  4. Update node.js
    5.5k
Update node.js
23 Beiträge 4 Kommentatoren 872 Aufrufe 2 Beobachtet
  • B blue106
    Keine ahnung wie das geht. Kanns nur so machen. Weiter als das komm ich net
    @blue106
    Dann lies den Hinweis von @Homoran
      @blue106
      blue106
      pi@raspberrypi:~ $ cd /opt/iobroker
      pi@raspberrypi:/opt/iobroker $ npm ls | grep -E 'github|ERR'
      │ │ │ ├── github-from-package@0.0.0
      │ │ │ ├── github-from-package@0.0.0 deduped
      │   ├── github-url-from-git@1.5.0
      │   ├─┬ new-github-release-url@1.0.0
      └─┬ streamedian@1.8.3 (github:SpecForge/html5_rtsp_player#c862c930cd63b2f8629f4350d527d87c5c2688b2)
        └─┬ jsencrypt@2.3.1 (git+https://github.com/kreopt/jsencrypt.git#02c7522a02c1ba5b375c456063296634cbe2a114)
      pi@raspberrypi:/opt/iobroker $ cd /opt/iobroker && npm prune
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      up to date in 17.493s
      110 packages are looking for funding
        run `npm fund` for details
      pi@raspberrypi:/opt/iobroker $ curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash
      ## Installing the NodeSource Node.js 16.x repo...
      ## Populating apt-get cache...
      + apt-get update
      E: Type 'sudo' is not known on line 7 in source list /etc/apt/sources.list
      E: The list of sources could not be read.
      Error executing command, exiting
      pi@raspberrypi:/opt/iobroker $ node -v
      v12.22.8
      pi@raspberrypi:/opt/iobroker $ iob stop
      + apt-get update
      MOD-EDIT: Code-tags angepasst!
      • B blue106
        + apt-get update
        v12.22.8
        + apt-get update
        @blue106
        cat /etc/apt/sources.list
        Da steht offenbar Quark in der sources.list drin.
          @blue106
          blue106
          schrieb am zuletzt editiert von blue106
          pi@raspberrypi:/opt/iobroker $ cat /etc/apt/sources.list
          deb http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free rpi
          Uncomment line below then 'apt-get update' to enable 'apt-get source'
          #deb-src http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free rpi
          deb https://archive.raspbian.org/raspian buster main contrib non-free
          deb-src https://archive.raspbian.org/raspbian buster main contrib non-free
          sudo apt-get update
          das kommt da
          • B blue106
            sudo apt-get update
            das kommt da
            @blue106
            Bitte saubere CodeTags setzen.
            • B blue106
              sudo apt-get update
              das kommt da
              @blue106
              Lösche die letzte Zeile ersatzlos raus.
              Dann
              sudo apt update
                @blue106
                Dann
                sudo apt update
                blue106
                @thomas-braun die zeile macht der ja automtisch. hatte nur den befehl cat... eingegeben
                • B blue106
                  @blue106
                  Nein, die Zeile hast du da mal reinkopiert, die kommt nicht 'von alleine' rein.
                    @blue106
                    blue106
                    Kommt immer wieder der fehler. Lasse es jetzt so. Bringt ja nix. Trotzdem danke
                    • B blue106
                      @blue106
                      Lösch die Zeile halt raus und dann in der Konsole
                      sudo apt update
                      Bei dir funktionieren so gar keine Upgrades des Betriebssystems. DAS bringt nichts.
                      sudo nano /etc/apt/sources.list
                      Letzte Zeile löschen, Strg-O, Enter, Strg-X
                      • B blue106
                        @blue106
                        Und dann bringst du Buster auf ein noch lebendes Release. Der Buster ist im September 2022 abgekündigt worden.
                          @blue106
                          sudo apt update
                          blue106
                          pi@raspberrypi:~ $ sudo apt update
                          Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                          Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                          Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
                          Ign:4 https://archive.raspbian.org/raspian buster InRelease
                          Hit:5 https://archive.raspbian.org/raspbian buster InRelease
                          Err:6 https://archive.raspbian.org/raspian buster Release
                            404  Not Found [IP: 2a00:1098:0:80:1000:75:0:2 443]
                          Reading package lists... Done
                          E: The repository 'https://archive.raspbian.org/raspian buster Release' does not have a Release file.
                          N: Updating from such a repository can't be done securely, and is therefore disabled by default.
                          N: See apt-secure(8) manpage for repository creation and user configuration details.
                          habs endlich gefunden in zeile 7 un habs geändert. aber wirklich akutell wird nix
                          • B blue106
                            @blue106
                            Jetzt hast du in einer anderen .list Datei in /etc/apt/sources.list.d/ noch Quatsch drin.
                            Da steht raspian, muss aber raspbian lauten.
                              @blue106
                              blue106
                              endlich hats geklappt. was ne schwere geburt.....
                              • B blue106
                                @blue106
                                sudo sed -i 's/raspian/raspbian/g' /etc/apt/sources.list
                                sudo sed -i 's/raspian/raspbian/g' /etc/apt/sources.list.d/*
                                Dann nochmal
                                sudo apt update
                                • B blue106
                                  @blue106 sagte in Update node.js:
                                  Warum? Ganz einfache Dinge.
                                  Was kommt jetzt bei
                                  sudo apt update
                                  um's Eck?
