  4. Test Adapter mihome-cloud
235 Beiträge 48 Kommentatoren 74.7k Aufrufe 46 Beobachtet
    Mein 3 Smartmi Fans tauchen auch mit umfangreichen Infos auf. Klappt!
    T
    T
    tombox
    @hannnes Kannst du ein screenshot zeigen. Gibt es remote commands die funktionieren?
    • JackDanielJ
      JackDanielJ
      JackDaniel
      @tombox sagte in Test Adapter mihome-cloud:
      @jackdaniel Danke für das feedback nochmal neu installieren und schauen was er dann ausgibt
      klemmt leider noch wo :(
      mihome-cloud.0
      2022-11-06 10:37:01.173	info	{"code":-8,"message":"invalid param","result":null}
      mihome-cloud.0
      2022-11-06 10:37:01.172	info	Error getting Events of the device for Luftbefeuchter (238442715) with {"expire":10,"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
      mihome-cloud.0
      2022-11-06 10:37:01.018	info	{"code":-2,"error":{"code":-2,"message":"did offline"},"exe_time":0,"id":4927700,"message":"did offline","net_cost":0,"ot_cost":0}
      mihome-cloud.0
      2022-11-06 10:37:01.017	info	Error getting Status of the device for Luftbefeuchter (238442715) with {"id":0,"method":"Set_HumiValue","accessKey":"IOS00026747c5acafc2","params":[]}
      mihome-cloud.0
      2022-11-06 10:37:00.911	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      mihome-cloud.0
      2022-11-06 10:37:00.910	info	terminating
      mihome-cloud.0
      2022-11-06 10:37:00.899	error	Invalid ID: mihome-cloud.0.320373564.remote.tate == _RobotStatusManager.RobotState.REMOTE ? Protocol.Methods.AppRemoteControlEnd : Protocol.Methods.AppPaus
      mihome-cloud.0
      2022-11-06 10:37:00.898	error	Error: Invalid ID: mihome-cloud.0.320373564.remote.tate == _RobotStatusManager.RobotState.REMOTE ? Protocol.Methods.AppRemoteControlEnd : Protocol.Methods.AppPaus at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17) at ObjectsInRedisClient._setObject (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:2980:26) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3211:29) at processImmediate (node:internal/timers:468:21)
      mihome-cloud.0
      2022-11-06 10:37:00.897	error	unhandled promise rejection: Invalid ID: mihome-cloud.0.320373564.remote.tate == _RobotStatusManager.RobotState.REMOTE ? Protocol.Methods.AppRemoteControlEnd : Protocol.Methods.AppPaus
      mihome-cloud.0
      2022-11-06 10:37:00.897	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      mihome-cloud.0
      2022-11-06 10:37:00.881	info	Found 1 remote events for yeelink.light.bslamp1
      mihome-cloud.0
      2022-11-06 10:37:00.880	info	Found 3 remote commands for yeelink.light.bslamp1
      mihome-cloud.0
      2022-11-06 10:36:57.082	info	Found plugin for yeelink.light.bslamp1
      mihome-cloud.0
      2022-11-06 10:36:57.081	error	TypeError: Cannot read properties of null (reading '0')
      mihome-cloud.0
      2022-11-06 10:36:56.037	info	Found plugin for roborock.vacuum.s5
      mihome-cloud.0
      2022-11-06 10:36:56.037	error	TypeError: Cannot read properties of null (reading '0')
      mihome-cloud.0
      2022-11-06 10:36:51.936	info	Found plugin for deerma.humidifier.jsq
      mihome-cloud.0
      2022-11-06 10:36:51.936	debug	{"code":0,"message":"","result":{"latest_info":[{"plugin_id":1001591,"plugin_package_id":1007699,"version":20,"sdk_version":10039,"change_log":"1.修改部分地区非英语状态下用户协议和隐私政策 2.修复撤销授权后,重新绑定设备无授权弹窗 3.用户协议内隐私超链接跳转本地隐私 4.修复隐私政策滑动超出屏幕范围","download_url":"https://cdn.alsgp0.fds.api.mi-img.com/rn-plugins/2020-06-03/signed_10039_1001591_20_IOS_bundle_9aff56ed7184c786c1f0f6db5e47ae4d.zip","size":6432439,"model":"deerma.humidifier.jsq","force_update_status":0,"status":8,"md5sum":"9aff56ed7184c786c1f0f6db5e47ae4d","gray_info":"[]","platform":2,"create_time":1591198078444,"dev_mode":1},{"plugin_id":1000570,"plugin_package_id":1012902,"version":39,"sdk_version":10047,"change_log":"修复和优化一些问题,内部版本52","download_url":"https://cdn.alsgp0.fds.api.mi-img.com/rn-plugins/2020-12-08/signed_10047_1000570_39_IOS_bundle_e6776fdd671602f308b9be25d889bb0c.zip","size":5443322,"model":"roborock.vacuum.s5","force_update_status":0,"status":8,"md5sum":"e6776fdd671602f308b9be25d889bb0c","gray_info":"{\"data\":[2263,5263],\"type\":\"range\"}","platform":2,"create_time":1607418709856,"dev_mode":1},{"plugin_id":1000708,"plugin_package_id":1002507,"version":2,"sdk_version":10026,"change_log":"1.修改jira。\n1.fix jira.","download_url":"https://cdn.alsgp0.fds.api.mi-img.com/rn-plugins/2019-09-11/signed_10026_1000708_2_IOS_bundle_ec15991cae11aa91ee5abb3f8e94b0a3.zip","size":5913729,"model":"yeelink.light.bslamp1","force_update_status":0,"status":8,"md5sum":"ec15991cae11aa91ee5abb3f8e94b0a3","gray_info":"{\"data\":[903,3903],\"type\":\"range\"}","platform":2,"create_time":1568186512298,"dev_mode":1}],"backup_info":null,"stand_plugin_info":null}}
