  3. Off Topic
  4. Proxmox
  5. Brauche Hilfe bei proxmox v6 zu v7
    2.7k
    4.8k
    4.0k
Geplant Angeheftet Gesperrt Verschoben Proxmox
83 Beiträge 5 Kommentatoren 14.0k Aufrufe 5 Beobachtet
  • FeuersturmF Feuersturm
    @crunchip
    root@pve:/etc/apt# cat sources.list
    deb http://ftp.de.debian.org/debian bullseye main contrib
    deb http://ftp.de.debian.org/debian bullseye-updates main contrib
    # security updates
    #deb http://security.debian.org/debian-security/ bullseye-security main contrib
    deb http://deb.debian.org/debian-security/ bullseye-security main contrib
    und
    root@pve:/etc/apt/sources.list.d# ls
    pve-enterprise.list  pve-enterprise.list.dpkg-new  pve-no-subscription.list
    root@pve:/etc/apt/sources.list.d# cat pve-no-subscription.list
    # PVE pve-no-subscription repository provided by proxmox.com,
    # NOT recommended for production use
    deb http://download.proxmox.com/debian/pve bullseye pve-no-subscription
    # security updates
    #deb http://security.debian.org/debian-security bullseye/updates main contrib
    crunchipC Abwesend
    crunchipC Abwesend
    @feuersturm klatch doch mal die non-free mit in die sources.list, ob dann was neues kommt
    #non-free
    deb http://deb.debian.org/debian bullseye main contrib non-free
    deb-src http://deb.debian.org/debian bullseye main contrib non-free
    deb http://deb.debian.org/debian-security/ bullseye-security main contrib non-free
    deb-src http://deb.debian.org/debian-security/ bullseye-security main contrib non-free
    deb http://deb.debian.org/debian bullseye-updates main contrib non-free
    deb-src http://deb.debian.org/debian bullseye-updates main contrib non-free
      #non-free
      FeuersturmF Offline
      FeuersturmF Offline
      Feuersturm
      @crunchip non-free hinzugefügt und Neustart vom Server gemacht
      Leider keine Besserung
      root@pve:~# cat /etc/apt/sources.list
      deb http://ftp.de.debian.org/debian bullseye main contrib non-free
      deb http://ftp.de.debian.org/debian bullseye-updates main contrib non-free
      # security updates
      root@pve:~# apt update
      Hit:1 http://download.proxmox.com/debian/pve bullseye InRelease
      Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
      Hit:3 http://ftp.de.debian.org/debian bullseye InRelease
      Hit:4 http://ftp.de.debian.org/debian bullseye-updates InRelease
      Reading package lists... Done
      All packages are up to date.
        # security updates
        crunchipC Abwesend
        crunchipC Abwesend
        @feuersturm ähm warte mal, da steht ja schon bullseye drin.
        eigentlich müsste es ja noch buster lauten, vor dem upgrade auf v7
          FeuersturmF Offline
          FeuersturmF Offline
          Feuersturm
          @crunchip Vorher war alles auf Buster (proxmox war auf 6.4.x). Hab dann nach dieser Anleitung https://pve.proxmox.com/wiki/Upgrade_from_6.x_to_7.0 die sources auf bullseye umgestellt und das apt dist-upgrade dann gestartet. Dabei ist er dann bei den oben genannten 58% stehen geblieben. Als ich dann den Server an den Monitor angeschlossen habe ist er wie oben beschrieben hier stehen geblieben
          Loading Linux 5.15.83-1-pve ...
            crunchipC Abwesend
            crunchipC Abwesend
            @feuersturm ja das hab ich schon verstanden. ich war/bin nur gerade etwas irritiert, weil es ja nicht durchlief., dachte ich das eventuell buster noch drin steht.
            oder du probierst es mit
            apt -f install
            aber wie gesagt, ich weiss nicht ob der kernel das Problem ist, bin da leider auch nicht so fit drin
            ich hatte erst vor 3 Tage ein upgrade gemacht, daher bin ich aktuell bei 5.15.74-1, ein erneutes upgrade auf den 5.15.83-1 steh bei mir noch aus
              apt -f install
              FeuersturmF Offline
              FeuersturmF Offline
              Feuersturm
              @crunchip
              Bevor ich apt -f install aufrufen konnte sagte das System, dass ich dpkg --configure -a aufrufen muss. Dies ist dann einmal durchgelaufen und das System ist danach auch wieder sauber mit dem Kernel 5.15.83-1 gestartet :-)
              Ich hab dann noch einmal ein apt -f install aufgerufen welches auch durchgelaufen ist.
