  3. Entwicklung
  4. [Neuer Adapter] Reolink Kamera
reolinkneuer adaptertestenkamera
1.1k Beiträge 166 Kommentatoren 679.1k Aufrufe 146 Beobachtet
  • da_WoodyD da_Woody
    @andy-grundt hüstel... nach nem update über den link hats mächtig geraschelt. hab dann mal alle 3 instanzen, die grün waren gestoppt, log gelöscht, die 0 gestartet:
    reolink.0
    2022-10-28 13:54:54.672	error	DB closed
    reolink.0
    2022-10-28 13:54:54.671	error	Error: DB closed at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24) at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25) at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:657:40) at ReoLinkCam.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5880:35)
    reolink.0
    2022-10-28 13:54:54.670	error	unhandled promise rejection: DB closed
    reolink.0
    2022-10-28 13:54:54.670	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    reolink.0
    2022-10-28 13:54:54.670	warn	get state error: Connection is closed.
    reolink.0
    2022-10-28 13:54:54.553	warn	get state error: DB closed
    reolink.0
    2022-10-28 13:54:53.430	error	Value not supported!
    reolink.0
    2022-10-28 13:54:53.217	error	Value not supported!
    reolink.0
    2022-10-28 13:54:52.936	error	Value not supported!
    reolink.0
    2022-10-28 13:54:52.708	error	Value not supported!
    reolink.0
    2022-10-28 13:54:52.475	error	Value not supported!
    reolink.0
    2022-10-28 13:54:52.346	error	Value not supported!
    reolink.0
    2022-10-28 13:54:52.220	error	Value not supported!
    reolink.0
    2022-10-28 13:54:52.094	error	Value not supported!
    reolink.0
    2022-10-28 13:54:51.982	error	Value not supported!
    reolink.0
    2022-10-28 13:54:51.836	error	Value not supported!
    reolink.0
    2022-10-28 13:54:51.700	error	Value not supported!
    reolink.0
    2022-10-28 13:54:51.569	error	Value not supported!
    reolink.0
    2022-10-28 13:54:51.443	error	Value not supported!
    reolink.0
    2022-10-28 13:54:51.293	error	Value not supported!
    reolink.0
    2022-10-28 13:54:51.174	error	Value not supported!
    reolink.0
    2022-10-28 13:54:50.991	error	Value not supported!
    reolink.0
    2022-10-28 13:54:50.858	error	Value not supported!
    reolink.0
    2022-10-28 13:54:50.750	error	Value not supported!
    reolink.0
    2022-10-28 13:54:50.620	error	Value not supported!
    reolink.0
    2022-10-28 13:54:50.491	error	Value not supported!
    reolink.0
    2022-10-28 13:54:50.336	error	Value not supported!
    reolink.0
    2022-10-28 13:54:50.208	error	Value not supported!
    reolink.0
    2022-10-28 13:54:50.090	error	Value not supported!
    reolink.0
    2022-10-28 13:54:49.984	error	Value not supported!
    reolink.0
    2022-10-28 13:54:49.847	error	Value not supported!
    reolink.0
    2022-10-28 13:54:49.713	error	Value not supported!
    reolink.0
    2022-10-28 13:54:49.578	error	Value not supported!
    reolink.0
    2022-10-28 13:54:49.442	error	Value not supported!
    reolink.0
    2022-10-28 13:54:49.320	error	Value not supported!
    reolink.0
    2022-10-28 13:54:49.159	error	Value not supported!
    reolink.0
    2022-10-28 13:54:49.028	error	Value not supported!
    reolink.0
    2022-10-28 13:54:48.911	error	Value not supported!
    reolink.0
    2022-10-28 13:54:48.785	error	Value not supported!
    reolink.0
    2022-10-28 13:54:48.645	error	Value not supported!
    da_WoodyD Offline
    da_WoodyD Offline
    #190
    @da_woody hab nochmal den adapter instance0 gestartet mit debug
    host.ioBroker
    2022-10-28 14:41:06.173	info	instance system.adapter.reolink.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.ioBroker
    2022-10-28 14:41:05.072	info	stopInstance system.adapter.reolink.0 send kill signal
    reolink.0
    2022-10-28 14:41:05.029	info	State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "string"
    reolink.0
    2022-10-28 14:41:04.737	debug	Error or not supported getMailNotification
    reolink.0
    2022-10-28 14:41:04.614	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    reolink.0
    2022-10-28 14:41:04.614	info	terminating
    reolink.0
    2022-10-28 14:41:04.614	debug	refreshStateTimeout: UNLOAD
    reolink.0
    2022-10-28 14:41:04.613	info	Got terminate signal TERMINATE_YOURSELF
    host.ioBroker
    2022-10-28 14:41:03.755	info	stopInstance system.adapter.reolink.0 (force=false, process=true)
    host.ioBroker
    2022-10-28 14:41:03.754	info	"system.adapter.reolink.0" disabled
    reolink.0
    2022-10-28 14:41:03.719	debug	mailValue 200: [{"cmd":"Unknown","code":1,"error":{"detail":"not support","rspCode":-9}}]
    reolink.0
    2022-10-28 14:41:03.647	error	Value not supported!
