  4. ZigBee neue Version 1.8.x
385 Beiträge 55 Kommentatoren 110.9k Aufrufe 49 Beobachtet
  • arteckA arteck
    @bommel_030 sagte in ZigBee neue Version 1.8.x:
    . Auch hier hagelte es das Log von und nichts ging mehr.
    geile Beschreibung damit kann ich viel anfangen .. danke dafür
    bommel_030
    @arteck
    aber gerne doch....
    Das Intervall erkennt man, immer die gleiche Meldung bis der Admin den Adapter killt:
    zigbee.0 2022-12-01 07:24:35.013	error	getDevices error: TypeError: Cannot read properties of undefined (reading 'resolveEntity') at /opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:270:64 at runMicrotasks (<anonymous>) at runNextTicks (node:internal/process/task_queues:61:5) at processImmediate (node:internal/timers:437:9)
    zigbee.0 2022-12-01 07:24:35.012	error	getDevices error: TypeError: Cannot read properties of undefined (reading 'resolveEntity') at /opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:270:64 at runMicrotasks (<anonymous>) at runNextTicks (node:internal/process/task_queues:61:5) at processImmediate (node:internal/timers:437:9)
    zigbee.0 2022-12-01 07:24:35.011	error	getDevices error: TypeError: Cannot read properties of undefined (reading 'resolveEntity') at /opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:270:64 at runMicrotasks (<anonymous>) at runNextTicks (node:internal/process/task_queues:61:5) at processImmediate (node:internal/timers:437:9)
    Mit der 1.8.3 läuft es. Lediglich folgender Hinweis:
    zigbee.0 2022-12-01 07:25:48.808	warn	Object 50325ffffe244913.power_on_behavior is invalid: obj.common.states has an invalid type! Expected "object", received "string"
    zigbee.0 2022-12-01 07:25:48.808	warn	This object will not be created in future versions. Please report this to the developer.
    zigbee.0 2022-12-01 07:25:48.808	warn	Object 50325ffffe24503f.power_on_behavior is invalid: obj.common.states has an invalid type! Expected "object", received "string"
    Sind beides identische IKEA Spots :
    ieee:0x50325ffffe272cf5
    nwk:47843 (0xbae3)
    model:LED2005R5
    Ein Problem habe ich noch mit einer Gruppe aus zwei anderen IKEA Lampen. Die haben aber auch schon mit der 1.7.6 gezickt. Das muss ich mir aber noch anschauen nachdem ich sie noch mal neu verbunden habe.
    • S spotterblog
      @thomas-braun ok dann muss ich mir das morgen nochmal genauer anschauen.
      Hab es jetzt zweimal versucht und nur extreme Fehler damit produziert.
      Vielleicht ist auch meine Urinstallation korrupt. Immerhin fehlen mir einige Buttons die ich immer wieder auf Screenshots sehe. Auch der Tab mit den Gruppen ist bei mir nicht vorhanden.
      Diese Dinge sind der Grund warum ich überhaupt ein GitHub Update machen wollte.
      LG
      @spotterblog den Tab mit den Gruppen gibts doch lange nicht mehr.. ?? Der war noch in 1.6xx aktiv, soviel ich noch weiss.. ?
      Die 1.8.5 geiert bei vielen ab, die Statemappings stimmen bei mir zumindest seit 1.8.1 nicht mehr..
      David G.D arteckA S 3 Antworten Letzte Antwort
        David G.D Online
        David G.D Online
        David G.
        @ilovegym
        Tatsache, ist mir noch garnicht aufgefallen.
        Gibt's denn noch einen Weg, neue Gruppen anzulegen?
        • David G.D David G.
          @ilovegym
          @david-g ja, die Gruppen werden auf der Rueckseite der Kachel, wo ich den Namen aendern kann, eingetragen. Eine neue einfach mit neuem Namen anlegen. Benutze das aber nicht mehr..