              Es scheint jetzt besser zu sein. Die Ausgabe von pveversion sieht jetzt auch anders aus als vorher.
              Danke für deine Hilfe @crunchip
              Linux pve 5.15.83-1-pve #1 SMP PVE 5.15.83-1 (2022-12-15T00:00Z) x86_64
              permitted by applicable law.
              Last login: Sat Dec 24 01:20:39 2022
              root@pve:~# pveversion --verbose
              proxmox-ve: 7.3-1 (running kernel: 5.15.83-1-pve)
              pve-manager: 7.3-4 (running version: 7.3-4/d69b70d4)
              pve-kernel-5.15: 7.3-1
              pve-kernel-helper: 7.3-1
              pve-kernel-5.4: 6.4-20
              pve-kernel-5.3: 6.1-6
              pve-kernel-5.15.83-1-pve: 5.15.83-1
              pve-kernel-5.4.203-1-pve: 5.4.203-1
              pve-kernel-5.4.195-1-pve: 5.4.195-1
              pve-kernel-5.4.189-2-pve: 5.4.189-2
              pve-kernel-5.4.143-1-pve: 5.4.143-1
              pve-kernel-5.4.140-1-pve: 5.4.140-1
              pve-kernel-5.4.106-1-pve: 5.4.106-1
              pve-kernel-5.3.18-3-pve: 5.3.18-3
              pve-kernel-5.3.18-2-pve: 5.3.18-2
              pve-kernel-5.3.10-1-pve: 5.3.10-1
              ceph-fuse: 14.2.21-1
              corosync: 3.1.7-pve1
              criu: 3.15-1+pve-1
              glusterfs-client: 9.2-1
              ifupdown: 0.8.36+pve2
              ksm-control-daemon: 1.4-1
              libjs-extjs: 7.0.0-1
              libknet1: 1.24-pve2
              libproxmox-acme-perl: 1.4.3
              libproxmox-backup-qemu0: 1.3.1-1
              libpve-access-control: 7.3-1
              libpve-apiclient-perl: 3.2-1
              libpve-common-perl: 7.3-1
              libpve-guest-common-perl: 4.2-3
              libpve-http-server-perl: 4.1-5
              libpve-storage-perl: 7.3-1
              libqb0: 1.0.5-1
              libspice-server1: 0.14.3-2.1
              lvm2: 2.03.11-2.1
              lxc-pve: 5.0.0-3
              lxcfs: 4.0.12-pve1
              novnc-pve: 1.3.0-3
              proxmox-backup-client: 2.3.1-1
              proxmox-backup-file-restore: 2.3.1-1
              proxmox-mini-journalreader: 1.3-1
              proxmox-offline-mirror-helper: 0.5.0-1
              proxmox-widget-toolkit: 3.5.3
              pve-cluster: 7.3-1
              pve-container: 4.4-2
              pve-docs: 7.3-1
              pve-edk2-firmware: 3.20220526-1
              pve-firewall: 4.2-7
              pve-firmware: 3.6-2
              pve-ha-manager: 3.5.1
              pve-i18n: 2.8-1
              pve-qemu-kvm: 7.1.0-4
              pve-xtermjs: 4.16.0-1
              qemu-server: 7.3-2
              smartmontools: 7.2-pve3
              spiceterm: 3.2-2
              swtpm: 0.8.0~bpo11+2
              vncterm: 1.7-1
              zfsutils-linux: 2.1.7-pve1
              crunchipC S D 3 Antworten Letzte Antwort
                @crunchip
                criu: 3.15-1+pve-1
                libknet1: 1.24-pve2
                libqb0: 1.0.5-1
                lvm2: 2.03.11-2.1
                lxc-pve: 5.0.0-3
                lxcfs: 4.0.12-pve1
                novnc-pve: 1.3.0-3
                pve-cluster: 7.3-1
                pve-docs: 7.3-1
                pve-firewall: 4.2-7
                pve-firmware: 3.6-2
                pve-i18n: 2.8-1
                qemu-server: 7.3-2
                spiceterm: 3.2-2
                vncterm: 1.7-1
                crunchipC Abwesend
                crunchipC Abwesend
                @feuersturm sieht gut aus, nochmal Glück gehabt👍
                  @crunchip
                  criu: 3.15-1+pve-1
                  libknet1: 1.24-pve2
                  libqb0: 1.0.5-1
                  lvm2: 2.03.11-2.1
                  lxc-pve: 5.0.0-3
                  lxcfs: 4.0.12-pve1
                  novnc-pve: 1.3.0-3
                  pve-cluster: 7.3-1
                  pve-docs: 7.3-1
                  pve-firewall: 4.2-7
                  pve-firmware: 3.6-2
                  pve-i18n: 2.8-1
                  qemu-server: 7.3-2
                  spiceterm: 3.2-2
                  vncterm: 1.7-1
                  saeft_2003
                  @feuersturm
                  Hast du einen lxc (vielleicht sogar wireguard) laufen?
