  4. Beca Thermostate einbinden (Firmware-Mod)
    5.3k
tuyamqttmqttraumthermostat
135 Beiträge 18 Kommentatoren 29.7k Aufrufe 14 Beobachtet
  • T TH16
    @mickym
    @Wal
    @berlinerbolle
    So sieht danach mein Log aus. Ist mir zu hoch. 😕
    mqtt.1 2021-05-07 19:38:45.828 info (28742) Starting MQTT authenticated server on 0.0.0.0:1887
    mqtt.1 2021-05-07 19:38:45.607 info (28742) starting. Version 2.3.5 in /opt/iobroker/node_modules/iobroker.mqtt, node: v12.22.1, js-controller: 3.2.16
    mqtt.1 2021-05-07 19:38:45.591 info (28742) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    host.raspberrypi 2021-05-07 19:38:44.184 info instance system.adapter.mqtt.1 started with pid 28742
    host.raspberrypi 2021-05-07 19:38:42.184 info instance system.adapter.mqtt.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.raspberrypi 2021-05-07 19:38:42.022 info stopInstance system.adapter.mqtt.1 killing pid 28727
    mqtt.1 2021-05-07 19:38:41.526 info (28727) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    mqtt.1 2021-05-07 19:38:41.524 info (28727) terminating
    mqtt.1 2021-05-07 19:38:41.021 info (28727) Got terminate signal TERMINATE_YOURSELF
    host.raspberrypi 2021-05-07 19:38:41.021 info stopInstance system.adapter.mqtt.1 send kill signal
    host.raspberrypi 2021-05-07 19:38:41.014 info stopInstance system.adapter.mqtt.1 (force=false, process=true)
    mqtt.1 2021-05-07 19:38:32.645 info (28727) Starting MQTT authenticated server on 0.0.0.0:1887
    mqtt.1 2021-05-07 19:38:32.106 info (28727) starting. Version 2.3.5 in /opt/iobroker/node_modules/iobroker.mqtt, node: v12.22.1, js-controller: 3.2.16
    mqtt.1 2021-05-07 19:38:32.090 info (28727) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    host.raspberrypi 2021-05-07 19:38:30.549 info instance system.adapter.mqtt.1 started with pid 28727
    host.raspberrypi 2021-05-07 19:38:28.506 info instance system.adapter.mqtt.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.raspberrypi 2021-05-07 19:38:28.345 info stopInstance system.adapter.mqtt.1 killing pid 28649
    mqtt.1 2021-05-07 19:38:27.845 info (28649) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    mqtt.1 2021-05-07 19:38:27.843 info (28649) terminating
    host.raspberrypi 2021-05-07 19:38:27.340 info stopInstance system.adapter.mqtt.1 send kill signal
    mqtt.1 2021-05-07 19:38:27.340 info (28649) Got terminate signal TERMINATE_YOURSELF
    host.raspberrypi 2021-05-07 19:38:27.320 info stopInstance system.adapter.mqtt.1 (force=false, process=true)
    mqtt.1 2021-05-07 19:37:03.930 info (28649) Client [wthermostat-4652331] publishOnSubscribe send all known states
    mqtt.1 2021-05-07 19:37:03.930 info (28649) Client [wthermostat-4652331] subscribes on "Thermostat-9-Flur-2OG/cmnd/#" with regex /^mqtt.1.Thermostat-9-Flur-2OG.cmnd../
    mqtt.1 2021-05-07 19:37:03.929 info (28649) Client [wthermostat-4652331] subscribes on "Thermostat-9-Flur-2OG/cmnd/#" with regex /^Thermostat-9-Flur-2OG.cmnd..
    mqtt.1 2021-05-07 19:37:03.929 info (28649) Client [wthermostat-4652331] unsubscribes on "mqtt.1/devices/#"
    mqtt.1 2021-05-07 19:37:03.928 info (28649) Client [wthermostat-4652331] unsubscribes on "devices/#"
    mqtt.1 2021-05-07 19:37:03.927 info (28649) Client [wthermostat-4652331] publishOnSubscribe send all known states
    mqtt.1 2021-05-07 19:37:03.927 info (28649) Client [wthermostat-4652331] subscribes on "devices/#" with regex /^mqtt.1.devices../
    mqtt.1 2021-05-07 19:37:03.926 info (28649) Client [wthermostat-4652331] subscribes on "devices/#" with regex /^devices..
