  4. Adapter alle rot nach fehlerhaften Update
    5.5k
18 Beiträge 3 Kommentatoren 1.6k Aufrufe 2 Beobachtet
  • Thomas RüttlerT Thomas Rüttler
    Die Adapter lassen sich nicht starten.
    HomoranH Offline
    HomoranH Offline
    @thomas-rüttler sagte in Adapter alle rot nach fehlerhaften Update:
    bitte keine Screenshots, text in code-tags posten!
    ich kann da nix zitieren
    Thomas RüttlerT 1 Antwort Letzte Antwort
      Thomas RüttlerT Offline
      Thomas Rüttler
      host.iobroker
      2023-01-05 09:46:50.007	error	iobroker npm-install: host.iobroker Cannot install iobroker.web@4.3.0: 217
      host.iobroker
      2023-01-05 09:46:43.862	info	iobroker npm-install: Installing iobroker.web@4.3.0... (System call)
      host.iobroker
      2023-01-05 09:46:43.859	info	iobroker npm-install: NPM version: 8.19.3
      host.iobroker
      2023-01-05 09:46:39.886	info	iobroker install web@4.3.0 using installedFrom
      host.iobroker
      2023-01-05 09:46:39.885	warn	startInstance cannot find adapter "web@4.3.0". Try to install it... 2 attempt
      host.iobroker
      2023-01-05 09:46:38.884	info	iobroker npm-install: exit 25
      host.iobroker
      2023-01-05 09:46:37.840	error	iobroker npm-install: host.iobroker Cannot install iobroker.shuttercontrol@1.4.18: 217
      host.iobroker
      2023-01-05 09:46:32.878	info	iobroker npm-install: Installing iobroker.shuttercontrol@1.4.18... (System call)
      host.iobroker
      2023-01-05 09:46:32.875	info	iobroker npm-install: NPM version: 8.19.3
      host.iobroker
      2023-01-05 09:46:28.928	info	iobroker install shuttercontrol@1.4.18 using installedFrom
      host.iobroker
      2023-01-05 09:46:28.928	warn	startInstance cannot find adapter "shuttercontrol@1.4.18". Try to install it... 2 attempt
      host.iobroker
      2023-01-05 09:46:27.927	info	iobroker npm-install: exit 25
      host.iobroker
      2023-01-05 09:46:26.879	error	iobroker npm-install: host.iobroker Cannot install iobroker.sql@2.2.0: 217
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        HomoranH Offline
        HomoranH Offline
        Vermutlich passt das hier?
        https://forum.iobroker.net/topic/57337/fehler-25-oder-217-bei-adapter-install-update-mit-npm8
          Hallo Thomas.
          Hier der Diag Report.
          Skript v.2022-12-31
          *** BASE SYSTEM ***
          Model           : Raspberry Pi 4 Model B Rev 1.4
          Architecture:   armv7l
          Docker:         false
          Virtualization: none
          Distributor ID: Raspbian
          Description:    Raspbian GNU/Linux 10 (buster)
          Release:        10
          Codename:       buster
          PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
          NAME="Raspbian GNU/Linux"
          VERSION_ID="10"
          VERSION="10 (buster)"
          VERSION_CODENAME=buster
          ID=raspbian
          ID_LIKE=debian
          HOME_URL="http://www.raspbian.org/"
          SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
          BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
          Systemuptime and Load:
           09:30:28 up 11:43,  2 users,  load average: 1.95, 1.00, 0.53
          CPU threads: 4
          *** Time and Time Zones ***
          Thu Jan  5 08:30:28 UTC 2023
          Thu Jan  5 09:30:28 CET 2023
          CET +0100
          Europe/Berlin
          *** User and Groups ***
          root
          /root
          root
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:
          *** MEMORY ***
          Mem:           7.9G        747M        5.2G        8.0M        1.9G        7.0G
          Swap:           99M          0B         99M
          Total:         8.0G        747M        5.3G
                   7898 M total memory
                    747 M used memory
                    650 M active memory
                   1818 M inactive memory
                   5237 M free memory
                    168 M buffer memory
                   1744 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          *** FILESYSTEM ***
          Filesystem                               Type      Size  Used Avail Use% Mounted on
          /dev/root                                ext4       15G  6.5G  7.4G  47% /
          devtmpfs                                 devtmpfs  3.7G     0  3.7G   0% /dev
          tmpfs                                    tmpfs     3.9G     0  3.9G   0% /dev/shm
          tmpfs                                    tmpfs     3.9G  8.5M  3.9G   1% /run
          tmpfs                                    tmpfs     5.0M  4.0K  5.0M   1% /run/lock
          tmpfs                                    tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
          /dev/mmcblk0p1                           vfat      253M   49M  204M  20% /boot
          //192.168.178.20/Public/Backup/iobroker/ cifs      3.7T  2.7T  984G  74% /opt/iobroker/backups
          tmpfs                                    tmpfs     790M     0  790M   0% /run/user/1000
          TARGET                  SOURCE                                   FSTYPE OPTIONS
          /                       /dev/mmcblk0p2                           ext4   rw,noatime
