    6.8k
lovelace uinspanelsonoff
8.1k Beiträge 280 Kommentatoren 8.5m Aufrufe 260 Beobachtet
  • H Offline
    hansano
    #1026
    @scribere8146 said in SONOFF NSPanel mit Lovelace UI:
    @hansano ich hab ein eigenes script dafür..
    Danke das werde ich gleich mal testen
    • T tobiasp
      erstmal Top Arbeit ich habe auch alles soweit eingerichtet nach den Anleitungen aber etliche "Warn" Meldungen.
      javascript.0
      	2022-11-12 14:29:30.051	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5909:56)
      javascript.0
      	2022-11-12 14:29:30.051	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:596:29)
      javascript.0
      	2022-11-12 14:29:30.048	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1214:38)
      javascript.0
      	2022-11-12 14:29:30.048	warn	at Object.<anonymous> (script.js.NsPanel_EG.NS_Panel:1135:12)
      javascript.0
      	2022-11-12 14:29:30.048	warn	at __awaiter (script.js.NsPanel_EG.NS_Panel:4:12)
      javascript.0
      	2022-11-12 14:29:30.047	warn	at new Promise (<anonymous>)
      javascript.0
      	2022-11-12 14:29:30.047	warn	at script.js.NsPanel_EG.NS_Panel:8:71
      javascript.0
      	2022-11-12 14:29:30.047	warn	at Object.next (script.js.NsPanel_EG.NS_Panel:14:53)
      javascript.0
      	2022-11-12 14:29:30.046	warn	at step (script.js.NsPanel_EG.NS_Panel:33:23)
      javascript.0
      	2022-11-12 14:29:30.046	warn	at Object.<anonymous> (script.js.NsPanel_EG.NS_Panel:1138:13)
      javascript.0
      	2022-11-12 14:29:30.046	warn	at HandleScreensaverUpdate (script.js.NsPanel_EG.NS_Panel:4462:29)
      javascript.0
      	2022-11-12 14:29:30.042	warn	getState "mqtt.0.SmartHome.NSPanel_1.stat.POWER2" not found (3)
      javascript.0
      	2022-11-12 14:29:30.042	warn	at processImmediate (node:internal/timers:466:21)
      javascript.0
      	2022-11-12 14:29:30.042	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5909:56)
      Was sind das für Warnmeldungen?
      Martin c
      #1027
      @tobiasp was genau war denn dein Fehler? Vielleicht habe ich zufällig den gleichen.
      • F froitzheims
        Hi Habe ein US Panel
        alles wie in der Anleitung gemacht mit dem Scripts unter
        global icon_mapping erstellt
        und unter common das NSPanel1
        die Beiden Punkte angepasst für den Panel Namen.
        Alias werden angelegt und der Screensaver läuft in englisch.
        Und es werden in den Ansichten keine Icons angezeigt.
        Was mache ich falsch ?
        Gruß Marcus
        Kuckuckmann
        #1028
        @froitzheims
        willkommen im Forum.
        Hast Du in deinem Skript locale: 'de-DE' eingestellt? Ich verstehe es so, dass EN für dich nicht korrekt ist, richtig?
        Was hast Du auf der Seite Büro denn konfiguriert? hast Du für das, was Du anzeigen willst auch Alias(e) angelegt?
        hast Du auch die 5 Zeile auf der cardEntities aktiviert? Das noch als kleiner Tip, dafür muss 0_userdata.0.NSPanel.1.NSPanel_Version auf "us" stehen.
        LG
        NSPanel Dokumentation im GitHub Wiki:
        • M Martin c
          ArmilarA Offline
          ArmilarA Offline
          Armilar
          Most Active Forum Testing
          #1029
          @martin-c
          Du könntest deine Warungen im Log auch einfach in Code-Tags posten...
          Kleiner Tipp... Falls es ähnlich aussieht. Die beiden Status-Icons hatten den falschen MQTT-Topic in der Config
          Die müssen ebenfalls angepasst werden.
          • F froitzheims
            Gruß Marcus
            ArmilarA Offline
            ArmilarA Offline
            Armilar
            #1030
            @froitzheims
            Die Anzeige in englischer Sprache, kann vielfältige Ursachen haben. Die häufigsten Ursachen waren ein veraltetes node.js oder falsche Einstellungen der Locales im Betriebssystem. Hierzu bräuchten wir etwas mehr Infos. Die node.js Version bekommst du im Systemterminal mit node -v heraus und dann wäre noch interessant, welches Betriebssystem du hast und auf welcher Hardware es läuft.
