  4. [gelöst] Admin - Website nicht erreichbar
    5.6k
18 Beiträge 5 Kommentatoren 1.6k Aufrufe 5 Beobachtet
  • CodierknechtC Codierknecht
    @ctnnemo
    Bitte die Ausgaben der Konsole als Text kopieren und hier in Code-Tags posten.
    Dazu das Terminalfenster groß ziehen, damit hier kein Zeilenumbruch zuschlägt.
    CodierknechtC Offline
    Codierknecht
    @codierknecht sagte in Admin - Website nicht erreichbar:
    HmIP|ZigBee|Tasmota|Unifi
    Zabbix Certified Specialist
    C 1 Antwort Letzte Antwort
      ctnnemo
      @codierknecht
      sorry - neuer Versuch - 🤡
      code_textpi@ioBroker-RasPi4:/opt/iobroker $ iobroker update
      Used repository: stable
      Adapter    "alexa2"       : 3.21.0   , installed 3.19.9 [Updatable]
      Adapter    "backitup"     : 2.5.4    , installed 2.4.12 [Updatable]
      Adapter    "daswetter"    : 3.1.4    , installed 3.1.3  [Updatable]
      Adapter    "discovery"    : 3.0.5    , installed 3.0.5
      Adapter    "dwd"          : 2.8.3    , installed 2.8.3
      Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
      Adapter    "flot"         : 1.11.0   , installed 1.11.0
      Adapter    "history"      : 2.2.0    , installed 2.2.0
      Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
      Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
      Adapter    "hs100"        : 2.1.2    , installed 2.1.2
      Adapter    "ical"         : 1.13.1   , installed 1.13.1
      Adapter    "info"         : 1.9.19   , installed 1.9.19
      Adapter    "iot"          : 1.11.9   , installed 1.11.9
      Controller "js-controller": 4.0.23   , installed 4.0.23
      Adapter    "logparser"    : 1.1.0    , installed 1.1.0
      Adapter    "lupusec"      : 1.3.6    , installed 1.3.6
      Adapter    "mclighting"   : 0.1.2    , installed 0.1.2
      Adapter    "mihome-vacuum": 3.8.6    , installed 3.4.2  [Updatable]
      Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
      Adapter    "nuki"         : 1.6.0    , installed 1.6.0
      Adapter    "nuki-extended": 2.3.1    , installed 2.6.5
      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
      Adapter    "pvforecast"   : 2.3.0    , installed 2.3.0
      Adapter    "roomba"       : 1.1.4    , installed 1.1.4
      Adapter    "rssfeed"      : 2.6.1    , installed 2.6.1
      Adapter    "shelly"       : 6.0.0    , installed 6.0.0
      Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
      Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
      Adapter    "spotify-premium": 1.2.1  , installed 1.2.1
      Adapter    "telegram"     : 1.14.1   , installed 1.14.1
      Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
      Adapter    "tuya"         : 3.8.1    , installed 3.6.15 [Updatable]
      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
      Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
      Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
      Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
      Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
      Adapter    "whatsapp-cmb" : 0.2.2    , installed 0.2.2
      Adapter    "worx"         : 2.0.3    , installed 1.7.0  [Updatable]
      pi@ioBroker-RasPi4:/opt/iobroker $ iobroker list instances
      + system.adapter.admin.0                  : admin                 : ioBroker-RasPi4                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alexa2.0                 : alexa2                : ioBroker-RasPi4                          -  enabled
        system.adapter.backitup.0               : backitup              : ioBroker-RasPi4                          -  enabled
        system.adapter.daswetter.0              : daswetter             : ioBroker-RasPi4                          -  enabled
        system.adapter.discovery.0              : discovery             : ioBroker-RasPi4                          -  enabled
        system.adapter.dwd.0                    : dwd                   : ioBroker-RasPi4                          -  enabled
        system.adapter.feiertage.0              : feiertage             : ioBroker-RasPi4                          -  enabled
        system.adapter.flot.0                   : flot                  : ioBroker-RasPi4                          - disabled
        system.adapter.history.0                : history               : ioBroker-RasPi4                          -  enabled
        system.adapter.hm-rega.0                : hm-rega               : ioBroker-RasPi4                          -  enabled
        system.adapter.hm-rpc.2                 : hm-rpc                : ioBroker-RasPi4                          -  enabled, port: 12001
        system.adapter.hm-rpc.3                 : hm-rpc                : ioBroker-RasPi4                          -  enabled, port: 12010
        system.adapter.hs100.0                  : hs100                 : ioBroker-RasPi4                          -  enabled
        system.adapter.ical.0                   : ical                  : ioBroker-RasPi4                          -  enabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker-RasPi4                          -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker-RasPi4                          -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker-RasPi4                          -  enabled
        system.adapter.info.0                   : info                  : ioBroker-RasPi4                          -  enabled
        system.adapter.iot.0                    : iot                   : ioBroker-RasPi4                          -  enabled
        system.adapter.javascript.0             : javascript            : ioBroker-RasPi4                          -  enabled
        system.adapter.logparser.0              : logparser             : ioBroker-RasPi4                          -  enabled
        system.adapter.lupusec.0                : lupusec               : ioBroker-RasPi4                          -  enabled
      + system.adapter.mclighting.0             : mclighting            : ioBroker-RasPi4                          - disabled, port: 81
        system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker-RasPi4                          -  enabled, port: 54321
        system.adapter.mobile.0                 : mobile                : ioBroker-RasPi4                          - disabled
        system.adapter.mqtt.0                   : mqtt                  : ioBroker-RasPi4                          -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.nuki-extended.0          : nuki-extended         : ioBroker-RasPi4                          -  enabled
        system.adapter.ping.0                   : ping                  : ioBroker-RasPi4                          -  enabled
