  4. History Adapter - exportieren / migrieren nach InfluxDB
influxdbhistoryexportierenmigrieren
52 Beiträge 15 Kommentatoren 9.6k Aufrufe 14 Beobachtet
  • S spoeh-man
    @dp20eic said in History Adapter - exportieren / migrieren nach InfluxDB:
    node analyzeinflux.js influxdb.0 info --deepAnalyze
    Ja die Dateien sind nahezu leer das heisst dass er die Datenpunkte vom History schon nicht korrekt lesen kann aber im IObroker am Datenpunkt mit dem Zahnrad sehe ich werte ohne ende
    @spoeh-man
    Gibt es irgend ein Log-File, das du uns hier zeigen kannst, von den jeweiligen Kommandos?
    Bernd
      @spoeh-man
      Bernd
      spoeh-man
      @dp20eic
      Klaro
      root@ioBroker:/opt/iobroker/node_modules/iobroker.history/converter# node analyzeinflux.js influxdb.0 info --deepAnalyze
      Do deep analysis to find holes in data
      InfluxDB-Configuration: {"debounce":1000,"retention":0,"dbname":"iobroker","host":"192.168.179.66","protocol":"http","path":"","port":8086,"user":"","organization":"Privat","round":4,"seriesBufferMax":0,"seriesBufferFlushInterval":600,"changesRelogInterval":0,"changesMinDelta":0,"reconnectInterval":10000,"pingInterval":15000,"requestTimeout":30000,"validateSSL":true,"dbversion":"2.x","usetags":false,"pingserver":true,"blockTime":0,"debounceTime":0,"disableSkippedValueLogging":false,"enableLogging":false,"customRetentionDuration":365,"relogLastValueOnStart":true}
      Query Data from instance "influxdb.0" (Version 2, Bucket iobroker)
      Datapoints found: 16
      FirstVal ID: 0_userdata.0.Aquarium.PH_Sollwert, Rows: [{"result":"_result","table":0,"_start":"1970-01-01T00:00:00Z","_stop":"2022-12-22T13:18:37.842243322Z","_time":"2022-12-21T12:42:50.907Z","_value":7.1,"_field":"value","_measurement":"0_userdata.0.Aquarium.PH_Sollwert","ts":1671626570907}] --> Wed Dec 21 2022 12:42:50 GMT+0000 (Coordinated Universal Time)
      DayVals ID: 0_userdata.0.Aquarium.PH_Sollwert: [20221222]
      ValType ID: 0_userdata.0.Aquarium.PH_Sollwert: "number"
      FirstVal ID: 0_userdata.0.Stromzähler.Jahresverbrauch, Rows: [{"result":"_result","table":0,"_start":"1970-01-01T00:00:00Z","_stop":"2022-12-22T13:18:37.99657047Z","_time":"2022-12-21T12:44:03.749Z","_value":3776.586,"_field":"value","_measurement":"0_userdata.0.Stromzähler.Jahresverbrauch","ts":1671626643749}] --> Wed Dec 21 2022 12:44:03 GMT+0000 (Coordinated Universal Time)
      DayVals ID: 0_userdata.0.Stromzähler.Jahresverbrauch: [20221222,20221222]
      ValType ID: 0_userdata.0.Stromzähler.Jahresverbrauch: "number"
      FirstVal ID: 0_userdata.0.Stromzähler.Verbrauch_Abrechnungperiode, Rows: [{"result":"_result","table":0,"_start":"1970-01-01T00:00:00Z","_stop":"2022-12-22T13:18:38.168296659Z","_time":"2022-12-21T12:45:03.386Z","_value":929.594,"_field":"value","_measurement":"0_userdata.0.Stromzähler.Verbrauch_Abrechnungperiode","ts":1671626703386}] --> Wed Dec 21 2022 12:45:03 GMT+0000 (Coordinated Universal Time)
      DayVals ID: 0_userdata.0.Stromzähler.Verbrauch_Abrechnungperiode: [20221222,20221222]
      ValType ID: 0_userdata.0.Stromzähler.Verbrauch_Abrechnungperiode: "number"
      FirstVal ID: Testdatenpunkt, Rows: [{"result":"_result","table":0,"_start":"1970-01-01T00:00:00Z","_stop":"2022-12-22T13:18:38.325955045Z","_time":"2022-12-21T12:14:56.267Z","_value":40,"_field":"value","_measurement":"Testdatenpunkt","ts":1671624896267}] --> Wed Dec 21 2022 12:14:56 GMT+0000 (Coordinated Universal Time)
      DayVals ID: Testdatenpunkt: [20221222]
      ValType ID: Testdatenpunkt: "number"
      FirstVal ID: shelly.0.SHEM-3#84CCA8AD96DA#1.Total.ConsumedPower, Rows: [{"result":"_result","table":0,"_start":"1970-01-01T00:00:00Z","_stop":"2022-12-22T13:18:38.480358464Z","_time":"2022-12-21T12:45:04.531Z","_value":7696383.1,"_field":"value","_measurement":"shelly.0.SHEM-3#84CCA8AD96DA#1.Total.ConsumedPower","ts":1671626704531}] --> Wed Dec 21 2022 12:45:04 GMT+0000 (Coordinated Universal Time)
      DayVals ID: shelly.0.SHEM-3#84CCA8AD96DA#1.Total.ConsumedPower: [20221222,20221222]
      ValType ID: shelly.0.SHEM-3#84CCA8AD96DA#1.Total.ConsumedPower: "number"
      FirstVal ID: shelly.0.SHEM-3#84CCA8AD96DA#1.Total.InstantPower, Rows: [{"result":"_result","table":0,"_start":"1970-01-01T00:00:00Z","_stop":"2022-12-22T13:18:38.638267956Z","_time":"2022-12-21T12:45:24.458Z","_value":436.45,"_field":"value","_measurement":"shelly.0.SHEM-3#84CCA8AD96DA#1.Total.InstantPower","ts":1671626724458}] --> Wed Dec 21 2022 12:45:24 GMT+0000 (Coordinated Universal Time)
      DayVals ID: shelly.0.SHEM-3#84CCA8AD96DA#1.Total.InstantPower: [20221222,20221222]
      ValType ID: shelly.0.SHEM-3#84CCA8AD96DA#1.Total.InstantPower: "number"
      FirstVal ID: sonoff.0.Aquarium_PH.ANALOG_pH0, Rows: [{"result":"_result","table":0,"_start":"1970-01-01T00:00:00Z","_stop":"2022-12-22T13:18:38.857229274Z","_time":"2022-12-21T12:50:25.252Z","_value":7.13,"_field":"value","_measurement":"sonoff.0.Aquarium_PH.ANALOG_pH0","ts":1671627025252}] --> Wed Dec 21 2022 12:50:25 GMT+0000 (Coordinated Universal Time)
      DayVals ID: sonoff.0.Aquarium_PH.ANALOG_pH0: [20221222,20221222]
      ValType ID: sonoff.0.Aquarium_PH.ANALOG_pH0: "number"
      FirstVal ID: sonoff.0.Solaranlage.ENERGY_Power, Rows: [{"result":"_result","table":0,"_start":"1970-01-01T00:00:00Z","_stop":"2022-12-22T13:18:39.023154755Z","_time":"2022-12-21T12:50:42.816Z","_value":2,"_field":"value","_measurement":"sonoff.0.Solaranlage.ENERGY_Power","ts":1671627042816}] --> Wed Dec 21 2022 12:50:42 GMT+0000 (Coordinated Universal Time)
      DayVals ID: sonoff.0.Solaranlage.ENERGY_Power: [20221222,20221222]
      ValType ID: sonoff.0.Solaranlage.ENERGY_Power: "number"
      FirstVal ID: sonoff.0.Solaranlage.ENERGY_Total, Rows: [{"result":"_result","table":0,"_start":"1970-01-01T00:00:00Z","_stop":"2022-12-22T13:18:39.193313178Z","_time":"2022-12-21T12:50:51.15Z","_value":604.922,"_field":"value","_measurement":"sonoff.0.Solaranlage.ENERGY_Total","ts":1671627051150}] --> Wed Dec 21 2022 12:50:51 GMT+0000 (Coordinated Universal Time)
      DayVals ID: sonoff.0.Solaranlage.ENERGY_Total: [20221222,20221222]
      ValType ID: sonoff.0.Solaranlage.ENERGY_Total: "number"
      FirstVal ID: stromzaeler, Rows: [{"result":"_result","table":0,"_start":"1970-01-01T00:00:00Z","_stop":"2022-12-22T13:18:39.346660386Z","_time":"2022-12-21T12:43:52.117Z","_value":47082.578,"_field":"value","_measurement":"stromzaeler","ts":1671626632117}] --> Wed Dec 21 2022 12:43:52 GMT+0000 (Coordinated Universal Time)
      DayVals ID: stromzaeler: [20221222,20221222]
      ValType ID: stromzaeler: "number"
      FirstVal ID: zigbee.0.00158d0001e8a0af.humidity, Rows: [{"result":"_result","table":0,"_start":"1970-01-01T00:00:00Z","_stop":"2022-12-22T13:18:39.50877007Z","_time":"2022-12-21T12:48:43.618Z","_value":51.51,"_field":"value","_measurement":"zigbee.0.00158d0001e8a0af.humidity","ts":1671626923618}] --> Wed Dec 21 2022 12:48:43 GMT+0000 (Coordinated Universal Time)
      DayVals ID: zigbee.0.00158d0001e8a0af.humidity: [20221222,20221222]
      ValType ID: zigbee.0.00158d0001e8a0af.humidity: "number"
      FirstVal ID: zigbee.0.00158d0001e8a0af.temperature, Rows: [{"result":"_result","table":0,"_start":"1970-01-01T00:00:00Z","_stop":"2022-12-22T13:18:39.662470987Z","_time":"2022-12-21T12:48:50.792Z","_value":22.12,"_field":"value","_measurement":"zigbee.0.00158d0001e8a0af.temperature","ts":1671626930792}] --> Wed Dec 21 2022 12:48:50 GMT+0000 (Coordinated Universal Time)
