  3. Off Topic
  4. Rundumglücklichsupport für @thorkillar ;-)
    5.5k
133 Beiträge 11 Kommentatoren 18.6k Aufrufe 2 Beobachtet
  • T thorkillar
    @thomas-braun nachdem ich everyone adminrechte auf diese datei gegeben habe, hat es funktioniert.
    v.0.0.7
    *** BASE SYSTEM ***
    Architecture: 	x86_64
    Docker: 	v7.1.1
    Virtualization: Unknown (buanet/Synology?)
    Distributor ID:	Debian
    Description:	Debian GNU/Linux 11 (bullseye)
    Release:	11
    Codename:	bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     13:30:34 up 18 days, 20:38,  0 users,  load average: 4.50, 4.00, 4.05
    CPU threads: 4
    *** Time and Time Zones ***
    Mon Nov 14 12:30:34 UTC 2022
    Mon Nov 14 13:30:34 CET 2022
    CET +0100
    Etc/UTC
    *** User and Groups ***
    root
    /root
    root
    *** X-Server-Setup ***
    X-Server: 	false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:             15G        6.3G        558M        402M        9.1G        8.9G
    Swap:            11G        1.1G         10G
    Total:           27G        7.5G         11G
            15966 M total memory
             6326 M used memory
             7327 M active memory
             5789 M inactive memory
              558 M free memory
               34 M buffer memory
             9047 M swap cache
            11627 M total swap
             1132 M used swap
            10495 M free swap
    *** FILESYSTEM ***
    Filesystem             Type   Size  Used Avail Use% Mounted on
    /dev/mapper/cachedev_0 btrfs   28T   20T  8.4T  70% /
    tmpfs                  tmpfs   64M     0   64M   0% /dev
    tmpfs                  tmpfs  7.8G     0  7.8G   0% /sys/fs/cgroup
    shm                    tmpfs   64M     0   64M   0% /dev/shm
    /dev/mapper/cachedev_0 btrfs   28T   20T  8.4T  70% /opt/iobroker
    /dev/mapper/cachedev_0 btrfs   28T   20T  8.4T  70% /etc/hosts
    tmpfs                  tmpfs  7.8G     0  7.8G   0% /proc/acpi
    tmpfs                  tmpfs  7.8G     0  7.8G   0% /proc/scsi
    tmpfs                  tmpfs  7.8G     0  7.8G   0% /sys/firmware
    TARGET             SOURCE        FSTYPE OPTIONS
    /                  /dev/mapper/cachedev_0[/@syno/@docker/btrfs/subvolumes/f52650c50de649759e0e52c54534bca4952c9a6acb221b51af93786ec636b02d]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=48445,subvol=/@syno/@docker/btrfs/subvolumes/f52650c50de649759e0e52c54534bca4952c9a6acb221b51af93786ec636b02d
    |-/opt/iobroker    /dev/mapper/cachedev_0[/@syno/docker/iobroker-live-20221109]        btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=1750,subvol=/@syno/docker/iobroker-live-20221109
    |-/etc/resolv.conf /dev/mapper/cachedev_0[/@syno/@docker/containers/f5b4f41494539b355e4b916e0e468658d31df4089d9965de175213877b7497ef/resolv.conf] btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/f5b4f41494539b355e4b916e0e468658d31df4089d9965de175213877b7497ef/resolv.conf
    |-/etc/hostname    /dev/mapper/cachedev_0[/@syno/@docker/containers/f5b4f41494539b355e4b916e0e468658d31df4089d9965de175213877b7497ef/hostname]    btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/f5b4f41494539b355e4b916e0e468658d31df4089d9965de175213877b7497ef/hostname
    `-/etc/hosts       /dev/mapper/cachedev_0[/@syno/@docker/containers/f5b4f41494539b355e4b916e0e468658d31df4089d9965de175213877b7497ef/hosts]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/f5b4f41494539b355e4b916e0e468658d31df4089d9965de175213877b7497ef/hosts
    /var:
    32M	/var/
    30M	/var/lib
    18M	/var/lib/apt/lists
    18M	/var/lib/apt
    13M	/var/lib/dpkg
    /opt/iobroker/backups:
    2.3G	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.4G	/opt/iobroker/iobroker-data/
    413M	/opt/iobroker/iobroker-data/backup-objects
    307M	/opt/iobroker/iobroker-data/files
    237M	/opt/iobroker/iobroker-data/history
    77M	/opt/iobroker/iobroker-data/files/vis.0
    202M	/opt/iobroker/iobroker-data/states.jsonl
    63M	/opt/iobroker/iobroker-data/objects.json.migrated
    63M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
    54M	/opt/iobroker/iobroker-data/objects.jsonl
    21M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/2.00a59c14.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v16.18.1
    /usr/bin/node 		v16.18.1
    /usr/bin/npm 		8.19.2
    nodejs:
      Installed: 16.18.1-deb-1nodesource1
      Candidate: 16.18.1-deb-1nodesource1
      Version table:
     *** 16.18.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
         12.22.12~dfsg-1~deb11u1 500
            500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
         12.22.5~dfsg-2~11u1 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
    Calling 'npm doctor' for you. Please be patient!
