  4. Neuinstallation und VIS geht auf Fehler
173 Beiträge 5 Kommentatoren 12.7k Aufrufe 5 Beobachtet
    @humidor
    Wie üblich in CodeTags.
    HumidorH Offline
    HumidorH Offline
    Humidor
    schrieb am zuletzt editiert von Humidor
    2022-10-09 18:23:22.274 - error: vis.0 (1500) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-10-09 18:23:22.276 - error: vis.0 (1500) unhandled promise rejection: Not exists
    2022-10-09 18:23:22.279 - error: vis.0 (1500) Error: Not exists
    at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17)
    at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1043:26)
    at Immediate. (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1092:29)
    at processImmediate (node:internal/timers:468:21)
    2022-10-09 18:23:22.280 - error: vis.0 (1500) Not exists
    2022-10-09 18:23:24.018 - error: host.iobroker-pi iobroker npm-install: host.iobroker-pi Cannot install iobroker.vis@1.4.15: 6
    2022-10-09 18:23:25.062 - info: host.iobroker-pi iobroker npm-install: exit 25
    2022-10-09 18:23:25.871 - info: renault.0 (1106) Feature not found for VF1AG000966808321. Ignore charge-history for updates.
    2022-10-09 18:23:26.063 - warn: host.iobroker-pi startInstance cannot find adapter "vis@1.4.15". Try to install it... 4 attempt
    2022-10-09 18:23:26.064 - info: host.iobroker-pi iobroker install vis@1.4.15 using installedVersion
    2022-10-09 18:23:28.865 - info: renault.0 (1106) Feature not found for VF1AG000966808321. Ignore lock-status for updates.
    2022-10-09 18:23:29.771 - info: renault.0 (1106) Feature not found for VF1AG000966808321. Ignore res-state for updates.
    2022-10-09 18:23:32.222 - info: host.iobroker-pi iobroker npm-install: NPM version: 8.15.0Installing iobroker.vis@1.4.15... (System call)
    2022-10-09 18:23:48.413 - error: vis.0 (1667) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-10-09 18:23:48.416 - error: vis.0 (1667) unhandled promise rejection: Not exists
    2022-10-09 18:23:48.419 - error: vis.0 (1667) Error: Not exists
    2022-10-09 18:23:48.421 - error: vis.0 (1667) Not exists
    2022-10-09 18:23:50.214 - error: host.iobroker-pi iobroker npm-install: host.iobroker-pi Cannot install iobroker.vis@1.4.15: 6
    2022-10-09 18:23:51.253 - info: host.iobroker-pi iobroker npm-install: exit 25
    2022-10-09 18:23:52.254 - error: host.iobroker-pi Cannot download and install adapter "vis@1.4.15". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
    2022-10-09 18:25:00.198 - info: javascript.0 (621) script.js.common.go-E_GridOffset: go-E Wolkenzähler hat GridOffset angepasst auf: 1500
    2022-10-09 18:26:55.644 - info: host.iobroker-pi iobroker add vis auto --host iobroker-pi --debug
    2022-10-09 18:26:59.888 - info: host.iobroker-pi iobroker NPM version: 8.15.0
    2022-10-09 18:26:59.890 - info: host.iobroker-pi iobroker Installing iobroker.vis@1.4.15... (System call)
    2022-10-09 18:27:17.440 - error: vis.0 (1758) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-10-09 18:27:17.443 - error: vis.0 (1758) unhandled promise rejection: Not exists
    2022-10-09 18:27:17.446 - error: vis.0 (1758) Error: Not exists
    2022-10-09 18:27:17.447 - error: vis.0 (1758) Not exists
    2022-10-09 18:27:19.253 - info: host.iobroker-pi iobroker npm ERR! code 6
    2022-10-09 18:27:19.259 - info: host.iobroker-pi iobroker npm ERR! path /opt/iobroker/node_modules/iobroker.vis
    2022-10-09 18:27:19.265 - info: host.iobroker-pi iobroker npm ERR! command failednpm ERR! command sh /tmp/install-56aeda2a.sh
    2022-10-09 18:27:19.273 - info: host.iobroker-pi iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-10-09T17_27_01_156Z-debug-0.log
    2022-10-09 18:27:19.306 - error: host.iobroker-pi iobroker host.iobroker-pi Cannot install iobroker.vis@1.4.15: 6
    2022-10-09 18:27:20.349 - info: host.iobroker-pi iobroker exit 25
    so oder?
    https://github.com/ioBroker/ioBroker.vis/issues/502
    BG
    • HumidorH Humidor
      so oder?
