  3. Off Topic
  4. Rundumglücklichsupport für @thorkillar ;-)
    5.5k
133 Beiträge 11 Kommentatoren 18.6k Aufrufe 2 Beobachtet
  • T thorkillar
    Ich habe jetzt kontrolliert. Kein Skript läuft. Dann den Docker neu gestartet.
    Und das Log-File wird nicht befüllt. Es wird erstellt, aber es ist leer.
    v.0.0.7
    *** BASE SYSTEM ***
    Architecture:   x86_64
    Docker:         v7.1.1
    Virtualization: Unknown (buanet/Synology?)
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     15:57:21 up 18 days, 23:05,  0 users,  load average: 4.40, 4.64, 4.94
    CPU threads: 4
    *** Time and Time Zones ***
    Mon Nov 14 14:57:21 UTC 2022
    Mon Nov 14 15:57:21 CET 2022
    CET +0100
    Etc/UTC
    *** User and Groups ***
    root
    /root
    root
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:             15G        5.7G        276M        514M         10G        9.5G
    Swap:            11G        977M         10G
    Total:           27G        6.6G         10G
            15966 M total memory
             5654 M used memory
             7013 M active memory
             6681 M inactive memory
              276 M free memory
               47 M buffer memory
             9987 M swap cache
            11627 M total swap
              977 M used swap
            10650 M free swap
    *** FILESYSTEM ***
    Filesystem             Type   Size  Used Avail Use% Mounted on
    /dev/mapper/cachedev_0 btrfs   28T   20T  8.4T  70% /
    tmpfs                  tmpfs   64M     0   64M   0% /dev
    tmpfs                  tmpfs  7.8G     0  7.8G   0% /sys/fs/cgroup
    shm                    tmpfs   64M     0   64M   0% /dev/shm
    /dev/mapper/cachedev_0 btrfs   28T   20T  8.4T  70% /opt/iobroker
    /dev/mapper/cachedev_0 btrfs   28T   20T  8.4T  70% /etc/hosts
    tmpfs                  tmpfs  7.8G     0  7.8G   0% /proc/acpi
    tmpfs                  tmpfs  7.8G     0  7.8G   0% /proc/scsi
    tmpfs                  tmpfs  7.8G     0  7.8G   0% /sys/firmware
    TARGET             SOURCE
    /                  /dev/mapper/cachedev_0[/@syno/@docker/btrfs/subvolumes/f52650
    |-/opt/iobroker    /dev/mapper/cachedev_0[/@syno/docker/iobroker-live-20221109]
    |-/etc/resolv.conf /dev/mapper/cachedev_0[/@syno/@docker/containers/f5b4f4149453
    |-/etc/hostname    /dev/mapper/cachedev_0[/@syno/@docker/containers/f5b4f4149453
    `-/etc/hosts       /dev/mapper/cachedev_0[/@syno/@docker/containers/f5b4f4149453
    /var:
    sudo: unable to resolve host buanet-iobroker1: Name or service not known
    32M     /var/
    30M     /var/lib
    18M     /var/lib/apt/lists
    18M     /var/lib/apt
    13M     /var/lib/dpkg
    /opt/iobroker/backups:
    2.3G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.5G    /opt/iobroker/iobroker-data/
    413M    /opt/iobroker/iobroker-data/backup-objects
    307M    /opt/iobroker/iobroker-data/files
    237M    /opt/iobroker/iobroker-data/history
    77M     /opt/iobroker/iobroker-data/files/vis.0
    348M    /opt/iobroker/iobroker-data/states.jsonl
    63M     /opt/iobroker/iobroker-data/objects.json.migrated
    63M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    58M     /opt/iobroker/iobroker-data/objects.jsonl
    21M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/2.00a59c14.chu
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.18.1
    /usr/bin/node           v16.18.1
    /usr/bin/npm            8.19.2
    nodejs:
      Installed: 16.18.1-deb-1nodesource1
      Candidate: 16.18.1-deb-1nodesource1
      Version table:
     *** 16.18.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
         12.22.12~dfsg-1~deb11u1 500
            500 http://deb.debian.org/debian-security bullseye-security/main amd64 P
         12.22.5~dfsg-2~11u1 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
    Calling 'npm doctor' for you. Please be patient!
