  3. Einsteigerfragen
  4. *gelöst* Zigbee Adapter läuft nicht mehr nach
    5.6k
132 Beiträge 4 Kommentatoren 9.1k Aufrufe 3 Beobachtet
    @gluecksmann
    Die Ausgabe des Skripts hier posten.
    gluecksmann
    #74
    *** BASE SYSTEM ***
    Architecture:   armv7l
    Docker:         false
    Virtualization: none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 10 (buster)
    Release:        10
    Codename:       buster
    PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="10"
    VERSION="10 (buster)"
    VERSION_CODENAME=buster
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     08:52:17 up 2 days,  1:10,  1 user,  load average: 0.68, 0.46, 0.44
    CPU threads: 4
    *** Time and Time Zones ***
    Fri Nov 11 07:52:17 UTC 2022
    Fri Nov 11 08:52:17 CET 2022
    CET +0100
    Europe/Berlin
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           7.9G        1.4G        4.8G         55M        1.8G        6.4G
    Swap:           99M         22M         77M
    Total:         8.0G        1.4G        4.8G
             7898 M total memory
             1354 M used memory
              695 M active memory
             2205 M inactive memory
             4769 M free memory
              203 M buffer memory
             1571 M swap cache
               99 M total swap
               22 M used swap
               77 M free swap
    *** FILESYSTEM ***
    /dev/root      ext4       29G  7.6G   21G  28% /
    devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     3.9G   66M  3.8G   2% /run
    tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
    TARGET        SOURCE         FSTYPE OPTIONS
    /             /dev/mmcblk0p2 ext4   rw,noatime
    |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    372M    /var/
    116M    /var/lib
    77M     /var/log
    76M     /var/cache
    69M     /var/lib/apt/lists
    /opt/iobroker/backups:
    94M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    480M    /opt/iobroker/iobroker-data/
    206M    /opt/iobroker/iobroker-data/files
    135M    /opt/iobroker/iobroker-data/backup-objects
    79M     /opt/iobroker/iobroker-data/sonosCache
    48M     /opt/iobroker/iobroker-data/files/javascript.admin
    21M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/2.00a59c14.chunk.js.map
    20M     /opt/iobroker/iobroker-data/states.jsonl
    14M     /opt/iobroker/iobroker-data/objects.jsonl
    12M     /opt/iobroker/iobroker-data/objects.json.migrated
    12M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.15.1
    /usr/bin/node           v16.15.1
    /usr/bin/npm            8.11.0
    nodejs:
      Installed: 16.15.1-deb-1nodesource1
      Candidate: 16.18.1-deb-1nodesource1
      Version table:
         16.18.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
     *** 16.15.1-deb-1nodesource1 100
         10.24.0~dfsg-1~deb10u2 500
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.23
    admin:          6.2.23
    + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
    ioBroker-Repositories
    Active repo(s): stable
    ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.2.23   , installed 6.2.23
    Adapter    "alexa2"       : 3.21.0   , installed 3.21.0
    Adapter    "alias-manager": 1.2.4    , installed 1.2.6
    Adapter    "backitup"     : 2.5.4    , installed 2.4.12 [Updatable]
    Adapter    "ble"          : 0.13.0   , installed 0.13.0
    Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
    Adapter    "daswetter"    : 3.1.3    , installed 3.1.3
    Adapter    "devices"      : 1.0.12   , installed 1.0.12
    Adapter    "discovery"    : 3.0.5    , installed 3.0.5
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "ecovacs-deebot": 1.4.4   , installed 1.4.4
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "gruenbeck"    : 0.0.42   , installed 0.0.42
    Adapter    "history"      : 2.2.0    , installed 2.2.0
    Adapter    "hue"          : 3.7.1    , installed 3.7.1
    Adapter    "ical"         : 1.13.1   , installed 1.13.1
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iot"          : 1.11.9   , installed 1.11.9
    Adapter    "javascript"   : 6.0.3    , installed 6.0.3
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "mielecloudservice": 6.4.0, installed 6.3.2  [Updatable]
    Adapter    "musiccast"    : 0.1.5    , installed 0.2.2
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "netatmo"      : 2.0.5    , installed 1.7.1  [Updatable]
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "shelly"       : 6.0.0    , installed 6.0.0
    Adapter    "shuttercontrol": 1.4.18  , installed 1.4.14 [Updatable]
    Adapter    "simple-api"   : 2.7.0    , installed 2.7.2
    Adapter    "smartcontrol" : 1.2.1    , installed 1.2.1
    Adapter    "socketio"     : 4.2.0    , installed 6.1.7
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "sonos"        : 2.2.3    , installed 2.2.3
    Adapter    "trashschedule": 2.0.3    , installed 2.0.3
    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
    Adapter    "web"          : 4.3.0    , installed 5.2.3