          |-/sys/fs/bpf           none                                     bpf    rw,nosuid,nodev,noexec,relatime,mode=700
          |-/boot                 /dev/mmcblk0p1                           vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          `-/opt/iobroker/backups //192.168.178.20/Public/Backup/iobroker/ cifs   rw,relatime,vers=3.0,cache=strict,username=ruettler,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.178.20,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1
          /var:
          1.8G    /var/
          1.2G    /var/cache/apt
          1.2G    /var/cache
          1.1G    /var/cache/apt/archives
          529M    /var/lib
          /opt/iobroker/backups:
          9.4G    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          660M    /opt/iobroker/iobroker-data/
          315M    /opt/iobroker/iobroker-data/files
          172M    /opt/iobroker/iobroker-data/history
          126M    /opt/iobroker/iobroker-data/backup-objects
          78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
          33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
          23M     /opt/iobroker/iobroker-data/objects.jsonl
          11M     /opt/iobroker/iobroker-data/objects.json.migrated
          11M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
          8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v16.19.0
          /usr/bin/node           v16.19.0
          /usr/bin/npm            8.19.3
          nodejs:
            Installed: 16.19.0-deb-1nodesource1
            Candidate: 16.19.0-deb-1nodesource1
            Version table:
           *** 16.19.0-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
               10.24.0~dfsg-1~deb10u2 500
          Temp directories causing npm8 problem: 1
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  4.0.23
          admin:          6.3.5
          javascript:     6.1.4
          Adapters from github:   1
          Adapter State
            system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
            system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
            system.adapter.cloud.0                  : cloud                 : iobroker                                 - disabled
            system.adapter.coronavirus-statistics.0 : coronavirus-statistics: iobroker                                 -  enabled
            system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
            system.adapter.devices.0                : devices               : iobroker                                 - disabled
          + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
            system.adapter.email.0                  : email                 : iobroker                                 -  enabled
            system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
            system.adapter.fhem.0                   : fhem                  : iobroker                                 -  enabled, port: 7072
            system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
            system.adapter.gree_aircon.0            : gree_aircon           : iobroker                                 - disabled
          + system.adapter.history.0                : history               : iobroker                                 -  enabled
            system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
            system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
            system.adapter.info.0                   : info                  : iobroker                                 -  enabled
          + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
            system.adapter.lg-ess-home.0            : lg-ess-home           : iobroker                                 -  enabled
            system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
            system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
            system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
            system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
            system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 - disabled
            system.adapter.sql.0                    : sql                   : iobroker                                 - disabled, port: 0
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
            system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
            system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
            system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
            system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
            system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
            system.adapter.web.0                    : web                   : iobroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
            system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
            system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : iobroker                                 -  enabled
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "alias-manager": 1.2.4    , installed 1.2.4
