    6.8k
lovelace uinspanelsonoff
8.1k Beiträge 280 Kommentatoren 8.5m Aufrufe 260 Beobachtet
  • T tobiasp
    erstmal Top Arbeit ich habe auch alles soweit eingerichtet nach den Anleitungen aber etliche "Warn" Meldungen.
    javascript.0
    	2022-11-12 14:29:30.051	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5909:56)
    javascript.0
    	2022-11-12 14:29:30.051	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:596:29)
    javascript.0
    	2022-11-12 14:29:30.048	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1214:38)
    javascript.0
    	2022-11-12 14:29:30.048	warn	at Object.<anonymous> (script.js.NsPanel_EG.NS_Panel:1135:12)
    javascript.0
    	2022-11-12 14:29:30.048	warn	at __awaiter (script.js.NsPanel_EG.NS_Panel:4:12)
    javascript.0
    	2022-11-12 14:29:30.047	warn	at new Promise (<anonymous>)
    javascript.0
    	2022-11-12 14:29:30.047	warn	at script.js.NsPanel_EG.NS_Panel:8:71
    javascript.0
    	2022-11-12 14:29:30.047	warn	at Object.next (script.js.NsPanel_EG.NS_Panel:14:53)
    javascript.0
    	2022-11-12 14:29:30.046	warn	at step (script.js.NsPanel_EG.NS_Panel:33:23)
    javascript.0
    	2022-11-12 14:29:30.046	warn	at Object.<anonymous> (script.js.NsPanel_EG.NS_Panel:1138:13)
    javascript.0
    	2022-11-12 14:29:30.046	warn	at HandleScreensaverUpdate (script.js.NsPanel_EG.NS_Panel:4462:29)
    javascript.0
    	2022-11-12 14:29:30.042	warn	getState "mqtt.0.SmartHome.NSPanel_1.stat.POWER2" not found (3)
    javascript.0
    	2022-11-12 14:29:30.042	warn	at processImmediate (node:internal/timers:466:21)
    javascript.0
    	2022-11-12 14:29:30.042	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5909:56)
    Was sind das für Warnmeldungen?
    tobiasp
    #693
    @tobiasp
    Erledigt, habe meinen Fehler gefunden!
    • T tobiasp
      @tobiasp
      danny_v1
      #694
      Hab es jetzt endlich ans laufen gebracht. Nachdem ich eine Seite angelegt und alles noch mal neu gemacht hab.
      Steckdosen kann ich schalten, Lampen funktionieren noch nicht. Hab mit dem alias Manager Lampen aus dem deconz Adapter versucht. Da hab ich nur den ein und aus switsch, der schaltet aber die Lampe nicht und die Farbtemp und Helligkeit wie es nicht dargestellt.
      • D danny_v1
        ArmilarA Offline
        ArmilarA Offline
        Armilar
        Most Active Forum Testing
        #695
        @danny_v1
        Was sind das für Lampen im Deconz?
        Haben die nur Farbtemperatur oder auch Farbe?
        Der Alias Licht kann nur an aus. Nimm mal Farbtemperatur oder Hue
        https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-ALIAS-Definitionen#farbtemperatur-channel-ct
        • ArmilarA Armilar
          @danny_v1
          danny_v1
          #696
          @armilar nur temp und Helligkeit, sind entweder Osram oder tint je nach lampe
          • D danny_v1
            ArmilarA Offline
            ArmilarA Offline
            Armilar
            #697
            @danny_v1 hab es oben noch erweitert
            • ArmilarA Armilar
              danny_v1
              #698
              @armilar ja danke jetzt geht's. Funktioniert nur im Geräte Manager und nicht mit alias Manager.
              ArmilarA 2 Antworten Letzte Antwort
              • D danny_v1
                ArmilarA Offline
                ArmilarA Offline
                Armilar
                #699
                @danny_v1
                Stimmt der Alias-Manager ist komplexer und für mal so eben mal ohne Ahnung von Devices und Channels eine ordentliche Herausforderung. Dafür sind die Pattern für Auto-Aliase bei weitem besser als beim Geräte-Manager.