    Adapter    "ws"           : 1.3.0    , installed 2.1.2
    Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
    Objects and States
    Objects:        10643
    States:         8595
    Hit:1 http://archive.raspberrypi.org/debian buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
    Reading package lists... Done
    Pending Updates: 194
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18832      648/sshd
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          14012910   21240/cupsd
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       4769369    14907/io.sonoff.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       4769178    14772/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       4771258    14772/iobroker.js-c
    tcp6       0      0 :::3500                 :::*                    LISTEN      1001       4772280    14938/io.sonos.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       4772087    14791/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       10039177   10195/io.web.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          18834      648/sshd
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          14012909   21240/cupsd
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       4772234    14892/io.shelly.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16023      637/dhcpcd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          14012293   21242/cups-browsed
    udp        0      0 0.0.0.0:41100           0.0.0.0:*                           1001       4774195    15209/io.musiccast.
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       4772424    15006/io.chromecast
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11164      368/avahi-daemon: r
    udp        0      0 0.0.0.0:57313           0.0.0.0:*                           108        11166      368/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          16515      637/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        11165      368/avahi-daemon: r
    udp6       0      0 :::56623                :::*                                108        11167      368/avahi-daemon: r
    Thomas BraunT G 2 Antworten Letzte Antwort
    • G gluecksmann
      *** BASE SYSTEM ***
      Docker:         false
      Release:        10
      Codename:       buster
      VERSION_ID="10"
      ID=raspbian
      ID_LIKE=debian
      CPU threads: 4
      CET +0100
      Europe/Berlin
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           99M         22M         77M
               7898 M total memory
               1354 M used memory
                695 M active memory
               4769 M free memory
                203 M buffer memory
               1571 M swap cache
                 99 M total swap
                 22 M used swap
                 77 M free swap
      *** FILESYSTEM ***
      /var:
      372M    /var/
      116M    /var/lib
      77M     /var/log
      76M     /var/cache
      /usr/bin/npm            8.11.0
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.2.23
      ioBroker-Instances
      Objects and States
      Objects:        10643
      States:         8595
      #75
      @gluecksmann
      iob stop
      sudo apt update
      sudo apt full-upgrade
      sudo reboot
      Künftig regelmäßig machen!
      Und die Adapter auch aktuell halten.
      G 1 Antwort Letzte Antwort
        @gluecksmann
        iob stop
        sudo apt update
        sudo reboot
        gluecksmann
        #76
        Diese Angabe verstehe ich nicht... was ist da zu Updaten? Bei den Adaptern werden mir nur 3 oder 4 Angezeigt das es Updates gibt
        • G gluecksmann
          CodierknechtC Online
          Codierknecht
          #77
          @gluecksmann
          HmIP|ZigBee|Tasmota|Unifi
          Zabbix Certified Specialist
          • CodierknechtC Codierknecht
            @gluecksmann
            gluecksmann
            #78
            @codierknecht
            Ja, das habe ich schon gesehen... ich möchte aber wissen WAS das ist. Ich das z.B. wie ein Windowsupdate zu verstehen, also Aktualisierungen des Betriebssystems?
            • G gluecksmann
              @codierknecht
              #79
              @gluecksmann
              Ja, das ist vom OS=Operating System = Betriebssystem
                @gluecksmann
                gluecksmann
                #80
                Ah, ok... Und da gibt es keine richtige Aufforderung das zu machen.... läut noch das Update...
                Thomas BraunT CodierknechtC 2 Antworten Letzte Antwort
                • G gluecksmann
                  #81
                  @gluecksmann
                  Was ist denn eine 'richtige Aufforderung'?
                  Das schaut man sich regelmäßig an.
                    @gluecksmann
                    gluecksmann
                    #82
                    Da könnte man jetzt drüber streiten... aber ich habe es auf meine ToDO Liste gesetzt das regelmäßig zu machen... Schauen wir mal ob wir jetzt weiterkommen...