    mqtt.1 2021-05-07 19:37:03.923 info (28649) Client [wthermostat-4595681] publishOnSubscribe send all known states
    mqtt.1 2021-05-07 19:37:03.923 info (28649) Client [wthermostat-4595681] subscribes on "Thermostat-11-Bad oben/cmnd/#" with regex /^mqtt.1.Thermostat-11-Bad_oben.cmnd../
    mqtt.1 2021-05-07 19:37:03.922 info (28649) Client [wthermostat-4595681] subscribes on "Thermostat-11-Bad oben/cmnd/#" with regex /^Thermostat-11-Bad_oben.cmnd..
    mqtt.1 2021-05-07 19:37:03.921 info (28649) Client [wthermostat-4595681] unsubscribes on "mqtt.1/devices/#"
    mqtt.1 2021-05-07 19:37:03.921 info (28649) Client [wthermostat-4595681] unsubscribes on "devices/#"
    mqtt.1 2021-05-07 19:37:03.918 info (28649) Client [wthermostat-4595681] publishOnSubscribe send all known states
    mqtt.1 2021-05-07 19:37:03.918 info (28649) Client [wthermostat-4595681] subscribes on "devices/#" with regex /^mqtt.1.devices../
    mqtt.1 2021-05-07 19:37:03.917 info (28649) Client [wthermostat-4595681] subscribes on "devices/#" with regex /^devices..
    mqtt.1 2021-05-07 19:37:03.914 info (28649) Client [wthermostat-4595736] publishOnSubscribe send all known states
    mqtt.1 2021-05-07 19:37:03.913 info (28649) Client [wthermostat-4595736] subscribes on "Thermostat-8-Patrick/cmnd/#" with regex /^mqtt.1.Thermostat-8-Patrick.cmnd../
    mqtt.1 2021-05-07 19:37:03.913 info (28649) Client [wthermostat-4595736] subscribes on "Thermostat-8-Patrick/cmnd/#" with regex /^Thermostat-8-Patrick.cmnd..
    mqtt.1 2021-05-07 19:37:03.909 info (28649) Client [wthermostat-4595736] unsubscribes on "mqtt.1/devices/#"
    mqtt.1 2021-05-07 19:37:03.908 info (28649) Client [wthermostat-4595736] unsubscribes on "devices/#"
    mqtt.1 2021-05-07 19:37:03.906 info (28649) Client [wthermostat-4595736] publishOnSubscribe send all known states
    mqtt.1 2021-05-07 19:37:03.905 info (28649) Client [wthermostat-4595736] subscribes on "devices/#" with regex /^mqtt.1.devices../
    mqtt.1 2021-05-07 19:37:03.905 info (28649) Client [wthermostat-4595736] subscribes on "devices/#" with regex /^devices..
    mqtt.1 2021-05-07 19:37:03.891 info (28649) Client [wthermostat-4598897] publishOnSubscribe send all known states
    mqtt.1 2021-05-07 19:37:03.891 info (28649) Client [wthermostat-4598897] subscribes on "Thermostat-10-Schlafzimmer/cmnd/#" with regex /^mqtt.1.Thermostat-10-Schlafzimmer.cmnd../
    mqtt.1 2021-05-07 19:37:03.890 info (28649) Client [wthermostat-4598897] subscribes on "Thermostat-10-Schlafzimmer/cmnd/#" with regex /^Thermostat-10-Schlafzimmer.cmnd..