      @humidor sagte in Neuinstallation und VIS geht auf Fehler:
      for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
      Und installier mal eine der Vorversionen von vis.
      HumidorH 1 Antwort Letzte Antwort
        HumidorH Offline
        HumidorH Offline
        Humidor
        @thomas-braun verstehe nicht was ich da tun soll
        den + Button für die Versionen zeigt er mir bei der VIS nicht an
        BG
        • HumidorH Humidor
          @humidor
          Im Terminal gibt es auch kein +
          iobroker upgrade vis@1.4.11 --debug
            @humidor
            HumidorH Offline
            HumidorH Offline
            Humidor
            @thomas-braun sagte in Neuinstallation und VIS geht auf Fehler:
            This upgrade of "vis" will at least introduce the following changes:
            -> 1.4.11:
            Removed ES6 commands to be supported by older browsers
            Fixed problem with update of grouped widgets
            Added web manifest to be able to handle vis as the web app
            -> 1.4.8:
            Added support for js-controller 4.x
            -> 1.4.7:
            Fixed subscribeOidAtRuntime if called with invalid IDs
            Added support of license manager
            BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
            Would you like to upgrade vis from @0.0.0 to @1.4.11 now? [(y)es, (n)o]: y
            Update vis from @0.0.0 to @1.4.11
            NPM version: 8.15.0
            Installing iobroker.vis@1.4.11... (System call)
            npm ERR! code 6
            npm ERR! command sh /tmp/install-1afdc587.sh
            npm ERR!     /home/iobroker/.npm/_logs/2022-10-09T17_55_17_832Z-debug-0.log
            host.iobroker-pi Cannot install iobroker.vis@1.4.11: 6
            BG
            • Thomas BraunT Online
              Was steht da drin?
              • HumidorH Humidor
                Hallo!
                habe mir ein neues Image auf eine SD mit Raspi gebrannt und dann mit Backup meine Install zurück geholgt. Er installiert nach und nach die Adapter, aber bei VIS hats einen Fehler. Was muss ich da machen?
                Was für ein Image?
                  Was steht da drin?
                  HumidorH Offline
                  HumidorH Offline
                  Humidor
                  Last login: Sun Oct 9 15:45:50 on ttys000
                  richardnussdorfer@MacBook-Pro-von-Richard ~ % ssh pi@192.168.0.92
                  pi@192.168.0.92's password:
                  Linux iobroker-pi 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l
                  permitted by applicable law.
                  Last login: Sun Oct 9 14:46:06 2022 from 192.168.0.193
                  SSH is enabled and the default password for the 'pi' user has not been changed.
                  This is a security risk - please login as the 'pi' user and type 'passwd' to set a new password.
                  Wi-Fi is currently blocked by rfkill.
                  Use raspi-config to set the country before use.
                  pi@iobroker-pi:~ $ sudo reboot
                  Connection to 192.168.0.92 closed by remote host.
                  Connection to 192.168.0.92 closed.
                  Last login: Sun Oct 9 15:02:28 2022 from 192.168.0.193
                  Last login: Sun Oct 9 15:42:15 2022 from 192.168.0.193
                  pi@iobroker-pi:~ $ iob stop
                  pi@iobroker-pi:~ $ iob fix
                  library: loaded
                  Library version=2022-06-15
                  Welcome to the ioBroker installation fixer!
                  Script version: 2022-06-03
                  You might need to enter your password a couple of times.
                  Installing prerequisites (1/3)
                  Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                  Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                  Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
                  Reading package lists... Done
                  Installed gcc-c++
                  Checking ioBroker user and directory permissions (2/3)
                  Checking autostart (3/3)
                  Enabling autostart...