            Wie @Kuckuckmann schon gesagt hat, kann das US-Panel 5 Zeilen anzeigen. Hierzu in der Config von eu auf us umstellen.
            Das wird aber nicht dein Problem lösen, dass du in der ersten konfigurierten Seite hast. Die Pages mit den Autoaliasen funktionieren, daher vermute ich, dass etwas mit den selbsterstellten Seiten nicht stimmt. Sende mal in Code-Tags bitte deine Variablen für die Büro-Seite und die Config. Ich vermute, dass du mit Datenpunkten, statt Aliasen arbeitest oder die Seite nicht in der Config eingetragen hast. Kann ich aber erst sehen, wenn du sie sendest.
            F 1 Antwort Letzte Antwort
            • ArmilarA Armilar
              @froitzheims
              froitzheims
              schrieb am zuletzt editiert von froitzheims
              #1031
              @armilar
              also Node -v
              v12.22.12
              ist ein Raspi4 mit 64 Bit system
              PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
              NAME="Debian GNU/Linux"
              VERSION_ID="11"
              VERSION="11 (bullseye)"
              VERSION_CODENAME=bullseye
              ID=debian
              das Script Büro ist:
              let Buero_Seite_1: PageEntities =
              "type": "cardEntities",
              "heading": "Büro",
              "useColor": true,
              "subPage": false,
              "parent": undefined,
              "items": [
              <PageItem>{ id: "alias.0.Lampe Holz", interpolateColor: true},
              <PageItem>{ id: "alias.0.NSPanel_1.Deckenbeleuchtung", interpolateColor: true},
              <PageItem>{ id: "alias.0.NSPanel_1.Testlampe2", name: "Filamentlampe", minValueBrightness: 0, maxValueBrightness: 70, interpolateColor: true},
              <PageItem>{ id: "alias.0.NSPanel_1.Luftreiniger", icon: "power", icon2: "power",offColor: MSRed, onColor: MSGreen}
              Alias habe ich für die Lampe so angelegt mit dem Alias Manager (Geräte wird bei mir nicht angezeigt obwohl istalliert)
              Die NSPanel_Version steht auf US-p
              Thomas BraunT ArmilarA K 3 Antworten Letzte Antwort
                bean
                #1032
                Danke für die coole Arbeit, mein Panel ist schon im "Produktiveinsatz":
                https://youtu.be/qEbxVWK6y8U
                Viel Homematic, Zigbee Sensoren und Steckdosen, Ikea Rollos, Toshiba Klimaanlage, Nuki Türschloss...
                Was ich noch für "Probleme" habe:
                • Ich schaffe es nicht, die beiden Hardwaretasten vernünftig zu konfigurieren, bei mir wechsel ich mit denen immer zwischen den Seiten, sie haben also die gleiche Funktion wie die beiden Navigationspfeile oben links und rechts. (Obwohl ich eine Seite unter der Buttonpagefunction hinterlegt habe)
                • Und zum neuen "Haus"-Symbol rechts oben: Muss das irgendwo konfiguriert werden? Bei mir geschieht nichts, wenn ich da drauftippe...
                ArmilarA 2 Antworten Letzte Antwort
                • ArmilarA Armilar
                  @lobomau sagte in SONOFF NSPanel mit Lovelace UI:
                  Wenn ich den setze, bewegt sich nichts. Nur umgekehrt, wenn ich level setze ändert sich DIRECTION.
                  Kann man also mit zusätzlichen Datenpunkten und z.B. Blockly umsetzen (z.B. in 0_userdata).
                  UP = true (aktualisiert) --> Level = 100
                  DOWN = true (aktualisiert) --> Level = 0
                  Dann Alias auf diese Datenpunkte. Sollte nachbildbar sein...
                  bean
                  #1033
                  @armilar said in SONOFF NSPanel mit Lovelace UI:
                  Noch einfacher gehts, wenn man die Schreibfunktionen des Datenpunkts im Devicemanager bearbeitet:
                  (Im Beispiel wird Level auf 100 (geöffnet) gesetzt, wenn der Datenpunkt OPEN getriggert/true wird)
                  • F froitzheims
                    @armilar
                    also Node -v
                    v12.22.12
                    VERSION_ID="11"
                    ID=debian
                    "heading": "Büro",
                    "useColor": true,
                    "subPage": false,
                    "items": [
                    #1034
                    @froitzheims sagte in SONOFF NSPanel mit Lovelace UI:
                    v12.22.12
                    Zu alt, nodeJS@12 ist abgekündigt. Installier da nodeJS@16.
