    6.8k
lovelace uinspanelsonoff
8.1k Beiträge 280 Kommentatoren 8.5m Aufrufe 260 Beobachtet
  • VumerV Vumer
    @tt-tom
    host.iobroker
    	2022-12-05 22:08:00.330	info	instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    javascript.0
    	2022-12-05 22:07:54.685	error	at processImmediate (node:internal/timers:466:21)
    javascript.0
    	2022-12-05 22:07:54.685	error	at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5909:56)
    javascript.0
    	2022-12-05 22:07:54.685	error	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
    javascript.0
    	2022-12-05 22:07:54.684	error	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
    javascript.0
    	2022-12-05 22:07:54.684	error	at Object.<anonymous> (script.js.common.NSPanel.Abfallkalender:61:18)
    javascript.0
    	2022-12-05 22:07:54.684	error	at subsequenceFromStartLast (script.js.common.NSPanel.Abfallkalender:52:24)
    javascript.0
    	2022-12-05 22:07:54.684	error	script.js.common.NSPanel.Abfallkalender: TypeError: Cannot read properties of null (reading 'length')
    host.iobroker
    	2022-12-05 22:07:51.554	info	instance system.adapter.ical.0 started with pid 14903
    host.iobroker
    	2022-12-05 22:07:51.539	info	instance scheduled system.adapter.ical.0 17 */6 * * *
    host.iobroker
    	2022-12-05 22:07:48.359	info	stopInstance canceled schedule system.adapter.ical.0
    host.iobroker
    	2022-12-05 22:07:48.359	info	stopInstance system.adapter.ical.0 (force=false, process=false)
    host.iobroker
    	2022-12-05 22:07:33.750	info	instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    es reich dem iCal Adapter neu zu starten
    aber nur wenn das Script leuft
    ArmilarA Offline
    ArmilarA Offline
    Armilar
    Most Active Forum Testing
    #1053
    @vumer
    ist die Tagesvorschau groß genug?
    Es sollten mindestens 4 Events erzeugt werden. Auch wenn die zum Teil über mehrere Wochen stattfinden.
    Da die einzige Längenermittlung im Skript ein Problem verursacht, könnte ich mir vorstellen, dass es bei der subsequenceFromStartLast stattfindet, jedoch kein 3. oder 4. Eintrag gefunden wird und dann der Fehler kommt. 🙄
    VumerV 1 Antwort Letzte Antwort
    • ArmilarA Armilar
      @vumer
      VumerV Offline
      VumerV Offline
      Vumer
      #1054
      @armilar sagte in SONOFF NSPanel mit Lovelace UI:
      Das war es. Ich hatte 14 Tage
      Danke.
      ArmilarA T 2 Antworten Letzte Antwort
      • VumerV Vumer
        Danke.
        ArmilarA Offline
        ArmilarA Offline
        Armilar
        #1055
        @vumer
        Ja, hätte mich auch sonst gewundert ;-)
        Jetzt noch die Warnungen (Aliase) drauflegen und ab ins Panel
        • ArmilarA Armilar
          @vumer
          VumerV Offline
          VumerV Offline
          Vumer
          #1056
          Was meinst du mit den Warnungen (Aliase)? Termine? Die sind schon lenger im Panel.
          • VumerV Vumer
            ArmilarA Offline
            ArmilarA Offline
            Armilar
            #1057
            @vumer
            Ach so, die sind schon drin. Na dann aber jetzt wieder alle 😊
            • ArmilarA Armilar
              @vumer
              VumerV Offline
              VumerV Offline
              Vumer
              #1058
              @armilar
              Ich hab nur Allergie auf rot im Log. Bei gelb gehts mir auch nicht gut
              • B bean
                Danke für die coole Arbeit, mein Panel ist schon im "Produktiveinsatz":
                https://youtu.be/qEbxVWK6y8U
                Viel Homematic, Zigbee Sensoren und Steckdosen, Ikea Rollos, Toshiba Klimaanlage, Nuki Türschloss...
                Was ich noch für "Probleme" habe:
                • Ich schaffe es nicht, die beiden Hardwaretasten vernünftig zu konfigurieren, bei mir wechsel ich mit denen immer zwischen den Seiten, sie haben also die gleiche Funktion wie die beiden Navigationspfeile oben links und rechts. (Obwohl ich eine Seite unter der Buttonpagefunction hinterlegt habe)
                • Und zum neuen "Haus"-Symbol rechts oben: Muss das irgendwo konfiguriert werden? Bei mir geschieht nichts, wenn ich da drauftippe...
