  4. ZigBee neue Version 1.8.x
385 Beiträge 55 Kommentatoren 110.9k Aufrufe 49 Beobachtet
  • arteckA arteck
    @ilovegym nimm die 1.8.3.. in der 1.8.5 stimmt noch was nicht
    amg_666A Offline
    amg_666A Offline
    amg_666
    @arteck 1.8.5 läuft bei mir auch nicht mehr:
    host.iobroker
    	2022-12-01 09:54:11.687	info	Restart adapter system.adapter.zigbee.0 because enabled
    host.iobroker
    	2022-12-01 09:54:11.687	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.iobroker
    	2022-12-01 09:54:11.687	error	Caught by controller[0]: at StatesController.collectOptions (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:167:41)
    host.iobroker
    	2022-12-01 09:54:11.687	error	Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'filter')
    host.iobroker
    	2022-12-01 09:54:11.687	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    host.iobroker
    	2022-12-01 09:54:11.686	error	Caught by controller[0]: at StatesController.collectOptions (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:167:41)
    host.iobroker
    	2022-12-01 09:54:11.686	error	Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'filter')
    host.iobroker
    	2022-12-01 09:54:11.686	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    zigbee.0
    	2022-12-01 09:54:11.031	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    zigbee.0
    	2022-12-01 09:54:11.026	info	terminating
    zigbee.0
    	2022-12-01 09:54:10.619	info	Zigbee: disabling joining new devices.
    zigbee.0
    	2022-12-01 09:54:10.524	info	cleaned everything up...
    zigbee.0
    	2022-12-01 09:54:10.391	error	Cannot read properties of undefined (reading 'filter')
    zigbee.0
    	2022-12-01 09:54:10.391	error	TypeError: Cannot read properties of undefined (reading 'filter') at StatesController.collectOptions (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:167:41)
    zigbee.0
    	2022-12-01 09:54:10.390	error	unhandled promise rejection: Cannot read properties of undefined (reading 'filter')
    zigbee.0
    	2022-12-01 09:54:10.390	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0
    	2022-12-01 09:54:10.386	error	Cannot read properties of undefined (reading 'filter')
    zigbee.0
    	2022-12-01 09:54:10.386	error	TypeError: Cannot read properties of undefined (reading 'filter') at StatesController.collectOptions (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:167:41)
    zigbee.0
    	2022-12-01 09:54:10.386	error	unhandled promise rejection: Cannot read properties of undefined (reading 'filter')
    zigbee.0
    	2022-12-01 09:54:10.385	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0
    	2022-12-01 09:54:09.265	error	Device 0xa4c138ff5d8ed635 "TS011F_plug_1" not described in statesMapping.
    zigbee.0
    	2022-12-01 09:54:09.261	error	Device 0xa4c138442eb7c935 "TS011F_plug_1" not described in statesMapping.
    zigbee.0
    	2022-12-01 09:54:09.235	error	syncDevStates: Illegal state in {"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":30,"_type":"Router","_ieeeAddr":"0x84fd27fffecf6567","_networkAddress":3968,"_manufacturerID":4098,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":266,"inputClusters":[0,3,4,5,6],"outputClusters":[25,10],"deviceNetworkAddress":3968,"deviceIeeeAddress":"0x84fd27fffecf6567","clusters":{"genBasic":{"attributes":{"65503":"\u0000\u0000\u0000\u0000\u0005","65506":30,"modelId":"TS011F","manufacturerName":"_TZ3000_1obwwnmq","powerSource":1,"zclVersion":3,"stackVersion":0,"hwVersion":1,"dateCode":"","appVersion":69}},"genOnOff":{"attributes":{"onOff":1,"onTime":0,"offWaitTime":0,"tuyaBacklightMode":1,"moesStartUpOnOff":2}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0018e1cb74","endpointID":0}],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"profileID":260,"deviceID":266,"inputClusters":[3,4,5,6],"outputClusters":[],"deviceNetworkAddress":3968,"deviceIeeeAddress":"0x84fd27fffecf6567","clusters":{"genOnOff":{"attributes":{"onOff":0,"onTime":0,"offWaitTime":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0018e1cb74","endpointID":0}],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":3,"profileID":260,"deviceID":266,"inputClusters":[3,4,5,6],"outputClusters":[],"deviceNetworkAddress":3968,"deviceIeeeAddress":"0x84fd27fffecf6567","clusters":{"genOnOff":{"attributes":{"onOff":1,"onTime":0,"offWaitTime":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0018e1cb74","endpointID":0}],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":3968,"deviceIeeeAddress":"0x84fd27fffecf6567","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"_TZ3000_1obwwnmq","_powerSource":"Mains (single phase)","_modelID":"TS011F","_applicationVersion":69,"_stackVersion":0,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1669884687467,"_defaultSendRequestWhen":"immediate"} - "5"
    zigbee.0
    	2022-12-01 09:54:09.231	error	Device 0xa4c1388e4fb7d6d8 "TS011F_plug_3" not described in statesMapping.
