  4. Wasserzähler - Version 2 - all-in-device
wasserzählerversion 2ai on the edgecnnwater meterwater gaugeesp32ov2640neuronale netzehausautomatisierung
3.4k Beiträge 240 Kommentatoren 2.4m Aufrufe 231 Beobachtet
  • N Offline
    N Offline
    nhet
    schrieb am zuletzt editiert von nhet
    #2435
    Moinsen, gibt es logische Erklärungen warum die folgende Werte nicht korrekt erkannt wurden?
    Hier ist meine Config:
    [MakeImage]
    ;LogImageLocation = /log/source
    WaitBeforeTakingPicture = 5
    ;LogfileRetentionInDays = 15
    Brightness = 0
    Contrast = 0
    Saturation = 0
    LEDIntensity = 10
    ImageQuality = 12
    ImageSize = VGA
    FixedExposure = false
    [Alignment]
    InitialRotate = -2
    InitialMirror = false
    SearchFieldX = 20
    SearchFieldY = 20
    AlignmentAlgo = default
    FlipImageSize = false
    /config/ref0.jpg 139 369
    /config/ref1.jpg 549 253
    [Digits]
    Model = /config/dig-s1d-md-v1.0-q.tflite
    ;CNNGoodThreshold =
    ;LogImageLocation = /log/digit
    ;LogfileRetentionInDays = 3
    strom.1000 229 32 50 85 0
    strom.100 273 32 50 85 0
    strom.10 313 32 50 85 0
    strom.1 351 32 50 85 0
    strom.01 397 32 50 85 0
    ;[Analog]
    Model = /config/ana1000s2.tflite
    ;LogImageLocation = /log/analog
    [PostProcessing]
    strom.DecimalShift = -1
    PreValueUse = true
    PreValueAgeStartup = 720
    AllowNegativeRates = false
    strom.MaxRateValue = 1
    strom.MaxRateType = AbsoluteChange
    strom.ExtendedResolution = true
    strom.IgnoreLeadingNaN = true
    ErrorMessage = true
    CheckDigitIncreaseConsistency = false
    [MQTT]
    Uri = mqtt://192.168.0. Xyz:1883
    MainTopic = stromzaehler
    ClientID = strom
    user = iob
    password =
    SetRetainFlag = false
    ;[InfluxDB]
    ;Uri =
    ;Database =
    ;Measurement =
    ;user =
    ;password =
    ;[GPIO]
    ;IO0 = input disabled 10 false false
    ;IO1 = input disabled 10 false false
    ;IO3 = input disabled 10 false false
    ;IO4 = built-in-led disabled 10 false false
    ;IO12 = input-pullup disabled 10 false false
    ;IO13 = input-pullup disabled 10 false false
    LEDType = WS2812
    LEDNumbers = 2
    LEDColor = 150 150 150
    [AutoTimer]
    AutoStart = true
    Intervall = 10
    [Debug]
    Logfile = false
    [System]
    ;TimeZone = CET-1CEST,M3.5.0,M10.5.0/3
    ;TimeServer = undefined
    ;AutoAdjustSummertime = false
    ;Hostname = undefined
    SetupMode = false
    ESP8266E 1 Antwort Letzte Antwort
    • J jomjol
      @esp8266 sagte in Wasserzähler - Version 2 - all-in-device:
      @chrisxy sagte in Wasserzähler - Version 2 - all-in-device:
      Mein Wasserzähler zeigt auch ein Wasserrohrbruch usw. an als Symbol. Bekommt man das irgendwie ausgewertet?
      Vielleicht mit einem anderen OCR? Kann ich das Bild vom ESP doppelt abgreifen?
      Der ESP32 Ist jetzt schon an seine Grenzen. Wie soll er dann noch ein 2. Bild auswerten?
      Muss ich leider so bestätigen. Zusätzliche Informationen sind mit verbliebenden 3% ROM und knappem Speicher nur sehr aufwendig möglich.
