  4. [Vorlage] Konfigurierte Script um States zu zahlen [lowbat, dimmer, shutter, chromecast, etc]
    6.0k
45 Beiträge 14 Kommentatoren 11.5k Aufrufe
    Smartuser
    @Smartuser:
    @pix:
    hab mir das Skript nun auch installiert und bin sehr zufrieden. Gutes Skript!
    Ich habe die Ausklammerung eines HM-Geräts jetzt auch hinbekommen. Oben habe ich's schon editiert, der Abfangcode funktioniert nur in der Subscription ( selektor.on() ).
    Hier das neue Skript:
    // http://forum.iobroker.net/viewtopic.php?f=21&t=2651#p23393
    ! //Add device rules
    addDeviceCounter("lowbat", $('channel[state.id=.LOWBAT]'), true);
    addDeviceCounter("sticky_unreach", $('channel[state.id=
    .STICKY_UNREACH]'), true);
    addDeviceCounter("unreach", $('channel[state.id=.UNREACH]'), true);
    addDeviceCounter("config_pending", $('channel[state.id=
    .CONFIG_PENDING]'), true);
    addDeviceCounter("open_windows", $('channel{TYPE=SHUTTER_CONTACT}[state.id=.STATE]'), true);
    addDeviceCounter("on_lights", $('channel{TYPE=DIMMER}[state.id=
    .LEVEL]'), function(state){return state>0;});
    addDeviceCounter("open_shutters", $('channel{TYPE=BLIND}[state.id=.LEVEL]'), function(state){return state>0;});
    addDeviceCounter("playing_music", $('channel[state.id=audio-.playing]'), true);
    • Code - do not change anything bellow this line *
    ! function addDeviceCounter(name, selector, val_to_count) {
    ! //Total amount of devices found by selector
    var state_total = 'deviceCounter.' + name + '.total';
    createState(state_total, 0);
    //List of devices that match condition
    var state_list = 'deviceCounter.' + name + '.list';
    createState(state_list, "");
    //Number of devices that match condition
    var state_counter = 'deviceCounter.' + name + '.counter';
    createState(state_counter, 0);
    ! function countDevs(obj) {
    var d_count = 0;
    var d_list = [];
    ! selector.each(function (id, i) {
    var status = getState(id).val;
    var obj = getObject(id);
    if ((typeof val_to_count === 'function' && val_to_count(status)) ||
    (typeof val_to_count === 'boolean' && val_to_count == status)) {
    //Get parent object
    var parentChannelId = id.slice(id.lastIndexOf("."));
    var parentDevicelId = id.split(".").slice(0,-2).join(".");
    var deviceObject = getObject(parentDevicelId);
    //remember device name
    d_list.push(deviceObject.common.name);
    ++d_count; // Zählt die Anzahl der vorhandenen Geräte unabhängig vom Status
    ! log(name + "(" + d_count + "): " + d_list);
    ! setState(state_list, d_list.join('
    setState(state_counter, d_list.length);
    setState(state_total, d_count);
    ! //Re-evaluate when a device status changes
    selector.on(function(obj) { // bei Zustandänderung . LOWBAT in allen Gewerken
    if (getObject(obj.deviceId).native.TYPE !=="HM-SCI-3-FM") { // Hier ggf. mit OR || weitere Geräte einfügen
    countDevs(obj);
    } else log('Gerät ' + getObject(obj.deviceId).native.TYPE + ' wird nicht mitgezählt');
    ! //Re-evaluate each hour
    schedule("
    /60 * * * *", countDevs);
    //Evaluate for the first time
    countDevs();
    Pix `
    Pix … danke für deine Arbeit.
    Leider wird das "HM-SCI-3-FM - Device" bei mir immer noch mit gezählt.
    Muss ich noch etwas beachten?
    Gruß `
    Hallo Pix,
    könntest du da bitte nochmal drüberschauen?
    Bei mir funktioniert das "ausklammern" nicht.
    • P Offline
      pix
      hier dann noch eine angepasste Version des Skriptes. Es werden nun für den Fenster-Zähler nur RHS (Rotate-Handle-Sensor) berücksichtigt, <u>keine</u> optischen oder magnetischen Tür-Fenster-Kontakte (TFK, Typen: HM-Sec-SCo, HM-Sec- SC2, HM-Sec- SC).
