  4. iobroker restore 0 funktioniert nicht
61 Beiträge 4 Kommentatoren 7.0k Aufrufe 3 Beobachtet
  • funkytownF funkytown
    markus@rpi:/opt/iobroker $ sudo ln -s /usr/bin/node /usr/bin/nodejs
    ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
    markus@rpi:/opt/iobroker $ dmesg -T | grep -i ext4
    [Fr Sep 16 19:47:41 2022] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:640x480M@60 smsc95xx.macaddr=DC:A6:32:28:5E:37 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=/dev/sdb1 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait nosplash plymouth.ignore-serial-consoles
    [Fr Sep 16 19:47:50 2022] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Fr Sep 16 19:47:50 2022] VFS: Mounted root (ext4 filesystem) readonly on device 8:17.
    [Fr Sep 16 19:47:59 2022] EXT4-fs (sdb1): re-mounted. Opts: (null). Quota mode: none.
    markus@rpi:/opt/iobroker $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    armv7l
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v16.17.0
    v16.17.0
    8.15.0
    4.0.23
    markus
    markus adm cdrom sudo audio video plugdev games users input netdev gpio iobroker
    /opt/iobroker
    OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
    OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
    OK:4 https://dl.yarnpkg.com/debian stable InRelease
    Aktualisierung für 24 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
    nodejs:
      Installiert:           16.17.0-deb-1nodesource1
      Installationskandidat: 16.17.0-deb-1nodesource1
      Versionstabelle:
     *** 16.17.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
         12.22.12~dfsg-1~deb11u1 500
    @funkytown
    sudo apt update
    sudo apt full-upgrade
    iobroker stop
    sudo reboot
    funkytownF 2 Antworten Letzte Antwort
      @funkytown
      sudo apt update
      iobroker stop
      sudo reboot
      funkytownF Offline
      funkytownF Offline
      funkytown
      schrieb am zuletzt editiert von funkytown
      @thomas-braun sagte in iobroker restore 0 funktioniert nicht:
      markus@rpi:~ $ sudo apt update
      [sudo] Passwort für markus:
      OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
      OK:3 https://dl.yarnpkg.com/debian stable InRelease
      OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
      Aktualisierung für 13 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
      markus@rpi:~ $ sudo apt full-upgrade
      Paketaktualisierung (Upgrade) wird berechnet… Fertig
      Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
        alsa-base gstreamer0.10-alsa gstreamer0.10-plugins-base libbluetooth3 libcdio18 libgstreamer-plugins-base0.10-0
        libgstreamer0.10-0 libnfs12 libxfconf-0-2 lxplug-volume pimixer point-rpi
      Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
      Die folgenden Pakete werden ENTFERNT:
        bluealsa fuse libgc1c2 libpolkit-backend-1-0 raspberrypi-artwork
      Die folgenden NEUEN Pakete werden installiert:
        agnostics cups-pk-helper fio flashrom fuse3 gir1.2-notify-0.7 gir1.2-packagekitglib-1.0 gir1.2-polkit-1.0 gir1.2-secret-1
        gui-pkinst ibverbs-providers libaio1 libboost-iostreams1.74.0 libboost-thread1.74.0 libcupsimage2 libftdi1-2 libfuse3-3 libgc1
        libgfapi0 libgfrpc0 libgfxdr0 libglusterfs0 libibverbs1 libnma-common libnma0 libnuma1 librados2 librbd1 librdmacm1
        lxplug-magnifier lxplug-menu lxplug-netman lxplug-updater lxplug-volumepulse pi-printer-support pixflat-icons
        printer-driver-escpr pulseaudio-module-bluetooth python3-cups python3-cupshelpers python3-smbc python3-toml rp-bookshelf
        rpi-eeprom system-config-printer system-config-printer-common system-config-printer-udev
        guile-2.2-libs gvfs gvfs-backends gvfs-common gvfs-daemons gvfs-fuse gvfs-libs libpolkit-agent-1-0 libpolkit-gobject-1-0
        policykit-1 raspberrypi-sys-mods raspberrypi-ui-mods raspi-config
      13 aktualisiert, 47 neu installiert, 5 zu entfernen und 0 nicht aktualisiert.
      Es müssen 31,3 MB an Archiven heruntergeladen werden.
      Nach dieser Operation werden 78,8 MB Plattenplatz zusätzlich benutzt.
      Möchten Sie fortfahren? [J/n] J
      Holen:1 http://archive.raspberrypi.org/debian bullseye/main armhf policykit-1 armhf 0.105-31+rpt1+deb11u1 [91,5 kB]
      Es wurde alles ohne Fehler installiert
      Jetzt komme ich nach dem reboot mit meinem SSH Client nicht mehr auf den PI.
