  4. Node-Red
  5. contrib tts lässt sich nicht installieren
    6.5k
36 Beiträge 3 Kommentatoren 3.3k Aufrufe 3 Beobachtet
  • S Saranger
    @mickym said in contrib tts lässt sich nicht installieren:
    folgende mitteilung bekomm ich aus der Konsole
    Welcome to Ubuntu 22.04.1 LTS (GNU/Linux 5.15.60-1-pve x86_64)
     * Documentation:  https://help.ubuntu.com
     * Management:     https://landscape.canonical.com
     * Support:        https://ubuntu.com/advantage
    Last login: Mon Dec 12 13:43:08 CET 2022 on tty1
    root@ioBroker:~# cd /opt/iobroker/iobroker-data/node-red
    root@ioBroker:/opt/iobroker/iobroker-data/node-red# rm -r node_modules
    root@ioBroker:/opt/iobroker/iobroker-data/node-red# npm install
    npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
    npm WARN deprecated formidable@1.2.2: Please upgrade to latest, formidable@v2 or formidable@v3! Check these notes: https://bit.ly/2ZEqIau
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21.1. For more information, see https://github.com/axios/axios/pull/3410
    npm WARN deprecated node-red-contrib-sonospollytts@2.0.8: Package no longer supported. Contact Support at https://www.npmjs.com/support for more info.
    added 294 packages, and audited 295 packages in 38s
    57 packages are looking for funding
      run `npm fund` for details
    7 vulnerabilities (4 moderate, 3 high)
    To address all issues (including breaking changes), run:
      npm audit fix --force
    Run `npm audit` for details.
    npm notice
    npm notice New major version of npm available! 8.19.2 -> 9.2.0
    npm notice Changelog: https://github.com/npm/cli/releases/tag/v9.2.0
    npm notice Run npm install -g npm@9.2.0 to update!
    npm notice
    @saranger
    Nicht als root agieren. Insbesondere nicht in den Verzeichnissen.
    Nie, nie, niemals als root!
      @saranger
      mickymM Offline
      mickymM Offline
      mickym
      @thomas-braun sagte in contrib tts lässt sich nicht installieren:
      @saranger
      Da hast Du natürlich Recht - da hab ich wieder mal nicht drauf geachtet. Danke für Hinweis. Dann auf jeden Fall nochmal machen - ich hoffe es hat mit den Rechten nichts zerschossen.
      • mickymM mickym
        @saranger
        Saranger
        @mickym
        ah das hab ich auch nicht auf dem schirm gehabt, ich hab glaube gar keinen anderen user.
        anbei wieder die meldung und nodered geht nicht
        2022-12-12T13:16:47.946Z Installieren : node-red-contrib-tts-ultimate 1.0.52
        2022-12-12T13:16:47.964Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict node-red-contrib-tts-ultimate@1.0.52
        2022-12-12T13:16:48.245Z [err] npm
        2022-12-12T13:16:48.245Z [err]  WARN config production Use `--omit=dev` instead.
        2022-12-12T13:16:57.529Z [err] npm
        2022-12-12T13:16:57.530Z [err]  WARN deprecated uuid@3.3.2: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
        • S Saranger
          @mickym
          @saranger sagte in contrib tts lässt sich nicht installieren:
          Das ist das erste was man in einem neuen Ubuntu tut. Eigentlich ist das in einer üblichen Installation eh schon im Installer so vorgesehen. Bei virtuellen Kisten wie gesagt die erste Aktion: User anlegen.
          • S Saranger
            @mickym
            @saranger
            Abbrechen, Rechte fixen!
            iob stop
            iob fix
              @saranger
              iob stop
              iob fix
              Saranger
              @thomas-braun said in contrib tts lässt sich nicht installieren:
              iob fix
              user hab ich jetzt angelegt und die beiden befehle hab ich auch ausgeführt
              Thomas BraunT mickymM 2 Antworten Letzte Antwort
              • mickymM Offline
                mickymM Offline
                mickym
                Ja ich glaube auch, dass da mit den Rechten insgesamt was nicht stimmt. Da übergebe ich lieber an @Thomas-Braun. Ich schau mal, ob ich auf meinem Testsystem die Node installieren kann.
                • S Saranger
                  iob fix
                  @saranger
                  iob diag
                  ausführen, die markierten Ausgaben hier wieder rein.
