  5. Daten aus URL in blocky
45 Beiträge 3 Kommentatoren 8.7k Aufrufe 1 Beobachtet
  • ingranuI ingranu
    Hallo zusammen
    Ich brauche mal Unterstützung in einem Bereich bei dem ich mich garnicht auskenne.
    Um eine Automation zu erstellen muss ich aus einer URL den Status eines Geräte abfragen.
    Die Datei sieht wie folgt aus:
    {XC_SUC}[{"type":"FS20","adr":"443525","state":"00:8E"},{"type":"FS20","adr":"2b063b","state":"FF:FF"},{"type":"EVENT","adr":"02","state":"1"},{"type":"FS20","adr":"8d3700","state":"FF:FF"},{"type":"FS20","adr":"aaf900","state":"FF:FF"},{"type":"FS20","adr":"20d600","state":"FF:FF"},{"type":"EVENT","adr":"03","state":"1"},{"type":"FS20","adr":"903702","state":"FF:FF"},{"type":"FS20","adr":"1c291e","state":"FF:FF"},{"type":"FS20","adr":"8d3702","state":"FF:FF"},{"type":"FS20","adr":"0b3212","state":"FF:FF"},{"type":"FS20","adr":"ffffa9","state":"FF:FF"},{"type":"FS20","adr":"015301","state":"FF:FF"},{"type":"FS20","adr":"231a42","state":"FF:FF"},{"type":"ELRO","adr":"123409","state":"FF:FF"},{"type":"FS20","adr":"ffff01","state":"FF:FF"},{"type":"IT","adr":"aa3c0080","state":"FF:FF"},{"type":"FS20","adr":"271b20","state":"FF:FF"},{"type":"FS20","adr":"800001","state":"FF:FF"},{"type":"ELRO","adr":"000550","state":"FF:FF"},{"type":"IT","adr":"518b1180","state":"FF:FF"},{"type":"IT","adr":"010","state":"FF:FF"},{"type":"ELRO","adr":"100550","state":"00:FF"},{"type":"IT","adr":"1db90080","state":"FF:FF"},{"type":"IT","adr":"b3930080","state":"FF:FF"},{"type":"IT","adr":"2e340080","state":"06:8E"},{"type":"IT","adr":"a5430080","state":"FF:FF"},{"type":"IT","adr":"7f450080","state":"FF:FF"},{"type":"IT","adr":"44240080","state":"06:00"},{"type":"FS20","adr":"1a0132","state":"FF:FF"},{"type":"IT","adr":"25ca0080","state":"06:FF"},{"type":"EVENT","adr":"01","state":"0"},{"type":"IT","adr":"60b5a280","state":"FF:FF"},{"type":"IT","adr":"518b1181","state":"06:62"},{"type":"IT","adr":"6616a881","state":"FF:FF"},{"type":"IT","adr":"60b5a282","state":"06:3C"},{"type":"IT","adr":"00","state":"FF:FF"},{"type":"IT","adr":"44205800","state":"FF:FF"},{"type":"IT","adr":"a1234561","state":"FF:FF"},{"type":"IT","adr":"af760080","state":"FF:FF"},{"type":"IT","adr":"13b80080","state":"FF:FF"},{"type":"IT","adr":"6616a880","state":"06:8E"}]
    In diesem File ist das Gerät: "type":"IT","adr":"44240080","state":"06:00"} enthalten wobei ich für die Automation den State davon brauche.
    Wie kann ich das mit Blocky umsetzen?
    Danke für die Hilfe.
    @ingranu sagte in Daten aus URL in blocky:
    wo ist das Blockly?
    ingranuI 1 Antwort Letzte Antwort
      wo ist das Blockly?
      ingranuI Offline
      ingranuI Offline
      ingranu
      @homoran sorry vergessen.
      Hab das bissle was gebastelt aber komme garned weiter..
      • ingranuI ingranu
        willst du wirklich jede Sekunde im 10 Sekundentakt Triggern?
        was kommt denn als result?
        im debug block ansehen!
        musst du nicht vorher das array in Elemente zerlegen, damit eine Liste draus wird?