    reolink.0
    2022-10-28 14:41:03.647	info	Changed state: EmailNotification
    reolink.0
    2022-10-28 14:41:03.646	debug	state reolink.0.settings.EmailNotification changed: Error or not supported (ack = true)
    reolink.0
    2022-10-28 14:41:03.596	info	State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "string"
    reolink.0
    2022-10-28 14:41:03.560	debug	Error or not supported getMailNotification
    reolink.0
    2022-10-28 14:41:03.520	debug	mailValue 200: [{"cmd":"Unknown","code":1,"error":{"detail":"not support","rspCode":-9}}]
    reolink.0
    2022-10-28 14:41:03.428	error	Value not supported!
    • WszeneW Offline
      WszeneW Offline
      Wszene
      schrieb am zuletzt editiert von Wszene
      #191
      @Andy-Grundt
      Hallo Zusammen,
      Ich habe 2x die Reolink RLC-510A
      Ich bekomme auch die Datenpunkte
      Habe da aber mal eine Frage zur Bewegungserkennung
      Sollte sich der DP "reolink.0.sensor.motion" bei Erkennung auf "1" ändern?
      Wenn Ja dann funktioniert das nicht
      Ich habe mal zum Testen in der App die Push-Mitteilung angeschalten Diese springt an
      Danke im Voraus
      Marcel
      Meine Hard- & Software:
      • CC2652P Zigbee Stick
      • Lichtschalter mit Tasmota
      • IKEA TRÅDFRI Glühbirnen
      • Aqara Sensoren
        msauer
        #192
        Hallo Zusammen,
        ich würde gerne in Blockly mit einem Trigger des Objekts reolink.0.sensor.motion ein Bild per pushover verschicken. Nun ist in dem Beispiel zwar die Javascript Prozedur vorgeschlagen, wie aber setzte ich das in Blockly um. Hat das schon jemand gemacht und mag es mit uns teilen?
        Mark
        Proxmox 3 Node HA-Cluster Mini-PC N150 mit 32 GB RAM und 3x1TB shared SSDs via Linstor. VM- iobroker ,OpenCCU / LXC - Adguard, Traccar, iSpy, Fileserver (emby, MiniDLNA)...etc.
          Mutze
          #193
          Guten Abend,
          vorweg, es ist toll was diese Community auf die Beine stellt. Das ist ein Grund warum ich heute meine Reolink Kameras bekommen habe.
          Dank dieses neuen Adapters habe ich auch bereits die erste Kamera in ioBroker einbinden können. Bei der Kamera handelt es sich um eine Reolink TrackMix PoE.
          Soweit ich das bisher beurteilen kann, funktioniert die Einbindung. Die Kamera einschl. der hier bereits diskutierten Parameter werden erkannt.
          Ein kleiner Hinweis.
          Nach dem Anlegen der ersten Instanz und das Einbinden der Kamera ist der Start des Adapters gescheitert. Der Adpater blieb auf der gelben Statusmeldung hängen und im Logfile stand etwas wie "type undefined".
          Dann erinnerte ich mich, dass ich Sonderzeichen für das Passwort der Kamera verwendet habe. Mit diesen Sonderzeichen hatte ich bereits bei einem anderen Adapter mal Probleme. Nach dem Ändern des Passwortes ohne die Sonderzeichen konnte die Verbindung problemlos aufgebaut werde.
          Ich weiß nicht ob die Entwickler mit dem Hinweis etwas anfangen können und ggf. in einem nächsten Release eine Änderung berücksichtigen.
          Ich werde in den kommenden Tagen gerne weiter testen und berichten.
          Folgende 2 weitere Kameratypen habe ich heute auch noch bekommen und werde diese auch testen.
          Reolink RCL-823A
          Reolink Duo 2 PoE
          Werden im Laufe der Woche auch eingebunden und ich berichte.
          Nochmals vielen Dank an die Entwickler und die Community.
