  4. iob diag - Skript
iob diag - Skript
863 Beiträge 52 Kommentatoren 307.5k Aufrufe 40 Beobachtet
  • NashraN Offline
    NashraN Offline
    Nashra
    Most Active Forum Testing
    #144
    Moin, aktuelles Skript, Proxmox lxc
    *** BASISSYSTEM ***
    CPU-Architektur: x86_64
    Docker: Nein
    LXC: lxc
    Distributor ID: Debian
    Description:    Debian GNU/Linux 10 (buster)
    Release:        10
    Codename:       buster
    PRETTY_NAME="Debian GNU/Linux 10 (buster)"
    NAME="Debian GNU/Linux"
    VERSION_ID="10"
    VERSION="10 (buster)"
    VERSION_CODENAME=buster
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime und Load:
     08:21:41 up 23:21,  1 user,  load average: 1.68, 1.37, 1.48
    CPU threads: 4
    *** Zeit und Zeitzonen ***
    Sun Nov  6 07:21:41 UTC 2022
    Sun Nov  6 08:21:41 CET 2022
    CET +0100
    Europe/Berlin
    *** User und Gruppen ***
    jack
    /home/jack
    jack sudo iobroker
    *** X-Server-Setup ***
    X-Server: Nein
    Desktop:
    Konsole:
    *** ARBEITSSPEICHER ***
    Mem:            10G        3.8G        5.3G        8.0M        1.0G        6.3G
    Swap:            0B          0B          0B
    Total:          10G        3.8G        5.3G
            10112 M total memory
             3808 M used memory
              310 M active memory
             4253 M inactive memory
             5297 M free memory
                0 M buffer memory
             1005 M swap cache
                0 M total swap
                0 M used swap
                0 M free swap
    *** DATEISYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--100--disk--1 ext4       21G  7.9G   12G  41% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
    tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
    tmpfs                            tmpfs     7.8G  8.1M  7.8G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    Daten in neuralgischen Verzeichnissen:
    /var:
    404M    /var/
    222M    /var/cache
    218M    /var/cache/apt
    178M    /var/lib
    157M    /var/cache/apt/archives
    /opt/iobroker/backups:
    1.1G    /opt/iobroker/backups/
    3.1M    /opt/iobroker/backups/scripte
    844K    /opt/iobroker/backups/scripte/Allerlei
    472K    /opt/iobroker/backups/scripte/Wetter
    440K    /opt/iobroker/backups/scripte/global
    /opt/iobroker/iobroker-data:
    1.7G    /opt/iobroker/iobroker-data/
    630M    /opt/iobroker/iobroker-data/files
    623M    /opt/iobroker/iobroker-data/backup-objects
    206M    /opt/iobroker/iobroker-data/files/vis.0
    90M     /opt/iobroker/iobroker-data/history
    Die 5 größten Dateien in iobroker-data:
    145M states.jsonl
     66M objects.jsonl
     28M objects.json.migrated
     28M objects.json.bak.migrated
     17M states.json.migrated
    *** Nodejs-Installation ***
    /usr/bin/nodejs         v16.18.0
    /usr/bin/node           v16.18.0
    /usr/bin/npm            8.19.2
    nodejs:
      Installed: 16.18.0-deb-1nodesource1
      Candidate: 16.18.1-deb-1nodesource1
      Version table:
         16.18.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x buster/main amd64 Packages
     *** 16.18.0-deb-1nodesource1 100
         10.24.0~dfsg-1~deb10u2 500
            500 http://security.debian.org buster/updates/main amd64 Packages
         10.24.0~dfsg-1~deb10u1 500
            500 http://ftp.debian.org/debian buster/main amd64 Packages
    *** ioBroker-Installation ***
    Versionsnummern der Kern-Adapter
    js-controller:  4.0.23
    Admin-Adapter:  6.2.23
    ioBroker-Repos und Updates
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    stable-live   : http://iobroker.live/repo/sources-dist.json
    latest-live   : http://iobroker.live/repo/sources-dist-latest.json
    Objekte und Zustände
    werden ermittelt - Dies kann einen Moment dauern.