                    @saranger
                    iob diag
                    Saranger
                    iob diag
                    bash: line 1: syntax error near unexpected token `<'
                    bash: line 1: `<!doctype html><html lang="en"><head><meta charset="utf-8"/><link rel="icon" href="/www/favicon.ico"/><meta name="viewport" content="width=device-width,initial-scale=1"/><meta name="theme-color" content="#2196F3"><meta name="description" content="Remote access to personal ioBroker server via ioBroker.cloud"/><link rel="apple-touch-icon" href="/www/logo192.png"/><link rel="manifest" href="/www/manifest.json"/><title>ioBroker Cloud</title><style>#root,body,html{height:100%;width:100%;display:flex;overflow:hidden}</style><script defer="defer" src="/www/static/js/main.ae982c84.js"></script><link href="/www/static/css/main.59da0ebb.css" rel="stylesheet"></head><body><noscript>You need to enable JavaScript to run this app.</noscript><div id="root"></div></body></html>'
                    • S Saranger
                      iob fix
                      mickymM Offline
                      mickymM Offline
                      mickym
                      @saranger Also auf meinem Testsystem konnte ich die Node installieren.
                      Die Meldungen ansonsten sind aber normal - habe hier mal das Log über die Installation über den Palletten-Manager:
                      2022-12-12T13:31:52.224Z Installieren : node-red-contrib-tts-ultimate 1.0.52
                      2022-12-12T13:31:52.226Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict node-red-contrib-tts-ultimate@1.0.52
                      2022-12-12T13:31:52.406Z [err] npm
                      2022-12-12T13:31:52.406Z [err]  WARN config production Use `--omit=dev` instead.
                      2022-12-12T13:31:53.776Z [err] npm
                      2022-12-12T13:31:53.776Z [err] WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
                      2022-12-12T13:31:53.779Z [err] npm
                      2022-12-12T13:31:53.779Z [err]  WARN deprecated formidable@1.2.2: Please upgrade to latest, formidable@v2 or formidable@v3! Check these notes: https://bit.ly/2ZEqIau
                      2022-12-12T13:31:53.792Z [err] npm
                      2022-12-12T13:31:53.792Z [err]  WARN deprecated uuid@3.3.2: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                      2022-12-12T13:32:06.791Z [out]
                      2022-12-12T13:32:06.791Z [out] added 169 packages in 14s
                      2022-12-12T13:32:06.800Z rc=0
                      Das heisst diese Math.random Warnung kann man ignorieren.
                      Bei Dir fehlt nur die Erfolgsmeldung dass 169 Pakete installiert wurden. Vielleicht Geduld?
                      • mickymM mickym
                        Saranger
                        @mickym ok gut zu wissen, vielleicht lässt sich das andere ja noch lösen :-)
                        danke Dir.
                        • S Saranger
                          iob diag
                          Saranger
                          anbei mal die Meldung noch im IObroker Log nach dem Versuch diese node zu installieren und das crashen von nodered
                          FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
                          2022-12-12 14:58:41.183 - warn: node-red.0 (2527) 1: 0xb06730 node::Abort() [node-red]
                          2022-12-12 14:58:41.183 - warn: node-red.0 (2527) 2: 0xa1b6d0 [node-red]
                          2022-12-12 14:58:41.184 - warn: node-red.0 (2527) 3: 0xce1e60 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [node-red]
                          2022-12-12 14:58:41.185 - warn: node-red.0 (2527) 4: 0xce2207 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [node-red]
                          2022-12-12 14:58:41.185 - warn: node-red.0 (2527) 5: 0xe99875 [node-red]
                          2022-12-12 14:58:41.186 - warn: node-red.0 (2527) 6: 0xea953d v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [node-red]
                          2022-12-12 14:58:41.187 - warn: node-red.0 (2527) 7: 0xeac23e v8::internal::Heap::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [node-red]
                          2022-12-12 14:58:41.187 - warn: node-red.0 (2527) 8: 0xe6d4b2 v8::internal::Factory::AllocateRaw(int, v8::internal::AllocationType, v8::internal::AllocationAlignment) [node-red]
                          2022-12-12 14:58:41.188 - warn: node-red.0 (2527) 9: 0xe65ac4 v8::internal::FactoryBase::AllocateRawWithImmortalMap(int, v8::internal::AllocationType, v8::internal::Map, v8::internal::AllocationAlignment) [node-red]