      Ich melde mich wieder wenn der PI korrekt hochgefahren ist.
      Synology DS218+, Homatic CCU3, FritzBox 7590, Raspberry Pi
        @funkytown
        Und schalte den Desktop an der Kiste aus. Da ist ja der ganze GUI-Quatsch drauf.
        funkytownF 1 Antwort Letzte Antwort
          @funkytown
          funkytownF Offline
          funkytownF Offline
          funkytown
          Bin noch nicht dazu gekommen den PI flott zu machen.
          Das gute daran ist, dass ich/wir jetzt erkennen, dass wir im Haus nicht vom ioBroker abhängig sind. Wir senden meistens (Status)Informationen in Wort und Bild hin und her. Das was wir über Sprachsteuerung im Haus darüber schalten, kann auch alles manuell geschaltet werden :-) Gute Erkenntnis!
            @funkytown
            sudo apt update
            iobroker stop
            sudo reboot
            funkytownF Offline
            funkytownF Offline
            funkytown
            mein RPi läuft wieder. Durch den reboot wurde eine falsche UUID in der cmdline.txt eingetragen.
            Leider ist der ioBroker immer noch nicht da!
              @funkytown
              Leider kann man da ohne Meldungen immer noch nichts zu sagen.
              Welche UUID war es denn? Die werden ja nicht gewürfelt...
                @funkytown
                funkytownF Offline
                funkytownF Offline
                funkytown
                also jetzt blicke ich da garnicht mehr durch. Ich bin jetzt an via ssh an dem betroffenen System angemeldet und die cmdline.txt und fstab schaut jetzt so aus. Wo ist mein Eintrag geblieben. Mir scheint als ob ich in einer anderen Baumstruktur also einem anderen /etc/boot bin.
                markus@rpi:/boot $ cat cmdline.txt
                dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=/dev/sdb1 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait nosplash plymouth.ignore-serial-consoles
                markus@rpi:/boot $ cat /etc/fstab
                proc            /proc           proc    defaults          0       0
                PARTUUID=02211fe5-01  /boot           vfat    defaults,flush    0       2
                #PARTUUID=924c1207-02  /               ext4    defaults,noatime  0       1
                # a swapfile is not a swap partition, no line here
                #   use  dphys-swapfile swap[on|off]  for that
                /dev/sdb1       /               ext4    defaults,noatime  0       1
                /dev/sdb2       swap            swap    defaults          0       0
                Ich bin jetzt mal für 3 Std. weg.
                  @funkytown sagte in iobroker restore 0 funktioniert nicht:
                  root=/dev/sdb1
                  Keine Ahnung was du da wie warum treibst, jedenfalls ist der Eintrag
                  root=/dev/sdb1
                  absolut atypisch. Vor allendingen sdb1
                  Für gewöhnlich wird da die UUID aus
                  blkid
                  eingetragen.
                    root=/dev/sdb1
                    root=/dev/sdb1
                    blkid
                    eingetragen.
                    funkytownF Offline
                    funkytownF Offline
                    funkytown
                    Das System läuft ja wieder nach dem full-upgrade.
                    markus@rpi:/opt/iobroker $ blkid
                    /dev/mmcblk0p1: LABEL_FATBOOT="boot" LABEL="boot" UUID="0C61-73F5" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="02211fe5-01"
                    /dev/mmcblk0p2: LABEL="rootfs" UUID="43f2d0bb-83be-464f-94d0-9a751f376c64" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="02211fe5-02"
                    /dev/sda1: LABEL="ESD-USB" UUID="5CD7-2DC8" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="292eb410-01"
                    /dev/sdb1: UUID="bbe67a8e-80a1-4c79-992c-a11ebfacecfe" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="3b18e43a-01"
                    /dev/sdb2: UUID="c25aeb0d-0033-4d60-a8a9-a914652a27c1" TYPE="swap" PARTUUID="3b18e43a-02"
                    armv7l
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    v16.17.0
                    v16.17.0
                    8.15.0
                    4.0.23
                    markus
                    markus adm cdrom sudo audio video plugdev games users input netdev lpadmin gpio iobroker
                    /opt/iobroker
                    Alle Pakete sind aktuell.
                    nodejs:
                     Versionstabelle:
                      armv7l
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v16.17.0
                      v16.17.0
                      8.15.0
                      4.0.23
                      markus
                      /opt/iobroker
                      nodejs:
                       Versionstabelle:
                      @funkytown
                      Ich würde da halt die UUID in die cmdline.txt eintragen. Dann springt dir die boot-Partition auch nicht weg.
                      Zum iobroker: Logs? Kommandozeile?