      DayVals ID: zigbee.0.00158d0001e8a0af.temperature: [20221222,20221222]
      ValType ID: zigbee.0.00158d0001e8a0af.temperature: "number"
      FirstVal ID: zigbee.0.00158d00020245b3.humidity, Rows: [{"result":"_result","table":0,"_start":"1970-01-01T00:00:00Z","_stop":"2022-12-22T13:18:39.815973012Z","_time":"2022-12-21T12:49:06.266Z","_value":50.31,"_field":"value","_measurement":"zigbee.0.00158d00020245b3.humidity","ts":1671626946266}] --> Wed Dec 21 2022 12:49:06 GMT+0000 (Coordinated Universal Time)
      DayVals ID: zigbee.0.00158d00020245b3.humidity: [20221222,20221222]
      ValType ID: zigbee.0.00158d00020245b3.humidity: "number"
      FirstVal ID: zigbee.0.00158d00020245b3.temperature, Rows: [{"result":"_result","table":0,"_start":"1970-01-01T00:00:00Z","_stop":"2022-12-22T13:18:39.965729664Z","_time":"2022-12-21T12:49:13.932Z","_value":22.28,"_field":"value","_measurement":"zigbee.0.00158d00020245b3.temperature","ts":1671626953932}] --> Wed Dec 21 2022 12:49:13 GMT+0000 (Coordinated Universal Time)
      DayVals ID: zigbee.0.00158d00020245b3.temperature: [20221222,20221222]
      ValType ID: zigbee.0.00158d00020245b3.temperature: "number"
      FirstVal ID: zigbee.0.00158d00025ea014.humidity, Rows: [{"result":"_result","table":0,"_start":"1970-01-01T00:00:00Z","_stop":"2022-12-22T13:18:40.114570292Z","_time":"2022-12-21T12:49:27.074Z","_value":92.81,"_field":"value","_measurement":"zigbee.0.00158d00025ea014.humidity","ts":1671626967074}] --> Wed Dec 21 2022 12:49:27 GMT+0000 (Coordinated Universal Time)
      DayVals ID: zigbee.0.00158d00025ea014.humidity: [20221222,20221222]
      ValType ID: zigbee.0.00158d00025ea014.humidity: "number"
      FirstVal ID: zigbee.0.00158d00025ea014.temperature, Rows: [{"result":"_result","table":0,"_start":"1970-01-01T00:00:00Z","_stop":"2022-12-22T13:18:40.264161074Z","_time":"2022-12-21T12:49:34.375Z","_value":8.42,"_field":"value","_measurement":"zigbee.0.00158d00025ea014.temperature","ts":1671626974375}] --> Wed Dec 21 2022 12:49:34 GMT+0000 (Coordinated Universal Time)
      DayVals ID: zigbee.0.00158d00025ea014.temperature: [20221222,20221222]
      ValType ID: zigbee.0.00158d00025ea014.temperature: "number"
      Writing files to /opt/iobroker/node_modules/iobroker.history/converter ...
          - saved /opt/iobroker/node_modules/iobroker.history/converter/existingDBValues.json
          - saved /opt/iobroker/node_modules/iobroker.history/converter/existingDBTypes.json
          - saved /opt/iobroker/node_modules/iobroker.history/converter/earliestDBValues.json
      • S spoeh-man
        @dp20eic
        Klaro
        @spoeh-man
        Ok, das war die Analyse. Soweit ich das jetzt verstehe, schaut die in die Influxdb Instanz, und Du hast dort nur diese 16 Datenpunkte, welche auch in den .json Files zu finden sein sollten.
        Jetzt wäre noch ein Log vom zweiten Schritt hilfreich, denn der sollte ja diese Information aus den drei Files nehmen und alles was noch nicht in der InfluxDB vorhanden ist reinkloppen, jedenfalls die Datenpunkte die dort in den .json Files vorhanden sind.
        Frage sind das die 16 Datenpunkte, die Du auch im History Adapter sicherst?
        Wie gesagt, ich habe mich nicht mit der Konvertierung beschäftigt, ich habe weggeschmissen und neu angefangen, daher vielleicht auch Dumme Fragen dabei!
        Bernd
          @spoeh-man
          Bernd
          spoeh-man
          @dp20eic
          Ja das sind die 16 Datenpunkte die ich Im History sichere. Das mit den Json dateien ist eben dass problem dort steht fast nichts drinnen ausser die Datenpunkte wenn ich aber dass 2. script laufen lassen kommt als Ausgabe: (ich habe es extra mal mit möglichst wenigen Parametern laufen lassen) 2. Ausgabe mal mit Datum von 1970
          node history2db.js influxdb.0 info 20211201 /opt/iobroker/iobroker-data/history/
          Send Data to influxdb.0
          Start at 20211201
          Use historyDir /opt/iobroker/iobroker-data/history/
          earliesDBValues initialized from cache 16
          ExistingDBTypes initialized from cache 16
          Started processFiles with 16 known db values
          We start earliest at 20211201
          DONE
          node history2db.js influxdb.0 info 19700101 /opt/iobroker/iobroker-data/history/
          Start at 19700101
          We start earliest at 19700101
          DONE
          aber übernommen wird leider nichts
          • S spoeh-man
            @dp20eic
            Start at 20211201
            DONE
            Start at 19700101
            DONE
            @spoeh-man
            Wenn da nicht mehr an output kommt, dann solltest Du mal auf Github ein Problem aufmachen.
            Oder evtl. wenn es gibt mit debug laufen lassen.
            Bernd
              @spoeh-man
              Bernd
              spoeh-man
              @dp20eic
              Ja debug zeigt den gleichen Inhalt ich hab mal ein Problem in Github eröffnet
              • J jensmaehn
                @jensmaehn said in History Adapter - exportieren / migrieren nach InfluxDB:
                @FredF said in History Adapter - exportieren / migrieren nach InfluxDB:
                @jensmaehn sagte in History Adapter - exportieren / migrieren nach InfluxDB:
                Bei mir war der entscheidende Hinweis: Alle Adapter bis auf Admin, web, history und influxdb zu deaktivieren, sonst hatte ich nur Abbrüche und Systemaufhänger..
                Danke für den Hinweis, werde das in die Beschreibung übernehmen.
                Woher hast du die Info?
                Viel Try & Error ;-)
                Liebt aber auch vielliecht daran, dass mein Setup mit Raspi 3 schon an seinen Grenzen läuft...
                Der Wechsel auf Raspi 4 steht nun unmittelbar bevor ;-)
                apollon77A Online
                apollon77A Online
                @jensmaehn Das glaube ich eher ... es werden halt viele Daten an den "neuen" adapter gesendet ... das generiert durchaus CPU Last. mehr aber auch nicht
                • D Davipet
                  ich versuche grade die Daten von etwa einem Jahr Histroy zu influx zu migrieren.
                  Es sind wirklich ziemlich viele Daten.
                  Ich habe die Influx Datenbank ganz frisch aufgesetzt und wollte einfach alle Daten migrieren ohne das Analyse-script durchlaufen zu lassen. Bekomme aber immer nur ein "ignore" bei allen Datenpunkten. Wie kommt das?
                  Und: Wenn ich das Analyse-script starte bekomme ich:
                  Invalid call
                  Aber danach keinen Promt. Also passiert irgend etwas?
                  Es werden in dem Converter-Ordner aber keine Dateien angelegt.
                  Ich habe das Fenster nun schon fast 48h offen - meint ihr da passiert noch etwas?
                  Danke!
                  David
                  apollon77A Online
                  apollon77A Online
                  @davipet Dann zeige bitte mal ein verzeichnislisting (bzw Auszug) von dem angegebenen History Datenverzeichnis. Sie da Verzeichnisse in "Datumsform" drin? yyyymmdd und am besten auch mal den Inhalt von einem davon und dann die zwei json Files die er in der vorbereitung angelegt hat.
                  Weil an sich sieht der Start des Skripts gut aus ... AM besten ruf es doch jetzt mal ohne einen Datumsparameter im Aufruf auf bzw dort eine 0. Was passiert dann?