                    @crunchip
                    criu: 3.15-1+pve-1
                    libknet1: 1.24-pve2
                    libqb0: 1.0.5-1
                    lvm2: 2.03.11-2.1
                    lxc-pve: 5.0.0-3
                    lxcfs: 4.0.12-pve1
                    novnc-pve: 1.3.0-3
                    pve-cluster: 7.3-1
                    pve-docs: 7.3-1
                    pve-firewall: 4.2-7
                    pve-firmware: 3.6-2
                    pve-i18n: 2.8-1
                    qemu-server: 7.3-2
                    spiceterm: 3.2-2
                    vncterm: 1.7-1
                    darkiop
                    #66
                    @feuersturm Schieb zur Sicherheit nochmal ein
                    apt dist-upgrade
                    hinterher.
                    Proxmox-ioBroker-Redis-HA Doku: https://forum.iobroker.net/topic/47478/dokumentation-einer-proxmox-iobroker-redis-ha-umgebung
                    • S saeft_2003
                      @feuersturm
                      FeuersturmF Offline
                      FeuersturmF Offline
                      Feuersturm
                      #67
                      @saeft_2003 sagte in Brauche Hilfe bei proxmox v6 zu v7:
                      @feuersturm
                      Nein wireguard hab ich nicht im Einsatz
                      • D darkiop
                        apt dist-upgrade
                        hinterher.
                        FeuersturmF Offline
                        FeuersturmF Offline
                        Feuersturm
                        #68
                        @darkiop sagte in Brauche Hilfe bei proxmox v6 zu v7:
                        apt dist-upgrade
                        hinterher.
                        Mach ich.
                          @feuersturm
                          saeft_2003
                          #69
                          @feuersturm sagte in Brauche Hilfe bei proxmox v6 zu v7:
                          @feuersturm
                          Und einen anderen lxc oder nur VMs?
                          • S saeft_2003
                            @feuersturm
                            FeuersturmF Offline
                            FeuersturmF Offline
                            Feuersturm
                            #70
                            Container und VMs sind gemischt. Primär sind es LXCs und eine VM, wenn ich mich richtig erinnere.
                            Siehst du einen Zusammenhang zu meinem Problem?
                              saeft_2003
                              #71
                              @feuersturm
                              Bei mir wurde auch das eingezeigt und dann nichts mehr…
                              Während dem Update gab es folgenden Fehler, dass ist bei mir der einzigste lxc den ich habe. Kann natürlich auch Zufall sein. Bin echt kein linux profi…
                              usr/sbin/grub-probe: error: disk `lvmid/d6vUe1-VmEL-SEgR-sIoS-IGLg-l441-4JTJ9F/UxkIqX-7fZT-iWgh-YcIu-0Qfh-Rnfd-GXLmxI' not found.
                              Found Ubuntu 21.04 (21.04) on /dev/mapper/pve-vm--1500--disk--0
                              Adding boot menu entry for UEFI Firmware Settings ...
                              done
                              • S saeft_2003
                                @feuersturm
                                done
                                FeuersturmF Offline
                                FeuersturmF Offline
                                Feuersturm
                                #72
                                @saeft_2003 ich poste dir später mal ein paar Screenshots, wie ich es bei mir wieder mit dem alten Kernel zum laufen bekomme habe.
                                  saeft_2003
                                  #73
                                  @feuersturm
                                  Das wäre echt super. Weil das Problem hatte ich bei meinem Testsystem das habe ich einfach neu aufgesetzt. Bei meinem Produktivsystem steht das Update noch an. Davor hab ich etwas bammel auch wenn ich weiß das ich einfach neu aufsetzten kann…
                                  • S saeft_2003
                                    @feuersturm
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    #74
                                    das Problem
                                    ein Problem, aber nicht das selbe
                                    S 2 Antworten Letzte Antwort
                                      das Problem
                                      saeft_2003
                                      #75
                                      @crunchip
                                      Ok hatte gedacht das es evtl das gleiche Problem war…
                                        das Problem
                                        saeft_2003
                                        schrieb am zuletzt editiert von saeft_2003
                                        #76
                                        @crunchip
                                        Vorbereitungen / Voraussetzungen
                                        Folgendes sollte vor einem Upgrade sichergestellt und überprüft werden:
                                        Achtung: Entfernen Sie unbedingt das Meta-Paket linux-image-amd64 und das entsprechende passende Zusatzpaket wie linux-image-4.19-amd64! Sind diese Pakete installiert, kann es zu massiven Problemen während des Upgrades kommen. Erfahrungen zeigten, dass sogar der vollständige BootLoader entfernt werden könnte!
