:9000
          hm-rpc.0
          2023-01-08 14:14:20.008	debug	Objects connected to redis: 0.0.0.0:9001
          hm-rpc.0
          2023-01-08 14:14:20.005	debug	Objects client initialize lua scripts
          hm-rpc.0
          2023-01-08 14:14:19.992	debug	Objects create User PubSub Client
          hm-rpc.0
          2023-01-08 14:14:19.991	debug	Objects create System PubSub Client
          hm-rpc.0
          2023-01-08 14:14:19.986	debug	Objects client ready ... initialize now
          hm-rpc.0
          2023-01-08 14:14:19.963	debug	Redis Objects: Use Redis connection: 0.0.0.0:9001
          hm-rpc.0
          2023-01-08 14:14:16.091	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          hm-rpc.0
          2023-01-08 14:14:16.091	debug	Plugin sentry destroyed
          hm-rpc.0
          2023-01-08 14:14:16.090	info	terminating
          hm-rpc.0
          2023-01-08 14:14:16.090	info	Disconnected
          hm-rpc.0
          2023-01-08 14:14:16.082	info	xmlrpc -> 192.168.178.80:2010/ init ["http://http://192.168.178.45/:2010",""]
          hm-rpc.0
          2023-01-08 14:14:16.081	info	Got terminate signal TERMINATE_YOURSELF
          hm-rpc.0
          2023-01-08 14:13:17.799	debug	start ping interval
          hm-rpc.0
          2023-01-08 14:13:17.798	debug	clear connecting interval
          hm-rpc.0
          2023-01-08 14:13:17.792	debug	xmlrpc -> 192.168.178.80:2010/ init ["http://http://192.168.178.45/:2010","IoBro:hm-rpc.0:17d68861e7654575c20ac2bc23ea3834"]
          hm-rpc.0
          2023-01-08 14:12:47.792	debug	start connecting interval
          @Homoran
          Neustarts hatte ich schon mehrfach ausgeführt
          • j hJ j h
            hm-rpc.0
            hm-rpc.0
            hm-rpc.0
            hm-rpc.0
            hm-rpc.0
            hm-rpc.0
            hm-rpc.0
            hm-rpc.0
            hm-rpc.0
            hm-rpc.0
            hm-rpc.0
            hm-rpc.0
            hm-rpc.0
            hm-rpc.0
            hm-rpc.0
            hm-rpc.0
            hm-rpc.0
            hm-rpc.0
            hm-rpc.0
            hm-rpc.0
            hm-rpc.0
            hm-rpc.0
            hm-rpc.0
            hm-rpc.0
            hm-rpc.0
            hm-rpc.0
            hm-rpc.0
            hm-rpc.0
            hm-rpc.0
            hm-rpc.0
            @Homoran
            ist jetzt alles da?
            und der Haken bei neu einlesen wieder weg?
              ist jetzt alles da?
              j hJ Offline
              j hJ Offline
              j h
              Nein, weder sind die Geräte in den Objekten, noch ist der Haken in der Config weg gegangen
              • j hJ j h
                @j-h .80 ist die CCU und .45 der ioBroker?
                was mich allerdings irritiert ist
                • j hJ Offline
                  j hJ Offline
                  j h
                  @homoran said in Homematic Adapter findet Geräte nicht:
                  Korrekt
                  "IoBro" ist der Host name. Oder was verwirrt dich dort?
                  • j hJ j h
                    Korrekt
                    ist das dahinter die IPv6 Adresse?
                    wenn ja, wo kommt die her?
                      j hJ Offline
                      j hJ Offline
                      j h
                      Puhhh eigentlich hab ich da nichts eingestellt. Habe lediglich in der fritzbox eine statische ip vergeben (die 45)
                      • j hJ j h
                        @j-h alles gut!
                        hab gerade bei mir getestet, sieht genauso aus.
                          @j-h alles gut!
                          j hJ Offline
                          j hJ Offline
                          j h
                          Mehr oder weniger gut 😅
                          Ich bin ratlos 🙈
                          • j hJ j h
                            Ich bin ratlos 🙈
                            Ich bin ratlos
                            da sind wir ja schon 2!
                            ich würde jetzt einmal die Instanz löschen und neu anlegen.
                            hab keine Ahnung was da faul ist. Außer an der RM wurde wieder etwas geändert.
                              Ich bin ratlos
                              j hJ Offline
                              j hJ Offline
                              j h
                              Auch den Adapter habe ich bereits neu installiert. Die RM VM hatte ich auch bereits mal neu installiert.
                              Evtl könnte ich dabei mal eine ältere Version auswählen
                              • j hJ j h
                                Die RM VM
                                ach VM! Wirklich kein Container?
                                j hJ paul53P 2 Antworten Letzte Antwort
                                  Die RM VM
                                  j hJ Offline
                                  j hJ Offline
                                  j h
                                  Ne, richtige VM.
                                  Ich habe nach der offiziellen Doku für Proxmox installiert.
                                  https://github.com/jens-maus/RaspberryMatic/wiki/Installation-Proxmox-VE
                                  Soll ich mal als Container installieren?
                                    Die RM VM
                                    @homoran sagte: ach VM! Wirklich kein Container?
                                    Entscheidend ist, ob sich RM und ioBroker im gleichen oder in verschiedenen Subnetz(en) befinden.
                                    • j hJ j h
                                      Ne, richtige VM.
                                      bahnuhrB Online
                                      bahnuhrB Online
                                      bahnuhr
                                      Ne, richtige VM.
                                      Ich bin genau nach dieser Anleitung vor gegangen.
                                      Also RM in einer VM unter Proxmox.
                                      Und dies funktioniert einwandfrei.
                                      Ich vermute es liegt an den Einstellungen
                                      RM - hm-rega - hm-rpc
                                      Danke.
                                      • bahnuhrB bahnuhr
                                        Ne, richtige VM.
                                        @bahnuhr sagte: hm-rega
                                        Die Einstellungen von hm-rega haben keinen Einfluss - HM-RPC funktioniert auch ohne HM-Rega-Adapter. Dann allerdings ohne Namen und Aufzählungen aus der RM.
                                          bahnuhrB Online
                                          bahnuhrB Online
                                          bahnuhr
                                          @paul53 sagte in Homematic Adapter findet Geräte nicht:
                                          hm-rega
                                          Er muss es ja nicht so machen.
                                          Aber bei mir läuft es; und zwar ohne https, callback oder sonst was.
                                          Und dies seit Anfang an.
                                          Bei @j-h halt nicht.
                                          Danke.
