  4. [gelöst] Admin - Website nicht erreichbar
    5.6k
18 Beiträge 5 Kommentatoren 1.6k Aufrufe 5 Beobachtet
  • CodierknechtC Codierknecht
    @ctnnemo
    Bitte die Ausgaben der Konsole als Text kopieren und hier in Code-Tags posten.
    Dazu das Terminalfenster groß ziehen, damit hier kein Zeilenumbruch zuschlägt.
    ctnnemo
    @codierknecht
    1. Vielen Dank erstmal für deine Hilfe - bin nach 3 Stunden echt am Verzweifeln -
    pi@ioBroker-RasPi4:/opt/iobroker $ iobroker update
    Used repository: stable
    Adapter    "alexa2"       : 3.21.0   , installed 3.19.9 [Updatable]
    Adapter    "backitup"     : 2.5.4    , installed 2.4.12 [Updatable]
    Adapter    "daswetter"    : 3.1.4    , installed 3.1.3  [Updatable]
    Adapter    "discovery"    : 3.0.5    , installed 3.0.5
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "history"      : 2.2.0    , installed 2.2.0
    Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
    Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
    Adapter    "hs100"        : 2.1.2    , installed 2.1.2
    Adapter    "ical"         : 1.13.1   , installed 1.13.1
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iot"          : 1.11.9   , installed 1.11.9
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "logparser"    : 1.1.0    , installed 1.1.0
    Adapter    "lupusec"      : 1.3.6    , installed 1.3.6
    Adapter    "mclighting"   : 0.1.2    , installed 0.1.2
    Adapter    "mihome-vacuum": 3.8.6    , installed 3.4.2  [Updatable]
    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
    Adapter    "nuki"         : 1.6.0    , installed 1.6.0
    Adapter    "nuki-extended": 2.3.1    , installed 2.6.5
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "pvforecast"   : 2.3.0    , installed 2.3.0
    Adapter    "roomba"       : 1.1.4    , installed 1.1.4
    Adapter    "rssfeed"      : 2.6.1    , installed 2.6.1
    Adapter    "shelly"       : 6.0.0    , installed 6.0.0
    Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "spotify-premium": 1.2.1  , installed 1.2.1
    Adapter    "telegram"     : 1.14.1   , installed 1.14.1
    Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
    Adapter    "tuya"         : 3.8.1    , installed 3.6.15 [Updatable]
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "whatsapp-cmb" : 0.2.2    , installed 0.2.2
    Adapter    "worx"         : 2.0.3    , installed 1.7.0  [Updatable]
    pi@ioBroker-RasPi4:/opt/iobroker $ iobroker list instances
    + system.adapter.admin.0                  : admin                 : ioBroker-RasPi4                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alexa2.0                 : alexa2                : ioBroker-RasPi4                          -  enabled
      system.adapter.backitup.0               : backitup              : ioBroker-RasPi4                          -  enabled
      system.adapter.daswetter.0              : daswetter             : ioBroker-RasPi4                          -  enabled
      system.adapter.discovery.0              : discovery             : ioBroker-RasPi4                          -  enabled
      system.adapter.dwd.0                    : dwd                   : ioBroker-RasPi4                          -  enabled
      system.adapter.feiertage.0              : feiertage             : ioBroker-RasPi4                          -  enabled
      system.adapter.flot.0                   : flot                  : ioBroker-RasPi4                          - disabled
      system.adapter.history.0                : history               : ioBroker-RasPi4                          -  enabled
      system.adapter.hm-rega.0                : hm-rega               : ioBroker-RasPi4                          -  enabled
      system.adapter.hm-rpc.2                 : hm-rpc                : ioBroker-RasPi4                          -  enabled, port: 12001
      system.adapter.hm-rpc.3                 : hm-rpc                : ioBroker-RasPi4                          -  enabled, port: 12010
      system.adapter.hs100.0                  : hs100                 : ioBroker-RasPi4                          -  enabled
      system.adapter.ical.0                   : ical                  : ioBroker-RasPi4                          -  enabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker-RasPi4                          -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker-RasPi4                          -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker-RasPi4                          -  enabled
      system.adapter.info.0                   : info                  : ioBroker-RasPi4                          -  enabled
      system.adapter.iot.0                    : iot                   : ioBroker-RasPi4                          -  enabled
      system.adapter.javascript.0             : javascript            : ioBroker-RasPi4                          -  enabled
      system.adapter.logparser.0              : logparser             : ioBroker-RasPi4                          -  enabled
      system.adapter.lupusec.0                : lupusec               : ioBroker-RasPi4                          -  enabled
    + system.adapter.mclighting.0             : mclighting            : ioBroker-RasPi4                          - disabled, port: 81
      system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker-RasPi4                          -  enabled, port: 54321
      system.adapter.mobile.0                 : mobile                : ioBroker-RasPi4                          - disabled
      system.adapter.mqtt.0                   : mqtt                  : ioBroker-RasPi4                          -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.nuki-extended.0          : nuki-extended         : ioBroker-RasPi4                          -  enabled
      system.adapter.ping.0                   : ping                  : ioBroker-RasPi4                          -  enabled
      system.adapter.pollenflug.0             : pollenflug            : ioBroker-RasPi4                          -  enabled
      system.adapter.roomba.0                 : roomba                : ioBroker-RasPi4                          -  enabled
      system.adapter.rpi2.0                   : rpi2                  : ioBroker-RasPi4                          -  enabled
      system.adapter.rssfeed.0                : rssfeed               : ioBroker-RasPi4                          -  enabled
      system.adapter.shelly.0                 : shelly                : ioBroker-RasPi4                          -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.sonoff.0                 : sonoff                : ioBroker-RasPi4                          -  enabled, port: 1885, bind: 0.0.0.0
      system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker-RasPi4                          -  enabled
      system.adapter.tr-064.0                 : tr-064                : ioBroker-RasPi4                          -  enabled
      system.adapter.tuya.0                   : tuya                  : ioBroker-RasPi4                          - disabled
      system.adapter.upnp.0                   : upnp                  : ioBroker-RasPi4                          -  enabled
      system.adapter.vis-bars.0               : vis-bars              : ioBroker-RasPi4                          -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker-RasPi4                          - disabled
      system.adapter.vis-history.0            : vis-history           : ioBroker-RasPi4                          -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker-RasPi4                          -  enabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker-RasPi4                          -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker-RasPi4                          -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : ioBroker-RasPi4                          -  enabled
      system.adapter.vis-metro.0              : vis-metro             : ioBroker-RasPi4                          -  enabled
      system.adapter.vis-players.0            : vis-players           : ioBroker-RasPi4                          -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker-RasPi4                          -  enabled
      system.adapter.vis.0                    : vis                   : ioBroker-RasPi4                          -  enabled
      system.adapter.web.0                    : web                   : ioBroker-RasPi4                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.worx.0                   : worx                  : ioBroker-RasPi4                          -  enabled
