  4. iobroker startet nicht nach node-js Update 16.18.1
    5.6k
errorupdate nodejs
55 Beiträge 5 Kommentatoren 6.9k Aufrufe 4 Beobachtet
  • xxx_turbo_xxxX Offline
    xxx_turbo_xxx
    leider nicht. Ich fürchte da ist jetzt alles am A*sch... Komm jetzt plötzlich nicht mal mehr per SSH auf den Raspi 😢
      xxx_turbo_xxx
      So... Nochmal ab und wieder angestöpselt...
      pi@raspberrypi:~ $ iobroker status
      node:internal/modules/cjs/loader:988
        throw err;
      Error: Cannot find module 'graceful-fs'
      Require stack:
      - /opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra/lib/fs                                     /index.js
      - /opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra/lib/in                                     dex.js
      - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
      - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
          at Function.Module._resolveFilename (node:internal/modules/cjs/loader:985:15                                     )
          at Function.Module._load (node:internal/modules/cjs/loader:833:27)
          at Module.require (node:internal/modules/cjs/loader:1057:19)
          at require (node:internal/modules/cjs/helpers:103:18)
          at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/nod                                     e_modules/fs-extra/lib/fs/index.js:5:12)
          at Module._compile (node:internal/modules/cjs/loader:1155:14)
          at Object.Module._extensions..js (node:internal/modules/cjs/loader:1209:10)
          at Module.load (node:internal/modules/cjs/loader:1033:32)
          at Function.Module._load (node:internal/modules/cjs/loader:868:12)
          at Module.require (node:internal/modules/cjs/loader:1057:19) {
        code: 'MODULE_NOT_FOUND',
        requireStack: [
          '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra/lib                                     /fs/index.js',
          '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra/lib                                     /index.js',
          '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
          '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
      • xxx_turbo_xxxX xxx_turbo_xxx
          throw err;
        Require stack:
          requireStack: [
        @xxx_turbo_xxx
        Here we go again.
        cd /opt/iobroker
        sudo -H -u iobroker npm install iobroker.js-controller
        • mickymM Offline
          mickymM Offline
          mickym
          Ansonsten falls Du so verzweifelt bist und alles nicht hilft, dass Du Neuaufbauen willst/musst, kannst ja noch meine Radikalmethode verwenden. Hilft natürlich nur, wenn Du nicht versuchst Deinen iobroker neu zu installieren und Deine package.json überschreibst.
            xxx_turbo_xxx
            pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
            npm ERR! code Unknown system error -117
            npm ERR! syscall rename
            npm ERR! path /opt/iobroker/node_modules/graceful-fs
            npm ERR! dest /opt/iobroker/node_modules/.graceful-fs-i6Qs7iN3
            npm ERR! errno -117
            npm ERR! Unknown system error -117: Unknown system error -117, rename '/opt/iobroker/node_modules/graceful-fs' -> '/opt/iobroker/node_modules/.graceful-fs-i6Qs7iN3'
            npm ERR!     /home/iobroker/.npm/_logs/2022-11-11T11_20_41_275Z-debug-0.log
              npm ERR! errno -117
              @xxx_turbo_xxx
              Das hatten wir doch alles schon...
              Die Verzeichnisse löschen.
                xxx_turbo_xxx
                habe ich ja versucht, bzw. gemacht... Ändert aber anscheinend nix. Oder hab ich da was falsch verstanden?
                pi@raspberrypi:~ $ cd /opt/iobroker
                npm ERR! errno -117
                pi@raspberrypi:/opt/iobroker $ cd /opt/iobroker/node_modules
                pi@raspberrypi:/opt/iobroker/node_modules $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                pi@raspberrypi:/opt/iobroker/node_modules $ ^C
                pi@raspberrypi:/opt/iobroker/node_modules $ cd /opt/iobroker
                npm ERR! errno -117
                npm ERR!     /home/iobroker/.npm/_logs/2022-11-11T11_26_35_301Z-debug-0.log
                  npm ERR! errno -117
                  npm ERR! errno -117
                  @xxx_turbo_xxx
                  Ah, ich glaube da hast du einen 'Fehler' in der RegEx aufgestöbert.