      ChrisXY
      #2436
      @jomjol okay schade. Kann man das Foto den als Link abrufen irgendwie ? Dann würde ich es vielleicht anders wo "Auswerten"
      J C 2 Antworten Letzte Antwort
      • C ChrisXY
        jomjol
        #2437
        @chrisxy
        http://IP-ADRESS/img_tmp/raw.jpg
        C 1 Antwort Letzte Antwort
        • N nhet
          [MakeImage]
          Brightness = 0
          Contrast = 0
          Saturation = 0
          LEDIntensity = 10
          ImageQuality = 12
          ImageSize = VGA
          [Alignment]
          InitialRotate = -2
          SearchFieldX = 20
          SearchFieldY = 20
          [Digits]
          ;CNNGoodThreshold =
          ;[Analog]
          [PostProcessing]
          PreValueUse = true
          ErrorMessage = true
          [MQTT]
          ClientID = strom
          user = iob
          password =
          ;[InfluxDB]
          ;Uri =
          ;Database =
          ;Measurement =
          ;user =
          ;password =
          ;[GPIO]
          LEDType = WS2812
          LEDNumbers = 2
          [AutoTimer]
          AutoStart = true
          Intervall = 10
          [Debug]
          Logfile = false
          [System]
          SetupMode = false
          ESP8266E Offline
          ESP8266E Offline
          ESP8266
          schrieb am zuletzt editiert von ESP8266
          #2438
          @nhet , ja die Reflexion auf der 2. Die beiden davor werden auch mal Probleme machen. Zu dem sind die Umrahmungen nicht wie in der Wiki beschrieben. Deine Cam scheint auch schräg von der Seite zu fotografieren, dadurch gibt es zusätzliche Verfälschungen.
          Auch wenn es sich hier um eine Wasseruhr handelt, sollten die Rahmen exakt ausgerichtet sein:
          und jeder Rahmen hat die gleiche Größe und y Position.
          btw...Wo lassen sie sich die RSSI und die Temp Werte aktivieren?
          N 1 Antwort Letzte Antwort
          • ESP8266E ESP8266
            N Offline
            N Offline
            nhet
            #2439
            @esp8266
            Ich hab's jetzt versucht den ESP besser auszurichten und die Felder neu einzustellen.
            Hier sind mal die Werte. Die Felder sind alle gleich groß und liegen alle auf demselben Y Punkt.
            strom.1000 336 48 39 67 0
            strom.100 378 48 39 67 0
            strom.10 417 48 39 67 0
            strom.1 459 48 39 67 0
            strom.01 510 48 39 67 0
            • ESP8266E Offline
              ESP8266E Offline
              ESP8266
              #2440
              @nhet , aber das innere Feld umschließt nicht die Zahlen. Jetzt sieht alles einigermaßen gerade aus.
              Deine Spiegelungen sind an Ziffer 2 , 3 und 4 noch immer vorhanden. Sie haben einen weißen Unterstrich.
              Du hast noch nicht meine Frage beantwortet.
              • ESP8266E ESP8266
                N Offline
                N Offline
                nhet
                #2441
                @esp8266 Das mit den Spiegelungen muss ich noch mal versuchen zu eliminieren. Geht vermutlich aber nur mit zusätzlichen LEDs?
                Du meinst mit Frage, die Frage nach dem RSSI und CPU-Temp Wert? Das kann ich dir leider nicht beantworten die Werte waren plötzlich da. Ich hatte gestern mal einige Updates von 11.1.1 bis nach 12.0.3 gemacht. Dabei hab ich jedes Release schön nach einander mit Firmware und html geflasht.
                • N nhet
                  ESP8266E Offline
                  ESP8266E Offline
                  ESP8266
                  #2442
                  @nhet , ok danke, ich habe noch nicht aktualisiert. Werde ich morgen machen. So wie ich das in deiner Config gelesen habe, nutzt du doch schon externe LED´s. Da würde ich mit der Position spielen. Die hatte ich auch und musste in der Röhre das LED Band runter schieben. Damit ging es.
                  • ESP8266E ESP8266
                    N Offline
                    N Offline
                    nhet
                    #2443
                    @esp8266 Nein, ich nutze aktuell die auf dem ESP fest verbaute LED
                    • N nhet
                      ESP8266E Offline
                      ESP8266E Offline
                      ESP8266
                      #2444
                      @nhet , nicht richtig hin geguckt. Dann versuche es mit ext. LED's.
                      • ? Offline
                        #2445
                        Hallo zusammen.
                        Ich habe gelegentlich das Problem, dass der PreValue größer als der RawValue ist. In der Config sind negative Werte sind nicht erlaubt, somit bekomme ich auch eine Fehlermeldung. Soweit ok.