    Objekte:        39924
    Zustände:       37014
    *** Repositories und OS-Updates ***
    Hit:1 http://security.debian.org buster/updates InRelease
    Hit:2 http://ftp.debian.org/debian buster InRelease
    Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
    Hit:4 http://ftp.debian.org/debian buster-updates InRelease
    Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian buster InRelease
    Reading package lists... Done
    Ausstehende Updates: 1
    *** Lauschende Ports ***
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          47286      315/master
    tcp        0      0 0.0.0.0:9999            0.0.0.0:*               LISTEN      1000       13031318   1000692/nc
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          46775      165/sshd
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          41781      1/init
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       46975      131/iobroker.js-con
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       47529      131/iobroker.js-con
    tcp6       0      0 :::8093                 :::*                    LISTEN      1001       80925      3151/io.rest-api.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       49243      330/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       69651      2247/io.web.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       64451      1833/io.socketio.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       63384      1747/io.simple-api.
    tcp6       0      0 :::3030                 :::*                    LISTEN      1001       72270      2352/io.radar-trap.
    tcp6       0      0 :::22                   :::*                    LISTEN      0          46777      165/sshd
    tcp6       0      0 :::111                  :::*                    LISTEN      0          41783      1/init
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          47287      315/master
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       53971      975/io.shelly.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       2742988    226480/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       2742989    226480/io.tuya.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          41782      1/init
    udp        0      0 0.0.0.0:57624           0.0.0.0:*                           1001       66125      1878/io.upnp.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       69164      1878/io.upnp.0
    udp        0      0 192.168.1.14:5353       0.0.0.0:*                           1001       53167      990/io.tr-064.0
    udp6       0      0 :::111                  :::*                                0          41784      1/init
    =================== ZUSAMMENFASSUNG ====================
    Betriebssystem:         Debian GNU/Linux 10 (buster)
    Installation:           lxc
    Zeitzone:               Europe/Berlin
    User-ID:                1000
    X-Server:               deaktiv
    Nodejs-Installation:    /usr/bin/nodejs         v16.18.0
                            /usr/bin/npm            8.19.2
    ioBroker Core:          js-controller           4.0.23
                                            admin:  6.2.23
    Objekte:                39924
    Zustände:               37014
    Größe der iob-Datenbanken:
     12K backup-objects
       0 objects.json.broken
     66M objects.jsonl
    4.0K objects.jsonl.lock
     17M states.json.bak.migrated
       0 states.json.broken
    148M states.jsonl
    4.0K states.jsonl.lock
    Gruß Ralf
    • E emil70
      @liv-in-sky sagte in iob diag - Skript:
      printf "\033c"
      Moin, Auf docker funktioniert es.
      Frage mich nur, wie man sich dann den ersten Teil ansehen will. Hochscrollen geht da nicht
      #145
      @emil70 sagte in iob diag - Skript:
      Bevor man auf die Zusammenfassung geht kann man scrollen.
      E 1 Antwort Letzte Antwort
        E Online
        E Online
        emil70
        #146
        @thomas-braun sagte in iob diag - Skript:
        Das ist mir klar.
        Hatte im script
        printf "\033c"
        mit eingebaut und
        read -p "Zur Zusammenfassung drücke die Enter-Taste";
        deaktiviert
        gruss emil70
        iobroker,pihole,homematic,motioneys,solaranlage laufen auf Proxmox (16 x AMD Ryzen 7 6800H with Radeon Graphics )
        • E emil70
          Das ist mir klar.
          Hatte im script
          printf "\033c"
          mit eingebaut und
          deaktiviert
          #147
          @emil70
          Ah, Missverständnis bei mir.
            @emil70
            E Online
            E Online
            emil70
            schrieb am zuletzt editiert von emil70
            #148
            Die Fehlermeldung
            ./iob_diag: line 47: systemd-detect-virt: command not found
            LXC:
            ./iob_diag: line 48: systemd-detect-virt: command not found
            Habe ich jetzt 2 x unter docker durch
            echo -e "LXC: `systemd-detect-virt`"
            SYSTDDVIRT=$(systemd-detect-virt)
            da muss doch eine
            if Abfrage auch geht
            so vielleicht oder ähnlich
            SYSTDDVIRT=systemd-detect-virt
            if [ -f "$SYSTDDVIRT" ]; then
                echo "LXC: Ja"
            else
                echo "LXC: Nein"
            fi;
            gruss emil70
            • E emil70
              Die Fehlermeldung
              LXC:
              da muss doch eine
                  echo "LXC: Ja"
              else
                  echo "LXC: Nein"
              fi;
              #149
              @emil70
              Schau jetzt nochmal wie dein LXC erkannt wird.
              M E 2 Antworten Letzte Antwort
                @emil70
                M Online
                M Online
                MCU
                #150
                @thomas-braun X-Server Info ist doch Windows, oder? Sollte es dann auch dort stehen?
