  4. Fehlermeldungen bei Installation mac
    5.7k
114 Beiträge 8 Kommentatoren 20.9k Aufrufe
    thoduh
    Beim hinzufügen von Adapter bekomme ich jetzt noch einen Fehler:
    $ ./iobroker add hm-rega
    npm install iobroker.hm-rega --production --prefix "/iobroker" (System call)
    npm
     WARN checkPermissions Missing write access to /iobroker/node_modules/engine.io-client/node_modulesnpm WARN checkPermissions Missing write access to /iobroker/node_modules/engine.io/node_modules
    npm WARN checkPermissions Missing write access to /iobroker/node_modules/express-session/node_modules
    npm WARN checkPermissions Missing write access to /iobroker/node_modules/npm/node_modules
    npm WARN checkPermissions Missing write access to /iobroker/node_modules/prompt/node_modules
    npm WARN checkPermissions Missing write access to /iobroker/node_modules/prompt/node_modules/winston/node_modules
    npm WARN checkPermissions Missing write access to /iobroker/node_modules/readable-stream/node_modules
    npm WARN checkPermissions Missing write access to /iobroker/node_modules/send/node_modules
    npm WARN checkPermissions Missing write access to /iobroker/node_modules/socket.io-adapter/node_modules
    npm WARN checkPermissions Missing write access to /iobroker/node_modules/socket.io-client/node_modules
    npm WARN checkPermissions Missing write access to /iobroker/node_modules/socket.io-parser/node_modules
    npm WARN checkPermissions Missing write access to /iobroker/node_modules/socket.io/node_modules
    npm WARN checkPermissions Missing write access to /iobroker/node_modules/tar.gz/node_modules
    npm
    WARN checkPermissions Missing write access to /iobroker/node_modules/unix-dgram/node_modulesnpm WARN checkPermissions Missing write access to /iobroker/node_modules/utile/node_modules
    npm WARN checkPermissions Missing write access to /iobroker/node_modules/winston/node_modules
    npm
     ERR! path /iobroker/node_modules/engine.io-client/node_modulesnpm ERR! code EACCES
    npm ERR! errno -13
    npm ERR! syscall access
    npm ERR! Error: EACCES: permission denied, access '/iobroker/node_modules/engine.io-client/node_modules'npm
     ERR!  { Error: EACCES: permission denied, access '/iobroker/node_modules/engine.io-client/node_modules'
    npm ERR!   stack: 'Error: EACCES: permission denied, access \'/iobroker/node_modules/engine.io-client/node_modules\'',npm ERR!   errno: -13,
    npm ERR!   code: 'EACCES',
    npm ERR!   syscall: 'access',
    npm ERR!   path: '/iobroker/node_modules/engine.io-client/node_modules' }
    npm ERR!
    npm ERR! Please try running this command again as root/Administrator.
    npm ERR! A complete log of this run can be found in:npm ERR!     /Users/MacMini/.npm/_logs/2017-07-27T15_56_32_482Z-debug.log
    ERROR: host.MacMini-LAN.fritz.box Cannot install iobroker.hm-rega: 243
      #66
      @thoduh:
      node-version: v8.2.1 `
      Die ist noch sehr neu und nicht von uns getestet.
      Bisher war die 4.x.x und neuerdings die 6.x.x die Empfohlene Version.
      die 8.x.x ist IMHO noch nicht als LTS-Version gekennzeichnet.