                ArmilarA Offline
                ArmilarA Offline
                Armilar
                #1059
                @bean
                Ist ja ein cooles Video. Und schon richtig viel drin... hatte ich vorhin gar nicht ganz wahrgenommen 👍
                • VumerV Vumer
                  @armilar
                  ArmilarA Offline
                  ArmilarA Offline
                  Armilar
                  #1060
                  @vumer
                  rot ist auch nicht meine Farbe im Log. Mit gelb kann ich leben, wenns nicht von meinen Sachen kommt 😂
                  • VumerV Vumer
                    Danke.
                    TT-Tom
                    #1061
                    HI @vumer,
                    schön das es läuft. Viel Spass weiter mit dem Panel.
                    Gruß Tom
                    Public Transport
                    NSPanel Adapter Wiki
                    • V Offline
                      V Offline
                      valbuz
                      #1062
                      Hallo
                      Bin auch dabei meine Erfahrungen mit dem Panel zu sammeln.
                      Soweit läuft's auch.
                      Bin jedoch noch etwas mit dem Screensaver am verhandeln... 😑
                      Wer kann mir die einzelnen Einstellungen kurz erklären? Siehe Bild.
                      Ebenfalls ändert sich nichts wenn ich folgenden Wert in der Script Datei ändere:
                      dimmode: 8,
                      Wie verhalten sich all diese Einstellungen untereinander? 🙄
                      Danke 🙏
                      2xProxmox auf NUC
                      E3DC 13kWh Speicher via RCSP an ioBroker
                      • ArmilarA Armilar
                        @bean
                        Manchmal überholen sich die Ereignisse. Das Haus-Symbol ist zwar schon zu sehen, bekommt erst mit der nächsten Script-Version eine Funktion.
                        Lies dir zu den Hardwaretasten kurz https://github.com/joBr99/nspanel-lovelace-ui/wiki/NSPanel-Tasmota-FAQ durch.
                        Falls das nicht dabei ist, nochmal melden...
                        froitzheims
                        schrieb am zuletzt editiert von froitzheims
                        #1063
                        @armilar
                        vielen leben Dank
                        nach dem Update auf die 16.X gab es noch das Problem mit dem nicht angezeigten device Adapter.
                        Ich habe auf Ubuntu eine IOBROKER Test installation dort habe ich aus meinem Echtsystem einmal das Backup zurück gespielt.
                        Und siehe da man konnte dort den Device Adapter danach installieren.
                        Ich habe versucht heraus zu finden warum das so ist.
                        Bin aber nicht wirklich weitergekommen hatten den Sourceanalytics im Verdacht.
                        Heute habe ich dann einfach ein Backup auf meinem Echtsystem zurückgespielt.
                        Dan konnte ich den Device Adapter installieren und kann jetzt endlich weiter testen .
                        Gruß Marcus
                        • V valbuz
                          Hallo
                          dimmode: 8,
                          Danke 🙏
                          ArmilarA Offline
                          ArmilarA Offline
                          Armilar
                          #1064
                          @valbuz
                          Ich mach es dann mal mit der Erklärung ;-)
                          Das Panel hat die Aliase vom Typ Slider erstellt, die wiederum greifen auf 4 Datenpunkte in 0_userdata (hat das Script dir ebenfalls erstellt) zu.
                          0_userdata.0.NSPanel.1.NSPanel_Dimmode_brightnessDay ist die Helligkeit (bei dir aktuell 10) des Displays, die mit der Stunde Tag (bei dir aktuell 10:00 Uhr = hourDay) beginnt.
                          0_userdata.0.NSPanel.1.NSPanel_Dimmode_brightnessDay ist die Helligkeit (bei dir aktuell 2) des Displays, die mit der Stunde Nacht (bei dir aktuell 5:00 Uhr = hourNight) beginnt.
                          Deine aktuellen Einstellungen:
                          Bei dir fängt der Abend/Nacht um 5:00 Uhr an. In dieser Zeit bis zum Tagesbeginn um 10:00 Uhr (d.h. 5 Stunden später) wird das Screensaver-Display auf Helligkeit 2% gestellt. Ab 10:00 Uhr fängt bei dir der Tag an. Das Display wechselt im Screensaver auf 10% Helligkeit.
                          Der Parameter dimmode: 8, ist noch ein Relikt aus alten Zeiten (Als es noch keine DP's gab und das Panel nur einen Zustand kannte) und wird nirgendwo mehr im Code verwendet.
