  4. npm ERR! code ENOTEMPTY - Adapter Upgrade nicht mehr möglich
69 Beiträge 8 Kommentatoren 16.9k Aufrufe 8 Beobachtet
  • D djsirius
    uodates sind gemacht. iobroker start bringt nichts.
    iobroker@debian:~$ iobroker start
    iobroker@debian:~$ iob status
    iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
    @djsirius
    iob logs
    sagt?
    Du bist aber auch etwas OffTopic hier.
      @djsirius
      iob logs
      sagt?
      djsirius
      @thomas-braun said in npm ERR! code ENOTEMPTY - Adapter Upgrade nicht mehr möglich:
      iob logs
      iobroker@debian:~$ iob logs
      Uncaught Rejection: Error: Cannot find module 'moment'
      Require stack:
      - /opt/iobroker/node_modules/file-stream-rotator/FileStreamRotator.js
      - /opt/iobroker/node_modules/winston-daily-rotate-file/daily-rotate-file.js
      - /opt/iobroker/node_modules/winston-daily-rotate-file/index.js
      - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/logger.js
      - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
      - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
      - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
          at Function.Module._resolveFilename (node:internal/modules/cjs/loader:985:15)
          at Function.Module._load (node:internal/modules/cjs/loader:833:27)
          at Module.require (node:internal/modules/cjs/loader:1057:19)
          at require (node:internal/modules/cjs/helpers:103:18)
          at Object.<anonymous> (/opt/iobroker/node_modules/file-stream-rotator/FileStreamRotator.js:15:14)
          at Module._compile (node:internal/modules/cjs/loader:1155:14)
          at Object.Module._extensions..js (node:internal/modules/cjs/loader:1209:10)
          at Module.load (node:internal/modules/cjs/loader:1033:32)
          at Function.Module._load (node:internal/modules/cjs/loader:868:12)
      djsirius
      • D djsirius
        iob logs
        Require stack:
        @djsirius
        cd /opt/iobroker
        sudo -H -u iobroker npm install iobroker.js-controller
          @djsirius
          cd /opt/iobroker
          djsirius
          iobroker@debian:~$ cd /opt/iobroker
          iobroker@debian:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-contr        oller
          npm ERR! syscall rename
          npm ERR! path /opt/iobroker/node_modules/iobroker.admin
          npm ERR! dest /opt/iobroker/node_modules/.iobroker.admin-TtUA2igk
          npm ERR! errno -39
          npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.admin' -> '/opt/iobroker/node_modules/.iobroker.admin-TtUA2igk'
          npm ERR!     /home/iobroker/.npm/_logs/2022-11-03T12_22_25_791Z-debug-0.log
          djsirius
          • D djsirius
            npm ERR! errno -39
            @djsirius sagte in npm ERR! code ENOTEMPTY - Adapter Upgrade nicht mehr möglich:
            ENOTEMPTY:
            Kennst du ja schon:
            for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
              ENOTEMPTY:
              Kennst du ja schon:
              djsirius
              @thomas-braun Vielen Dank!
              Aber warum habe ich so oft diese Probleme?
              djsirius
              • D djsirius
                Das weiß ich nicht.
                Ich hab das hier nie auf meinen Systemen. Und da ist eins dabei, das wird andauernd mit 'wilden Beta/Alpha-Versionen' beackert.
                  @habi
                  Wenn es jetzt läuft ist doch alles in Ordnung.
                  iobroker update -i
                  sagt?
                  ZellyZ Offline
                  ZellyZ Offline
                  Zelly
                  ich traue mich schon fast gar nicht nachzufragen, weil ich vermutlich auch Murks gemacht habe. Ich kenne mich echt wenig aus und mein ganzes Wissen habe ich nur aus solchen Foren.
                  Zu meinem Problem: Auch ich kann keine Adapter installieren und upgraden.
                  Genau bei dem punkt habe ich folgende Ausgabe:
                  pi@raspberrypi:~ $ iobroker update -i
                  Used repository: stable
                  Objects database error: write EPIPE
                  Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                  States database error: connect ECONNREFUSED 127.0.0.1:9000
                  Adapter "admin" : 6.2.23 , installed 6.2.23
                  Adapter "alexa2" : 3.21.0 , installed 3.21.0
                  Adapter "backitup" : 2.5.4 , installed 2.4.12 [Updatable]
                  Adapter "daswetter" : 3.1.4 , installed 3.1.4
                  Adapter "deconz" : 1.3.21 , installed 2.0.5
                  Adapter "discovery" : 3.0.5 , installed 3.1.0
                  Adapter "email" : 1.1.3 , installed 1.1.4
                  Adapter "firetv" : 1.0.0 , installed 1.0.0
                  Adapter "geofency" : 1.1.1 , installed 1.2.4
                  Adapter "info" : 1.9.19 , installed 1.9.21
                  Adapter "javascript" : 6.0.3 , installed 6.0.3
                  Controller "js-controller": 4.0.23 , installed 4.0.23
                  Adapter "mihome-vacuum": 3.8.6 , installed 3.6.0 [Updatable]
                  Adapter "nuki" : 1.6.0 , installed 1.6.0
                  Adapter "pushover" : 3.0.3 , installed 3.0.3
                  Adapter "shelly" : 6.0.0 , installed 6.2.4
                  Adapter "shuttercontrol": 1.4.18 , installed 1.4.18
                  Adapter "simple-api" : 2.7.0 , installed 2.7.2
                  Adapter "socketio" : 4.2.0 , installed 6.1.10
                  Adapter "tankerkoenig" : 2.1.1 , installed 2.1.1
                  Adapter "tuya" : 3.9.4 , installed 3.7.2 [Updatable]
                  Adapter "vis" : 1.4.15 , installed 1.4.15
                  Adapter "web" : 4.3.0 , installed 5.2.10
                  Adapter "ws" : 1.3.0 , installed 2.1.5
                  Für mich zu viel "Error" in den ersten Zeilen...