      Ausserdem gibt es nun eine Blacklist, in welcher die nicht zu beachtenden Typen aufgelistet werden (bitte selbst editieren). Zum Test ist hier der Typ HM-Sec-RHS auch eingetragen. Es macht natürlich keinen Sinn, erst das Skript auf RHS umzubiegen und diese Sensoren dann auszuklammern. "HM-Sec-RHS" steht also nur zum Debug in der Blacklist. Also bitte nach den ersten Test rausnehmen…
      /* Test Zähler
      ! http://forum.iobroker.net/viewtopic.php?f=21&t=2651#p23393
      ! von Vegetto
      ! 17.07.2017 eingebaut
      30.07.2017 Blacklist
      RHS Typ
      ! const logging = true;
      ! const blacklist = ['HM-SCI-3-FM', 'HM-Sec-RHS']; //Hier Gerätetyp eintragen, der nicht beachtet werden soll
      .LOWBAT]'), true);
      addDeviceCounter("sticky_unreach", $('channel[state.id=.STICKY_UNREACH]'), true);
      .UNREACH]'), true);
      addDeviceCounter("config_pending", $('channel[state.id=.CONFIG_PENDING]'), true);
      //addDeviceCounter("open_windows", $('channel{TYPE=SHUTTER_CONTACT}[state.id=
      .STATE]'), true);
      addDeviceCounter("open_windows", $('channel{TYPE=ROTARY_HANDLE_SENSOR}[state.id=.STATE]'), function(state){return state>0;}); // liefert 0,1,2
      var state_total = 'System.deviceCounter.' + name + '.total';
      var state_list = 'System.deviceCounter.' + name + '.list';
      var state_counter = 'System.deviceCounter.' + name + '.counter';
      var d_count = 0;
      var d_list = [];
      //Get parent object
      ! if (logging) log(name + "(" + d_count + "): " + d_list);
      var device_type = getObject(obj.deviceId).native.TYPE;
      if (logging) log('Zähler Skript - Auslösender Aktor vom Typ: ' + device_type);
      var dontcount = (blacklist.indexOf(device_type) != -1) ? true : false;
      if (dontcount) log('Geräte vom Typ ' + device_type + ' stehen in der Blacklist und werden nicht gezählt');
      else countDevs(obj);
      schedule("
      countDevs();
      ! Edit: logging nach den ersten Tests bitte auf false stellen
      Pix
        Smartuser
        @pix:
        /* Test Zähler
        ! von Vegetto
        RHS Typ
        .LOWBAT]'), true);
        .UNREACH]'), true);
        .STATE]'), true);
        var d_count = 0;
        var d_list = [];
        //Get parent object
        schedule("
        countDevs();
        Pix `
        Hallo Pix,
        keine Ahnung woran es liegt, aber bei mir wird auch mit dem aktellen Script das "HM-SCI-3-FM - Device" mitgezählt :|
        Sonst funktioniert das Script 1a.
        Hier der Log beim Starten:
        18:38:00.088	[info]	javascript.0 Stop script script.js.Scripte.State_Counter
        18:38:00.971	[info]	javascript.0 Start javascript script.js.Scripte.State_Counter
        18:38:00.972	[info]	javascript.0 script.js.Scripte.State_Counter: lowbat(42):
        18:38:00.973	[info]	javascript.0 script.js.Scripte.State_Counter: sticky_unreach(32):
        18:38:00.973	[info]	javascript.0 script.js.Scripte.State_Counter: unreach(32):
        18:38:00.974	[info]	javascript.0 script.js.Scripte.State_Counter: config_pending(32):
        18:38:00.975	[info]	javascript.0 script.js.Scripte.State_Counter: open_windows(17): Eingangstür,Alarmanlagen Melder,Alarmanlagen Melder,Alarmanlagen Melder,Fenster Badezimmer,Fenster Ben,Fenster Gäste-WC,Fenster Partyzimmer 2
        18:38:00.975	[info]	javascript.0 script.js.Scripte.State_Counter: on_lights(0):
        18:38:00.975	[info]	javascript.0 script.js.Scripte.State_Counter: open_shutters(6): Rollladen Küche,Rollladen Schlafzimmer,Rollladen Wohnzimmer,Rollladen Gäste-WC,Rollladen Esszimmer,Rollladen Partyzimmer
        18:38:00.975	[info]	javascript.0 script.js.Scripte.State_Counter: playing_music(0):
        18:38:00.976	[info]	javascript.0 script.js.Scripte.State_Counter: registered 161 subscriptions and 8 schedules
        Hier noch beim Öffnen eines zusätzlichen Fensters
        18:38:42.327	[info]	javascript.0 script.js.Scripte.State_Counter: Zähler Skript - Auslösender Aktor vom Typ: HM-Sec-SCo
        18:38:42.328	[info]	javascript.0 script.js.Scripte.State_Counter: open_windows(17): Eingangstür,Alarmanlagen Melder,Alarmanlagen Melder,Alarmanlagen Melder,Fenster Badezimmer,Fenster Ben,Fenster Gäste-WC,Fenster Wohnzimmer 1,Fenster Partyzimmer 2
        Wie du siehst werden immer die 3 Kanäle des "HM-SCI-3-FM - Device" mitgezählt (Alarmanlagen Melder,Alarmanlagen Melder,Alarmanlagen Melder)
        • P Offline
          pix
          kann es denn sein, dass der Typ evtl nicht HM-SCI-3-FM ist? Ich kann nirgends eine Debugausgabe sehen. Kannst du den Alarmanlagenmelder mal den Status wechseln lassen?