        • ingranuI ingranu
          Hallo zusammen
          @ingranu sagte: {XC_SUC}
          Ist dieser Teil vor dem Array konstant? Wenn ja, sollte es so funktionieren:
            ingranuI Offline
            ingranuI Offline
            ingranu
            @homoran Nein der Trigger kann ich dann anpassen, mir gehts in erster Linie nur darum den Status auslesen zu können bevor ich die Automation mache.
            Debug :
            13:05:37.335	info	javascript.0 (4987) Start javascript script.js.common.Mediola_states1
            13:05:37.343	info	javascript.0 (4987) script.js.common.Mediola_states1: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
            13:05:40.058	error	javascript.0 (4987) script.js.common.Mediola_states1: TypeError: Cannot read property 'length' of undefined
            13:05:40.061	error	javascript.0 (4987) at script.js.common.Mediola_states1:8:34
              ingranuI Offline
              ingranuI Offline
              ingranu
              @paul53 Folgende kommt dabei raus:
              2.11.2022, 13:25:43.351	[info ]: javascript.0 (4987) Stop script script.js.common.Mediola_states2
              2.11.2022, 13:26:42.679	[info ]: javascript.0 (4987) Stop script script.js.common.Mediola_states2
              2.11.2022, 13:27:36.855	[info ]: javascript.0 (4987) Stop script script.js.common.Mediola_states2
              2.11.2022, 13:28:50.488	[info ]: javascript.0 (4987) Stop script script.js.common.Mediola_states2
              2.11.2022, 13:29:33.853	[info ]: javascript.0 (4987) Stop script script.js.common.Mediola_states2
              2.11.2022, 13:29:38.440	[info ]: javascript.0 (4987) Start javascript script.js.common.Mediola_states2
              2.11.2022, 13:29:38.463	[error]: javascript.0 (4987) script.js.common.Mediola_states2: Cannot get adr of undefined
              2.11.2022, 13:29:38.464	[info ]: javascript.0 (4987) script.js.common.Mediola_states2: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
              2.11.2022, 13:29:38.472	[error]: javascript.0 (4987) script.js.common.Mediola_states2: TypeError: Cannot read property 'length' of undefined
              2.11.2022, 13:29:38.473	[error]: javascript.0 (4987)     at script.js.common.Mediola_states2:24:30
              2.11.2022, 13:29:38.473	[error]: javascript.0 (4987)     at script.js.common.Mediola_states2:36:3
              2.11.2022, 13:29:40.061	[error]: javascript.0 (4987) script.js.common.Mediola_states2: TypeError: Cannot read property 'slice' of undefined
              2.11.2022, 13:29:40.062	[error]: javascript.0 (4987)     at script.js.common.Mediola_states2:7:21
              2.11.2022, 13:29:46.558	[info ]: javascript.0 (4987) Stop script script.js.common.Mediola_states2
              2.11.2022, 13:30:41.173	[info ]: javascript.0 (4987) Stop script script.js.common.Mediola_states2
              2.11.2022, 13:30:50.898	[info ]: javascript.0 (4987) Stop script script.js.common.Mediola_states2
              2.11.2022, 13:31:02.486	[info ]: javascript.0 (4987) Start javascript script.js.common.Mediola_states2
              2.11.2022, 13:31:02.495	[info ]: javascript.0 (4987) script.js.common.Mediola_states2: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
              2.11.2022, 13:31:10.070	[error]: javascript.0 (4987) script.js.common.Mediola_states2: TypeError: Cannot read property 'slice' of undefined
              2.11.2022, 13:31:10.071	[error]: javascript.0 (4987)     at script.js.common.Mediola_states2:7:21
              2.11.2022, 13:31:13.864	[info ]: javascript.0 (4987) Stop script script.js.common.Mediola_states2
              2.11.2022, 13:31:13.875	[info ]: javascript.0 (4987) Start javascript script.js.common.Mediola_states2
