  3. Einsteigerfragen
  4. gelöst: Shelly 2.5 in shuttercontrol einbinden Hilfe
    5.6k
51 Beiträge 3 Kommentatoren 3.2k Aufrufe 3 Beobachtet
  • W woupi
    @crunchip
    Ich habe gerade auf debug umgestellt und anschließend "OpenAll" auf true gesetzt.
    Hier der passende log dazu.
    shuttercontrol.0
    2022-12-05 19:25:53.828	debug	#0 wait for shutter check end
    shuttercontrol.0
    2022-12-05 19:25:53.817	debug	#0 wait for shutter check started
    shuttercontrol.0
    2022-12-05 19:25:35.878	debug	Shuttercontrol save all shutter states
    shuttercontrol.0
    2022-12-05 18:25:25.888	debug	Position Old value = 101. New value = 100. automatic is active
    shuttercontrol.0
    2022-12-05 18:25:25.888	debug	Shutter state changed: Position old value = 101 new value = 100
    shuttercontrol.0
    2022-12-05 18:25:25.884	debug	#0 wait for shutter check end
    shuttercontrol.0
    2022-12-05 18:25:25.878	debug	shutterUpButton Position old height: 101% new height: 100%
    shuttercontrol.0
    2022-12-05 18:25:25.874	debug	#0 wait for shutter check started
    shuttercontrol.0
    2022-12-05 18:25:25.869	info	Button openAll Set ID: Position value: 100%
    shuttercontrol.0
    2022-12-05 18:25:25.868	debug	start buttonAction
    shuttercontrol.0
    2022-12-05 18:25:23.818	debug	#0 wait for shutter check end
    shuttercontrol.0
    2022-12-05 18:25:23.808	debug	#0 wait for shutter check started
    shuttercontrol.0
    2022-12-05 18:25:17.719	debug	Shuttercontrol save all shutter states
    shuttercontrol.0
    2022-12-05 18:25:07.725	debug	Position Old value = 101. New value = 100. automatic is active
    shuttercontrol.0
    2022-12-05 18:25:07.725	debug	Shutter state changed: Position old value = 101 new value = 100
    shuttercontrol.0
    2022-12-05 18:25:07.724	debug	#0 wait for shutter check end
    shuttercontrol.0
    2022-12-05 18:25:07.718	debug	shutterUpButton Position old height: 101% new height: 100%
    shuttercontrol.0
    2022-12-05 18:25:07.714	debug	#0 wait for shutter check started
    shuttercontrol.0
    2022-12-05 18:25:07.711	info	Button openAll Set ID: Position value: 100%
    shuttercontrol.0
    2022-12-05 18:25:07.710	debug	start buttonAction
    crunchipC Abwesend
    crunchipC Abwesend
    @woupi sagte in Shelly 2.5 in shuttercontrol einbinden Hilfe:
    old height: 101%
    denke das ist ein Problem, gibt keine 101%
    • W woupi
      @crunchip
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      da_WoodyD Online
      da_WoodyD Online
      @woupi hast du den 2.5er richtig kallibriert?
      W 1 Antwort Letzte Antwort
      • da_WoodyD da_Woody
        W Offline
        W Offline
        woupi
        @da_woody
        Das wird der Fehler sein, den kalibriert habe ich nichts.
        Gibt es dazu irgendwo eine Anleitung?
        NUC10i3, Proxmox, VM Ubuntu iobroker, lxc ubuntu influxdb, grafana, lxc ubuntu SAE, lxc ubuntu MotionEye, WP Panasonic Jeisha 5kW mit Heishamon, Shelly 2.5 und 2pm Rolladensteuerung, OpenWB Wallbox
        • W woupi
          @da_woody
          crunchipC Abwesend
          crunchipC Abwesend
          je nach dem welchen Rollo du hast, Endpunkte am Rollo einstellen und dann in der App Referenzfahrt machen
          W 2 Antworten Letzte Antwort
            W Offline
            W Offline
            woupi
            @crunchip
              W Offline
              W Offline
              woupi
              schrieb am zuletzt editiert von woupi
              @crunchip
              Habe ich gemacht, gebracht hat es leider aber nichts.
