  4. iobroker startet nicht nach node-js Update 16.18.1
    5.6k
errorupdate nodejs
55 Beiträge 5 Kommentatoren 6.9k Aufrufe 4 Beobachtet
  • xxx_turbo_xxxX Offline
    xxx_turbo_xxx
    @thomas-braun said in iobroker startet nicht nach node-js Update 16.18.1:
    iobroker fix
    nicht bewusst. Und den fixer hab ich nach dem node-js Update auch drüber laufen lassen. Mach ich grundsätzlich...
    Hab ih aber jetzt nochmal drüber gejagt und jetzt konnte ich den Befehl ausführen
    sudo -H -u iobroker npm install iobroker.js-controller
    pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
    npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
    npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
    npm WARN deprecated w3c-hr-time@1.0.2: Use your platform's native performance.now() and performance.timeOrigin.
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated tough-cookie@0.12.1: ReDoS vulnerability parsing Set-Cookie https://nodesecurity.io/advisories/130
    npm WARN deprecated appium-logger@2.1.0: Moved into appium-support
    npm WARN deprecated core-js@1.2.7: core-js@<3.23.3 is no longer maintained and not recommended for usage due to the number of issues. Because of the V8 engine whims, feature detection in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled. Some versions have web compatibility issues. Please, upgrade your dependencies to the actual version of core-js.
    npm WARN deprecated core-js@2.6.12: core-js@<3.23.3 is no longer maintained and not recommended for usage due to the number of issues. Because of the V8 engine whims, feature detection in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled. Some versions have web compatibility issues. Please, upgrade your dependencies to the actual version of core-js.
    added 1 package, and changed 1104 packages in 7m
    107 packages are looking for funding
      run `npm fund` for details
    • Thomas BraunT Online
      @xxx_turbo_xxx
      Und? Lüppt das nun wieder?
        xxx_turbo_xxx
        leider nicht. Ich fürchte da ist jetzt alles am A*sch... Komm jetzt plötzlich nicht mal mehr per SSH auf den Raspi 😢
          xxx_turbo_xxx
          So... Nochmal ab und wieder angestöpselt...
          pi@raspberrypi:~ $ iobroker status
          node:internal/modules/cjs/loader:988
            throw err;
          Error: Cannot find module 'graceful-fs'
          Require stack:
          - /opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra/lib/fs                                     /index.js
          - /opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra/lib/in                                     dex.js
          - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
          - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
              at Function.Module._resolveFilename (node:internal/modules/cjs/loader:985:15                                     )
              at Function.Module._load (node:internal/modules/cjs/loader:833:27)
              at Module.require (node:internal/modules/cjs/loader:1057:19)
              at require (node:internal/modules/cjs/helpers:103:18)
              at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/nod                                     e_modules/fs-extra/lib/fs/index.js:5:12)
              at Module._compile (node:internal/modules/cjs/loader:1155:14)
              at Object.Module._extensions..js (node:internal/modules/cjs/loader:1209:10)
              at Module.load (node:internal/modules/cjs/loader:1033:32)
              at Function.Module._load (node:internal/modules/cjs/loader:868:12)
              at Module.require (node:internal/modules/cjs/loader:1057:19) {
            code: 'MODULE_NOT_FOUND',
            requireStack: [
              '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra/lib                                     /fs/index.js',
              '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra/lib                                     /index.js',
              '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
              '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          • xxx_turbo_xxxX xxx_turbo_xxx
              throw err;
            Require stack:
              requireStack: [
            @xxx_turbo_xxx
            Here we go again.
            cd /opt/iobroker
            • mickymM Offline
              mickymM Offline
              mickym
              Ansonsten falls Du so verzweifelt bist und alles nicht hilft, dass Du Neuaufbauen willst/musst, kannst ja noch meine Radikalmethode verwenden. Hilft natürlich nur, wenn Du nicht versuchst Deinen iobroker neu zu installieren und Deine package.json überschreibst.
                xxx_turbo_xxx
                npm ERR! code Unknown system error -117
                npm ERR! syscall rename
                npm ERR! path /opt/iobroker/node_modules/graceful-fs
                npm ERR! dest /opt/iobroker/node_modules/.graceful-fs-i6Qs7iN3
                npm ERR! errno -117
                npm ERR! Unknown system error -117: Unknown system error -117, rename '/opt/iobroker/node_modules/graceful-fs' -> '/opt/iobroker/node_modules/.graceful-fs-i6Qs7iN3'
                npm ERR!     /home/iobroker/.npm/_logs/2022-11-11T11_20_41_275Z-debug-0.log
                  npm ERR! errno -117
                  @xxx_turbo_xxx
                  Das hatten wir doch alles schon...