    Check                               Value   Recommendation/Notes
    npm ping                            ok
    npm -v                              not ok  Use npm v9.1.1
    node -v                             not ok  Use node v18.12.1 (current: v16.18.1)
    npm config get registry             ok      using default registry (https://registry.npmjs.org/)
    which git                           ok      /usr/bin/git
    Perms check on cached files         ok
    Perms check on local node_modules   ok
    Perms check on global node_modules  ok
    Perms check on local bin folder     ok
    Perms check on global bin folder    ok
    Verify cache contents               ok      verified 3184 tarballs
    The recommended versions for ioBroker are nodeJS v16 / npm v8
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	4.0.23
    admin: 		6.2.23
    Adapters from github: 	0
    + system.adapter.admin.0                  : admin                 : buanet-iobroker1                         -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.hm-rpc.0                 : hm-rpc                : buanet-iobroker1                         -  enabled, port: 18701
    + system.adapter.hm-rpc.1                 : hm-rpc                : buanet-iobroker1                         -  enabled, port: 12001
    + system.adapter.hm-rpc.2                 : hm-rpc                : buanet-iobroker1                         -  enabled, port: 12010
    + system.adapter.hue.0                    : hue                   : buanet-iobroker1                         -  enabled, port: 80
    + system.adapter.hue.1                    : hue                   : buanet-iobroker1                         -  enabled, port: 80
    + system.adapter.telegram.0               : telegram              : buanet-iobroker1                         -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.web.0                    : web                   : buanet-iobroker1                         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    ioBroker-Repositories
    Active repo(s): stable
    ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.2.23   , installed 6.2.23
    Adapter    "alexa2"       : 3.21.0   , installed 3.21.0
    Adapter    "apple-find-me": 0.0.14   , installed 0.0.14
    Adapter    "backitup"     : 2.5.4    , installed 2.4.12 [Updatable]
    Adapter    "birthdays"    : 2.1.0    , installed 2.1.0
    Adapter    "bring"        : 1.8.1    , installed 1.8.1
    Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
    Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
    Adapter    "daswetter"    : 3.1.3    , installed 3.1.3
    Adapter    "devices"      : 1.0.12   , installed 1.0.12
    Adapter    "discovery"    : 3.0.5    , installed 3.0.5
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "email"        : 1.1.3    , installed 1.1.3
    Adapter    "emby"         : 1.0.2    , installed 1.0.2
    Adapter    "fb-checkpresence": 1.1.19, installed 1.1.19
    Adapter    "history"      : 2.2.0    , installed 2.2.0
    Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
    Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
    Adapter    "hue"          : 3.7.1    , installed 3.7.1
    Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
    Adapter    "ical"         : 1.13.1   , installed 1.13.1
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iot"          : 1.11.9   , installed 1.11.9
    Adapter    "iqontrol"     : 2.0.0    , installed 2.0.0
    Adapter    "javascript"   : 6.0.3    , installed 6.0.3
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "nuki"         : 1.6.0    , installed 1.6.0
    Adapter    "nuki-extended": 2.3.1    , installed 2.3.1
    Adapter    "odl"          : 2.0.5    , installed 2.0.5
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "pushover"     : 3.0.3    , installed 3.0.3
    Adapter    "roomba"       : 1.1.4    , installed 1.1.4
    Adapter    "rssfeed"      : 2.6.1    , installed 2.6.1
    Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
    Adapter    "synology"     : 2.1.9    , installed 2.1.9
    Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
    Adapter    "telegram"     : 1.14.1   , installed 1.14.1
    Adapter    "text2command" : 2.2.2    , installed 2.2.2
    Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
    Adapter    "trashschedule": 2.0.3    , installed 2.0.3
    Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "vis-icontwo"  : 0.89.0   , installed 0.89.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "vis-lcars"    : 1.0.4    , installed 1.0.4
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
    Objects and States
    Objects: 	38385
    States: 	54217
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 https://deb.nodesource.com/node_16.x bullseye InRelease