                          2022-12-12 14:58:41.189 - warn: node-red.0 (2527) 10: 0xe67d22 v8::internal::FactoryBase::NewDescriptorArray(int, int, v8::internal::AllocationType) [node-red]
                          2022-12-12 14:58:41.189 - warn: node-red.0 (2527) 11: 0x10b5d77 v8::internal::DescriptorArray::CopyUpTo(v8::internal::Isolate*, v8::internal::Handle, int, int) [node-red]
                          2022-12-12 14:58:41.191 - warn: node-red.0 (2527) 12: 0x10a3eb1 v8::internal::Map::CopyAddDescriptor(v8::internal::Isolate*, v8::internal::Handle, v8::internal::Descriptor*, v8::internal::TransitionFlag) [node-red]
                          13: 0x10a446c v8::internal::Map::CopyWithField(v8::internal::Isolate*, v8::internal::Handle, v8::internal::Handle, v8::internal::Handle, v8::internal::PropertyAttributes, v8::internal::PropertyConstness, v8::internal::Representation, v8::internal::TransitionFlag) [node-red]
                          2022-12-12 14:58:41.192 - warn: node-red.0 (2527) 14: 0x10a6298 v8::internal::Map::TransitionToDataProperty(v8::internal::Isolate*, v8::internal::Handle, v8::internal::Handle, v8::internal::Handle, v8::internal::PropertyAttributes, v8::internal::PropertyConstness, v8::internal::StoreOrigin) [node-red]
                          2022-12-12 14:58:41.192 - warn: node-red.0 (2527) 15: 0x1094df2 v8::internal::LookupIterator::PrepareTransitionToDataProperty(v8::internal::Handle, v8::internal::Handle, v8::internal::PropertyAttributes, v8::internal::StoreOrigin) [node-red]
                          2022-12-12 14:58:41.193 - warn: node-red.0 (2527) 16: 0x10b827a v8::internal::Object::AddDataProperty(v8::internal::LookupIterator*, v8::internal::Handle, v8::internal::PropertyAttributes, v8::Maybe, v8::internal::StoreOrigin) [node-red]
                          2022-12-12 14:58:41.194 - warn: node-red.0 (2527) 17: 0x10bc7a3 v8::internal::Object::SetProperty(v8::internal::LookupIterator*, v8::internal::Handle, v8::internal::StoreOrigin, v8::Maybe) [node-red]
                          2022-12-12 14:58:41.195 - warn: node-red.0 (2527) 18: 0x11efce6 v8::internal::Runtime::SetObjectProperty(v8::internal::Isolate*, v8::internal::Handle, v8::internal::Handle, v8::internal::Handle, v8::internal::StoreOrigin, v8::Maybe) [node-red]
                          2022-12-12 14:58:41.195 - warn: node-red.0 (2527) 19: 0x11f1269 v8::internal::Runtime_SetKeyedProperty(int, unsigned long*, v8::internal::Isolate*) [node-red]
                          2022-12-12 14:58:41.196 - warn: node-red.0 (2527) 20: 0x15da159 [node-red]
                          2022-12-12 14:58:41.208 - info: node-red.0 (2527) node-red exited with null
                          2022-12-12 14:58:46.208 - info: node-red.0 (2527) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                          2022-12-12 14:58:49.542 - warn: node-red.0 (2527) 12 Dec 14:58:49 - [warn] Projects disabled : editorTheme.projects.enabled=false
                          2022-12-12 14:58:50.138 - warn: node-red.0 (2527)
                          <--- Last few GCs --->
                          [4805:0x5fcdf70] 3865 ms: Mark-sweep (reduce) 125.1 (131.4) -> 124.1 (131.4) MB, 50.5 / 0.0 ms (average mu = 0.147, current mu = 0.057) allocation failure scavenge might not succeed
                          [4805:0x5fcdf70] 3916 ms: Mark-sweep (reduce) 125.2 (131.4) -> 124.3 (131.7) MB, 47.6 / 0.0 ms (average mu = 0.105, current mu = 0.061) allocation failure scavenge might not succeed
                          <--- JS stacktrace --->
                          2022-12-12 14:58:50.138 - warn: node-red.0 (2527) 1: 0xb06730 node::Abort() [node-red]
                          2022-12-12 14:58:50.139 - warn: node-red.0 (2527) 2: 0xa1b6d0 [node-red]
                          2022-12-12 14:58:50.140 - warn: node-red.0 (2527) 3: 0xce1e60 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [node-red]
                          2022-12-12 14:58:50.141 - warn: node-red.0 (2527) 4: 0xce2207 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [node-red]
                          2022-12-12 14:58:50.142 - warn: node-red.0 (2527) 5: 0xe99875 [node-red]
                          2022-12-12 14:58:50.143 - warn: node-red.0 (2527) 6: 0xea953d v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [node-red]
                          2022-12-12 14:58:50.145 - warn: node-red.0 (2527) 7: 0xeac23e v8::internal::Heap::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [node-red]