      mihome-cloud.0
      2022-11-06 10:36:51.806	info	Fetching Plugins
      mihome-cloud.0
      2022-11-06 10:36:51.806	info	prop.ct
      mihome-cloud.0
      2022-11-06 10:36:51.806	info	prop.bright
      mihome-cloud.0
      2022-11-06 10:36:51.805	info	prop.power
      mihome-cloud.0
      2022-11-06 10:36:51.805	info	Found yeelink.light.bslamp1 (Nachttischlampe) with 3 properties
      mihome-cloud.0
      2022-11-06 10:36:51.797	debug	{"did":"75543767","uid":1754651949,"token":"5da80bd97d0fe34520e531fbbb6ce41b","name":"Nachttischlampe","pid":0,"localip":"192.168.1.100","mac":"78:11:DC:92:75:AF","ssid":"JackDaniel","bssid":"78:45:58:B1:95:32","rssi":-63,"longitude":"0.00000000","latitude":"0.00000000","show_mode":1,"model":"yeelink.light.bslamp1","permitLevel":16,"isOnline":true,"spec_type":"urn:miot-spec-v2:device:light:0000A001:yeelink-bslamp1:1","extra":{"isSetPincode":0,"pincodeType":0,"fw_version":"1.6.6_0172","isSubGroup":false,"showGroupMember":false,"split":{}},"orderTime":1649341774,"freqFlag":true,"hide_mode":0,"comFlag":129}
      mihome-cloud.0
      2022-11-06 10:36:51.796	info	event.status
      mihome-cloud.0
      2022-11-06 10:36:51.796	info	Found roborock.vacuum.s5 (R2D2) with 1 properties
      mihome-cloud.0
      2022-11-06 10:36:51.789	debug	{"did":"320373564","uid":1754651949,"token":"717154435a79744d364d31494c577967","name":"R2D2","pid":0,"localip":"192.168.1.101","mac":"64:90:C1:02:7F:1F","ssid":"JackDaniel","bssid":"78:45:58:B1:95:32","rssi":-70,"longitude":"0.00000000","latitude":"0.00000000","show_mode":1,"model":"roborock.vacuum.s5","permitLevel":16,"isOnline":true,"spec_type":"urn:miot-spec-v2:device:vacuum:0000A006:roborock-s5:1","extra":{"isSetPincode":0,"pincodeType":0,"fw_version":"3.5.8_002034","isSubGroup":false,"showGroupMember":false,"split":{}},"orderTime":1635497246,"freqFlag":true,"hide_mode":0,"comFlag":129}
      mihome-cloud.0
      2022-11-06 10:36:51.782	debug	{"did":"238442715","uid":1754651949,"token":"b2e21761512e0ccb16c2ededd82218ab","name":"Luftbefeuchter","pid":0,"localip":"192.168.1.202","mac":"44:23:7C:BC:A3:DB","ssid":"JackDaniel","bssid":"18:E8:29:EA:04:B6","rssi":-50,"longitude":"0.00000000","latitude":"0.00000000","show_mode":1,"model":"deerma.humidifier.jsq","permitLevel":16,"isOnline":false,"spec_type":"urn:miot-spec-v2:device:humidifier:0000A00E:deerma-jsq:1","extra":{"isSetPincode":0,"pincodeType":0,"fw_version":"2.0.7","mcu_version":"0113","isSubGroup":false,"showGroupMember":false,"split":{}},"orderTime":1642267702,"freqFlag":true,"hide_mode":0,"comFlag":129}
      mihome-cloud.0
      2022-11-06 10:36:51.782	info	Found 3 devices
      mihome-cloud.0
      2022-11-06 10:36:51.781	debug	{"code":0,"message":"","result":{"list":[{"did":"238442715","uid":1754651949,"token":"b2e21761512e0ccb16c2ededd82218ab","name":"Luftbefeuchter","pid":0,"localip":"192.168.1.202","mac":"44:23:7C:BC:A3:DB","ssid":"JackDaniel","bssid":"18:E8:29:EA:04:B6","rssi":-50,"longitude":"0.00000000","latitude":"0.00000000","show_mode":1,"model":"deerma.humidifier.jsq","permitLevel":16,"isOnline":false,"spec_type":"urn:miot-spec-v2:device:humidifier:0000A00E:deerma-jsq:1","extra":{"isSetPincode":0,"pincodeType":0,"fw_version":"2.0.7","mcu_version":"0113","isSubGroup":false,"showGroupMember":false,"split":{}},"orderTime":1642267702,"freqFlag":true,"hide_mode":0,"comFlag":129},{"did":"320373564","uid":1754651949,"token":"717154435a79744d364d31494c577967","name":"R2D2","pid":0,"localip":"192.168.1.101","mac":"64:90:C1:02:7F:1F","ssid":"JackDaniel","bssid":"78:45:58:B1:95:32","rssi":-70,"longitude":"0.00000000","latitude":"0.00000000","show_mode":1,"model":"roborock.vacuum.s5","permitLevel":16,"isOnline":true,"spec_type":"urn:miot-spec-v2:device:vacuum:0000A006:roborock-s5:1","extra":{"isSetPincode":0,"pincodeType":0,"fw_version":"3.5.8_002034","isSubGroup":false,"showGroupMember":false,"split":{}},"orderTime":1635497246,"freqFlag":true,"hide_mode":0,"comFlag":129},{"did":"75543767","uid":1754651949,"token":"5da80bd97d0fe34520e531fbbb6ce41b","name":"Nachttischlampe","pid":0,"localip":"192.168.1.100","mac":"78:11:DC:92:75:AF","ssid":"JackDaniel","bssid":"78:45:58:B1:95:32","rssi":-63,"longitude":"0.00000000","latitude":"0.00000000","show_mode":1,"model":"yeelink.light.bslamp1","permitLevel":16,"isOnline":true,"spec_type":"urn:miot-spec-v2:device:light:0000A001:yeelink-bslamp1:1","extra":{"isSetPincode":0,"pincodeType":0,"fw_version":"1.6.6_0172","isSubGroup":false,"showGroupMember":false,"split":{}},"orderTime":1649341774,"freqFlag":true,"hide_mode":0,"comFlag":129}],"next_start_did":"","has_more":false}}