            Kueppert
            schrieb am zuletzt editiert von Kueppert
            Hallo @arteck
            hab eben die Version auf 1.8.5 hochgezogen (vorher 1.8.1, die lief). Hab da einen Haufen Fehlermeldungen erhalten und die Instanz ist rot. ANbei aus meinem LOG paar Infos:
            zigbee.0 2022-12-01 09:21:10.869	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
            zigbee.0 2022-12-01 09:21:10.864	info	terminating
            zigbee.0 2022-12-01 09:21:10.513	info	Zigbee: disabling joining new devices.
            zigbee.0 2022-12-01 09:21:10.363	info	cleaned everything up...
            zigbee.0 2022-12-01 09:21:10.329	error	Cannot read properties of undefined (reading 'filter')
            zigbee.0 2022-12-01 09:21:10.329	error	TypeError: Cannot read properties of undefined (reading 'filter') at StatesController.collectOptions (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:167:41) at runMicrotasks (<anonymous>) at runNextTicks (node:internal/process/task_queues:61:5) at processImmediate (node:internal/timers:437:9)
            zigbee.0 2022-12-01 09:21:10.328	error	unhandled promise rejection: Cannot read properties of undefined (reading 'filter')
            zigbee.0 2022-12-01 09:21:10.328	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            zigbee.0 2022-12-01 09:21:10.326	error	Cannot read properties of undefined (reading 'filter')
            zigbee.0 2022-12-01 09:21:10.326	error	TypeError: Cannot read properties of undefined (reading 'filter') at StatesController.collectOptions (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:167:41) at runMicrotasks (<anonymous>) at runNextTicks (node:internal/process/task_queues:61:5) at processImmediate (node:internal/timers:437:9)
            zigbee.0 2022-12-01 09:21:10.325	error	unhandled promise rejection: Cannot read properties of undefined (reading 'filter')
            zigbee.0 2022-12-01 09:21:10.319	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            zigbee.0 2022-12-01 09:21:10.311	error	Cannot read properties of undefined (reading 'filter')
            zigbee.0 2022-12-01 09:21:10.311	error	TypeError: Cannot read properties of undefined (reading 'filter') at StatesController.collectOptions (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:167:41) at runMicrotasks (<anonymous>) at runNextTicks (node:internal/process/task_queues:61:5) at processImmediate (node:internal/timers:437:9)
            zigbee.0 2022-12-01 09:21:10.310	error	unhandled promise rejection: Cannot read properties of undefined (reading 'filter')
            zigbee.0 2022-12-01 09:21:10.309	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            zigbee.0 2022-12-01 09:21:09.072	error	syncDevStates: Illegal state in {"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":52,"_type":"Router","_ieeeAddr":"0x00178801024c5b7c","_networkAddress":14343,"_manufacturerID":4107,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":11,"profileID":49246,"deviceID":528,"inputClusters":[0,3,4,5,6,8,4096,64515,768,64513],"outputClusters":[25],"deviceNetworkAddress":14343,"deviceIeeeAddress":"0x00178801024c5b7c","clusters":{"genBasic":{"attributes":{"modelId":"LCT010","manufacturerName":"Signify Netherlands B.V.","powerSource":1,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20210331","swBuildId":"1.88.1"}},"lightingColorCtrl":{"attributes":{"colorCapabilities":31,"colorTempPhysicalMin":153,"colorTempPhysicalMax":500}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[33],"outputClusters":[33],"deviceNetworkAddress":14343,"deviceIeeeAddress":"0x00178801024c5b7c","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"Signify Netherlands B.V.","_powerSource":"Mains (single phase)","_modelID":"LCT010","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20210331","_softwareBuildID":"1.88.1","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":88764544},"_lastSeen":1669882168730,"_defaultSendRequestWhen":"immediate"} - "5"