    mqtt.1 2021-05-07 19:37:03.888 info (28649) Client [wthermostat-4598897] unsubscribes on "mqtt.1/devices/#"
    mqtt.1 2021-05-07 19:37:03.888 info (28649) Client [wthermostat-4598897] unsubscribes on "devices/#"
    mqtt.1 2021-05-07 19:37:03.884 info (28649) Client [wthermostat-4598897] publishOnSubscribe send all known states
    mqtt.1 2021-05-07 19:37:03.884 info (28649) Client [wthermostat-4598897] subscribes on "devices/#" with regex /^mqtt.1.devices../
    mqtt.1 2021-05-07 19:37:03.883 info (28649) Client [wthermostat-4598897] subscribes on "devices/#" with regex /^devices..
    mqtt.1 2021-05-07 19:37:03.870 info (28649) Client [wthermostat-4652331] connected with secret 1620409023859_5461
    mqtt.1 2021-05-07 19:37:03.867 info (28649) Client [wthermostat-4595681] connected with secret 1620409023858_2356
    mqtt.1 2021-05-07 19:37:03.864 info (28649) Client [wthermostat-4595736] connected with secret 1620409023857_7572
    mqtt.1 2021-05-07 19:37:03.696 info (28649) Client [wthermostat-4598897] connected with secret 1620409023679_3962
    WalW Offline
    WalW Offline
    Wal
    #112
    @th16 ,
    da stimmt was ganz gewaltiges bei dir nicht.
    Dein Server reconnectet mehrmals.
    Walter
    DoorIO-Adapter
    • WalW Wal
      @berlinerbolle ,
      ja man braucht den TuyaMCU,settime und Skript Support deshalb muss die Firmware selbst erstellt werden.
      berlinerbolle
      #113
      @wal
      Ah, danke. Davon lasse ich wahrscheinlich lieber die Finger...oder gibt es hervorstechende Vorteile, das Ganze mit Tasmota zu betreiben?
      Gibt es dazu eventuell irgendwo eine Anleitung die ich befolgen kann, falls ich es an einem verregneten Tag mal ausprobieren möchte? Ich glaube einen Thermostat hab ich noch als Reserve zum Rumspielen (auch wenn ich keine Lust hab wieder zu löten, falls ich was kaputt mache).
      WalW 1 Antwort Letzte Antwort
      • B berlinerbolle
        @wal
        WalW Offline
        WalW Offline
        Wal
        #114
        @berlinerbolle,
        nein gibt es nicht, ein Thermostat ist ein Thermostat.
        Du hast bei Fas noch den Vorteil mit dem Schedule, das geht bei Tasmota noch nicht.
        Walter
        DoorIO-Adapter
        • mickymM mickym
          @th16 Mach mal die Code-Tags um Dein Log. Aber das sieht doch gar nicht so schlecht aus, man sieht wie sich die Thermostate mit Deinem Broker verbinden.
          Wichtig ist erst mal nur der Filter:
          und wie gesagt das Senden von allen States beim Verbinden ist auch quatsch. Du sendest aktuell ein Kommando und sonst gar nichts. Es gibt nichts was die Thermostaten interessiert ausser dem was unter Deinem cmnd Ast steht. Falls das was im cmnd Ast drinsteht, wird das in der Regel sofort vom Tasmota gerät gecheckt, da dieses den cmnd Ast abonniert hat und somit sofort auf die Änderungen reagiert.
          Das siehst Du übrigens an diesen Meldungen: Thermostat-11-Bad oben/cmnd/#"
          Hier sagt Dir der Adapter, dass das Thermostat diesen Ast subscibed also abondiert hat.
          Warum Dein Adapter allerdings abschmiert - weiß ich auch nicht - wie gesagt - ich würde mit dem Adapter nur als CLient arbeiten und als broker mosquitto nehmen. Man sieht ja an @berlinerbolle - das ich hier nicht der Einzige mit solchen Erfahrungen bin und er deshalb die gleiche Konfig wie ich genommen hat.
          TH16
          #115
          @mickym
          @Wal
          @berlinerbolle
          ENDLICH, ES FUNKTIONIERT !!! 👍 👍 👍 👏
          Nachdem ich jetzt nun nochmal alles neu gestartet habe und über Alexa und auch manuell den Wert geändert habe, funktioniert es endlich.