      mihome-cloud.0
      2022-11-06 10:36:51.625	info	Get devices
      mihome-cloud.0
      2022-11-06 10:36:51.622	info	Login successful
      mihome-cloud.0
      2022-11-06 10:36:51.621	debug	"ok"
      mihome-cloud.0
      2022-11-06 10:36:51.481	debug	"&&&START&&&{\"qs\":\"%3Fsid%3Dxiaomiio%26_json%3Dtrue\",\"ssecurity\":\"eLbNG0p56Mp/DYQOdhf4Og==\",\"code\":0,\"passToken\":\"V1:DXmurwq2/R1BHTELu6obCcDnh9hauOPj3DoX5tdXCKVmnlboKcoPNH/WiZSEz6zf7fxMnuHG7xmQRLHGs3uv7uyCbSI8lsLiDgmEEHOhTF5Whl9SSqUCt3tLumfA45sFSRgVqLvdQ8AfxhRkghXsfI0qxmgMycGQ00ge+lIimNORPamxswjf4kjFymxLnQeNSlqJn4X/3o4ODLfMtEedBpxnbvW1+aR7mDWINn5mKxB033Nbs/IAHmk9TLjc8+JXvBG5KynMNvJ8Sf7Yv+eRvPsgkv3uuGZgxIEJK3B6EEg=\",\"description\":\"成功\",\"securityStatus\":0,\"nonce\":5768626167211188224,\"userId\":1754651949,\"cUserId\":\"EzXMhMFs8J0wtEntUPSNUwO-ghA\",\"result\":\"ok\",\"psecurity\":\"+YaMogoDNn2lP+ERYNRvZw==\",\"captchaUrl\":null,\"location\":\"https://sts.api.io.mi.com/sts?d=wb_ef2622a1-355d-43ff-8640-1d31120126f3&ticket=0&pwd=1&p_ts=1667727411000&fid=0&p_lm=1&auth=h4CrMYd5y3N817SPY26%2BiSeE5ATB1mvnplGu%2B4h6ooR9xWVTdeCgrzxlGS3bjLmQ3i5Ckt81U4aBAGuKcagHzrU4F1pMBiwH5tFf2y2Lff1GDmXBQntkQtGIx28D7lDioBs4qvZHPwwny0m%2B4liDXTmPovqEbZw7daMVVHS9QrQ%3D&m=1&_group=DEFAULT&tsl=0&p_ca=0&p_ur=AT&p_idc=Europe&nonce=YNSuCyLJsGUBqCAA&_ssign=RB5dvDQ2Jzs5EbFybwyUELNKrLA%3D\",\"pwd\":1,\"child\":0,\"desc\":\"成功\"}"
      mihome-cloud.0
      2022-11-06 10:36:51.204	debug	"&&&START&&&{\"serviceParam\":\"{\\\"checkSafePhone\\\":false,\\\"checkSafeAddress\\\":false,\\\"lsrp_score\\\":0.0}\",\"qs\":\"%3Fsid%3Dxiaomiio%26_json%3Dtrue\",\"code\":70016,\"description\":\"登录验证失败\",\"securityStatus\":0,\"_sign\":\"0psXfr43eNI0IX6q9Suk3qWbRqU=\",\"sid\":\"xiaomiio\",\"result\":\"error\",\"captchaUrl\":null,\"callback\":\"https://sts.api.io.mi.com/sts\",\"location\":\"https://account.xiaomi.com/fe/service/login?_json=true&sid=xiaomiio&qs=%253Fsid%253Dxiaomiio%2526_json%253Dtrue&callback=https%3A%2F%2Fsts.api.io.mi.com%2Fsts&_sign=0psXfr43eNI0IX6q9Suk3qWbRqU%3D&serviceParam=%7B%22checkSafePhone%22%3Afalse%2C%22checkSafeAddress%22%3Afalse%2C%22lsrp_score%22%3A0.0%7D&showActiveX=false&theme=&needTheme=false&bizDeviceType=\",\"pwd\":0,\"child\":0,\"desc\":\"登录验证失败\"}"
      mihome-cloud.0
      2022-11-06 10:36:50.917	info	Login to MiHome Cloud
      mihome-cloud.0
      2022-11-06 10:36:50.895	info	starting. Version 0.0.1 (non-npm: TA2k/ioBroker.mihome-cloud#3a7857507ff5078425c0881211690537a9ccf6ce) in /opt/iobroker/node_modules/iobroker.mihome-cloud, node: v16.18.1, js-controller: 4.0.23
      mihome-cloud.0
      2022-11-06 10:36:50.478	debug	States connected to redis: 127.0.0.1:9000
      mihome-cloud.0
      2022-11-06 10:36:50.350	debug	States create User PubSub Client
      mihome-cloud.0
      2022-11-06 10:36:50.349	debug	States create System PubSub Client
      mihome-cloud.0
      2022-11-06 10:36:50.304	debug	Redis States: Use Redis connection: 127.0.0.1:9000
      mihome-cloud.0
      2022-11-06 10:36:50.260	debug	Objects connected to redis: 127.0.0.1:9001
      mihome-cloud.0
      2022-11-06 10:36:50.254	debug	Objects client initialize lua scripts
      mihome-cloud.0
      2022-11-06 10:36:50.144	debug	Objects create User PubSub Client
      mihome-cloud.0
      2022-11-06 10:36:50.143	debug	Objects create System PubSub Client
      mihome-cloud.0
      2022-11-06 10:36:50.142	debug	Objects client ready ... initialize now
      mihome-cloud.0
      2022-11-06 10:36:50.082	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
      Carpe diem
      T bahnuhrB 2 Antworten Letzte Antwort
        in "remote" ist noch nichts drin.
        Wenn ich sonst noch wo nachsehen soll, bitte mit kurzer Wegbeschreibung für Dummys, wo ich hin muss.
        haselchenH T 2 Antworten Letzte Antwort
        • JackDanielJ JackDaniel
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          mihome-cloud.0
          T
          T
          tombox
          @jackdaniel Habe noch mal was verbessert aber es scheint so aufgrund der Unterschiedlichkeit der Geräte nicht möglich ein generischen Ansatz für alle Geräte zu finden.
          JackDanielJ 1 Antwort Letzte Antwort
          • T tombox
            JackDanielJ
            JackDanielJ
            JackDaniel
            @tombox
            der crash ist nun weg, gibt aber noch fehler im log
            wird der zugang zu meiner cloud benötigt?
