  4. Diskussion zum Linux-Werkzeugkasten
107 Beiträge 18 Kommentatoren 22.7k Aufrufe 17 Beobachtet
    @negalein
    Z. B. so:
    sudo usermod -aG GRUPPENNAME BENUTZERNAME
    NegaleinN Offline
    NegaleinN Offline
    Negalein
    @thomas-braun sagte in Diskussion zum Linux-Werkzeugkasten:
    da will er nicht
    nega@ioBroker:~$ sudo usermod -aG adm dialout users nega
    Usage: usermod [options] LOGIN
    Options:
      -b, --badnames                allow bad names
      -c, --comment COMMENT         new value of the GECOS field
      -d, --home HOME_DIR           new home directory for the user account
      -e, --expiredate EXPIRE_DATE  set account expiration date to EXPIRE_DATE
      -f, --inactive INACTIVE       set password inactive after expiration
                                    to INACTIVE
      -g, --gid GROUP               force use GROUP as new primary group
      -G, --groups GROUPS           new list of supplementary GROUPS
      -a, --append                  append the user to the supplemental GROUPS
                                    mentioned by the -G option without removing
                                    the user from other groups
      -h, --help                    display this help message and exit
      -l, --login NEW_LOGIN         new value of the login name
      -L, --lock                    lock the user account
      -m, --move-home               move contents of the home directory to the
                                    new location (use only with -d)
      -o, --non-unique              allow using duplicate (non-unique) UID
      -p, --password PASSWORD       use encrypted password for the new password
      -R, --root CHROOT_DIR         directory to chroot into
      -P, --prefix PREFIX_DIR       prefix directory where are located the /etc/* files
      -s, --shell SHELL             new login shell for the user account
      -u, --uid UID                 new UID for the user account
      -U, --unlock                  unlock the user account
      -v, --add-subuids FIRST-LAST  add range of subordinate uids
      -V, --del-subuids FIRST-LAST  remove range of subordinate uids
      -w, --add-subgids FIRST-LAST  add range of subordinate gids
      -W, --del-subgids FIRST-LAST  remove range of subordinate gids
      -Z, --selinux-user SEUSER     new SELinux user mapping for the user account
    nega@ioBroker:~$
    ° Fixer ---> iob fix
    • NegaleinN Negalein
      da will er nicht
      Options:
                                      to INACTIVE
      nega@ioBroker:~$
      @negalein
      Auf was für einer Linux-Distribution bist du da eigentlich unterwegs? Die Befehle für die user-Verwaltung unterscheiden sich ggf.
        @negalein
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        Ubuntu
          Ubuntu
          @negalein
          Immer nur eine Gruppe angeben.
          sudo usermod -aG adm nega
          sudo usermod -aG dialout nega
          sudo usermod -aG users nega
            Ubuntu
            @negalein sagte in Diskussion zum Linux-Werkzeugkasten:
            Ubuntu
            Gerade bei ubuntu wundert es mich, da ist der root nämlich schon immer von Haus aus deaktiviert gewesen. Das ist also aktiv und bewusst umgefummelt worden. Klarer Fall von: Macht man nicht.
            Sonderfall: Benutzer root
            Standardmäßig existiert unter Linux immer ein Konto für den Benutzer root mit der User-ID 0. Dies ist ein Systemkonto mit vollem Zugriff auf das gesamte System und damit auch auf alle Dateien und Einstellungen aller Benutzer.
            Bei Ubuntu wird dem Benutzer root allerdings kein Passwort zugewiesen. Dadurch kann sich niemand unter dem Namen "root" anmelden.
            Der erste anlegte Benutzer ist unter Ubuntu bzw. dessen Derivaten immer automatisch Mitglied der Gruppe sudo und kann so mit Root-Rechten arbeiten. Wie bei Bedarf weitere Nutzer dieser Gruppe hinzugefügt werden können ist weiter unten im Artikel erklärt.
              @negalein
              NegaleinN Offline
              NegaleinN Offline
              Negalein
              Merci :)
              nega@ioBroker:~$ groups
              nega adm dialout sudo users iobroker
                Ubuntu
                M Online
                M Online
                MCU
                Aufgrund der npm6 Probleme https://forum.iobroker.net/topic/55183/github-installationen-mit-npm6-sehr-langsam
                Gibt es irgendwo eine Anleitung um ein Update von npm6 auf npm8 zu vollziehen?