              Über shelly funktioniert es über shuttercontrol leider nicht.
              shuttercontrol.0
              2022-12-06 05:40:00.005	debug	Sun Elevation: -23.6°
              shuttercontrol.0
              2022-12-06 05:40:00.004	debug	Sun Azimut: 97.1°
              shuttercontrol.0
              2022-12-06 05:40:00.004	debug	calculate astrodata ...
              shuttercontrol.0
              2022-12-06 05:39:51.348	debug	Shuttercontrol save all shutter states
              shuttercontrol.0
              2022-12-06 05:39:47.809	debug	Shuttercontrol save all shutter states
              shuttercontrol.0
              2022-12-06 04:39:44.681	debug	shutterUpButton Position already up at: 100% - setting current action: up
              shuttercontrol.0
              2022-12-06 04:39:44.678	debug	start buttonAction
              shuttercontrol.0
              2022-12-06 04:39:41.347	debug	shutterUpButton Position already up at: 100% - setting current action: up
              shuttercontrol.0
              2022-12-06 04:39:41.344	debug	start buttonAction
              shuttercontrol.0
              2022-12-06 04:39:37.815	debug	Position Old value = 101. New value = 100. automatic is active
              shuttercontrol.0
              2022-12-06 04:39:37.815	debug	Shutter state changed: Position old value = 101 new value = 100
              shuttercontrol.0
              2022-12-06 04:39:37.815	debug	#0 wait for shutter check end
              shuttercontrol.0
              2022-12-06 04:39:37.808	debug	shutterUpButton Position old height: 101% new height: 100%
              shuttercontrol.0
              2022-12-06 04:39:37.804	debug	#0 wait for shutter check started
              shuttercontrol.0
              2022-12-06 04:39:37.802	info	Button openAll Set ID: Position value: 100%
              shuttercontrol.0
              2022-12-06 04:39:37.801	debug	start buttonAction
              shuttercontrol.0
              2022-12-06 04:39:37.657	debug	#0 wait for shutter check end
              shuttercontrol.0
              2022-12-06 04:39:37.646	debug	#0 wait for shutter check started
              shuttercontrol.0
              2022-12-06 04:39:35.888	debug	Shuttercontrol save all shutter states
              shuttercontrol.0
              2022-12-06 04:39:33.337	debug	shutterDownButton Position already down at: 0% - setting current action: down
              shuttercontrol.0
              2022-12-06 04:39:33.334	debug	start buttonAction
              shuttercontrol.0
              2022-12-06 04:39:25.895	debug	Position Old value = 101. New value = 0. automatic is active
              shuttercontrol.0
              2022-12-06 04:39:25.895	debug	Shutter state changed: Position old value = 101 new value = 0
              shuttercontrol.0
              2022-12-06 04:39:25.895	debug	#0 wait for shutter check end
              shuttercontrol.0
              2022-12-06 04:39:25.886	debug	shutterDownButton Position old height: 101% new height: 0%
              shuttercontrol.0
              2022-12-06 04:39:25.884	debug	#0 wait for shutter check started
              shuttercontrol.0
              2022-12-06 04:39:25.882	info	Button closeAll Set ID: Position value: 0%
              shuttercontrol.0
              2022-12-06 04:39:25.881	debug	start buttonAction
              • W woupi
                @crunchip
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                shuttercontrol.0
                crunchipC Abwesend
                crunchipC Abwesend
                @woupi zeig mal das ganze debug log ab start vom adapter
                und zeig mal das Raw vom Datenpunkt, siehe screen, rechts auf den Bleistift
                welche Firmware hat dein shelly?
                  W Offline
                  W Offline
                  woupi
                  @crunchip
                  Vielen Dank, ich werde es aber leider erst heute Abend schaffen (bin auf der Arbeit).
