  4. npm ERR! code ENOTEMPTY - Adapter Upgrade nicht mehr möglich
69 Beiträge 8 Kommentatoren 16.9k Aufrufe 8 Beobachtet
    @djsirius
    iob logs
    sagt?
    Du bist aber auch etwas OffTopic hier.
    djsirius
    @thomas-braun said in npm ERR! code ENOTEMPTY - Adapter Upgrade nicht mehr möglich:
    iob logs
    iobroker@debian:~$ iob logs
    Uncaught Rejection: Error: Cannot find module 'moment'
    Require stack:
    - /opt/iobroker/node_modules/file-stream-rotator/FileStreamRotator.js
    - /opt/iobroker/node_modules/winston-daily-rotate-file/daily-rotate-file.js
    - /opt/iobroker/node_modules/winston-daily-rotate-file/index.js
    - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/logger.js
    - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
    - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
    - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:985:15)
        at Function.Module._load (node:internal/modules/cjs/loader:833:27)
        at Module.require (node:internal/modules/cjs/loader:1057:19)
        at require (node:internal/modules/cjs/helpers:103:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/file-stream-rotator/FileStreamRotator.js:15:14)
        at Module._compile (node:internal/modules/cjs/loader:1155:14)
        at Object.Module._extensions..js (node:internal/modules/cjs/loader:1209:10)
        at Module.load (node:internal/modules/cjs/loader:1033:32)
        at Function.Module._load (node:internal/modules/cjs/loader:868:12)
    djsirius
    • D djsirius
      iob logs
      Require stack:
      @djsirius
      cd /opt/iobroker
      sudo -H -u iobroker npm install iobroker.js-controller
        @djsirius
        cd /opt/iobroker
        djsirius
        iobroker@debian:~$ cd /opt/iobroker
        iobroker@debian:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-contr        oller
        npm ERR! syscall rename
        npm ERR! path /opt/iobroker/node_modules/iobroker.admin
        npm ERR! dest /opt/iobroker/node_modules/.iobroker.admin-TtUA2igk
        npm ERR! errno -39
        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.admin' -> '/opt/iobroker/node_modules/.iobroker.admin-TtUA2igk'
        npm ERR!     /home/iobroker/.npm/_logs/2022-11-03T12_22_25_791Z-debug-0.log
        djsirius
        • D djsirius
          npm ERR! errno -39
          @djsirius sagte in npm ERR! code ENOTEMPTY - Adapter Upgrade nicht mehr möglich:
          ENOTEMPTY:
          Kennst du ja schon:
          for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
            ENOTEMPTY:
            Kennst du ja schon:
            djsirius
            @thomas-braun Vielen Dank!
            Aber warum habe ich so oft diese Probleme?
            djsirius
            • D djsirius
              Das weiß ich nicht.
              Ich hab das hier nie auf meinen Systemen. Und da ist eins dabei, das wird andauernd mit 'wilden Beta/Alpha-Versionen' beackert.
                @habi
                Wenn es jetzt läuft ist doch alles in Ordnung.
                iobroker update -i
                sagt?
                ZellyZ Offline
                ZellyZ Offline
                Zelly
                ich traue mich schon fast gar nicht nachzufragen, weil ich vermutlich auch Murks gemacht habe. Ich kenne mich echt wenig aus und mein ganzes Wissen habe ich nur aus solchen Foren.
                Zu meinem Problem: Auch ich kann keine Adapter installieren und upgraden.
                Genau bei dem punkt habe ich folgende Ausgabe:
                pi@raspberrypi:~ $ iobroker update -i
                Used repository: stable
                Objects database error: write EPIPE
                Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                States database error: connect ECONNREFUSED 127.0.0.1:9000
                Adapter "admin" : 6.2.23 , installed 6.2.23
                Adapter "alexa2" : 3.21.0 , installed 3.21.0
                Adapter "backitup" : 2.5.4 , installed 2.4.12 [Updatable]
                Adapter "daswetter" : 3.1.4 , installed 3.1.4
                Adapter "deconz" : 1.3.21 , installed 2.0.5
                Adapter "discovery" : 3.0.5 , installed 3.1.0
                Adapter "email" : 1.1.3 , installed 1.1.4
                Adapter "firetv" : 1.0.0 , installed 1.0.0
                Adapter "geofency" : 1.1.1 , installed 1.2.4
                Adapter "info" : 1.9.19 , installed 1.9.21
                Adapter "javascript" : 6.0.3 , installed 6.0.3
                Controller "js-controller": 4.0.23 , installed 4.0.23
                Adapter "mihome-vacuum": 3.8.6 , installed 3.6.0 [Updatable]
                Adapter "nuki" : 1.6.0 , installed 1.6.0
                Adapter "pushover" : 3.0.3 , installed 3.0.3
                Adapter "shelly" : 6.0.0 , installed 6.2.4
                Adapter "shuttercontrol": 1.4.18 , installed 1.4.18
                Adapter "simple-api" : 2.7.0 , installed 2.7.2
                Adapter "socketio" : 4.2.0 , installed 6.1.10
                Adapter "tankerkoenig" : 2.1.1 , installed 2.1.1
                Adapter "tuya" : 3.9.4 , installed 3.7.2 [Updatable]
                Adapter "vis" : 1.4.15 , installed 1.4.15
                Adapter "web" : 4.3.0 , installed 5.2.10
                Adapter "ws" : 1.3.0 , installed 2.1.5
                Für mich zu viel "Error" in den ersten Zeilen...
                Kann mir vielleicht jemand helfen?