    Reading package lists...
    Pending Updates: 2
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:6011            0.0.0.0:*               LISTEN      254178     137800     -
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0          59556      -
    tcp        0      0 0.0.0.0:22333           0.0.0.0:*               LISTEN      0          307399866  -
    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          92334111   -
    tcp        0      0 127.0.0.1:512           0.0.0.0:*               LISTEN      0          177055     -
    tcp        0      0 192.168.0.132:12001     0.0.0.0:*               LISTEN      1000       307438514  -
    tcp        0      0 127.0.0.1:161           0.0.0.0:*               LISTEN      0          77318      -
    tcp        0      0 0.0.0.0:6690            0.0.0.0:*               LISTEN      0          196908458  -
    tcp        0      0 192.168.0.132:9092      0.0.0.0:*               LISTEN      1000       307468261  -
    tcp        0      0 0.0.0.0:3493            0.0.0.0:*               LISTEN      0          155577480  -
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       307427015  -
    tcp        0      0 0.0.0.0:5000            0.0.0.0:*               LISTEN      0          59550      -
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       307426758  -
    tcp        0      0 0.0.0.0:5001            0.0.0.0:*               LISTEN      0          59552      -
    tcp        0      0 192.168.0.132:12010     0.0.0.0:*               LISTEN      1000       307445440  -
    tcp        0      0 0.0.0.0:554             0.0.0.0:*               LISTEN      0          249500604  -
    tcp        0      0 127.0.0.1:38443         0.0.0.0:*               LISTEN      0          239165315  -
    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          92334112   -
    tcp        0      0 192.168.0.132:18701     0.0.0.0:*               LISTEN      1000       307437252  -
    tcp        0      0 0.0.0.0:5357            0.0.0.0:*               LISTEN      0          242475320  -
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          59554      -
    tcp        0      0 192.168.0.132:49170     0.0.0.0:*               LISTEN      254178     137597     -
    tcp        0      0 127.0.0.1:914           0.0.0.0:*               LISTEN      0          117576     -
    tcp        0      0 127.0.0.1:5555          0.0.0.0:*               LISTEN      0          92238145   -
    tcp        0      0 127.0.0.1:915           0.0.0.0:*               LISTEN      0          92185235   -
    tcp        0      0 127.0.0.1:33300         0.0.0.0:*               LISTEN      0          84042      -
    tcp        0      0 0.0.0.0:21              0.0.0.0:*               LISTEN      0          307592591  -
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          307399862  -
    tcp        0      0 127.0.0.1:38008         0.0.0.0:*               LISTEN      0          239165313  -
    tcp        0      0 127.0.0.1:5432          0.0.0.0:*               LISTEN      55         120686     -
    tcp6       0      0 :::443                  :::*                    LISTEN      0          59557      -
    tcp6       0      0 :::22333                :::*                    LISTEN      0          307399868  -
    tcp6       0      0 :::445                  :::*                    LISTEN      0          92334109   -
    tcp6       0      0 :::3261                 :::*                    LISTEN      0          88245      -
    tcp6       0      0 :::5566                 :::*                    LISTEN      0          108373     -
    tcp6       0      0 :::3263                 :::*                    LISTEN      0          88243      -
    tcp6       0      0 :::8096                 :::*                    LISTEN      240699     267851639  -
    tcp6       0      0 :::3264                 :::*                    LISTEN      0          88248      -
    tcp6       0      0 :::3265                 :::*                    LISTEN      0          89256      -
    tcp6       0      0 :::6690                 :::*                    LISTEN      0          196908459  -
    tcp6       0      0 :::5000                 :::*                    LISTEN      0          59551      -
    tcp6       0      0 :::5001                 :::*                    LISTEN      0          59553      -
    tcp6       0      0 ::1:38443               :::*                    LISTEN      0          239165316  -
    tcp6       0      0 :::139                  :::*                    LISTEN      0          92334110   -
    tcp6       0      0 :::5357                 :::*                    LISTEN      0          242475321  -