                  Autostart enabled!
                  Your installation was fixed successfully
                  Run iobroker start to start ioBroker again!
                  pi@iobroker-pi:~ $ iob start
                  Last login: Sun Oct 9 16:02:22 2022 from 192.168.0.193
                  pi@iobroker-pi:~ $ sudo apt update
                  Hit:2 https://deb.nodesource.com/node_12.x buster InRelease
                  Hit:3 http://raspbian.raspberrypi.org/raspbian buster InRelease
                  Building dependency tree
                  All packages are up to date.
                  pi@iobroker-pi:~ $ sudo apt upgrade
                  Calculating upgrade... Done
                  0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                  pi@iobroker-pi:~ $ sudo apt dist-upgradesudo apt dist-upgrade
                  E: Invalid operation dist-upgradesudo
                  pi@iobroker-pi:~ $ curl -fsSL https://deb.nodesource.com/setup_14.x | sudo -E bash -
                  Installing the NodeSource Node.js 14.x repo...
                  Populating apt-get cache...
                  • apt-get update
                    Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                    Hit:3 http://archive.raspberrypi.org/debian buster InRelease
                  Confirming "buster" is supported...
                  • curl -sLf -o /dev/null 'https://deb.nodesource.com/node_14.x/dists/buster/Release'
                  Adding the NodeSource signing key to your keyring...
                  • curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
                    gpg: WARNING: unsafe ownership on homedir '/home/pi/.gnupg'
                  Creating apt sources list file for the NodeSource Node.js 14.x repo...
                  • echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_14.x buster main' > /etc/apt/sources.list.d/nodesource.list
                  • echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_14.x buster main' >> /etc/apt/sources.list.d/nodesource.list
                  Running apt-get update for you...
                  • apt-get update
                    Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                    Get:3 https://deb.nodesource.com/node_14.x buster InRelease [4,584 B]
                    Get:4 https://deb.nodesource.com/node_14.x buster/main armhf Packages [782 B]
                    Fetched 5,366 B in 2s (2,988 B/s)
                  Run sudo apt-get install -y nodejs to install Node.js 14.x and npm
                  You may also need development tools to build native addons:
                   sudo apt-get install gcc g++ make
                  To install the Yarn package manager, run:
                   curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
                   echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
                   sudo apt-get update && sudo apt-get install yarn
                  pi@iobroker-pi:~ $ sudo apt-get install -y nodejs
                  The following packages will be upgraded:
                  nodejs
                  1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                  Need to get 23.3 MB of archives.
                  After this operation, 31.2 MB of additional disk space will be used.
                  Get:1 https://deb.nodesource.com/node_14.x buster/main armhf nodejs armhf 14.20.1-deb-1nodesource1 [23.3 MB]
                  Fetched 23.3 MB in 3s (7,113 kB/s)
                  apt-listchanges: Reading changelogs...
                  (Reading database ... 52601 files and directories currently installed.)
                  Preparing to unpack .../nodejs_14.20.1-deb-1nodesource1_armhf.deb ...
                  Unpacking nodejs (14.20.1-deb-1nodesource1) over (12.22.12-deb-1nodesource1) ...
                  Setting up nodejs (14.20.1-deb-1nodesource1) ...
                  Processing triggers for man-db (2.8.5-2) ...
                  Last login: Sun Oct 9 16:29:51 2022 from 192.168.0.193
                  pi@iobroker-pi:~ $ node -v
                  v14.20.1
                  pi@iobroker-pi:~ $ curl -fsSL https://deb.nodesource.com/setup_16.x | sudo -E bash -
                  Installing the NodeSource Node.js 16.x repo...
                  • apt-get update
                    Hit:3 https://deb.nodesource.com/node_14.x buster InRelease
                  • curl -sLf -o /dev/null 'https://deb.nodesource.com/node_16.x/dists/buster/Release'
                  Creating apt sources list file for the NodeSource Node.js 16.x repo...
