  4. JavaScript
  5. Datenpunkt aus xml
Datenpunkt aus xml
39 Beiträge 4 Kommentatoren 1.8k Aufrufe 2 Beobachtet
    australien
    schrieb am zuletzt editiert von australien
    jetz kommt Leben ins Geschehen
    20:19:52.202	info	javascript.0 (6486) Stop script script.js.common.PV
    20:38:16.280	info	javascript.0 (6486) Stop script script.js.common.PV
    20:38:17.819	info	javascript.0 (6486) Start javascript script.js.common.PV
    20:38:17.856	info	javascript.0 (6486) script.js.common.PV: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
    20:39:07.644	info	javascript.0 (6486) script.js.common.PV: {'root':{'Device':[{'$':{'Name':'SF-WR-5503','Type':'Inverter','Serial':'752794AB005565810009','BusAddress':'1','NetBiosName':'INV005565810009','IpAddress':'10.68.0.85','DateTime':'2022-11-14T20:38:18'},'Measurements':[{'Measurement':[{'$':{'Value':'233.046','Unit':'V','Type':'AC_Voltage1'}},{'$':{'Value':'235.306','Unit':'V','Type':'AC_Voltage2'}},{'$':{'Value':'234.911','Unit':'V','Type':'AC_Voltage3'}},{'$':{'Value':'50.002','Unit':'Hz','Type':'AC_Frequency1'}},{'$':{'Value':'50.006','Unit':'Hz','Type':'AC_Frequency2'}},{'$':{'Value':'50.003','Unit':'Hz','Type':'AC_Frequency3'}},{'$':{'Value':'0.000','Unit':'V','Type':'DC_Voltage'}},{'$':{'Value':'21.260','Unit':'°C','Type':'Temp'}}]}]}]}}
    20:40:00.071	info	javascript.0 (6486) script.js.common.PV: {'root':{'Device':[{'$':{'Name':'SF-WR-5503','Type':'Inverter','Serial':'752794AB005565810009','BusAddress':'1','NetBiosName':'INV005565810009','IpAddress':'10.68.0.85','DateTime':'2022-11-14T20:39:10'},'Measurements':[{'Measurement':[{'$':{'Value':'233.334','Unit':'V','Type':'AC_Voltage1'}},{'$':{'Value':'235.452','Unit':'V','Type':'AC_Voltage2'}},{'$':{'Value':'235.217','Unit':'V','Type':'AC_Voltage3'}},{'$':{'Value':'50.015','Unit':'Hz','Type':'AC_Frequency1'}},{'$':{'Value':'50.024','Unit':'Hz','Type':'AC_Frequency2'}},{'$':{'Value':'50.008','Unit':'Hz','Type':'AC_Frequency3'}},{'$':{'Value':'0.000','Unit':'V','Type':'DC_Voltage'}},{'$':{'Value':'21.250','Unit':'°C','Type':'Temp'}}]}]}]}}
    nur wir teile ich die Daten nun Datenpunkten zu?
    • A australien
      @australien sagte in Datenpunkt aus xml:
      Ersetze log(obj) durch
      const messung = obj.root.Device[0].Measurements[0].Measurement;
      for(let obj of messung) {
          log(obj.$.Type + ': ' + parseFloat(obj.$.Value) + ' ' + obj.$.Unit);
          // setState('0_userdata.0.SolarFrontier.' + obj.$.Type, parseFloat(obj.$.Value), true);
      Erstelle vorher die 8 Datenpunkte vom Typ "number" unter "0_userdata.0".
