    6.3k
4.8k Beiträge 4 Kommentatoren 2.9m Aufrufe 4 Beobachtet
  • Damrak2022D Damrak2022
    @mickym Erledigt
    mickymM Offline
    mickymM Offline
    mickym
    #2898
    @damrak2022 Na dann solltest Du es ja nun testen können.
    • mickymM mickym
      @mickym Habe ich
      So hier nun 4 Nodes zum Importieren:
             "id": "0bdac8e0b723321f",
             "type": "ui_text",
             "z": "289f539dcc33814e",
             "group": "57f13d6f733e5c9d",
             "order": 5,
             "width": "2",
             "height": "1",
             "name": "Status überwachte Geräte",
             "label": "",
             "format": "<font color=\"{{msg.color}}\"><i class=\"fa fa-{{msg.icon}} fa-2x\"></i></font>",
             "layout": "row-spread",
             "className": "",
             "x": 4810,
             "y": 3580,
             "wires": []
             "id": "74613a1c6b1796d5",
             "type": "change",
             "name": "Warnung",
             "rules": [
                     "t": "set",
                     "p": "icon",
                     "pt": "msg",
                     "to": "warning",
                     "tot": "str"
                     "t": "set",
                     "p": "color",
                     "pt": "msg",
                     "to": "yellow",
                     "tot": "str"
                     "t": "set",
                     "p": "className",
                     "pt": "msg",
                     "to": "blink",
                     "tot": "str"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 4600,
             "y": 3620,
             "wires": [
                     "0bdac8e0b723321f"
             "id": "78418a884e260024",
             "type": "change",
             "name": "Alles OK",
             "rules": [
                     "t": "set",
                     "p": "icon",
                     "pt": "msg",
                     "to": "check-circle",
                     "tot": "str"
                     "t": "set",
                     "p": "color",
                     "pt": "msg",
                     "to": "green",
                     "tot": "str"
                     "t": "set",
                     "p": "className",
                     "pt": "msg",
                     "to": "",
                     "tot": "str"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 4600,
             "y": 3580,
             "wires": [
                     "0bdac8e0b723321f"
             "id": "f299d7aacac950dd",
             "type": "ui_text",
             "order": 7,
             "width": "2",
             "height": "1",
             "name": "Status ready to go?",
             "label": "",
             "className": "",
             "x": 4790,
             "y": 3740,
             "wires": []
             "id": "f3224b0e423b4e97",
             "type": "change",
             "name": "Ready",
             "rules": [
                     "t": "set",
                     "p": "icon",
                     "pt": "msg",
                     "to": "thumbs-up",
                     "tot": "str"
                     "t": "set",
                     "p": "color",
                     "pt": "msg",
                     "to": "green",
                     "tot": "str"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 4610,
             "y": 3740,
             "wires": [
                     "f299d7aacac950dd"
             "id": "c965c4c4045df923",
             "type": "change",
             "name": "Not Ready",
             "rules": [
                     "t": "set",
                     "p": "icon",
                     "pt": "msg",
                     "to": "thumbs-o-down",
                     "tot": "str"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 4590,
             "y": 3700,
             "wires": [
                     "f299d7aacac950dd"
             "id": "57f13d6f733e5c9d",
             "type": "ui_group",
             "name": "Test",
             "tab": "20b3095113f94d70",
             "order": 2,
             "disp": true,
             "width": "6",
             "collapse": false,
             "className": ""
             "id": "20b3095113f94d70",
             "type": "ui_tab",
             "name": "Home",
             "icon": "dashboard",
             "order": 1,
             "disabled": false,
             "hidden": false
      Die oberen Nodes gibst Du für die Überwachung an für Geräte die immer eingeschaltet sein sollen, die unteren, die ausgeschaltet werden sollten, wenn Du die Wohnung verlässt.
      Damrak2022D Offline
      Damrak2022D Offline
      Damrak2022
      #2899
      @mickym Das sieht gerade merkwürdig aus
      Mit besten Grüßen
      Andy
        mickymM Offline
        mickymM Offline
        mickym
        #2900
        @damrak2022 Hast Du denn alles richtig verkabelt?
        • mickymM mickym
          Damrak2022D Offline
          Damrak2022D Offline
          Damrak2022
          #2901
          @mickym Denke schon, habe die Kabel gerade auch mal getauscht - sieht aber genauso aus.flows.json
          Mit besten Grüßen
          Andy
            mickymM Offline
            mickymM Offline
            mickym
            #2902
            @damrak2022 Du kannst doch nicht alles durcheinander mischen. Du musst das doch getrennt halten. Du brauchst doch switch Nodes für jede Gruppe. - Ich dachte soweit solltest Du den Flow verstehen. Und natürlich verkehrt zugeordnet. Oben ist bei Dir doch wenn alles bereits zum Weggehen ist - also ist Ready am False Ausgang. Du musst schon bissi überlegen, was wir nun die letzten beiden Tage gemacht haben.
