  4. Test Adapter LG ThinQ
    6.7k
950 Beiträge 72 Kommentatoren 415.5k Aufrufe 69 Beobachtet
  • L Lucky_ESA
    @freak9882 Hier das Blockly. Ersetze die 3 xxx mit deiner Seriennummer. Dann kannst du die neuen DP in VIS darstellen.
    0_userdata.0.frigde
    0_userdata.0.freezer
     <variables>
       <variable id="Wi/oqgyp:,oi#%a0E$?O">SearchStr</variable>
       <variable id="*cZJ6NWMhBk*B}I|5EIs">SN</variable>
     </variables>
     <block type="procedures_defcustomreturn" id="{O*5V-23?}s?glAtjyra" x="38" y="-62">
       <mutation statements="false">
         <arg name="SearchStr" varid="Wi/oqgyp:,oi#%a0E$?O"></arg>
       </mutation>
       <field name="NAME">fridgeTemp</field>
       <field name="SCRIPT">Y29uc3QgVGhpbnFTdHJpbmcgPSB7DQogICAgLypmcmlkZ2VUZW1wKi8NCiAgICAnMSc6ICI3IiwNCiAgICAiMiI6ICI2IiwNCiAgICAiMyI6ICI1IiwNCiAgICAiNCI6ICI0IiwNCiAgICAiNSI6ICIzIiwNCiAgICAiNiI6ICIyIiwNCiAgICAiNyI6ICIxIg0KfTsNCg0KaWYgKFRoaW5xU3RyaW5nW1NlYXJjaFN0cl0pIHsNCiAgICByZXR1cm4gVGhpbnFTdHJpbmdbU2VhcmNoU3RyXTsNCn0gZWxzZSB7DQogICAgcmV0dXJuIFNlYXJjaFN0cjsNCn0NCg==</field>
     </block>
     <block type="procedures_defcustomreturn" id="Z.%QtZGh}:Qs=O?JP0*3" x="38" y="-37">
       </mutation>
       <field name="NAME">freezerTemp</field>
       <field name="SCRIPT">Y29uc3QgVGhpbnFTdHJpbmcgPSB7DQogICAgLypmcmlkZ2VUZW1wKi8NCiAgICAnMSc6ICctMTQnLA0KICAgICcyJzogJy0xNScsDQogICAgJzMnOiAnLTE2JywNCiAgICAnNCc6ICctMTcnLA0KICAgICc1JzogJy0xOCcsDQogICAgJzYnOiAnLTE5JywNCiAgICAnNyc6ICctMjAnLA0KICAgICc4JzogJy0yMScsDQogICAgJzknOiAnLTIyJywNCiAgICAnMTAnOiAnLTIzJywNCiAgICAnMTEnOiAnLTI0JywNCiAgICAnMjU1JzogJzAnDQp9Ow0KDQppZiAoVGhpbnFTdHJpbmdbU2VhcmNoU3RyXSkgew0KICAgIHJldHVybiBUaGlucVN0cmluZ1tTZWFyY2hTdHJdOw0KfSBlbHNlIHsNCiAgICByZXR1cm4gU2VhcmNoU3RyOw0KfQ0K</field>
     </block>
     <block type="variables_set" id="-vCvZ56ky{j9FAwwvwlQ" x="37" y="12">
       <field name="VAR" id="*cZJ6NWMhBk*B}I|5EIs">SN</field>
       <value name="VALUE">
         <block type="text" id="B6|f,HT7InjG=.a(!0h6">
           <field name="TEXT">lg-thinq.0.xxx</field>
         </block>
       </value>
       <next>
         <block type="create" id=")g:)EuZaOk51/}B#4c9:" collapsed="true">
           <field name="NAME">0_userdata.0.frigde</field>
           <value name="COMMON">
             <block type="text" id="0=`9d57uRQCT^:7^tTAR">
               <field name="TEXT">{"fridge":"Kühlschrank","type":"number"}</field>
             </block>
           </value>
           <next>
             <block type="create" id="`mtgnM-ZKQJNJ.fYpR2!" collapsed="true">
               <field name="NAME">0_userdata.0.freezer</field>
                 <block type="text" id="61LT:XA])W#hrAI4)OIi">
                   <field name="TEXT">{"freezer":"Eisschrank","type":"number"}</field>
                 </block>
               </value>
               <next>
                 <block type="update" id="kMiQ|tyj;A*)kRH?/OC*" collapsed="true">
                   <field name="OID">0_userdata.0.freezer</field>
                     <block type="procedures_callcustomreturn" id="L{/k]HHzSr4Uc[qjtbW$">
                       <mutation name="freezerTemp">
                         <arg name="SearchStr"></arg>
                       </mutation>
                       <value name="ARG0">
                         <block type="get_value_var" id="*%zcB^84Ndd!-rg[r0Az">
                           <value name="OID">
                             <shadow type="text">
                               <field name="TEXT"></field>
                             </shadow>
                             <block type="text_join" id="(HI7?cFg/SQX~Jp4c@7T">
                               <value name="ADD0">
                                 <block type="variables_get" id="e[#}VE=B!X?t^H{QMa}4">
                                 </block>
                               </value>
                               <value name="ADD1">
                                 <block type="text" id="L!/!`y~SXkNF=rFO0!=4">
                                   <field name="TEXT">.snapshot.refState.freezerTemp_C</field>
                                 </block>
                               </value>
                             </block>
                           </value>
                         </block>
                       </value>
                     </block>
                   </value>
                   <next>
                     <block type="update" id="EwM=a(`gu)XWC|ED!_vx" collapsed="true">
                       <field name="OID">0_userdata.0.frigde</field>
                         <block type="procedures_callcustomreturn" id="zQR?mTE,6]d9M,Lv7^^j">
                           <mutation name="fridgeTemp">
                           </mutation>
                           <value name="ARG0">
                             <block type="get_value_var" id="AT=L!{j)Yvb{m*~=4]82">
                               <value name="OID">
                                 </shadow>
                                 <block type="text_join" id="vrL]dVVw8EeeC|8s|0{t">
                                   <value name="ADD0">
                                     <block type="variables_get" id="hsOi##osH6XHHWF}YGB4">