                    • F froitzheims
                      @armilar
                      also Node -v
                      v12.22.12
                      VERSION_ID="11"
                      ID=debian
                      "heading": "Büro",
                      "useColor": true,
                      "subPage": false,
                      "items": [
                      ArmilarA Offline
                      ArmilarA Offline
                      Armilar
                      #1035
                      @froitzheims
                      Zuerst mal die locales checken:
                      sudo raspi-config
                      dann zu Set locale navigieren und de_DE.UTF-8 auswählen (falls noch nicht aktiv)
                      mit
                      sudo apt-get update
                      sudo apt-get dist-upgrade
                      auf den neuesten Stand bringen.
                      Dann node.js updaten auf die empfohlene Version 16.18.1 (npm zieht sich automatisch auf die 8.19.2) Am Besten nach der Anleitung (und bitte keine 18.X.X):
                      https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
                      Deine Laufzeitumgebung für JavaScript (und das ist node.js) und somit die Laufzeitumgebung für den kompletten ioBroker und auch das TS-Script ist völlig veraltet. Daher bitte updaten.
                      Die us-p Version ist okay - muss nichts geändert werden!
                      Die Aliase sind nicht korrekt. Versuche den Geräte-Manager nach dem node.js Update nochmal in Gang zu bringen. Der Alias-Manager kann das zwar auch, jedoch brauchst du hierfür Erfahrung.
                      Deine Datenpunkte im Alias sind allesamt falsch benannt. Eine Lampe benötigt nicht diese Datenpunkte zum steuern, sondern mindestens etwas zum Schalten also on/switch oder bei einigen auch power. Diese gehen dann im ALIAS über einen ACTUAL oder/und SET.
                      Siehe auch: https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-ALIAS-Table
                      Der Geräte-Manager macht das in der Regel richtig.
                      Und ebenfalls sollten Leerzeichen (und Sonderzeichen, Umlaute) vermieden werden. Besser zusammenschreiben wie LampeHolz oder Lampe_Holz
                      • B bean
                        ArmilarA Offline
                        ArmilarA Offline
                        Armilar
                        #1036
                        @bean
                        Manchmal überholen sich die Ereignisse. Das Haus-Symbol ist zwar schon zu sehen, bekommt erst mit der nächsten Script-Version eine Funktion.
                        Lies dir zu den Hardwaretasten kurz https://github.com/joBr99/nspanel-lovelace-ui/wiki/NSPanel-Tasmota-FAQ durch.
                        Falls das nicht dabei ist, nochmal melden...
                        B F 2 Antworten Letzte Antwort
                        • B bean
                          ArmilarA Offline
                          ArmilarA Offline
                          Armilar
                          #1037
                          @bean sagte in SONOFF NSPanel mit Lovelace UI:
                          Wobei, wenn ich den Ternary richtig interpretiere fragst du folgendes ab:
                          Wenn der Wert auf ungleich 0 ist, dann setzte 100 (also hoch) sonst 0 (also runter)
                          Warum setzt du nicht val = 100 und val = 0? 🙄
                          Weil was ist, wenn der Wert z.B. auf 1, 2 oder 3 steht. Dann fährt das Rollo bei Up runter...