          Adapter    "backitup"     : 2.5.9    , installed 2.5.9
          Adapter    "devices"      : 1.1.2    , installed 1.1.2
          Adapter    "flot"         : 1.11.0   , installed 1.11.0
          Adapter    "history"      : 2.2.4    , installed 2.2.4
          Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
          Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
          Adapter    "iot"          : 1.11.9   , installed 1.11.9
          Adapter    "javascript"   : 6.1.4    , installed 6.1.4
          Controller "js-controller": 4.0.24   , installed 4.0.23 [Updatable]
          Objects and States
          Objects:        8336
          States:         7247
          Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
          Hit:2 http://archive.raspberrypi.org/debian buster InRelease
          Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16081      683/sshd
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       40062      7525/iobroker.js-co
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       39783      7525/iobroker.js-co
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       40151      7553/io.admin.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          16083      683/sshd
          tcp6       0      0 :::3306                 :::*                    LISTEN      109        14254      844/mysqld
          udp        0      0 0.0.0.0:54763           0.0.0.0:*                           108        14728      401/avahi-daemon: r
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16899      605/dhcpcd
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14726      401/avahi-daemon: r
          udp6       0      0 :::35739                :::*                                108        14729      401/avahi-daemon: r
          udp6       0      0 :::546                  :::*                                0          14884      605/dhcpcd
          udp6       0      0 :::5353                 :::*                                108        14727      401/avahi-daemon: r
          2023-01-05 09:19:36.696  - info: host.iobroker iobroker install sql@2.2.0 using installedVersion
          2023-01-05 09:19:40.855  - info: host.iobroker iobroker npm-install: NPM version: 8.19.3
          2023-01-05 09:19:40.857  - info: host.iobroker iobroker npm-install: Installing iobroker.sql@2.2.0... (System call)
          2023-01-05 09:19:50.460  - error: host.iobroker iobroker npm-install: host.iobroker Cannot install iobroker.sql@2.2.0: 217
          2023-01-05 09:19:51.489  - info: host.iobroker iobroker npm-install: exit 25
          2023-01-05 09:19:52.490  - warn: host.iobroker startInstance cannot find adapter "shuttercontrol@1.4.18". Try to install it... 3 attempt
          2023-01-05 09:19:52.490  - info: host.iobroker iobroker install shuttercontrol@1.4.18 using installedVersion
          2023-01-05 09:19:56.974  - info: host.iobroker iobroker npm-install: NPM version: 8.19.3
          2023-01-05 09:19:56.979  - info: host.iobroker iobroker npm-install: Installing iobroker.shuttercontrol@1.4.18... (System call)
          2023-01-05 09:20:03.452  - error: host.iobroker iobroker npm-install: host.iobroker Cannot install iobroker.shuttercontrol@1.4.18: 217
          2023-01-05 09:20:04.726  - info: host.iobroker iobroker npm-install: exit 25
          2023-01-05 09:20:05.728  - warn: host.iobroker startInstance cannot find adapter "sql@2.2.0". Try to install it... 4 attempt
          2023-01-05 09:20:05.729  - info: host.iobroker iobroker install sql@2.2.0 using installedVersion
          2023-01-05 09:20:13.112  - info: host.iobroker iobroker npm-install: NPM version: 8.19.3
          2023-01-05 09:20:13.114  - info: host.iobroker iobroker npm-install: Installing iobroker.sql@2.2.0... (System call)
          2023-01-05 09:20:23.631  - error: host.iobroker iobroker npm-install: host.iobroker Cannot install iobroker.sql@2.2.0: 217
          2023-01-05 09:20:24.673  - info: host.iobroker iobroker npm-install: exit 25
          2023-01-05 09:20:25.675  - warn: host.iobroker startInstance cannot find adapter "shuttercontrol@1.4.18". Try to install it... 4 attempt
          2023-01-05 09:20:25.675  - info: host.iobroker iobroker install shuttercontrol@1.4.18 using installedVersion
          2023-01-05 09:20:31.879  - info: host.iobroker iobroker npm-install: NPM version: 8.19.3
          2023-01-05 09:20:31.882  - info: host.iobroker iobroker npm-install: Installing iobroker.shuttercontrol@1.4.18... (System call)
          2023-01-05 09:20:39.341  - error: host.iobroker iobroker npm-install: host.iobroker Cannot install iobroker.shuttercontrol@1.4.18: 217
          2023-01-05 09:20:40.387  - info: host.iobroker iobroker npm-install: exit 25
          2023-01-05 09:20:41.388  - error: host.iobroker Cannot download and install adapter "sql@2.2.0". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
          2023-01-05 09:20:41.889  - error: host.iobroker Cannot download and install adapter "shuttercontrol@1.4.18". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
          @thomas-rüttler
          Das kommt halt davon, wenn man da als root durch ein veraltetes System hampelt...
