  4. Adapter alle rot nach fehlerhaften Update
    5.5k
18 Beiträge 3 Kommentatoren 1.6k Aufrufe 2 Beobachtet
  • Thomas RüttlerT Thomas Rüttler
    host.iobroker
    2023-01-05 09:46:50.007	error	iobroker npm-install: host.iobroker Cannot install iobroker.web@4.3.0: 217
    host.iobroker
    2023-01-05 09:46:43.862	info	iobroker npm-install: Installing iobroker.web@4.3.0... (System call)
    host.iobroker
    2023-01-05 09:46:43.859	info	iobroker npm-install: NPM version: 8.19.3
    host.iobroker
    2023-01-05 09:46:39.886	info	iobroker install web@4.3.0 using installedFrom
    host.iobroker
    2023-01-05 09:46:39.885	warn	startInstance cannot find adapter "web@4.3.0". Try to install it... 2 attempt
    host.iobroker
    2023-01-05 09:46:38.884	info	iobroker npm-install: exit 25
    host.iobroker
    2023-01-05 09:46:37.840	error	iobroker npm-install: host.iobroker Cannot install iobroker.shuttercontrol@1.4.18: 217
    host.iobroker
    2023-01-05 09:46:32.878	info	iobroker npm-install: Installing iobroker.shuttercontrol@1.4.18... (System call)
    host.iobroker
    2023-01-05 09:46:32.875	info	iobroker npm-install: NPM version: 8.19.3
    host.iobroker
    2023-01-05 09:46:28.928	info	iobroker install shuttercontrol@1.4.18 using installedFrom
    host.iobroker
    2023-01-05 09:46:28.928	warn	startInstance cannot find adapter "shuttercontrol@1.4.18". Try to install it... 2 attempt
    host.iobroker
    2023-01-05 09:46:27.927	info	iobroker npm-install: exit 25
    host.iobroker
    2023-01-05 09:46:26.879	error	iobroker npm-install: host.iobroker Cannot install iobroker.sql@2.2.0: 217
    HomoranH Offline
    HomoranH Offline
    @thomas-rüttler sagte in Adapter alle rot nach fehlerhaften Update:
    Vermutlich passt das hier?
    https://forum.iobroker.net/topic/57337/fehler-25-oder-217-bei-adapter-install-update-mit-npm8
    Thomas RüttlerT 1 Antwort Letzte Antwort
      Hallo Thomas.
      Hier der Diag Report.
      Skript v.2022-12-31
      *** BASE SYSTEM ***
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Architecture:   armv7l
      Docker:         false
      Virtualization: none
      Distributor ID: Raspbian
      Description:    Raspbian GNU/Linux 10 (buster)
      Release:        10
      Codename:       buster
      PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
      NAME="Raspbian GNU/Linux"
      VERSION_ID="10"
      VERSION="10 (buster)"
      VERSION_CODENAME=buster
      ID=raspbian
      ID_LIKE=debian
      HOME_URL="http://www.raspbian.org/"
      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
      Systemuptime and Load:
       09:30:28 up 11:43,  2 users,  load average: 1.95, 1.00, 0.53
      CPU threads: 4
      *** Time and Time Zones ***
      Thu Jan  5 08:30:28 UTC 2023
      Thu Jan  5 09:30:28 CET 2023
      CET +0100
      Europe/Berlin
      *** User and Groups ***
      root
      /root
      root
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:           7.9G        747M        5.2G        8.0M        1.9G        7.0G
      Swap:           99M          0B         99M
      Total:         8.0G        747M        5.3G
               7898 M total memory
                747 M used memory
                650 M active memory
               1818 M inactive memory
               5237 M free memory
                168 M buffer memory
               1744 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      *** FILESYSTEM ***
      Filesystem                               Type      Size  Used Avail Use% Mounted on
      /dev/root                                ext4       15G  6.5G  7.4G  47% /
      devtmpfs                                 devtmpfs  3.7G     0  3.7G   0% /dev
      tmpfs                                    tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs                                    tmpfs     3.9G  8.5M  3.9G   1% /run
      tmpfs                                    tmpfs     5.0M  4.0K  5.0M   1% /run/lock
      tmpfs                                    tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
      /dev/mmcblk0p1                           vfat      253M   49M  204M  20% /boot
      //192.168.178.20/Public/Backup/iobroker/ cifs      3.7T  2.7T  984G  74% /opt/iobroker/backups
      tmpfs                                    tmpfs     790M     0  790M   0% /run/user/1000
      TARGET                  SOURCE                                   FSTYPE OPTIONS
      /                       /dev/mmcblk0p2                           ext4   rw,noatime
      |-/sys/fs/bpf           none                                     bpf    rw,nosuid,nodev,noexec,relatime,mode=700
      |-/boot                 /dev/mmcblk0p1                           vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      `-/opt/iobroker/backups //192.168.178.20/Public/Backup/iobroker/ cifs   rw,relatime,vers=3.0,cache=strict,username=ruettler,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.178.20,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1
      /var:
      1.8G    /var/
      1.2G    /var/cache/apt
      1.2G    /var/cache
      1.1G    /var/cache/apt/archives
      529M    /var/lib
      /opt/iobroker/backups:
      9.4G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      660M    /opt/iobroker/iobroker-data/
      315M    /opt/iobroker/iobroker-data/files
      172M    /opt/iobroker/iobroker-data/history
      126M    /opt/iobroker/iobroker-data/backup-objects
      78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
      33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
      23M     /opt/iobroker/iobroker-data/objects.jsonl
      11M     /opt/iobroker/iobroker-data/objects.json.migrated
      11M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
