  4. ERROR: Process exited with code 25 NPM Update usw
    5.6k
42 Beiträge 5 Kommentatoren 5.4k Aufrufe 3 Beobachtet
  • N n811e
    @homoran said in ERROR: Process exited with code 25 NPM Update usw:
    @n811e sagte in ERROR: Process exited with code 25 NPM Update usw:
    Zugriff auf das Webinterface habe ich dadurch auch nicht erhalten.
    so weit sind wir noch nicht, bitte keine operative Hektik
    https://forum.iobroker.net/post/884324
    was kommt jetzt bei iobroker upgrade wasauchimmer --debug ??
    jetzt kommt das:
    pi@raspberrypi:~ $ iobroker upgrade device-watcher --debug
    This upgrade of "device-watcher" will introduce the following changes:
    -> 2.0.2:
    added status to battery list
    batt devices which are offline are now still included in the battery list
    small improvements of translations
    offline time settings: you can use 0 instead of -1 (it will be the new standard)
    improvements of adaptername
    fixed issues [#66](https://github.com/ciddi89/ioBroker.device-watcher/issues/66) & [#67](https://github.com/ciddi89/ioBroker.device-watcher/issues/67)
    repaired blacklist notifications
    added handling for blacklist object
    -> 2.0.1:
    If the device is offline, set signal strength to '0%'
    If the device is offline, set battery to ' - '
    repair some small issues in the lists
    -> 2.0.0:
    added Lupusec, HS100 adapter, Zigbee2MQTT and MaxCube
    changed name of Homematic to HM-RPC
    made a completly makeover of the blacklist
    clean up the code and shorten some
    -> 1.1.0:
    removed indicatoren for daily sent messages
    changed selector for shelly devices
    added Zigbee2MQTT adapter
    added cron function to use own time for daily overview messages
    -> 1.0.1:
    added WLED, Ikea Tradfri, Roomba, HmIp, Tado, Netatmo, Yeelight-2, Unifi, Nut and Meross adapter
    fixed battery message
    corrected and repaired some issues of last contact time
    added support for old HM devices
    some small refactoring of code
    changed shelly selector from dp rssi to dp online
    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
    Would you like to upgrade device-watcher from @1.0.0 to @2.0.2 now? [(y)es, (n)o]: y
    Update device-watcher from @1.0.0 to @2.0.2
    NPM version: 8.19.2
    Installing iobroker.device-watcher@2.0.2... (System call)
    added 7 packages, removed 1508 packages, and changed 7 packages in 28s
    36 packages are looking for funding
      run `npm fund` for details
    Update "system.adapter.device-watcher.0"
    upload [19] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/device-watcher.png device-watcher.png image/png
    upload [18] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [17] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [16] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [15] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [14] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [13] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [12] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [11] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [10] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [9] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
    upload [8] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [7] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/images/add_blacklist.png images/add_blacklist.png image/png
    upload [6] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/images/list1.png images/list1.png image/png
    upload [5] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/images/list2.png images/list2.png image/png
    upload [4] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/images/list3.png images/list3.png image/png
    upload [3] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/index_m.html index_m.html text/html
    upload [2] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/jsonConfig.json jsonConfig.json application/json
    upload [1] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/style.css style.css text/css
    upload [0] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/words.js words.js application/javascript
    pi@raspberrypi:~ $
    HomoranH Offline
    HomoranH Offline
    jetzt kommt das:
    sieht das aus wie
    sehe ich keine Regung.
    Ist doch jetzt alles gefixt.
    • N n811e
      jetzt kommt das:
      -> 2.0.2:
      -> 2.0.1:
      -> 2.0.0:
      -> 1.1.0:
      -> 1.0.1:
      NPM version: 8.19.2
      pi@raspberrypi:~ $
      GlasfaserG Offline
      GlasfaserG Offline
      @n811e
      alles gut ... luppt doch !
      Die Ausgabe mit --debug ist nur für uns im Forum , dann können wir mehr sehen !
      HomoranH N 2 Antworten Letzte Antwort
      • GlasfaserG Glasfaser
        @n811e
        HomoranH Offline
        HomoranH Offline
        @glasfaser sagte in ERROR: Process exited with code 25 NPM Update usw:
        oder für den User, damit er die eben genannten Kriterien für die Ausführung des Rettungsscripts sieht
          @n811e
          N Offline
          N Offline
          n811e
          @glasfaser said in ERROR: Process exited with code 25 NPM Update usw:
          @n811e
          Ich kann da leider nichts erkennen, aber wenn ihr sagt das dass gut aussieht, freu ich mich schon mal und möchte mich bedanken.