                Sollte so was auch in den Werkzeugkasten, oder sollte man lieber abwarten?
                Danke.
                • M MCU
                  Danke.
                  @mcu sagte in Diskussion zum Linux-Werkzeugkasten:
                  Ich würde immer empfehlen, auch die npm-Version zu fahren, die vom nodeJS-Projekt upstream für das jeweilige Gesamtpaket vorgesehen ist. Für nodeJS@14 ist das halt npm@6.
                  npm@8 ist erst für nodeJS@16 vorgesehen.
                  Ich würde aber auch nicht eine node@16 für den ioBroker empfehlen wollen.
                  Ein Dilemma.
                  Aber es gibt wohl Überlegungen nodeJS16 bald zur empfohlenen Version zu machen. U. a. wegen der langsamen Installation von git.
                  https://forum.iobroker.net/topic/55290/meeting-für-iobroker-core-dev-admin-15-06-22-20-30/4
                  • P Offline
                    patrikp
                    schrieb am zuletzt editiert von patrikp
                    Den Werkzeugkasten habe ich heute entdeckt und finde ihn sehr hilfreich. Natürlich direkt einen Fehler in meiner Installation gefunden. node und npm liegen in /usr/local/bin/* und nicht in /usr/bin/*. Kann man die einfach umziehen, und was ist dabei zu beachten, oder ist eine Neuinstallation notwendig?
                    Gruß und besten Dank
                    • P patrikp
                      @patrikp
                      Dann schau mal in den zweiten Link in meiner Signatur. Da steht es ausführlicher drin.
                      P 1 Antwort Letzte Antwort
                        @patrikp
                        patrikp
                        @thomas-braun oh, sorry. doch nicht alles gelesen.🙄
                        ...und ja. Es hat geholfen. Danke nochmal.
                        • P patrikp
                          ThomKast
                          @Thomas-Braun braun
                          Hättest Du vielleicht auch noch eine Deiner guten Anleitungen für die Absicherung der Komponenten...
                          IOB, Influxdb, Grafana, SSL-Zertifikat....
                          Hatte mich durch viele Informationen gehangelt, aber abschließend keinen sauberen erzielt. IOB war unter http, aber grafana unter https zu erreichen und so was... Habe zwar keinen Port offen, aber ich fände es gut, wenn es eine brauchbare, einheitliche Empfehlung gäbe.
                          Gruß, Thomas
                          Michael UrayM 1 Antwort Letzte Antwort
                          • T ThomKast
                            @Thomas-Braun braun
                            Gruß, Thomas
                            Michael UrayM Offline
                            Michael Uray
                            In meinem Docker Container scheint einmal ein root user und dann auch noch ein iobroker user auf.
                            # cat /etc/passwd
                            root:x:0:0:root:/root:/bin/bash
                            daemon:x:1:1:daemon:/usr/sbin:/usr/sbin/nologin
                            bin:x:2:2:bin:/bin:/usr/sbin/nologin
                            sys:x:3:3:sys:/dev:/usr/sbin/nologin
                            sync:x:4:65534:sync:/bin:/bin/sync
                            games:x:5:60:games:/usr/games:/usr/sbin/nologin
                            man:x:6:12:man:/var/cache/man:/usr/sbin/nologin
                            lp:x:7:7:lp:/var/spool/lpd:/usr/sbin/nologin
                            mail:x:8:8:mail:/var/mail:/usr/sbin/nologin
                            news:x:9:9:news:/var/spool/news:/usr/sbin/nologin
                            uucp:x:10:10:uucp:/var/spool/uucp:/usr/sbin/nologin
                            proxy:x:13:13:proxy:/bin:/usr/sbin/nologin
                            www-data:x:33:33:www-data:/var/www:/usr/sbin/nologin
                            backup:x:34:34:backup:/var/backups:/usr/sbin/nologin
                            list:x:38:38:Mailing List Manager:/var/list:/usr/sbin/nologin
                            irc:x:39:39:ircd:/run/ircd:/usr/sbin/nologin
                            gnats:x:41:41:Gnats Bug-Reporting System (admin):/var/lib/gnats:/usr/sbin/nologin
                            nobody:x:65534:65534:nobody:/nonexistent:/usr/sbin/nologin
                            _apt:x:100:65534::/nonexistent:/usr/sbin/nologin
                            _rpc:x:101:65534::/run/rpcbind:/usr/sbin/nologin
                            statd:x:102:65534::/var/lib/nfs:/usr/sbin/nologin
                            iobroker:x:1000:1000::/opt/iobroker:/bin/bash
                            • Michael UrayM Michael Uray
                              # cat /etc/passwd
                              @michael-uray
                              Ja, das ist vollkommen richtig. In der /etc/passwd stehen alle User des Systems drin.