                  PS: Die eine Logzeile "We start earliest at ..." ist am Ende genau falsch ... Die muss "We only process values before ...". Also mit 1970 kommt deshalb nix ...aber mit Datum von heute sollte mehr passieren :-) Am Ende ist da eine "0" aber das beste weil dann ermittelt er den "end wert" aus den gesammelten Daten
                  • apollon77A apollon77
                    spoeh-man
                    @apollon77
                    Verzeichnislisting vom Datenverzeichnis
                    root@ioBroker:/opt/iobroker/iobroker-data/history# ls -la
                    total 28
                    drwxrwxr-x+ 845 iobroker iobroker 20480 Dec 25 00:01 ' '
                    drwxrwxr-x+   3 iobroker iobroker  4096 Dec 21 09:17  .
                    drwxrwxr-x+  10 iobroker iobroker  4096 Dec 25 05:48  ..
                    ich glaube da könnte auch schon dass Problem sein aber im iobroker ist genau dieses verzeichnis im Adapter hinterlegtiobroker History.jpg
                    • S spoeh-man
                      @apollon77
                      total 28
                      apollon77A Online
                      apollon77A Online
                      @spoeh-man was ist das denn für ein Verzeichnis da mit einem Leerzeichen? Ist vllt in der Konfiguration da auch ein Space am Ende?sind die files dort? Wenn ja setze beim Aufruf den Pfad mal in Anführungszeichen und hänge auch ein Leerzeichen noch an.
                        spoeh-man
                        @apollon77
                        Ich glaube das war es woher auch immer dass Leerzeichen stammt hätte nur noch keine Zeit zur Migration musste zur Arbeit
                        • S spoeh-man
                          @apollon77
                          apollon77A Online
                          apollon77A Online
                          @spoeh-man also alle Speiseöle oben sind ohne Anführungszeichen um den odad und ohne Leerzeichen am Ende beim Aufruf des convert Skripts.
                            spoeh-man
                            @apollon77
                            Was für Speiseöle?. Irgendwie kann ich es trotz mehrmaligen Lesens nicht genau deuten was die frage ist aber das script tut gerade seinen dienst. Vielen Lieben dank für eure Hilfe
                            • apollon77A Online
                              apollon77A Online
                              Ohje Handy mal wieder ... Screenshots war das wort :-)) Aber wenn es jetzt tut ist ja alles super
                                SaarlandUHU
                                schrieb am zuletzt editiert von SaarlandUHU
                                ich wollte meine Datenbank auch zu Influx migrieren.
                                Habe die Skripte soweit befolgt. Die laufen auch ohne Fehlermeldung durch. Allerdings werden keine Daten aus dem Datenbestand vom History Adapter kopiert.
                                Meine Vermutung liegt im Timestamp der Daten im History Adapter.
                                Beim Blick in die .json-Datei vom Analyse-Skript werden für die frühesten Datensätze allesamt Timestamps angezeigt, die weit in der Zukunft liegen. Beim Durchlaufen des Migriervorgangs kann er dann natürlich keine Daten finden, die zwischen dem frühesten Timestamp und heute liegen.
                                Nachfolgend noch der Inhalt aus der earliestDBValues.json
                                "0_userdata.0.Datenpunkte.Smartphones.A52.akkustand_a52": 1666880736920,
                                "0_userdata.0.Datenpunkte.Smartphones.S21_Daniel.akkustand": 1666019090582,
                                "0_userdata.0.Stromzähler_Haushalt.Day": 1668880485755,
                                "0_userdata.0.Stromzähler_Haushalt.Hour": 1668880491552,
                                "0_userdata.0.Stromzähler_Haushalt.Month": 1668880495366,
                                "0_userdata.0.Stromzähler_Haushalt.Week": 1668880499441,
                                "0_userdata.0.Stromzähler_Wärme.Day": 1668856754022,
                                "0_userdata.0.Stromzähler_Wärme.Hour": 1668856759361,
                                "0_userdata.0.Stromzähler_Wärme.Month": 1668856763564,
                                "0_userdata.0.Stromzähler_Wärme.Week": 1668856767983,
                                "fb-checkpresence.0.Elisabeth": 1665517455635,
                                "fb-checkpresence.0.Galaxy-A52s-5G": 1666880013945,
                                "fb-checkpresence.0.S21-von-Daniel": 1665517455635,
                                "hm-rpc.1.000A9F298FCC7E.1.ACTUAL_TEMPERATURE": 1670432616118,
                                "hm-rpc.1.000A9F298FCC7E.1.HUMIDITY": 1670432604334,
                                "hm-rpc.1.000A9F298FCCA1.1.ACTUAL_TEMPERATURE": 1669310916637,
                                "hm-rpc.1.000A9F298FCCA1.1.HUMIDITY": 1669310929119,
                                "hm-rpc.1.000E9D89BB7599.1.ACTUAL_TEMPERATURE": 1670435485571,
                                "hm-rpc.1.000E9D89BB7599.1.HUMIDITY": 1670435492677,
                                "hm-rpc.1.000E9D89BB75F0.1.ACTUAL_TEMPERATURE": 1670436739498,
                                "hm-rpc.1.000E9D89BB75F0.1.HUMIDITY": 1670436745120,
                                "hm-rpc.1.000E9D89BB7A94.1.ACTUAL_TEMPERATURE": 1670564492102,
                                "hm-rpc.1.000E9D89BB7A94.1.HUMIDITY": 1670564499583,
                                "hm-rpc.1.000E9D89BB7A99.1.ACTUAL_TEMPERATURE": 1670564520552,
                                "hm-rpc.1.000E9D89BB7A99.1.HUMIDITY": 1670564531677,
                                "hm-rpc.1.0010DD89A2D19F.1.ACTUAL_TEMPERATURE": 1674831917725,
                                "hm-rpc.1.0010DD89A2D19F.1.HUMIDITY": 1674831943051,
                                "hm-rpc.1.001B9F29967090.1.LEVEL": 1673431338655,
                                "hm-rpc.1.001B9F29967090.3.LEVEL": 1673431327737,
                                "hm-rpc.1.001B9F29967090.5.LEVEL": 1673431317357,
                                "hm-rpc.1.001B9F29967090.7.LEVEL": 1673431503528,
                                "hm-rpc.1.001B9F29967090.8.LEVEL": 1673431514677,
                                "hmip.0.devices.3014F711A0000C9D899EBE47.channels.1.actualTemperature": 1665517455635,
                                "hmip.0.devices.3014F711A0000C9D899EBE47.channels.1.humidity": 1665517455635,
                                "shelly.0.SHPLG-S#221667#1.Relay0.Power": 1665517455635,
                                "shelly.0.SHPLG-S#D9DB12#1.Relay0.Power": 1665517455635,
                                "smartmeter.0.1-0:16_7_0__255.value": 1675284084805,
                                "smartmeter.0.1-0:1_8_0__255.value": 1675284090098,
                                "smartmeter.1.1-0:16_7_0__255.value": 1675284094925,
                                "smartmeter.1.1-0:1_8_0__255.value": 1675284101036,
                                "stiebel-isg.0.Einstellungen.HEIZEN.GRUNDEINSTELLUNG.val134": 1674680233958,
                                "stiebel-isg.0.Info.ANLAGE.HEIZEN.AUSSENTEMPERATUR": 1674587962908,
                                "zigbee.0.00124b002510816a.humidity": 1665517455635,
                                "zigbee.0.00124b002510816a.temperature": 1665517455635,
                                "zigbee.0.00124b0025138250.humidity": 1665517455635,
                                "zigbee.0.00124b0025138250.temperature": 1665517455635,
                                "zigbee.0.00124b002513845c.humidity": 1665517455635,
                                "zigbee.0.00124b002513845c.temperature": 1665517455635,
                                "zigbee.0.00124b002549ddea.humidity": 1665517455635,
                                "zigbee.0.00124b002549ddea.temperature": 1665517455635
                                Bei Diagrammen, die ich mit Flot oder ECharts erstelle passen die Zeiten. Auch die Ordnerstruktur im History Ordner auf dem Pi passt. Da ist für jeden Tag ein Ordner nach dem muster YYYYMMDD erstellt.
                                Habt ihr ne Ahnung woran das liegen könnte und wie man das abstellen kann?
                                Vielen Dank schonmal
                                Edit wegen Typo
                                • S SaarlandUHU
                                  Edit wegen Typo
                                  klassisch
                                  schrieb am zuletzt editiert von klassisch
                                  @saarlanduhu Wenn ich einen mit history erzeugten timestamp in https://www.epochconverter.com/ gebe und "timestamp to human date" drücke, kommt die richtige Zeit raus mit dem Hinweis "assuming timestamp in ms".
                                  Lösche ich die letzten 3 Stellen, dann kommt auch wieder das gleiche Datum raus mit dem Hinweis "assuming timestamp in s".
                                  Es scheinen also 2 Formate für epoch üblich zu sein, im ms und in s.
                                  Vielleicht gibt es da Misverständnisse bei der konvertierung?
                                  • K klassisch
                                    SaarlandUHU
                                    @klassisch, danke dir.
                                    das erklärt zumindest mal warums an den anderen Stellen dann passt.