    Check                               Value   Recommendation/Notes
    npm ping                            ok
    npm -v                              not ok  Use npm v9.1.1
    node -v                             not ok  Use node v18.12.1 (current: v16.18.1
    npm config get registry             ok      using default registry (https://regi
    which git                           ok      /usr/bin/git
    Perms check on cached files         ok
    Perms check on local node_modules   ok
    Perms check on global node_modules  ok
    Perms check on local bin folder     ok
    Perms check on global bin folder    ok
    Verify cache contents               ok      verified 3184 tarballs
    npm ERR! Some problems found. See above for recommendations.
    npm ERR!     /opt/iobroker/.npm/_logs/2022-11-14T14_57_29_637Z-debug-0.log
    The recommended versions for ioBroker are nodeJS v16 / npm v8
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.23
    admin:          6.2.23
    Adapters from github:   0
    + system.adapter.admin.0                  : admin                 : buanet-iobro
    + system.adapter.hm-rpc.0                 : hm-rpc                : buanet-iobro
    + system.adapter.hm-rpc.1                 : hm-rpc                : buanet-iobro
    + system.adapter.hm-rpc.2                 : hm-rpc                : buanet-iobro
    + system.adapter.hue.0                    : hue                   : buanet-iobro
    + system.adapter.hue.1                    : hue                   : buanet-iobro
    + system.adapter.telegram.0               : telegram              : buanet-iobro
    + system.adapter.web.0                    : web                   : buanet-iobro
    ioBroker-Repositories
    Active repo(s): stable
    ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.2.23   , installed 6.2.23
    Adapter    "alexa2"       : 3.21.0   , installed 3.21.0
    Adapter    "apple-find-me": 0.0.14   , installed 0.0.14
    Adapter    "backitup"     : 2.5.4    , installed 2.4.12 [Updatable]
    Adapter    "birthdays"    : 2.1.0    , installed 2.1.0
    Adapter    "bring"        : 1.8.1    , installed 1.8.1
    Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
    Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
    Adapter    "daswetter"    : 3.1.3    , installed 3.1.3
    Adapter    "devices"      : 1.0.12   , installed 1.0.12
    Adapter    "discovery"    : 3.0.5    , installed 3.0.5
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "email"        : 1.1.3    , installed 1.1.3
    Adapter    "emby"         : 1.0.2    , installed 1.0.2
    Adapter    "fb-checkpresence": 1.1.19, installed 1.1.19
    Adapter    "history"      : 2.2.0    , installed 2.2.0
    Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
    Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
    Adapter    "hue"          : 3.7.1    , installed 3.7.1
    Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
    Adapter    "ical"         : 1.13.1   , installed 1.13.1
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iot"          : 1.11.9   , installed 1.11.9
    Adapter    "iqontrol"     : 2.0.0    , installed 2.0.0
    Adapter    "javascript"   : 6.0.3    , installed 6.0.3
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "nuki"         : 1.6.0    , installed 1.6.0
    Adapter    "nuki-extended": 2.3.1    , installed 2.3.1
    Adapter    "odl"          : 2.0.5    , installed 2.0.5
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "pushover"     : 3.0.3    , installed 3.0.3
    Adapter    "roomba"       : 1.1.4    , installed 1.1.4
    Adapter    "rssfeed"      : 2.6.1    , installed 2.6.1
    Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
    Adapter    "synology"     : 2.1.9    , installed 2.1.9
    Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
    Adapter    "telegram"     : 1.14.1   , installed 1.14.1
    Adapter    "text2command" : 2.2.2    , installed 2.2.2
    Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
    Adapter    "trashschedule": 2.0.3    , installed 2.0.3
    Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "vis-icontwo"  : 0.89.0   , installed 0.89.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "vis-lcars"    : 1.0.4    , installed 1.0.4
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
    Objects and States
    Objects:        38385
    States:         54218
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 https://deb.nodesource.com/node_16.x bullseye InRelease
    Hit:3 http://deb.debian.org/debian-security bullseye-security InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Reading package lists... Done
    Pending Updates: 2
    *** Listening Ports ***
    Proto Recv-Q Send-Q Local Address           Foreign Address         State
    tcp        0      0 0.0.0.0:6011            0.0.0.0:*               LISTEN
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN
    tcp        0      0 0.0.0.0:22333           0.0.0.0:*               LISTEN