                  • echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main' > /etc/apt/sources.list.d/nodesource.list
                  • echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main' >> /etc/apt/sources.list.d/nodesource.list
                  • apt-get update
                    Get:3 https://deb.nodesource.com/node_16.x buster InRelease [4,584 B]
                    Get:4 https://deb.nodesource.com/node_16.x buster/main armhf Packages [783 B]
                    Fetched 5,367 B in 1s (4,026 B/s)
                  Run sudo apt-get install -y nodejs to install Node.js 16.x and npm
                  pi@iobroker-pi:~ $
                  nodejs
                  Need to get 24.1 MB of archives.
                  After this operation, 2,072 kB of additional disk space will be used.
                  Get:1 https://deb.nodesource.com/node_16.x buster/main armhf nodejs armhf 16.17.1-deb-1nodesource1 [24.1 MB]
                  Fetched 24.1 MB in 3s (7,256 kB/s)
                  (Reading database ... 52699 files and directories currently installed.)
                  Preparing to unpack .../nodejs_16.17.1-deb-1nodesource1_armhf.deb ...
                  Unpacking nodejs (16.17.1-deb-1nodesource1) over (14.20.1-deb-1nodesource1) ...
                  Setting up nodejs (16.17.1-deb-1nodesource1) ...
                  Last login: Sun Oct 9 18:06:04 2022 from 192.168.0.193
                  pi@iobroker-pi:~ $ curl -sL https://iobroker.net/fix.sh | bash -
                  library: loaded
                  ioBroker or some processes are still running:
                  io.admin.0
                  io.history.0
                  io.javascript.0
                  io.telegram.0
                  Please stop them first and try again!
                  pi@iobroker-pi:~ $ iobroker stop
                  library: loaded
                  Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
                  Installed gcc-c++
                  Autostart enabled!
                  pi@iobroker-pi:~ $ cd /opt/iobroker
                  pi@iobroker-pi:/opt/iobroker $
                  pi@iobroker-pi:/opt/iobroker $ sudo npm cache verify
                  ^[[A^[[B
                  Cache verified and compressed (~/.npm/_cacache)
                  Content verified: 1865 (82716378 bytes)
                  Index entries: 2899
                  Finished in 24.574s
                  pi@iobroker-pi:/opt/iobroker $ sudo chown -R iobroker /opt/iobroker
                  pi@iobroker-pi:/opt/iobroker $ sudo apt update -y && sudo apt upgrade -y
                  Get:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
                  Fetched 15.0 kB in 1s (12.9 kB/s)
                  pi@iobroker-pi:/opt/iobroker $ sudo apt-get purge nodejs -y && sudo apt-get autoremove -y && sudo apt-get autoclean -y
                  The following packages will be REMOVED:
                  nodejs*
                  0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
                  After this operation, 119 MB disk space will be freed.
                  (Reading database ... 50868 files and directories currently installed.)
                  Removing nodejs (16.17.1-deb-1nodesource1) ...
                  dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/generator' not empty so not removed
                  Del nodejs 12.22.12-deb-1nodesource1 [15.9 MB]
                  Del nodejs 14.20.1-deb-1nodesource1 [23.3 MB]
                  pi@iobroker-pi:/opt/iobroker $ sudo curl -sL https://deb.nodesource.com/setup_16.x | sudo bash -
                  • apt-get update
                  • apt-get update
                  pi@iobroker-pi:/opt/iobroker $ sudo apt-get install -y nodejs
                  The following NEW packages will be installed:
                  nodejs
                  0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                  Need to get 0 B/24.1 MB of archives.
                  After this operation, 119 MB of additional disk space will be used.
                  Selecting previously unselected package nodejs.
                  (Reading database ... 47737 files and directories currently installed.)