                    W Offline
                    W Offline
                    woupi
                    @crunchip
                    Ich fang mal mit der Firmware an:
                    20221027-092056/v1.12.1-ga9117d3
                    Bei dem zweiten hoffe ich, dass Du das meinst:
                    Hier dann noch der log, von gestern, gesamt bekomme ich den aber nicht hier rein, der ist zu groß. Wie kann ich den denn selektieren, so das nur der Teil kopiert werden kann, der was mit dem shuttercotrol zu tun hat?
                    2022-12-05 18:24:51.321  - info: shuttercontrol.0 (22020) Got terminate signal TERMINATE_YOURSELF
                    2022-12-05 18:24:51.321  - info: shuttercontrol.0 (22020) cleaned everything up...
                    2022-12-05 18:24:51.322  - info: shuttercontrol.0 (22020) terminating
                    2022-12-05 18:24:51.322  - info: shuttercontrol.0 (22020) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2022-12-05 18:24:54.741  - debug: shuttercontrol.0 (73840) Redis Objects: Use Redis connection: 127.0.0.1:9001
                    2022-12-05 18:24:54.773  - debug: shuttercontrol.0 (73840) Objects client ready ... initialize now
                    2022-12-05 18:24:54.774  - debug: shuttercontrol.0 (73840) Objects create System PubSub Client
                    2022-12-05 18:24:54.774  - debug: shuttercontrol.0 (73840) Objects create User PubSub Client
                    2022-12-05 18:24:54.798  - debug: shuttercontrol.0 (73840) Objects client initialize lua scripts
                    2022-12-05 18:24:54.801  - debug: shuttercontrol.0 (73840) Objects connected to redis: 127.0.0.1:9001
                    2022-12-05 18:24:54.815  - debug: shuttercontrol.0 (73840) Redis States: Use Redis connection: 127.0.0.1:9000
                    2022-12-05 18:24:54.822  - debug: shuttercontrol.0 (73840) States create System PubSub Client
                    2022-12-05 18:24:54.823  - debug: shuttercontrol.0 (73840) States create User PubSub Client
                    2022-12-05 18:24:54.836  - debug: shuttercontrol.0 (73840) States connected to redis: 127.0.0.1:9000
                    2022-12-05 18:24:54.915  - debug: shuttercontrol.0 (73840) Plugin sentry Initialize Plugin (enabled=true)
                    2022-12-05 18:24:55.114  - info: shuttercontrol.0 (73840) starting. Version 1.4.18 in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v14.21.1, js-controller: 4.0.21
                    2022-12-05 18:24:55.130  - debug: shuttercontrol.0 (73840) shutter Config Check started
                    2022-12-05 18:24:55.130  - debug: shuttercontrol.0 (73840) shutter Config Check successfully completed
                    2022-12-05 18:24:55.132  - debug: shuttercontrol.0 (73840) Shutter State: shelly.0.SHSW-25#3494547C201A#1.Shutter.Position
                    2022-12-05 18:24:55.138  - debug: shuttercontrol.0 (73840) Position: save settings
                    2022-12-05 18:24:58.209  - debug: shuttercontrol.0 (73840) Travel times of the shutters are calculated
                    2022-12-05 18:24:58.210  - debug: shuttercontrol.0 (73840) calculate astrodata ...