          1000 Dank an alle Beteiligten, die mir diesen steinigen Weg geebnet haben! 👏
          • T TH16
            @mickym
            @Wal
            @berlinerbolle
            mickymM Offline
            mickymM Offline
            mickym
            #116
            @th16 Na herzlichen Glückwunsch. Ich weiß es sieht oft alles sehr verwirrend aus, was der Adapter alles ins Log reinschreibt und in meinen Augen gehört fast alles auf das Debug Level und nicht auf das Info Level, was hier rausgespukt wird, das schreibt Dir nämlich das ganze Log voll. Ich hab zumindest den "großen" Adapter nun auf "warn" Level eingestellt. ;)
            T 2 Antworten Letzte Antwort
            • mickymM mickym
              TH16
              schrieb am zuletzt editiert von TH16
              #117
              @mickym
              @Wal
              @berlinerbolle
              Das Problem ist am Ende immer, dass man einfach nicht alles wissen kann.
              Ich habe mich auch erst seit Mitte/Ende letzten Jahres mit Smart Home, speziell mit ioBroker und dem ganzen Zubehör beschäftigt. Und obwohl ich seit dem sehr vieles dazu gelernt habe und fast das ganze Haus den Garten usw. automatisiert habe, möchte ich meine Kenntnisse auf sehr gering einschätzen und ich Danke hier jedem, der einem weiterhilft. Die verschiedenen Themen sind so Umfangreich und manche "Logiken" doch nicht so logisch wie man erwartet usw.
              Doch auf Eines konnte ich mich immer verlassen, dass einem hier geholfen wird.
              Also nochmals VIELEN DANK ! 👍
              Einen schönen Abend an Alle und ein schönes WE.
              • mickymM mickym
                TH16
                #118
                @mickym
                @Wal
                @berlinerbolle
                eine Frage hätte ich da noch, weil doch unterschiedliche Temperaturen angezeigt werden.
                Wie kann ich an dem Thermostat ein Temperaturoffset einstellen?
                Leider konnte ich nichts dazu finden.
                Beim "normalen Tasmota" kann man das über die Konsole einstellen, doch die gibt es bei der Version von Fashberg nicht, oder hab ich da was übersehen?
                Thermostat ist BHT-002GALW mit der Firmware von Fashberg 1.19
                • O Online
                  O Online
                  oxident
                  #119
                  Hallo zusammen!
                  Weiß jemand, ob man derzeit bei Amazon noch "flashbare" Modelle bekommt oder sind nutzen die mittlerweile alle schon den anderen Chipsatz?
                  WalW B 2 Antworten Letzte Antwort
                  • O oxident
                    Hallo zusammen!
                    WalW Offline
                    WalW Offline
                    Wal
                    schrieb am zuletzt editiert von Wal
                    #120
                    @oxident ,
                    ich denke das die älteren Geräte wie das BHT-002 oder das Beca Smart 6000 alle noch funktionieren da die nicht mehr gebaut werden, sondern nur abverkauft werden, ist aber nur eine Vermutung.
                    Die Teile kosten aber auch doppelt so viel und man muss Lötkenntnisse besitzen.
                    Walter
                    DoorIO-Adapter
                    O 1 Antwort Letzte Antwort
                    • WalW Wal
                      @oxident ,
                      O Online
                      O Online
                      oxident
                      #121
                      @wal Danke, das hilft mir weiter. Meinst Du denn, es besteht auch bei diesen Geräte eventuell noch die Chance, dass man die Firmware ohne Umlöten umflashen kann?
                      B WalW 2 Antworten Letzte Antwort
                      • O oxident
                        berlinerbolle
                        #122
                        @oxident
                        Glückssache, aber meiner Erfahrung nach inzwischen relativ unwahrscheinlich. Ich meine die Chancen stehen aber besser, wenn man hier auf Amazon kauft (und den höheren Preis bezahlt), als wenn man direkt aus China bestellt. Vorausgesetzt natürlich, die Geräte lagern auch hier in Deutschland und werden nicht erst importiert.
                        • B berlinerbolle
                          @oxident
                          O Online
                          O Online
                          oxident
                          #123
                          @berlinerbolle Alles klar, werde es versuchen und dann Rückmeldung geben. Danke Euch!