                          Zu den definierten Stunden stellt jeweils ein Scheduler im Script die Helligkeiit um. Bei Start des Scriptes erfolgt ebenfalls eine initiale Überprüfung.
                          //Subpage 2 von Subpages_2
                                 let NSPanel_Einstellungen: PageEntities =
                                     'type': 'cardEntities',
                                     'heading': 'Screensaver',
                                     'useColor': true,
                                     'subPage': true,
                                     'parent': Service,
                                     'items': [
                                         <PageItem>{ id: AliasPath + 'Dimmode.brightnessDay', name: 'Brightness Tag', icon: 'brightness-5', offColor: MSYellow, onColor: MSYellow, useColor: true, minValue: 5, maxValue: 10},
                                         <PageItem>{ id: AliasPath + 'Dimmode.brightnessNight', name: 'Brightness Nacht', icon: 'brightness-4', offColor: MSYellow, onColor: MSYellow, useColor: true, minValue: 0, maxValue: 4},
                                         <PageItem>{ id: AliasPath + 'Dimmode.hourDay', name: 'Stunde Tag', icon: 'sun-clock', offColor: MSYellow, onColor: MSYellow, useColor: true, minValue: 0, maxValue: 23},
                                         <PageItem>{ id: AliasPath + 'Dimmode.hourNight', name: 'Stunde Nacht', icon: 'sun-clock-outline', offColor: MSYellow, onColor: MSYellow, useColor: true, minValue: 0, maxValue: 23}
                          In diesen pageItems findest du ebenfalls die Einstellungen für die Slider in Form von minValue und maxValue. Die können natürlich angepasst werden.
                          • F froitzheims
                            @armilar
                            vielen leben Dank
                            Gruß Marcus
                            ArmilarA Offline
                            ArmilarA Offline
                            Armilar
                            #1065
                            @froitzheims
                            Sehr gerne. Noch ein Tipp für die Zukunft...
                            Unter Info und dann unter Systeminformationen rechts:
                            findest du die Node.js Version ebenfalls. Wenn die gelb oder rot wird, steht in der Regel auch die empfohlene Version dabei. Wenn es eine empfohlene Version gibt, sollte die nach Möglichkeit auch unmittelbar installiert werden. Die wird immer entsprechend korrekte Funktionalitäten für den ioBroker zur Verfügung stellen. Anderenfalls kann es zu Problemen in der Ausführung kommen!
                            Der Satz "Never touch a running System" ist das dümmste was man in der Server-Welt machen kann. Die vorherige Version ist bereits fehlerbehaftet und die neue Version beinhaltet bereits das "Pflaster" für diese Fehler. Gilt auch für das Betriebssystem.
                            Konntest du damit auch das Sprachthema erledigen?
                            • ArmilarA Armilar
                              @valbuz
                                         'useColor': true,
                                         'subPage': true,
                                         'parent': Service,
                                         'items': [
                              V Offline
                              V Offline
                              valbuz
                              #1066
                              @armilar Da Danke ich vielmals! 👍 😊
                              Ja bei Relikten aus alten Zeiten, wird's schwierig um eine Logik zu finden 😳
                              Danke nochmals.
                              Pat
                              2xProxmox auf NUC
                              • J joBr99
                                @armilar said in SONOFF NSPanel mit Lovelace UI:
                                Die 12.2.0.6 scheint dann wohl wieder ein neues Problem zu haben.
                                Also ich hab gerade mal ein Panel auf 12.2.0.6/aktuelle dev version geupdated, funktioniert alles wie es soll. Das Fehlerbild mit >= 12.2.0.4 war allerdings auch, dass der Ladebalken bei 0% stehen geblieben ist. Wo die 8080808080 herkamen haben wir nicht so ganz herausgefunden gehabt, war aber dann auch irgendwie weg.
                                W Offline
                                W Offline
                                Woffi1967
                                #1067
                                @jobr99 : Hallo jobr99,
                                sorry wenn ich jetzt diesen Weg wähle.
                                Leider finde ich keinen Button um ein neues Thema zu öffnen.
                                Ich habe ein Problem, das Scritpt NSPanelTS.ts zu starten. Ich bekomme die Fehlermeldung
                                javascript.0 (1433) script.js.common.NSPANEL_1_3_6_0_3 compile failed: at script.js.common.NSPANEL_1_3_6_0_3:166
                                In der Zeile 166 steht folgender Befehl: let timeoutSlider: any;
                                Würde mich über eine Hilfe freuen.