            zigbee.0 2022-12-01 09:21:09.068	error	syncDevStates: Illegal state in {"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":50,"_type":"Router","_ieeeAddr":"0x00178801088afa55","_networkAddress":38729,"_manufacturerID":4107,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":11,"profileID":49246,"deviceID":528,"inputClusters":[0,3,4,5,6,8,4096,64515,768,64513],"outputClusters":[25],"deviceNetworkAddress":38729,"deviceIeeeAddress":"0x00178801088afa55","clusters":{"genBasic":{"attributes":{"modelId":"LCT012","manufacturerName":"Signify Netherlands B.V.","powerSource":1,"zclVersion":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20210331","swBuildId":"1.88.1"}},"lightingColorCtrl":{"attributes":{"colorCapabilities":31,"colorTempPhysicalMin":153,"colorTempPhysicalMax":500,"colorMode":1,"colorTemperature":500}},"genOnOff":{"attributes":{"onOff":0}},"genLevelCtrl":{"attributes":{"currentLevel":1}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[33],"outputClusters":[33],"deviceNetworkAddress":38729,"deviceIeeeAddress":"0x00178801088afa55","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"Signify Netherlands B.V.","_powerSource":"Mains (single phase)","_modelID":"LCT012","_applicationVersion":2,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20210331","_softwareBuildID":"1.88.1","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":2},"_lastSeen":1669882468350,"_defaultSendRequestWhen":"immediate"} - "5"
            zigbee.0 2022-12-01 09:21:09.061	error	syncDevStates: Illegal state in {"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":47,"_type":"Router","_ieeeAddr":"0x60a423fffed2f163","_networkAddress":9360,"_manufacturerID":4098,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":81,"inputClusters":[0,4,5,6,1794,2820],"outputClusters":[25,10],"deviceNetworkAddress":9360,"deviceIeeeAddress":"0x60a423fffed2f163","clusters":{"genBasic":{"attributes":{"modelId":"TS0121","manufacturerName":"_TZ3000_g5xawfcq","powerSource":1,"zclVersion":3,"appVersion":65,"stackVersion":0,"hwVersion":1,"dateCode":""}},"seMetering":{"attributes":{"divisor":100,"multiplier":1,"currentSummDelivered":[0,2453]}},"haElectricalMeasurement":{"attributes":{"acVoltageMultiplier":1,"acVoltageDivisor":1,"acCurrentMultiplier":1,"acCurrentDivisor":1000,"acPowerMultiplier":1,"acPowerDivisor":1,"rmsVoltage":234,"rmsCurrent":0,"activePower":0}},"genOnOff":{"attributes":{"onOff":0,"onTime":0,"offWaitTime":0,"tuyaBacklightMode":1,"moesStartUpOnOff":2}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0018eb42ab","endpointID":1},{"cluster":2820,"type":"endpoint","deviceIeeeAddress":"0x00124b0018eb42ab","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"_TZ3000_g5xawfcq","_powerSource":"Mains (single phase)","_modelID":"TS0121","_applicationVersion":65,"_stackVersion":0,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1669882831498,"_defaultSendRequestWhen":"immediate"} - "5"
            zigbee.0 2022-12-01 09:21:09.057	error	syncDevStates: Illegal state in {"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":46,"_type":"Router","_ieeeAddr":"0x60a423fffed2ef55","_networkAddress":17627,"_manufacturerID":4098,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":81,"inputClusters":[0,4,5,6,1794,2820],"outputClusters":[25,10],"deviceNetworkAddress":17627,"deviceIeeeAddress":"0x60a423fffed2ef55","clusters":{"genBasic":{"attributes":{"modelId":"TS0121","manufacturerName":"_TZ3000_g5xawfcq","powerSource":1,"zclVersion":3,"appVersion":65,"stackVersion":0,"hwVersion":1,"dateCode":""}},"seMetering":{"attributes":{"divisor":100,"multiplier":1,"currentSummDelivered":[0,24739]}},"haElectricalMeasurement":{"attributes":{"acVoltageMultiplier":1,"acVoltageDivisor":1,"acCurrentMultiplier":1,"acCurrentDivisor":1000,"acPowerMultiplier":1,"acPowerDivisor":1,"rmsVoltage":234,"rmsCurrent":0,"activePower":0}},"genOnOff":{"attributes":{"onOff":0,"onTime":0,"offWaitTime":0,"tuyaBacklightMode":1,"moesStartUpOnOff":2}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0018eb42ab","endpointID":1},{"cluster":2820,"type":"endpoint","deviceIeeeAddress":"0x00124b0018eb42ab","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"_TZ3000_g5xawfcq","_powerSource":"Mains (single phase)","_modelID":"TS0121","_applicationVersion":65,"_stackVersion":0,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1669882831273,"_defaultSendRequestWhen":"immediate"} - "5"
            zigbee.0 2022-12-01 09:21:08.779	error	Device 0x0017880109623b09 "929002294203" not described in statesMapping.