              2.11.2022, 13:31:13.883	[info ]: javascript.0 (4987) script.js.common.Mediola_states2: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
              2.11.2022, 13:31:20.057	[error]: javascript.0 (4987) script.js.common.Mediola_states2: TypeError: Cannot read property 'slice' of undefined
              2.11.2022, 13:31:20.058	[error]: javascript.0 (4987)     at script.js.common.Mediola_states2:7:21
              2.11.2022, 13:31:23.046	[info ]: javascript.0 (4987) Stop script script.js.common.Mediola_states2
              2.11.2022, 13:31:23.055	[info ]: javascript.0 (4987) Start javascript script.js.common.Mediola_states2
              2.11.2022, 13:31:23.064	[info ]: javascript.0 (4987) script.js.common.Mediola_states2: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
              2.11.2022, 13:31:30.057	[error]: javascript.0 (4987) script.js.common.Mediola_states2: TypeError: Cannot read property 'slice' of undefined
              2.11.2022, 13:31:30.057	[error]: javascript.0 (4987)     at script.js.common.Mediola_states2:7:21
              2.11.2022, 13:31:34.305	[info ]: javascript.0 (4987) Stop script script.js.common.Mediola_states2
              2.11.2022, 13:31:34.316	[info ]: javascript.0 (4987) Start javascript script.js.common.Mediola_states2
              2.11.2022, 13:31:34.331	[info ]: javascript.0 (4987) script.js.common.Mediola_states2: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
              2.11.2022, 13:31:40.061	[error]: javascript.0 (4987) script.js.common.Mediola_states2: TypeError: Cannot read property 'slice' of undefined
              2.11.2022, 13:31:40.061	[error]: javascript.0 (4987)     at script.js.common.Mediola_states2:7:21
              2.11.2022, 13:31:50.056	[error]: javascript.0 (4987) script.js.common.Mediola_states2: TypeError: Cannot read property 'slice' of undefined
              2.11.2022, 13:31:50.058	[error]: javascript.0 (4987)     at script.js.common.Mediola_states2:7:21
              2.11.2022, 13:32:00.058	[error]: javascript.0 (4987) script.js.common.Mediola_states2: TypeError: Cannot read property 'slice' of undefined
              2.11.2022, 13:32:00.060	[error]: javascript.0 (4987)     at script.js.common.Mediola_states2:7:21
              2.11.2022, 13:32:10.057	[error]: javascript.0 (4987) script.js.common.Mediola_states2: TypeError: Cannot read property 'slice' of undefined
              2.11.2022, 13:32:10.057	[error]: javascript.0 (4987)     at script.js.common.Mediola_states2:7:21
              2.11.2022, 13:32:20.061	[error]: javascript.0 (4987) script.js.common.Mediola_states2: TypeError: Cannot read property 'slice' of undefined
              2.11.2022, 13:32:20.063	[error]: javascript.0 (4987)     at script.js.common.Mediola_states2:7:21
              • ingranuI ingranu
                @ingranu sagte: Cannot read property 'slice' of undefined
                Kann es sein, dass in result nicht immer etwas geliefert wird? Dann frage result ab:
                oder prüfe den Anfang:
                  ingranuI Offline
                  ingranuI Offline
                  ingranu
                  @paul53 einfach nix..
                  Ausgabe kommt bei Abruf der URL aber immer
                  13:56:24.492	info	javascript.0 (4987) Stop script script.js.common.Mediola_states2
                  13:56:24.502	info	javascript.0 (4987) Start javascript script.js.common.Mediola_states2
                  13:56:24.509	info	javascript.0 (4987) script.js.common.Mediola_states2: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                  • ingranuI ingranu
                    @ingranu sagte: einfach nix..
                    Bau Debug-Ausgaben ein, um zu sehen, was passiert.
                    Weise bei "aktualisiere" noch einen Datenpunkt zu.