            mihome-cloud.0
            Zeit
            debug
            Nachricht
            mihome-cloud.0
            2022-11-06 16:55:27.957	info	{"code":-8,"message":"invalid param","result":null}
            mihome-cloud.0
            2022-11-06 16:55:27.957	info	Error getting Events of the device for Nachttischlampe (75543767) with {"expire":10,"method":["this.apiDataSource.registerProps"],"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
            mihome-cloud.0
            2022-11-06 16:55:27.844	error	SyntaxError: Unexpected token o in JSON at position 1 at JSON.parse (<anonymous>) at MihomeCloud.parseResponse (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:660:19) at /opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:618:37 at processTicksAndRejections (node:internal/process/task_queues:96:5) at async MihomeCloud.updateDevices (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:593:9) at async Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:779:11)
            mihome-cloud.0
            mihome-cloud.0
            2022-11-06 16:55:27.843	error	/home/rpc/75543767
            mihome-cloud.0
            2022-11-06 16:55:27.723	info	{"code":-8,"message":"invalid param","result":null}
            mihome-cloud.0
            2022-11-06 16:55:27.722	info	Error getting Events of the device for R2D2 (320373564) with {"expire":10,"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
            mihome-cloud.0
            2022-11-06 16:55:27.406	info	{"code":-8,"message":"invalid param","result":null}
            mihome-cloud.0
            2022-11-06 16:55:27.406	info	Error getting Events of the device for Luftbefeuchter (238442715) with {"expire":10,"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
            mihome-cloud.0
            2022-11-06 16:55:27.320	info	undefined is not a valid state value for id "mihome-cloud.0.238442715.status.status"
            mihome-cloud.0
            2022-11-06 16:55:27.011	info	Update devices
            mihome-cloud.0
            2022-11-06 16:55:18.727	info	{"code":-8,"message":"invalid param","result":null}
            mihome-cloud.0
            2022-11-06 16:55:18.727	info	Error getting Events of the device for Nachttischlampe (75543767) with {"expire":10,"method":["this.apiDataSource.registerProps"],"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
            mihome-cloud.0
            2022-11-06 16:55:18.606	error	SyntaxError: Unexpected token o in JSON at position 1 at JSON.parse (<anonymous>) at MihomeCloud.parseResponse (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:660:19) at /opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:618:37 at processTicksAndRejections (node:internal/process/task_queues:96:5) at async MihomeCloud.updateDevices (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:593:9) at async Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:779:11)
            mihome-cloud.0
            2022-11-06 16:55:18.605	error	SyntaxError: Unexpected token o in JSON at position 1
            mihome-cloud.0
            2022-11-06 16:55:18.605	error	/home/rpc/75543767
            mihome-cloud.0
            2022-11-06 16:55:18.443	info	{"code":-8,"message":"invalid param","result":null}
            mihome-cloud.0
            2022-11-06 16:55:18.443	info	Error getting Events of the device for R2D2 (320373564) with {"expire":10,"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
            mihome-cloud.0
            2022-11-06 16:55:18.183	info	{"code":-8,"message":"invalid param","result":null}
            mihome-cloud.0
            2022-11-06 16:55:18.183	info	Error getting Events of the device for Luftbefeuchter (238442715) with {"expire":10,"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
            mihome-cloud.0
            2022-11-06 16:55:18.068	info	undefined is not a valid state value for id "mihome-cloud.0.238442715.status.status"
            mihome-cloud.0
            2022-11-06 16:55:17.717	info	Update devices
            mihome-cloud.0
            2022-11-06 16:55:17.011	info	{"code":0,"exe_time":60,"id":9879399,"message":"ok","net_cost":74,"ot_cost":0,"otlocalts":1667750117003464,"result":["error"]}
            mihome-cloud.0
            2022-11-06 16:55:07.715	info	{"code":0,"exe_time":200,"id":8544340,"message":"ok","net_cost":65,"ot_cost":0,"otlocalts":1667750107708289,"result":["error"]}
            mihome-cloud.0
            2022-11-06 16:54:54.583	info	{"code":-8,"message":"invalid param","result":null}
            mihome-cloud.0
            2022-11-06 16:54:54.582	info	Error getting Events of the device for Nachttischlampe (75543767) with {"expire":10,"method":["this.apiDataSource.registerProps"],"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
            mihome-cloud.0
            2022-11-06 16:54:54.464	error	SyntaxError: Unexpected token o in JSON at position 1 at JSON.parse (<anonymous>) at MihomeCloud.parseResponse (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:660:19) at /opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:618:37 at processTicksAndRejections (node:internal/process/task_queues:96:5) at async MihomeCloud.updateDevices (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:593:9) at async Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:779:11)
            mihome-cloud.0
            2022-11-06 16:54:54.463	error	SyntaxError: Unexpected token o in JSON at position 1
            mihome-cloud.0
            2022-11-06 16:54:54.463	error	/home/rpc/75543767
            mihome-cloud.0
            2022-11-06 16:54:54.260	info	{"code":-8,"message":"invalid param","result":null}
            mihome-cloud.0
            2022-11-06 16:54:54.260	info	Error getting Events of the device for R2D2 (320373564) with {"expire":10,"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
            mihome-cloud.0
            2022-11-06 16:54:54.048	info	{"code":-8,"message":"invalid param","result":null}
            mihome-cloud.0
            2022-11-06 16:54:54.047	info	Error getting Events of the device for Luftbefeuchter (238442715) with {"expire":10,"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
            mihome-cloud.0
            2022-11-06 16:54:53.934	info	undefined is not a valid state value for id "mihome-cloud.0.238442715.status.status"
            mihome-cloud.0
            2022-11-06 16:54:53.652	info	Update devices
            mihome-cloud.0
            2022-11-06 16:54:43.651	info	{"code":0,"exe_time":240,"id":2281919,"message":"ok","net_cost":63,"ot_cost":0,"otlocalts":1667750083643273,"result":["error"]}
            mihome-cloud.0
            2022-11-06 16:54:38.739	info	{"code":-8,"message":"invalid param","result":null}
            mihome-cloud.0
            2022-11-06 16:54:38.739	info	Error getting Events of the device for Nachttischlampe (75543767) with {"expire":10,"method":["this.apiDataSource.registerProps"],"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
            mihome-cloud.0
            2022-11-06 16:54:38.651	error	SyntaxError: Unexpected token o in JSON at position 1 at JSON.parse (<anonymous>) at MihomeCloud.parseResponse (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:660:19) at /opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:618:37 at processTicksAndRejections (node:internal/process/task_queues:96:5) at async MihomeCloud.updateDevices (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:593:9) at async Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:779:11)