                • M MCU
                  #151
                  @mcu sagte in iob diag - Skript:
                  Nein, der X-Server ist die Server-Umgebung für eine graphische Oberfläche unter Linux.
                  • OstfrieseUnterwegsO Offline
                    OstfrieseUnterwegs
                    #152
                    Hilfreiches Script!
                    Bei der Zusammenfassung fehlen noch die Steuerzeichen für die Code-Tags.
                    • OstfrieseUnterwegsO OstfrieseUnterwegs
                      Hilfreiches Script!
                      #153
                      @ostfrieseunterwegs
                      Sind jetzt drin.
                        @ostfrieseunterwegs
                        Sind jetzt drin.
                        NegaleinN Offline
                        NegaleinN Offline
                        Negalein
                        #154
                        Jetzt hab ich mal die komplette ausgabe hier.
                        Was sagt das so vom System (abgesehen von den Updates)? Gut, schlecht?
                        *** BASISSYSTEM ***
                        Docker: Nein
                        LXC: lxc
                        Distributor ID: Ubuntu
                        Description:    Ubuntu 20.04.4 LTS
                        Release:        20.04
                        Codename:       focal
                        NAME="Ubuntu"
                        VERSION="20.04.4 LTS (Focal Fossa)"
                        ID=ubuntu
                        ID_LIKE=debian
                        PRETTY_NAME="Ubuntu 20.04.4 LTS"
                        VERSION_ID="20.04"
                        HOME_URL="https://www.ubuntu.com/"
                        SUPPORT_URL="https://help.ubuntu.com/"
                        BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
                        PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
                        VERSION_CODENAME=focal
                        UBUNTU_CODENAME=focal
                         15:06:25 up 59 days,  3:24,  1 user,  load average: 2.02, 2.04, 1.94
                        CPU threads: 4
                        Sun Nov  6 14:06:25 UTC 2022
                        Sun Nov  6 15:06:25 CET 2022
                        CET +0100
                        Europe/Vienna
                        nega
                        /home/nega
                        nega adm dialout sudo users iobroker
                        X-Server: Nein
                        Desktop:
                        Konsole: tty
                        Mem:           6.1G        4.8G        918M        0.0K        474M        1.4G
                        Swap:          2.0G        1.7G        303M
                        Total:         8.2G        6.5G        1.2G
                                 6144 M total memory
                                 4751 M used memory
                                 3807 M active memory
                                 1044 M inactive memory
                                  918 M free memory
                                    0 M buffer memory
                                  474 M swap cache
                                 2048 M total swap
                                 1744 M used swap
                                  303 M free swap
                        *** DATEISYSTEM ***
                        /dev/mapper/pve-vm--100--disk--0 ext4       20G   14G  5.1G  73% /
                        10.0.1.21:/volume1/Backups       nfs4       14T  7.6T  6.5T  54% /opt/iobroker/backups
                        tmpfs                            tmpfs     1.6G  132K  1.6G   1% /run
                        tmpfs                            tmpfs     1.6G     0  1.6G   0% /run/user/1001
                        /var:
                        [sudo] password for nega:
                        2.5G    /var/
                        2.0G    /var/log/journal/b354c482f7cc342776f020ee5ea440c3
                        2.0G    /var/log
                        294M    /var/lib
                        3.3G    /opt/iobroker/backups/
                        4.0G    /opt/iobroker/iobroker-data/
                        2.5G    /opt/iobroker/iobroker-data/history
                        1014M   /opt/iobroker/iobroker-data/files
                        341M    /opt/iobroker/iobroker-data/files/vis.0
                        316M    /opt/iobroker/iobroker-data/backup-objects
                        126M states.jsonl
                         43M objects.jsonl
                         29M objects.json.migrated
                         29M objects.json.bak.migrated
                        9.4M states.json.migrated
                        /usr/bin/nodejs         v16.15.1
                        /usr/bin/node           v16.15.1
                        /usr/bin/npm            8.11.0
                        nodejs:
                          Installed: 16.15.1-deb-1nodesource1
                          Version table:
                                500 https://deb.nodesource.com/node_16.x focal/main amd64 Packages
                         *** 16.15.1-deb-1nodesource1 100
                             10.19.0~dfsg-3ubuntu1 500
                                500 http://archive.ubuntu.com/ubuntu focal/universe amd64 Packages
                        Active repo(s): Beta (latest)
                        Used repository: Beta (latest)
                        Adapter    "vis-materialdesign": 0.5.9, installed 0.5.5 [Updatable]
                        Objekte:        44024
                        Zustände:       40453
                        Hit:1 https://deb.nodesource.com/node_16.x focal InRelease
                        Hit:2 http://archive.ubuntu.com/ubuntu focal InRelease