          Pix
            Smartuser
            @pix:
            Pix `
            hab ich eben etwa 4x gemacht.
            Hier der Log:
            22:58:00.110	[info]	javascript.0 script.js.Scripte.State_Counter: Zähler Skript - Auslösender Aktor vom Typ: HM-SCI-3-FM
            22:58:00.112	[info]	javascript.0 script.js.Scripte.State_Counter: Geräte vom Typ HM-SCI-3-FM stehen in der Blacklist und werden nicht gezählt
            22:58:00.838	[info]	javascript.0 script.js.Scripte.State_Counter: Zähler Skript - Auslösender Aktor vom Typ: HM-SCI-3-FM
            22:58:00.839	[info]	javascript.0 script.js.Scripte.State_Counter: Geräte vom Typ HM-SCI-3-FM stehen in der Blacklist und werden nicht gezählt
            22:58:02.345	[info]	javascript.0 script.js.Scripte.State_Counter: Zähler Skript - Auslösender Aktor vom Typ: HM-SCI-3-FM
            22:58:02.347	[info]	javascript.0 script.js.Scripte.State_Counter: Geräte vom Typ HM-SCI-3-FM stehen in der Blacklist und werden nicht gezählt
            22:58:03.852	[info]	javascript.0 script.js.Scripte.State_Counter: Zähler Skript - Auslösender Aktor vom Typ: HM-SCI-3-FM
            22:58:03.853	[info]	javascript.0 script.js.Scripte.State_Counter: Geräte vom Typ HM-SCI-3-FM stehen in der Blacklist und werden nicht gezählt
              tempestas
              Mal eine blöde Frage:
              gibt es eine elegante Lösung, von HmIP duie LOW_BAT (nicht LOWBAT) Stato abzufragen, aber mit in den lowbat counter aufzunehmen? Geht bestimmt einfach, ich bin leider gescheitert.
              <size="85">ioBroker | 21 Adapter | Ubuntu Server | intel NUC | Homematic CCU2 | Hue | Osram Lightify| Sonos | 2x Instar Cam | Samsung Tab A 2016 im Holzrahmen| 3x Echo dot | 1x Echo | Neato Botvac D5</size>
                Smartuser
                @Pix
                Kannst du dir das bitte nochmal anschauen?
                http://forum.iobroker.net/viewtopic.php?p=77860#p77860
                Hilft dir der Log weiter?
                • P Offline
                  pix
                  Ja manchmal sieht man den Wald vor Bäumen nicht! :lol:
                  Die von mir abgeänderte Subscription prüft, ob das auslösende Gerät in der Blacklist steht. Wenn nicht, startet es die Funktion countDev(). Allerdings wird diese Funktion auch standardmäßig bei Skriptstart und jede Stunde gestartet. Und zwar ohne vorherige Prüfung. Deshalb der Fehler.
                  Auf die Schnelle bitte am Schluss erstmal die beiden Zeilen auch och auskommentieren:
                  //schedule("*/60 * * * *", countDevs);
                  //countDevs();
                  Man müsste also die Abfrage nach der Blacklist eigentlich in die Funktion countDev() packen.
                  Pix
                  • P Offline
                    pix
                    Hallo,@tempestas:
                    gibt es eine elegante Lösung, von HmIP duie LOW_BAT (nicht LOWBAT) Stato abzufragen, aber mit in den lowbat counter aufzunehmen? Geht bestimmt einfach, ich bin leider gescheitert. `
                    schon mal versucht, das Skript oben um diese Zeile zu ergänzen?
                    addDeviceCounter("lowbat",         $('channel[state.id=*.LOW_BAT]'),                           true);
                    Pix
                      Smartuser
                      @pix:
                      //countDevs();
                      Pix `
                      Ok, danke … ich habe beide Zeilen auskommentiert.
                      Den Rest mit "deinen" Funktionen ist mir zu hoch :lol:
                      • F Offline
                        FuXXz
                        ist es möglich Homematic IP Geräte mit einzuschließen? Ich habe z.B. den HM IP Fensterkontakt HmIP-SWDO-I
                        Viele Grüße
                        • DutchmanD Offline
                          DutchmanD Offline
                          Dutchman
                          @FuXXz:
                          Viele Grüße `
                          sind die datenpunkte fuer IP den anders als welche im script benutzt werden ?