          Gruss Mutze
          • W Wolfi
            @oelison
            ok ptzPreset funktioniert auch bei mir!
            (E1 Outdoor)
            Gruss
            meerkat
            #194
            Hi @wolfi
            Ich habe auch eine E1 Outdoor gekauft und wollte nun auch den preset nutzen. Bei mir steht nur Null im datenpunkt und wenn ich bspw. 1 eintrage, dann passiert nichts.
            Presets sind natürlich in der Kamera angelegt und über die App bzw. Website kann ich diese auch ansteuern.
            Hast du nich spezielle Einstellungen gemacht?
            W 1 Antwort Letzte Antwort
            • M meerkat
              Hi @wolfi
              W Offline
              W Offline
              Wolfi
              schrieb am zuletzt editiert von Wolfi
              #195
              @meerkat
              Stimmt geht bei mir via Adapter auch nicht mehr.
              Was ist eigentlich die aktuelle Version? Suche den Link zur Installation?
              geht zur not auch so via blockly
              https://forum.iobroker.net/post/853217
              • W Wolfi
                @meerkat
                meerkat
                #196
                Hi @wolfi,
                Teste ich nachher mal. Hast du den im Post genannten link auch noch? Würde mal schauen, was ich dann noch einbaue
                Meerkat
                • M meerkat
                  Hi @wolfi,
                  Meerkat
                  W Offline
                  W Offline
                  Wolfi
                  #197
                  @meerkat
                  Finde gerade den link nicht mehr suche mal nach " Reolink API CGI commands
                  OK habe jetzt die Version 0.1.1 installiert bekommen.
                  PLZPreset geht aber nicht!
                  Kann das sonst noch jemand bestätigen? (E1 Outdoor)
                  R 1 Antwort Letzte Antwort
                  • W Wolfi
                    @meerkat
                    RoaBo
                    #198
                    @wolfi Nabend. Ich habe eine TrackMix Wifi und auch da leider nicht. Auch klappt es nicht mit dem curl Befehl. In Blocky reagiert nichts und per ssh gibt er "please login first" aus.
                    • R RoaBo
                      meerkat
                      #199
                      Hi @roabo @Wolfi
                      Habe gestern Abend auch noch lange probiert. Beim curl musste ich in der Adresse den Bereich cgi-bin weglassen und alles mit Token senden. Dafür gibt es ne eigenen aufruf. Teste heute abend noch weiter und gebe dann mal Rückmeldung
                      • M meerkat
                        Hi @roabo @Wolfi
                        W Offline
                        W Offline
                        Wolfi
                        #200
                        @meerkat
                        Hier mein blockly zum Importieren. (IP mit port und PW anpassen.)
                        Zeitgesteuert für Pos 4 und 5
                        Gruss
                        Reolink_PLZ.txt
                        • W Wolfi
                          @meerkat
                          Gruss
                          Reolink_PLZ.txt
                          RoaBo
                          #201
                          @wolfi Super! Das funktioniert. Vielen Dank!
                          • W Offline
                            W Offline
                            Wolfi
                            #202
                            Kann bitte jemand sagen ob das PLZPreset mit dem Aktuellen
                            Version des Adapters funktionieren sollte??
                            Jemand der eine E1 Outdoor hatte.
                            Ich meinte in einer früheren Version hat es mal funktioniert.
                            Gruss
                            oelisonO 1 Antwort Letzte Antwort
                            • W Wolfi
                              Gruss
                              oelisonO Offline
                              oelisonO Offline
                              oelison
                              #203
                              @wolfi Nein, geht nicht. Hatte auf meinem produktiv System noch eine alte (0.0.3), bei der hat das funktioniert. Dann update gemacht auf das aktuelle repository (0.1.1) und es geht nicht mehr.
                              I like Rust. ioBroker-Adapter: matrix, mediola-gateway, support for reolink
                              • oelisonO oelison
                                W Offline
                                W Offline
                                Wolfi
                                #204
                                @oelison
                                Danke für die Klärung
                                Gruss
                                • R Offline
                                  romestylez
                                  schrieb am zuletzt editiert von romestylez
                                  #205
                                  Danke für den Adapter habe diesen installiert. Nutze zwei 820A.
                                  Ist es möglich das Bild/Stream nur anzuzeigen wenn die Motion Detection etwas erkennt ? Falls ja wie ? Ich speichere bei Motion Detection das Video auf mein NAS. Wäre halt schön wenn der Livestream im ioBroker startet wenn Bewegung erkannt wird.