                Beim Geräte-Manager wartet man immer noch vergeblich auf diverse korrekte Geräte-Typen, die der Alias-Manager jedoch wiederum beherrscht. Daher auch die autoCreateAlias bei den Media-Playern. Wenn du dir so einen selbst bauen möchtest, läufst du zwischenzeitlich Amok.
                Also - die Gerätetypen, die beschrieben sind - funktionieren im Geräte-Manager und sind dort auch schneller angelegt.
                • D danny_v1
                  ArmilarA Offline
                  ArmilarA Offline
                  Armilar
                  #700
                  @danny_v1 sagte in SONOFF NSPanel mit Lovelace UI:
                  Weiterhin frohes Testen mit dem NSPanel-Emulator
                  • I Offline
                    I Offline
                    icemanmw
                    schrieb am zuletzt editiert von icemanmw
                    #701
                    kurze Frage; gibt es eine Einstellung / Parameter der ein automatisches springen auf CARD 0 ermöglicht.
                    Also ich meine wenn der Screensaver angeht, dann spring im Hintergrund auf CARD 0. Somit muss ich nicht jedes mal durch alles Seiten durchblättern und er steht immer am Anfang.
                    E ArmilarA 2 Antworten Letzte Antwort
                    • I icemanmw
                      eppi
                      #702
                      @icemanmw
                      ja das geht, siehe hier https://forum.iobroker.net/topic/50888/sonoff-nspanel/1493?_=1668316321940
                      • W Offline
                        W Offline
                        Wuschl
                        schrieb am zuletzt editiert von Wuschl
                        #703
                        Ich habe ein NS-Panel das sich nicht flashen lässt. 2 Stück waren erfolgreich, das 3. steigt beim "FlashNextion http://nspanel.pky.eu/lui-release.tft" aus. Das komische ist auch, daß der Bildschirm verdreht ist. Wo könnte der Fehler sein?
                        Tasmota flashen geht ohne Probleme. Gibt es irgendwo die orginal Firmware, daß ich es event. zurückschicken kann?
                        Edit: Hab es doch geschafft, mit "FlashNextion http://nspanel.pky.eu/lovelace-ui/github/nspanel-v3.1.0.tft" hat es geklappt.
                        • I icemanmw
                          ArmilarA Offline
                          ArmilarA Offline
                          Armilar
                          #704
                          @icemanmw
                          Ich übernehme das mal mit einem separaten Parameter (Datenpunkt) in die nächsten Versionen
                          Wichtig ist lediglich diese Zeile in der bExit:
                          GeneratePage(config.pages[0]);
                          Wird dann aber per "default" auf "false" stehen, da es sich bei den meisten Panel-Usern eher andersherum verhält.
                          • W Wuschl
                            ArmilarA Offline
                            ArmilarA Offline
                            Armilar
                            #705
                            @wuschl
                            Manchmal kann ein Flash auch hängen bleiben oder in 90° verdreht im Display stattfinden. Habe das auch nie herausgefunden. Dann einfach nochmal flashen und alles ist wieder hübsch...
                              Kuckuckmann
                              #706
                              Mal Offtopic...wir sid schon wieder bei 705 Posts im Thread....Wahnsinn :-)
                              NSPanel Dokumentation im GitHub Wiki:
                              T ArmilarA 2 Antworten Letzte Antwort
                              • K Kuckuckmann
                                TT-Tom
                                #707
                                @kuckuckmann
                                da sieht man wie viel potential dieses Panel hat. Und bei den perfekten Support hier, wird das nicht Enden. Danke nochmal an Alle, die dieses geile Projekt unterstützt .
                                Gruß Tom
                                Public Transport
                                NSPanel Adapter Wiki
                                • T TT-Tom
                                  @kuckuckmann
                                  australien
                                  schrieb am zuletzt editiert von australien
                                  #708
                                  ich beschäftige mich nun seit ein paar Tagen mit dem NSPanel.
                                  Verbindung und Anzeitge mit Sonos (mehrere) hab ich auch schon hin bekommen. Nur mit Lichtern, einfache ein/aus bekomme ich nicht klar.
                                  Genauer gesagt, ich bekomme nur die Überschrift angezeigt, aber keine Einträge. Mit der vorherigen Version der NsPanelTs.ts funktionierte es allerdings schon.