    tcp6       0      0 :::80                   :::*                    LISTEN      0          59555      -
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       307427239  -
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       307457486  -
    tcp6       0      0 :::21                   :::*                    LISTEN      0          307592592  -
    tcp6       0      0 :::22                   :::*                    LISTEN      0          307399864  -
    tcp6       0      0 ::1:38008               :::*                    LISTEN      0          239165314  -
    udp        0      0 192.168.0.132:53682     0.0.0.0:*                           240699     267855149  -
    udp        0      0 0.0.0.0:46083           0.0.0.0:*                           0          307410329  -
    udp        0      0 192.168.0.132:5353      0.0.0.0:*                           1000       307450051  -
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           0          307325023  -
    udp        0      0 192.168.0.132:55900     0.0.0.0:*                           254178     137599     -
    udp        0      0 127.0.0.1:56019         0.0.0.0:*                           240699     267855150  -
    udp        0      0 0.0.0.0:47971           0.0.0.0:*                           0          307325025  -
    udp    33408      0 0.0.0.0:68              0.0.0.0:*                           0          242473464  -
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          30078      -
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          28335      -
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          30926      -
    udp        0      0 192.168.0.132:123       0.0.0.0:*                           87         242467037  -
    udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          32846      -
    udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          32842      -
    udp        0      0 192.168.0.255:137       0.0.0.0:*                           0          304732305  -
    udp        0      0 192.168.0.132:137       0.0.0.0:*                           0          304732304  -
    udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          304732260  -
    udp        0      0 192.168.0.255:138       0.0.0.0:*                           0          304732307  -
    udp        0      0 192.168.0.132:138       0.0.0.0:*                           0          304732306  -
    udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          304732261  -
    udp        0      0 127.0.0.1:161           0.0.0.0:*                           0          77317      -
    udp        0      0 0.0.0.0:41153           0.0.0.0:*                           240699     267855148  -
    udp        0      0 0.0.0.0:9997            0.0.0.0:*                           0          30529      -
    udp        0      0 0.0.0.0:9998            0.0.0.0:*                           0          30528      -
    udp        0      0 0.0.0.0:9999            0.0.0.0:*                           0          30527      -
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           240699     267855147  -
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           0          242474366  -
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           254178     137600     -
    udp        0      0 127.0.0.1:60123         0.0.0.0:*                           254178     137598     -
    udp        0      0 0.0.0.0:19996           0.0.0.0:*                           233155     249503794  -
    udp        0      0 0.0.0.0:19997           0.0.0.0:*                           233155     249503793  -
    udp        0      0 0.0.0.0:19998           0.0.0.0:*                           233155     249503792  -
    udp        0      0 0.0.0.0:3702            0.0.0.0:*                           99         242473604  -
    udp6       0      0 :::5353                 :::*                                0          307325024  -
    udp6       0      0 :::7359                 :::*                                240699     267856031  -
    udp6       0      0 2001:9e8:1c1:b600:2:123 :::*                                87         303265663  -
    udp6       0      0 fe80::211:32ff:fe8d:123 :::*                                87         242467042  -
    udp6       0      0 ::1:123                 :::*                                0          32848      -
    udp6       0      0 :::123                  :::*                                0          32839      -
    udp6       0      0 :::60035                :::*                                0          307325026  -
    udp6       0      0 :::3702                 :::*                                99         242473606  -
    iob diag has finished.