                    EDIT: Der Schleifenabbruch erfolgt an der falschen Stelle: Die Schleife wird sofort abgebrochen und nicht erst bei erfüllter Bedingung.
                    ingranuI 2 Antworten Letzte Antwort
                    • ingranuI ingranu
                      @ingranu sagte: Ausgabe kommt bei Abruf der URL aber immer
                      Wenn ich es mit dem oben angegeben String in result teste, erhalte ich das erwartete Ergebnis:
                      Schleifenabbruch korrigieren!!
                        ingranuI Offline
                        ingranuI Offline
                        ingranu
                        @paul53 Da tuuuut sich jetzt was :-)
                        javascript.0 (4987) script.js.common.Mediola_states3: [{"type":"FS20","adr":"443525","state":"00:A6"},{"type":"FS20","adr":"2b063b","state":"FF:FF"},{"type":"EVENT","adr":"02","state":"1"},{"type":"FS20","adr":"8d3700","state":"FF:FF"},{"type":"FS20","adr":"aaf900","state":"FF:FF"},{"type":"FS20","adr":"20d600","state":"FF:FF"},{"type":"EVENT","adr":"03","state":"1"},{"type":"FS20","adr":"903702","state":"FF:FF"},{"type":"FS20","adr":"1c291e","state":"FF:FF"},{"type":"FS20","adr":"8d3702","state":"FF:FF"},{"type":"FS20","adr":"0b3212","state":"FF:FF"},{"type":"FS20","adr":"ffffa9","state":"FF:FF"},{"type":"FS20","adr":"015301","state":"FF:FF"},{"type":"FS20","adr":"231a42","state":"FF:FF"},{"type":"ELRO","adr":"123409","state":"FF:FF"},{"type":"FS20","adr":"ffff01","state":"FF:FF"},{"type":"IT","adr":"aa3c0080","state":"FF:FF"},{"type":"FS20","adr":"271b20","state":"FF:FF"},{"type":"FS20","adr":"800001","state":"FF:FF"},{"type":"ELRO","adr":"000550","state":"00:12"},{"type":"IT","adr":"518b1180","state":"06:12"},{"type":"IT","adr":"010","state":"FF:FF"},{"type":"ELRO","adr":"100550","state":"00:FF"},{"type":"IT","adr":"1db90080","state":"FF:FF"},{"type":"IT","adr":"b3930080","state":"FF:FF"},{"type":"IT","adr":"2e340080","state":"06:A6"},{"type":"IT","adr":"a5430080","state":"FF:FF"},{"type":"IT","adr":"7f450080","state":"FF:FF"},{"type":"IT","adr":"44240080","state":"06:12"},{"type":"FS20","adr":"1a0132","state":"FF:FF"},{"type":"IT","adr":"25ca0080","state":"06:FF"},{"type":"EVENT","adr":"01","state":"0"},{"type":"IT","adr":"60b5a280","state":"FF:FF"},{"type":"IT","adr":"518b1181","state":"06:7A"},{"type":"IT","adr":"6616a881","state":"FF:FF"},{"type":"IT","adr":"60b5a282","state":"06:54"},{"type":"IT","adr":"00","state":"FF:FF"},{"type":"IT","adr":"44205800","state":"FF:FF"},{"type":"IT","adr":"a1234561","state":"FF:FF"},{"type":"IT","adr":"af760080","state":"06:12"},{"type":"IT","adr":"13b80080","state":"FF:FF"},{"type":"IT","adr":"6616a880","state":"06:A6"}]
                          ingranuI Offline
                          ingranuI Offline
                          ingranu
                          @paul53 said in Daten aus URL in blocky:
                          • ingranuI ingranu
                            @ingranu sagte: Da tuuuut sich jetzt was
                            Den Schleifenabbruch hast du korrigiert?