                                    Leider bringt mich das bei der Migration der Daten nicht weiter. Bzw. Zumindest weiß ich nicht wie ich die Info für mein Problem nutzen könnte. 🤔
                                    • S SaarlandUHU
                                      klassisch
                                      @saarlanduhu sagte in History Adapter - exportieren / migrieren nach InfluxDB:
                                      Ich leider auch nicht. Vielleicht kann man bei InfluxDB (was ich nicht habe und nicht kenne) etwas konfigurieren?
                                      • apollon77A Online
                                        apollon77A Online
                                        Ookkk.die timestamps sollte er selbst behandeln. Also. Bitte zeig mal wie du es ausführst und was die Ausgabe ist.
                                          SaarlandUHU
                                          @apollon77
                                          so führe ichs aus
                                          remotepi@raspberrypi:/opt/iobroker/node_modules/iobroker.history/converter $ node history2db.js influxdb.0 info 0 /opt/iobroker/iobroker-data/history 2 --logChangesOnly 5 --processNonExistingValuesOnly
                                          und das ist das Ergebnis (gekürzt, damit es nicht zu lange wird....geht in ähnlicher weise zurück bis zum 20221011)
                                          Log changes only once per 5 minutes
                                          existingDBValues initialized from cache: 60
                                          earliesDBValues initialized from cache 60
                                          earliesDBValues overwritten with 1675500678721
                                          ExistingDBTypes initialized from cache 60
                                          Started processFiles with 60 known db values
                                          We start earliest at 20230204
                                          Day 20230204 - history.0_userdata.0.Datenpunkte.Smartphones.A52.akkustand_a52.json
                                          Check: 20230204 / pos 85
                                             Ignore existing ID history.0_userdata.0.Datenpunkte.Smartphones.A52.akkustand_a52.json: 0_userdata.0.Datenpunkte.Smartphones.A52.akkustand_a52
                                          Day 20230204 - history.0_userdata.0.Datenpunkte.Smartphones.S21_Daniel.akkustand.json
                                          Check: 20230204 / pos 109
                                             Ignore existing ID history.0_userdata.0.Datenpunkte.Smartphones.S21_Daniel.akkustand.json: 0_userdata.0.Datenpunkte.Smartphones.S21_Daniel.akkustand
                                          Day 20230204 - history.0_userdata.0.Stromzähler_Haushalt.Hour.json
                                          Check: 20230204 / pos 77
                                             Ignore existing ID history.0_userdata.0.Stromzähler_Haushalt.Hour.json: 0_userdata.0.Stromzähler_Haushalt.Hour
                                          Day 20230204 - history.0_userdata.0.Stromzähler_Wärme.Hour.json
                                             Ignore existing ID history.0_userdata.0.Stromzähler_Wärme.Hour.json: 0_userdata.0.Stromzähler_Wärme.Hour
                                          Day 20230204 - history.daswetter.1.NextHours.Location_1.Day_1.current.clouds_value.json
                                             Ignore ID history.daswetter.1.NextHours.Location_1.Day_1.current.clouds_value.json: daswetter.1.NextHours.Location_1.Day_1.current.clouds_value
                                          Day 20230204 - history.daswetter.1.NextHours.Location_1.Day_1.current.symbol_desc.json
                                             Ignore ID history.daswetter.1.NextHours.Location_1.Day_1.current.symbol_desc.json: daswetter.1.NextHours.Location_1.Day_1.current.symbol_desc
                                          Day 20230204 - history.fb-checkpresence.0.Elisabeth.json
                                          Check: 20230204 / pos 113
                                             Ignore existing ID history.fb-checkpresence.0.Elisabeth.json: fb-checkpresence.0.Elisabeth
                                          Day 20230204 - history.hm-rpc.1.000A9F298FCC7E.1.ACTUAL_TEMPERATURE.json
                                          Check: 20230204 / pos 59
                                             Ignore existing ID history.hm-rpc.1.000A9F298FCC7E.1.ACTUAL_TEMPERATURE.json: hm-rpc.1.000A9F298FCC7E.1.ACTUAL_TEMPERATURE
                                          Day 20230204 - history.hm-rpc.1.000A9F298FCC7E.1.HUMIDITY.json
                                             Ignore existing ID history.hm-rpc.1.000A9F298FCC7E.1.HUMIDITY.json: hm-rpc.1.000A9F298FCC7E.1.HUMIDITY
                                          Day 20230204 - history.hm-rpc.1.000A9F298FCCA1.1.ACTUAL_TEMPERATURE.json
                                          Check: 20230204 / pos 72
                                             Ignore existing ID history.hm-rpc.1.000A9F298FCCA1.1.ACTUAL_TEMPERATURE.json: hm-rpc.1.000A9F298FCCA1.1.ACTUAL_TEMPERATURE
                                          Day 20230204 - history.hm-rpc.1.000A9F298FCCA1.1.HUMIDITY.json
                                             Ignore existing ID history.hm-rpc.1.000A9F298FCCA1.1.HUMIDITY.json: hm-rpc.1.000A9F298FCCA1.1.HUMIDITY
                                          Day 20230204 - history.hm-rpc.1.000E9D89BB7599.1.ACTUAL_TEMPERATURE.json
                                             Ignore existing ID history.hm-rpc.1.000E9D89BB7599.1.ACTUAL_TEMPERATURE.json: hm-rpc.1.000E9D89BB7599.1.ACTUAL_TEMPERATURE
                                          Day 20230204 - history.hm-rpc.1.000E9D89BB7599.1.HUMIDITY.json
                                             Ignore existing ID history.hm-rpc.1.000E9D89BB7599.1.HUMIDITY.json: hm-rpc.1.000E9D89BB7599.1.HUMIDITY
                                          Day 20230204 - history.hm-rpc.1.000E9D89BB75F0.1.ACTUAL_TEMPERATURE.json
                                             Ignore existing ID history.hm-rpc.1.000E9D89BB75F0.1.ACTUAL_TEMPERATURE.json: hm-rpc.1.000E9D89BB75F0.1.ACTUAL_TEMPERATURE
                                          Day 20230204 - history.hm-rpc.1.000E9D89BB75F0.1.HUMIDITY.json
                                             Ignore existing ID history.hm-rpc.1.000E9D89BB75F0.1.HUMIDITY.json: hm-rpc.1.000E9D89BB75F0.1.HUMIDITY
                                          Day 20230204 - history.hm-rpc.1.000E9D89BB7A94.1.ACTUAL_TEMPERATURE.json
                                          Check: 20230204 / pos 57
                                             Ignore existing ID history.hm-rpc.1.000E9D89BB7A94.1.ACTUAL_TEMPERATURE.json: hm-rpc.1.000E9D89BB7A94.1.ACTUAL_TEMPERATURE
                                          Day 20230204 - history.hm-rpc.1.000E9D89BB7A94.1.HUMIDITY.json
                                             Ignore existing ID history.hm-rpc.1.000E9D89BB7A94.1.HUMIDITY.json: hm-rpc.1.000E9D89BB7A94.1.HUMIDITY
                                          Day 20230204 - history.hm-rpc.1.000E9D89BB7A99.1.ACTUAL_TEMPERATURE.json
                                             Ignore existing ID history.hm-rpc.1.000E9D89BB7A99.1.ACTUAL_TEMPERATURE.json: hm-rpc.1.000E9D89BB7A99.1.ACTUAL_TEMPERATURE
                                          Day 20230204 - history.hm-rpc.1.000E9D89BB7A99.1.HUMIDITY.json
                                             Ignore existing ID history.hm-rpc.1.000E9D89BB7A99.1.HUMIDITY.json: hm-rpc.1.000E9D89BB7A99.1.HUMIDITY
                                          Day 20230204 - history.hm-rpc.1.0010DD89A2D19F.1.ACTUAL_TEMPERATURE.json
                                             Ignore existing ID history.hm-rpc.1.0010DD89A2D19F.1.ACTUAL_TEMPERATURE.json: hm-rpc.1.0010DD89A2D19F.1.ACTUAL_TEMPERATURE
                                          Day 20230204 - history.hm-rpc.1.0010DD89A2D19F.1.HUMIDITY.json
                                             Ignore existing ID history.hm-rpc.1.0010DD89A2D19F.1.HUMIDITY.json: hm-rpc.1.0010DD89A2D19F.1.HUMIDITY
                                          Day 20230204 - history.hm-rpc.1.001B9F29967090.1.LEVEL.json
                                          Check: 20230204 / pos 24
                                             Ignore existing ID history.hm-rpc.1.001B9F29967090.1.LEVEL.json: hm-rpc.1.001B9F29967090.1.LEVEL
                                          Day 20230204 - history.hm-rpc.1.001B9F29967090.3.LEVEL.json
                                             Ignore existing ID history.hm-rpc.1.001B9F29967090.3.LEVEL.json: hm-rpc.1.001B9F29967090.3.LEVEL
                                          Day 20230204 - history.hm-rpc.1.001B9F29967090.5.LEVEL.json
                                             Ignore existing ID history.hm-rpc.1.001B9F29967090.5.LEVEL.json: hm-rpc.1.001B9F29967090.5.LEVEL
                                          Day 20230204 - history.hm-rpc.1.001B9F29967090.7.LEVEL.json
                                             Ignore existing ID history.hm-rpc.1.001B9F29967090.7.LEVEL.json: hm-rpc.1.001B9F29967090.7.LEVEL
                                          Day 20230204 - history.hm-rpc.1.001B9F29967090.8.LEVEL.json
                                             Ignore existing ID history.hm-rpc.1.001B9F29967090.8.LEVEL.json: hm-rpc.1.001B9F29967090.8.LEVEL
                                          Day 20230204 - history.hmip.0.devices.3014F711A0000C9D899EBE47.channels.1.actualTemperature.json
                                          Check: 20230204 / pos 115