      • BuZZyB Offline
        BuZZyB Offline
        BuZZy
        #67
        Mach jetzt nochmal
        sudo chmod -R 777 /iobroker
        Dann versuch nochmal einen Adapter zu installieren.
          thoduh
          #68
          ERROR: module.js:487    throw err;
          Error: Cannot find module 'mime'
              at Function.Module._resolveFilename (module.js:485:15)
              at Function.Module._load (module.js:437:25)
              at Module.require (module.js:513:17)
              at require (internal/module.js:11:18)
              at Install.createInstance (/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:584:27)
              at /iobroker/node_modules/iobroker.js-controller/lib/setup.js:741:41
              at /iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:157:39
              at enableAdapters (/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:47:21)
              at /iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:156:21
              at ChildProcess. <anonymous>(/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:325:31)
          ERROR: process exited with code 1</anonymous>
          habe iobroker gerade im Terminal mit ctrl+c abgebrochen und bekomme es jetzt wieder nicht zum laufen :shock:
          MacMini-LAN:iobroker MacMini$ cd node_modules/iobroker.js-controller
          -bash: cd: node_modules/iobroker.js-controller: No such file or directory
          Auch start oder stop funktioniert nicht…
          • BuZZyB Offline
            BuZZyB Offline
            BuZZy
            #69
            Durchsuch mal den ganzen Mac ob irgendwo der Ordner iobroker.js-controller vorhanden ist.
            Mir gehen so langsam die Ideen aus, als letztes würde ich probieren auf die vom Rainer empfohlene Version vom Node zurück zu gehen (Node deinstallieren und dann node (6.x.x) installieren) und dann nochmal iobroker installieren.
            Von unterwegs gesendet
              thoduh
              #70
              Also anscheinend gibt es diesen Ordner nicht mehr.
              Habe so langsam auch meine Zweifel ob ich meine bisher funktionierende und gepflegte gut Hausautomatisierung einem so instabilen System anvertrauen sollte…
              Werde am WE noch ein letztes mal danach schauen, denn wenn ich ständig an dem System zweifeln muss, ist das nichts für mich.
              Trotzdem nochmals VIELEN DANK !
                #71
                Ich werde nachher mal sehen, ob ich noch irgendwo mal IoB mit Nodejs 8.x installieren kann.
                Dann sehen wir wenigstens, ob es daran liegt.
                • BuZZyB Offline
                  BuZZyB Offline
                  BuZZy
                  #72
                  Lass dir gesagt sein dass es absolut keine Probleme gibt und iobroker wirklich sehr sehr gut läuft. Aber wenn die richtigen Installationsbedingungen nicht gegeben sind (falsche node Version, falsche Berechtigungen, eventuell auch Einschränkungen von Apple die im Betriebssystem gemacht werden) kann das Programm (iobroker) nichts dafür. Versuch auf eine node 6.x.x Version runter zu gehen und dann nochmal installieren. :)
                  Ein Mac ist ja eigentlich auch kein "Server".. ;)
                  • supernova1963S Offline
                    supernova1963
                    #73
                    Hallo thoduh,
                    Also, wenn ich dich recht verstehe, willst du den Ordner ioBroker unbedingt im root Verzeichnis deiner Systemplatte platzieren und mit sudo chmod -R 777 /iobroker jedem alle Rechte auf diesen Verzeichnisbaum geben.
                    Kann ich dich irgendwie davon abbringen?
                    Ich würde den Ordner unter /User/MacMini/Documents/ioBrokerMac angelegen (ohne sudo!!!) und es funktioniert trotzdem (bzw. gerade deswegen).
                    cd /Users/MacMini/Documents
                    mkdir ioBrokerMac
                    cd /Users/MacMini/Documents/ioBrokerMac
                    npm install https://github.com/ioBroker/ioBroker.js-controller/tarball/master --production --prefix /Users/MacMini/Documents/ioBrokerMac
                    cd /Users/MacMini/Documents/ioBrokerMac/node_modules/iobroker.js-controller
                    # Hier ein sudo, sicherheitshalber, wenn MacMini kein Admin ist, sonst geht's auch ohne
                    sudo chmod +x iobroker
                    node controller.js
                    Wenn das nicht läuft, liegt's an der nicht getesteten node Version 8.x.
                    Es läuft bei mir zum Test auf einem Mac Mini Mac OS Sierra 10.12.6 (16G29) node -v = v6.11.1
                    Die Befehle: ./iobroker start, stop, … funktionieren bei mir derzeit auch nicht. Ich muß mal sehen, ob ich dahinter komme, oder ob es irgendwie mit der Installation zusammenhängt.
