  4. Test Tesla-Motors v2.0.x
1.0k Beiträge 112 Kommentatoren 402.7k Aufrufe 101 Beobachtet
  • E exmerci
    Adapter    "admin"        : 6.2.22   , installed 6.2.22
    Adapter    "alexa2"       : 3.19.9   , installed 3.19.9
    Adapter    "backitup"     : 2.4.12   , installed 2.4.12
    Adapter    "cloud"        : 4.2.2    , installed 4.2.2
    Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
    Adapter    "discovery"    : 3.0.5    , installed 3.0.5
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "email"        : 1.1.3    , installed 1.1.3
    Adapter    "fb-checkpresence": 1.1.19, installed 1.1.19
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
    Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
    Adapter    "ham"          : 5.3.0    , installed 5.3.0
    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
    Adapter    "history"      : 2.2.0    , installed 2.2.0
    Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
    Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
    Adapter    "hs100"        : 2.1.2    , installed 2.1.2
    Adapter    "ical"         : 1.13.1   , installed 1.13.1
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iot"          : 1.11.9   , installed 1.11.9
    Adapter    "javascript"   : 6.0.3    , installed 6.0.3
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "lgtv11"       : 1.0.5    , installed 1.0.5
    Adapter    "luftdaten"    : 2.2.4    , installed 2.2.4
    Adapter    "maxcube"      : 1.0.4    , installed 1.0.4
    Adapter    "meross"       : 1.14.0   , installed 1.14.0
    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
    Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
    Adapter    "onvif"        : 0.4.4    , installed 0.4.4
    Adapter    "parcel"       : 0.0.20   , installed 0.0.20
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "shelly"       : 6.0.0    , installed 6.0.0
    Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
    Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "spotify-premium": 1.2.1  , installed 1.2.1
    Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
    Adapter    "telegram"     : 1.14.1   , installed 1.14.1
    Adapter    "tesla-motors" : 1.3.0    , installed 1.3.0
    Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
    Adapter    "trashschedule": 2.0.3    , installed 2.0.3
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "vis-lcars"    : 1.0.4    , installed 1.0.4
    Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
    Adapter    "whatsapp-cmb" : 0.2.2    , installed 0.2.2
    Adapter    "yahka"        : 0.13.1   , installed 0.13.1
    Adapter    "yamaha"       : 0.5.3    , installed 0.5.3
    Ich dachte ich könnte jetzt weitermachen, aber ich habe keine Tesla Instanz
    #572
    @exmerci sagte in Test Tesla-Motors v1.0.0:
    Weil bei Installationen aus dem GitHub eine Instanz manuell hinzugefügt werden muss.
    Wäre bei ordentlicher Installation aus den Repos nicht erforderlich.
    E 1 Antwort Letzte Antwort
      exmerci
      #573
      Und wie geht das?
      Oder kann ich das jetzt wieder deinstallieren (wie ohne Instanz) und normal wieder installieren?
      • E exmerci
        Und wie geht das?
        #574
        @exmerci
        iobroker upgrade tesla-motors@1.3.0
          @exmerci
          exmerci
          #575
          @thomas-braun sagte in Test Tesla-Motors v1.0.0:
          Irgendwie tut sich da nichts. Der Adapter ist weiterhin installiert, aber keine Instanz.
          • E exmerci
            #576
            @exmerci
            Dann klick auf das +-Zeichen.
            Oder
            iobroker add tesla-motors.0
              @exmerci
              Oder
              exmerci
              schrieb am zuletzt editiert von exmerci
              #577
              Soweit so gut. Leider klappt der Login nicht. Mal suchen, ob in dem Thread schon etwas darüber steht.
              PS. Jetzt geht es. Ich musste einen Teil aus der Browserzeile entfernen. Hatte ich übersehen.
              • lobomauL lobomau
                @danielos vampire drain war zuletzt kein Problem mit dem Adapter. Bist du aktuell? Bei mir läuft 1.3.0.