    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN
    tcp        0      0 127.0.0.1:512           0.0.0.0:*               LISTEN
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN
    tcp        0      0 127.0.0.1:38008         0.0.0.0:*               LISTEN
    tcp        0      0 127.0.0.1:5432          0.0.0.0:*               LISTEN
    tcp        0      0 192.168.0.132:12001     0.0.0.0:*               LISTEN
    tcp        0      0 127.0.0.1:161           0.0.0.0:*               LISTEN
    tcp        0      0 0.0.0.0:6690            0.0.0.0:*               LISTEN
    tcp        0      0 192.168.0.132:9092      0.0.0.0:*               LISTEN
    tcp        0      0 0.0.0.0:3493            0.0.0.0:*               LISTEN
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN
    tcp        0      0 0.0.0.0:5000            0.0.0.0:*               LISTEN
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN
    tcp        0      0 0.0.0.0:5001            0.0.0.0:*               LISTEN
    tcp        0      0 192.168.0.132:12010     0.0.0.0:*               LISTEN
    tcp        0      0 0.0.0.0:554             0.0.0.0:*               LISTEN
    tcp        0      0 127.0.0.1:38443         0.0.0.0:*               LISTEN
    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN
    tcp        0      0 192.168.0.132:18701     0.0.0.0:*               LISTEN
    tcp        0      0 0.0.0.0:5357            0.0.0.0:*               LISTEN
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN
    tcp        0      0 192.168.0.132:49170     0.0.0.0:*               LISTEN
    tcp        0      0 127.0.0.1:914           0.0.0.0:*               LISTEN
    tcp        0      0 127.0.0.1:5555          0.0.0.0:*               LISTEN
    tcp        0      0 127.0.0.1:915           0.0.0.0:*               LISTEN
    tcp        0      0 127.0.0.1:33300         0.0.0.0:*               LISTEN
    tcp        0      0 0.0.0.0:21              0.0.0.0:*               LISTEN
    tcp6       0      0 :::443                  :::*                    LISTEN
    tcp6       0      0 :::22333                :::*                    LISTEN
    tcp6       0      0 :::445                  :::*                    LISTEN
    tcp6       0      0 :::3261                 :::*                    LISTEN
    tcp6       0      0 :::5566                 :::*                    LISTEN
    tcp6       0      0 :::3263                 :::*                    LISTEN
    tcp6       0      0 :::8096                 :::*                    LISTEN
    tcp6       0      0 :::3264                 :::*                    LISTEN
    tcp6       0      0 :::3265                 :::*                    LISTEN
    tcp6       0      0 :::6690                 :::*                    LISTEN
    tcp6       0      0 :::5000                 :::*                    LISTEN
    tcp6       0      0 :::5001                 :::*                    LISTEN
    tcp6       0      0 ::1:38443               :::*                    LISTEN
    tcp6       0      0 :::139                  :::*                    LISTEN
    tcp6       0      0 :::5357                 :::*                    LISTEN
    tcp6       0      0 :::80                   :::*                    LISTEN
    tcp6       0      0 :::8081                 :::*                    LISTEN
    tcp6       0      0 :::8082                 :::*                    LISTEN
    tcp6       0      0 :::21                   :::*                    LISTEN
    tcp6       0      0 :::22                   :::*                    LISTEN
    tcp6       0      0 ::1:38008               :::*                    LISTEN
    udp        0      0 192.168.0.132:53682     0.0.0.0:*
    udp        0      0 0.0.0.0:46083           0.0.0.0:*
    udp        0      0 192.168.0.132:5353      0.0.0.0:*
    udp        0      0 0.0.0.0:5353            0.0.0.0:*
    udp        0      0 192.168.0.132:55900     0.0.0.0:*
    udp        0      0 127.0.0.1:56019         0.0.0.0:*
    udp        0      0 0.0.0.0:47971           0.0.0.0:*
    Copy text starting here:
                            v.0.0.7
    Operatingsystem:        Debian GNU/Linux 11 (bullseye)
    Installation:           Docker
    Timezone:               Etc/UTC
    User-ID:                0
    X-Server:               false
    Pending OS-Updates:     2
    Nodejs-Installation:    /usr/bin/nodejs         v16.18.1
                            /usr/bin/npm            8.19.2
    ioBroker Core:          js-controller           4.0.23
                            admin                   6.2.23
    Objects type: jsonl
    States  type: jsonl
    root@buanet-iobroker1:/opt/iobroker#
    HomoranH Offline
    HomoranH Offline
    #77
    @thorkillar sagte in Benötige Hilfe: Viele Adapter stürzen regelmäßige ab:
    ist das das selbe wie ein reboot?
    dein SWAP hat nach wie vor
    Swap: 11G 977M 10G
    1GB verbraucht
      Aber egal
      Nee, nicht egal.