            zigbee.0 2022-12-01 09:21:08.647	error	Device 0x0017880109b29dca "929002294203" not described in statesMapping.
            zigbee.0 2022-12-01 09:21:08.518	error	Device 0xf0d1b800001968ab "4058075047853" not described in statesMapping.
            zigbee.0 2022-12-01 09:21:08.379	error	Device 0x14b457fffecc44a5 "404000/404005/404012/404019" not described in statesMapping.
            zigbee.0 2022-12-01 09:21:08.188	error	Device 0x14b457fffecc31db "404000/404005/404012/404019" not described in statesMapping.
              arteckA Offline
              arteckA Offline
              arteck
              @ilovegym nimm die 1.8.3.. in der 1.8.5 stimmt noch was nicht
              amg_666A ? 2 Antworten Letzte Antwort
              • arteckA arteck
                amg_666A Offline
                amg_666A Offline
                amg_666
                @arteck 1.8.5 läuft bei mir auch nicht mehr:
                host.iobroker
                	2022-12-01 09:54:11.687	info	Restart adapter system.adapter.zigbee.0 because enabled
                host.iobroker
                	2022-12-01 09:54:11.687	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                host.iobroker
                	2022-12-01 09:54:11.687	error	Caught by controller[0]: at StatesController.collectOptions (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:167:41)
                host.iobroker
                	2022-12-01 09:54:11.687	error	Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'filter')
                host.iobroker
                	2022-12-01 09:54:11.687	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                host.iobroker
                	2022-12-01 09:54:11.686	error	Caught by controller[0]: at StatesController.collectOptions (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:167:41)
                host.iobroker
                	2022-12-01 09:54:11.686	error	Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'filter')
                host.iobroker
                	2022-12-01 09:54:11.686	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                zigbee.0
                	2022-12-01 09:54:11.031	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                zigbee.0
                	2022-12-01 09:54:11.026	info	terminating
                zigbee.0
                	2022-12-01 09:54:10.619	info	Zigbee: disabling joining new devices.
                zigbee.0
                	2022-12-01 09:54:10.524	info	cleaned everything up...
                zigbee.0
                	2022-12-01 09:54:10.391	error	Cannot read properties of undefined (reading 'filter')
                zigbee.0
                	2022-12-01 09:54:10.391	error	TypeError: Cannot read properties of undefined (reading 'filter') at StatesController.collectOptions (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:167:41)
                zigbee.0
                	2022-12-01 09:54:10.390	error	unhandled promise rejection: Cannot read properties of undefined (reading 'filter')
                zigbee.0
                	2022-12-01 09:54:10.390	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                zigbee.0
                	2022-12-01 09:54:10.386	error	Cannot read properties of undefined (reading 'filter')
                zigbee.0
                	2022-12-01 09:54:10.386	error	TypeError: Cannot read properties of undefined (reading 'filter') at StatesController.collectOptions (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:167:41)
                zigbee.0
                	2022-12-01 09:54:10.386	error	unhandled promise rejection: Cannot read properties of undefined (reading 'filter')
                zigbee.0
                	2022-12-01 09:54:10.385	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                zigbee.0
                	2022-12-01 09:54:09.265	error	Device 0xa4c138ff5d8ed635 "TS011F_plug_1" not described in statesMapping.
                zigbee.0
                	2022-12-01 09:54:09.261	error	Device 0xa4c138442eb7c935 "TS011F_plug_1" not described in statesMapping.