                                     </block>
                                   </value>
                                   <value name="ADD1">
                                     <block type="text" id="p^+dq~hyw(hg+=@}P^Xv">
                                       <field name="TEXT">.snapshot.refState.fridgeTemp_C</field>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                             </block>
                           </value>
                         </block>
                       </value>
                       <next>
                         <block type="on_ext" id="J/jj8:/t4~w*0}`3oJm1">
                           <mutation xmlns="http://www.w3.org/1999/xhtml" items="2"></mutation>
                           <value name="OID0">
                             <shadow type="field_oid" id=")d~I5ZNj4HZ9^}ZgL}{m">
                             </shadow>
                             <block type="text_join" id="M4pMW/v[_7s8*,`)oM@A">
                               <value name="ADD0">
                                 <block type="variables_get" id="0v|nm+^LI7Ke!VWpMsmB">
                                 </block>
                               </value>
                               <value name="ADD1">
                                 <block type="text" id="*kBpQLtlf;TJZX%1@[?c">
                                 </block>
                               </value>
                             </block>
                           </value>
                           <value name="OID1">
                             <shadow type="field_oid" id="dO#WepI0Gp4k$iv!LA+d">
                             </shadow>
                             <block type="text_join" id=":VzGJBji_19+80wWMxPQ">
                               <value name="ADD0">
                                 <block type="variables_get" id="AW#;E:SvXfy=pv+~XN+u">
                                 </block>
                               </value>
                               <value name="ADD1">
                                 <block type="text" id="cQ[okqhlfABep8O8E1hI">
                                 </block>
                               </value>
                             </block>
                           </value>
                           <statement name="STATEMENT">
                             <block type="update" id="@}jp@rcqew+6q(nw#8Or">
                                 <block type="procedures_callcustomreturn" id="*tsX@gclr8l8h%zFtf5Y">
                                   </mutation>
                                   <value name="ARG0">
                                     <block type="get_value_var" id="C9K^Y6t2-jdB7:A9p[#N">
                                       <value name="OID">
                                         <shadow type="text" id="FHNhUGVu6@#Gly;T$uj9">
                                         </shadow>
                                         <block type="text_join" id=")M[dwfCYvR`FndjoL*f;">
                                           <value name="ADD0">
                                             <block type="variables_get" id="f^E:ScQ$.aNtcbDyuU]^">
                                             </block>
                                           </value>
                                           <value name="ADD1">
                                             <block type="text" id="$585HZPRVL,AaEA7i,YZ">
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <next>
                                 <block type="update" id="$g}fx7axLQ@Ex+pRv-[G">
                                     <block type="procedures_callcustomreturn" id="HB5@@W/@nOyCoMVZuB|N">
                                       </mutation>
                                       <value name="ARG0">
                                         <block type="get_value_var" id="8*b1@*p,(q.Wgx`.22~v">
                                           <value name="OID">
                                             <shadow type="text" id="^/d]p5xH#nNbB7-5=Nuw">
                                             </shadow>
                                             <block type="text_join" id="v0Kbipvp*#Wp_UlqU+UF">
                                               <value name="ADD0">
                                                 <block type="variables_get" id="@{5x!)sSfK??gHX|pGq-">
                                                 </block>
                                               </value>
                                               <value name="ADD1">
                                                 <block type="text" id=",{taw@3hLkfV4+PpbMTR">
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                 </block>
                               </next>
                             </block>
                           </statement>
                         </block>
                       </next>
                     </block>
                   </next>
                 </block>
               </next>
             </block>
           </next>
         </block>
       </next>
     </block>
    </xml>
    Edit1: Nach dem Import vom Blockly solltest du den Javascript Adapter neu starten.