                          2022-12-12 14:58:50.146 - warn: node-red.0 (2527) 8: 0xe6d4b2 v8::internal::Factory::AllocateRaw(int, v8::internal::AllocationType, v8::internal::AllocationAlignment) [node-red]
                          2022-12-12 14:58:50.147 - warn: node-red.0 (2527) 9: 0xe67dcc v8::internal::FactoryBase::AllocateRawArray(int, v8::internal::AllocationType) [node-red]
                          2022-12-12 14:58:50.148 - warn: node-red.0 (2527) 10: 0xe67ea5 v8::internal::FactoryBase::NewFixedArrayWithFiller(v8::internal::Handle, int, v8::internal::Handle, v8::internal::AllocationType) [node-red]
                          2022-12-12 14:58:50.149 - warn: node-red.0 (2527) 11: 0x1016382 [node-red]
                          2022-12-12 14:58:50.150 - warn: node-red.0 (2527) 12: 0x101650c [node-red]
                          2022-12-12 14:58:50.151 - warn: node-red.0 (2527) 13: 0x1016668 [node-red]
                          2022-12-12 14:58:50.151 - warn: node-red.0 (2527) 14: 0x10744b5 v8::internal::JSObject::AddDataElement(v8::internal::Handle, unsigned int, v8::internal::Handle, v8::internal::PropertyAttributes) [node-red]
                          2022-12-12 14:58:50.152 - warn: node-red.0 (2527) 15: 0x10b820e v8::internal::Object::AddDataProperty(v8::internal::LookupIterator*, v8::internal::Handle, v8::internal::PropertyAttributes, v8::Maybe, v8::internal::StoreOrigin) [node-red]
                          2022-12-12 14:58:50.153 - warn: node-red.0 (2527) 16: 0x10bc7a3 v8::internal::Object::SetProperty(v8::internal::LookupIterator*, v8::internal::Handle, v8::internal::StoreOrigin, v8::Maybe) [node-red]
                          2022-12-12 14:58:50.154 - warn: node-red.0 (2527) 17: 0x11efce6 v8::internal::Runtime::SetObjectProperty(v8::internal::Isolate*, v8::internal::Handle, v8::internal::Handle, v8::internal::Handle, v8::internal::StoreOrigin, v8::Maybe) [node-red]
                          2022-12-12 14:58:50.154 - warn: node-red.0 (2527) 18: 0x11f1269 v8::internal::Runtime_SetKeyedProperty(int, unsigned long*, v8::internal::Isolate*) [node-red]
                          2022-12-12 14:58:50.155 - warn: node-red.0 (2527) 19: 0x15da159 [node-red]
                          2022-12-12 14:58:50.168 - info: node-red.0 (2527) node-red exited with null
                          2022-12-12 14:58:55.168 - info: node-red.0 (2527) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                          2022-12-12 14:58:58.450 - warn: node-red.0 (2527) 12 Dec 14:58:58 - [warn] Projects disabled : editorTheme.projects.enabled=false
                          2022-12-12 14:58:58.949 - warn: node-red.0 (2527)
                          [4827:0x6ac1f70] 3718 ms: Mark-sweep 125.1 (133.9) -> 123.5 (134.4) MB, 44.0 / 0.0 ms (average mu = 0.240, current mu = 0.109) allocation failure scavenge might not succeed
                          [4827:0x6ac1f70] 3767 ms: Mark-sweep 125.6 (134.4) -> 124.0 (134.9) MB, 43.5 / 0.0 ms (average mu = 0.177, current mu = 0.105) allocation failure scavenge might not succeed
                          2022-12-12 14:58:58.951 - warn: node-red.0 (2527) 1: 0xb06730 node::Abort() [node-red]
                          2022-12-12 14:58:58.951 - warn: node-red.0 (2527) 2: 0xa1b6d0 [node-red]
                          2022-12-12 14:58:58.951 - warn: node-red.0 (2527) 4: 0xce2207 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [node-red]
                          2022-12-12 14:58:58.955 - warn: node-red.0 (2527) 5: 0xe99875 [node-red]
                          8: 0xe6d77a v8::internal::Factory::NewFillerObject(int, bool, v8::internal::AllocationType, v8::internal::AllocationOrigin) [node-red]
                          9: 0x11e64e6 v8::internal::Runtime_AllocateInYoungGeneration(int, unsigned long*, v8::internal::Isolate*) [node-red]
                          10: 0x15da159 [node-red]
                          2022-12-12 14:58:58.968 - info: node-red.0 (2527) node-red exited with null
                          2022-12-12 14:59:00.775 - error: rpi2.0 (2689) Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on
                          /dev/loop0 16337788 3655048 11827496 24% /
                          /1024
                          2022-12-12 14:59:00.776 - error: rpi2.0 (2689) Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on
                          • S Saranger
                            /1024
                            mickymM Offline
                            mickymM Offline
                            mickym
                            @saranger hast du mal den speicherbedarf im Node-red Adapter erhöht?