      Mit welchen Rechten bist du da unterwegs und wie rufst du das skript auf?
      thorkillar
      #78
      @thomas-braun ok
      ich bin als Admin auf der Synology eingeloggt.
      • dann starte ich den Docker.
      • wähle den Container mit Doppelklick aus
      • Wechsel in den Reiter Terminal
      • und führe dann nacheinander die Befehle aus:
      curl https://raw.githubusercontent.com/Grothesk242/iob_diag/main/iob_diag > iob_diag
      chmod 744 iob_diag
      ./iob_diag | tee iob_diag.log
      server - Synology DiskStation - 14.11.2022, 16_46.mkv
        thorkillar
        #79
        @homoran sagte in Benötige Hilfe: Viele Adapter stürzen regelmäßige ab:
        Der DockerContainer wird komplett gestoppt und startet dann neu. Denke also ja.
          Swap: 11G 977M 10G
          1GB verbraucht
          thorkillar
          #80
          Swap: 11G 977M 10G
          1GB verbraucht
          kann das auch ein Adapter verbrauchen?
          Und was ist ein Swap?
          • T thorkillar
            Swap: 11G 977M 10G
            1GB verbraucht
            #81
            SWAP ist der 'Überlauf' für RAM. Wenn kurzfristig mehr RAM benötigt wird als physisch zur Verfügung steht 'schwappt' das da rein.
            Wie/ob das bei deinem Docker richtig aufgesetzt ist weiß ich aber nicht. Mir scheinen 11GB nur wesentlich zu viel.
              thorkillar
              schrieb am zuletzt editiert von thorkillar
              #82
              @thomas-braun Kann ich den SWAP irgendwo bei der Installation einstellen? Oder nachträglich verkleinern? Ich möchte ungern den iobroker neu aufsetzen und den gleichen Fehler machen.
              Thomas BraunT CodierknechtC OliverIOO 3 Antworten Letzte Antwort
              • T thorkillar
                #83
                @thorkillar
                Da musst du einen der Docktoren fragen.
                Ich setz die Dinger nicht ein.
                • T thorkillar
                  CodierknechtC Offline
                  Codierknecht
                  #84
                  @thorkillar
                  Also auf meiner Synology verhält sich der Container völlig unauffällig.
                  Mir dünkt, Du hast da mal (bewusst oder unbewusst) das Ganze gehörig durcheinander gebracht.
                  Du hast doch alles auf 'nem Verzeichnis auf Deiner Synology liegen.
                  Warum dann nicht mal den Container stoppen,Image verwerfen, neues (aktuelles) Image vom Hub ziehen und damit einen neuen Container aufsetzen?
                  HmIP|ZigBee|Tasmota|Unifi
                  Zabbix Certified Specialist
                  • CodierknechtC Codierknecht
                    @thorkillar
                    thorkillar
                    #85
                    @codierknecht sagte in Benötige Hilfe: Viele Adapter stürzen regelmäßige ab:
                    Korrekt.
                    Das hab ich ja gemacht. Mit dem aktuellen Ergebnis.
                    Mir würde jetzt nur einfallen, den iobroker komplett neu aufzusetzen und die Skripte und Daten zur importieren.
                    Möchte halt gern vorher den Fehler finden.... Um nicht nach Stunden der Arbeit vor dem gleichen Problem zu stehen :-/
                    Kann eine Adapter Instanz die Probleme verursachen?
                    • T thorkillar
                      OliverIOO Offline
                      OliverIOO Offline
                      OliverIO
                      #86
                      ich denke nicht und du solltest da auch nix dran tun. linux macht das alles von alleine.
                      klar kann man nachträglich noch was dran ändern (wie eigentlich alles bei linux),
                      aber bei swap denke ich muss nur ein spezialist was machen, der ganz genau weiß was er tut.
                      für mehr informationen kannst du hier nachlesen:
                      https://wiki.ubuntuusers.de/Swap/
                      und bitte die Befehle im Artikel nicht wild ausprobieren, ausser es sind Befehle mit denen man Infos sieht. Du befindest dich hier in der Danger-Zone, wo deine Installation schnell kaputt ist (dd und so)
                      Für dich gilt: Wenn der Swap über 25% bis spätestens 50% geht, hast du definitiv zu wenig RAM. Dann wird es zeit sich nach alternativen umzuschauen.