    freak9882
    #176
    @lucky_esa sorry, become folgende Fehlermeldung. Hast du eine Idee?
    22.11.2022, 17:03:07.567 [info ]: javascript.0 (26959) Stop script script.js.Kühlschrank
    22.11.2022, 17:03:07.578 [info ]: javascript.0 (26959) Start javascript script.js.Kühlschrank
    22.11.2022, 17:03:07.580 [error]: javascript.0 (26959) script.js.Kühlschrank compile failed:
    at script.js.Kühlschrank:1
    André
    L 1 Antwort Letzte Antwort
    • F freak9882
      André
      Lucky_ESA
      #177
      @freak9882 sagte in Test Adapter LG ThinQ v0.0.1:
      Du hast alles ersetzt satt nur die 3 x.
      lg-thinq.0.xxx
      lg-thinq.0.7b9.....
      Gruß//Lucky
      F 1 Antwort Letzte Antwort
      • L Lucky_ESA
        lg-thinq.0.xxx
        lg-thinq.0.7b9.....
        Gruß//Lucky
        freak9882
        #178
        @lucky_esa ich bin da zu blöd zu. Das habe ich gemacht:
        Bildschirmfoto 2022-11-22 um 19.39.55.png Bildschirmfoto 2022-11-22 um 19.39.11.png
        • F freak9882
          Lucky_ESA
          #179
          @freak9882 Du musst ein Blockly erstellen und nicht ein Script. Im Blockly dann den Code von oben importieren.
          • L Lucky_ESA
            freak9882
            schrieb am zuletzt editiert von freak9882
            #180
            @lucky_esa Danke für deine Geduld, scheint jetzt zu laufen. Wo finde ich denn dann den richtigen Datenpunkt?
            Sorry, absoluter Anfänger auf dem Gebiet.
            • F freak9882
              Lucky_ESA
              schrieb am zuletzt editiert von Lucky_ESA
              #181
              @freak9882 Kein Problem.
              Wie oben beschrieben unter:
              0_userdata.0.frigde
              Edit1: Nach dem Import bitte die Instanz javascript neu starten.
              Gruß//Lucky
              • L Lucky_ESA
                0_userdata.0.frigde
                Gruß//Lucky
                freak9882
                #182
                @lucky_esa Ich geb auf, bin da zu blöd für. Sehe da keine Werte.
                Danke für deine Hilfe.
                • L Offline
                  Lucky_ESA
                  #183
                  Mach mal diesen Screenshot.
                  • L Lucky_ESA
                    freak9882
                    #184
                    hab nur die letzten 3 Ziffern gelöscht
                    • L Offline
                      Lucky_ESA
                      #185
                      Was steht bei dir hier? Deine SN ist zu kurz...
                      lg-thinq.0.xxx.platformType
                      M F 2 Antworten Letzte Antwort
                      • L Lucky_ESA
                        mmaric
                        #186
                        @lucky_esa
                        @tombox
                        Danke für Eure unermüdliche Arbeit.
                        Gibt es einen Weg sich bei Euch mit einem kleinen Obolus zu bedanken ?
                        paypal oder so ?
                        Mladen
                        • L Lucky_ESA
                          freak9882
                          #187
                          @lucky_esa DANKE, jetzt funktioniert es. Ich hatte anstatt auf copy einfache den hinteren Bereich der serial nur kopiert.Bildschirmfoto 2022-11-23 um 18.52.20.png
                          • M mmaric
                            @lucky_esa
                            @tombox
                            paypal oder so ?