                  Unpacking nodejs (16.17.1-deb-1nodesource1) ...
                  pi@iobroker-pi:/opt/iobroker $ iobroker stop
                  pi@iobroker-pi:/opt/iobroker $ curl -sL https://iobroker.net/fix.sh | bash -
                  library: loaded
                  Installed gcc-c++
                  Autostart enabled!
                  pi@iobroker-pi:/opt/iobroker $ npm install -y iobroker.js-controller --unsafe-perm --production --save --prefix
                  npm WARN invalid config prefix=true set in command line options
                  npm WARN invalid config Must be valid filesystem path
                  npm WARN config production Use --omit=dev instead.
                  npm WARN old lockfile
                  npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                  npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                  npm WARN old lockfile This is a one-time fix-up, please be patient...
                  (##################) ⠴ idealTree:iobroker: sill idealTree buildDeps
                  npm WARN skipping integrity check for git dependency ssh://git@github.com/walli545/ioBroker.time-switch.git
                  (##################) ⠏ reify:@types/node: timing reifyNode:node_modules/iobroker.time-switch/node_modules/cron-parser Completed in 158ms
                  added 6 packages, removed 2 packages, and changed 1 package in 3m
                  189 packages are looking for funding
                  run npm fund for details
                  added 1 package, removed 1 package, and changed 1 package in 9s
                  pi@iobroker-pi:/opt/iobroker $ npm rebuild
                  rebuilt dependencies successfully
                  pi@iobroker-pi:/opt/iobroker $ iobroker update
                  Adapter "admin" : 6.2.22 , installed 6.2.22
                  Adapter "alias-manager": 1.2.4 , installed 1.2.6
                  Adapter "backitup" : 2.4.12 , installed 2.4.16
                  Adapter "cloud" : 4.2.2 , installed 4.2.2
                  Adapter "daswetter" : 3.1.3 , installed 3.1.4
                  Adapter "denon" : 1.13.4 , installed 1.13.4
                  Adapter "discovery" : 3.0.5 , installed 3.0.5
                  Adapter "echarts" : 1.0.12 , installed 1.0.12
                  Adapter "fritzdect" : 2.2.3 , installed 2.2.6
                  Adapter "fronius" : 1.1.3 , installed 1.1.3
                  Adapter "fuelpricemonitor": 0.3.0 , installed 0.3.0
                  Adapter "go-e" : 1.0.23 , installed 1.0.25
                  Adapter "habpanel" : 0.5.0 , installed 0.5.0
                  Adapter "harmony" : 1.2.2 , installed 1.2.2
                  Adapter "history" : 2.2.0 , installed 2.2.4
                  Adapter "hs100" : 2.1.2 , installed 2.1.2
                  Adapter "hue" : 3.7.1 , installed 3.7.1
                  Adapter "hue-extended" : 2.0.0 , installed 2.0.0
                  Adapter "icons-icons8" : 0.0.1 , installed 0.0.1
                  Adapter "icons-mfd-png": 1.1.0 , installed 1.1.0
                  Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                  Adapter "icons-ultimate-png": 1.0.1, installed 1.0.1
                  Adapter "influxdb" : 3.1.8 , installed 3.2.0
                  Adapter "info" : 1.9.19 , installed 1.9.21
                  Adapter "iot" : 1.11.9 , installed 1.12.2
                  Adapter "javascript" : 6.0.3 , installed 6.0.3
                  Controller "js-controller": 4.0.23 , installed 4.0.23
                  Adapter "kecontact" : 1.4.1 , installed 1.4.1
                  Adapter "linktap" : 0.2.1 , installed 0.2.1
                  Adapter "logparser" : 1.1.0 , installed 1.1.0
                  Adapter "modbus" : 5.0.5 , installed 5.0.8
                  Adapter "mqtt" : 4.0.7 , installed 4.0.7
                  Adapter "owntracks" : 1.0.3 , installed 1.0.4
                  Adapter "places" : 1.1.2 , installed 1.1.2
                  Adapter "psa" : 0.0.11 , installed 0.0.11
                  Adapter "renault" : 0.0.14 , installed 0.0.14
                  Adapter "s7" : 1.3.13 , installed 1.3.14
                  Adapter "shelly" : 6.0.0 , installed 6.2.0
                  Adapter "simple-api" : 2.7.0 , installed 2.7.2
                  Adapter "socketio" : 4.2.0 , installed 6.1.9
                  Adapter "sonoff" : 2.5.1 , installed 2.5.1
                  Adapter "synology" : 2.1.9 , installed 2.1.9
                  Adapter "telegram" : 1.14.1 , installed 1.14.1
                  Adapter "virtualpowermeter": 1.4.6, installed 1.4.6
                  Adapter "vis-icontwo" : 0.89.0 , installed 0.89.0
                  Adapter "vis-inventwo" : 3.3.1 , installed 3.3.3
                  Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12
                  Adapter "vis-justgage" : 1.0.2 , installed 1.0.2
                  Adapter "vis-map" : 1.0.4 , installed 1.0.4
                  Adapter "web" : 4.3.0 , installed 5.2.5
                  Adapter "ws" : 1.3.0 , installed 2.1.4
                  Adapter "yahka" : 0.13.1 , installed 0.14.0
                  Adapter "zigbee" : 1.7.5 , installed 1.7.6
                  pi@iobroker-pi:/opt/iobroker $ iobroker upgrade self
                  Host "iobroker-pi" is up to date.