                    2022-12-05 18:24:58.210  - debug: shuttercontrol.0 (73840) goldenHourEnd today: 08:14
                    2022-12-05 18:24:58.210  - debug: shuttercontrol.0 (73840) goldenHour today: 14:28
                    2022-12-05 18:24:58.210  - debug: shuttercontrol.0 (73840) current day: 1
                    2022-12-05 18:24:58.211  - debug: shuttercontrol.0 (73840) Sunrise today: 07:16
                    2022-12-05 18:24:58.211  - debug: shuttercontrol.0 (73840) Sunset today: 15:26
                    2022-12-05 18:24:58.211  - debug: shuttercontrol.0 (73840) Starting up shutters GoldenHour area: 08:44
                    2022-12-05 18:24:58.211  - debug: shuttercontrol.0 (73840) Shutdown shutters GoldenHour area: 14:58
                    2022-12-05 18:24:58.211  - debug: shuttercontrol.0 (73840) Starting up shutters Sunrise area: 07:46
                    2022-12-05 18:24:58.211  - debug: shuttercontrol.0 (73840) Shutdown shutters Sunset area: 15:56
                    2022-12-05 18:24:58.230  - debug: shuttercontrol.0 (73840) check IsLater : 07:46 08:00
                    2022-12-05 18:24:58.230  - debug: shuttercontrol.0 (73840) check IsLater : 07:46 05:00
                    2022-12-05 18:24:58.230  - debug: shuttercontrol.0 (73840) yes, IsLater : 07:46 05:00
                    2022-12-05 18:24:58.230  - debug: shuttercontrol.0 (73840) check IsEarlier : 07:46 08:00
                    2022-12-05 18:24:58.231  - debug: shuttercontrol.0 (73840) yes, IsEarlier : 07:46 08:00
                    2022-12-05 18:24:58.231  - debug: shuttercontrol.0 (73840) Starting up shutters living area: 07:46 debug 5
                    2022-12-05 18:24:58.235  - debug: shuttercontrol.0 (73840) check IsLater : 07:46 06:30
                    2022-12-05 18:24:58.236  - debug: shuttercontrol.0 (73840) yes, IsLater : 07:46 06:30
                    2022-12-05 18:24:58.236  - debug: shuttercontrol.0 (73840) Starting up shutters sleep area: 06:30 debug 4
                    2022-12-05 18:24:58.239  - debug: shuttercontrol.0 (73840) check IsLater : 07:46 06:30
                    2022-12-05 18:24:58.239  - debug: shuttercontrol.0 (73840) yes, IsLater : 07:46 06:30
                    2022-12-05 18:24:58.239  - debug: shuttercontrol.0 (73840) Starting up shutters children area: 06:30 debug 4
                    2022-12-05 18:24:58.242  - debug: shuttercontrol.0 (73840) check IsLater : 15:56 22:00
                    2022-12-05 18:24:58.242  - debug: shuttercontrol.0 (73840) check IsEarlier : 15:56 22:00
                    2022-12-05 18:24:58.242  - debug: shuttercontrol.0 (73840) yes, IsEarlier : 15:56 22:00
                    2022-12-05 18:24:58.242  - debug: shuttercontrol.0 (73840) Shutdown shutters living area: 15:56 debug 7
                    2022-12-05 18:24:58.242  - debug: shuttercontrol.0 (73840) shutterDownLiving
                    2022-12-05 18:24:58.249  - debug: shuttercontrol.0 (73840) Shutdown shutters children area: 15:56 debug 7
                    2022-12-05 18:24:58.254  - debug: shuttercontrol.0 (73840) Shutdown shutters sleep area: 15:56 debug 7
                    2022-12-05 18:24:58.271  - debug: shuttercontrol.0 (73840) complete down at 22:00
                    2022-12-05 18:25:00.015  - debug: shuttercontrol.0 (73840) calculate astrodata ...