                                        Könnte das etwas mit meinem Problem zu tun haben?
                                        Edit: Das steht im offiziellen wiki
                                        Upgrade wants to remove package 'proxmox-ve'
                                        If you have installed Proxmox VE on top of Debian Buster, you may have installed the package 'linux-image-amd64', which conflicts with current 6.x setups. To solve this, you have to remove this package with
                                        apt remove linux-image-amd64
                                        before the dist-upgrade.
                                        • FeuersturmF Offline
                                          FeuersturmF Offline
                                          Feuersturm
                                          #77
                                          Ich hab noch einmal in dem Log term.log.1 im Pfad var\log\apt\ nachgesehen und dort steht am Ende auch das, was du @saeft_2003 auch in deinem Log Auszug hattest
                                          stat: cannot statx '/dev/mapper/pve-snap_vm--103--disk--0_Current_20221008': No such file or directory
                                          lsblk: /dev/mapper/pve-snap_vm--103--disk--0_Current_20221008: not a block device
                                          stat: cannot statx '/dev/mapper/pve-snap_vm--103--disk--0_UpdateAuf_Ubuntu20LTS': No such file or directory
                                          lsblk: /dev/mapper/pve-snap_vm--103--disk--0_UpdateAuf_Ubuntu20LTS: not a block device
                                          stat: cannot statx '/dev/mapper/pve-snap_vm--103--disk--0_Update_auf_6d5d54': No such file or directory
                                          lsblk: /dev/mapper/pve-snap_vm--103--disk--0_Update_auf_6d5d54: not a block device
                                          stat: cannot statx '/dev/mapper/pve-snap_vm--103--disk--0_VorUpdate_20210116': No such file or directory
                                          lsblk: /dev/mapper/pve-snap_vm--103--disk--0_VorUpdate_20210116: not a block device
                                          stat: cannot statx '/dev/mapper/pve-snap_vm--103--disk--0_VorUpdate_20211212': No such file or directory
                                          lsblk: /dev/mapper/pve-snap_vm--103--disk--0_VorUpdate_20211212: not a block device
                                          stat: cannot statx '/dev/mapper/pve-snap_vm--105--disk--0_influxdb_ssh': No such file or directory
                                          lsblk: /dev/mapper/pve-snap_vm--105--disk--0_influxdb_ssh: not a block device
                                          File descriptor 3 (pipe:[448678]) leaked on vgs invocation. Parent PID 13601: grub-probe
                                          grub-probe: error: disk `lvmid/w8EijX-RSBf-RtMO-H4qI-9Zdl-Xtvj-baV7lV/J8PMJU-J3aX-IDsm-xQ8D-dLqG-54Ds-5EU6bk' not found.
                                          File descriptor 3 (pipe:[448678]) leaked on vgs invocation. Parent PID 13699: grub-probe
                                          grub-probe: error: disk `lvmid/w8EijX-RSBf-RtMO-H4qI-9Zdl-Xtvj-baV7lV/MH9xuu-N9sk-trKO-TDFF-KxLC-eAgD-kr06O4' not found.
                                          File descriptor 3 (pipe:[448678]) leaked on vgs invocation. Parent PID 13795: /usr/sbin/grub-probe
                                          /usr/sbin/grub-probe: error: disk `lvmid/SCBSz9-xzdE-Uq3D-EIbM-l2AZ-VGkU-Pyre88/G7Sabl-ID5k-fdYg-06vc-bh04-AAMt-We1RI5' not found.
                                          Found Ubuntu 18.04.6 LTS (18.04) on /dev/mapper/data2-vm--2010--disk--0
                                          File descriptor 3 (pipe:[448678]) leaked on vgs invocation. Parent PID 13862: /usr/sbin/grub-probe
                                          /usr/sbin/grub-probe: error: disk `lvmid/SCBSz9-xzdE-Uq3D-EIbM-l2AZ-VGkU-Pyre88/wHAfZv-fei3-f35o-FnxH-rOlM-6il1-m2bHVZ' not found.