                            Mladen
                            Lucky_ESA
                            #188
                            @mmaric Habe die neue Version auf dem GIT. Du kannst jetzt gerne mal vom GIT laden. Wie das genau geht habe weiter oben per Bilder beschrieben.
                            Wird bei dir irgendwo angezeigt wann dein Filter getauscht werden muss?
                            remote.break.holiday_silent_update: Hiermit musst du immer die aktuellen Daten von der Cloud laden bevor du andere Änderungen vornimmst
                            remote.break.holiday_silent_data: Hier wird der JSON von der Cloud dann gespeichert.
                            remote.break.holiday_startdate: Hier das Startdatum für den Urlaubsmodus eintragen. Das Datum darf nicht in der Vergangenheit liegen (Format DD.MM.YY HH:MM)
                            remote.break.holiday_enddate: Hier das Enddatum für den Urlaubsmodus eintragen. Das Datum darf nicht in der Vergangenheit liegen und muss größer sein als das Startdatum (Format DD.MM.YY HH:MM)
                            remote.break.holiday_heating: Heizen An/Aus (wie in der APP)
                            remote.break.holiday_water: Warmwasser An/Aus (wie in der APP)
                            remote.break.holiday_onoff: Erst die o. g. Datenpunkte füllen und dann hier den Urlaubsmodus aktivieren/deaktivieren
                            remote.break.silent_mode_starttime: Hier die Startzeit für den geräuscharmen Modus eintragen (Format HH:MM)
                            remote.break.silent_mode_endtime: Hier die Endzeit für den geräuscharmen Modus eintragen. Sollte natürlich größer als das Startdatum sein. (Format HH:MM)
                            remote.break.silent_mode_onoff: Geräuscharmen Modus aktivieren/deaktivieren
                            remote.break.holiday_sendJSON: Nur für Experten gedacht. Der JSON hat einen Array der aus JSON Type 1, 2 und 3 besteht. 1 steht für die Laufzeiten, die 2 für den Urlaubsmodus und Type 3 für den geräuscharmen Modus. Man könnte nun bei Type 1 weitere JSON`s anhängen und damit generiert man mehr Schaltzeiten. Das wollte ich jetzt nicht per Datenpunkte darstellen.
                            Danke für dein Angebot aber ich möchte nichts.
                            Du kannst ja testen...Ich werde auch noch ein wenig testen und dann tombox darum bitten in latest zu gehen.
                            Gruß//Lucky
                            • F freak9882
                              Lucky_ESA
                              #189
                              Freut mich...
                              Gruß//Lucky
                              • L Offline
                                Lars0815
                                #190
                                Guten Morgen, leider habe ich noch dem Update auf die aktuellste Version nur noch diese Meldung. Neuinstallieren brachte auch kein Erfolg.
                                lg-thinq.0
                                Zeit
                                debug
                                Nachricht
                                lg-thinq.0
                                2022-12-01 06:35:15.249 info starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.lg-thinq, node: v16.18.0, js-controller: 4.0.23
                                lg-thinq.0
                                2022-12-01 06:35:19.326 warn Terminated (UNCAUGHT_EXCEPTION): Without reason
                                lg-thinq.0
                                2022-12-01 06:35:19.324 info terminating
                                lg-thinq.0
                                2022-12-01 06:35:19.316 error Cannot convert undefined or null to object
                                lg-thinq.0
                                2022-12-01 06:35:19.315 error TypeError: Cannot convert undefined or null to object at Function.keys (<anonymous>) at LgThinq.createAirRemoteStates (/opt/iobroker/node_modules/iobroker.lg-thinq/lib/air_conditioning.js:61:16) at processTicksAndRejections (node:internal/process/task_queues:96:5) at async LgThinq.getDeviceModelInfo (/opt/iobroker/node_modules/iobroker.lg-thinq/main.js:668:17) at async LgThinq.onReady (/opt/iobroker/node_modules/iobroker.lg-thinq/main.js:154:57)
                                lg-thinq.0
                                2022-12-01 06:35:19.314 error unhandled promise rejection: Cannot convert undefined or null to object
                                lg-thinq.0
                                2022-12-01 06:35:19.313 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                lg-thinq.0
                                2022-12-01 06:35:18.861 info createAirRemoteStates: Cannot found ControlDevice
                                lg-thinq.0
                                2022-12-01 06:35:18.530 info Found: 1 devices
                                lg-thinq.0
                                2022-12-01 06:35:17.342 info Login successful
                                M T L 3 Antworten Letzte Antwort
                                • L Lars0815
                                  lg-thinq.0
                                  Zeit
                                  debug
                                  Nachricht
                                  lg-thinq.0
                                  lg-thinq.0
                                  lg-thinq.0
                                  lg-thinq.0
                                  lg-thinq.0
                                  lg-thinq.0
                                  lg-thinq.0
                                  lg-thinq.0
                                  lg-thinq.0
                                  lg-thinq.0
                                  mmaric
                                  #191
                                  @lars0815
                                  hast Du die Objekte mal gelöscht und dann die Instanz wieder gestartet ?