    zigbee.0
    	2022-12-01 09:54:09.221	error	Device 0xa4c13896f124a5e3 "TS011F_plug_1" not described in statesMapping.
    zigbee.0
    	2022-12-01 09:54:09.186	error	syncDevStates: Illegal state in {"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":19,"_type":"Router","_ieeeAddr":"0x5c0272fffe96fa2a","_networkAddress":63264,"_manufacturerID":4476,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":266,"inputClusters":[0,3,4,5,6,8,4096],"outputClusters":[5,25,32,4096],"deviceNetworkAddress":63264,"deviceIeeeAddress":"0x5c0272fffe96fa2a","clusters":{"genBasic":{"attributes":{"modelId":"TRADFRI control outlet","manufacturerName":"IKEA of Sweden","powerSource":1,"zclVersion":3,"appVersion":32,"stackVersion":98,"hwVersion":1,"dateCode":"20191026","swBuildId":"2.0.024"}},"genOnOff":{"attributes":{"onOff":1}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0018e1cb74","endpointID":1}],"_configuredReportings":[{"cluster":6,"attrId":0,"minRepIntval":0,"maxRepIntval":3600,"repChange":0}],"meta":{},"pendingRequests":[]},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[33],"outputClusters":[33],"deviceNetworkAddress":63264,"deviceIeeeAddress":"0x5c0272fffe96fa2a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"IKEA of Sweden","_powerSource":"Mains (single phase)","_modelID":"TRADFRI control outlet","_applicationVersion":32,"_stackVersion":98,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"20191026","_softwareBuildID":"2.0.024","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1669884806459,"_defaultSendRequestWhen":"immediate"} - "5"
    zigbee.0
    	2022-12-01 09:54:08.528	info	Zigbee started
      @spotterblog den Tab mit den Gruppen gibts doch lange nicht mehr.. ?? Der war noch in 1.6xx aktiv, soviel ich noch weiss.. ?
      Die 1.8.5 geiert bei vielen ab, die Statemappings stimmen bei mir zumindest seit 1.8.1 nicht mehr..
      spotterblog
      @ilovegym ah ok, wusste ich nicht.
      Ich hatte bis vor kurzem den deconz Adapter laufen.
      Habe den Tab nur in verschiedenen Screenshots gesehen.
      @Thomas-Braun
      Wie gesagt, außer mit einer Steckdosenleiste läuft bei mir 1.7.6 super.
      Lediglich Buttons wie der für OTA fehlen bei mir. Wobei ich aber nicht weiß ob das so sein soll oder nicht.
      Habe als Erstversion 1.7.5 gehabt und dann wegen IKEA Trädfri Problemen auf 1.7.6 geupdated was auch geholfen hat. Die Buttons haben aber auch in 1.7.5 schon gefehlt.
      • S spotterblog
        @Thomas-Braun
        arteckA Offline
        arteckA Offline
        arteck
        @spotterblog sagte in ZigBee neue Version 1.8.x:
        welche buttons ?
        • arteckA arteck
          welche buttons ?
          spotterblog
          @arteck
          Irgendwie habe ich jetzt denke ich den "Fehler" gefunden.
          Habe mich eben von der Arbeit aus mit VPN auf meinen ioBroker verbunden und da ist jetzt der blaue Firmware Update Button zu sehen.
          Zuhause wenn ich lokal über die IP einsteige fehlt dieser Button.
          Ist aber der selbe User.