    + instance is alive
    1. Hoffe dass ich das richtige kopiert habe.
      @ctnnemo
      CodierknechtC Offline
      Codierknecht
      @codierknecht sagte in Admin - Website nicht erreichbar:
      HmIP|ZigBee|Tasmota|Unifi
      Zabbix Certified Specialist
      C 1 Antwort Letzte Antwort
        ctnnemo
        @codierknecht
        sorry - neuer Versuch - 🤡
        code_textpi@ioBroker-RasPi4:/opt/iobroker $ iobroker update
        + instance is alive
        • C ctnnemo
          @codierknecht
          + instance is alive
          crunchipC Abwesend
          crunchipC Abwesend
          @ctnnemo da ging wohl was schief, admin Instanz aber kein Adapter
          • C Offline
            ctnnemo
            Wie kann ich das Problem lösen?
            Der Versuch eine 2te Admin - Instanz zu installieren schlägt fehl.
            Die Admin - Instand zu löschen geht nicht weil WEB-Instanz davon abhänig ist.
            • CodierknechtC Offline
              Codierknecht
              @ctnnemo sagte in Admin - Website nicht erreichbar:
              Na wenn kein Admin-Adapter vorhanden oder zumindest nicht sauber installiert ist, dürfte das auch schwierig werden.
              Mein Rat: Hab Geduld bis sich die Spezialisten melden.
              Wenn Du nicht bis dahin warten kannst/willst:
              Ich hoffe, ein
              iobroker stop
              iobroker fix
              iobroker restart
              kann ich an der Stelle empfehlen, ohne dass mir einer der Experten den Kopf dafür abreisst.
              • C ctnnemo
                crunchipC Abwesend
                crunchipC Abwesend
                @ctnnemo
                iob add admin --debug
                danach nochmal prüfen
                iob list adapters
                  @ctnnemo
                  iob list adapters
                  ctnnemo
                  @Codierknecht : Versucht habe ich es ... lief ohne Auffälligkeiten.
                  gebracht hat es aber leider nix.
                  @crunchip
                  .... leider zickt das Teil
                  pi@ioBroker-RasPi4:/opt/iobroker $ iob add admin
                  NPM version: 8.19.2
                  Installing iobroker.admin@6.2.23... (System call)
                  host.ioBroker-RasPi4 Cannot install iobroker.admin@6.2.23: 217
                  GlasfaserG crunchipC 2 Antworten Letzte Antwort
                  • C ctnnemo
                    @crunchip
                    NPM version: 8.19.2
                    GlasfaserG Offline
                    GlasfaserG Offline
                    217
                    Was zeigt
                    • C ctnnemo
                      @crunchip
                      NPM version: 8.19.2
                      crunchipC Abwesend
                      crunchipC Abwesend
                      @ctnnemo da fehlt der --debug am Ende, dann würden wir auch sehen warum
                      • C Offline
                        ctnnemo
                        pi@ioBroker-RasPi4:/opt/iobroker $ iob add admin --debug
                        NPM version: 8.19.2
                        npm ERR! code ENOTEMPTY
                        npm ERR! syscall rename
                        npm ERR! path /opt/iobroker/node_modules/es-abstract
                        npm ERR! dest /opt/iobroker/node_modules/.es-abstract-bryRKUKR
                        npm ERR! errno -39
                        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/es-abstract' -> '/opt/iobroker/node_modules/.es-abstract-bryRKUKR'
                        npm ERR!     /home/iobroker/.npm/_logs/2022-11-18T22_09_49_746Z-debug-0.log
                        oh man. ich glaube das Hauptproblem sitzt ca. 50 cm vor dem Monitor 🙄
                        mit den Tiefen des Systems habe ich mich nie beschäftigt.
                        • C ctnnemo
                          NPM version: 8.19.2
                          npm ERR! errno -39
                          GlasfaserG Offline
                          GlasfaserG Offline
                          Siehe hier .. wie man da vorgeht .
                          https://forum.iobroker.net/topic/57337/fehler-25-bei-adapter-install-update-mit-npm8
                          • GlasfaserG Glasfaser
                            ctnnemo
                            @glasfaser
                            @Codierknecht
                            @crunchip
                            @Thomas-Braun
                            ganz herzlichen Dank für eure Hilfe. Ich konnte die Admin-Instanz wieder installieren und darauf zugreifen! Ihr seid SPITZE!!!!!!!!