                                             Ignore existing ID history.hmip.0.devices.3014F711A0000C9D899EBE47.channels.1.actualTemperature.json: hmip.0.devices.3014F711A0000C9D899EBE47.channels.1.actualTemperature
                                          Day 20230204 - history.hmip.0.devices.3014F711A0000C9D899EBE47.channels.1.humidity.json
                                             Ignore existing ID history.hmip.0.devices.3014F711A0000C9D899EBE47.channels.1.humidity.json: hmip.0.devices.3014F711A0000C9D899EBE47.channels.1.humidity
                                          Day 20230204 - history.shelly.0.SHPLG-S#221667#1.Relay0.Power.json
                                             Ignore existing ID history.shelly.0.SHPLG-S#221667#1.Relay0.Power.json: shelly.0.SHPLG-S#221667#1.Relay0.Power
                                          Day 20230204 - history.shelly.0.SHPLG-S#D9DB12#1.Relay0.Power.json
                                          Check: 20230204 / pos 112
                                             Ignore existing ID history.shelly.0.SHPLG-S#D9DB12#1.Relay0.Power.json: shelly.0.SHPLG-S#D9DB12#1.Relay0.Power
                                          Day 20230204 - history.smartmeter.0.1-0~16_7_0__255.value.json
                                             Ignore ID history.smartmeter.0.1-0~16_7_0__255.value.json: smartmeter.0.1-0~16_7_0__255.value
                                          Day 20230204 - history.smartmeter.0.1-0~1_8_0__255.value.json
                                             Ignore ID history.smartmeter.0.1-0~1_8_0__255.value.json: smartmeter.0.1-0~1_8_0__255.value
                                          Day 20230204 - history.smartmeter.1.1-0~16_7_0__255.value.json
                                             Ignore ID history.smartmeter.1.1-0~16_7_0__255.value.json: smartmeter.1.1-0~16_7_0__255.value
                                          Day 20230204 - history.smartmeter.1.1-0~1_8_0__255.value.json
                                             Ignore ID history.smartmeter.1.1-0~1_8_0__255.value.json: smartmeter.1.1-0~1_8_0__255.value
                                          Day 20230204 - history.stiebel-isg.0.Info.ANLAGE.HEIZEN.AUSSENTEMPERATUR.json
                                             Ignore existing ID history.stiebel-isg.0.Info.ANLAGE.HEIZEN.AUSSENTEMPERATUR.json: stiebel-isg.0.Info.ANLAGE.HEIZEN.AUSSENTEMPERATUR
                                          Day 20230204 - history.zigbee.0.00124b002510816a.humidity.json
                                          Check: 20230204 / pos 114
                                             Ignore existing ID history.zigbee.0.00124b002510816a.humidity.json: zigbee.0.00124b002510816a.humidity
                                          Day 20230204 - history.zigbee.0.00124b002510816a.temperature.json
                                             Ignore existing ID history.zigbee.0.00124b002510816a.temperature.json: zigbee.0.00124b002510816a.temperature
                                          Day 20230204 - history.zigbee.0.00124b0025138250.humidity.json
                                             Ignore existing ID history.zigbee.0.00124b0025138250.humidity.json: zigbee.0.00124b0025138250.humidity
                                          Day 20230204 - history.zigbee.0.00124b0025138250.temperature.json
                                             Ignore existing ID history.zigbee.0.00124b0025138250.temperature.json: zigbee.0.00124b0025138250.temperature
                                          Day 20230204 - history.zigbee.0.00124b002513845c.humidity.json
                                             Ignore existing ID history.zigbee.0.00124b002513845c.humidity.json: zigbee.0.00124b002513845c.humidity
                                          Day 20230204 - history.zigbee.0.00124b002513845c.temperature.json
                                             Ignore existing ID history.zigbee.0.00124b002513845c.temperature.json: zigbee.0.00124b002513845c.temperature
                                          Day 20230204 - history.zigbee.0.00124b002549ddea.humidity.json
                                             Ignore existing ID history.zigbee.0.00124b002549ddea.humidity.json: zigbee.0.00124b002549ddea.humidity
                                          Day 20230204 - history.zigbee.0.00124b002549ddea.temperature.json
                                             Ignore existing ID history.zigbee.0.00124b002549ddea.temperature.json: zigbee.0.00124b002549ddea.temperature
                                          Day end
                                          Day 20230203 - history.0_userdata.0.Datenpunkte.Smartphones.A52.akkustand_a52.json
                                          Check: 20230203 / pos 84
                                          Day 20230203 - history.0_userdata.0.Datenpunkte.Smartphones.S21_Daniel.akkustand.json
                                          Check: 20230203 / pos 108
                                          Day 20230203 - history.0_userdata.0.Stromzähler_Haushalt.Day.json
                                          Check: 20230203 / pos 76
                                             Ignore existing ID history.0_userdata.0.Stromzähler_Haushalt.Day.json: 0_userdata.0.Stromzähler_Haushalt.Day
                                          Day 20230203 - history.0_userdata.0.Stromzähler_Haushalt.Hour.json
                                          Day 20230203 - history.0_userdata.0.Stromzähler_Wärme.Day.json
                                             Ignore existing ID history.0_userdata.0.Stromzähler_Wärme.Day.json: 0_userdata.0.Stromzähler_Wärme.Day
                                          Day 20230203 - history.0_userdata.0.Stromzähler_Wärme.Hour.json
                                          Day 20230203 - history.daswetter.1.NextHours.Location_1.Day_1.current.symbol_desc.json
                                          Day 20230203 - history.fb-checkpresence.0.Elisabeth.json
                                          Check: 20230203 / pos 112
                                          Day 20230203 - history.fb-checkpresence.0.Galaxy-A52s-5G.json
                                          Check: 20230203 / pos 73
                                             Ignore existing ID history.fb-checkpresence.0.Galaxy-A52s-5G.json: fb-checkpresence.0.Galaxy-A52s-5G
                                          Day 20230203 - history.fb-checkpresence.0.S21-von-Daniel.json
                                          Check: 20230203 / pos 113
                                             Ignore existing ID history.fb-checkpresence.0.S21-von-Daniel.json: fb-checkpresence.0.S21-von-Daniel
                                          Day 20230203 - history.hm-rpc.1.000A9F298FCC7E.1.ACTUAL_TEMPERATURE.json
                                          Check: 20230203 / pos 58
                                          Day 20230203 - history.hm-rpc.1.000A9F298FCC7E.1.HUMIDITY.json
                                          Day 20230203 - history.hm-rpc.1.000A9F298FCCA1.1.ACTUAL_TEMPERATURE.json
                                          Check: 20230203 / pos 71
                                          Day 20230203 - history.hm-rpc.1.000A9F298FCCA1.1.HUMIDITY.json
                                          Day 20230203 - history.hm-rpc.1.000E9D89BB7599.1.ACTUAL_TEMPERATURE.json
                                          Day 20230203 - history.hm-rpc.1.000E9D89BB7599.1.HUMIDITY.json
                                          Day 20230203 - history.hm-rpc.1.000E9D89BB75F0.1.ACTUAL_TEMPERATURE.json
                                          Day 20230203 - history.hm-rpc.1.000E9D89BB75F0.1.HUMIDITY.json
                                          Day 20230203 - history.hm-rpc.1.000E9D89BB7A94.1.ACTUAL_TEMPERATURE.json
                                          Check: 20230203 / pos 56
                                          Day 20230203 - history.hm-rpc.1.000E9D89BB7A94.1.HUMIDITY.json
                                          Day 20230203 - history.hm-rpc.1.000E9D89BB7A99.1.ACTUAL_TEMPERATURE.json
                                          Day 20230203 - history.hm-rpc.1.000E9D89BB7A99.1.HUMIDITY.json
                                          Day 20230203 - history.hm-rpc.1.0010DD89A2D19F.1.ACTUAL_TEMPERATURE.json
                                          Day 20230203 - history.hm-rpc.1.0010DD89A2D19F.1.HUMIDITY.json
                                          Day 20230203 - history.hm-rpc.1.001B9F29967090.1.LEVEL.json
                                          Check: 20230203 / pos 23
                                          Day 20230203 - history.hm-rpc.1.001B9F29967090.3.LEVEL.json
                                          Day 20230203 - history.hm-rpc.1.001B9F29967090.5.LEVEL.json
                                          Day 20230203 - history.hm-rpc.1.001B9F29967090.7.LEVEL.json
                                          Day 20230203 - history.hm-rpc.1.001B9F29967090.8.LEVEL.json
                                          Day 20230203 - history.hmip.0.devices.3014F711A0000C9D899EBE47.channels.1.actualTemperature.json
                                          Check: 20230203 / pos 114
                                          Day 20230203 - history.hmip.0.devices.3014F711A0000C9D899EBE47.channels.1.humidity.json
                                          Day 20230203 - history.shelly.0.SHPLG-S#221667#1.Relay0.Power.json
                                          Day 20230203 - history.shelly.0.SHPLG-S#D9DB12#1.Relay0.Power.json
                                          Check: 20230203 / pos 111
                                          Day 20230203 - history.smartmeter.0.1-0~16_7_0__255.value.json
                                          Day 20230203 - history.smartmeter.0.1-0~1_8_0__255.value.json