          Komisch. Der einzige Unterschied zu Hause ist der Dark Mode. Das muss ich später nochmal prüfen.
          • arteckA arteck
            @arteck sagte in ZigBee neue Version 1.8.x:
            yes, die 1.8.3 laeuft ohne Fehler hier.
            Wenn du n Debug log von irgenwas brauchst, sag bescheid, hab ne recht hohe Anzahl an Geraeten.. diesmal sind auch alle Icons richtig und das Assignment stimmt wieder.
              Kueppert
              @ilovegym jo, bei mir in der 1.8.3 sind die Geräte-Bildchen auch wieder korrekt, war bei der 1.8.5 nämlich nicht der Fall :) Mir noch garnicht aufgefallen, weil ich noch nicht nachgesehen hatte ^^
              • arteckA Offline
                arteckA Offline
                arteck
                so neue version ist unterwegs.. 1.8.7 da sollte wieder alles tun
                R L 2 Antworten Letzte Antwort
                • arteckA arteck
                  rotamint
                  Danke für Deine Mühe, ist das in 1.8.7 auch (wieder) gefixt und ... wie komme ich an die 1.8.7 ran zur Installation?
                  DANKE! LG. S.
                  • R rotamint
                    DANKE! LG. S.
                    @rotamint sagte in ZigBee neue Version 1.8.x:
                    So wie du auch an die 1.8.5 gekommen bist? Willkommen im Beta-Bereich, wo die Versionen noch Ecken und Kanten haben dürfen.
                    R 1 Antwort Letzte Antwort
                      rotamint
                      Aber darum treffen wir uns ja im Beta-Bereich, um die Ecken und Kanten noch rund zu bekommen 👍
                      Thomas BraunT arteckA 2 Antworten Letzte Antwort
                      • R rotamint
                        @rotamint
                        Die 1.8.7 muss ja auch erst im Repo eingecheckt werden. Passiert alle 12 Stunden, um 2 und 14 Uhr, soweit ich weiß. Morgen früh ist es dann gesynct.
                        • R rotamint
                          arteckA Offline
                          arteckA Offline
                          arteck
                          @rotamint oder so
                          https://github.com/ioBroker/ioBroker.zigbee/wiki/GIT-install
                            @rotamint
                            rotamint
                            @thomas-braun Wieder was dazu gelernt. Danke!
                            • arteckA arteck
                              @rotamint oder so
                              rotamint
                              @arteck Danke für's Lösungsweg aufzeigen! Hat geklappt und FB20-002 funktioniert auch wieder. 👍
                                spotterblog
                                1.8.7 läuft soweit.
                                Firmware Updates haben jetzt auch funktioniert.
                                Lediglich meine Steckdosenleiste hat leider in der neuen Version immer noch keinen vollen Support.
                                Nach dem Starten kommt immer dieser Fehler:
                                DeviceConfigure:Failed to DeviceConfigure.configure 0x70b3d52b60012015 TS011F (Error: Read 0x70b3d52b60012015/1 genBasic(["manufacturerName","zclVersion","appVersion","modelId","powerSource",65534], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (no response received) at DeconzAdapter.sendZclFrameToEndpoint (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/adapter/deconzAdapter.ts:658:23) at Endpoint.sendRequest (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:299:20) at Endpoint.read (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:472:28) at Object.configureMagicPacket (/opt/iobroker/node_modules/zigbee-herdsman-converters/lib/tuya.js:1179:9) at Object.configure (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/useelink.js:36:13) at DeviceConfigure.doConfigure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:134:13) at DeviceConfigure.configure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:112:17) at DeviceConfigure.onZigbeeStarted (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:54:21) at async Promise.all (index 1))
                                Dann alle 5min dieser:
                                DeviceConfigure:Failed to DeviceConfigure.configure 0x70b3d52b60012015 TS011F (TypeError: Cannot read properties of undefined (reading 'debug') at Object.configureMagicPacket (/opt/iobroker/node_modules/zigbee-herdsman-converters/lib/tuya.js:1184:20) at Object.configure (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/useelink.js:36:13) at DeviceConfigure.doConfigure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:134:13) at DeviceConfigure.configure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:112:17))
                                amg_666A arteckA 2 Antworten Letzte Antwort
                                • S spotterblog
                                  1.8.7 läuft soweit.