                  Die Verzeichnisse löschen.
                    xxx_turbo_xxx
                    habe ich ja versucht, bzw. gemacht... Ändert aber anscheinend nix. Oder hab ich da was falsch verstanden?
                    pi@raspberrypi:~ $ cd /opt/iobroker
                    npm ERR! errno -117
                    pi@raspberrypi:/opt/iobroker $ cd /opt/iobroker/node_modules
                    pi@raspberrypi:/opt/iobroker/node_modules $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                    pi@raspberrypi:/opt/iobroker/node_modules $ ^C
                    pi@raspberrypi:/opt/iobroker/node_modules $ cd /opt/iobroker
                    npm ERR! errno -117
                    npm ERR!     /home/iobroker/.npm/_logs/2022-11-11T11_26_35_301Z-debug-0.log
                      npm ERR! errno -117
                      npm ERR! errno -117
                      @xxx_turbo_xxx
                      Ah, ich glaube da hast du einen 'Fehler' in der RegEx aufgestöbert.
                      Komplette Ausgabe zu
                      for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do echo ${i%}; done
                      bitte.
                        npm ERR! errno -117
                        npm ERR! errno -117
                        @xxx_turbo_xxx sagte in iobroker startet nicht nach node-js Update 16.18.1:
                        Und auch mal bitte
                        find /opt/iobroker/node_modules -type d -iname '.*-????????' ! -iname '.local-chromium' | wc -l
                          xxx_turbo_xxx
                          Beim ersten Befehl passiert nichts (zumindest nicht offensichtlich..
                          der Zweite gibt 0 zurück
                          pi@raspberrypi:/opt/iobroker/node_modules $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do echo ${i%}; done
                          pi@raspberrypi:/opt/iobroker/node_modules $ find /opt/iobroker/node_modules -type d -iname '.*-????????' ! -iname '.local-chromium' | wc -l
                            Okay, muss ich mal was überlegen...
                              @Homoran
                              Du bist doch so'n RegExer...
                              Was filtert denn das so hin:
                              Das erste Zeichen ist immer ein Punkt, das neunte Zeichen von hinten ist immer ein - und die letzten acht Zeichen sind immer alphanumerisch. Und dazwischen kann alles mögliche sein.
                              mickymM HomoranH 2 Antworten Letzte Antwort
                                @Homoran
                                mickymM Offline
                                mickymM Offline
                                mickym
                                @thomas-braun Probier das mal
                                \..*-\w{8}$
                                Kannst ja hier ausprobieren: https://regex101.com/r/0A3FpP/1
                                • mickymM mickym
                                  \..*-\w{8}$
                                  @mickym
                                  Bin ich zu doof für. Wobei eigentlich auch die ursprüngliche Version das finden muss. Tut es zumindest bei mir im Test-Setup:
                                  echad@chet:~ $ for i in $(find /home/echad/testverzeichnis -type d -iname ".*-????????" ! -iname ".local-chromium"); do echo ${i%}; done
                                  /home/echad/testverzeichnis/test1/.test-mit-2bindest
                                  /home/echad/testverzeichnis/test1/.test2-lokali2i
                                  /home/echad/testverzeichnis/test1/.graceful-fs-i6Qs7iN3
                                    @xxx_turbo_xxx
                                    Ich finde in der Abfrage keinen Fehler.
                                    sudo rm -rf /opt/iobroker/node_modules/.graceful-fs-i6Qs7iN3
                                    sagt?
                                      @thomas-braun sagte in iobroker startet nicht nach node-js Update 16.18.1:
                                      Ich vermute sogar, dass du da versucht hast sharp zu installieren und das komplett daneben gegangen ist.
                                      Da muss ich zurückrudern, die Dateien hab ich auch:
                                      echad@chet:~ $ locate gdk-pixbuf-loader.h
                                      /opt/iobroker/node_modules/sharp/vendor/8.12.2/linux-arm64v8/include/gdk-pixbuf-2.0/gdk-pixbuf/gdk-pixbuf-loader.h
                                      /usr/include/gdk-pixbuf-2.0/gdk-pixbuf/gdk-pixbuf-loader.h
                                      Allerdings mit den korrekten Rechten...
                                        @Homoran
                                        dann würde ich den Punkt escapen \. ein normaler Punkt steht für "beliebiges Zeichen"
                                          Danke.
                                          Aber der Befehl funktioniert auch mit Wildcards statt RegEx. Keine Ahnung wo es da beim OP klemmt.