                                          Day 20230203 - history.smartmeter.1.1-0~16_7_0__255.value.json
                                          Day 20230203 - history.smartmeter.1.1-0~1_8_0__255.value.json
                                          Day 20230203 - history.stiebel-isg.0.Info.ANLAGE.HEIZEN.AUSSENTEMPERATUR.json
                                          Day 20230203 - history.zigbee.0.00124b002510816a.humidity.json
                                          Day 20230203 - history.zigbee.0.00124b002510816a.temperature.json
                                          Day 20230203 - history.zigbee.0.00124b0025138250.humidity.json
                                          Day 20230203 - history.zigbee.0.00124b0025138250.temperature.json
                                          Day 20230203 - history.zigbee.0.00124b002513845c.humidity.json
                                          Day 20230203 - history.zigbee.0.00124b002513845c.temperature.json
                                          Day 20230203 - history.zigbee.0.00124b002549ddea.humidity.json
                                          Day 20230203 - history.zigbee.0.00124b002549ddea.temperature.json
                                          Day end
                                          Day 20230202 - history.0_userdata.0.Datenpunkte.Smartphones.A52.akkustand_a52.json
                                          Check: 20230202 / pos 83
                                          Day 20230202 - history.0_userdata.0.Datenpunkte.Smartphones.S21_Daniel.akkustand.json
                                          Check: 20230202 / pos 107
                                          Day 20230202 - history.0_userdata.0.Stromzähler_Haushalt.Day.json
                                          Check: 20230202 / pos 75
                                          Day 20230202 - history.0_userdata.0.Stromzähler_Haushalt.Hour.json
                                          Day 20230202 - history.0_userdata.0.Stromzähler_Haushalt.Month.json
                                          Check: 20230202 / pos 9
                                             Ignore existing ID history.0_userdata.0.Stromzähler_Haushalt.Month.json: 0_userdata.0.Stromzähler_Haushalt.Month
                                          Day 20230202 - history.0_userdata.0.Stromzähler_Haushalt.Week.json
                                          Check: 20230202 / pos 17
                                             Ignore existing ID history.0_userdata.0.Stromzähler_Haushalt.Week.json: 0_userdata.0.Stromzähler_Haushalt.Week
                                          Day 20230202 - history.0_userdata.0.Stromzähler_Wärme.Day.json
                                          Day 20230202 - history.0_userdata.0.Stromzähler_Wärme.Hour.json
                                          Day 20230202 - history.0_userdata.0.Stromzähler_Wärme.Month.json
                                             Ignore existing ID history.0_userdata.0.Stromzähler_Wärme.Month.json: 0_userdata.0.Stromzähler_Wärme.Month
                                          Day 20230202 - history.0_userdata.0.Stromzähler_Wärme.Week.json
                                             Ignore existing ID history.0_userdata.0.Stromzähler_Wärme.Week.json: 0_userdata.0.Stromzähler_Wärme.Week
                                          Day 20230202 - history.daswetter.1.NextHours.Location_1.Day_1.current.clouds_value.json
                                          Day 20230202 - history.daswetter.1.NextHours.Location_1.Day_1.current.symbol_desc.json
                                          Day 20230202 - history.fb-checkpresence.0.A41-von-Daniel.json
                                             Ignore ID history.fb-checkpresence.0.A41-von-Daniel.json: fb-checkpresence.0.A41-von-Daniel
                                          Day 20230202 - history.fb-checkpresence.0.Elisabeth.json
                                          Check: 20230202 / pos 111
                                          Day 20230202 - history.fb-checkpresence.0.Galaxy-A52s-5G.json
                                          Check: 20230202 / pos 72
                                          Day 20230202 - history.fb-checkpresence.0.S21-von-Daniel.json
                                          Check: 20230202 / pos 112
                                          Day 20230202 - history.hm-rpc.1.000A9F298FCC7E.1.ACTUAL_TEMPERATURE.json
                                          Check: 20230202 / pos 57
                                          Day 20230202 - history.hm-rpc.1.000A9F298FCC7E.1.HUMIDITY.json
                                          Day 20230202 - history.hm-rpc.1.000A9F298FCCA1.1.ACTUAL_TEMPERATURE.json
                                          Check: 20230202 / pos 70
                                          Day 20230202 - history.hm-rpc.1.000A9F298FCCA1.1.HUMIDITY.json
                                          Day 20230202 - history.hm-rpc.1.000E9D89BB7599.1.ACTUAL_TEMPERATURE.json
                                          Day 20230202 - history.hm-rpc.1.000E9D89BB7599.1.HUMIDITY.json
                                          Day 20230202 - history.hm-rpc.1.000E9D89BB75F0.1.ACTUAL_TEMPERATURE.json
                                          Day 20230202 - history.hm-rpc.1.000E9D89BB75F0.1.HUMIDITY.json
                                          Day 20230202 - history.hm-rpc.1.000E9D89BB7A94.1.ACTUAL_TEMPERATURE.json
                                          Check: 20230202 / pos 55
                                          Day 20230202 - history.hm-rpc.1.000E9D89BB7A94.1.HUMIDITY.json
                                          Day 20230202 - history.hm-rpc.1.000E9D89BB7A99.1.ACTUAL_TEMPERATURE.json
                                          Day 20230202 - history.hm-rpc.1.000E9D89BB7A99.1.HUMIDITY.json
                                          Day 20230202 - history.hm-rpc.1.0010DD89A2D19F.1.ACTUAL_TEMPERATURE.json
                                          Check: 20230202 / pos 6
                                          Day 20230202 - history.hm-rpc.1.0010DD89A2D19F.1.HUMIDITY.json
                                          Day 20230202 - history.hm-rpc.1.001B9F29967090.1.LEVEL.json
                                          Check: 20230202 / pos 22
                                          Day 20230202 - history.hm-rpc.1.001B9F29967090.3.LEVEL.json
                                          Day 20230202 - history.hm-rpc.1.001B9F29967090.5.LEVEL.json
                                          Day 20230202 - history.hm-rpc.1.001B9F29967090.7.LEVEL.json
                                          Day 20230202 - history.hm-rpc.1.001B9F29967090.8.LEVEL.json
                                          Day 20230202 - history.hmip.0.devices.3014F711A00003DA4996421B.channels.0.unreach.json
                                             Ignore ID history.hmip.0.devices.3014F711A00003DA4996421B.channels.0.unreach.json: hmip.0.devices.3014F711A00003DA4996421B.channels.0.unreach
                                          Day 20230202 - history.hmip.0.devices.3014F711A0000C9D899EBE47.channels.1.actualTemperature.json
                                          Check: 20230202 / pos 113
                                          Day 20230202 - history.hmip.0.devices.3014F711A0000C9D899EBE47.channels.1.humidity.json
                                          Day 20230202 - history.hmip.0.homes.441515ac-c1bd-4999-9b66-7cad5446def4.weather.weatherCondition.json
                                             Ignore ID history.hmip.0.homes.441515ac-c1bd-4999-9b66-7cad5446def4.weather.weatherCondition.json: hmip.0.homes.441515ac-c1bd-4999-9b66-7cad5446def4.weather.weatherCondition
                                          Day 20230202 - history.shelly.0.SHPLG-S#221667#1.Relay0.Power.json
                                          Day 20230202 - history.shelly.0.SHPLG-S#D9DB12#1.Relay0.Power.json
                                          Check: 20230202 / pos 110
                                          Day 20230202 - history.smartmeter.0.1-0~16_7_0__255.value.json
                                          Day 20230202 - history.smartmeter.0.1-0~1_8_0__255.value.json
                                          Day 20230202 - history.smartmeter.1.1-0~16_7_0__255.value.json
                                          Day 20230202 - history.smartmeter.1.1-0~1_8_0__255.value.json
                                          Day 20230202 - history.stiebel-isg.0.Einstellungen.HEIZEN.GRUNDEINSTELLUNG.val134.json
                                          Check: 20230202 / pos 3
                                             Ignore existing ID history.stiebel-isg.0.Einstellungen.HEIZEN.GRUNDEINSTELLUNG.val134.json: stiebel-isg.0.Einstellungen.HEIZEN.GRUNDEINSTELLUNG.val134
                                          Day 20230202 - history.stiebel-isg.0.Info.ANLAGE.HEIZEN.AUSSENTEMPERATUR.json
                                          Day 20230202 - history.zigbee.0.00124b002510816a.humidity.json
                                          Day 20230202 - history.zigbee.0.00124b002510816a.temperature.json
                                          Day 20230202 - history.zigbee.0.00124b0025138250.humidity.json
                                          Day 20230202 - history.zigbee.0.00124b0025138250.temperature.json
                                          Day 20230202 - history.zigbee.0.00124b002513845c.humidity.json
                                          Day 20230202 - history.zigbee.0.00124b002513845c.temperature.json
                                          Day 20230202 - history.zigbee.0.00124b002549ddea.humidity.json
                                          Day 20230202 - history.zigbee.0.00124b002549ddea.temperature.json