                      • funkytownF Offline
                        funkytownF Offline
                        funkytown
                        Hab den Eintrag in der cmdline.txt gemacht und rebootet.
                        Welche Logs benötigst du jetzt?
                        markus@rpi:~ $ blkid
                        markus@rpi:~ $ cat /boot/cmdline.txt
                        dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=PARTUUID=3b18e43a-01 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                          @funkytown
                          iobroker status
                          iobroker update
                          iobroker list instances
                            @funkytown
                            iobroker status
                            iobroker update
                            funkytownF Offline
                            funkytownF Offline
                            funkytown
                            markus@rpi:~ $ iobroker status
                            Objects type: jsonl
                            States  type: jsonl
                            markus@rpi:~ $ iobroker update
                            Used repository: stable
                            Adapter    "admin"        : 6.2.22   , installed 6.2.20 [Updatable]
                            Adapter    "alexa2"       : 3.19.9   , installed 3.19.7 [Updatable]
                            Adapter    "backitup"     : 2.4.12   , installed 2.4.10 [Updatable]
                            Adapter    "cloud"        : 4.2.2    , installed 4.2.2
                            Adapter    "cul"          : 2.0.2    , installed 2.0.2
                            Adapter    "discovery"    : 3.0.5    , installed 3.0.5
                            Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                            Adapter    "email"        : 1.1.3    , installed 1.1.3
                            Adapter    "history"      : 2.2.0    , installed 2.2.0
                            Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
                            Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
                            Adapter    "info"         : 1.9.19   , installed 1.9.19
                            Adapter    "iot"          : 1.11.9   , installed 1.11.8 [Updatable]
                            Adapter    "javascript"   : 6.0.3    , installed 6.0.0  [Updatable]
                            Controller "js-controller": 4.0.23   , installed 4.0.23
                            Adapter    "linux-control": 1.1.3    , installed 1.1.5
                            Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                            Adapter    "node-red"     : 4.0.0    , installed 3.3.1  [Updatable]
                            Adapter    "openweathermap": 0.3.0   , installed 0.3.0
                            Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                            Adapter    "pushover"     : 3.0.3    , installed 3.0.2  [Updatable]
                            Adapter    "radar2"       : 2.0.3    , installed 2.0.3
                            Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
                            Adapter    "synology"     : 2.1.9    , installed 2.1.9
                            Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
                            Adapter    "telegram"     : 1.14.1   , installed 1.13.0 [Updatable]
                            Adapter    "text2command" : 2.2.2    , installed 2.2.2
                            Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
                            Adapter    "trashschedule": 2.0.3    , installed 2.0.3
                            Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                            Adapter    "withings"     : 0.0.9    , installed 0.0.9
                            Adapter    "yahka"        : 0.13.1   , installed 0.13.1
                            markus@rpi:~ $ iobroker list instances
                              system.adapter.admin.0                  : admin                 : rpi                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              system.adapter.admin.1                  : admin                 : rpi                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              system.adapter.alexa2.0                 : alexa2                : rpi                                      -  enabled
                              system.adapter.alexa2.1                 : alexa2                : rpi                                      -  enabled
                            + system.adapter.backitup.0               : backitup              : rpi                                      -  enabled
                            + system.adapter.discovery.0              : discovery             : rpi                                      -  enabled
                              system.adapter.dwd.0                    : dwd                   : rpi                                      - disabled
                            + system.adapter.email.0                  : email                 : rpi                                      -  enabled
                            + system.adapter.history.0                : history               : rpi                                      -  enabled
                            + system.adapter.hm-rega.0                : hm-rega               : rpi                                      -  enabled
                            + system.adapter.hm-rpc.0                 : hm-rpc                : rpi                                      -  enabled, port: 0
                            + system.adapter.hm-rpc.1                 : hm-rpc                : rpi                                      -  enabled, port: 0
                            + system.adapter.hm-rpc.2                 : hm-rpc                : rpi                                      -  enabled, port: 0
                            + system.adapter.hm-rpc.3                 : hm-rpc                : rpi                                      -  enabled, port: 0
                              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : rpi                                      - disabled
                            + system.adapter.info.0                   : info                  : rpi                                      -  enabled
                            + system.adapter.iot.0                    : iot                   : rpi                                      -  enabled
                            + system.adapter.javascript.0             : javascript            : rpi                                      -  enabled
                            + system.adapter.linux-control.0          : linux-control         : rpi                                      -  enabled
                            + system.adapter.mqtt.0                   : mqtt                  : rpi                                      -  enabled, port: 1883, bind: 0.0.0.0
                            + system.adapter.ping.0                   : ping                  : rpi                                      -  enabled