        system.adapter.pollenflug.0             : pollenflug            : ioBroker-RasPi4                          -  enabled
        system.adapter.roomba.0                 : roomba                : ioBroker-RasPi4                          -  enabled
        system.adapter.rpi2.0                   : rpi2                  : ioBroker-RasPi4                          -  enabled
        system.adapter.rssfeed.0                : rssfeed               : ioBroker-RasPi4                          -  enabled
        system.adapter.shelly.0                 : shelly                : ioBroker-RasPi4                          -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.sonoff.0                 : sonoff                : ioBroker-RasPi4                          -  enabled, port: 1885, bind: 0.0.0.0
        system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker-RasPi4                          -  enabled
        system.adapter.tr-064.0                 : tr-064                : ioBroker-RasPi4                          -  enabled
        system.adapter.tuya.0                   : tuya                  : ioBroker-RasPi4                          - disabled
        system.adapter.upnp.0                   : upnp                  : ioBroker-RasPi4                          -  enabled
        system.adapter.vis-bars.0               : vis-bars              : ioBroker-RasPi4                          -  enabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker-RasPi4                          - disabled
        system.adapter.vis-history.0            : vis-history           : ioBroker-RasPi4                          -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker-RasPi4                          -  enabled
        system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker-RasPi4                          -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker-RasPi4                          -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : ioBroker-RasPi4                          -  enabled
        system.adapter.vis-metro.0              : vis-metro             : ioBroker-RasPi4                          -  enabled
        system.adapter.vis-players.0            : vis-players           : ioBroker-RasPi4                          -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker-RasPi4                          -  enabled
        system.adapter.vis.0                    : vis                   : ioBroker-RasPi4                          -  enabled
        system.adapter.web.0                    : web                   : ioBroker-RasPi4                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.worx.0                   : worx                  : ioBroker-RasPi4                          -  enabled
      + instance is alive
      • C ctnnemo
        @codierknecht
        + instance is alive
        crunchipC Abwesend
        crunchipC Abwesend
        @ctnnemo da ging wohl was schief, admin Instanz aber kein Adapter
        • C Offline
          ctnnemo
          Wie kann ich das Problem lösen?
          Der Versuch eine 2te Admin - Instanz zu installieren schlägt fehl.
          Die Admin - Instand zu löschen geht nicht weil WEB-Instanz davon abhänig ist.
          • CodierknechtC Offline
            Codierknecht
            @ctnnemo sagte in Admin - Website nicht erreichbar:
            Na wenn kein Admin-Adapter vorhanden oder zumindest nicht sauber installiert ist, dürfte das auch schwierig werden.
            Mein Rat: Hab Geduld bis sich die Spezialisten melden.
            Wenn Du nicht bis dahin warten kannst/willst:
            Ich hoffe, ein
            iobroker stop
            iobroker fix
            iobroker restart
            kann ich an der Stelle empfehlen, ohne dass mir einer der Experten den Kopf dafür abreisst.
            • C ctnnemo
              crunchipC Abwesend
              crunchipC Abwesend
              @ctnnemo
              iob add admin --debug
              danach nochmal prüfen
              iob list adapters
                @ctnnemo
                iob list adapters
                ctnnemo
                @Codierknecht : Versucht habe ich es ... lief ohne Auffälligkeiten.
                gebracht hat es aber leider nix.
                @crunchip
                .... leider zickt das Teil
                pi@ioBroker-RasPi4:/opt/iobroker $ iob add admin
                NPM version: 8.19.2
                Installing iobroker.admin@6.2.23... (System call)
                host.ioBroker-RasPi4 Cannot install iobroker.admin@6.2.23: 217
                GlasfaserG crunchipC 2 Antworten Letzte Antwort
                • C ctnnemo
                  @crunchip
                  NPM version: 8.19.2
                  GlasfaserG Offline
                  GlasfaserG Offline
                  217
                  Was zeigt
                  • C ctnnemo
                    @crunchip
                    NPM version: 8.19.2
                    crunchipC Abwesend
                    crunchipC Abwesend
                    @ctnnemo da fehlt der --debug am Ende, dann würden wir auch sehen warum
                    • C Offline
                      ctnnemo
                      pi@ioBroker-RasPi4:/opt/iobroker $ iob add admin --debug
                      NPM version: 8.19.2
                      npm ERR! code ENOTEMPTY
                      npm ERR! syscall rename
                      npm ERR! path /opt/iobroker/node_modules/es-abstract
                      npm ERR! dest /opt/iobroker/node_modules/.es-abstract-bryRKUKR
                      npm ERR! errno -39
                      npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/es-abstract' -> '/opt/iobroker/node_modules/.es-abstract-bryRKUKR'
                      npm ERR!     /home/iobroker/.npm/_logs/2022-11-18T22_09_49_746Z-debug-0.log
                      oh man. ich glaube das Hauptproblem sitzt ca. 50 cm vor dem Monitor 🙄
                      mit den Tiefen des Systems habe ich mich nie beschäftigt.
                      • C ctnnemo
                        NPM version: 8.19.2
                        npm ERR! errno -39
                        GlasfaserG Offline
                        GlasfaserG Offline
                        Siehe hier .. wie man da vorgeht .
                        https://forum.iobroker.net/topic/57337/fehler-25-bei-adapter-install-update-mit-npm8
                        • GlasfaserG Glasfaser
                          ctnnemo
                          @glasfaser
                          @Codierknecht
                          @crunchip
                          @Thomas-Braun
                          ganz herzlichen Dank für eure Hilfe. Ich konnte die Admin-Instanz wieder installieren und darauf zugreifen! Ihr seid SPITZE!!!!!!!!