                                  amg_666A Offline
                                  amg_666A Offline
                                  amg_666
                                  Also ich hab jetzt über github die 1.8.7 installiert.
                                  Adapter ist grün, scheint auch zu funktionieren, aber im Log habe ich jede Menge Warnungen:
                                  zigbee.0
                                  	2022-12-01 23:32:10.003	warn	DeviceAvailability:Failed to ping 0x00124b00235279d6 ZB-CL01
                                  zigbee.0
                                  	2022-12-01 23:32:09.356	warn	DeviceAvailability:Failed to ping 0x00124b00234ca487 ZB-CL01
                                  zigbee.0
                                  	2022-12-01 23:31:46.707	warn	This object will not be created in future versions. Please report this to the developer.
                                  zigbee.0
                                  	2022-12-01 23:31:46.707	warn	Object zigbee.0.84fd27fffecf6567.indicator_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                                  zigbee.0
                                  	2022-12-01 23:31:46.702	warn	This object will not be created in future versions. Please report this to the developer.
                                  zigbee.0
                                  	2022-12-01 23:31:46.701	warn	Object zigbee.0.84fd27fffecf6567.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                                  zigbee.0
                                  	2022-12-01 23:31:46.534	warn	This object will not be created in future versions. Please report this to the developer.
                                  zigbee.0
                                  	2022-12-01 23:31:46.533	warn	Object 84fd27fffecf6567.indicator_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                                  zigbee.0
                                  	2022-12-01 23:31:46.532	warn	This object will not be created in future versions. Please report this to the developer.
                                  zigbee.0
                                  	2022-12-01 23:31:46.531	warn	Object 84fd27fffecf6567.power_outage_memory is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                                  zigbee.0
                                  	2022-12-01 23:31:45.404	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
                                  zigbee.0
                                  	2022-12-01 23:31:45.401	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
                                  zigbee.0
                                  	2022-12-01 23:31:45.398	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
                                  zigbee.0
                                  	2022-12-01 23:31:45.395	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
                                  zigbee.0
                                  	2022-12-01 23:31:45.389	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_3.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_3.png
                                  zigbee.0
                                  	2022-12-01 23:31:45.386	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_3.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_3.png
                                  zigbee.0
                                  	2022-12-01 23:31:45.383	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
                                  zigbee.0
                                  	2022-12-01 23:31:45.380	warn	download icon from https://www.zigbee2mqtt.io/images/devices/MCCGQ14LM.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/MCCGQ14LM.png
                                  zigbee.0
                                  	2022-12-01 23:31:45.375	warn	download icon from https://www.zigbee2mqtt.io/images/devices/MCCGQ14LM.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/MCCGQ14LM.png
                                  zigbee.0
                                  	2022-12-01 23:31:45.353	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
                                  zigbee.0
                                  	2022-12-01 23:31:45.350	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
                                  zigbee.0
                                  	2022-12-01 23:31:45.347	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
                                  zigbee.0
                                  	2022-12-01 23:31:45.326	warn	download icon from https://www.zigbee2mqtt.io/images/devices/MCCGQ14LM.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/MCCGQ14LM.png
                                  zigbee.0
                                  	2022-12-01 23:31:45.312	info	Zigbee started
                                    spotterblog
                                    Habe gerade zwei Aqara Wandschalter neu eingebunden.
                                    Bekomme direkt nach dem Einbinden ebenfalls Warnungen:
                                    zigbee.0
                                    2022-12-01 23:15:51.986	info	DeviceConfigure successful 0x54ef44100044c675 lumi.remote.b28ac1
                                    zigbee.0
                                    2022-12-01 23:15:46.436	warn	This object will not be created in future versions. Please report this to the developer.
                                    zigbee.0
                                    2022-12-01 23:15:46.435	warn	Object zigbee.0.54ef44100044c675.operation_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                                    zigbee.0
                                    2022-12-01 23:15:46.420	warn	This object will not be created in future versions. Please report this to the developer.
                                    zigbee.0
                                    2022-12-01 23:15:46.419	warn	Object zigbee.0.54ef44100044c675.click_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                                    zigbee.0
                                    2022-12-01 23:15:46.410	warn	This object will not be created in future versions. Please report this to the developer.