    Copy text starting here:
    			v.0.0.7
    Operatingsystem: 	Debian GNU/Linux 11 (bullseye)
    Installation: 		Docker
    Timezone: 		Etc/UTC
    User-ID: 		0
    X-Server: 		false
    Pending OS-Updates: 	2
    Nodejs-Installation: 	/usr/bin/nodejs 	v16.18.1
    			/usr/bin/npm 		8.19.2
    ioBroker Core: 		js-controller 		4.0.23
    			admin 			6.2.23
    ioBroker Status: 	iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    Pending iob updates: 	1
    Objects: 		38385
    States: 		54217
    Size of iob-Database:
    0	/opt/iobroker/iobroker-data/objects.json.broken
    207M	/opt/iobroker/iobroker-data/states.jsonl
    17M	/opt/iobroker/iobroker-data/states.json.migrated
    17M	/opt/iobroker/iobroker-data/states.json.bak.migrated
    ====================== END OF SUMMARY ==================
    #69
    @thorkillar sagte in Benötige Hilfe: Viele Adapter stürzen regelmäßige ab:
    Was sollen das für Rechte sein? Die log Datei bekommt die Default-Rechte des ausführenden Users.
    Swap:            11G        1.1G
    Beides zu groß, aus meiner Sicht. Da läuft vermutlich ein Skript nicht sauber.
      Swap:            11G        1.1G
      thorkillar
      schrieb am zuletzt editiert von thorkillar
      #70
      @thomas-braun ich habe aber alle Skripte gestoppt.
      • T thorkillar
        HomoranH Offline
        HomoranH Offline
        #71
        und danach rebootet?
          thorkillar
          #72
          @homoran ich bin der meinung ja. Aber starte jetzt nochmal und führe das Skript dann erneut aus.
          • T thorkillar
            thorkillar
            #73
            Ich habe jetzt kontrolliert. Kein Skript läuft. Dann den Docker neu gestartet.
            Und das Log-File wird nicht befüllt. Es wird erstellt, aber es ist leer.
            v.0.0.7
            *** BASE SYSTEM ***
            Docker:         v7.1.1
            Release:        11
            Codename:       bullseye
            VERSION_ID="11"
            ID=debian
             15:57:21 up 18 days, 23:05,  0 users,  load average: 4.40, 4.64, 4.94
            CPU threads: 4
            Mon Nov 14 14:57:21 UTC 2022
            Mon Nov 14 15:57:21 CET 2022
            CET +0100
            Etc/UTC
            root
            /root
            root
            X-Server:       false
            Desktop:
            Terminal:
            *** MEMORY ***
            Mem:             15G        5.7G        276M        514M         10G        9.5G
            Swap:            11G        977M         10G
            Total:           27G        6.6G         10G
                     5654 M used memory
                     7013 M active memory
                     6681 M inactive memory
                      276 M free memory
                       47 M buffer memory
                     9987 M swap cache
                    11627 M total swap
                      977 M used swap
                    10650 M free swap
            *** FILESYSTEM ***
            TARGET             SOURCE
            /var:
            sudo: unable to resolve host buanet-iobroker1: Name or service not known
            32M     /var/
            30M     /var/lib
            18M     /var/lib/apt
            13M     /var/lib/dpkg
            1.5G    /opt/iobroker/iobroker-data/
            348M    /opt/iobroker/iobroker-data/states.jsonl
            58M     /opt/iobroker/iobroker-data/objects.jsonl
            /usr/bin/npm            8.19.2
            nodejs:
              Version table:
            npm ping                            ok
            npm ERR! Some problems found. See above for recommendations.