          Aber wie erhalte ich wieder Zugriff auf Webinterface?
          HomoranH GlasfaserG 2 Antworten Letzte Antwort
          • N n811e
            @n811e
            HomoranH Offline
            HomoranH Offline
            @n811e
            dass jetzt kein Fehler mer kommt siehst du doch auch, oder nicht?
            Was sagt iobroker update -i ?
            N 1 Antwort Letzte Antwort
            • N n811e
              @n811e
              GlasfaserG Offline
              GlasfaserG Offline
              @n811e
              und was sagt
              iobroker list instances
                @n811e
                N Offline
                N Offline
                n811e
                @n811e
                Ehrlich gesagt, habe ich vorher auch keinen Fehler erkannt 😢
                iobroker update -i Sagt:
                pi@raspberrypi:~ $ iobroker update -i
                Used repository: stable
                Adapter    "admin"        : 6.2.23   , installed 6.2.23
                Adapter    "backitup"     : 2.5.4    , installed 2.4.12 [Updatable]
                Adapter    "device-watcher": 2.0.2   , installed 2.0.2
                Adapter    "discovery"    : 3.0.5    , installed 3.0.5
                Controller "js-controller": 4.0.23   , installed 4.0.23
                  @n811e
                  und was sagt
                  N Offline
                  N Offline
                  n811e
                  Das kommt dabei raus:
                  pi@raspberrypi:~ $ iobroker list instances
                    system.adapter.admin.3                  : admin                 : raspberrypi                              - disabled, port: 8089, bind: 0.0.0.0, run as: admin
                    system.adapter.alexa2.0                 : alexa2                : raspberrypi                              - disabled
                    system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              -  enabled
                  + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
                  + system.adapter.device-watcher.0         : device-watcher        : raspberrypi                              -  enabled
                  + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : raspberrypi                              -  enabled
                  + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                  + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
                  + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 12001
                  + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 12010
                  + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                    system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              - disabled
                  + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                  + system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
                  + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1886, bind: 0.0.0.0
                  + system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
                  + system.adapter.onvif.0                  : onvif                 : raspberrypi                              -  enabled
                  + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
                  + system.adapter.samsung.0                : samsung               : raspberrypi                              -  enabled
                  + system.adapter.samsung_tizen.0          : samsung_tizen         : raspberrypi                              -  enabled, port: 8002
                  + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
                  + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                  + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                  + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                  + system.adapter.synology.0               : synology              : raspberrypi                              -  enabled, port: 5000
                  + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
                  + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                  + system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
                    system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
                    system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                    system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
                  + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                    system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
                    system.adapter.vis-material-webfont.0   : vis-material-webfont  : raspberrypi                              -  enabled
                    system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
                    system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
                  + system.adapter.worx.0                   : worx                  : raspberrypi                              -  enabled
                  + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
                  + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_46f93a68f7d8eb11893d0815b9da5f8b-if00-port0
                  + instance is alive
                  • Thomas BraunT Online
                    @n811e
                    admin.3?
                    Wie dem auch sei ..
                    iobroker start admin.3
                    Läuft dann auf port: 8089 warum auch immer das verbogen wurde.
                      @n811e
                      admin.3?
                      Wie dem auch sei ..
                      N Offline
                      N Offline
                      n811e
                      @thomas-braun said in ERROR: Process exited with code 25 NPM Update usw:
                      @n811e
                      admin.3?
                      Wie dem auch sei ..
                      Leider bin ich erst heute dazu gekommen, mich damit weiter auseinander zu setzen.
                      Ess klappt jetzt!!! Vielen lieben Dank, für die vielen und vor allem schnellen Tips und Hilfen.
                      Allein hätte ich das nie hinbekommen!!
                      DANKESCHÖN
                      @Thomas-Braun
                      admin.3?
                      Wie dem auch sei ..
                      Das liegt daran, dass ich ganz am Anfang, den Tipp bekommen habe, es über diesen Befehl zu versuche:
                      sudo iobroker add admin --enabled --port 8089
                      Den Port habe ich wieder richtig gesetzt, aber glaubst Du, man bekommt den Admin-adapter wieder zu admin.0 ?
                      • N n811e
                        @n811e
                        admin.3?
                        Wie dem auch sei ..
                        DANKESCHÖN
                        @Thomas-Braun
                        admin.3?
                        Wie dem auch sei ..
                        GlasfaserG Offline
                        GlasfaserG Offline
                        Und von wem ..
                        sudo vor iobroker Befehle ist falsch !