            mihome-cloud.0
            2022-11-06 16:54:38.650	error	SyntaxError: Unexpected token o in JSON at position 1
            mihome-cloud.0
            2022-11-06 16:54:38.650	error	/home/rpc/75543767
            mihome-cloud.0
            2022-11-06 16:54:38.492	info	{"code":-8,"message":"invalid param","result":null}
            mihome-cloud.0
            2022-11-06 16:54:38.492	info	Error getting Events of the device for R2D2 (320373564) with {"expire":10,"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
            mihome-cloud.0
            2022-11-06 16:54:38.236	info	{"code":-8,"message":"invalid param","result":null}
            mihome-cloud.0
            2022-11-06 16:54:38.236	info	Error getting Events of the device for Luftbefeuchter (238442715) with {"expire":10,"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
            mihome-cloud.0
            2022-11-06 16:54:38.151	info	undefined is not a valid state value for id "mihome-cloud.0.238442715.status.status"
            mihome-cloud.0
            2022-11-06 16:54:37.622	info	Update devices
            mihome-cloud.0
            2022-11-06 16:54:27.622	info	{"code":0,"exe_time":260,"id":5199127,"message":"ok","net_cost":103,"ot_cost":0,"otlocalts":1667750067604380,"result":["error"]}
            mihome-cloud.0
            2022-11-06 16:53:37.107	info	[{"sa_id":513,"model":"yeelink.light.bslamp1","name":"Turn on","keyName":"Turn on","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.color1.set_power","value":["on","smooth",500]},"protocol_type":1},{"sa_id":522,"model":"yeelink.light.bslamp1","name":"Turn off","keyName":"Turn off","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.color1.set_power","value":["off","smooth",500]},"protocol_type":1},{"sa_id":523,"model":"yeelink.light.bslamp1","name":"Turn on/off","keyName":"Turn on/off","type":0,"groupInfo":[],"tr_id":301,"payload":{"did":"","command":"yeelink.light.color1.toggle"},"protocol_type":1},{"sa_id":524,"model":"yeelink.light.bslamp1","name":"Light up for an adjustable period of time","keyName":"Light up for an adjustable period of time","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.bslamp1.set_scene","plug_id":"GET_YEELINK_DELAY_SETTING"},"protocol_type":1},{"sa_id":525,"model":"yeelink.light.bslamp1","name":"Turn on and set light","keyName":"Turn on and set light","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.bslamp1.set_scene","plug_id":"GET_YEELINK_SCENE"},"protocol_type":1},{"sa_id":526,"model":"yeelink.light.bslamp1","name":"Brightness up","keyName":"Brightness up","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.bslamp1.set_adjust","value":["increase","bright"]},"protocol_type":1},{"sa_id":527,"model":"yeelink.light.bslamp1","name":"Brightness down","keyName":"Brightness down","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.bslamp1.set_adjust","value":["decrease","bright"]},"protocol_type":1},{"sa_id":528,"model":"yeelink.light.bslamp1","name":"Switch brightness level","keyName":"Switch brightness level","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.bslamp1.set_adjust","value":["circle","bright"]},"protocol_type":1},{"sa_id":529,"model":"yeelink.light.bslamp1","name":"Color temperature up","keyName":"Color temperature up","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.bslamp1.set_adjust","value":["increase","ct"]},"protocol_type":1},{"sa_id":530,"model":"yeelink.light.bslamp1","name":"Color temperature down","keyName":"Color temperature down","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.bslamp1.set_adjust","value":["decrease","ct"]},"protocol_type":1},{"sa_id":531,"model":"yeelink.light.bslamp1","name":"Switch color temperature level","keyName":"Switch color temperature level","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.bslamp1.set_adjust","value":["circle","ct"]},"protocol_type":1},{"sa_id":532,"model":"yeelink.light.bslamp1","name":"Turn on or adjust brightness","keyName":"Turn on or adjust brightness","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.bslamp1.set_adjust","value":["auto","bright"]},"protocol_type":1},{"sa_id":533,"model":"yeelink.light.bslamp1","name":"Turn on or adjust color temperature","keyName":"Turn on or adjust color temperature","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.bslamp1.set_adjust","value":["auto","ct"]},"protocol_type":1},{"sa_id":534,"model":"yeelink.light.bslamp1","name":"Turn on or adjust color","keyName":"Turn on or adjust color","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.bslamp1.set_adjust","value":["auto","color"]},"protocol_type":1},{"sa_id":535,"model":"yeelink.light.bslamp1","name":"Adjust brightness","keyName":"Adjust brightness","type":0,"groupInfo":[],"tr_id":302,"payload":{"did":"","command":"yeelink.light.bslamp1.adjust_bright"},"protocol_type":1},{"sa_id":536,"model":"yeelink.light.bslamp1","name":"Adjust color temperature","keyName":"Adjust color temperature","type":0,"groupInfo":[],"tr_id":302,"payload":{"did":"","command":"yeelink.light.bslamp1.adjust_ct"},"protocol_type":1},{"sa_id":537,"model":"yeelink.light.bslamp1","name":"Adjust color","keyName":"Adjust color","type":0,"groupInfo":[],"tr_id":302,"payload":{"did":"","command":"yeelink.light.bslamp1.adjust_color"},"protocol_type":1},{"sa_id":538,"model":"yeelink.light.bslamp1","name":"Switch color","keyName":"Switch color","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.bslamp1.set_adjust","value":["circle","color"]},"protocol_type":1}]
            mihome-cloud.0
            2022-11-06 16:53:37.107	info	yeelink.light.bslamp1
            mihome-cloud.0
            2022-11-06 16:53:37.106	info	[{"sa_id":958,"model":"roborock.vacuum.s5","name":"Start cleaning","keyName":"Start cleaning","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"roborock.vacuum.s5.app_start"},"protocol_type":1},{"sa_id":959,"model":"roborock.vacuum.s5","name":"Switch to Balanced mode","keyName":"Switch to Balanced mode","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"roborock.vacuum.s5.set_custom_mode","value":60},"protocol_type":1},{"sa_id":960,"model":"roborock.vacuum.s5","name":"Switch to Quiet mode","keyName":"Switch to Quiet mode","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"roborock.vacuum.s5.set_custom_mode","value":38},"protocol_type":1},{"sa_id":961,"model":"roborock.vacuum.s5","name":"Pause cleaning","keyName":"Pause cleaning","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"roborock.vacuum.s5.app_pause"},"protocol_type":1},{"sa_id":962,"model":"roborock.vacuum.s5","name":"Switch to Turbo mode","keyName":"Switch to Turbo mode","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"roborock.vacuum.s5.set_custom_mode","value":77},"protocol_type":1},{"sa_id":963,"model":"roborock.vacuum.s5","name":"Go back to the dock","keyName":"Go back to the dock","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"roborock.vacuum.s5.app_smart_charge"},"protocol_type":1}]
            mihome-cloud.0
            2022-11-06 16:53:37.106	info	roborock.vacuum.s5
            mihome-cloud.0