                                  • L Lars0815
                                    lg-thinq.0
                                    Zeit
                                    debug
                                    Nachricht
                                    lg-thinq.0
                                    lg-thinq.0
                                    lg-thinq.0
                                    lg-thinq.0
                                    lg-thinq.0
                                    lg-thinq.0
                                    lg-thinq.0
                                    lg-thinq.0
                                    lg-thinq.0
                                    lg-thinq.0
                                    tombox
                                    #192
                                    @lars0815 Mit der Github version sollte es behoben sein was aber noch interessant wäre ist ein GitHub issue wo du aus dem debug log die information von deinem gerät reinschreibst
                                    • L Lars0815
                                      lg-thinq.0
                                      Zeit
                                      debug
                                      Nachricht
                                      lg-thinq.0
                                      lg-thinq.0
                                      lg-thinq.0
                                      lg-thinq.0
                                      lg-thinq.0
                                      lg-thinq.0
                                      lg-thinq.0
                                      lg-thinq.0
                                      lg-thinq.0
                                      lg-thinq.0
                                      Lucky_ESA
                                      #193
                                      @lars0815 Bitte ein issues HIER und dein Debug Log dort posten. Ich benötige immer den Inhalt vom DP modelJsonUri damit ich das implementieren kann.
                                      Gruß//Lucky
                                      • L Lucky_ESA
                                        Gruß//Lucky
                                        Lars0815
                                        #194
                                        @lucky_esa
                                        Auch mit Version 1.3 folgendes Problem:
                                        2022-12-04 20:14:53.138 - info: lg-thinq.0 (5400) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                                        2022-12-04 20:14:53.412 - info: lg-thinq.0 (5400) starting. Version 0.1.3 (non-npm: TA2k/ioBroker.lg-thinq#c1c688b5321605dcab49f244ebdf0f707fffad0a) in /opt/iobroker/node_modules/iobroker.lg-thinq, node: v16.18.0, js-controller: 4.0.23
                                        2022-12-04 20:14:53.497 - info: smartmeter.0 (7177) Received 7 values, 3 updated
                                        2022-12-04 20:14:54.900 - info: lg-thinq.0 (5400) Login successful
                                        2022-12-04 20:14:55.784 - info: lg-thinq.0 (5400) Found: 1 devices
                                        2022-12-04 20:14:56.094 - info: lg-thinq.0 (5400) createAirRemoteStates: Cannot found ControlDevice
                                        2022-12-04 20:14:56.362 - error: lg-thinq.0 (5400) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                        2022-12-04 20:14:56.363 - error: lg-thinq.0 (5400) unhandled promise rejection: Cannot read properties of undefined (reading '0')
                                        2022-12-04 20:14:56.364 - error: lg-thinq.0 (5400) TypeError: Cannot read properties of undefined (reading '0')
                                        at LgThinq.getDeviceModelInfo (/opt/iobroker/node_modules/iobroker.lg-thinq/main.js:684:44)
                                        2022-12-04 20:14:56.365 - error: lg-thinq.0 (5400) Cannot read properties of undefined (reading '0')
                                        2022-12-04 20:14:56.371 - info: lg-thinq.0 (5400) terminating
                                        2022-12-04 20:14:56.373 - warn: lg-thinq.0 (5400) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                        2022-12-04 20:14:57.116 - error: host.rpi4 instance system.adapter.lg-thinq.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                        • L Lars0815
                                          @lucky_esa
                                          tombox
                                          #195
                                          @lars0815 kannst du mal den adapter in debug laufen lassen und den content nach
                                          Get Device Model Info
                                          posten