                                  • R romestylez
                                    BananaJoeB Offline
                                    BananaJoeB Offline
                                    BananaJoe
                                    #206
                                    @romestylez das ist jetzt nicht direkt das was du lesen willst, aber ich hatte schon vor einiger Zeit das Problem das ich einen Stream nur laufen lassen wollte wenn die View überhaupt sichtbar ist.
                                    Mit der gleichen Methode könnte man natürlich auch bei einer statischen View arbeiten:
                                    https://forum.iobroker.net/topic/36345/gelöst-vis-video-stream-nur-starten-wenn-view-sichtbar-ist?_=1668785812268
                                    Ich nutze inzwischen aber nur noch Standbilder die alle 60 Sekunden aktualisiert werden.
                                    Passiert etwas (z.B. Klingel) setze ich das hoch auf alle 1 bis 2 Sekunden, nach 60 Sekunden wieder auf den normalen Intervall
                                    Das nutze ich das Bild Widget und habe bei Refresh ein Datenpunkt-Binding eingegeben
                                    • R Offline
                                      romestylez
                                      #207
                                      @bananajoe said in [Neuer Adapter] Reolink Kamera:
                                      Danke für den Hinweis es gibt da leider ein paar kleine Probleme. Die Reolink kann per http nur ein Bild liefern keinen Stream (zumindest meine RCL-820).
                                      Wenn man das Camera Widget nimmt um das Bild anzuzeigen dann wird nicht geupdated da etwas an die URL hinten angehangen wird und der Pfad dann nicht gefunden werden kann auf der Kamera das war irgendwas mit "refts" oder so am Ende die Option nix an die URL anzuhängen gibts leider bei diesem Camera Snapshot Widget nicht.
                                      Ich habe nun ein iFrame was sich alle 2 Sekunden updated gemacht mit dem Link zum Bild. Nun müsste ich damit halt prüfen ob es vorne Bewegung gibt. Leider wird aber das Objekt "reolink.0.sensor.motion" nicht gefüllt wenn Bewegung erkannt wird und die App mir diese meldet. Wahrscheinlich weil ich auf ein NAS aufzeichne per FTP und nicht auf eine SD-Karte.
                                      Ich werde mir deine Methode aber auf jeden Fall merken kann man sicher für andere Sachen übernehmen ;)
                                        ahennies
                                        #208
                                        Moin, ich habe eine RCL-820A, die leider nicht mit dem Adapter sprechen möchte. Was funktioniert ist das Einbinden der Kamera über motioneye rmtp, aber mein RPi 3 kann das nicht wirklich leisten. Da bekomme ich nur ein graues Fenster. Alles andere was hier bereits beschrieben wurde tut leider nicht.
                                        Also wenn jemand eine RCL-820A hat und vielleicht etwas rausgefunden hat, dann würde ich mich über den einen oder anderen Tipp freuen.
                                        Mein Ziel ist es, die Kamera, wie auch immer, in den iobroker zu bringen.
                                        Da ich aber noch zwei Kameras benötige, wäre es natürlich auch interessant zu erfahren, welche Kameras mit der neuesten Version funktionieren.
                                        Achim
                                        R H 2 Antworten Letzte Antwort
                                        • A ahennies
                                          Achim
                                          romestylez
                                          #209
                                          @ahennies said in [Neuer Adapter] Reolink Kamera:
                                          Achim
                                          Ich habe auch eine RCL-820A. Ich habe den Adapter installiert und dann die Kamera hinzugefügt. Aber mir bringt der Adapter leider nichts weil die Motion Detection nicht funktioniert. Ich kann das Bild also nicht abgreifen.
                                          Ich habe jetzt folgendes Widget "gebaut":
                                          [{"tpl":"tplMfdCamSnapshot","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","asButton":false,"interval":"2000","dialog_width":"896","dialog_height":"512","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"url":"http://IPDERKAMERA/cgi-bin/api.cgi?cmd=Snap&channel=0&user=USERNAME&password=USER&width=640&height=480","modal":false,"autoclose":"20000","overflowX":"initial","overflowY":"initial","noHeader":true,"title":"Kamera vorne","iconColor":"#fff","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false},"style":{"left":"1198px","top":"17px","width":"","z-index":"1"},"widgetSet":"jqui-mfd"}]
                                          Damit bekomme ich das Bild der Kamera welches sich alle 2 Sekunden aktualisiert. Nach 20 Sekunden schließt sich das Pop-Up mit dem Kamera Bild automatisch.
                                          Wie gesagt es ist sehr schade das der Adapter nicht funktioniert. Ich hätte ihn gerne genutzt.
                                          P A 2 Antworten Letzte Antwort