                  All adapters are up to date
                  pi@iobroker-pi:/opt/iobroker $ sudo reboot
                  Last login: Sun Oct 9 18:08:03 2022 from 192.168.0.193
                  pi@iobroker-pi:~ $ iobroker upgrade vis@1.4.11 --debug
                  -> 1.4.11:
                  -> 1.4.8:
                  -> 1.4.7:
                  NPM version: 8.15.0
                  npm ERR! code 6
                  pi@iobroker-pi:~ $ cd /home
                  pi@iobroker-pi:/home $ cd iobroker
                  pi@iobroker-pi:/home/iobroker $ cd .npm
                  pi@iobroker-pi:/home/iobroker/.npm $ cd _logs
                  pi@iobroker-pi:/home/iobroker/.npm/_logs $ edit 2022-10-09T17_55_17_832Z-debug-0.log
                  Error: no write permission for file "2022-10-09T17_55_17_832Z-debug-0.log"
                  pi@iobroker-pi:/home/iobroker/.npm/_logs $ ls
                  2022-10-09T17_22_38_366Z-debug-0.log 2022-10-09T17_23_17_003Z-debug-0.log 2022-10-09T17_27_01_156Z-debug-0.log
                  2022-10-09T17_22_49_636Z-debug-0.log 2022-10-09T17_23_30_950Z-debug-0.log 2022-10-09T17_55_16_475Z-debug-0.log
                  2022-10-09T17_22_55_400Z-debug-0.log 2022-10-09T17_23_32_782Z-debug-0.log 2022-10-09T17_55_17_832Z-debug-0.log
                  2022-10-09T17_22_57_971Z-debug-0.log 2022-10-09T17_26_59_780Z-debug-0.log
                  pi@iobroker-pi:/home/iobroker/.npm/_logs $ sudo edit 2022-10-09T17_55_17_832Z-debug-0.log
                  581 timing reifyNode:node_modules/follow-redirects Completed in 140ms
                  582 timing reifyNode:node_modules/iobroker.javascript/node_modules/@types/node Completed in 225ms
                  583 http fetch GET 200 https://registry.npmjs.org/axios/-/axios-0.25.0.tgz 325ms (cache miss)
                  584 timing reifyNode:node_modules/iobroker.vis/node_modules/axios Completed in 357ms
                  585 http fetch GET 200 https://registry.npmjs.org/iobroker.vis/-/iobroker.vis-1.4.11.tgz 2473ms (cache miss)
                  586 timing reifyNode:node_modules/iobroker.vis Completed in 2500ms
                  587 timing reify:unpack Completed in 2501ms
                  588 timing reify:unretire Completed in 6ms
                  589 timing build:queue Completed in 9ms
                  590 info run iobroker.vis@1.4.11 install node_modules/iobroker.vis node main.js --install
                  591 info run iobroker.vis@1.4.11 install { code: 6, signal: null }
                  592 timing reify:rollback:createSparse Completed in 361ms
                  593 timing reify:rollback:retireShallow Completed in 321ms
                  594 timing command:install Completed in 17308ms
                  595 verbose stack Error: command failed
                  595 verbose stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:63:27)
                  595 verbose stack at ChildProcess.emit (node:events:513:28)
                  595 verbose stack at maybeClose (node:internal/child_process:1093:16)
                  595 verbose stack at Process.ChildProcess._handle.onexit (node:internal/child_process:302:5)
                  596 verbose pkgid iobroker.vis@1.4.11
                  597 verbose cwd /opt/iobroker
                  598 verbose Linux 5.10.103-v7l+
                  599 verbose node v16.17.1
                  600 verbose npm v8.15.0
                  601 error code 6
                  602 error path /opt/iobroker/node_modules/iobroker.vis
                  603 error command failed
                  604 error command sh /tmp/install-1afdc587.sh
                  605 verbose exit 6
                  606 timing npm Completed in 17648ms
                  607 verbose unfinished npm timer reify 1665338118161
                  608 verbose unfinished npm timer reify:build 1665338130969
                  609 verbose unfinished npm timer build 1665338130974
                  610 verbose unfinished npm timer build:deps 1665338130975
                  611 verbose unfinished npm timer build:run:install 1665338130985