            2022-11-06 16:53:37.106	info	[{"sa_id":6791,"model":"deerma.humidifier.jsq","name":"Turn off the humidifier","keyName":"Turn off the humidifier","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"deerma.humidifier.mjjsq.Set_OnOff","value":0},"protocol_type":1},{"sa_id":6792,"model":"deerma.humidifier.jsq","name":"Turn on the humidifier","keyName":"Turn on the humidifier","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"deerma.humidifier.mjjsq.Set_OnOff","value":1},"protocol_type":1},{"sa_id":6793,"model":"deerma.humidifier.jsq","name":"Set to constant humidity mode","keyName":"Set to constant humidity mode","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"deerma.humidifier.mjjsq.Set_HumidifierGears","value":4},"protocol_type":1},{"sa_id":6794,"model":"deerma.humidifier.jsq","name":"Set the humidifying speed to low","keyName":"Set the humidifying speed to low","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"deerma.humidifier.mjjsq.Set_HumidifierGears","value":1},"protocol_type":1},{"sa_id":6795,"model":"deerma.humidifier.jsq","name":"Set the humidifying speed to medium","keyName":"Set the humidifying speed to medium","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"deerma.humidifier.mjjsq.Set_HumidifierGears","value":2},"protocol_type":1},{"sa_id":6796,"model":"deerma.humidifier.jsq","name":"Set the humidifying speed to high","keyName":"Set the humidifying speed to high","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"deerma.humidifier.mjjsq.Set_HumidifierGears","value":3},"protocol_type":1}]
            mihome-cloud.0
            2022-11-06 16:53:37.106	info	deerma.humidifier.jsq
            mihome-cloud.0
            2022-11-06 16:53:37.006	info	{"code":0,"message":"","result":{"homelist":[{"id":"137001000499","name":"Da Ham","bssid":"","dids":[],"icon":"style_1_favorites","shareflag":0,"permit_level":10,"status":1,"background":"static1","smart_room_background":"style_1_favorites","longitude":0,"latitude":0,"city_id":0,"address":"","create_time":1519470799,"roomlist":[{"id":"137001034342","name":"Gästezimmer","bssid":"","parentid":"137001000499","dids":["75543767"],"icon":"more_1","background":"style_1_favorites","shareflag":0,"create_time":1636094924},{"id":"137001000503","name":"Wohnzimmer","bssid":"","parentid":"137001000499","dids":["238442715","320373564"],"icon":"livingroom_1","background":"style_1_favorites","shareflag":0,"create_time":1519494939}],"uid":1754651949}],"has_more":false,"max_id":"75543767"}}
            mihome-cloud.0
            2022-11-06 16:53:36.880	info	{"code":0,"message":"","result":{"local_list":[],"third_list":[]}}
            mihome-cloud.0
            2022-11-06 16:53:36.792	info	{"code":-8,"message":"invalid param","result":null}
            mihome-cloud.0
            2022-11-06 16:53:36.792	info	Error getting Events of the device for Nachttischlampe (75543767) with {"expire":10,"method":["this.apiDataSource.registerProps"],"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
            mihome-cloud.0
            2022-11-06 16:53:36.647	error	SyntaxError: Unexpected token o in JSON at position 1 at JSON.parse (<anonymous>) at MihomeCloud.parseResponse (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:660:19) at /opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:618:37 at runMicrotasks (<anonymous>) at processTicksAndRejections (node:internal/process/task_queues:96:5) at async MihomeCloud.updateDevices (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:593:9) at async MihomeCloud.onReady (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:93:7)
            mihome-cloud.0
            2022-11-06 16:53:36.646	error	SyntaxError: Unexpected token o in JSON at position 1
            mihome-cloud.0
            2022-11-06 16:53:36.646	error	/home/rpc/75543767
            mihome-cloud.0
            2022-11-06 16:53:33.509	info	{"code":-8,"message":"invalid param","result":null}
            mihome-cloud.0
            2022-11-06 16:53:33.509	info	Error getting Events of the device for R2D2 (320373564) with {"expire":10,"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
            mihome-cloud.0
            2022-11-06 16:53:33.252	info	{"code":-8,"message":"invalid param","result":null}
            mihome-cloud.0
            2022-11-06 16:53:33.252	info	Error getting Events of the device for Luftbefeuchter (238442715) with {"expire":10,"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
            mihome-cloud.0
            2022-11-06 16:53:33.196	info	undefined is not a valid state value for id "mihome-cloud.0.238442715.status.status"
            mihome-cloud.0
            2022-11-06 16:53:33.190	warn	This object will not be created in future versions. Please report this to the developer.
            mihome-cloud.0
            2022-11-06 16:53:33.190	warn	Object mihome-cloud.0.238442715.status.status is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
            mihome-cloud.0
            2022-11-06 16:53:32.401	info	Found 1 remote events for yeelink.light.bslamp1
            mihome-cloud.0
            2022-11-06 16:53:32.401	info	Found 80 remote commands for yeelink.light.bslamp1
            mihome-cloud.0
            2022-11-06 16:53:30.604	info	Found plugin for yeelink.light.bslamp1
            mihome-cloud.0
            2022-11-06 16:53:30.604	info	Found 0 remote events for roborock.vacuum.s5
            mihome-cloud.0
            2022-11-06 16:53:30.593	info	Found 247 remote commands for roborock.vacuum.s5
            mihome-cloud.0
            2022-11-06 16:53:30.567	warn	Please report this url to the developer: https://cdn.alsgp0.fds.api.mi-img.com/rn-plugins/2020-12-08/signed_10047_1000570_39_IOS_bundle_e6776fdd671602f308b9be25d889bb0c.zip
            mihome-cloud.0
            2022-11-06 16:53:30.567	warn	Remote commmands too long for roborock.vacuum.s5
            mihome-cloud.0
            2022-11-06 16:53:26.974	info	Found plugin for roborock.vacuum.s5
            mihome-cloud.0
            2022-11-06 16:53:26.974	info	Found 0 remote events for deerma.humidifier.jsq
            mihome-cloud.0
            2022-11-06 16:53:26.973	info	Found 11 remote commands for deerma.humidifier.jsq
            mihome-cloud.0
            2022-11-06 16:53:25.843	info	Found plugin for deerma.humidifier.jsq
            mihome-cloud.0
            2022-11-06 16:53:25.723	info	Fetching Plugins
            mihome-cloud.0
            2022-11-06 16:53:25.722	info	prop.ct
            mihome-cloud.0
            2022-11-06 16:53:25.722	info	prop.bright
            mihome-cloud.0
            2022-11-06 16:53:25.722	info	prop.power
            mihome-cloud.0
            2022-11-06 16:53:25.722	info	Found yeelink.light.bslamp1 (Nachttischlampe) in configDes with 3 properties
            mihome-cloud.0
            2022-11-06 16:53:25.720	info	event.status
            mihome-cloud.0
            2022-11-06 16:53:25.719	info	Found roborock.vacuum.s5 (R2D2) in configDes with 1 properties
            mihome-cloud.0
            2022-11-06 16:53:25.715	info	Found 3 devices
            mihome-cloud.0
            2022-11-06 16:53:25.547	info	Get devices
            mihome-cloud.0
            2022-11-06 16:53:25.543	info	Login successful
            mihome-cloud.0
            2022-11-06 16:53:24.790	info	Login to MiHome Cloud
            mihome-cloud.0
            2022-11-06 16:53:24.756	info	starting. Version 0.0.1 (non-npm: TA2k/ioBroker.mihome-cloud#ed6074fea8ada7e315fc8c159664cd8edfaa7007) in /opt/iobroker/node_modules/iobroker.mihome-cloud, node: v16.18.1, js-controller: 4.0.23
            Carpe diem
              haselchenH
              haselchenH
              haselchen
              @hannnes
              Die Infos , die Du hast, gab es schon mit der 1.Version des Adapters.