      8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v16.19.0
      /usr/bin/node           v16.19.0
      /usr/bin/npm            8.19.3
      nodejs:
        Installed: 16.19.0-deb-1nodesource1
        Candidate: 16.19.0-deb-1nodesource1
        Version table:
       *** 16.19.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
           10.24.0~dfsg-1~deb10u2 500
      Temp directories causing npm8 problem: 1
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  4.0.23
      admin:          6.3.5
      javascript:     6.1.4
      Adapters from github:   1
      Adapter State
        system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
        system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        system.adapter.cloud.0                  : cloud                 : iobroker                                 - disabled
        system.adapter.coronavirus-statistics.0 : coronavirus-statistics: iobroker                                 -  enabled
        system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
        system.adapter.devices.0                : devices               : iobroker                                 - disabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
        system.adapter.email.0                  : email                 : iobroker                                 -  enabled
        system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
        system.adapter.fhem.0                   : fhem                  : iobroker                                 -  enabled, port: 7072
        system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
        system.adapter.gree_aircon.0            : gree_aircon           : iobroker                                 - disabled
      + system.adapter.history.0                : history               : iobroker                                 -  enabled
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
        system.adapter.info.0                   : info                  : iobroker                                 -  enabled
      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        system.adapter.lg-ess-home.0            : lg-ess-home           : iobroker                                 -  enabled
        system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
        system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
        system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
        system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 - disabled
        system.adapter.sql.0                    : sql                   : iobroker                                 - disabled, port: 0
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
        system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
        system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
        system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
        system.adapter.web.0                    : web                   : iobroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
        system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : iobroker                                 -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "alias-manager": 1.2.4    , installed 1.2.4
      Adapter    "backitup"     : 2.5.9    , installed 2.5.9
      Adapter    "devices"      : 1.1.2    , installed 1.1.2
      Adapter    "flot"         : 1.11.0   , installed 1.11.0
      Adapter    "history"      : 2.2.4    , installed 2.2.4
      Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
      Adapter    "iot"          : 1.11.9   , installed 1.11.9
      Adapter    "javascript"   : 6.1.4    , installed 6.1.4
      Controller "js-controller": 4.0.24   , installed 4.0.23 [Updatable]
      Objects and States
      Objects:        8336
      States:         7247
      Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Hit:2 http://archive.raspberrypi.org/debian buster InRelease
      Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16081      683/sshd
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       40062      7525/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       39783      7525/iobroker.js-co
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       40151      7553/io.admin.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          16083      683/sshd
      tcp6       0      0 :::3306                 :::*                    LISTEN      109        14254      844/mysqld
      udp        0      0 0.0.0.0:54763           0.0.0.0:*                           108        14728      401/avahi-daemon: r
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16899      605/dhcpcd
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14726      401/avahi-daemon: r
      udp6       0      0 :::35739                :::*                                108        14729      401/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          14884      605/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        14727      401/avahi-daemon: r
      2023-01-05 09:19:36.696  - info: host.iobroker iobroker install sql@2.2.0 using installedVersion
      2023-01-05 09:19:40.855  - info: host.iobroker iobroker npm-install: NPM version: 8.19.3
      2023-01-05 09:19:40.857  - info: host.iobroker iobroker npm-install: Installing iobroker.sql@2.2.0... (System call)
      2023-01-05 09:19:50.460  - error: host.iobroker iobroker npm-install: host.iobroker Cannot install iobroker.sql@2.2.0: 217
      2023-01-05 09:19:51.489  - info: host.iobroker iobroker npm-install: exit 25
      2023-01-05 09:19:52.490  - warn: host.iobroker startInstance cannot find adapter "shuttercontrol@1.4.18". Try to install it... 3 attempt