                    LG
                    Gernot
                      #74
                      @supernova1963:
                      Wenn das nicht läuft, liegt's an der nicht getesteten node Version 8.x. `
                      Installation auf OPi plus2e läuft gerade.
                      Werde Nodejs 8.x nehmen
                      • AlCalzoneA Offline
                        AlCalzoneA Offline
                        AlCalzone
                        #75
                        @thoduh:
                        Habe so langsam auch meine Zweifel ob ich meine bisher funktionierende und gepflegte gut Hausautomatisierung einem so instabilen System anvertrauen sollte… `
                        Sei mir nicht böse, aber ioBroker ist mittlerweile so stabil, dass 95% der Probleme vor dem Bildschirm zu erwarten sind, gerade bei Installationsproblemen.
                        Deine Probleme klingen mir schwer nach fehlenden Berechtigungen. Auf einem UNIX-artigen System wie OSX und Linux ist es außerdem ungewöhnlich direkt in "/" zu installieren.
                        Wenn du nicht wie in der Anleitung empfohlen auf ein User-Verzeichnis ausweichen willst (auf Linux wird "/opt/iobroker" empfohlen), könnte es notwendig sein, ein "sudo" vor die Befehle zu setzen, d.h.
                        sudo npm install ...
                        sudo iobroker add ...
                        ...etc
                          #76
                          @AlCalzone:
                          Deine Probleme klingen mir schwer nach fehlenden Berechtigungen `
                          Davon gehe ich ja auch aus.
                          Bin gerade dabei nodejs 8 zu testen, da ist dieser Teil der Anleitung:
                          ioBroker installieren
                          sudo mkdir /opt/iobroker
                          sudo chmod 777 /opt/iobroker
                          cd /opt/iobroker
                          sudo npm install iobroker --unsafe-perm
                          das chmod 777 ist entscheidend.
                            #77
                            Update:
                            Die Installation ist durch. Der OPi meinte noch ein Kernel-Update fahren zu müssen :(
                            Die Installation sah auch etwas wild aus:
                            root@OPi:~# node -v
                            v8.2.1
                            root@OPi:~# sudo mkdir /opt/iobroker
                            root@OPi:~# sudo chmod 777 /opt/iobroker
                            root@OPi:~# cd /opt/iobroker
                            root@OPi:/opt/iobroker# sudo npm install iobroker --unsafe-perm
                            ! > iobroker@1.0.0 install /opt/iobroker/node_modules/iobroker
                            node lib/setup.js
                            ! npm install iobroker.discovery --production --prefix /opt/iobroker
                            node-pre-gyp info it worked if it ends with ok
                            node-pre-gyp verb cli [ '/usr/bin/nodejs',
                            node-pre-gyp verb cli '/opt/iobroker/node_modules/serialport/node_modules/.bin/node-pre-gyp',
                            node-pre-gyp verb cli 'install',
                            node-pre-gyp verb cli '--fallback-to-build' ]
                            node-pre-gyp info using node-pre-gyp@0.6.32
                            node-pre-gyp info using node@8.2.1 | linux | arm
                            node-pre-gyp verb command install []
                            node-pre-gyp info check checked for "/opt/iobroker/node_modules/serialport/build/Release/serialport.node" (not found)
                            node-pre-gyp http GET https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v57-linux-arm.tar .gz
                            node-pre-gyp http 404 https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v57-linux-arm.tar .gz
                            node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-no de-v57-linux-arm.tar.gz
                            node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@8.2.1 (node-v57 ABI) (falling back to source compile with node-gyp)
                            node-pre-gyp http 404 status code downloading tarball https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialpo rt-v4.0.7-node-v57-linux-arm.tar.gz
                            node-pre-gyp verb command build [ 'rebuild' ]
                            ../src/serialport.cpp: In function ‘int getIntFromObject(v8::Localv8::object, std::string)’:
                            ../src/serialport.cpp:90:52: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/8.2.1/include/node/v8.h:9336): Use maybe version [-Wdeprecated-declarations]
                            return getValueFromObject(options, key)->ToInt32()->Int32Value();
                            ../src/serialport.cpp: In function ‘double getDoubleFromObject(v8::Localv8::object, std::string)’:
                            ../src/serialport.cpp:102:53: warning: ‘v8::Local v8::numberv8::Value::ToNumber() const’ is deprecated (declared at /root/.node-gyp/8.2.1/include/node/v8.h:9300): Use maybe version [-Wdeprecated-declarations]
                            return getValueFromObject(options, key)->ToNumber()->NumberValue();
                            ../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:
                            ../src/serialport.cpp:174:31: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/8.2.1/include/node/v8.h:9336): Use maybe version [-Wdeprecated-declarations]
                            int fd = argv[1]->ToInt32()->Int32Value();
                            ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
                            ../src/serialport.cpp:193:29: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/8.2.1/include/node/v8.h:9336): Use maybe version [-Wdeprecated-declarations]
                            int fd = info[0]->ToInt32()->Int32Value();
                            ../src/serialport.cpp:217:116: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/8.2.1/include/node/v8.h:9336): Use maybe version [-Wdeprecated-declarations]
                            baton->baudRate = Nan::Get(options, Nan::Newv8::string("baudRate").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
                            ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Write(Nan::NAN_METHOD_ARGS_TYPE)’:
                            ../src/serialport.cpp:252:29: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/8.2.1/include/node/v8.h:9336): Use maybe version [-Wdeprecated-declarations]
                            ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
                            ../src/serialport.cpp:369:32: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/8.2.1/include/node/v8.h:9336): Use maybe version [-Wdeprecated-declarations]
                            baton->fd = info[0]->ToInt32()->Int32Value();
                            ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
                            ../src/serialport.cpp:480:29: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/8.2.1/include/node/v8.h:9336): Use maybe version [-Wdeprecated-declarations]
                            ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
                            ../src/serialport.cpp:528:29: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/8.2.1/include/node/v8.h:9336): Use maybe version [-Wdeprecated-declarations]
                            ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
                            ../src/serialport.cpp:585:29: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/8.2.1/include/node/v8.h:9336): Use maybe version [-Wdeprecated-declarations]
                            ../src/serialport_unix.cpp: In function ‘OpenBatonPlatformOptions* ParsePlatformOptions(const v8::Localv8::object&)’:
                            ../src/serialport_unix.cpp:44:109: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/8.2.1/include/node/v8.h:9336): Use maybe version [-Wdeprecated-declarations]
                            result->vmin = Nan::Get(options, Nan::Newv8::string("vmin").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
                            ../src/serialport_unix.cpp:45:111: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/8.2.1/include/node/v8.h:9336): Use maybe version [-Wdeprecated-declarations]
                            result->vtime = Nan::Get(options, Nan::Newv8::string("vtime").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
                            ../src/serialport_poller.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE SerialportPoller::New(Nan::NAN_METHOD_ARGS_TYPE)’:
                            ../src/serialport_poller.cpp:86:31: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/8.2.1/include/node/v8.h:9336): Use maybe version [-Wdeprecated-declarations]
                            obj->fd_ = info[0]->ToInt32()->Int32Value();
                            node-pre-gyp info ok
                            npm WARN saveError ENOENT: no such file or directory, open '/opt/iobroker/package.json'
                            npm notice created a lockfile as package-lock.json. You should commit this file.
                            npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json'
                            npm WARN iobroker No description
                            npm WARN iobroker No repository field.
                            npm WARN iobroker No README data
                            npm WARN iobroker No license field.
                            ! npm install iobroker.admin --production --prefix /opt/iobroker
                            ! npm install iobroker.js-controller --production --prefix /opt/iobroker
                            ! Write "./iobroker start" to start the ioBroker
                            Auto-start was enabled. Write "update-rc.d -f iobroker.sh remove" to disable auto-start
                            iobroker is started. Go to "http://ip-addr:8081" to open the admin UI.