              Sorry, dass ich dich da bremsen muss :)
              Ich denke, nun wird an den möglichen Einstellungen gefeilt, dass du das Teil auch steuern kannst.
              • haselchenH haselchen
                @hannnes
                @haselchen
                Achso, nee, Du musst mich nicht bremsen. Ich machen hier tatsächlich nur mit, um zu helfen. Ist mir völlig klar, dass das noch nicht von Anfang an geht. Ich frage nur, ob ich was nachsehen soll, was für Tom wichtig wäre. :-)
                  T
                  T
                  tombox
                  @hannnes Könntest du mir so ein fan mal via miHome app teilen, würde mich interessieren wie der in der app ausgelesen wird
                  tombox2020@gmail.com
                  • T tombox
                    @tombox
                    Ich versuche es später nochmal
                      @tombox
                      @tombox
                      Ok ein einzelnes Gerät konnte ich teilen. Das gesamte zuhause hat nicht geklappt. Siehst Du was?
                        @tombox
                        T
                        T
                        tombox
                        @hannnes Ja sehe das Gerät aber ich denke ich muss den Adapter nochmal umschreiben. Denn der Aufbau wie Geräte bei mihome eingebunden werden ist sehr schwierig
                        • T tombox
                          @tombox
                          Bin schon sehr gespannt.
                          Bekommt ioBroker ein Update automatisch mit, oder installiert man dann manuell „drüber“?
                            @tombox
                            T
                            T
                            tombox
                            @hannnes Wenn der Adapter beta wird bekommt der iobroker das mit. ansonsten nach Aufforderung manuell installieren
                            ? Thomas BraunT 2 Antworten Letzte Antwort
                            • T tombox
                              @tombox 👍
                              • T tombox
                                Hi ich habe ein neuen Adapter für MiHome erstellt der den Status der MiHome Geräte via Cloud herunterlädt.
                                mihome-cloud.0.xxx.general Allgemeine Information
                                mihome-cloud.0.xxx.status Aktueller Status
                                Zum Installieren:
                                https://github.com/TA2k/ioBroker.mihome-cloud
                                Unter Adapter Experten Modus aktivieren:
                                Unter Adapter das Github Icon klicken:
                                Benutzerdefiniert auswählen und die Url einfügen.
                                Dann unter Adapter den MiHome-cloud Adapter suchen und ganz rechts auf das Plus klicken.
                                Loginablauf:
                                Die MiHome Zugangsdaten eingeben
                                Steuerung*
                                Unter mihome-cloud.0.ID.remote Können Befehle gesendet entweder den State unbestätigt auf true setzen.
                                Wenn ein Befehl Input erwartet werden die im Namen aufgezählt und als default Wert werden die IDs aufgelistet.
                                Name und ID findet man unter status. Mögliche Werte findet man auf den Bleistift drückt und dann unter states.
                                Eingabewerte könnte z.b. ["10",0,1]
                                Szenen/Smart Szenario
                                Falls unter Remote keine Steuerung möglich ist können Szenen/Smart Szenario angelegt werden und diese können unter mihome-cloud.0.scenes ausgeführt werden
                                Bsp: Saugroboter Raumreinigung
                                mihome-cloud.0.id.remote.set-room-clean benötigt als Input
                                sweep set-room-clean 7-3 in[clean-room-ids,clean-room-mode,clean-room-oper] [24,25,26]
                                Potenziel findet man Room Ids unter:
                                mihome-cloud.0.id.remote.get-map-room-list
                                mihome-cloud.0.id.remote.get-preference-ii
                                beide benötigen
                                [clean-current-map] [33] als Input
                                mihome-cloud.0.id.status.clean-current-map sweep clean-current-map 7-33
                                ist leider null
                                Man kann alternativ
                                mihome-cloud.0.id.status.cur-map-id
                                nutzen oder
                                mihome-cloud.0.id.remote.get-map-list map get-map-list 10-1 out[map-list]
                                die Kartenliste abfragen und sieht das result unter unter mihome-cloud.0.id.status.map-list map map-list 10-4
                                Diese Id kann man dann setzen
                                mihome-cloud.0.id.remote.get-map-room-list map get-map-room-list 10-13 in[cur-map-id] out[room-id-name-list]
                                mihome-cloud.0.id.remote.get-preference-ii sweep get-preference-ii 7-10 in[clean-current-map] out[clean-preference,clean-prefer-on,clean-preference-ii,clean-prefer-on-ii]
                                Format: [1673811000]
                                Dann erhält man die Informationen unter:
                                mihome-cloud.0.id.status.room-id-name-list: [{"name":"room1","id":10}]
                                oder
                                mihome-cloud.0.id.status.clean-preference ["1_10_0_1_0_0_1","1_11_0_0_0_0_1","1_12_1_1_2_0_1","1_13_0_0_0_0_1"]
                                mihome-cloud.0.id.status.clean-prefer-on
                                mihome-cloud.0.id.status.clean-preference-ii
                                mihome-cloud.0.id.status.clean-prefer-on-ii
                                Mit den Informationen kann man dann
                                mihome-cloud.0.id.remote.start-room-sweep
                                Format ["10","11","12","13"]
                                oder
                                Format ["10",0,1]
                                B
                                B
                                bob der 1.
                                @tombox
                                Cooler Adapter,mein Dreame D9 wird auch erkannt.
                                • T tombox
                                  Thomas BraunT
                                  Thomas BraunT
                                  @tombox
                                  Gerade nochmal reingeschaut.
                                  Meine Kaffeemaschine kommt jetzt mit Datenpunkten ums Eck:
                                    @tombox
                                    B
                                    B
                                    bob der 1.
                                    Welche Maschiene ist das?