            npm ERR!     /opt/iobroker/.npm/_logs/2022-11-14T14_57_29_637Z-debug-0.log
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.2.23
            ioBroker-Instances
            Objects and States
            Objects:        38385
            States:         54218
            Hit:2 https://deb.nodesource.com/node_16.x bullseye InRelease
            Hit:3 http://deb.debian.org/debian-security bullseye-security InRelease
            Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
            Reading package lists... Done
            Pending Updates: 2
            Proto Recv-Q Send-Q Local Address           Foreign Address         State
                                    v.0.0.7
            Timezone:               Etc/UTC
            User-ID:                0
            X-Server:               false
                                    /usr/bin/npm            8.19.2
                                    admin                   6.2.23
            Objects type: jsonl
            States  type: jsonl
            root@buanet-iobroker1:/opt/iobroker#
            • T thorkillar
              v.0.0.7
              *** BASE SYSTEM ***
              Docker:         v7.1.1
              Release:        11
              Codename:       bullseye
              VERSION_ID="11"
              ID=debian
              CPU threads: 4
              CET +0100
              Etc/UTC
              root
              /root
              root
              X-Server:       false
              Desktop:
              Terminal:
              *** MEMORY ***
              Swap:            11G        977M         10G
              Total:           27G        6.6G         10G
                       5654 M used memory
                        276 M free memory
                         47 M buffer memory
                       9987 M swap cache
                      11627 M total swap
                        977 M used swap
                      10650 M free swap
              *** FILESYSTEM ***
              TARGET             SOURCE
              /var:
              32M     /var/
              30M     /var/lib
              18M     /var/lib/apt
              13M     /var/lib/dpkg
              /usr/bin/npm            8.19.2
              nodejs:
                Version table:
              npm ping                            ok
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.2.23
              ioBroker-Instances
              Objects and States
              Objects:        38385
              States:         54218
              Pending Updates: 2
                                      v.0.0.7
              Timezone:               Etc/UTC
              User-ID:                0
              X-Server:               false
                                      /usr/bin/npm            8.19.2
                                      admin                   6.2.23
              Objects type: jsonl
              States  type: jsonl
              #74
              Hier nicht:
              echad@chet:~/iob_diag $ ls -lh
              total 72K
              -rwxr-xr-x 1 echad echad 7.4K Nov 12 22:15 iob_diag
              -rw-r--r-- 1 echad echad  16K Nov 14 16:30 iob_diag.log
                Hier nicht:
                total 72K
                thorkillar
                #75
                @thomas-braun mmmm .bei mir schon. Aber egal ;-) Kann den Text ja auch so kopieren.
                Kannst Du / könnt Ihr zu meinem ioB Problem was sagen? Sieht die Diagnose mit Stillstand aller Skripte okay aus?
                • T thorkillar
                  #76
                  Aber egal
                  Nee, nicht egal.
                  Mit welchen Rechten bist du da unterwegs und wie rufst du das skript auf?