                  Kann mir vielleicht jemand helfen?
                  • ZellyZ Zelly
                    @zelly
                    Da ist was mit der Datenbank.
                    du -h
                    iobroker restart
                    sagen z. B.
                    ZellyZ 1 Antwort Letzte Antwort
                      @zelly
                      du -h
                      iobroker restart
                      sagen z. B.
                      ZellyZ Offline
                      ZellyZ Offline
                      Zelly
                      Die Ausgabe ist zu lang, um sie hier zu posten... aber nach restart war immer noch das problem da.
                      Ist hier was falsch?
                      pi@raspberrypi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v18.12.1
                      v18.12.1
                      8.19.2
                      nodejs:
                      Installiert: 18.12.1-deb-1nodesource1
                      Installationskandidat: 18.12.1-deb-1nodesource1
                      Versionstabelle:
                      *** 18.12.1-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
                      10.24.0~dfsg-1~deb10u2 500
                      • ZellyZ Zelly
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        v18.12.1
                        v18.12.1
                        8.19.2
                        nodejs:
                        Versionstabelle:
                        @zelly
                        df -h
                        meinte ich auch, sorry.
                        Nodejs ist grundsätzlich wohl sauber installiert, allerdings ist die Empfehlung v16.
                        Dein Betriebssystem ist aus dem regulären Support raus, installier da Bullseye.
                          @zelly
                          df -h
                          ZellyZ Offline
                          ZellyZ Offline
                          Zelly
                          zunächst: vielen Dank für deine Unterstützung!
                          pi@raspberrypi:~ $ df -h
                          Dateisystem    Größe Benutzt Verf. Verw% Eingehängt auf
                          /dev/root        15G    4,2G  9,6G   31% /
                          devtmpfs        430M       0  430M    0% /dev
                          tmpfs           462M       0  462M    0% /dev/shm
                          tmpfs           462M     18M  444M    4% /run
                          tmpfs           5,0M    4,0K  5,0M    1% /run/lock
                          tmpfs           462M       0  462M    0% /sys/fs/cgroup
                          /dev/mmcblk0p1  253M     49M  204M   20% /boot
                          tmpfs            93M       0   93M    0% /run/user/1000
                          • ZellyZ Zelly
                            @zelly
                            iobroker status
                              @zelly
                              iobroker status
                              ZellyZ Offline
                              ZellyZ Offline
                              Zelly
                              pi@raspberrypi:~ $ iobroker status
                              Objects type: jsonl
                              States  type: jsonl
                              • ZellyZ Zelly
                                Objects type: jsonl
                                States  type: jsonl
                                @zelly
                                Okay...
                                iobroker stop
                                iobroker fix
                                iobroker update
                                  @zelly
                                  Okay...
                                  iobroker stop
                                  iobroker fix
                                  iobroker update
                                  ZellyZ Offline
                                  ZellyZ Offline
                                  Zelly
                                  so... ist jetzt einmal durchgelaufen:
                                  Kann ich jetzt wieder den iobroker starten?
                                  Ich vermute "Bullseye" muss nochmal separat installiert werden?
                                  • ZellyZ Zelly
                                    @zelly
                                    Dann zieh die Adapter jetzt auf den aktuellen Stand.
                                    Auf Bullseye kann u. U. online upgegraded werden.
                                    Ich hab das z. B. hier mal gemacht:
                                    https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
                                    Ansonsten: Am besten eine frische Neuinstallation, Backup einspielen.
                                      @zelly
                                      ZellyZ Offline
                                      ZellyZ Offline
                                      Zelly
                                      Hochziehen funktioniert bei mir leider nicht.
                                      Would you like to upgrade backitup from @2.4.12 to @2.5.4 now? [(y)es, (n)o]: y
                                      Update backitup from @2.4.12 to @2.5.4
                                      host.raspberrypi Adapter "system.adapter.backitup.0" is stopped.
                                      NPM version: 8.19.2
                                      Installing iobroker.backitup@2.5.4... (System call)
                                      host.raspberrypi Cannot install iobroker.backitup@2.5.4: 217
                                      So ist es mit allen Adaptern.
                                      • ZellyZ Zelly
                                        NPM version: 8.19.2
                                        @zelly
                                        Bitte immer vollständig posten.
                                        iobroker update backitup --debug
                                        Wird aber vermutlich mal wieder
                                        https://forum.iobroker.net/topic/57337/fehler-25-bei-adapter-install-update-mit-npm8
                                        sein.
                                          @zelly
                                          sein.
                                          ZellyZ Offline
                                          ZellyZ Offline
                                          Zelly
                                          also der Befehl brachte irgendwie nichts:
                                          pi@raspberrypi:~ $ iobroker update backitup --debug
                                          Used repository: backitup
                                          Error: unknown repository is active - "backitup". Known: stable, beta
                                          Im ioBroker das Upgrade direkt probiert... dabei wurde es mit "npm ERR! code ENOTEMPTY" abgebrochen:
                                          $ iobroker upgrade backitup@2.5.4 --debug
                                          NPM version: 8.19.2
                                          npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-11-24T22_00_30_809Z-debug-0.log
                                          ERROR: Process exited with code 25
                                          Also jetzt den Befehl aus dem Link ausführen?
                                          Es handelt sich ja um die Fehlermeldung 25