          Bullseye installieren, kein root login!
          iobroker fix
            @thomas-rüttler
            iobroker fix
            Thomas Rüttler
            Wenn das mein Problem löst und ich mit dem Backup wieder zu meiner laufenden Instanz zurück komme wäre das für mich auch eine Option.
              @thomas-rüttler
              Auf einer abgekündigten Distribution als root herumzukaspern ist keine Option.
              Das wirst du so oder so ändern müssen.
                Thomas Rüttler
                Leider hat das nicht geholfen.
                javascript.0
                2023-01-05 09:53:23.986	error	Exception-Code: MODULE_NOT_FOUND: Cannot find module './consts'Require stack:- /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js- /opt/iobroker/node_modules/iobroker.javascript/main.js
                javascript.0
                2023-01-05 09:53:23.985	error	Error: Cannot find module './consts'Require stack:- /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js- /opt/iobroker/node_modules/iobroker.javascript/main.js at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15) at Function.Module._load (node:internal/modules/cjs/loader:841:27) at Module.require (node:internal/modules/cjs/loader:1067:19) at require (node:internal/modules/cjs/helpers:103:18) at sandBox (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:40:22) at execute (/opt/iobroker/node_modules/iobroker.javascript/main.js:1723:21) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1961:13) at /opt/iobroker/node_modules/iobroker.javascript/main.js:2053:17 at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:1527:17) at processImmediate (node:internal/timers:468:21)
                javascript.0
                2023-01-05 09:53:23.985	error	uncaught exception: Cannot find module './consts'Require stack:- /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js- /opt/iobroker/node_modules/iobroker.javascript/main.js
                javascript.0
                2023-01-05 09:53:23.979	error	Exception-Code: MODULE_NOT_FOUND: Cannot find module './consts'Require stack:- /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js- /opt/iobroker/node_modules/iobroker.javascript/main.js
                  @thomas-rüttler
                  Thomas Rüttler
                  Stimmt.
                  Aber das könnte ich dann planen. Komme ich denn denn über den Weg und dem Backup zurück zu meiner Instanz ?
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    HomoranH Offline
                    HomoranH Offline
                    was hat nicht geholfen?
                    ich sehe keine Konsolenausgabe.
                      javascript.0
                      javascript.0
                      javascript.0
                      javascript.0
                      @thomas-rüttler
                      Bist du jetzt wieder als Standard-User unterwegs?
                      Dann:
                      iobroker stop
                      iobroker fix
                      cd /opt/iobroker
                      sudo -H -u iobroker npm install iobroker.js-controller
                      iobroker start
                        @thomas-rüttler
                        Dann:
                        iobroker stop
                        iobroker fix
                        cd /opt/iobroker
                        iobroker start
                        Thomas Rüttler
                        Hallo Thomas. Vielen Dank.
                        Das hat geholfen.
                          Das hat geholfen.
                          @thomas-rüttler
                          Dann mach es dir nicht gleich wieder per root kaputt.