                            • mickymM mickym
                              Saranger
                              @mickym nein du meinst den ram wenn ich im iobroker auf den noderedadapter gehe? Wieviel sollte man da geben?
                              • S Saranger
                                @saranger
                                Wie bist du denn da eigentlich insgesamt unterwegs?
                                free -ht
                                sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                                uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                • S Saranger
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  @saranger ich glaub Standard ist 128. ich hab 2048 weil ich viele flows habe, aber kannst ja mal mit 512 oder 1024 Testen.
                                    Saranger
                                    saranger@ioBroker:~$ free -ht
                                    Mem:           4.0Gi       1.3Gi       2.4Gi       0.0Ki       293Mi       2.7Gi
                                    Swap:          512Mi          0B       512Mi
                                    Total:         4.5Gi       1.3Gi       2.9Gi
                                    saranger@ioBroker:~$ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                                    [sudo] password for saranger:
                                    Sorry, try again.
                                    saranger@ioBroker:~$ uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                    x86_64
                                    Kein Docker
                                    /usr/bin/nodejs
                                    /usr/bin/node
                                    /usr/bin/npm
                                    v16.18.1
                                    v16.18.1
                                    8.19.2
                                    4.0.23
                                    saranger
                                    saranger sudo iobroker
                                    /home/saranger
                                    Hit:1 https://deb.nodesource.com/node_16.x jammy InRelease
                                    Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
                                    Get:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease [114 kB]
                                    Get:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease [110 kB]
                                    Fetched 224 kB in 1s (228 kB/s)
                                    Reading package lists... Done
                                    All packages are up to date.
                                    nodejs:
                                      Installed: 16.18.1-deb-1nodesource1
                                      Candidate: 16.18.1-deb-1nodesource1
                                      Version table:
                                     *** 16.18.1-deb-1nodesource1 500
                                            500 https://deb.nodesource.com/node_16.x jammy/main amd64 Packages
                                         12.22.9~dfsg-1ubuntu3 500
                                            500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
                                    • S Saranger
                                      Sorry, try again.
                                      x86_64
                                      Kein Docker
                                      /usr/bin/nodejs
                                      /usr/bin/node
                                      /usr/bin/npm
                                      v16.18.1
                                      v16.18.1
                                      8.19.2
                                      4.0.23
                                      saranger
                                      /home/saranger
                                      nodejs:
                                        Version table:
                                      Saranger
                                      @mickym werd ich mal testen, ich muss dazu sagen das Ganze läuft auf Proxmox und ich habe seit dem auch immer probleme beim Deploy, teilweise muss ich 4 mal darauf klicken bis es funktioniert.
                                      • S Saranger
                                        mickymM Offline
                                        mickymM Offline
                                        mickym
                                        @saranger na dann wird es Zeit, bei 128k, ist das ein Zeichen, dass der Speicher knapp ist und da immer rumgeswapt wird. Ich würde mal 1024 nehmen und wie gesagt ich habe 2048.
                                        Das heißt nicht dass soviel gebraucht wird, aber der Speicher für Node-Red wird halt nicht so schnell limitiert.
                                        • mickymM mickym
                                          Saranger
                                          @mickym und das war die Lösung des Problems hab es auf 1024 gestellt und jetzt lies sich die Node installieren. Verrückt
                                          mickymM Thomas BraunT 2 Antworten Letzte Antwort