                                          Found Ubuntu 18.04.6 LTS (18.04) on /dev/mapper/data2-vm--2060--disk--0
                                          File descriptor 3 (pipe:[448678]) leaked on vgs invocation. Parent PID 13919: /usr/sbin/grub-probe
                                          /usr/sbin/grub-probe: error: disk `lvmid/SCBSz9-xzdE-Uq3D-EIbM-l2AZ-VGkU-Pyre88/g0hjoK-QQ8N-0Jnf-fnm3-HR4E-FxvE-I2kVIG' not found.
                                          Found Ubuntu 22.04.1 LTS (22.04) on /dev/mapper/data2-vm--3108--disk--1
                                          File descriptor 3 (pipe:[448678]) leaked on vgs invocation. Parent PID 13976: /usr/sbin/grub-probe
                                          /usr/sbin/grub-probe: error: disk `lvmid/SCBSz9-xzdE-Uq3D-EIbM-l2AZ-VGkU-Pyre88/OnR9t0-5tlo-h4ir-CTQK-ndou-U1sC-LSk3pG' not found.
                                          Found Ubuntu 22.04.1 LTS (22.04) on /dev/mapper/data2-vm--3109--disk--0
                                          File descriptor 3 (pipe:[448678]) leaked on vgs invocation. Parent PID 14067: /usr/sbin/grub-probe
                                          /usr/sbin/grub-probe: error: disk `lvmid/SCBSz9-xzdE-Uq3D-EIbM-l2AZ-VGkU-Pyre88/4gJg58-GKRC-fC1J-W1Aq-etR1-aLvN-j28iH0' not found.
                                          Found Ubuntu 22.04.1 LTS (22.04) on /dev/mapper/data2-vm--3201--disk--0
                                          File descriptor 3 (pipe:[448678]) leaked on vgs invocation. Parent PID 14124: /usr/sbin/grub-probe
                                          /usr/sbin/grub-probe: error: disk `lvmid/SCBSz9-xzdE-Uq3D-EIbM-l2AZ-VGkU-Pyre88/B8aHNJ-7Qu5-ebzy-239W-vhg4-1q2B-LgA2iJ' not found.
                                          Found Ubuntu 22.04.1 LTS (22.04) on /dev/mapper/data2-vm--4000--disk--0
                                          File descriptor 3 (pipe:[448678]) leaked on vgs invocation. Parent PID 14181: /usr/sbin/grub-probe
                                          /usr/sbin/grub-probe: error: disk `lvmid/SCBSz9-xzdE-Uq3D-EIbM-l2AZ-VGkU-Pyre88/ir2NVA-rf2w-u8tY-cvyC-Ae4G-q6aE-PUq2FV' not found.
                                          Found Ubuntu 20.04.5 LTS (20.04) on /dev/mapper/data2-vm--5000--disk--0
                                          File descriptor 3 (pipe:[448678]) leaked on vgs invocation. Parent PID 14238: /usr/sbin/grub-probe
                                          /usr/sbin/grub-probe: error: disk `lvmid/SCBSz9-xzdE-Uq3D-EIbM-l2AZ-VGkU-Pyre88/tzD2nF-x954-d3Ty-sodg-dEt2-Uwr0-KDJtei' not found.
                                          Found Ubuntu 22.04.1 LTS (22.04) on /dev/mapper/data2-vm--7000--disk--0
                                          File descriptor 3 (pipe:[448678]) leaked on vgs invocation. Parent PID 14295: /usr/sbin/grub-probe
                                          /usr/sbin/grub-probe: error: disk `lvmid/w8EijX-RSBf-RtMO-H4qI-9Zdl-Xtvj-baV7lV/J8PMJU-J3aX-IDsm-xQ8D-dLqG-54Ds-5EU6bk' not found.
                                          Found Ubuntu 20.04.5 LTS (20.04) on /dev/mapper/pve-vm--103--disk--0
                                          File descriptor 3 (pipe:[448678]) leaked on vgs invocation. Parent PID 14370: /usr/sbin/grub-probe
                                          /usr/sbin/grub-probe: error: disk `lvmid/w8EijX-RSBf-RtMO-H4qI-9Zdl-Xtvj-baV7lV/MH9xuu-N9sk-trKO-TDFF-KxLC-eAgD-kr06O4' not found.
                                          Found Ubuntu 18.04.4 LTS (18.04) on /dev/mapper/pve-vm--105--disk--0
                                          done
                                          Nachdem mein Update ja nicht weiter ging hatte ich Montior und Tastatur angeschlossen und ich sah auf dem Bildschirm nur ein
                                          Über das Bootmenü konnte ich dann über das folgende Menü einen älteren Kernel 5.4.203 wählen und das System ist erstmal wieder gestartet.