      Log:
      20:59:41.099	info	javascript.1 (2579) script.js.common.Neuer_Test: AC_Voltage1: 233.046 V
      20:59:41.100	info	javascript.1 (2579) script.js.common.Neuer_Test: AC_Voltage2: 235.306 V
      20:59:41.100	info	javascript.1 (2579) script.js.common.Neuer_Test: AC_Voltage3: 234.911 V
      20:59:41.100	info	javascript.1 (2579) script.js.common.Neuer_Test: AC_Frequency1: 50.002 Hz
      20:59:41.100	info	javascript.1 (2579) script.js.common.Neuer_Test: AC_Frequency2: 50.006 Hz
      20:59:41.100	info	javascript.1 (2579) script.js.common.Neuer_Test: AC_Frequency3: 50.003 Hz
      20:59:41.100	info	javascript.1 (2579) script.js.common.Neuer_Test: DC_Voltage: 0 V
      20:59:41.100	info	javascript.1 (2579) script.js.common.Neuer_Test: Temp: 21.26 °C
        Log:
        HomoranH Offline
        HomoranH Offline
        @paul53 wieso sind im obj nur 8 Werte?
        die xml enthält 17
          die xml enthält 17
          @homoran sagte: die xml enthält 17
          Dann müssen die übrigen wohl in einem anderen Array-Element enthalten sein. Ich schau mal.
            HomoranH Offline
            HomoranH Offline
            alle in <Measurements>
            <root>
            <Device Name="SF-WR-5503" Type="Inverter" Serial="752794Axxxxxxx" BusAddress="1" NetBiosName="INV005565810009" IpAddress="10.68.0.85" DateTime="2022-11-14T14:34:49">
            <Measurements>
            <Measurement Value="232.511" Unit="V" Type="AC_Voltage1"/>
            <Measurement Value="234.392" Unit="V" Type="AC_Voltage2"/>
            <Measurement Value="234.739" Unit="V" Type="AC_Voltage3"/>
            <Measurement Value="0.188" Unit="A" Type="AC_Current1"/>
            <Measurement Value="0.186" Unit="A" Type="AC_Current2"/>
            <Measurement Value="0.182" Unit="A" Type="AC_Current3"/>
            <Measurement Value="83.355" Unit="W" Type="AC_Power"/>
            <Measurement Value="30.510" Unit="W" Type="AC_Power1"/>
            <Measurement Value="28.707" Unit="W" Type="AC_Power2"/>
            <Measurement Value="27.966" Unit="W" Type="AC_Power3"/>
            <Measurement Value="49.997" Unit="Hz" Type="AC_Frequency1"/>
            <Measurement Value="50.005" Unit="Hz" Type="AC_Frequency2"/>
            <Measurement Value="50.001" Unit="Hz" Type="AC_Frequency3"/>
            <Measurement Value="435.600" Unit="V" Type="DC_Voltage"/>
            <Measurement Value="0.195" Unit="A" Type="DC_Current"/>
            <Measurement Value="84.942" Unit="W" Type="DC_Power"/>
            <Measurement Value="39.610" Unit="°C" Type="Temp"/>
            </Measurements>
            </Device>
            </root>
              <root>
              <Measurements>
              </Measurements>
              </Device>
              </root>
              Das Ergebnis (Log) von xml2js lieferte nur die 8 Werte.
              A HomoranH 2 Antworten Letzte Antwort
                australien
                super, danke euch beiden!
                  HomoranH Offline
                  HomoranH Offline
                  @paul53 das ist ja das Problem
                  ich habe so etwas auch bei meinem Kostal, allerdings muss ich da in derAPI due gewünschten Parameter abfragen. das ist anscheinend auf eine maximale Anzahl je Abfrage limitiert.
                  Vielleicht ist die Zeichenanzahl begrenzt
                  @australien wie bist du denn an das vollständige xml Dokument gekommen?
                  • A australien
                    @australien
                    Kann es sein, dass nachts keine Stromstärke- und Leistungswerte geliefert werden?
                      @australien
                      HomoranH Offline
                      HomoranH Offline
                      @paul53 guter Ansatz!
                        australien
                        mit Nachts ist mir klar, ich werd mir das morgen unter Tags noch anschauen, falls kein Nebel ist ;)
                        Danke Euch beiden nochmals!!
                          @australien
                          HomoranH Offline
                          HomoranH Offline
                          @australien
                          was ist denn die DC Voltage, wenn nicht die Panel Spannung?