                                Mfg Wolfgang
                                ArmilarA 2 Antworten Letzte Antwort
                                • W Woffi1967
                                  Mfg Wolfgang
                                  ArmilarA Offline
                                  ArmilarA Offline
                                  Armilar
                                  #1068
                                  @woffi1967
                                  Hi und erstmal herzlich willkommen.
                                  Neues Thema ist gar nicht erforderlich und somit absolut korrekt gemacht. @joBr99 ist übrigens für die Nextion-TFT-Firmware und Home Assistant zuständig. Deshalb übernehme ich mal im Bereich TS-Script und ioBroker...
                                  Könntest du das Log mit den Fehlern kurz in Code-Tags posten? Oben in der Menüleiste f163ce7f-a28b-419e-b388-5c144fff3ec8-image.png
                                  Nur mit der Info des timeoutSlider kann ich erstmal alleine nichts anfangen.
                                  EDIT: Die Fehlersuche ist oft nicht einfach, da die Zeilennummern (in deinem Fall 166) nicht auf den Fehler hinweisen. Ist eher eine Näherung ;-)
                                  • W Woffi1967
                                    Mfg Wolfgang
                                    ArmilarA Offline
                                    ArmilarA Offline
                                    Armilar
                                    #1069
                                    @woffi1967
                                    Ich tippe übrigens auf die IconSelector, also das 2. TypeScript, dass die Icons enthält und im global angelegt sein muss (und natürlich angeschaltet)
                                    Bist du nach dieser Anleitung vorgegangen?
                                    https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker---Basisinstallation
                                      bean
                                      schrieb am zuletzt editiert von bean
                                      #1070
                                      Seit neuesten bekomme ich beim Start des Scripts zwei Zeilen mit den roten Fehlern
                                      Error by subscription (trigger): empty ID defined. All states matched.
                                      Ich vermute, irgendein Datenpunkt in den Aliasen passt nicht, aber kann ich das irgendwie debuggen bzw selber draufkommen, welche Subscription den Fehler auslöst?
                                      Das Skript startet trotzdem und läuft scheinbar auch fehlerfrei, aber rot ist doch störend 😰
                                      • B bean
                                        ArmilarA Offline
                                        ArmilarA Offline
                                        Armilar
                                        #1071
                                        @bean
                                        rot ist nicht so schön ;-) Ich habe auch nicht die geringste Ahnung, warum sich das nicht in Pink umstellen lässt.
                                        Nee, mal kurz Spaß beiseite. Stell mal im Script-Editor oben in der Ecke:
                                        im Schraubenschlüssel den Haken bei "Ausführliche Protokollausgaben" rein und starte mal durch. Danach sende mal das Log mit den Fehlern in rot und so ein klein wenig an Log-Infos drumherum hier in Code-Tags.
                                        Evtl. siehst du selbst die Fehlerquelle schon...
                                        • ArmilarA Armilar
                                          @bean
                                          bean
                                          #1072
                                          Ah! Aber die Fehlerquelle ist noch unklar
                                          19:30:47.180	info	javascript.0 (557640) script.js.common.NSPanel.1: subscribe: {"pattern":{"id":"0_userdata.0.NSPanel_1.Relay.1","change":"ne","q":0},"name":"script.js.common.NSPanel.1"}
                                          19:30:47.181	info	javascript.0 (557640) script.js.common.NSPanel.1: subscribe: {"pattern":{"id":"0_userdata.0.NSPanel_1.Relay.2","change":"ne","q":0},"name":"script.js.common.NSPanel.1"}
                                          19:30:47.181	error	javascript.0 (557640) script.js.common.NSPanel.1 Error by subscription (trigger): empty ID defined. All states matched.
                                          19:30:47.182	info	javascript.0 (557640) script.js.common.NSPanel.1: Wetter-Alias existiert bereits
                                          19:30:47.183	info	javascript.0 (557640) script.js.common.NSPanel.1: subscribe: {"pattern":{"id":"0_userdata.0.NSPanel_1.PageNavi","change":"any","q":0},"name":"script.js.common.NSPanel.1"}
                                          Scheinbar werden die beiden Relais-Datenpunkte abonniert, dann zwei Fehler, und dann geht es mit dem Wetter etc. weiter. Oder lese ich das falsch? Danke!
                                          EDIT: Hat sicher erledigt - ich hatte bei mrIcon1ScreensaverEntity und mrIcon2ScreensaverEntity unter entity "null" eingetragen weil ich keine Icons oben haben wollte, in der letzten Scriptversion warf das noch keinen Fehler.