                • ZellyZ Zelly
                  @zelly
                  Da ist was mit der Datenbank.
                  du -h
                  iobroker restart
                  sagen z. B.
                  ZellyZ 1 Antwort Letzte Antwort
                    @zelly
                    du -h
                    iobroker restart
                    sagen z. B.
                    ZellyZ Offline
                    ZellyZ Offline
                    Zelly
                    Die Ausgabe ist zu lang, um sie hier zu posten... aber nach restart war immer noch das problem da.
                    Ist hier was falsch?
                    pi@raspberrypi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    v18.12.1
                    v18.12.1
                    8.19.2
                    nodejs:
                    Installiert: 18.12.1-deb-1nodesource1
                    Installationskandidat: 18.12.1-deb-1nodesource1
                    Versionstabelle:
                    *** 18.12.1-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
                    10.24.0~dfsg-1~deb10u2 500
                    • ZellyZ Zelly
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v18.12.1
                      v18.12.1
                      8.19.2
                      nodejs:
                      Versionstabelle:
                      @zelly
                      df -h
                      meinte ich auch, sorry.
                      Nodejs ist grundsätzlich wohl sauber installiert, allerdings ist die Empfehlung v16.
                      Dein Betriebssystem ist aus dem regulären Support raus, installier da Bullseye.
                        @zelly
                        df -h
                        ZellyZ Offline
                        ZellyZ Offline
                        Zelly
                        zunächst: vielen Dank für deine Unterstützung!
                        pi@raspberrypi:~ $ df -h
                        Dateisystem    Größe Benutzt Verf. Verw% Eingehängt auf
                        /dev/root        15G    4,2G  9,6G   31% /
                        devtmpfs        430M       0  430M    0% /dev
                        tmpfs           462M       0  462M    0% /dev/shm
                        tmpfs           462M     18M  444M    4% /run
                        tmpfs           5,0M    4,0K  5,0M    1% /run/lock
                        tmpfs           462M       0  462M    0% /sys/fs/cgroup
                        /dev/mmcblk0p1  253M     49M  204M   20% /boot
                        tmpfs            93M       0   93M    0% /run/user/1000
                        • ZellyZ Zelly
                          @zelly
                          iobroker status
                            @zelly
                            iobroker status
                            ZellyZ Offline
                            ZellyZ Offline
                            Zelly
                            pi@raspberrypi:~ $ iobroker status
                            Objects type: jsonl
                            States  type: jsonl
                            • ZellyZ Zelly
                              Objects type: jsonl
                              States  type: jsonl
                              @zelly
                              Okay...
                              iobroker stop
                              iobroker fix
                              iobroker update
                                @zelly
                                Okay...
                                iobroker stop
                                iobroker fix
                                iobroker update
                                ZellyZ Offline
                                ZellyZ Offline
                                Zelly
                                so... ist jetzt einmal durchgelaufen:
                                Kann ich jetzt wieder den iobroker starten?
                                Ich vermute "Bullseye" muss nochmal separat installiert werden?
                                • ZellyZ Zelly
                                  @zelly
                                  Dann zieh die Adapter jetzt auf den aktuellen Stand.
                                  Auf Bullseye kann u. U. online upgegraded werden.
                                  Ich hab das z. B. hier mal gemacht:
                                  https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
                                  Ansonsten: Am besten eine frische Neuinstallation, Backup einspielen.
                                    @zelly
                                    ZellyZ Offline
                                    ZellyZ Offline
                                    Zelly
                                    Hochziehen funktioniert bei mir leider nicht.
                                    Would you like to upgrade backitup from @2.4.12 to @2.5.4 now? [(y)es, (n)o]: y
                                    Update backitup from @2.4.12 to @2.5.4
                                    host.raspberrypi Adapter "system.adapter.backitup.0" is stopped.
                                    NPM version: 8.19.2
                                    Installing iobroker.backitup@2.5.4... (System call)
                                    host.raspberrypi Cannot install iobroker.backitup@2.5.4: 217
                                    So ist es mit allen Adaptern.
                                    • ZellyZ Zelly
                                      NPM version: 8.19.2
                                      @zelly
                                      Bitte immer vollständig posten.
                                      iobroker update backitup --debug
                                      Wird aber vermutlich mal wieder
                                      https://forum.iobroker.net/topic/57337/fehler-25-bei-adapter-install-update-mit-npm8
                                      sein.
                                        @zelly
                                        sein.
                                        ZellyZ Offline
                                        ZellyZ Offline
                                        Zelly
                                        also der Befehl brachte irgendwie nichts:
                                        pi@raspberrypi:~ $ iobroker update backitup --debug
                                        Used repository: backitup
                                        Error: unknown repository is active - "backitup". Known: stable, beta
                                        Im ioBroker das Upgrade direkt probiert... dabei wurde es mit "npm ERR! code ENOTEMPTY" abgebrochen:
                                        $ iobroker upgrade backitup@2.5.4 --debug
                                        NPM version: 8.19.2
                                        npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-11-24T22_00_30_809Z-debug-0.log
                                        ERROR: Process exited with code 25
                                        Also jetzt den Befehl aus dem Link ausführen?
                                        Es handelt sich ja um die Fehlermeldung 25
                                        • ZellyZ Zelly
                                          NPM version: 8.19.2
                                          @zelly sagte in npm ERR! code ENOTEMPTY - Adapter Upgrade nicht mehr möglich:
                                          iobroker repo list
                                          sagt?
                                          Den Befehl aus dem Link kannst du aber unabhänigig davon schon mal ausführen.