                                    • B bob der 1.
                                      Thomas BraunT
                                      Thomas BraunT
                                      @bob-der-1
                                      Ist die zweite Scishare Kaffeemaschine
                                        @tombox
                                        T
                                        T
                                        tombox
                                        @hannnes Ich habe eine neue Funktion integriert das Geräte via Spec versucht werden abzurufen und nicht nur via Plugin.
                                        Einfach alle Objekte von mihome-cloud löschen und dann neuinstallierten und schauen was unter status und remote kommt bzw ob man was via remote steuern kann
                                        Thomas BraunT ? 2 Antworten Letzte Antwort
                                        • T tombox
                                          Thomas BraunT
                                          Thomas BraunT
                                          @tombox
                                          Dafür sind jetzt meine Kaffeearten wieder futsch.
                                          Und viele Errors:
                                          2022-11-13 19:40:05.722  - error: mihome-cloud.0 (76460) TypeError: service.properties is not iterable
                                          2022-11-13 19:40:05.725  - error: mihome-cloud.0 (76460) TypeError: service.properties is not iterable
                                              at MihomeCloud.extractRemotesFromSpec (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:422:38)
                                              at async /opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:267:15
                                              at async MihomeCloud.getDeviceList (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:204:5)
                                              at async MihomeCloud.onReady (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:94:7)
                                          2022-11-13 19:40:07.897  - info: tuya.0 (1233) 012003832c3ae840bc99: Error on Reconnect: connection timed out
                                          2022-11-13 19:40:08.584  - error: mihome-cloud.0 (76460) /home/rpc/lumi.158d0002228321
                                          2022-11-13 19:40:08.585  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
                                              at MihomeCloud.parseResponse (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:859:19)
                                              at /opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:757:37
                                              at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                                              at async MihomeCloud.updateDevices (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:732:9)
                                              at async MihomeCloud.onReady (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:96:7)
                                          2022-11-13 19:40:10.275  - error: mihome-cloud.0 (76460) /home/rpc/lumi.158d0002791f32
                                          2022-11-13 19:40:10.275  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
                                          2022-11-13 19:40:10.276  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
                                          2022-11-13 19:40:11.602  - info: mihome-cloud.0 (76460) Error getting Status of the device via Plugin for Klima WZ (blt.3.rauh1qas4400) with {"id":0,"method":"nnerF","accessKey":"IOS00026747c5acafc2","params":[]}
                                          2022-11-13 19:40:11.602  - info: mihome-cloud.0 (76460) {"code":-1,"message":"bluetooth device does not support sending rpc"}
                                          2022-11-13 19:40:13.047  - error: mihome-cloud.0 (76460) /home/rpc/lumi.158d0001c0ff0a
                                          2022-11-13 19:40:13.048  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
                                          2022-11-13 19:40:14.767  - error: mihome-cloud.0 (76460) /home/rpc/lumi.158d000201afb5
                                          2022-11-13 19:40:14.768  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
                                          2022-11-13 19:40:16.460  - error: mihome-cloud.0 (76460) /home/rpc/lumi.158d000210a8ce
                                          2022-11-13 19:40:16.461  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
                                          2022-11-13 19:40:17.932  - error: mihome-cloud.0 (76460) /home/rpc/lumi.158d00021126f7
                                          2022-11-13 19:40:17.932  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
                                          2022-11-13 19:40:17.933  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
                                          2022-11-13 19:40:21.307  - error: mihome-cloud.0 (76460) /home/rpc/lumi.158d0001ad43b1
                                          2022-11-13 19:40:21.307  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
                                          2022-11-13 19:40:21.308  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
                                          2022-11-13 19:40:22.783  - error: mihome-cloud.0 (76460) /home/rpc/lumi.158d0001c1e912
                                          2022-11-13 19:40:22.784  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
                                          2022-11-13 19:40:22.785  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
                                          2022-11-13 19:40:24.465  - error: mihome-cloud.0 (76460) /home/rpc/lumi.158d0002150d0a
                                          2022-11-13 19:40:24.465  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
                                          2022-11-13 19:40:24.466  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
                                          2022-11-13 19:40:26.137  - error: mihome-cloud.0 (76460) /home/rpc/lumi.158d000289edfa
                                          2022-11-13 19:40:26.137  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
                                          2022-11-13 19:40:26.138  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
                                          2022-11-13 19:40:31.673  - error: mihome-cloud.0 (76460) /home/rpc/63722155
                                          2022-11-13 19:40:31.673  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
                                          2022-11-13 19:40:31.674  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
                                          2022-11-13 19:40:33.025  - info: mihome-cloud.0 (76460) Error getting Status of the device via Plugin for Klima SZ (blt.3.raujllfo4000) with {"id":0,"method":"nnerF","accessKey":"IOS00026747c5acafc2","params":[]}
                                          2022-11-13 19:40:33.025  - info: mihome-cloud.0 (76460) {"code":-1,"message":"bluetooth device does not support sending rpc"}
                                          2022-11-13 19:40:34.750  - error: mihome-cloud.0 (76460) /home/rpc/lumi.158d0001dbbcf1
                                          2022-11-13 19:40:34.751  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
                                          2022-11-13 19:40:34.752  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
                                          2022-11-13 19:40:36.253  - error: mihome-cloud.0 (76460) /home/rpc/lumi.158d000289ebbe
                                          2022-11-13 19:40:36.253  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
                                          2022-11-13 19:40:36.254  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
                                          2022-11-13 19:40:37.961  - error: mihome-cloud.0 (76460) /home/rpc/lumi.158d000289ebbe
                                          2022-11-13 19:40:37.962  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
                                          2022-11-13 19:40:39.626  - error: mihome-cloud.0 (76460) /home/rpc/78328901
                                          2022-11-13 19:40:39.626  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
                                          2022-11-13 19:40:39.627  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
                                          2022-11-13 19:40:41.397  - error: mihome-cloud.0 (76460) /home/rpc/90211825
                                          2022-11-13 19:40:41.398  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
                                          2022-11-13 19:40:41.399  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
                                          2022-11-13 19:40:43.109  - error: mihome-cloud.0 (76460) /home/rpc/lumi.158d0001bb4d1d
                                          2022-11-13 19:40:43.109  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
                                          2022-11-13 19:40:43.110  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
                                          2022-11-13 19:40:44.766  - error: mihome-cloud.0 (76460) /home/rpc/lumi.158d0001bb5435
                                          2022-11-13 19:40:44.766  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
                                          2022-11-13 19:40:44.767  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
                                          83.8k