                                    zigbee.0
                                    2022-12-01 23:15:46.410	warn	Object 54ef44100044c675.operation_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                                    zigbee.0
                                    2022-12-01 23:15:46.409	warn	This object will not be created in future versions. Please report this to the developer.
                                    zigbee.0
                                    2022-12-01 23:15:46.409	warn	Object 54ef44100044c675.click_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                                    zigbee.0
                                    2022-12-01 23:15:46.302	info	Configuring 0x54ef44100044c675 lumi.remote.b28ac1
                                    zigbee.0
                                    2022-12-01 23:15:46.298	info	Device '0x54ef44100044c675' is supported, identified as: Xiaomi Aqara wireless remote switch H1 (double rocker) (WXKG15LM)
                                    zigbee.0
                                    2022-12-01 23:15:46.297	info	Successfully interviewed '0x54ef44100044c675', device has successfully been paired
                                    zigbee.0
                                    2022-12-01 23:15:37.480	info	Starting interview of '0x54ef44100044c675'
                                    zigbee.0
                                    2022-12-01 22:44:29.336	info	DeviceConfigure successful 0x54ef44100044c6af lumi.remote.b28ac1
                                    zigbee.0
                                    2022-12-01 22:44:23.092	warn	This object will not be created in future versions. Please report this to the developer.
                                    zigbee.0
                                    2022-12-01 22:44:23.092	warn	Object zigbee.0.54ef44100044c6af.operation_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                                    zigbee.0
                                    2022-12-01 22:44:23.084	warn	This object will not be created in future versions. Please report this to the developer.
                                    zigbee.0
                                    2022-12-01 22:44:23.084	warn	Object zigbee.0.54ef44100044c6af.click_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                                    zigbee.0
                                    2022-12-01 22:44:23.075	warn	This object will not be created in future versions. Please report this to the developer.
                                    zigbee.0
                                    2022-12-01 22:44:23.074	warn	Object 54ef44100044c6af.operation_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                                    zigbee.0
                                    2022-12-01 22:44:23.074	warn	This object will not be created in future versions. Please report this to the developer.
                                    zigbee.0
                                    2022-12-01 22:44:23.073	warn	Object 54ef44100044c6af.click_mode is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                                    zigbee.0
                                    2022-12-01 22:44:22.998	info	Configuring 0x54ef44100044c6af lumi.remote.b28ac1
                                    zigbee.0
                                    2022-12-01 22:44:22.997	info	Device '0x54ef44100044c6af' is supported, identified as: Xiaomi Aqara wireless remote switch H1 (double rocker) (WXKG15LM)
                                    zigbee.0
                                    2022-12-01 22:44:22.997	info	Successfully interviewed '0x54ef44100044c6af', device has successfully been paired
                                    zigbee.0
                                    2022-12-01 22:44:08.708	info	Starting interview of '0x54ef44100044c6af'
                                    • amg_666A amg_666
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      arteckA Offline
                                      arteckA Offline
                                      arteck
                                      @amg_666 sagte in ZigBee neue Version 1.8.x:
                                      84fd27fffecf6567
                                      zeig mal die Datenpunkte von dem und die Kachel mit der Infoseite
                                      für den Rest hier
                                      https://github.com/ioBroker/ioBroker.zigbee/wiki/Missing-icons-after-adatapter-Update
                                      @spotterblog
                                      54ef44100044c6af
                                      von dem auch Kachel und die Infoseite
                                      • S spotterblog
                                        1.8.7 läuft soweit.
                                        arteckA Offline
                                        arteckA Offline
                                        arteck
                                        am conbee ?? dann mach erst ein firmwareupdate von dem Teil
                                        • L Offline
                                          legro
                                          @arteck said in ZigBee neue Version 1.8.x:
                                          es ist mal wieder eine neue Version da..
                                          diesmal hat sich nicht viel getan..
                                          Heißt das auch, dass hinsichtlich der BITRON-Sirenen sich nichts getan hat? 😕 Dort funktioniert die Konfiguration der Geräte payload ja nicht mehr richtig.
                                          Raspberry Pi 5 mit 8GB + 120GB SSD + Coordinator COD-m + ioBroker ..