            So sieht es dann fertig aus mit Animation:
            • mickymM mickym
              Damrak2022D Offline
              Damrak2022D Offline
              Damrak2022
              #2903
              @mickym Sorry, ich versuche das nun gerade zu rücken
              Mit besten Grüßen
              Andy
                mickymM Offline
                mickymM Offline
                mickym
                #2904
                Also scheint mir, dass Du nicht ganz verstanden hast, was wir gemacht haben. Jedenfalls sollte nun eine Warnung erscheinen, wenn eins der Geräte ausgeschaltet ist, das immer angeschaltet sein sollte und umgekehrt ist der Daumen erst nach oben, wenn alle Geräte ausgeschaltet sind bevor Du die Wohnung verlässt.
                • mickymM mickym
                  Damrak2022D Offline
                  Damrak2022D Offline
                  Damrak2022
                  #2905
                  @mickym Irgendwo scheine ich was verdreht zu haben, denn wenn ich nach Deinem Screenshot verkabelt, klappt es noch nicht
                  Mit besten Grüßen
                  Andy
                    mickymM Offline
                    mickymM Offline
                    mickym
                    #2906
                    @damrak2022 Nicht rumprobieren - logisch denken. ;) - Oben haben wir dass Ready ist, wenn das Ergebnis false ist. Nicht ready wenn true rauskommt. Bei true ist ja noch ein Gerät eingeschaltet.
                    Unten ist es umgekehrt. Es ist alles in Ordnung wenn true und Warnung wenn false. Schreib Dir halt nochmal auf, was wir mit ODER und UND verknüpft haben und was Sinn der Sache ist.
                    • mickymM mickym
                      Damrak2022D Offline
                      Damrak2022D Offline
                      Damrak2022
                      #2907
                      @mickym Ja, allerdings habe ich true und false jetzt scho so oft von oben nach unten gewechselt, das ich mir das nochmal ganz in Ruhe anschauen muss.
                      Mit besten Grüßen
                      Andy
                        mickymM Offline
                        mickymM Offline
                        mickym
                        #2908
                        @damrak2022 Nochmal hänge eine Debug Node an die letzte JOIN Node und schau was rauskommt. - Poste den Flow. Wenn Du nicht durchblickst musst Du Schritt für Schritt durchgehen.
                        • mickymM mickym
                          Damrak2022D Offline
                          Damrak2022D Offline
                          Damrak2022
                          #2909
                          @mickym Bitte
                          Bei beiden Switch Nodes steht true oben
                          Mit besten Grüßen
                          Andy
                            @mickym Bitte
                            mickymM Offline
                            mickymM Offline
                            mickym
                            #2910
                            @damrak2022 OK - ich sehe schon den Fehler. Lösch mal die Labels aus Deinen TextNodes raus. Und mach noch die beiden Nodes rein. Die Label müssen wegen dem Blinken in extra Nodes, also die Labels rausmachen und im Dashboard immer eine Label Node und eine Node mit dem Value getrennt.
                                   "id": "415e6037041bc923",
                                   "type": "ui_text",
                                   "order": 4,
                                   "width": "4",
                                   "height": "1",
                                   "name": "",
                                   "label": "Überwachte Geräte",
                                   "format": "{{msg.payload}}",
                                   "className": "",
                                   "x": 4810,
                                   "y": 3500,
                                   "wires": []
                                   "id": "96f001d18a893ff5",
                                   "type": "ui_text",
                                   "order": 6,
                                   "width": "4",
                                   "height": "1",
                                   "name": "",
                                   "label": "Ready to go?",
                                   "className": "",
                                   "x": 4810,
                                   "y": 3460,
                                   "wires": []
                                   "type": "ui_group",
                                   "name": "Test",
                                   "order": 2,
                                   "disp": true,
                                   "width": "6",
                                   "collapse": false,
                                   "className": ""
                                   "type": "ui_tab",
                                   "name": "Home",
                                   "order": 1,
                                   "disabled": false,
                                   "hidden": false
                            So muss dass dann im Dashboard aussehen:
                            Die beiden Nodes - die statisch nur das Label enthalten werde nicht verkabelt.