                    • G gluecksmann
                      Codierknecht
                      #83
                      @gluecksmann sagte in *gelöst* Zigbee Adapter läuft nicht mehr nach:
                      Du hast halt hier keinen Desktop-Aufsatz, der das Ganze in Form von Meldungen o.ä. präsentiert.
                      Ein Linux soll vor allem eins: Laufen!
                      Um Updates muss man sich schon selbst kümmern.
                      Ich bin ja auch eher "WIndows-ianer". Die "Linux-er" ticken da anders 😁 😁 😁
                      • G gluecksmann
                        *** BASE SYSTEM ***
                        Docker:         false
                        Release:        10
                        Codename:       buster
                        VERSION_ID="10"
                        ID=raspbian
                        ID_LIKE=debian
                        CPU threads: 4
                        CET +0100
                        Europe/Berlin
                        pi
                        /home/pi
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Swap:           99M         22M         77M
                                 7898 M total memory
                                 1354 M used memory
                                  695 M active memory
                                 4769 M free memory
                                  203 M buffer memory
                                 1571 M swap cache
                                   99 M total swap
                                   22 M used swap
                                   77 M free swap
                        *** FILESYSTEM ***
                        /var:
                        372M    /var/
                        116M    /var/lib
                        77M     /var/log
                        76M     /var/cache
                        /usr/bin/npm            8.11.0
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.2.23
                        ioBroker-Instances
                        Objects and States
                        Objects:        10643
                        States:         8595
                        gluecksmann
                        #84
                        @gluecksmann
                        So, das wäre erledigt...stehe ich leider immer noch vor dem Problem die vis-view.json in den Ordner Main zu bekommen...
                          #85
                          @codierknecht
                          Ist ja nicht so, als wenn es nicht drölftrilliarden Desktops oder Fenstermanager für Linux gäbe. Aber im Serverbetrieb verbietet sich der Betrieb eines Desktops.
                          Die 'pending Updates' wurden in früheren Versionen in der Konsole bei der motd Begrüßung angezeigt.
                          Wurde aber wegen Sicherheitsbedenken wieder abgeschafft.
                          CodierknechtC G 2 Antworten Letzte Antwort
                            @codierknecht
                            Codierknecht
                            #86
                            OT:
                            @thomas-braun sagte in *gelöst* Zigbee Adapter läuft nicht mehr nach:
                            Wir hatten mal einen Kollegen, der in einem (Windows-)Serverprozess Fehlermeldungen per MessageBox ausgegeben hat.
                            Das war ein Spaß ...
                              @codierknecht
                              gluecksmann
                              #87
                              Verstehe kein Wort... Sorry... DAU
                              • crunchipC Abwesend
                                crunchipC Abwesend
                                #88
                                hast du denn wie oben die alte gelöscht? bzw du hast doch den Adapter neu installiert, richtig, somit ist alles leer, hast du schon ein Projekt erstellt? oder ist auch kein main mehr vorhanden?
                                  gluecksmann
                                  #89
                                  @crunchip
                                  Ich habe den VIS Adaper gelöscht...inkl alles darauf beruhenden Komponenten.
                                  Beim Start legt er ja ein neues Projekt an, deswegen ist da wieder ein Main Ordner vorhanden
                                  • G gluecksmann
                                    @crunchip
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    #90
                                    @gluecksmann dann versuchen wir es mal so
                                    iob stop
                                    danach
                                    cd /opt/iobroker/iobroker-data/files/vis.0
                                    mv main MeinAltesProjekt
                                    anschließend iobroker wieder starten und dein Projekt main importieren
                                      iob stop
                                      danach
                                      gluecksmann
                                      #91
                                      @crunchip sagte in *gelöst* Zigbee Adapter läuft nicht mehr nach:
                                      iob stop
                                      danach
                                      wie importiere ich das Projekt?
                                      • G gluecksmann
                                        iob stop
                                        danach
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        #92
                                        @gluecksmann na vis editor, Dateimanager
                                        zeig mal was für Projekt nun angezeigt wird im Editor
                                          gluecksmann
                                          #93
                                          @crunchip
                                          wenn ich VIS starte, sagt er mir das er noch kein Projekt hat.. wenn ich es ihn anlegen lasse, habe ich wieder den Ordner MAIN, wo ich aber meine Datei NICHT reinkopiert bekomme...