                              system.adapter.pollenflug.0             : pollenflug            : rpi                                      - disabled
                            + system.adapter.pushover.0               : pushover              : rpi                                      -  enabled
                            + system.adapter.rpi2.0                   : rpi2                  : rpi                                      -  enabled
                            + system.adapter.scenes.0                 : scenes                : rpi                                      -  enabled
                              system.adapter.synology.0               : synology              : rpi                                      - disabled, port: 5000
                            + system.adapter.tankerkoenig.0           : tankerkoenig          : rpi                                      -  enabled
                              system.adapter.telegram.0               : telegram              : rpi                                      - disabled, port: 8443, bind: 0.0.0.0
                              system.adapter.text2command.0           : text2command          : rpi                                      - disabled
                            + system.adapter.tr-064.0                 : tr-064                : rpi                                      -  enabled
                              system.adapter.vis-material-advanced.0  : vis-material-advanced : rpi                                      - disabled
                              system.adapter.vis.0                    : vis                   : rpi                                      - disabled
                              system.adapter.web.0                    : web                   : rpi                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                              system.adapter.withings.0               : withings              : rpi                                      - disabled
                              system.adapter.yahka.0                  : yahka                 : rpi                                      - disabled
                            + system.adapter.yahka.1                  : yahka                 : rpi                                      -  enabled
                            + instance is alive
                              Objects type: jsonl
                              States  type: jsonl
                              + instance is alive
                              @funkytown
                              iobroker upgrade
                              iobroker del admin.1
                              iobroker start admin.0
                              Warum 2 Instanzen vom Admin?
                                @funkytown
                                iobroker upgrade
                                funkytownF Offline
                                funkytownF Offline
                                funkytown
                                Da stimmt schon was nicht!
                                markus@rpi:~ $ iobroker upgrade
                                This upgrade of "alexa2" will introduce the following changes:
                                -> 3.19.9:
                                Receive the correct player status again when musik is stopped
                                -> 3.19.8:
                                Add safeguard for too high intervals
                                Would you like to upgrade alexa2 from @3.19.7 to @3.19.9 now? [(y)es, (n)o]: y
                                Update alexa2 from @3.19.7 to @3.19.9
                                NPM version: 8.15.0
                                Installing iobroker.alexa2@3.19.9... (System call)
                                host.rpi Cannot install iobroker.alexa2@3.19.9: 217
                                  -> 3.19.9:
                                  -> 3.19.8:
                                  NPM version: 8.15.0
                                  @funkytown
                                  for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                                    @funkytown
                                    iobroker upgrade
                                    funkytownF Offline
                                    funkytownF Offline
                                    funkytown
                                    This upgrade of "openweathermap" will introduce the following changes:
                                    -> 0.3.0:
                                    Added new widget for vis2.0
                                    Would you like to upgrade openweathermap from @0.2.5 to @0.3.0 now? [(y)es, (n)o]: n
                                    No upgrade of "openweathermap" desired.
                                    This upgrade of "admin" will introduce the following changes:
                                    -> 6.2.22:
                                    Corrected admin4 adapter settings
                                    -> 6.2.21:
                                    Corrected small JSON config issue
                                    Would you like to upgrade admin from @6.2.20 to @6.2.22 now? [(y)es, (n)o]: y
                                    Update admin from @6.2.20 to @6.2.22
                                    host.rpi Adapter "system.adapter.admin.0" is stopped.
                                    NPM version: 8.15.0
                                    Installing iobroker.admin@6.2.22... (System call)
                                    host.rpi Cannot install iobroker.admin@6.2.22: 217
                                      -> 0.3.0:
                                      -> 6.2.22:
                                      -> 6.2.21:
                                      NPM version: 8.15.0
                                      iobroker upgrade admin --debug
                                        funkytownF Offline
                                        funkytownF Offline
                                        funkytown
                                        markus@rpi:~ $ iobroker upgrade admin --debug
                                        -> 6.2.22:
                                        -> 6.2.21:
                                        NPM version: 8.15.0
                                        npm ERR! code ENOTEMPTY
                                        npm ERR! syscall rename
                                        npm ERR! path /opt/iobroker/node_modules/addressparser
                                        npm ERR! dest /opt/iobroker/node_modules/.addressparser-qF9vtHFg
                                        npm ERR! errno -39
                                        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/addressparser' -> '/opt/iobroker/node_modules/.addressparser-qF9vtHFg'
                                        npm ERR!     /home/iobroker/.npm/_logs/2022-09-22T20_14_23_357Z-debug-0.log
                                          -> 6.2.22:
                                          -> 6.2.21:
                                          NPM version: 8.15.0
                                          npm ERR! errno -39
                                          @funkytown
                                          Nochmal