      2023-01-05 09:19:52.490  - info: host.iobroker iobroker install shuttercontrol@1.4.18 using installedVersion
      2023-01-05 09:19:56.974  - info: host.iobroker iobroker npm-install: NPM version: 8.19.3
      2023-01-05 09:19:56.979  - info: host.iobroker iobroker npm-install: Installing iobroker.shuttercontrol@1.4.18... (System call)
      2023-01-05 09:20:03.452  - error: host.iobroker iobroker npm-install: host.iobroker Cannot install iobroker.shuttercontrol@1.4.18: 217
      2023-01-05 09:20:04.726  - info: host.iobroker iobroker npm-install: exit 25
      2023-01-05 09:20:05.728  - warn: host.iobroker startInstance cannot find adapter "sql@2.2.0". Try to install it... 4 attempt
      2023-01-05 09:20:05.729  - info: host.iobroker iobroker install sql@2.2.0 using installedVersion
      2023-01-05 09:20:13.112  - info: host.iobroker iobroker npm-install: NPM version: 8.19.3
      2023-01-05 09:20:13.114  - info: host.iobroker iobroker npm-install: Installing iobroker.sql@2.2.0... (System call)
      2023-01-05 09:20:23.631  - error: host.iobroker iobroker npm-install: host.iobroker Cannot install iobroker.sql@2.2.0: 217
      2023-01-05 09:20:24.673  - info: host.iobroker iobroker npm-install: exit 25
      2023-01-05 09:20:25.675  - warn: host.iobroker startInstance cannot find adapter "shuttercontrol@1.4.18". Try to install it... 4 attempt
      2023-01-05 09:20:25.675  - info: host.iobroker iobroker install shuttercontrol@1.4.18 using installedVersion
      2023-01-05 09:20:31.879  - info: host.iobroker iobroker npm-install: NPM version: 8.19.3
      2023-01-05 09:20:31.882  - info: host.iobroker iobroker npm-install: Installing iobroker.shuttercontrol@1.4.18... (System call)
      2023-01-05 09:20:39.341  - error: host.iobroker iobroker npm-install: host.iobroker Cannot install iobroker.shuttercontrol@1.4.18: 217
      2023-01-05 09:20:40.387  - info: host.iobroker iobroker npm-install: exit 25
      2023-01-05 09:20:41.388  - error: host.iobroker Cannot download and install adapter "sql@2.2.0". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
      2023-01-05 09:20:41.889  - error: host.iobroker Cannot download and install adapter "shuttercontrol@1.4.18". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
      @thomas-rüttler
      Das kommt halt davon, wenn man da als root durch ein veraltetes System hampelt...
      Bullseye installieren, kein root login!
      iobroker fix
        @thomas-rüttler
        iobroker fix
        Thomas RüttlerT Offline
        Thomas Rüttler
        Wenn das mein Problem löst und ich mit dem Backup wieder zu meiner laufenden Instanz zurück komme wäre das für mich auch eine Option.
          @thomas-rüttler
          Auf einer abgekündigten Distribution als root herumzukaspern ist keine Option.
          Das wirst du so oder so ändern müssen.
            Thomas Rüttler
            Leider hat das nicht geholfen.
            javascript.0
            2023-01-05 09:53:23.986	error	Exception-Code: MODULE_NOT_FOUND: Cannot find module './consts'Require stack:- /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js- /opt/iobroker/node_modules/iobroker.javascript/main.js
            javascript.0
            2023-01-05 09:53:23.985	error	Error: Cannot find module './consts'Require stack:- /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js- /opt/iobroker/node_modules/iobroker.javascript/main.js at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15) at Function.Module._load (node:internal/modules/cjs/loader:841:27) at Module.require (node:internal/modules/cjs/loader:1067:19) at require (node:internal/modules/cjs/helpers:103:18) at sandBox (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:40:22) at execute (/opt/iobroker/node_modules/iobroker.javascript/main.js:1723:21) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1961:13) at /opt/iobroker/node_modules/iobroker.javascript/main.js:2053:17 at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:1527:17) at processImmediate (node:internal/timers:468:21)
            javascript.0
            2023-01-05 09:53:23.985	error	uncaught exception: Cannot find module './consts'Require stack:- /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js- /opt/iobroker/node_modules/iobroker.javascript/main.js
            javascript.0
            2023-01-05 09:53:23.979	error	Exception-Code: MODULE_NOT_FOUND: Cannot find module './consts'Require stack:- /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js- /opt/iobroker/node_modules/iobroker.javascript/main.js
              @thomas-rüttler
              Thomas Rüttler
              Stimmt.
              Aber das könnte ich dann planen. Komme ich denn denn über den Weg und dem Backup zurück zu meiner Instanz ?
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                HomoranH Offline
                HomoranH Offline
                was hat nicht geholfen?
                ich sehe keine Konsolenausgabe.
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  @thomas-rüttler
                  Bist du jetzt wieder als Standard-User unterwegs?
                  Dann:
                  iobroker stop
                  iobroker fix
                  cd /opt/iobroker
                  sudo -H -u iobroker npm install iobroker.js-controller
                  iobroker start
                    @thomas-rüttler
                    Dann:
                    iobroker stop
                    iobroker fix
                    cd /opt/iobroker
                    iobroker start
                    Thomas Rüttler
                    Hallo Thomas. Vielen Dank.
                    Das hat geholfen.
                      Das hat geholfen.
                      @thomas-rüttler
                      Dann mach es dir nicht gleich wieder per root kaputt.