                          addDeviceCounter("lowbat",         $('channel[state.id=*.LOWBAT]'),                      true);
                          addDeviceCounter("sticky_unreach", $('channel[state.id=*.STICKY_UNREACH]'),              true);
                          addDeviceCounter("unreach",        $('channel[state.id=*.UNREACH]'),                     true);
                          addDeviceCounter("config_pending", $('channel[state.id=*.CONFIG_PENDING]'),              true);
                          addDeviceCounter("open_windows",   $('channel{TYPE=SHUTTER_CONTACT}[state.id=*.STATE]'), true);
                          addDeviceCounter("on_lights",      $('channel{TYPE=DIMMER}[state.id=*.LEVEL]'),          function(state){return state>0;});
                          addDeviceCounter("open_shutters",  $('channel{TYPE=BLIND}[state.id=*.LEVEL]'),           function(state){return state>0;});
                          addDeviceCounter("playing_music",  $('channel[state.id=*audio-*.playing]'),              true);
                            tempestas
                            Homematic IP hat als Datenpunkt für Lowbat LOW_BAT
                            Ja, kann man einschließen.
                            • DutchmanD Offline
                              DutchmanD Offline
                              Dutchman
                              @tempestas:
                              Ja, kann man einschließen. `
                              Ich hab mal ueber das script geschaut und sehe das alles ueber device rules gebaut ist, daher solltes es quick & durty reichen diese linie ein zu fuegen:
                              addDeviceCounter("lowbat_IP",      $('channel[state.id=*.LOW_BAT]'),                     true);
                              Das gesammte script sieht dan so aus:
                              //Add device rules
                               * Code - do not change anything bellow this line *
                                      var d_count = 0;
                                      var d_list  = [];
                                              //Get parent object
                                  selector.on(function(obj) {    // bei Zustandänderung *. LOWBAT in allen Gewerken
                                      countDevs(obj);
                                  countDevs();
                              wobei low_bat von IP devices jetzt seperat gezaehlt wird:
                              javascript.0	2017-11-06 14:57:00.785	info	script.js.common.Low_Bat: lowbat(28):
                              javascript.0	2017-11-06 14:57:00.763	info	script.js.common.Low_Bat: lowbat_IP(0):
                              Es geht noch besser um die IP_low bat auf den jetzigen Low_bat hinzu zu zaehlen hab aber so schnell nicht die zeit um das zu verbauen (eventueel jemand andders :)
                              (ich habe keine IP devices)
                                tempestas
                                Pix hatte auf meine Frage damals schon gesschrieben:
                                damit sollte dann der counter lowbat sowohl auf LOWBAT als auch LOW_BAT getriggert werden, oder?
                                Habs nie ausprobiert
                                • DutchmanD Offline
                                  DutchmanD Offline
                                  Dutchman
                                  @tempestas:
                                  Habs nie ausprobiert `
                                  jah werden sie siehe meinen vorige post…. ;)
                                    tempestas
                                    @Dutchman:
                                    @tempestas:
                                    jah werden sie siehe meinen vorige post…. ;) `
                                    ich hatte auf genau das Posting geantwortet. Du hattest geschrieben:
                                    Darauf war meine Antwort bezogen.
                                    • DutchmanD Offline
                                      DutchmanD Offline
                                      Dutchman
                                      @tempestas:
                                      Darauf war meine Antwort bezogen. `
                                      sorry du hast recht mein fehler ! @FuXXz kannst du es dan mal so testen ?
                                      //Add device rules
                                              var d_count = 0;
                                              var d_list  = [];
                                                      //Get parent object
                                              countDevs(obj);
                                          countDevs();
                                      • F Offline
                                        FuXXz
                                        ich wollte den Fensterkontakt zählen lassen, ich glaube diese Zeile ist dafür zuständig.
                                        Ich glaube aber dass die HM IP Kontakte SENSOR heissen, aber wenn ich dies im Script ändere, passiert nichts.
                                        Unter Objekte lowbat_IP sind counter und total beides auf 0
                                        • DutchmanD Offline
                                          DutchmanD Offline
                                          Dutchman
                                          @FuXXz:
                                          Unter Objekte lowbat_IP sind counter und total beides auf 0 `
                                          oeffne mal bitte die raw data des kanaal 1 (ganz rechts auf dem bleistift und dan tab raw(expert).
                                          dan sehen wir was fuer ein typ das ist, sollte dieser abweischen von TYPE=BLIND komt da das problem her