                        Hit:3 http://archive.ubuntu.com/ubuntu focal-updates InRelease
                        Hit:4 http://archive.ubuntu.com/ubuntu focal-security InRelease
                        Hit:5 https://packagecloud.io/ookla/speedtest-cli/ubuntu focal InRelease
                        Ausstehende Updates: 160
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          33162      144/sshd: /usr/sbin
                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          31745      1/init
                        tcp        0      0 0.0.0.0:49541           0.0.0.0:*               LISTEN      1000       44973986   199443/wput
                        tcp        0      0 0.0.0.0:33179           0.0.0.0:*               LISTEN      1000       44724275   198404/wput
                        tcp        0      0 0.0.0.0:41371           0.0.0.0:*               LISTEN      1000       43004499   191228/wput
                        tcp        0      0 0.0.0.0:33251           0.0.0.0:*               LISTEN      1000       44643010   198128/wput
                        tcp        0      0 0.0.0.0:8701            0.0.0.0:*               LISTEN      1000       40089      770/io.hm-rpc.2
                        tcp        0      0 0.0.0.0:57615           0.0.0.0:*               LISTEN      1000       43167669   192281/wput
                        tcp        0      0 0.0.0.0:49771           0.0.0.0:*               LISTEN      1000       44518133   197607/wput
                        tcp        0      0 0.0.0.0:50049           0.0.0.0:*               LISTEN      1000       44392437   197031/wput
                        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       32287      120/iobroker.js-con
                        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       34067      120/iobroker.js-con
                        tcp        0      0 0.0.0.0:34003           0.0.0.0:*               LISTEN      1000       43824216   194549/wput
                        tcp        0      0 0.0.0.0:50219           0.0.0.0:*               LISTEN      1000       43682667   193926/wput
                        tcp        0      0 0.0.0.0:50595           0.0.0.0:*               LISTEN      1000       44224282   196358/wput
                        tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1001       459018472  2020380/sshd: nega@
                        tcp        0      0 0.0.0.0:34351           0.0.0.0:*               LISTEN      1000       44100092   195644/wput
                        tcp        0      0 0.0.0.0:2001            0.0.0.0:*               LISTEN      1000       264468026  1162298/io.hm-rpc.1
                        tcp        0      0 0.0.0.0:2010            0.0.0.0:*               LISTEN      1000       264468032  1162305/io.hm-rpc.0
                        tcp        0      0 0.0.0.0:59225           0.0.0.0:*               LISTEN      1000       43961951   195082/wput
                        tcp        0      0 127.0.0.1:39533         0.0.0.0:*               LISTEN      1000       75833      2444/chrome
                        tcp        0      0 0.0.0.0:43455           0.0.0.0:*               LISTEN      1000       43006388   191447/wput
                        tcp        0      0 0.0.0.0:35221           0.0.0.0:*               LISTEN      1000       43003855   191402/wput
                        tcp        0      0 0.0.0.0:35075           0.0.0.0:*               LISTEN      1000       44974560   199032/wput
                        tcp        0      0 0.0.0.0:51879           0.0.0.0:*               LISTEN      1000       44972794   199121/wput
                        tcp        0      0 0.0.0.0:43891           0.0.0.0:*               LISTEN      1000       44271852   196521/wput
                        tcp        0      0 0.0.0.0:60251           0.0.0.0:*               LISTEN      1000       44627799   198053/wput
                        tcp        0      0 0.0.0.0:52405           0.0.0.0:*               LISTEN      1000       44054142   195482/wput
                        tcp        0      0 10.0.1.202:8100         0.0.0.0:*               LISTEN      1000       51625      1182/io.doorbird.0
                        tcp        0      0 0.0.0.0:44075           0.0.0.0:*               LISTEN      1000       43358491   192556/wput
                        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        31365      100/systemd-resolve
                        tcp        0      0 0.0.0.0:52609           0.0.0.0:*               LISTEN      1000       44238554   196384/wput
                        tcp        0      0 0.0.0.0:37085           0.0.0.0:*               LISTEN      1000       43005160   191286/wput
                        tcp        0      0 0.0.0.0:45139           0.0.0.0:*               LISTEN      1000       44485383   197472/wput
                        tcp        0      0 0.0.0.0:37335           0.0.0.0:*               LISTEN      1000       43106212   192002/wput
                        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          33238      296/master
                        tcp        0      0 0.0.0.0:53881           0.0.0.0:*               LISTEN      1000       43093131   191976/wput
                        tcp        0      0 0.0.0.0:46065           0.0.0.0:*               LISTEN      1000       45025654   199681/wput
                        tcp        0      0 0.0.0.0:54035           0.0.0.0:*               LISTEN      1000       44970604   199166/wput
                        tcp        0      0 0.0.0.0:54677           0.0.0.0:*               LISTEN      1000       43004848   191522/wput
                        tcp        0      0 0.0.0.0:55605           0.0.0.0:*               LISTEN      1000       44348045   196856/wput