                      Ideal ist Swap=0%, aber ein paar Sachen werden da wohl immer wieder mal reingeschoben.
                      Normalerweise ist der Swap eine separate Partition auf der Festplatte. d.h. wenn du anpassen willst, dann muss die partition vergrößert (und damit eine andere verkleinert werden)
                      und denke dran, der computer versucht sap als RAM zu verwenden. Die Geschwindigkeit geht dann eigentlich katastrophal in den Keller, da Lese/Schreibgeschwindigkeit RAM gegenüber SSD/HD viel größer ist.
                      Meine Adapter und Widgets
                      Links im Profil
                      • OliverIOO OliverIO
                        thorkillar
                        #87
                        @oliverio oh, okay danke. dann lass ich das lieber. Wenn das das System alleine hinbekommt, dann soll es das auch machen. Platz hat das System genug.
                        *** MEMORY ***
                        Swap:            11G        977M         10G
                        Total:           27G        6.6G         10G
                        Zum Verständnis:
                        6,6 G werden benötigt
                        977M SWAP + 5,7 GB aus dem RAM ?
                        Was ist aber mit den 9,5G (available)
                        @oliverio sagte in Benötige Hilfe: Viele Adapter stürzen regelmäßige ab:
                        Ich habe zZ. 16 GB auf meinem NAS. Und die RAM Auslastung der NAS ist bei unter 50% im letzen halben Jahr.
                        Was wären Deiner Meinung nach Alternativen? => Ein raspberry pi 4 ?
                        Thomas BraunT CodierknechtC 2 Antworten Letzte Antwort
                        • T thorkillar
                          *** MEMORY ***
                          Swap:            11G        977M         10G
                          Total:           27G        6.6G         10G
                          Zum Verständnis:
                          #88
                          Das ist noch verfügbar. Das wird mit dem buff/cache 'verrechnet'.
                          • T thorkillar
                            *** MEMORY ***
                            Swap:            11G        977M         10G
                            Total:           27G        6.6G         10G
                            Zum Verständnis:
                            Codierknecht
                            #89
                            Wenn Du ein NAS mit 16GB hast? Eher nicht.
                            Wobei ich 8GB RAM dauerhaft schon recht viel finde.
                            Was ist denn auf der Kiste alles am Start?
                              thorkillar
                              #90
                              @thomas-braun okay verstehe.
                              Ich habe das Skript nochmal durchlaufen lassen. Und da ist mir folgender Absatz ROT ins Auge gesprungen.
                              Und das hier wird auch einige Dutzende Male angezeigt.
                              Using TZID without Luxon available is unsupported. Returned times are in UTC, not the requested time zone
                              Und jetzt die Frage, was mache ich am besten?
                                thorkillar
                                #91
                                Docker - > ioBroker
                                CodierknechtC HomoranH 2 Antworten Letzte Antwort
                                • T thorkillar
                                  Docker - > ioBroker
                                  Codierknecht
                                  #92
                                  @thorkillar
                                  Holla - da kommt was zusammen 😁
                                  • T thorkillar
                                    #93
                                    Das ist okay. Ich überlege auch den npm doctor wieder rauszunehmen, der empfiehlt immer die neuste Medizin (das aktuelle LTS Release). Des wegen steht aber auch dabei, dass für ioBroker die Empfehlung abweichend zu des Doktors Meinung im Moment nodejs16/npm8 ist.
                                    • T thorkillar
                                      Docker - > ioBroker
                                      HomoranH Offline
                                      HomoranH Offline
                                      #94
                                      @thorkillar hast du tatsächlich 3 Versionen nodejs parallel installiert?
                                      CodierknechtC T 2 Antworten Letzte Antwort
                                        HomoranH Offline
                                        HomoranH Offline
                                        #95
                                        @thomas-braun aber der Doktor ist doch unterwegs in Times And Relative Dimensions In Space!
                                          Codierknecht
                                          #96
                                          ... und 4x PHP 😨