                            Damrak2022D mickymM 3 Antworten Letzte Antwort
                            • mickymM mickym
                                     "type": "ui_text",
                                     "order": 4,
                                     "width": "4",
                                     "height": "1",
                                     "name": "",
                                     "className": "",
                                     "x": 4810,
                                     "y": 3500,
                                     "wires": []
                                     "type": "ui_text",
                                     "order": 6,
                                     "width": "4",
                                     "height": "1",
                                     "name": "",
                                     "className": "",
                                     "x": 4810,
                                     "y": 3460,
                                     "wires": []
                                     "type": "ui_group",
                                     "name": "Test",
                                     "order": 2,
                                     "disp": true,
                                     "width": "6",
                                     "collapse": false,
                                     "className": ""
                                     "type": "ui_tab",
                                     "name": "Home",
                                     "order": 1,
                                     "disabled": false,
                                     "hidden": false
                              Damrak2022D Offline
                              Damrak2022D Offline
                              Damrak2022
                              #2911
                              @mickym Moment
                              Mit besten Grüßen
                              Andy
                                @mickym Moment
                                Damrak2022D Offline
                                Damrak2022D Offline
                                Damrak2022
                                #2912
                                @damrak2022 Labels sind raus.
                                Bildschirm­foto 2022-12-27 um 23.33.04.png Bildschirm­foto 2022-12-27 um 23.30.44.png
                                Mit besten Grüßen
                                Andy
                                • mickymM mickym
                                         "type": "ui_text",
                                         "order": 4,
                                         "width": "4",
                                         "height": "1",
                                         "name": "",
                                         "className": "",
                                         "x": 4810,
                                         "y": 3500,
                                         "wires": []
                                         "type": "ui_text",
                                         "order": 6,
                                         "width": "4",
                                         "height": "1",
                                         "name": "",
                                         "className": "",
                                         "x": 4810,
                                         "y": 3460,
                                         "wires": []
                                         "type": "ui_group",
                                         "name": "Test",
                                         "order": 2,
                                         "disp": true,
                                         "width": "6",
                                         "collapse": false,
                                         "className": ""
                                         "type": "ui_tab",
                                         "name": "Home",
                                         "order": 1,
                                         "disabled": false,
                                         "hidden": false
                                  Damrak2022D Offline
                                  Damrak2022D Offline
                                  Damrak2022
                                  #2913
                                  @mickym sagte in Visualisierung mit Node Red erstellen:
                                  Was meinst Du damit?
                                  Mit besten Grüßen
                                  Andy
                                    Damrak2022D Offline
                                    Damrak2022D Offline
                                    Damrak2022
                                    #2914
                                    @damrak2022 Das stimmt doch nicht, oder
                                    Mit besten Grüßen
                                    Andy
                                    • mickymM mickym
                                             "type": "ui_text",
                                             "order": 4,
                                             "width": "4",
                                             "height": "1",
                                             "name": "",
                                             "className": "",
                                             "x": 4810,
                                             "y": 3500,
                                             "wires": []
                                             "type": "ui_text",
                                             "order": 6,
                                             "width": "4",
                                             "height": "1",
                                             "name": "",
                                             "className": "",
                                             "x": 4810,
                                             "y": 3460,
                                             "wires": []
                                             "type": "ui_group",
                                             "name": "Test",
                                             "order": 2,
                                             "disp": true,
                                             "width": "6",
                                             "collapse": false,
                                             "className": ""
                                             "type": "ui_tab",
                                             "name": "Home",
                                             "order": 1,
                                             "disabled": false,
                                             "hidden": false
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      #2915
                                      @mickym Ok - das musst Du halt selbst anpassen. Die Gruppe ist bei mir 6 Einheiten breit.
                                      Die Node mit dem Label - Überwachte Geräte 4 x 1 und der Status 2 x 1 und bei Ready to Go das Gleiche.
                                      Nein Du machst eine Gruppe 6 Einheiten breit.