                    2022-12-05 18:25:00.015  - debug: shuttercontrol.0 (73840) Sun Azimut: 267.4°
                    2022-12-05 18:25:00.015  - debug: shuttercontrol.0 (73840) Sun Elevation: -27.2°
                    2022-12-05 18:25:07.710  - debug: shuttercontrol.0 (73840) start buttonAction
                    2022-12-05 18:25:07.711  - info: shuttercontrol.0 (73840) Button openAll Set ID: Position value: 100%
                    2022-12-05 18:25:07.714  - debug: shuttercontrol.0 (73840) #0 wait for shutter check started
                    2022-12-05 18:25:07.718  - debug: shuttercontrol.0 (73840) shutterUpButton Position old height: 101% new height: 100%
                    2022-12-05 18:25:07.724  - debug: shuttercontrol.0 (73840) #0 wait for shutter check end
                    2022-12-05 18:25:07.725  - debug: shuttercontrol.0 (73840) Shutter state changed: Position old value = 101 new value = 100
                    2022-12-05 18:25:07.725  - debug: shuttercontrol.0 (73840) Position Old value = 101. New value = 100. automatic is active
                    2022-12-05 18:25:17.719  - debug: shuttercontrol.0 (73840) Shuttercontrol save all shutter states
                    2022-12-05 18:25:23.808  - debug: shuttercontrol.0 (73840) #0 wait for shutter check started
                    2022-12-05 18:25:23.818  - debug: shuttercontrol.0 (73840) #0 wait for shutter check end
                    2022-12-05 18:25:25.868  - debug: shuttercontrol.0 (73840) start buttonAction
                    2022-12-05 18:25:25.869  - info: shuttercontrol.0 (73840) Button openAll Set ID: Position value: 100%
                    2022-12-05 18:25:25.874  - debug: shuttercontrol.0 (73840) #0 wait for shutter check started
                    2022-12-05 18:25:25.878  - debug: shuttercontrol.0 (73840) shutterUpButton Position old height: 101% new height: 100%
                    2022-12-05 18:25:25.884  - debug: shuttercontrol.0 (73840) #0 wait for shutter check end
                    2022-12-05 18:25:25.888  - debug: shuttercontrol.0 (73840) Shutter state changed: Position old value = 101 new value = 100
                    2022-12-05 18:25:25.888  - debug: shuttercontrol.0 (73840) Position Old value = 101. New value = 100. automatic is active
                    2022-12-05 18:25:35.878  - debug: shuttercontrol.0 (73840) Shuttercontrol save all shutter states
                    2022-12-05 18:25:53.817  - debug: shuttercontrol.0 (73840) #0 wait for shutter check started
                    2022-12-05 18:25:53.828  - debug: shuttercontrol.0 (73840) #0 wait for shutter check end
                    • crunchipC Abwesend
                      crunchipC Abwesend
                      @woupi ich hab keinen Plan woher bei dir die 101% her kommt
                      was zeigt den der Datenpunkt level an, wenn
                      • ganz oben
                      • ganz unten
                        • ganz oben
                        • ganz unten
                        W Offline
                        W Offline
                        woupi
                        @crunchip
                        Den Datenpunkt level finde ich weder beim shelly noch bei shuttercontrol.
                        Oder meinst Du position level.blind?
                        Der zeigt immer 101% egal ob ganz oben oder ganz unten
                        • W woupi
                          @crunchip
                          crunchipC Abwesend
                          crunchipC Abwesend
                          eben, das zeigt auch das log
                          kalibriert hast du ja und Haken ist auch gesetzt?
                            W Offline
                            W Offline
                            woupi
                            @crunchip
                            Ja, genau
                              crunchipC Abwesend
                              @woupi also entweder liegt das an der aktuellen Firmware, (ich hab noch die vorherige) oder das stimmt irgendwas anderes nicht.
                              hab nur das dazu gefunden
                              https://forum.iobroker.net/post/292970
                              heisst, noch mal kalibrieren
                              andernfalls, würde ich den shelly mal komplett zurück setzen und neu konfigurieren
                                W Offline
                                W Offline
                                woupi
                                @crunchip
                                Ok, danke für deine Hilfe, das werde ich dann am besten am WE, in Ruhe, machen.
                                • W woupi
                                  @crunchip
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  @woupi kalibrier doch erstmal neu, vllt hilft es ja schon
                                    W Offline
                                    W Offline
                                    woupi
                                    @crunchip
                                    Das habe ich zwischendurch, natürlich, schon mehrfach versucht, ohne Erfolg.
                                    • W woupi
                                      @crunchip
                                      crunchipC Abwesend
                                      crunchipC Abwesend
                                      @woupi ok, was wird den im shelly bei % angezeigt? wenn du ihn verfährst
                                        W Offline
                                        W Offline
                                        woupi
                                        @crunchip
                                        Ich habe in der app gesucht, über die ip auf der WEB Oberfläche, aber ich finde keine Info über die Position in Prozent,
                                        • W woupi
                                          @crunchip
                                          crunchipC Abwesend
                                          crunchipC Abwesend
                                          @woupi sieht das nicht so aus?