                                          Day end
                                          Day 20230201 - history.0_userdata.0.Datenpunkte.Smartphones.A52.akkustand_a52.json
                                          Check: 20230201 / pos 82
                                          Day 20230201 - history.0_userdata.0.Datenpunkte.Smartphones.S21_Daniel.akkustand.json
                                          Check: 20230201 / pos 106
                                          Day 20230201 - history.0_userdata.0.Stromzähler_Haushalt.Day.json
                                          Check: 20230201 / pos 74
                                          Day 20230201 - history.0_userdata.0.Stromzähler_Haushalt.Hour.json
                                          Day 20230201 - history.0_userdata.0.Stromzähler_Haushalt.Month.json
                                          Day 20230201 - history.0_userdata.0.Stromzähler_Wärme.Day.json
                                          Day 20230201 - history.0_userdata.0.Stromzähler_Wärme.Hour.json
                                          Day 20230201 - history.0_userdata.0.Stromzähler_Wärme.Month.json
                                          Day 20230201 - history.daswetter.1.NextHours.Location_1.Day_1.current.clouds_value.json
                                          Day 20230201 - history.daswetter.1.NextHours.Location_1.Day_1.current.symbol_desc.json
                                          Day 20230201 - history.fb-checkpresence.0.Elisabeth.json
                                          Check: 20230201 / pos 110
                                          Day 20230201 - history.fb-checkpresence.0.Galaxy-A52s-5G.json
                                          Check: 20230201 / pos 71
                                          Day 20230201 - history.fb-checkpresence.0.S21-von-Daniel.json
                                          Check: 20230201 / pos 111
                                          Day 20230201 - history.hm-rpc.1.000A9F298FCC7E.1.ACTUAL_TEMPERATURE.json
                                          Check: 20230201 / pos 56
                                          Day 20230201 - history.hm-rpc.1.000A9F298FCC7E.1.HUMIDITY.json
                                          Day 20230201 - history.hm-rpc.1.000A9F298FCCA1.1.ACTUAL_TEMPERATURE.json
                                          Check: 20230201 / pos 69
                                          Day 20230201 - history.hm-rpc.1.000A9F298FCCA1.1.HUMIDITY.json
                                          Day 20230201 - history.hm-rpc.1.000E9D89BB7599.1.ACTUAL_TEMPERATURE.json
                                          Day 20230201 - history.hm-rpc.1.000E9D89BB7599.1.HUMIDITY.json
                                          Day 20230201 - history.hm-rpc.1.000E9D89BB75F0.1.ACTUAL_TEMPERATURE.json
                                          Day 20230201 - history.hm-rpc.1.000E9D89BB75F0.1.HUMIDITY.json
                                          Day 20230201 - history.hm-rpc.1.000E9D89BB7A94.1.ACTUAL_TEMPERATURE.json
                                          Check: 20230201 / pos 54
                                          Day 20230201 - history.hm-rpc.1.000E9D89BB7A94.1.HUMIDITY.json
                                          Day 20230201 - history.hm-rpc.1.000E9D89BB7A99.1.ACTUAL_TEMPERATURE.json
                                          Day 20230201 - history.hm-rpc.1.000E9D89BB7A99.1.HUMIDITY.json
                                          Day 20230201 - history.hm-rpc.1.0010DD89A2D19F.1.ACTUAL_TEMPERATURE.json
                                          Day 20230201 - history.hm-rpc.1.0010DD89A2D19F.1.HUMIDITY.json
                                          Day 20230201 - history.hm-rpc.1.001B9F29967090.1.LEVEL.json
                                          Check: 20230201 / pos 21
                                          Day 20230201 - history.hm-rpc.1.001B9F29967090.3.LEVEL.json
                                          Day 20230201 - history.hm-rpc.1.001B9F29967090.5.LEVEL.json
                                          Day 20230201 - history.hm-rpc.1.001B9F29967090.7.LEVEL.json
                                          Day 20230201 - history.hm-rpc.1.001B9F29967090.8.LEVEL.json
                                          Day 20230201 - history.hmip.0.devices.3014F711A0000C9D899EBE47.channels.1.actualTemperature.json
                                          Check: 20230201 / pos 112
                                          Day 20230201 - history.hmip.0.devices.3014F711A0000C9D899EBE47.channels.1.humidity.json
                                          Day 20230201 - history.hmip.0.homes.441515ac-c1bd-4999-9b66-7cad5446def4.weather.weatherCondition.json
                                          Day 20230201 - history.shelly.0.SHPLG-S#221667#1.Relay0.Power.json
                                          Day 20230201 - history.shelly.0.SHPLG-S#D9DB12#1.Relay0.Power.json
                                          Check: 20230201 / pos 109
                                          Day 20230201 - history.smartmeter.0.1-0~16_7_0__255.value.json
                                          Day 20230201 - history.smartmeter.0.1-0~1_8_0__255.value.json
                                          Day 20230201 - history.smartmeter.1.1-0~16_7_0__255.value.json
                                          Day 20230201 - history.smartmeter.1.1-0~1_8_0__255.value.json
                                          Day 20230201 - history.stiebel-isg.0.Info.ANLAGE.HEIZEN.AUSSENTEMPERATUR.json
                                          Day 20230201 - history.zigbee.0.00124b002510816a.humidity.json
                                          Day 20230201 - history.zigbee.0.00124b002510816a.temperature.json
                                          Day 20230201 - history.zigbee.0.00124b0025138250.humidity.json
                                          Day 20230201 - history.zigbee.0.00124b0025138250.temperature.json
                                          Day 20230201 - history.zigbee.0.00124b002513845c.humidity.json
                                          Day 20230201 - history.zigbee.0.00124b002513845c.temperature.json
                                          Day 20230201 - history.zigbee.0.00124b002549ddea.humidity.json
                                          Day 20230201 - history.zigbee.0.00124b002549ddea.temperature.json
                                          Day end
                                          Day 20230131 - history.0_userdata.0.Datenpunkte.Smartphones.A52.akkustand_a52.json
                                          Check: 20230131 / pos 81
                                          Day 20230131 - history.0_userdata.0.Datenpunkte.Smartphones.S21_Daniel.akkustand.json
                                          Check: 20230131 / pos 105
                                          Day 20230131 - history.0_userdata.0.Stromzähler_Haushalt.Day.json
                                          Check: 20230131 / pos 73
                                          Day 20230131 - history.0_userdata.0.Stromzähler_Haushalt.Hour.json
                                          Day 20230131 - history.0_userdata.0.Stromzähler_Wärme.Day.json
                                          Day 20230131 - history.0_userdata.0.Stromzähler_Wärme.Hour.json
                                          Day 20230131 - history.daswetter.1.NextHours.Location_1.Day_1.current.clouds_value.json
                                          Day 20230131 - history.daswetter.1.NextHours.Location_1.Day_1.current.symbol_desc.json
                                          Day 20230131 - history.fb-checkpresence.0.Elisabeth.json
                                          Check: 20230131 / pos 109
                                          Day 20230131 - history.fb-checkpresence.0.Galaxy-A52s-5G.json
                                          Check: 20230131 / pos 70
                                          Day 20230131 - history.fb-checkpresence.0.S21-von-Daniel.json
                                          Check: 20230131 / pos 110
                                          Day 20230131 - history.hm-rpc.1.000A9F298FCC7E.1.ACTUAL_TEMPERATURE.json
                                          Check: 20230131 / pos 55
                                          Day 20230131 - history.hm-rpc.1.000A9F298FCC7E.1.HUMIDITY.json
                                          Day 20230131 - history.hm-rpc.1.000A9F298FCCA1.1.ACTUAL_TEMPERATURE.json
                                          Check: 20230131 / pos 68
                                          Day 20230131 - history.hm-rpc.1.000A9F298FCCA1.1.HUMIDITY.json
                                          Day 20230131 - history.hm-rpc.1.000E9D89BB7599.1.ACTUAL_TEMPERATURE.json
                                          Day 20230131 - history.hm-rpc.1.000E9D89BB7599.1.HUMIDITY.json
                                          Day 20230131 - history.hm-rpc.1.000E9D89BB75F0.1.ACTUAL_TEMPERATURE.json
                                          Day 20230131 - history.hm-rpc.1.000E9D89BB75F0.1.HUMIDITY.json
                                          Day 20230131 - history.hm-rpc.1.000E9D89BB7A94.1.ACTUAL_TEMPERATURE.json
                                          Check: 20230131 / pos 53
                                          Day 20230131 - history.hm-rpc.1.000E9D89BB7A94.1.HUMIDITY.json
                                          Day 20230131 - history.hm-rpc.1.000E9D89BB7A99.1.ACTUAL_TEMPERATURE.json
                                          Day 20230131 - history.hm-rpc.1.000E9D89BB7A99.1.HUMIDITY.json
                                          Day 20230131 - history.hm-rpc.1.0010DD89A2D19F.1.ACTUAL_TEMPERATURE.json
                                          Check: 20230131 / pos 4