                              ingranuI Offline
                              ingranuI Offline
                              ingranu
                              Ja die Schleife habe ich korrigiert, die Ausgabe erfolgt jetzt wie folgt, also alle Geräte:
                              javascript.0 (4987) script.js.common.Mediola_states4: [{"type":"FS20","adr":"443525","state":"00:A7"},{"type":"FS20","adr":"2b063b","state":"FF:FF"},{"type":"EVENT","adr":"02","state":"1"},{"type":"FS20","adr":"8d3700","state":"FF:FF"},{"type":"FS20","adr":"aaf900","state":"FF:FF"},{"type":"FS20","adr":"20d600","state":"FF:FF"},{"type":"EVENT","adr":"03","state":"1"},{"type":"FS20","adr":"903702","state":"FF:FF"},{"type":"FS20","adr":"1c291e","state":"FF:FF"},{"type":"FS20","adr":"8d3702","state":"FF:FF"},{"type":"FS20","adr":"0b3212","state":"FF:FF"},{"type":"FS20","adr":"ffffa9","state":"FF:FF"},{"type":"FS20","adr":"015301","state":"FF:FF"},{"type":"FS20","adr":"231a42","state":"FF:FF"},{"type":"ELRO","adr":"123409","state":"FF:FF"},{"type":"FS20","adr":"ffff01","state":"FF:FF"},{"type":"IT","adr":"aa3c0080","state":"FF:FF"},{"type":"FS20","adr":"271b20","state":"FF:FF"},{"type":"FS20","adr":"800001","state":"FF:FF"},{"type":"ELRO","adr":"000550","state":"00:13"},{"type":"IT","adr":"518b1180","state":"06:13"},{"type":"IT","adr":"010","state":"FF:FF"},{"type":"ELRO","adr":"100550","state":"00:FF"},{"type":"IT","adr":"1db90080","state":"FF:FF"},{"type":"IT","adr":"b3930080","state":"FF:FF"},{"type":"IT","adr":"2e340080","state":"06:A7"},{"type":"IT","adr":"a5430080","state":"FF:FF"},{"type":"IT","adr":"7f450080","state":"FF:FF"},{"type":"IT","adr":"44240080","state":"06:13"},{"type":"FS20","adr":"1a0132","state":"FF:FF"},{"type":"IT","adr":"25ca0080","state":"06:FF"},{"type":"EVENT","adr":"01","state":"0"},{"type":"IT","adr":"60b5a280","state":"FF:FF"},{"type":"IT","adr":"518b1181","state":"06:7B"},{"type":"IT","adr":"6616a881","state":"FF:FF"},{"type":"IT","adr":"60b5a282","state":"06:55"},{"type":"IT","adr":"00","state":"FF:FF"},{"type":"IT","adr":"44205800","state":"FF:FF"},{"type":"IT","adr":"a1234561","state":"FF:FF"},{"type":"IT","adr":"af760080","state":"06:13"},{"type":"IT","adr":"13b80080","state":"FF:FF"},{"type":"IT","adr":"6616a880","state":"06:A7"}]
                              Aber wie kann ich jetzt da ne Automation mache, respektive kann ich den Wert welche in benötige irgendwo als Variable eintragen lassen?
                              • ingranuI ingranu
                                @ingranu
                                Da muss noch eine Log-Ausgabe hinterher kommen:
                                06:13
                                Deaktiviere mal den "Debug output json", denn offenbar kommt das JSON rein.
                                Der Block "aktualisiere" schreibt den Wert in einen unter "0_userdata.0" selbst erstellten Datenpunkt vom Typ "string".
                                  @ingranu
                                  06:13
                                  ingranuI Offline
                                  ingranuI Offline
                                  ingranu
                                  @paul53 Welchen Debug meinst du? Diesen hier?
                                  • ingranuI ingranu
                                    @ingranu sagte: Welchen Debug meinst du? Diesen hier?
                                    Ja, und den ganz oben (debug output result). Dann bleibt nur noch der Debug-Block für das ausgefilterte "state".
                                      ingranuI Offline
                                      ingranuI Offline
                                      ingranu
                                      @paul53 Sieht nur wie folgt aus:
                                      unten keine Info Ausgabe mehr
                                      • ingranuI ingranu
                                        @ingranu sagte: unten keine Info Ausgabe mehr
                                        Wo befindet sich jetzt der Block "die Schleife abbrechen"?
                                          ingranuI Offline
                                          ingranuI Offline
                                          ingranu