                                  let Test_Licht1: PageEntities =
                                      "type": "cardEntities",
                                      "heading": "Licht 1",
                                      "useColor": true,
                                      "subPage": false,
                                      "parent": undefined,
                                      "items": [
                                          <PageItem>{ id: "alias.0.NSPanel.1.KellerLicht.SET", name: "Keller Licht", interpolateColor: true},
                                          <PageItem>{ id: "alias.0.NSPanel.1.Licht.Kueche.ON", name: "Küche Wasser", interpolateColor: true}
                                  Die Aliase sind korrekt angelegt. was übersehe ich?
                                  • A australien
                                        "useColor": true,
                                        "subPage": false,
                                        "items": [
                                    ArmilarA Offline
                                    ArmilarA Offline
                                    Armilar
                                    #709
                                    @australien
                                    Nimm mal die .SET und .ON aus dem PageItem raus. Die ermittelt das Panel automatisch über den Channel des Alias. Und genau deshalb benötigen wir keine Datenpunkte...
                                    korrekt wäre also:
                                    <PageItem>{ id: "alias.0.NSPanel.1.KellerLicht", name: "Keller Licht", interpolateColor: true},
                                    <PageItem>{ id: "alias.0.NSPanel.1.Licht.Kueche", name: "Küche Wasser", interpolateColor: true}
                                    Das TS-Skript sieht zuerst auf den Channel des Alias. Wenn der z.B. Licht ist holt der sich selbst die Datenpunkte aus dem Alias-Pattern (z.B. .SET und .ACTUAL)
                                    • K Kuckuckmann
                                      ArmilarA Offline
                                      ArmilarA Offline
                                      Armilar
                                      #710
                                      @kuckuckmann
                                      Ja, scheint eines der Top-Themen zu sein - ich vermute mal die Anzahl der stillen Mitleser und die Anzahl der eingesetzten Panels wird gigantisch sein... ;-)
                                        Matze_HH
                                        #711
                                        @armilar Auch vorab von mir ein riesen Lob für diesen überragenden Support und die Entwicklung.
                                        Eine Frage habe ich für zwischendurch :) Hier hatte ein User den Alarmanlagen-Adapter mal angesprochen. Gibt es eine schicke Möglichkeit den Adapter zu integrieren?
                                        Das wäre der Grund mir ein 3. Panel zu holen, noch keinen Plan wohin damit aber haben beruhigt.
                                        Spontan doch noch eine 2. Frage:
                                        Kann ich 2 Rolläden auf einer Page steuern und den Screensaver einmal antippen und bin sofort auf der Seite?
                                        Ich verwende die Aqara Roller Shade E1... hier habe ich nicht alle Datenpunkte, wie in der Beschreibung gefordert.
                                        • M Matze_HH
                                          ArmilarA Offline
                                          ArmilarA Offline
                                          Armilar
                                          #712
                                          @matze_hh
                                          Die Antwort ist in beiden Fällen "ja"
                                          Zu 1)
                                          @Kuckuckmann hatte vor kurzer Zeit erst geschrieben (eher angedeutet), wie das externe Skript diesen Adapter mit dem Panel kombiniert. Ich wollte mir das auch mal ansehen (habe den Adapter sogar installiert), bin aber noch nicht dazu gekommen.
                                          Warum extern? Weil die Anzahl der zusammen mit dem Panel benutzen Adapter nicht eingeschränkt ist. Deshalb soll es auch für alle Anwendungsarten und User offen bleiben. Eine direkte Verdrahtung eines speziellen Adapters würde das Panel an anderer Stelle wieder unflexibel machen.
                                          Evtl. kann man ja noch eine Wiki-Anleitung für das Panel mit dem Alarm-Adapter machen... Müsste aber leicht umsetzbar sein.
                                          Zu 2)
                                          Siehe Post von @eppi https://forum.iobroker.net/post/890954
                                          Im Prinzip setzt du die Rolladen Page als erste Seite. Dann erweiterst du die bExit um
                                          Die 0 steht im Übrigen für die Seite 0. Könnte natürlich vom Seitenzähler auch z.B. 2 sein.
                                          Ich baue eine Option in die nächten Versionen ein...