                          VumerV B 2 Antworten Letzte Antwort
                          • VumerV Offline
                            VumerV Offline
                            Vumer
                            schrieb am zuletzt editiert von Vumer
                            #1038
                            @armilar sagte in SONOFF NSPanel mit Lovelace UI:
                            Ich hoffe das ist schon älter ;)
                            Abfallkalender
                            const idAbfalliCal = 'ical.0'; // iCal Instanz zum Abfallkalender
                            const idZeichenLoeschen = 0; // x Zeichen links vom String abziehen, wenn vor dem Eventname noch Text steht z.B. Strassenname; Standard = 0
                            const idRestmuellName ='Restabfall'; // Schwarze Tonne
                            const idWertstoffName = 'Gelbe Tonne'; // Gelbe Tonne / Sack
                            const idPappePapierName = 'Papiertonne'; // Blaue Tonne
                            const idBioabfaelleName = 'Komposttonne'; // Braune Tonne
                            var i, Muell_JSON, Event2, Color = 0;
                            for (i = 1; i <= 4; i++) {
                            if (!existsState('0_userdata.0.Abfallkalender.' + parseFloat(i) + '.date')) {
                            log(i + '.date nicht vorhanden, wurde erstellt');
                            createState('0_userdata.0.Abfallkalender.' + parseFloat(i) + '.date', '',
                            name: parseFloat(i) + '.date',
                            role: 'state',
                            type: 'string',
                            read: true,
                            write: true,
                            def: ''
                            if (!existsState('0_userdata.0.Abfallkalender.' + parseFloat(i) + '.event')) {
                            log(i + '.event nicht vorhanden, wurde erstellt');
                            createState('0_userdata.0.Abfallkalender.' + parseFloat(i) + '.event', '',
                            name: parseFloat(i) + '.event',
                            role: 'state',
                            type: 'string',
                            read: true,
                            write: true,
                            def: ''
                            if (!existsState('0_userdata.0.Abfallkalender.' + parseFloat(i) + '.color')) {
                            log(i + '.color nicht vorhanden, wurde erstellt');
                            createState('0_userdata.0.Abfallkalender.' + parseFloat(i) + '.color', 0,
                            name: parseFloat(i) + '.color',
                            role: 'state',
                            type: 'number',
                            read: true,
                            write: true,
                            def: 0
                            function subsequenceFromStartLast(sequence, at1) {
                            var start = at1;
                            var end = sequence.length;
                            return sequence.slice(start, end);
                            on({ id: idAbfalliCal + '.data.table', change: "ne" }, async function () {
                            for (i = 0; i <= 3; i++) {
                            Muell_JSON = getState(idAbfalliCal + '.data.table').val;
                            setStateDelayed((['0_userdata.0.Abfallkalender.', parseFloat(i) + 1, '.date'].join('')), getAttr(Muell_JSON, (String(i) + '.date')), false, parseInt(((0) || "").toString(), 10), false);
                            Event2 = subsequenceFromStartLast(getAttr(Muell_JSON, (String(i) + '.event')), idZeichenLoeschen);
                            setStateDelayed((['0_userdata.0.Abfallkalender.', parseFloat(i) + 1, '.event'].join('')), Event2, false, parseInt(((0) || "").toString(), 10), false);
                            if (Event2 == idRestmuellName) {
                            Color = 33840;
                            } else if (Event2 == idBioabfaelleName) {
                            Color = 48192;
                            } else if (Event2 == idPappePapierName) {
                            Color = 2016;
                            } else if (Event2 == idWertstoffName) {
                            Color = 65504;
                            setStateDelayed((['0_userdata.0.Abfallkalender.', parseFloat(i) + 1, '.color'].join('')), Color, false, parseInt(((0) || "").toString(), 10), false);
                            javascript.0 2022-12-05 12:17:07.105	error	at processImmediate (node:internal/timers:466:21)
                            javascript.0 2022-12-05 12:17:07.105	error	at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5909:56)
                            javascript.0 2022-12-05 12:17:07.105	error	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
                            javascript.0 2022-12-05 12:17:07.105	error	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
                            javascript.0 2022-12-05 12:17:07.105	error	at Object.<anonymous> (script.js.common.NSPanel.Abfallkalender:61:18)
                            javascript.0 2022-12-05 12:17:07.105	error	at subsequenceFromStartLast (script.js.common.NSPanel.Abfallkalender:52:24)
                            javascript.0 2022-12-05 12:17:07.104	error	script.js.common.NSPanel.Abfallkalender: TypeError: Cannot read properties of null (reading 'length')
                            was habe ich wieder falsch gemacht?
                            ArmilarA T 2 Antworten Letzte Antwort
                            • ArmilarA Armilar
                              VumerV Offline
                              VumerV Offline
                              Vumer
                              #1039
                              Beim HM funktioniert das so mit 0 und 100
                              • VumerV Vumer
                                Abfallkalender
                                role: 'state',
                                type: 'string',
                                read: true,
                                write: true,
                                def: ''
                                role: 'state',
                                type: 'string',
                                read: true,
                                write: true,
                                def: ''
                                role: 'state',
                                type: 'number',
                                read: true,
                                write: true,
                                def: 0
                                var start = at1;
                                Color = 33840;
                                Color = 48192;
                                Color = 2016;
                                Color = 65504;
                                ArmilarA Offline
                                ArmilarA Offline
                                Armilar
                                #1040
                                @vumer
                                Kann ich dir erst sagen, wenn du mir die zugehörige Seite für das NSPanel mitteilst die 4 Aliase vom Gerätetyp: Warnung aufruft...