                        Den PreValue kann ich nur über die Weboberfläche ändern. Gibt es eine Möglichkeit den PreValue über mqtt oder api zu setzen? In einem Fehlerfall könnte ich dass dann über ein Skript lösen.
                          Hallo zusammen.
                          ESP8266E Offline
                          ESP8266E Offline
                          ESP8266
                          #2446
                          @achbz , wäre für mich auch intressant. Dazu müsste der Datenpunkt "Prevalue" zur Verfügung gestellt werden. Ein 2. Datenpunkt für die Neueingabe.
                          @jomjol ginge das? Wäre Nett wenn du das in den Code mit einbringen würdest.
                          Da drüber habe ich mir schon mal Gedanken gemacht und doch vergessen.
                          • ESP8266E ESP8266
                            jomjol
                            #2447
                            Über API geht:
                            /setPreValue?value=VALUE&numbers=NUMBERNAME
                            • J jomjol
                              Über API geht:
                              #2448
                              Über API geht:
                              Hallo @jomjol, danke für den Hinweis.
                              Ich musste allerdings den Befehl erweitern um ein ".html", da ich sonst immer die Meldung "Failed to read existing file" erhalten habe.
                              Also /setPreValue.html?value=xxxx&numbers=main
                                Über API geht:
                                jomjol
                                #2449
                                @achbz Kann gut sein - in den neuen Versionen versuchen wir das html wieder abzuschaffen
                                • ESP8266E Offline
                                  ESP8266E Offline
                                  ESP8266
                                  #2450
                                  @jomjol sagte in Wasserzähler - Version 2 - all-in-device
                                  Über API geht:
                                  Eine bitte an dich, wenn es möglich ist.
                                  Bei mir, was ich vorhabe funktioniert das nicht und das wäre mit einem Datenpunkt der Schreibbar ist besser zu lösen. Ein zweiter wäre Luxus, aber nicht schlecht. Also wie beim value oder raw zusätzlich den pre. Das wäre zur Kontrolle im IOB besser.
                                  Ich möchte mit einem Script bei einem error aus dem Raw Wert den Prevalue setzen und das Automatisch. Ich wüsste jetzt nicht , wie ich das via API und Blocky zusammen fummeln könnte. Mein Java-Script Kenntnisse reichen dafür nicht aus.
                                  Ich hoffe dass ich mich verständlich genug ausgedrückt habe. Sonst Sorry....
                                  • ESP8266E ESP8266
                                    Über API geht:
                                    jomjol
                                    #2451
                                    @esp8266 Ist verständlich, aber die Firmware ist komplet auf Senden ausgerichtet und empfängt keine Datenpunkte. Dass will ich jetzt für den einen Spezialfall nicht einbauen.
                                    Du musst eigentlich nur eine URL mit dem o.g. Format ansurfen. Müsste eigentlich mit jeder Umgebung auch mit Blockly einfach gehen.
                                    • J jomjol
                                      @chrisxy
                                      ChrisXY
                                      #2452
                                      @jomjol Danke ;) Damit kann ich dann ja schon arbeiten. Nen tipp für ne "relativ" einfache OCR Software ? Hab schon überlegt über meine Kamera Sofware Blueiris zu gehen " Alarm" wenn Gegenstand weg/da ... aber da wird es ja sicher was besseres für geben.
                                      • David G.D Online
                                        David G.D Online
                                        David G.
                                        #2453
                                        ich habe nun auch so weit alles fertig für meinen Wasserzähler.
                                        Die Konstruktion habe ich schonmal aufgebaut und getestet.
                                        Allerdings wackelt alles etwas, der Zähler (bzw die relevanten Bereiche) sind aber immer komplett zu erkennen.
                                        Ist das tragisch?
                                        Ich vermute um das zu kompensieren werden wenn ich die Bereiche mit den Zahlen erstelle noch die roten Felder gesetzt?
                                        EDIT
                                        Kann es sein, dass die Einstellungen für die LED keinen Effekt haben?
                                        Jens MeyerJ 1 Antwort Letzte Antwort
                                        • David G.D David G.
                                          Ist das tragisch?
                                          EDIT
                                          Jens MeyerJ Offline
                                          Jens MeyerJ Offline
                                          Jens Meyer
                                          #2454
                                          @david-g
                                          Wackeln ist nicht gut u d du musst dann schon erstmal das komplette Setup durchlaufen