                            ! + iobroker@1.0.0
                            added 46 packages in 444.962s
                            root@OPi:/opt/iobroker# iobroker restart
                            iobroker controller daemon is not running
                            Starting iobroker controller daemon...
                            iobroker controller daemon started. PID: 2039</v8::int32></v8::string></v8::int32></v8::string></v8::int32></v8::object></v8::int32></v8::int32></v8::int32></v8::int32></v8::int32></v8::string></v8::int32></v8::int32></v8::int32></v8::number></v8::object></v8::int32></v8::object>
                            ABER ioBroker war …..nicht erreichbar.
                            ein
                            brachte dann die Erkenntnis:
                            Danach war dann der Admin unter <ip>:8081 erreichbar.
                            Also am node 8.2.1 liegt es nicht.
                            Ich habe die Installation als root durchgeführt.
                            Rainer</ip>
                              #78
                              Addendum:
                              Hier die Dateistruktur:
                              • BuZZyB Offline
                                BuZZyB Offline
                                BuZZy
                                #79
                                Funktioniert denn auch die Adapterinstallation bei dir Rainer?
                                  #80
                                  Discovery und Admin hatte er ja schon während der Grundinstallation installiert,
                                  im Moment versuche ich den RPi2-Adapter zu installieren…
                                  ...und NEIN, Exit mit Code 1
                                  $ ./iobroker add rpi2
                                  npm install iobroker.rpi2 --production --prefix "/opt/iobroker" (System call)
                                      at Install.createInstance (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:584:27)
                                      at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:741:41
                                      at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:157:39
                                      at enableAdapters (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:47:21)
                                      at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:156:21
                                      at ChildProcess. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:325:31)
                                  Ich teste noch mal welche
                                  EDIT1:
                                  $ ./iobroker add hm-rpc
                                  Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                      at Function.Module.runMain (module.js:605:10)
                                      at startup (bootstrap_node.js:158:16)
                                      at bootstrap_node.js:575:3
                                  EDIT2:
                                  • BuZZyB Offline
                                    BuZZyB Offline
                                    BuZZy
                                    #81
                                    Wie sieht es denn aus wenn du es unter node 6.x.x versuchst?
                                      #82
                                      Jetzt lief gar nichts mehr, kein iobroker update, kein drüberinstallieren - da kam auch ENOSELF
                                      npm ERR! code ENOSELF
                                      npm ERR! Refusing to install package with name "iobroker" under a package
                                      npm ERR! also called "iobroker". Did you name your project the same
                                      npm ERR! as the dependency you're installing?
                                      npm ERR!
                                      npm ERR! For more information, see:
                                      npm ERR!     <https: docs.npmjs.com/cli/install#limitations-of-npms-install-algorithm="">npm ERR! A complete log of this run can be found in:
                                      npm ERR!     /root/.npm/_logs/2017-07-27T19_02_55_498Z-debug.log</https:>
                                      Hab nochmal komplett gelöscht und Installiere nochmal unter Nodejs 8
                                      Wenn das wieder schiefgeht lösch ich node8 und mach es unter node 6
                                        #83
                                        Zweiter Anlauf mit Node8 hat auch nicht geklappt.
                                        Erster Versuch mit Node6 brachte auch einen ENOSELF. Da das nicht sein konnte/durfte einen reboot gefahren.