                                          Day 20230131 - history.hm-rpc.1.0010DD89A2D19F.1.HUMIDITY.json
                                          Day 20230131 - history.hm-rpc.1.001B9F29967090.1.LEVEL.json
                                          Check: 20230131 / pos 20
                                          Day 20230131 - history.hm-rpc.1.001B9F29967090.3.LEVEL.json
                                          Day 20230131 - history.hm-rpc.1.001B9F29967090.5.LEVEL.json
                                          Day 20230131 - history.hm-rpc.1.001B9F29967090.7.LEVEL.json
                                          Day 20230131 - history.hm-rpc.1.001B9F29967090.8.LEVEL.json
                                          Day 20230131 - history.hmip.0.devices.3014F711A00003DA4996421B.channels.0.unreach.json
                                          Day 20230131 - history.hmip.0.devices.3014F711A0000C9D899EBE47.channels.1.actualTemperature.json
                                          Check: 20230131 / pos 111
                                          Day 20230131 - history.hmip.0.devices.3014F711A0000C9D899EBE47.channels.1.humidity.json
                                          Day 20230131 - history.hmip.0.homes.441515ac-c1bd-4999-9b66-7cad5446def4.weather.weatherCondition.json
                                          Day 20230131 - history.shelly.0.SHPLG-S#221667#1.Relay0.Power.json
                                          Day 20230131 - history.shelly.0.SHPLG-S#D9DB12#1.Relay0.Power.json
                                          Check: 20230131 / pos 108
                                          Day 20230131 - history.smartmeter.0.1-0~16_7_0__255.value.json
                                          Day 20230131 - history.smartmeter.0.1-0~1_8_0__255.value.json
                                          Day 20230131 - history.smartmeter.1.1-0~16_7_0__255.value.json
                                          Day 20230131 - history.smartmeter.1.1-0~1_8_0__255.value.json
                                          Day 20230131 - history.stiebel-isg.0.Info.ANLAGE.HEIZEN.AUSSENTEMPERATUR.json
                                          Day 20230131 - history.zigbee.0.00124b002510816a.humidity.json
                                          Day 20230131 - history.zigbee.0.00124b002510816a.temperature.json
                                          Day 20230131 - history.zigbee.0.00124b0025138250.humidity.json
                                          Day 20230131 - history.zigbee.0.00124b0025138250.temperature.json
                                          Day 20230131 - history.zigbee.0.00124b002513845c.humidity.json
                                          Day 20230131 - history.zigbee.0.00124b002513845c.temperature.json
                                          Day 20230131 - history.zigbee.0.00124b002549ddea.humidity.json
                                          Day 20230131 - history.zigbee.0.00124b002549ddea.temperature.json
                                          Day end
                                          Day 20230130 - history.0_userdata.0.Datenpunkte.Smartphones.A52.akkustand_a52.json
                                          Check: 20230130 / pos 80
                                          Day 20230130 - history.0_userdata.0.Datenpunkte.Smartphones.S21_Daniel.akkustand.json
                                          Check: 20230130 / pos 104
                                          Day 20230130 - history.0_userdata.0.Stromzähler_Haushalt.Day.json
                                          Check: 20230130 / pos 72
                                          Day 20230130 - history.0_userdata.0.Stromzähler_Haushalt.Hour.json
                                          Day 20230130 - history.0_userdata.0.Stromzähler_Haushalt.Week.json
                                          Check: 20230130 / pos 18
                                          Day 20230130 - history.0_userdata.0.Stromzähler_Wärme.Day.json
                                          Day 20230130 - history.0_userdata.0.Stromzähler_Wärme.Hour.json
                                          Day 20230130 - history.0_userdata.0.Stromzähler_Wärme.Week.json
                                          Day 20230130 - history.daswetter.1.NextHours.Location_1.Day_1.current.clouds_value.json
                                          Day 20230130 - history.daswetter.1.NextHours.Location_1.Day_1.current.symbol_desc.json
                                          Day 20230130 - history.fb-checkpresence.0.Elisabeth.json
                                          Check: 20230130 / pos 108
                                          Day 20230130 - history.fb-checkpresence.0.Galaxy-A52s-5G.json
                                          Check: 20230130 / pos 69
                                          Day 20230130 - history.fb-checkpresence.0.S21-von-Daniel.json
                                          Check: 20230130 / pos 109
                                          Day 20230130 - history.hm-rpc.1.000A9F298FCC7E.1.ACTUAL_TEMPERATURE.json
                                          Check: 20230130 / pos 54
                                          Day 20230130 - history.hm-rpc.1.000A9F298FCC7E.1.HUMIDITY.json
                                          Day 20230130 - history.hm-rpc.1.000A9F298FCCA1.1.ACTUAL_TEMPERATURE.json
                                          Check: 20230130 / pos 67
                                          Day 20230130 - history.hm-rpc.1.000A9F298FCCA1.1.HUMIDITY.json
                                          Day 20230130 - history.hm-rpc.1.000E9D89BB7599.1.ACTUAL_TEMPERATURE.json
                                          Day 20230130 - history.hm-rpc.1.000E9D89BB7599.1.HUMIDITY.json
                                          Day 20230130 - history.hm-rpc.1.000E9D89BB75F0.1.ACTUAL_TEMPERATURE.json
                                          Day 20230130 - history.hm-rpc.1.000E9D89BB75F0.1.HUMIDITY.json
                                          Day 20230130 - history.hm-rpc.1.000E9D89BB7A94.1.ACTUAL_TEMPERATURE.json
                                          Check: 20230130 / pos 52
                                          Day 20230130 - history.hm-rpc.1.000E9D89BB7A94.1.HUMIDITY.json
                                          Day 20230130 - history.hm-rpc.1.000E9D89BB7A99.1.ACTUAL_TEMPERATURE.json
                                          Day 20230130 - history.hm-rpc.1.000E9D89BB7A99.1.HUMIDITY.json
                                          Day 20230130 - history.hm-rpc.1.0010DD89A2D19F.1.ACTUAL_TEMPERATURE.json
                                          Check: 20230130 / pos 3
                                          Day 20230130 - history.hm-rpc.1.0010DD89A2D19F.1.HUMIDITY.json
                                          Day 20230130 - history.hm-rpc.1.001B9F29967090.1.LEVEL.json
                                          Check: 20230130 / pos 19
                                          Day 20230130 - history.hm-rpc.1.001B9F29967090.3.LEVEL.json
                                          Day 20230130 - history.hm-rpc.1.001B9F29967090.5.LEVEL.json
                                          Day 20230130 - history.hm-rpc.1.001B9F29967090.7.LEVEL.json
                                          Day 20230130 - history.hm-rpc.1.001B9F29967090.8.LEVEL.json
                                          Day 20230130 - history.hmip.0.devices.3014F711A00003DA4996421B.channels.0.unreach.json
                                          Day 20230130 - history.hmip.0.devices.3014F711A0000C9D899EBE47.channels.1.actualTemperature.json
                                          Check: 20230130 / pos 110
                                          Day 20230130 - history.hmip.0.devices.3014F711A0000C9D899EBE47.channels.1.humidity.json
                                          Day 20230130 - history.hmip.0.homes.441515ac-c1bd-4999-9b66-7cad5446def4.weather.weatherCondition.json
                                          Day 20230130 - history.shelly.0.SHPLG-S#221667#1.Relay0.Power.json
                                          Day 20230130 - history.shelly.0.SHPLG-S#D9DB12#1.Relay0.Power.json
                                          Check: 20230130 / pos 107
                                          Day 20230130 - history.smartmeter.0.1-0~16_7_0__255.value.json
                                          Day 20230130 - history.smartmeter.0.1-0~1_8_0__255.value.json
                                          Day 20230130 - history.smartmeter.1.1-0~16_7_0__255.value.json
                                          Day 20230130 - history.smartmeter.1.1-0~1_8_0__255.value.json
                                          Day 20230130 - history.stiebel-isg.0.Info.ANLAGE.HEIZEN.AUSSENTEMPERATUR.json
                                          Day 20230130 - history.zigbee.0.00124b002510816a.humidity.json
                                          Day 20230130 - history.zigbee.0.00124b002510816a.temperature.json
                                          Day 20230130 - history.zigbee.0.00124b0025138250.humidity.json
                                          Day 20230130 - history.zigbee.0.00124b0025138250.temperature.json
                                          Day 20230130 - history.zigbee.0.00124b002513845c.humidity.json
                                          Day 20230130 - history.zigbee.0.00124b002513845c.temperature.json
                                          Day 20230130 - history.zigbee.0.00124b002549ddea.humidity.json
                                          Day 20230130 - history.zigbee.0.00124b002549ddea.temperature.json
                                          Day end
                                          Day end
                                          DONE
