  4. Update node.js
    5.5k
Update node.js
23 Beiträge 4 Kommentatoren 872 Aufrufe 2 Beobachtet
    blue106
    Das hier kommt immer. Hab die anleitung von thomas genommen
    • B blue106
      @blue106
      Keine Screenshots. Kann man nicht lesen, kann man nicht zitieren usw.
      Text aus der Konsole in CodeTags eingebettet hier rein.
        @blue106
        blue106
        Keine ahnung wie das geht. Kanns nur so machen. Weiter als das komm ich net
        • B blue106
          @blue106
          Dann lies den Hinweis von @Homoran
            @blue106
            blue106
            pi@raspberrypi:~ $ cd /opt/iobroker
            pi@raspberrypi:/opt/iobroker $ npm ls | grep -E 'github|ERR'
            │ │ │ ├── github-from-package@0.0.0
            │ │ │ ├── github-from-package@0.0.0 deduped
            │   ├── github-url-from-git@1.5.0
            │   ├─┬ new-github-release-url@1.0.0
            └─┬ streamedian@1.8.3 (github:SpecForge/html5_rtsp_player#c862c930cd63b2f8629f4350d527d87c5c2688b2)
              └─┬ jsencrypt@2.3.1 (git+https://github.com/kreopt/jsencrypt.git#02c7522a02c1ba5b375c456063296634cbe2a114)
            pi@raspberrypi:/opt/iobroker $ cd /opt/iobroker && npm prune
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
            up to date in 17.493s
            110 packages are looking for funding
              run `npm fund` for details
            pi@raspberrypi:/opt/iobroker $ curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash
            ## Installing the NodeSource Node.js 16.x repo...
            ## Populating apt-get cache...
            + apt-get update
            E: Type 'sudo' is not known on line 7 in source list /etc/apt/sources.list
            E: The list of sources could not be read.
            Error executing command, exiting
            pi@raspberrypi:/opt/iobroker $ node -v
            v12.22.8
            pi@raspberrypi:/opt/iobroker $ iob stop
            + apt-get update
            MOD-EDIT: Code-tags angepasst!
            • B blue106
              + apt-get update
              v12.22.8
              + apt-get update
              @blue106
              cat /etc/apt/sources.list
              Da steht offenbar Quark in der sources.list drin.
                @blue106
                blue106
                schrieb am zuletzt editiert von blue106
                pi@raspberrypi:/opt/iobroker $ cat /etc/apt/sources.list
                deb http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free rpi
                Uncomment line below then 'apt-get update' to enable 'apt-get source'
                #deb-src http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free rpi
                deb https://archive.raspbian.org/raspian buster main contrib non-free
                deb-src https://archive.raspbian.org/raspbian buster main contrib non-free
                sudo apt-get update
                das kommt da
                • B blue106
                  sudo apt-get update
                  das kommt da
                  @blue106
                  Bitte saubere CodeTags setzen.
                  • B blue106
                    sudo apt-get update
                    das kommt da
                    @blue106
                    Lösche die letzte Zeile ersatzlos raus.
                    Dann
                    sudo apt update
                      @blue106
                      Dann
                      sudo apt update
                      blue106
                      @thomas-braun die zeile macht der ja automtisch. hatte nur den befehl cat... eingegeben
                      • B blue106
                        @blue106
                        Nein, die Zeile hast du da mal reinkopiert, die kommt nicht 'von alleine' rein.
                          @blue106
                          blue106
                          Kommt immer wieder der fehler. Lasse es jetzt so. Bringt ja nix. Trotzdem danke
                          • B blue106
                            @blue106
                            Lösch die Zeile halt raus und dann in der Konsole
                            sudo apt update
                            Bei dir funktionieren so gar keine Upgrades des Betriebssystems. DAS bringt nichts.
                            sudo nano /etc/apt/sources.list
                            Letzte Zeile löschen, Strg-O, Enter, Strg-X
                            • B blue106
                              @blue106
                              Und dann bringst du Buster auf ein noch lebendes Release. Der Buster ist im September 2022 abgekündigt worden.
                                @blue106
                                sudo apt update
                                blue106
                                pi@raspberrypi:~ $ sudo apt update
                                Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                                Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
                                Ign:4 https://archive.raspbian.org/raspian buster InRelease
                                Hit:5 https://archive.raspbian.org/raspbian buster InRelease
                                Err:6 https://archive.raspbian.org/raspian buster Release
                                  404  Not Found [IP: 2a00:1098:0:80:1000:75:0:2 443]
                                Reading package lists... Done
                                E: The repository 'https://archive.raspbian.org/raspian buster Release' does not have a Release file.
                                N: Updating from such a repository can't be done securely, and is therefore disabled by default.
                                N: See apt-secure(8) manpage for repository creation and user configuration details.
                                habs endlich gefunden in zeile 7 un habs geändert. aber wirklich akutell wird nix
                                • B blue106
                                  @blue106
                                  Jetzt hast du in einer anderen .list Datei in /etc/apt/sources.list.d/ noch Quatsch drin.
                                  Da steht raspian, muss aber raspbian lauten.
                                    @blue106
                                    blue106
                                    endlich hats geklappt. was ne schwere geburt.....
                                    • B blue106
                                      @blue106
                                      sudo sed -i 's/raspian/raspbian/g' /etc/apt/sources.list
                                      sudo sed -i 's/raspian/raspbian/g' /etc/apt/sources.list.d/*
                                      Dann nochmal
                                      sudo apt update
                                      • B blue106
                                        @blue106 sagte in Update node.js:
                                        Warum? Ganz einfache Dinge.
                                        Was kommt jetzt bei
                                        sudo apt update
                                        um's Eck?