                Aktualisiert bei mir alle 15s.
                exmerci
                #578
                @lobomau sagte in Test Tesla-Motors v1.0.0:
                ich bin noch neu was Tesla und diesen Thread betrifft.
                Was heisst "vampire drain war zuletzt kein Problem"?
                Wenn ich das richtig verstanden habe, ist es so, wenn ich alle 60 Sekunden aktualisiere, schläft das Auto nie ein, oder?
                Das heisst doch aber auch, das immer ordentlich Akku verbraucht wird, oder? Macht das Sinn? Angenommen das Auto steht mal eine Woche ohne Ladekabel, dann könnte es sein, das es dann leer ist, richtig?
                • E exmerci
                  lobomauL Offline
                  lobomauL Offline
                  lobomau
                  schrieb am zuletzt editiert von lobomau
                  #579
                  @exmerci genau... meiner schläft nach 10min ein, wenn ich ihn in Ruhe lasse. Und das mache ich auch. Ist also meistens am Schlafen, wenn nicht gerade geladen oder gefahren wird. Nicht schlafen lassen kostet bestimmt 2-3% Tag. Sonst bist du unter 1%.
                  Mit meinen Einstellungen habe ich kein Problem. Wenn er trotzdem nicht schläft, kann es an einem Script liegen, dass andauernd Daten abruft. Der Adapter alleine macht kein Problem.
                  Host: NUC8i3 mit Proxmox:
                  • Slave: Pi4
                  • lobomauL lobomau
                    exmerci
                    #580
                    @lobomau
                    Wenn er nicht geladen wird. Ok. Und wie machst du das? Weckst du ihn alle 10 Minuten auf, solange das Kabel dran hängt?
                    Und wie merkt der Adapter, das dass Kabel angeschlossen wurde?
                    • E exmerci
                      @lobomau
                      lobomauL Offline
                      lobomauL Offline
                      lobomau
                      #581
                      @exmerci nein, auch mit Kabel dran schläft er ein, wenn nicht gerade geladen wird.
                      Der Adapter ist so gemacht, dass er nur Daten regelmäßig abruft, wenn der Tesla nicht schläft.
                      Stelle alle SCripte mal auf aus und nimm meine Einstellungen. Dann sollte er nach 10 min einschlafen. Oder du hast noch Drittsoftware-Geschichten am Laufen undabhängig von ioBroker.
                      Edit: wenn das Kabel angeschlossen wird, ist/wird der Tesla natürlich erstmal wach und schläft nach 10min wieder ein, wenn nicht geladen wird.
                      • Slave: Pi4
                      • lobomauL lobomau
                        exmerci
                        #582
                        @lobomau
                        Ich habe noch gar nichts am Laufen, sondern wollte erst anfangen. Aber gleich richtig :)
                        Also wenn du nach Haus kommst, und das Kabel anschliesst oder aber schon zu Hause bist und das Kabel anschliesst, merkt das Script das?
                        Und das Script merkt auch von selbst, wenn der Wagen nicht geladen wird, oder wie hältst du ihn für die Zeit wach?
                        • E exmerci
                          @lobomau
                          lobomauL Offline
                          lobomauL Offline
                          lobomau
                          #583
                          Richtig.
                          wenn nicht geladen und sonst nichts mit dem Auto gemacht wird, also auch nicht Handyapp benutzt wird, schläft der Tesla dann nach 10min ein und dann gibts auch keine Daten mehr zum Adapter. Also als permanten Außenlufttemperatur Sensor ist der Tesla nur bedingt geeignet ;-)
                          Aber da ich kein Programmierer bin, kann ich jetzt auch nicht sagen wie es exakt funktioniert.
                          • Slave: Pi4
                          • lobomauL lobomau
                            Richtig.
                            exmerci
                            #584
                            Dafür habe ich auch Thermometer, die keine 60K € kosten. :)
                            Danke für die Erklärungen. Dann werde ich mir mal was zusammenbasteln.