                          • O oxident
                            Hallo zusammen!
                            berlinerbolle
                            #124
                            @oxident said in Beca Thermostate einbinden (Firmware-Mod):
                            Hallo zusammen!
                            Ein Indikator ist (leider) zum Beispiel die Auflösung der Temperatur. Die neuen Geräte haben da teilweise Auflösungen von 0.1, die Alten so weit ich weiß maximal 0.5
                            • O oxident
                              WalW Offline
                              WalW Offline
                              Wal
                              #125
                              @oxident sagte in Beca Thermostate einbinden (Firmware-Mod):
                              Ich musste die Thermostate immer über einen Adapter flashen, Tuya-Convert hat bei mir da nicht funktioniert.
                              Walter
                              DoorIO-Adapter
                              • WalW Wal
                                O Online
                                O Online
                                oxident
                                schrieb am zuletzt editiert von oxident
                                #126
                                @wal Ok, bin jetzt doch eingeknickt und mache es lieber mit'nem Shelly und Temperaturfühler.
                                Löten schaff ich nicht ;-)
                                • O oxident
                                  WalW Offline
                                  WalW Offline
                                  Wal
                                  #127
                                  Du kannst dir auch den Thread über das Sonoff Panel anschauen falls du was mit Display möchtest, das hat eine Thermostat Funktion.
                                  Walter
                                  DoorIO-Adapter
                                  P 1 Antwort Letzte Antwort
                                  • WalW Wal
                                    Paulbaumann
                                    #128
                                    @wal
                                    Hallo
                                    ich bin neu hier weil
                                    Ich irgendwie in Kontakt mit
                                    Klaus Ahrensberg bzw. den Entwicklern
                                    kommen will.
                                    Habe schon diverse Sachen mit Tuya-convert entclouded
                                    Was will ich?
                                    Ein WLAN Raumthermostat kaufen das ich via Tuya-convert entclouden und dann mit der Ahrensberg Firmware betreiben kann
                                    Problem:
                                    Er gibt 8 Modelle als kompatibel an, leider alles Unterputz Thermostate.
                                    Ich brauche aber ein Aufputz Raumthermostat.
                                    Welches nehmen, was geht?
                                    Würde ungern irgendein WLAN Raumthermostat mit ESP8266 entclouden wenn es dann nicht funktioniert.
                                    • P Paulbaumann
                                      @wal
                                      Hallo
                                      kommen will.
                                      Was will ich?
                                      Problem:
                                      berlinerbolle
                                      #129
                                      @paulbaumann
                                      Warum so kompliziert? Nimm doch einfach eine Aufputzdose, und baue dort ein unterstütztes Thermostat deiner Wahl ein. Da gibt es auch Dosen, die nicht hässlich sind...vor allem nicht hässlicher, als die Gehäuse potentieller Aufputz-Thermostate.
                                      • P Paulbaumann
                                        @wal
                                        Hallo
                                        kommen will.
                                        Was will ich?
                                        Problem:
                                        WalW Offline
                                        WalW Offline
                                        Wal
                                        #130
                                        @paulbaumann ,
                                        das mit der Aufputzdose von @berlinerbolle ist eine gute Idee, aber ich hatte wie gesagt noch kein Thermostat das mit Tuya-Convert zu fashen ging und für den Status vom Relais muss eh gelötet werden.
                                        Walter
                                        DoorIO-Adapter
                                        • P Offline
                                          Paulbaumann
                                          #131
                                          Danke für die schnellen Antworten, aber ich kann damit nichts anfangen.
                                          Wahrscheinlich setzt man bei mir zuviel voraus.
                                          Ich kann definitiv nicht löten und bin froh wenn ich mein 08/15 Theben Drehregler (Aufputz) von der Wand bekomme. Habe eher 2 linke Hände. Dafür kenne ich mich besser mit Tyua-konvert aus. Brauche schon so ein Aufputz Thermostat sons
                                          t muss ich das Handtuch werfen
                                          P B 2 Antworten Letzte Antwort