                  • T thorkillar
                    v.0.0.7
                    *** BASE SYSTEM ***
                    Docker:         v7.1.1
                    Release:        11
                    Codename:       bullseye
                    VERSION_ID="11"
                    ID=debian
                    CPU threads: 4
                    CET +0100
                    Etc/UTC
                    root
                    /root
                    root
                    X-Server:       false
                    Desktop:
                    Terminal:
                    *** MEMORY ***
                    Swap:            11G        977M         10G
                    Total:           27G        6.6G         10G
                             5654 M used memory
                              276 M free memory
                               47 M buffer memory
                             9987 M swap cache
                            11627 M total swap
                              977 M used swap
                            10650 M free swap
                    *** FILESYSTEM ***
                    TARGET             SOURCE
                    /var:
                    32M     /var/
                    30M     /var/lib
                    18M     /var/lib/apt
                    13M     /var/lib/dpkg
                    /usr/bin/npm            8.19.2
                    nodejs:
                      Version table:
                    npm ping                            ok
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.2.23
                    ioBroker-Instances
                    Objects and States
                    Objects:        38385
                    States:         54218
                    Pending Updates: 2
                                            v.0.0.7
                    Timezone:               Etc/UTC
                    User-ID:                0
                    X-Server:               false
                                            /usr/bin/npm            8.19.2
                                            admin                   6.2.23
                    Objects type: jsonl
                    States  type: jsonl
                    HomoranH Offline
                    HomoranH Offline
                    #77
                    ist das das selbe wie ein reboot?
                    dein SWAP hat nach wie vor
                    Swap: 11G 977M 10G
                    1GB verbraucht
                      Aber egal
                      Nee, nicht egal.
                      thorkillar
                      #78
                      @thomas-braun ok
                      ich bin als Admin auf der Synology eingeloggt.
                      • dann starte ich den Docker.
                      • wähle den Container mit Doppelklick aus
                      • Wechsel in den Reiter Terminal
                      • und führe dann nacheinander die Befehle aus:
                      curl https://raw.githubusercontent.com/Grothesk242/iob_diag/main/iob_diag > iob_diag
                      chmod 744 iob_diag
                      ./iob_diag | tee iob_diag.log
                      server - Synology DiskStation - 14.11.2022, 16_46.mkv
                        thorkillar
                        #79
                        @homoran sagte in Benötige Hilfe: Viele Adapter stürzen regelmäßige ab:
                        Der DockerContainer wird komplett gestoppt und startet dann neu. Denke also ja.
                          Swap: 11G 977M 10G
                          1GB verbraucht
                          thorkillar
                          #80
                          Swap: 11G 977M 10G
                          1GB verbraucht
                          kann das auch ein Adapter verbrauchen?
                          Und was ist ein Swap?
                          • T thorkillar
                            Swap: 11G 977M 10G
                            1GB verbraucht
                            #81
                            SWAP ist der 'Überlauf' für RAM. Wenn kurzfristig mehr RAM benötigt wird als physisch zur Verfügung steht 'schwappt' das da rein.
                            Wie/ob das bei deinem Docker richtig aufgesetzt ist weiß ich aber nicht. Mir scheinen 11GB nur wesentlich zu viel.
                              thorkillar
                              #82
                              @thomas-braun Kann ich den SWAP irgendwo bei der Installation einstellen? Oder nachträglich verkleinern? Ich möchte ungern den iobroker neu aufsetzen und den gleichen Fehler machen.
                              Thomas BraunT CodierknechtC OliverIOO 3 Antworten Letzte Antwort
                              • T thorkillar
                                #83
                                @thorkillar
                                Da musst du einen der Docktoren fragen.
                                Ich setz die Dinger nicht ein.
                                • T thorkillar
                                  CodierknechtC Offline
                                  Codierknecht
                                  #84
                                  @thorkillar
                                  Also auf meiner Synology verhält sich der Container völlig unauffällig.
                                  Mir dünkt, Du hast da mal (bewusst oder unbewusst) das Ganze gehörig durcheinander gebracht.
                                  Du hast doch alles auf 'nem Verzeichnis auf Deiner Synology liegen.