                zigbee.0
                	2022-12-01 09:54:09.235	error	syncDevStates: Illegal state in {"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":30,"_type":"Router","_ieeeAddr":"0x84fd27fffecf6567","_networkAddress":3968,"_manufacturerID":4098,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":266,"inputClusters":[0,3,4,5,6],"outputClusters":[25,10],"deviceNetworkAddress":3968,"deviceIeeeAddress":"0x84fd27fffecf6567","clusters":{"genBasic":{"attributes":{"65503":"\u0000\u0000\u0000\u0000\u0005","65506":30,"modelId":"TS011F","manufacturerName":"_TZ3000_1obwwnmq","powerSource":1,"zclVersion":3,"stackVersion":0,"hwVersion":1,"dateCode":"","appVersion":69}},"genOnOff":{"attributes":{"onOff":1,"onTime":0,"offWaitTime":0,"tuyaBacklightMode":1,"moesStartUpOnOff":2}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0018e1cb74","endpointID":0}],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"profileID":260,"deviceID":266,"inputClusters":[3,4,5,6],"outputClusters":[],"deviceNetworkAddress":3968,"deviceIeeeAddress":"0x84fd27fffecf6567","clusters":{"genOnOff":{"attributes":{"onOff":0,"onTime":0,"offWaitTime":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0018e1cb74","endpointID":0}],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":3,"profileID":260,"deviceID":266,"inputClusters":[3,4,5,6],"outputClusters":[],"deviceNetworkAddress":3968,"deviceIeeeAddress":"0x84fd27fffecf6567","clusters":{"genOnOff":{"attributes":{"onOff":1,"onTime":0,"offWaitTime":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0018e1cb74","endpointID":0}],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":3968,"deviceIeeeAddress":"0x84fd27fffecf6567","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"_TZ3000_1obwwnmq","_powerSource":"Mains (single phase)","_modelID":"TS011F","_applicationVersion":69,"_stackVersion":0,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1669884687467,"_defaultSendRequestWhen":"immediate"} - "5"
                zigbee.0
                	2022-12-01 09:54:09.231	error	Device 0xa4c1388e4fb7d6d8 "TS011F_plug_3" not described in statesMapping.
                zigbee.0
                	2022-12-01 09:54:09.221	error	Device 0xa4c13896f124a5e3 "TS011F_plug_1" not described in statesMapping.
                zigbee.0
                	2022-12-01 09:54:09.186	error	syncDevStates: Illegal state in {"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":19,"_type":"Router","_ieeeAddr":"0x5c0272fffe96fa2a","_networkAddress":63264,"_manufacturerID":4476,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":266,"inputClusters":[0,3,4,5,6,8,4096],"outputClusters":[5,25,32,4096],"deviceNetworkAddress":63264,"deviceIeeeAddress":"0x5c0272fffe96fa2a","clusters":{"genBasic":{"attributes":{"modelId":"TRADFRI control outlet","manufacturerName":"IKEA of Sweden","powerSource":1,"zclVersion":3,"appVersion":32,"stackVersion":98,"hwVersion":1,"dateCode":"20191026","swBuildId":"2.0.024"}},"genOnOff":{"attributes":{"onOff":1}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0018e1cb74","endpointID":1}],"_configuredReportings":[{"cluster":6,"attrId":0,"minRepIntval":0,"maxRepIntval":3600,"repChange":0}],"meta":{},"pendingRequests":[]},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[33],"outputClusters":[33],"deviceNetworkAddress":63264,"deviceIeeeAddress":"0x5c0272fffe96fa2a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"IKEA of Sweden","_powerSource":"Mains (single phase)","_modelID":"TRADFRI control outlet","_applicationVersion":32,"_stackVersion":98,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"20191026","_softwareBuildID":"2.0.024","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1669884806459,"_defaultSendRequestWhen":"immediate"} - "5"
                zigbee.0
                	2022-12-01 09:54:08.528	info	Zigbee started
                  spotterblog
                  @ilovegym ah ok, wusste ich nicht.