                  612 verbose unfinished npm timer build:run:install:node_modules/iobroker.vis 1665338130986
                  613 verbose code 6
                  614 error A complete log of this run can be found in:
                  614 error /home/iobroker/.npm/_logs/2022-10-09T17_55_17_832Z-debug-0.log
                  ach, ich krieg das nicht hin den kompletten Inhalt zu kopieren, toller Apple...
                  601 error code 6
                  605 verbose exit 6
                  613 verbose code 6
                  BG
                    Was für ein Image?
                    HumidorH Offline
                    HumidorH Offline
                    Humidor
                    @thomas-braun meine Überlegung mom., nach akt. Websuche. Neu aufsetzten und VIS vor Backup einspielen installieren.
                    BG
                    • HumidorH Humidor
                      @humidor
                      Und lass die Finger von irgendwelchen Images.
                        @humidor
                        HumidorH Offline
                        HumidorH Offline
                        Humidor
                        @thomas-braun irgenwelche? ich nehme das originale iobroker und hole mein Backup zurück, thats it.
                        BG
                        • HumidorH Humidor
                          Es gibt keine (aktuellen) Images mehr.
                          Die Installation erfolgt über das Installationsskript.
                            HumidorH Offline
                            HumidorH Offline
                            Humidor
                            @thomas-braun du meinst das:
                            https://www.iobroker.net/#de/documentation/install/linux.md
                            BG
                            • HumidorH Humidor
                              @humidor
                              Ja, z.B.
                              • HumidorH Humidor
                                crunchipC Abwesend
                                crunchipC Abwesend
                                @humidor oder die v1.4.0 installieren, sollte klappen.
                                In deinem Fall jedoch, installier neu damit hast du dann nodejs auf aktuellem stand
                                  @humidor
                                  Ja, z.B.
                                  HumidorH Offline
                                  HumidorH Offline
                                  Humidor
                                  @thomas-braun ich habe jetzt per prompt den raspi und iobroker installiert
                                  bevor ich nun mein Backup wiederherstelle, sollte ich noch etwas tun?
                                  BG
                                  • HumidorH Humidor
                                    @humidor
                                    Wenn im dem Backup der vis-Adapter drin ist installier vorab eine der Vorversionen.
                                      @humidor
                                      HumidorH Offline
                                      HumidorH Offline
                                      Humidor
                                      @thomas-braun wie kann ich das, er gibt mir im iobroker nur die 1.4.15 frei
                                      dh dann über prompt, ist das:
                                      BG
                                      • HumidorH Humidor
                                        @humidor
                                        Ja.
                                          @humidor
                                          Ja.
                                          HumidorH Offline
                                          HumidorH Offline
                                          Humidor
                                          @thomas-braun jetzt zeigt er mir die VIS in den Adapter an, unter Instanzen scheint diese aber nicht auf
                                          muss diese jetzt noch installiert werden?
                                          BG