                            • E Offline
                              exmerci
                              #585
                              Vielleicht bin ich wieder blind, aber gibt es einen Datenpunkt, in dem man sehen kann, wann die Daten das letzte mal aktualisiert wurden?
                              JLegJ 1 Antwort Letzte Antwort
                              • E exmerci
                                JLegJ Offline
                                JLegJ Offline
                                JLeg
                                #586
                                …jeder Datenpunkt hat (mehrere) Zeitstempel - z.B. bei Blockly mal die Auswahl beim „Objekt“ (Trigger) ausklappen…
                                • D danielos
                                  Guten Tag zusammen
                                  Zuerst einmal vielen, vielen herzlichen Dank für den Adapter. Ich liebe diesen und ermöglicht mir vieles, das ich sonst schmerzlich vermissen würde.
                                  Ich habe jedoch ein grosses Problem mit Vampire Drain, das ich nun wirklich mal beheben muss und hoffe, ihr könnt mir dabei helfen.
                                  Ich habe eine PV Anlage auf dem Dach und aufgrund der Hausinstallation ist es leider nicht möglich, dass Überschussladen direkt von der Ladestation zu machen, weshalb ich folgenden Workaround gemacht habe:
                                  1. PV-Anlage prüft, ob es "Überschuss" gibt
                                  2. Sofern dies der Fall ist, wird beim Tesla das Laden gestartet (je nach verfügbarer Energie mit 1 - 15 AMP) -> der verfügbare Überschuss führt im Minutentakt zu Anpassungen an den AMPs.
                                  Da dieser Workflow nur gestartet werden soll, wenn der Tesla in der Garage steht und angeschlossen ist, wird natürlich immer geprüft, ob dies der Fall ist. Das führt nun aber dazu, dass mein Auto nicht mehr schläft und so ungefähr 3-4% pro Nacht verliert, was massiv ist.
                                  Aktuell habe ich den Intervall auf 10 Sekunden gestellt, vermutlich ist dies das Problem. Am Allerliebsten wäre mir nun eben eigentlich ein Skript, das den Adapter komplett abschaltet, wenn es keinen Überschuss gibt (z.B. die ganze Nacht). Das dürfte das Problem beheben.
                                  Oder habt ihr andere Ideen bzw. wäre sowas überhaupt möglich? Wenn ich den Intervall auf mehr als 10 Sekunden stelle, dürfte dies ja das Problem nicht beheben. Einerseits dürfte es Probleme geben, weil der eigentliche Flow allenfalls nicht mehr funktioniert und andererseits das Auto dann wohl dennoch nicht schläft.
                                  Danke für eure Hilfe!!
                                  dpcFan
                                  #587
                                  @danielos Hallo! Mein UseCase ist gleich und es stoppt derzeit noch am Adapter, der baut keine Connection auf... "Invalid codeURL please visit instance settings and copy url after login" obwohl ich nun alles gemacht habe, was in der Doku steht! Wenn ich aber das PRoblem gelöst habe, kommt es zum "Nachbauen", worin hast Du die Logik umgesetzt? JavaScript? Kannst Du mir das Script zur Verfügung stellen (ich bin nicht faul, habe das Auto grade ne Woche und will nicht Nächte verbringen, es in meine Haustechnik zu integrieren....).
                                  T E 2 Antworten Letzte Antwort
                                  • D dpcFan
                                    tombox
                                    #588
                                    @dpcfan hast du 1.3.1 installiert?
                                    • T tombox
                                      dpcFan
                                      #589
                                      • D dpcFan
                                        tombox
                                        #590
                                        @dpcfan Mal via GitHub oder npm installieren
                                        • D dpcFan
                                          exmerci
                                          #591
                                          @dpcfan
                                          Wenn du immer noch das Login Problem hast, nimm mal aus der kopierten URL das locale=de-DE& raus.
                                          Der Code muss nicht so:
                                          https://auth.tesla.com/void/callback?locale=de-DE&code=
                                          sondern so aussehen.
                                          https://auth.tesla.com/void/callback?code=