                          und
                          @homoran sagte in Datenpunkt aus xml:
                            australien
                            Guten Morgen,
                            Nebel, aber liefert etwas, somit sind wieder alle 17 Datenpunkte vorhanden.
                            <Measurements>
                            <Measurement Value="234.225" Unit="V" Type="AC_Voltage1"/>
                            <Measurement Value="236.033" Unit="V" Type="AC_Voltage2"/>
                            <Measurement Value="235.065" Unit="V" Type="AC_Voltage3"/>
                            <Measurement Value="0.144" Unit="A" Type="AC_Current1"/>
                            <Measurement Value="0.155" Unit="A" Type="AC_Current2"/>
                            <Measurement Value="0.147" Unit="A" Type="AC_Current3"/>
                            <Measurement Value="6.654" Unit="W" Type="AC_Power"/>
                            <Measurement Value="6.163" Unit="W" Type="AC_Power1"/>
                            <Measurement Value="2.353" Unit="W" Type="AC_Power2"/>
                            <Measurement Value="2.135" Unit="W" Type="AC_Power3"/>
                            <Measurement Value="49.951" Unit="Hz" Type="AC_Frequency1"/>
                            <Measurement Value="49.957" Unit="Hz" Type="AC_Frequency2"/>
                            <Measurement Value="49.958" Unit="Hz" Type="AC_Frequency3"/>
                            <Measurement Value="382.300" Unit="V" Type="DC_Voltage"/>
                            <Measurement Value="0.017" Unit="A" Type="DC_Current"/>
                            <Measurement Value="6.499" Unit="W" Type="DC_Power"/>
                            <Measurement Value="36.550" Unit="°C" Type="Temp"/>
                            </Measurements>
                            @Homoran hatte ich vor 6 Jahren bei der Installation der Anlage erfragt. Es waren sogar 3 xml Seiten, nur die anderen beiden waren nicht brauchbar, weiß die auch nicht mehr.
                            • A australien
                              Guten Morgen,
                              <Measurements>
                              </Measurements>
                              @australien sagte: alle 17 Datenpunkte vorhanden.
                              Dann erstelle die restlichen Datenpunkte und erweitere um eine Abfrage.
                              if(messung.length == 17) {
                                australien
                                Datenpunkte hab ich bereits erstellt und werden auch geschrieben - mit dem alten script.
                                Worin besteht der unterschied?
                                • A australien
                                  @australien sagte: Worin besteht der unterschied?
                                  Dass mit der zusätzlichen Abfrage nachts nichts geschrieben wird.
                                    australien
                                    Nachts sind die Werte der Leistung aber sowieso 0 und somit ist es doch auch egal.
                                    • A australien
                                      HomoranH Offline
                                      HomoranH Offline
                                      eben nicht!
                                      Nachts g7bt das xml gar nichts zum auswerten zurück
                                      • A australien
                                        @australien sagte: ist es doch auch egal.
                                        Ja, ist es, wenn die Werte nicht historisiert werden.
                                          australien
                                          Ok, das passiert ja noch nicht, will aber natürlich in naher Zukunft die Daten speichern.
                                          Sollte also die Abrage auf das ganze xml ausgeweitet werden, auch wenn weniger Daten vorhanden sind.
                                          Die letzten gültigen Datenpunkte der Leistung sind alle mit dem Wert 0 befüllt, was ja auch passen würde.
                                          Die ganze Abrage macht ja sowieso nur Sinn, solange Sonne scheint, also eigentlich ein CRON mit Astronomischer Tag würde das ganze einschränken.
                                          so in etwa
                                          const parser = require('xml2js').parseString;
                                          const url = 'http://10.68.0.85/measurements.xml';
                                          schedule('{"time":{"start":"sunrise","end":"sunset","mode":"minutes","interval":1},"period":{"days":1}}', function() {
                                              request(url, function(error, response, result) {
                                                  if(!error) parser(result, function(err, obj) {
                                                      if(!err) {
                                                          //log(obj); // Ausgabe posten!
                                                              //log(obj.$.Type + ': ' + parseFloat(obj.$.Value) + ' ' + obj.$.Unit);