                                        Dann ordentlich mit Ähnlichen Warnungen durchgefahren:
                                        node lib/setup.js
                                        node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v48-linux-arm.tar.gz
                                        node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@6.11.1 (node-v48 ABI) (falling back to source compile with node-gyp)
                                        ../src/serialport.cpp:90:52: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
                                        ../src/serialport.cpp:102:53: warning: ‘v8::Local v8::numberv8::Value::ToNumber() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8173): Use maybe version [-Wdeprecated-declarations]
                                        ../src/serialport.cpp:174:31: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
                                        ../src/serialport.cpp:193:29: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
                                        ../src/serialport.cpp:217:116: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
                                        ../src/serialport.cpp:252:29: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
                                        ../src/serialport.cpp:369:32: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
                                        ../src/serialport.cpp:480:29: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
                                        ../src/serialport.cpp:528:29: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
                                        ../src/serialport.cpp:585:29: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
                                        ../src/serialport_unix.cpp:44:109: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
                                        ../src/serialport_unix.cpp:45:111: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
                                        ../src/serialport_poller.cpp:86:31: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
                                        /opt/iobroker
                                        └─┬ iobroker@1.0.0
                                        └─┬ yargs@7.1.0
                                        ├── camelcase@3.0.0
                                        ├─┬ cliui@3.2.0
                                        │ ├─┬ strip-ansi@3.0.1
                                        │ │ └── ansi-regex@2.1.1
                                        │ └── wrap-ansi@2.1.0
                                        ├── decamelize@1.2.0
                                        ├── get-caller-file@1.0.2
                                        ├─┬ os-locale@1.4.0
                                        │ └─┬ lcid@1.0.0
                                        │ └── invert-kv@1.0.0
                                        ├─┬ read-pkg-up@1.0.1
                                        │ ├─┬ find-up@1.1.2
                                        │ │ ├── path-exists@2.1.0
                                        │ │ └─┬ pinkie-promise@2.0.1
                                        │ │ └── pinkie@2.0.4
                                        │ └─┬ read-pkg@1.1.0
                                        │ ├─┬ load-json-file@1.1.0
                                        │ │ ├── graceful-fs@4.1.11
                                        │ │ ├─┬ parse-json@2.2.0
                                        │ │ │ └─┬ error-ex@1.3.1
                                        │ │ │ └── is-arrayish@0.2.1
                                        │ │ ├── pify@2.3.0
                                        │ │ └─┬ strip-bom@2.0.0
                                        │ │ └── is-utf8@0.2.1
                                        │ ├─┬ normalize-package-data@2.4.0
                                        │ │ ├── hosted-git-info@2.5.0
                                        │ │ ├─┬ is-builtin-module@1.0.0
                                        │ │ │ └── builtin-modules@1.1.1
                                        │ │ ├── semver@5.4.1
                                        │ │ └─┬ validate-npm-package-license@3.0.1
                                        │ │ ├─┬ spdx-correct@1.0.2
                                        │ │ │ └── spdx-license-ids@1.2.2
                                        │ │ └── spdx-expression-parse@1.0.4
                                        │ └── path-type@1.1.0
                                        ├── require-directory@2.1.1
                                        ├── require-main-filename@1.0.1
                                        ├── set-blocking@2.0.0
                                        ├─┬ string-width@1.0.2
                                        │ ├── code-point-at@1.1.0
                                        │ └─┬ is-fullwidth-code-point@1.0.0
                                        │ └── number-is-nan@1.0.1
                                        ├── which-module@1.0.0
                                        ├── y18n@3.2.1
                                        └── yargs-parser@5.0.0
                                        ! npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json'
                                        iobroker controller daemon started. PID: 1580</v8::int32></v8::string></v8::int32></v8::string></v8::int32></v8::object></v8::int32></v8::int32></v8::int32></v8::int32></v8::int32></v8::string></v8::int32></v8::int32></v8::int32></v8::number></v8::object></v8::int32></v8::object>
                                        und zum Schluss auch nicht selber gestartet.
                                        Installation von rpi2 hat geklappt. HM-rpc auc und hm-rega läuft gerade (zu dem Zeitpunkt war es unter node8 bereits beendet)
                                        Jetzt weiß ich nur nicht ob es unter node8 vielleicht nach einem reboot zu irgendeinem Zeitpunkt dann ebenfalls geklappt hätte???
                                          tesso
                                          #84
                                          Mein opi2e läuft seit Wochen mit node 8.0.0 und das stabil.
                                          die node 8.2.1 kann ich heute abend testen.