                                  Warum dann nicht mal den Container stoppen,Image verwerfen, neues (aktuelles) Image vom Hub ziehen und damit einen neuen Container aufsetzen?
                                  HmIP|ZigBee|Tasmota|Unifi
                                  Zabbix Certified Specialist
                                  • CodierknechtC Codierknecht
                                    @thorkillar
                                    thorkillar
                                    #85
                                    @codierknecht sagte in Benötige Hilfe: Viele Adapter stürzen regelmäßige ab:
                                    Korrekt.
                                    Das hab ich ja gemacht. Mit dem aktuellen Ergebnis.
                                    Mir würde jetzt nur einfallen, den iobroker komplett neu aufzusetzen und die Skripte und Daten zur importieren.
                                    Möchte halt gern vorher den Fehler finden.... Um nicht nach Stunden der Arbeit vor dem gleichen Problem zu stehen :-/
                                    Kann eine Adapter Instanz die Probleme verursachen?
                                    • T thorkillar
                                      OliverIOO Offline
                                      OliverIOO Offline
                                      OliverIO
                                      #86
                                      ich denke nicht und du solltest da auch nix dran tun. linux macht das alles von alleine.
                                      klar kann man nachträglich noch was dran ändern (wie eigentlich alles bei linux),
                                      aber bei swap denke ich muss nur ein spezialist was machen, der ganz genau weiß was er tut.
                                      für mehr informationen kannst du hier nachlesen:
                                      https://wiki.ubuntuusers.de/Swap/
                                      und bitte die Befehle im Artikel nicht wild ausprobieren, ausser es sind Befehle mit denen man Infos sieht. Du befindest dich hier in der Danger-Zone, wo deine Installation schnell kaputt ist (dd und so)
                                      Für dich gilt: Wenn der Swap über 25% bis spätestens 50% geht, hast du definitiv zu wenig RAM. Dann wird es zeit sich nach alternativen umzuschauen.
                                      Ideal ist Swap=0%, aber ein paar Sachen werden da wohl immer wieder mal reingeschoben.
                                      Normalerweise ist der Swap eine separate Partition auf der Festplatte. d.h. wenn du anpassen willst, dann muss die partition vergrößert (und damit eine andere verkleinert werden)
                                      und denke dran, der computer versucht sap als RAM zu verwenden. Die Geschwindigkeit geht dann eigentlich katastrophal in den Keller, da Lese/Schreibgeschwindigkeit RAM gegenüber SSD/HD viel größer ist.
                                      Meine Adapter und Widgets
                                      Links im Profil
                                      • OliverIOO OliverIO
                                        thorkillar
                                        #87
                                        @oliverio oh, okay danke. dann lass ich das lieber. Wenn das das System alleine hinbekommt, dann soll es das auch machen. Platz hat das System genug.
                                        *** MEMORY ***
                                        Swap:            11G        977M         10G
                                        Total:           27G        6.6G         10G
                                        Zum Verständnis:
                                        6,6 G werden benötigt
                                        977M SWAP + 5,7 GB aus dem RAM ?
                                        Was ist aber mit den 9,5G (available)
                                        @oliverio sagte in Benötige Hilfe: Viele Adapter stürzen regelmäßige ab:
                                        Ich habe zZ. 16 GB auf meinem NAS. Und die RAM Auslastung der NAS ist bei unter 50% im letzen halben Jahr.
                                        Was wären Deiner Meinung nach Alternativen? => Ein raspberry pi 4 ?
                                        Thomas BraunT CodierknechtC 2 Antworten Letzte Antwort
                                        • T thorkillar
                                          *** MEMORY ***
                                          Swap:            11G        977M         10G
                                          Total:           27G        6.6G         10G
                                          Zum Verständnis:
                                          #88
                                          Das ist noch verfügbar. Das wird mit dem buff/cache 'verrechnet'.