                  Komplette Ausgabe zu
                  for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do echo ${i%}; done
                  bitte.
                    npm ERR! errno -117
                    npm ERR! errno -117
                    @xxx_turbo_xxx sagte in iobroker startet nicht nach node-js Update 16.18.1:
                    Und auch mal bitte
                    find /opt/iobroker/node_modules -type d -iname '.*-????????' ! -iname '.local-chromium' | wc -l
                      xxx_turbo_xxx
                      Beim ersten Befehl passiert nichts (zumindest nicht offensichtlich..
                      der Zweite gibt 0 zurück
                      pi@raspberrypi:/opt/iobroker/node_modules $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do echo ${i%}; done
                      pi@raspberrypi:/opt/iobroker/node_modules $ find /opt/iobroker/node_modules -type d -iname '.*-????????' ! -iname '.local-chromium' | wc -l
                        Okay, muss ich mal was überlegen...
                          @Homoran
                          Du bist doch so'n RegExer...
                          Was filtert denn das so hin:
                          Das erste Zeichen ist immer ein Punkt, das neunte Zeichen von hinten ist immer ein - und die letzten acht Zeichen sind immer alphanumerisch. Und dazwischen kann alles mögliche sein.
                          mickymM HomoranH 2 Antworten Letzte Antwort
                            @Homoran
                            mickymM Offline
                            mickymM Offline
                            mickym
                            @thomas-braun Probier das mal
                            \..*-\w{8}$
                            Kannst ja hier ausprobieren: https://regex101.com/r/0A3FpP/1
                            • mickymM mickym
                              \..*-\w{8}$
                              @mickym
                              Bin ich zu doof für. Wobei eigentlich auch die ursprüngliche Version das finden muss. Tut es zumindest bei mir im Test-Setup:
                              echad@chet:~ $ for i in $(find /home/echad/testverzeichnis -type d -iname ".*-????????" ! -iname ".local-chromium"); do echo ${i%}; done
                              /home/echad/testverzeichnis/test1/.test-mit-2bindest
                              /home/echad/testverzeichnis/test1/.test2-lokali2i
                              /home/echad/testverzeichnis/test1/.graceful-fs-i6Qs7iN3
                                @xxx_turbo_xxx
                                Ich finde in der Abfrage keinen Fehler.
                                sudo rm -rf /opt/iobroker/node_modules/.graceful-fs-i6Qs7iN3
                                sagt?
                                • Thomas BraunT Online
                                  @thomas-braun sagte in iobroker startet nicht nach node-js Update 16.18.1:
                                  Ich vermute sogar, dass du da versucht hast sharp zu installieren und das komplett daneben gegangen ist.
                                  Da muss ich zurückrudern, die Dateien hab ich auch:
                                  echad@chet:~ $ locate gdk-pixbuf-loader.h
                                  /opt/iobroker/node_modules/sharp/vendor/8.12.2/linux-arm64v8/include/gdk-pixbuf-2.0/gdk-pixbuf/gdk-pixbuf-loader.h
                                  /usr/include/gdk-pixbuf-2.0/gdk-pixbuf/gdk-pixbuf-loader.h
                                  Allerdings mit den korrekten Rechten...
                                    @Homoran
                                    dann würde ich den Punkt escapen \. ein normaler Punkt steht für "beliebiges Zeichen"
                                      Danke.
                                      Aber der Befehl funktioniert auch mit Wildcards statt RegEx. Keine Ahnung wo es da beim OP klemmt.
                                        xxx_turbo_xxx
                                        Vielen Dank schonmal für euren Support! Habt ihr noch ne Idee wie ich bei meinem Problem weiter komme?
                                        Thomas BraunT mickymM 2 Antworten Letzte Antwort
                                          @xxx_turbo_xxx