                              • Michael UrayM Offline
                                Michael Uray
                                @thomas-braun ich habe das hier wegen der root user Diskussion im Docker Container gepostet.
                                Sollte man demnach dann Arbeiten im Container nicht unter dem User iobroker durchführen anstatt als root, wenn es so einen Benutzer gibt?
                                Was hat es denn eigentlich generell für negative Auswirkungen auf den iobroker, wenn man immer alles als root ausführt?
                                • Thomas BraunT Online
                                  @michael-uray
                                  Man sollte einen eigenen User haben bzw. anlegen, also weder root noch iobroker.
                                  Man läuft Gefahr sich das System immer weiter zu verbiegen. Neben den sonstigen Gründen nicht als root durch das System zu stolpern.
                                    @michael-uray
                                    shellyrulestheworld
                                    @thomas-braun ich habe mal auf deine Anregung user angelegt (so wie von dir im Linux Baukasten beschrieben). Aber ich verzweifle irgendwie daran :-)
                                    root@influxdb-grafana:/# su peter
                                    peter@influxdb-grafana:/$ sudo
                                    bash: sudo: Kommando nicht gefunden.
                                    peter@influxdb-grafana:/$ sudo apt upgrade
                                    peter@influxdb-grafana:/$ # apt-get install sudo
                                    peter@influxdb-grafana:/$ apt-get install sudo
                                    E: Sperrdatei /var/lib/dpkg/lock-frontend konnte nicht geöffnet werden. - open (13: Keine Berechtigung)
                                    E: Erlangen der Sperre für die Dpkg-Oberfläche (/var/lib/dpkg/lock-frontend) nicht möglich; sind Sie root?
                                    peter@influxdb-grafana:/$ su root
                                    Passwort:
                                    root@influxdb-grafana:/# # apt-get install sudo~
                                    peter@influxdb-grafana:/$ apt update
                                    E: Sperrdatei /var/lib/apt/lists/lock konnte nicht geöffnet werden. - open (13: Keine Berechtigung)
                                    E: Das Verzeichnis /var/lib/apt/lists/ kann nicht gesperrt werden.
                                    W: Problem beim Entfernen (unlink) der Datei /var/cache/apt/pkgcache.bin - RemoveCaches (13: Keine Berechtigung)
                                    W: Problem beim Entfernen (unlink) der Datei /var/cache/apt/srcpkgcache.bin - RemoveCaches (13: Keine Berechtigung)
                                    peter@influxdb-grafana:/$ sudo apt update
                                    peter@influxdb-grafana:/$ usermod -aG sudo peter
                                    usermod: Permission denied.
                                    usermod: /etc/passwd konnte nicht gesperrt werden; versuchen Sie es später noch einmal.
                                    Passwort:
                                    root@influxdb-grafana:/# usermod -aG sudo username
                                    usermod: Benutzer »username« ist nicht vorhanden.
                                    root@influxdb-grafana:/# usermod -aG sudo peter
                                    peter@influxdb-grafana:/$ groups
                                    peter sudo
                                    Passwort:
                                    root@influxdb-grafana:/# groups
                                    root
                                    es scheint irgendwas nicht zu klappen mit dem neuen User. Könntest du mir bitte auf die Sprünge helfen?
                                    • S shellyrulestheworld
                                      Passwort:
                                      Passwort:
                                      peter sudo
                                      Passwort:
                                      root
                                      @shellyrulestheworld sagte in Diskussion zum Linux-Werkzeugkasten:
                                      hast du den user auch der gruppe sudo hinzugefügt
                                      was sagt groups als user ausgeführt?
                                        shellyrulestheworld
                                        peter sudo
                                          peter sudo
                                          @shellyrulestheworld danke
                                          bin kein linux crack. weiss nicht ob der Wechsel mit su genau das selbe bewirkt wie root abmelden und als pezer wieder anzumelden.
                                          Mal sehen was @Thomas-Braun Dazu sagt.
                                          Abgesehen davon sollte peter auch in der Gruppe iobroker sein