                        tcp        0      0 0.0.0.0:55641           0.0.0.0:*               LISTEN      1000       44972791   199371/wput
                        tcp        0      0 0.0.0.0:55973           0.0.0.0:*               LISTEN      1000       44365268   196933/wput
                        tcp        0      0 0.0.0.0:39571           0.0.0.0:*               LISTEN      1000       43340786   192452/wput
                        tcp        0      0 0.0.0.0:55901           0.0.0.0:*               LISTEN      1000       44975404   199328/wput
                        tcp        0      0 0.0.0.0:39817           0.0.0.0:*               LISTEN      1000       43777455   194268/wput
                        tcp        0      0 0.0.0.0:47885           0.0.0.0:*               LISTEN      1000       44286400   196625/wput
                        tcp        0      0 0.0.0.0:47903           0.0.0.0:*               LISTEN      1000       44301836   196685/wput
                        tcp        0      0 0.0.0.0:56143           0.0.0.0:*               LISTEN      1000       43005597   191328/wput
                        tcp        0      0 0.0.0.0:40105           0.0.0.0:*               LISTEN      1000       43154688   192203/wput
                        tcp        0      0 0.0.0.0:56613           0.0.0.0:*               LISTEN      1000       44207006   196223/wput
                        tcp        0      0 0.0.0.0:40239           0.0.0.0:*               LISTEN      1000       44675322   198247/wput
                        tcp        0      0 0.0.0.0:40943           0.0.0.0:*               LISTEN      1000       44972788   199269/wput
                        tcp        0      0 0.0.0.0:57187           0.0.0.0:*               LISTEN      1000       44533340   197681/wput
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          33164      144/sshd: /usr/sbin
                        tcp6       0      0 :::111                  :::*                    LISTEN      0          31747      1/init
                        tcp6       0      0 ::1:6010                :::*                    LISTEN      1001       459018471  2020380/sshd: nega@
                        tcp6       0      0 :::61991                :::*                    LISTEN      1000       31264400   140098/io.harmony.1
                        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          33239      296/master
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       256495404  1127044/io.web.0
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       279040541  1226006/io.admin.0
                        tcp6       0      0 :::8087                 :::*                    LISTEN      1000       241264278  1059609/io.simple-a
                        tcp6       0      0 :::8084                 :::*                    LISTEN      1000       64858      2100/io.socketio.0
                        tcp6       0      0 :::8093                 :::*                    LISTEN      1000       66370      2381/io.rest-api.0
                        udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1000       439148881  848/io.mihome.0
                        udp        0      0 0.0.0.0:59620           0.0.0.0:*                           1000       318977549  1401696/io.snmp.0
                        udp        0      0 0.0.0.0:59889           0.0.0.0:*                           1000       318977550  1401696/io.snmp.0
                        udp        0      0 0.0.0.0:44504           0.0.0.0:*                           1000       458560000  1877717/io.xbox.0
                        udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       31264401   140098/io.harmony.1
                        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       352740191  1551038/io.shelly.0
                        udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        31364      100/systemd-resolve
                        udp        0      0 10.0.1.202:68           0.0.0.0:*                           105        457919803  95/systemd-networkd
                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          31746      1/init
                        udp6       0      0 :::111                  :::*                                0          31748      1/init
                        Betriebssystem:         Ubuntu 20.04.4 LTS
                        Installation:           lxc
                        Zeitzone:               Europe/Vienna
                        User-ID:                1001
                        X-Server:               deaktiv
                        Nodejs-Installation:    /usr/bin/nodejs         v16.15.1
                                                /usr/bin/npm            8.11.0
        admin:  6.2.23
                        Objekte:                44024
                        Zustände:               40453
                         12K backup-objects
                         43M objects.jsonl
                        9.4M states.json.bak.migrated
                        128M states.jsonl
                        ° Fixer ---> iob fix
                        • NegaleinN Negalein
                          *** BASISSYSTEM ***
                          Docker: Nein
                          LXC: lxc
                          Release:        20.04
                          Codename:       focal
                          NAME="Ubuntu"
                          ID=ubuntu
                          ID_LIKE=debian
                          VERSION_ID="20.04"
                          CPU threads: 4
                          CET +0100
                          Europe/Vienna
                          nega
                          /home/nega
                          X-Server: Nein
                          Desktop:
                          Konsole: tty
                                   6144 M total memory
                                   4751 M used memory
                                    918 M free memory
                                      0 M buffer memory
                                    474 M swap cache
                                   2048 M total swap
                                   1744 M used swap
                                    303 M free swap
                          *** DATEISYSTEM ***
                          /var:
                          2.5G    /var/
                          2.0G    /var/log
                          294M    /var/lib
                          126M states.jsonl
                           43M objects.jsonl
                          /usr/bin/npm            8.11.0
                          nodejs:
                            Version table:
                          Objekte:        44024
                          Zustände:       40453
                          Installation:           lxc
                          User-ID:                1001
                          X-Server:               deaktiv
                                                  /usr/bin/npm            8.11.0
        admin:  6.2.23
                          Objekte:                44024
                          Zustände:               40453
                           12K backup-objects
                           43M objects.jsonl
                          128M states.jsonl
                          #155
                          @negalein sagte in iob diag - Skript:
                          Da musst du DRINGEND ran. Je mehr das wird, umso komplexer wird ein Update. Und 160 ist schon echt viel.
                          HomoranH NegaleinN 3 Antworten Letzte Antwort
                            #156
                            @thomas-braun ich war nochmal kurz auf der Eisbahn.
                            bei updates der Pakete steht nix
                            OK:2 http://deb.debian.org/debian bullseye-updates InRelease
                            OK:3 http://security.debian.org/debian-security bullseye-security InRelease
                            OK:4 https://deb.nodesource.com/node_14.x bullseye InRelease
                            Aktive Internetverbindungen (Nur Server)
                            Proto Recv-Q Send-Q Local Address           Foreign Address         State       Benutzer   Inode      PID/Program name
                            ist aber falsch
                            i@iobroker-VM03:~$ sudo apt update        OK:1 http://security.debian.org/debian-security bullseye-security InRelease
                            OK:2 http://deb.debian.org/debian bullseye InRelease                                                      OK:3 http://deb.debian.org/debian bullseye-updates InRelease
                            Aktualisierung für 74 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                            pi@iobroker-VM03:~$
                            hab jetzt nix gemacht, damit ich noch testen kann!
                              ist aber falsch
                              pi@iobroker-VM03:~$
                              #157
                              Führ mal
                              Bitte
                              sudo apt-get update
                              apt-get upgrade -s
                              aus.
                                Führ mal
                                Bitte
                                sudo apt-get update
                                apt-get upgrade -s
                                aus.
                                #158
                                Führ mal
                                Bitte
                                sudo apt-get upgrade
                                apt-get upgrade -s
                                aus.
                                ehrlich?
                                danach geht nix mehr zu testen
                                upgrade? nicht update?
                                  Führ mal
                                  Bitte
                                  apt-get upgrade -s
                                  aus.
                                  ehrlich?
                                  #159
                                  @homoran sagte in iob diag - Skript:
                                  Doch, das upgrade wird nur simuliert, nicht geschrieben.
                                  Ich seh aber schon, wo es da klemmt.
                                  HomoranH OstfrieseUnterwegsO 2 Antworten Letzte Antwort
                                    #160
                                    doch! bereits bei der erstrn Zeile, oder?
                                      OstfrieseUnterwegs
                                      #161
                                      @thomas-braun muss das nicht
                                      sudo apt-get upgrade -s
                                      sein?
                                        #162
                                        Hast recht.
                                        Muss
                                        sudo apt-get update
                                        apt-get upgrade -s
                                        lauten.
                                          sein?
                                          #163
                                          @ostfrieseunterwegs
                                          Nein, wir wollen da nicht mit root-Rechten agieren.
                                          Immer nur so scharfes Werkzeug wie gerade notwendig verwenden...
                                          OstfrieseUnterwegsO 1 Antwort Letzte Antwort