                                Im Spoiler finde ich nur ein Script, das Datenpunkte aus einem iCal in 0_userdata erstellt und befüllt. ;-)
                                VumerV 1 Antwort Letzte Antwort
                                • ArmilarA Armilar
                                  @bean
                                  bean
                                  #1041
                                  Danke für den Linkt, kannte ich noch nicht. Hatte die Buttons in Tasmota aber einer anderen Infosammlung entsprechend entkoppelt, das funktioniert auch (Keine Relaisbenutzung).
                                  Im script sind die Buttons auch konfiguriert (zB button2Page: Abfall,), aber trotzdem wechseln die Seiten bei Tastenbetätigung durch...
                                  • B bean
                                    ArmilarA Offline
                                    ArmilarA Offline
                                    Armilar
                                    #1042
                                    Ich kann mit der Aussage nichts anfangen. Was wechselt wann, wie durch?
                                    Welche Seiten sind wo konfiguriert und wie sehen die aus?
                                    Was ist konfiguriert, was passiert wenn du was machst (präzise und detailliert) und was wird erwartet? Was hast du z.B. an Rules im Tasmota benutzt und wie sehen die aus? Welche Einstellungen hat Tasmota ggfs. noch bekommen?
                                    Das ist mir zu wenig Content. Ich wüsste da nicht ansatzweise, wo ich unterstützen kann...
                                    • ArmilarA Armilar
                                      @vumer
                                      VumerV Offline
                                      VumerV Offline
                                      Vumer
                                      #1043
                                      das ist auch der script.js.common.NSPanel.Abfallkalender
                                      Der NSPanelTs.ts lief gar nicht. Und der Fehler tritt auf wenn ich dem script.js.common.NSPanel.Abfallkalender starte
                                      • ArmilarA Armilar
                                        bean
                                        #1044
                                        Bin da ja auch noch am experimentieren, aber meiner Erkenntnis nach:
                                        Der Datenpunkt "Open" ist ja vom Typ Boolean und gleichzeitig ein Trigger/Taster, ist also immer auf "true" und wird nur aktualisiert.
                                        Ich dachte ich muss bei der Funktion erst den Wert abfragen, dass es einfach so auch gehen könnte hab ich noch nicht bedacht, wird ausprobiert. Zumindest ist ein eigenes Skript nicht notwendig.
                                        • ArmilarA Armilar
                                          bean
                                          #1045
                                          Ich habe Pages konfiguriert
                                             pages: [
                                                     SzenenLicht,
                                                     SzenenRollos,
                                                     Mattelsberg,
                                                     CardPowerExample,
                                                     Radio,
                                                     Alexa,
                                                     Sonos,
                                                     Abfall
                                          und die Buttonpages
                                              button1Page: button1cardPage,
                                              button2Page: Abfall
                                          Diese Seiten funktionieren genauso wie erwartet, alles super.
                                          Wenn ich nun die physischen Tasten am Panel drücke, wechsle ich zwischen den Pages durch, mit der rechten Taste wechsle ich "Vorwärts" (nach unten in der Liste der Pages), mit der linken wechsle ich "rückwärts" (nach oben), so als würde ein Seitenzähler um eins erhöht oder verringert.
                                          Erwartet hätte ich, dass mich der Druck auf die linke Taste auf die button1cardPage bringt und ein Druck auf die rechte Taste auf die Abfallseite.
                                          Ich habe Rule2 mit beiden Buttons konfiguriert und an meine MQTT-Struktur angepasst.
                                          Rule2 on Button1#state do Publish %topic%/%prefix%/RESULT {"CustomRecv":"event,button1"} endon on Button2#state do Publish %topic%/%prefix%/RESULT {"CustomRecv":"event,button2"} endon
                                          Die Button-Events kommen auch im passenden Datenpunkt an. Sonst (glaub ich) habe ich nichts an Tasmota geändert.
                                          Kein Stress, er funktioniert ja grundsätzlich, nur nicht so wie erwartet. Ich habe nur etwas das Gefühl, hier einem Bug auf der Spur zu sein, aber dass dieses Verhalten nur hier auftritt, ist seltsam.
                                          Und falls ich es noch nicht erwähnt habe: Danke für die super Arbeit!!
