  4. Proxmox VM ioBroker Installation kein Web Zugriff
    5.6k
25 Beiträge 6 Kommentatoren 3.1k Aufrufe 8 Beobachtet
    @burningbaer sagte in Proxmox VM ioBroker Installation kein Web Zugriff:
    steht dort wieder "Webseite ist nicht erreichbar".
    läuft der admin?
    iob list instances per Konsole prüfen, falls dieser nicht läuft iob start admin
    oder starte die VM mal neu und probier dann
    burningbaer
    @crunchip
    Da scheint auf alle Fälle etwas nicht in Ordnung zu sein. 😥
    cbaer@iobroker:~$ iob list instances
    node:internal/modules/cjs/loader:959
    throw err;
    Error: Cannot find module 'node-forge'
    Require stack:
    • /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js
    • /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
    • /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
    • /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
      at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15 )
      at Function.Module._load (node:internal/modules/cjs/loader:804:27)
      at Module.require (node:internal/modules/cjs/loader:1028:19)
      at require (node:internal/modules/cjs/helpers:102:18)
      at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-co mmon/lib/common/tools.js:7:15)
      at Module._compile (node:internal/modules/cjs/loader:1126:14)
      at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
      at Module.load (node:internal/modules/cjs/loader:1004:32)
      at Function.Module._load (node:internal/modules/cjs/loader:839:12)
      at Module.require (node:internal/modules/cjs/loader:1028:19) {
      code: 'MODULE_NOT_FOUND',
      requireStack: [
      '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools. js',
      '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
      '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
      '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
      cbaer@iobroker:~$ iob start admin
      throw err;
    Require stack:
      at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15)
      at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:7:15)
      requireStack: [
      '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js',
    Was kann ich da beim installieren vergessen haben?
    wendy2702W crunchipC 2 Antworten Letzte Antwort
    • B burningbaer
      @crunchip
      throw err;
      Require stack:
        requireStack: [
        throw err;
      Require stack:
        requireStack: [
      wendy2702W Offline
      wendy2702W Offline
      @burningbaer was für ein Linux hast du als unterbau verwendet?
      • B burningbaer
        @crunchip
        throw err;
        Require stack:
          requireStack: [
          throw err;
        Require stack:
          requireStack: [
        crunchipC Abwesend
        crunchipC Abwesend
        eigentlich nix und du hast dich sicher an die Anleitung gehalten?
        Denn dann bleibt die Frage offen, wie schon gefragt, was du verwendet hast, Debian, Ubuntu....?
        • wendy2702W wendy2702
          burningbaer
          @wendy2702
          Ich habe folgendes Debian verwendet:
          Dieses habe ich dort herunter geladen, wie in der Beschreibung zu lesen ist.
          Als ich das ganze über LXC eingerichtet habe, hatte ich Ubuntu benutzt. Dort hatte ich keine Probleme.
          • B burningbaer
            @wendy2702
            crunchipC Abwesend
            crunchipC Abwesend
            @burningbaer komisch, sollte mit debian aber funktionieren, probier es doch nochmal, vllt ging da irgendwas beim install schief
              burningbaer
              schrieb am zuletzt editiert von burningbaer
              So,
              ich bin jetzt noch einmal die ganze Anleitung durch gegangen.
              Proxmox habe ich ebenfalls neu installiert nach dieser Anleitung.
              Habe jetzt Zugriff auf iobroker über Browser. Woran es jetzt genau lag, kann ich leider nicht sagen, aber wenigstens funktioniert es jetzt.
              Werde jetzt mal in Ruhe anfangen alles einzurichten, da kommt bestimmt noch die ein oder andere Frage! 😬
              Vielen Dank für eure Hilfe und Geduld. 👍
              Wenn ich jetzt influxdb und Grafana noch installieren möchte, würdet ihr Vorschlagen dieses in der gleichen VM wie iobroker zu machen, eine neue VM für jeweils influx und Grafana oder im LXC?
              wendy2702W da_WoodyD 2 Antworten Letzte Antwort
              • B burningbaer
                So,
                wendy2702W Offline
                wendy2702W Offline
                @burningbaer Ich würde einzelne VM's machen.
                Ist einfacher aus meiner Sicht die bessere Wahl.
                  burningbaer
                  Danke,
                  wird im Angriff genommen.
                  • crunchipC Abwesend
                    crunchipC Abwesend
                    dafür hat man ja proxmox und legt separate Maschinen an, ist auch leichter zu handhaben, wenn alles getrennt läuft, ausser der Rechner ist leistungstechnisch nicht der Renner, dann jedoch sollte man generell über bessere Hardware nachdenken, bzw ob warum man proxmox überhaupt nutzen möchte
                    • B burningbaer
                      So,
                      da_WoodyD Online
                      da_WoodyD Online
                      nein, eigene VM! wobei ich influx und grafana in einer VM habe. gehört für mich einfach zusammen.
                      ob ich das auch trennen würde? ich kanns dir nicht sagen....
                        burningbaer
                        So,
                        das Grundlegenste läuft jetzt erstmal. Vielen Dank für all eure Hilfe und Ratschläge.
                        Jetzt werde ich mich mit den Feinheiten beschäftigen und versuchen die alte Datenbank auf die Neue zu übertragen. Bin aber froh, dass der Rest schon einmal läuft! 😁
                        G 1 Antwort Letzte Antwort
                        • B burningbaer
                          So,
                          guergen
                          @burningbaer Ich habe alles in eigenen LXC´s, ausser es braucht nen USB-Anschluss, dann ist es einfacher eine VM zu nehmen
                          • G guergen
                            burningbaer
                            @guergen said in Proxmox VM ioBroker Installation kein Web Zugriff:
                            So habe ich es jetzt auch gemacht. Iobroker in VM Rest in LXC. Ist wohl die einfachste Lösung.
                              burningbaer
                              Ich hoffe ich darf hier im Thread noch etwas fragen.
                              Kennt jemand eine Anleitung, wie ich InfluxDB in Version 1 installiere.
                              Bekomme es einfach nicht hin. Die Anleitungen die ich gefunden habe sind wahrscheinlich zu alt.
                              Ich habe eine gefunden für InfluxDB 2x die auch funktioniert, aber ich komme mit Version2 nicht klar und würde gerne Version1x installieren.
                              • B burningbaer
                                @burningbaer
                                Mit apt?
                                Ganz normal wie man halt Programme/Pakete grundsätzlich installiert.
                                apt policy influxdb
                                sollte dir eine Version 1.8 anzeigen.
                                Installation mit
                                sudo apt install influxdb
                                  @burningbaer
                                  Mit apt?
                                  apt policy influxdb
                                  Installation mit
                                  burningbaer
                                  @thomas-braun said in Proxmox VM ioBroker Installation kein Web Zugriff:
                                  @burningbaer
                                  Mit apt?
                                  apt policy influxdb
                                  Installation mit
                                  Installiert hatte ich es, aber bekam im iobroker keinen Zugriff. Hatte auch User und alles erstellt, aber klappte leider nicht. Egal, werde mich mit InfluxDB 2x mal beschäftigen. Muss man sich ja anscheinend sowieso daran eines Tages gewöhnen.
                                  L 1 Antwort Letzte Antwort