                                      Wenn Du auf das Layout deiner Testtab Seite anschaust, dann schaut das so aus:
                                      • mickymM mickym
                                        Damrak2022D Offline
                                        Damrak2022D Offline
                                        Damrak2022
                                        #2916
                                        @mickym Okay, ich schaue mir das Layout an
                                        Mit besten Grüßen
                                        Andy
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          #2917
                                          Ansonsten hier nochmal alles zum Import - mit Deiner Testtab Seite:
                                                 "id": "9c84a501ed4c87c3",
                                                 "type": "switch",
                                                 "z": "ba3b2e30dc8fe655",
                                                 "name": "",
                                                 "property": "payload",
                                                 "propertyType": "msg",
                                                 "rules": [
                                                         "t": "false"
                                                         "t": "true"
                                                 "checkall": "true",
                                                 "repair": false,
                                                 "outputs": 2,
                                                 "x": 830,
                                                 "y": 280,
                                                 "wires": [
                                                         "538258582cc670b4"
                                                         "4eb3852997ae1f8a"
                                                 "id": "58cb99a19a0ff7e4",
                                                 "type": "ui_text",
                                                 "group": "f8c09969e01446fb",
                                                 "order": 7,
                                                 "width": "2",
                                                 "height": "1",
                                                 "label": "",
                                                 "className": "",
                                                 "x": 1230,
                                                 "y": 260,
                                                 "wires": []
                                                 "id": "538258582cc670b4",
                                                 "type": "change",
                                                 "name": "Ready",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "icon",
                                                         "pt": "msg",
                                                         "to": "thumbs-up",
                                                         "tot": "str"
                                                         "t": "set",
                                                         "p": "color",
                                                         "pt": "msg",
                                                         "to": "green",
                                                         "tot": "str"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 1010,
                                                 "y": 240,
                                                 "wires": [
                                                         "58cb99a19a0ff7e4"
                                                 "id": "4eb3852997ae1f8a",
                                                 "type": "change",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "icon",
                                                         "pt": "msg",
                                                         "tot": "str"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 1030,
                                                 "y": 280,
                                                 "wires": [
                                                         "58cb99a19a0ff7e4"
                                                 "id": "b94dab76e77fc884",
                                                 "type": "switch",
                                                 "name": "",
                                                 "rules": [
                                                         "t": "false"
                                                         "t": "true"
                                                 "checkall": "true",
                                                 "repair": false,
                                                 "outputs": 2,
                                                 "x": 830,
                                                 "y": 340,
                                                 "wires": [
                                                         "c191ae81989bbd1f"
                                                         "1e83244f30c91f5d"
                                                 "id": "54aaa0ca0da2b7c2",
                                                 "type": "ui_text",
                                                 "order": 5,
                                                 "width": "2",
                                                 "height": "1",
                                                 "label": "",
                                                 "className": "",
                                                 "x": 1230,
                                                 "y": 320,
                                                 "wires": []
                                                 "id": "c191ae81989bbd1f",
                                                 "type": "change",
                                                 "name": "Warnung",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "icon",
                                                         "pt": "msg",
                                                         "to": "warning",
                                                         "tot": "str"
                                                         "t": "set",
                                                         "p": "color",
                                                         "pt": "msg",
                                                         "to": "yellow",
                                                         "tot": "str"
                                                         "t": "set",
                                                         "p": "className",
                                                         "pt": "msg",
                                                         "to": "blink",
                                                         "tot": "str"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 1020,
                                                 "y": 320,
                                                 "wires": [
                                                         "54aaa0ca0da2b7c2"
                                                 "id": "1e83244f30c91f5d",
                                                 "type": "change",
                                                 "name": "Alles OK",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "icon",
                                                         "pt": "msg",
                                                         "tot": "str"
                                                         "t": "set",
                                                         "p": "color",
                                                         "pt": "msg",
                                                         "to": "green",
                                                         "tot": "str"
                                                         "t": "set",
                                                         "p": "className",
                                                         "pt": "msg",
                                                         "to": "",
                                                         "tot": "str"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 1020,
                                                 "y": 360,
                                                 "wires": [
                                                         "54aaa0ca0da2b7c2"
                                                 "id": "2d4a599c13429ec2",
                                                 "type": "ui_text",
                                                 "order": 4,
                                                 "width": "4",
                                                 "height": "1",
                                                 "name": "",
                                                 "className": "",
                                                 "x": 1210,
                                                 "y": 160,
                                                 "wires": []
                                                 "id": "158bf46937c0d128",
                                                 "type": "ui_text",
                                                 "order": 6,
                                                 "width": "4",
                                                 "height": "1",
                                                 "name": "",
                                                 "className": "",
                                                 "x": 1210,
                                                 "y": 120,
                                                 "wires": []
                                                 "id": "f8c09969e01446fb",
                                                 "type": "ui_group",
                                                 "name": "Testansicht",
                                                 "tab": "0c3299b0a882cc5f",
                                                 "order": 1,
                                                 "disp": true,
                                                 "width": "6",
                                                 "collapse": false,
                                                 "className": ""
                                                 "id": "0c3299b0a882cc5f",
                                                 "type": "ui_tab",
                                                 "name": "Testtab",
                                                 "order": 19,
                                                 "disabled": false,
                                                 "hidden": false
                                          Die Nodes, die das Icon enthalten sind 2 Einheiten breit. Die ganze Gruppe ist 6 Einheiten breit:
                                          Die Label Nodes die nicht verkabelt sind - sind 4 Einheiten breit
                                          Die ganze Gruppe 6 Einheiten.