                  Ich hatte bis vor kurzem den deconz Adapter laufen.
                  Habe den Tab nur in verschiedenen Screenshots gesehen.
                  @Thomas-Braun
                  Wie gesagt, außer mit einer Steckdosenleiste läuft bei mir 1.7.6 super.
                  Lediglich Buttons wie der für OTA fehlen bei mir. Wobei ich aber nicht weiß ob das so sein soll oder nicht.
                  Habe als Erstversion 1.7.5 gehabt und dann wegen IKEA Trädfri Problemen auf 1.7.6 geupdated was auch geholfen hat. Die Buttons haben aber auch in 1.7.5 schon gefehlt.
                  • S spotterblog
                    @Thomas-Braun
                    arteckA Offline
                    arteckA Offline
                    arteck
                    @spotterblog sagte in ZigBee neue Version 1.8.x:
                    welche buttons ?
                    • arteckA arteck
                      welche buttons ?
                      spotterblog
                      @arteck
                      Irgendwie habe ich jetzt denke ich den "Fehler" gefunden.
                      Habe mich eben von der Arbeit aus mit VPN auf meinen ioBroker verbunden und da ist jetzt der blaue Firmware Update Button zu sehen.
                      Zuhause wenn ich lokal über die IP einsteige fehlt dieser Button.
                      Ist aber der selbe User.
                      Komisch. Der einzige Unterschied zu Hause ist der Dark Mode. Das muss ich später nochmal prüfen.
                      • arteckA arteck
                        @arteck sagte in ZigBee neue Version 1.8.x:
                        yes, die 1.8.3 laeuft ohne Fehler hier.
                        Wenn du n Debug log von irgenwas brauchst, sag bescheid, hab ne recht hohe Anzahl an Geraeten.. diesmal sind auch alle Icons richtig und das Assignment stimmt wieder.
                          Kueppert
                          @ilovegym jo, bei mir in der 1.8.3 sind die Geräte-Bildchen auch wieder korrekt, war bei der 1.8.5 nämlich nicht der Fall :) Mir noch garnicht aufgefallen, weil ich noch nicht nachgesehen hatte ^^
                          • arteckA Offline
                            arteckA Offline
                            arteck
                            so neue version ist unterwegs.. 1.8.7 da sollte wieder alles tun
                            R L 2 Antworten Letzte Antwort
                            • arteckA arteck
                              rotamint
                              Danke für Deine Mühe, ist das in 1.8.7 auch (wieder) gefixt und ... wie komme ich an die 1.8.7 ran zur Installation?
                              DANKE! LG. S.
                              • R rotamint
                                DANKE! LG. S.
                                @rotamint sagte in ZigBee neue Version 1.8.x:
                                So wie du auch an die 1.8.5 gekommen bist? Willkommen im Beta-Bereich, wo die Versionen noch Ecken und Kanten haben dürfen.
                                R 1 Antwort Letzte Antwort
                                  rotamint
                                  Aber darum treffen wir uns ja im Beta-Bereich, um die Ecken und Kanten noch rund zu bekommen 👍
                                  Thomas BraunT arteckA 2 Antworten Letzte Antwort
                                  • R rotamint
                                    @rotamint
                                    Die 1.8.7 muss ja auch erst im Repo eingecheckt werden. Passiert alle 12 Stunden, um 2 und 14 Uhr, soweit ich weiß. Morgen früh ist es dann gesynct.
                                    • R rotamint
                                      arteckA Offline
                                      arteckA Offline
                                      arteck
                                      @rotamint oder so
                                      https://github.com/ioBroker/ioBroker.zigbee/wiki/GIT-install
                                        @rotamint
                                        rotamint
                                        @thomas-braun Wieder was dazu gelernt. Danke!
                                        • arteckA arteck
                                          @rotamint oder so
                                          rotamint
                                          @arteck Danke für's Lösungsweg aufzeigen! Hat geklappt und FB20-002 funktioniert auch wieder. 👍
